path: root/fs/befs/datastream.c
2016-10-08befs: befs: fix style issues in datastream.cLuis de Bethencourt
Fixing the following checkpatch.pl errors: ERROR: "foo * bar" should be "foo *bar" + befs_blocknr_t blockno, befs_block_run * run); WARNING: Missing a blank line after declarations + struct buffer_head *bh; + befs_debug(sb, "---> %s length: %llu", __func__, len); WARNING: Block comments use * on subsequent lines + /* + Double indir block, plus all the indirect blocks it maps. (and other instances of these) Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Salah Triki <salah.triki@gmail.com>
2016-10-08befs: improve documentation in datastream.cLuis de Bethencourt
Convert function descriptions to kernel-doc style. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Salah Triki <salah.triki@gmail.com>
2016-10-08befs: fix typos in datastream.cLuis de Bethencourt
2016-10-08fs: befs: remove unnecessary *befs_sb variableSalah Triki
Remove *befs_sb and just call BEFS_SB(sb) directly, since the returned value by this function is only used once. Signed-off-by: Salah Triki <salah.triki@gmail.com> Acked-by: Luis de Bethencourt <luisbg@osg.samsung.com>
2016-10-08fs: befs: Remove useless calls to brelse in befs_find_brun_dblindirectSalah Triki
The calls to brelse are useless since dbl_indir_block and indir_block are NULL. Signed-off-by: Salah Triki <salah.triki@gmail.com> Acked-by: Luis de Bethencourt <luisbg@osg.samsung.com>
2016-10-08fs: befs: Remove redundant validation from befs_find_brun_directSalah Triki
The only caller of befs_find_brun_direct is befs_fblock2brun, which already validates that the block is within the range of direct blocks. So remove the duplicate validation. Signed-off-by: Salah Triki <salah.triki@gmail.com> Acked-by: Luis de Bethencourt <luisbg@osg.samsung.com>
2016-10-08befs: make consistent use of befs_error()Luis de Bethencourt
befs_error() is used in potential errors that could happen in befs to provide informational log messages. befs_debug() is silent when CONFIG_BEFS_DEBUG=no, and very verbose when switched on, which is why it is used for general debugging but not for errors. Fix a few cases where the befs debug utility usage isn't following the expected pattern. To make sure we have consistent information in the logs. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com>
2016-10-08fs: befs: replace befs_bread by sb_breadSalah Triki
Since befs_bread merely calls sb_bread, replace it by sb_bread. Link: http://lkml.kernel.org/r/1466800258-4542-1-git-send-email-salah.triki@gmail.com Signed-off-by: Salah Triki <salah.triki@gmail.com> Acked-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2016-05-23fs/befs/datastream.c:befs_find_brun_dblindirect(): remove unneeded ↵Salah Triki
initializations to NULL iaddr_array is unconditionally initialized to NULL in befs_find_brun_dblindirect(). Link: http://lkml.kernel.org/r/940def273e30ef37957fba9da6981a10fb3c9741.1462649034.git.salah.triki@acm.org Signed-off-by: Salah Triki <salah.triki@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23fs/befs/datastream.c:befs_read_lsymlink(): remove unneeded initialization to ↵Salah Triki
NULL bh is reinitialized by befs_read_datastream() so no need to init it with NULL in the beginning of befs_read_lsymlink(). Link: http://lkml.kernel.org/r/e22f279bceb8d026af048952e02ba98925b21c92.1462649034.git.salah.triki@acm.org Signed-off-by: Salah Triki <salah.triki@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23fs/befs/datastream.c:befs_read_datastream(): remove unneeded initialization ↵Salah Triki
to NULL bh is reinitialized by befs_bread_iaddr() so no need to init it with NULL in the beginning of befs_read_datastream(). Link: http://lkml.kernel.org/r/81e1f70187db34d195c8e42b1ff78be6a71c0060.1462649034.git.salah.triki@acm.org Signed-off-by: Salah Triki <salah.triki@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-10befs: constify stuff a bitAl Viro
2015-04-17befs: replace typedef befs_sb_info by structureFabian Frederick
See Documenation/CodingStyle Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/befs: kernel-doc fixesFabian Frederick
Fix some comment errors. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03BEFS: logging cleanupFabian Frederick
Summary: - all printk(KERN_foo converted to pr_foo() - add pr_fmt and remove redundant prefixes - convert befs_() to va_format (based on patch by Joe Perches) - remove non standard %Lu - use __func__ for all debugging [akpm@linux-foundation.org: fix printk warnings, reported by Fengguang] Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joe Perches <joe@perches.com> Cc: Fengguang Wu <fengguang.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-10-10[PATCH] befs: endianness annotationsAl Viro
split the data structures that exist in host- and disk-endian variants, annotate the fields of disk-endian ones, propagate changes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] befs: prepare to sanitizing headersAl Viro
pulled includes of endian.h from fs/befs/*.c to befs.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24fix typos "wich" -> "which"Uwe Zeisberger
Signed-off-by: Uwe Zeisberger <zeisberg@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
