path: root/fs/autofs4/root.c
2010-05-10autofs4-2.6.34-rc1 - fix link_count usageIan Kent
After commit 1f36f774b2 ("Switch !O_CREAT case to use of do_last()") in 2.6.34-rc1 autofs direct mounts stopped working. This is caused by current->link_count being 0 when ->follow_link() is called from do_filp_open(). I can't work out why this hasn't been seen before Als patch series. This patch removes the autofs dependence on current->link_count. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Revert "autofs4: always use lookup for lookup"Al Viro
This reverts commit 213614d583748d00967a91cacd656f417efb36ce. Alas, ->d_revalidate() can't rely on ->lookup() finishing what it's started; if d_alloc() in do_lookup() fails, we are not going to call ->lookup() at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16autofs4: always use lookup for lookupIan Kent
We need to be able to cope with the directory mutex being held during ->d_revalidate() in some cases, but not all cases, and not necessarily by us. Because we need to release the mutex when we call back to the daemon to do perform a mount we must be sure that it is us who holds the mutex so we must redirect mount requests to ->lookup() if the mutex is held. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: rename dentry to expiring in autofs4_lookup_expiring()Ian Kent
In autofs4_lookup_expiring() a declaration within the list traversal loop uses a declaration that has the same name as the function parameter. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: rename dentry to active in autofs4_lookup_active()Ian Kent
In autofs4_lookup_active() a declaration within the list traversal loop uses a declaration that has the same name as the function parameter. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: eliminate d_unhashed in path walk checksIan Kent
We unhash the dentry (in a subsequent patch) in ->d_revalidate() in order to send mount requests to ->lookup(). But then we can not rely on d_unhased() to give reliable results because it may be called at any time by any code path. The d_unhashed() function is used by __simple_empty() in the path walking callbacks but autofs mount point dentrys should have no directories at all so a list_empty() on d_subdirs should be (and is) sufficient. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: cleanup active and expire lookupIan Kent
The lookup functions for active and expiring dentrys use parameters that can be easily obtained on entry so we change the call to to take just the dentry. This makes the subsequent change, to send all lookups to ->lookup(), a bit cleaner. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: renamer unhashed to active in autofs4_lookup()Ian Kent
Rename the variable unhashed to active in autofs4_lookup() to better reflect its usage. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: use autofs_info for pending flagIan Kent
Eliminate the use of the d_lock spin lock by using the autofs super block info spin lock. This reduces the number of spin locks we use by one and makes the code for the following patch (to redirect ->d_revalidate() to ->lookup()) a little simpler. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: use helper function for need mount checkIan Kent
Define simple helper function for checking if we need to trigger a mount. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: use helper functions for expiring listIan Kent
Define some simple helper functions for adding and deleting entries on the expiring dentry list. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16autofs4: use helper functions for active list handlingIan Kent
Define some simple helper functions for adding and deleting entries on the active (and unhashed) dentry list. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Sage Weil <sage@newdream.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Yehuda Saheh <yehuda@newdream.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11switch follow_down()Al Viro
2009-04-01autofs4: fix lookup deadlockIan Kent
A deadlock can occur when user space uses a signal (autofs version 4 uses SIGCHLD for this) to effect expire completion. The order of events is: Expire process completes, but before being able to send SIGCHLD to it's parent ... Another process walks onto a different mount point and drops the directory inode semaphore prior to sending the request to the daemon as it must ... A third process does an lstat on on the expired mount point causing it to wait on expire completion (unfortunately) holding the directory semaphore. The mount request then arrives at the daemon which does an lstat and, deadlock. For some time I was concerned about releasing the directory semaphore around the expire wait in autofs4_lookup as well as for the mount call back. I finally realized that the last round of changes in this function made the expiring dentry and the lookup dentry separate and distinct so the check and possible wait can be done anywhere prior to the mount call back. This patch moves the check to just before the mount call back and inside the directory inode mutex release. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: autofs, autofs4Al Viro
2008-08-25[PATCH] fix ->llseek() for a bunch of directoriesAl Viro
2008-07-24autofs4: remove unused ioctlsIan Kent
The ioctls AUTOFS_IOC_TOGGLEREGHOST and AUTOFS_IOC_ASKREGHOST were added several years ago but what they were intended for has never been implemented (as far as I'm aware noone uses them) so remove them. Signed-off-by: Ian Kent <raven@themaw.net> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: reorganize expire pending wait function callsIan Kent
This patch re-orgnirzes the checking for and waiting on active expires and elininates redundant checks. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: fix direct mount pending expire race - correctionIan Kent
Appologies, somehow I seem to have sent an out dated version of this patch. Here is an additional patch that brings the patch up to date. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: fix direct mount pending expire raceIan Kent
For direct and offset type mounts that are covered by another mount we cannot check the AUTOFS_INF_EXPIRING flag during a path walk which leads to lookups walking into an expiring mount while it is being expired. For example, for the direct multi-mount map entry with a couple of offsets: /race/mm1 / <server1>:/<path1> /om1 <server2>:/<path2> /om2 <server1>:/<path3> an autofs trigger mount is mounted on /race/mm1 and when accessed it is over mounted and trigger mounts made for /race/mm1/om1 and /race/mm1/om2. So it isn't possible for path walks to see the expiring flag at all and they happily walk into the file system while it is expiring. When expiring these mounts follow_down() must stop at the autofs mount and all processes must block in the ->follow_link() method (except the daemon) until the expire is complete. This is done by decrementing the d_mounted field of the autofs trigger mount root dentry until the expire is completed. In ->follow_link() all processes wait on the expire and the mount following is completed for the daemon until the expire is complete. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: fix indirect mount pending expire raceIan Kent
The selection of a dentry for expiration and the setting of the AUTOFS_INF_EXPIRING flag isn't done atomically which can lead to lookups walking into an expiring mount. What happens is that an expire is initiated by the daemon and a dentry is selected for expire but, since there is no lock held between the selection and setting of the expiring flag, a process may find the flag clear and continue walking into the mount tree at the same time the daemon attempts the expire it. Signed-off-by: Ian Kent <raven@themaw.net> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: fix pending checksIan Kent
There are two cases for which a dentry that has a pending mount request does not wait for completion. One is via autofs4_revalidate() and the other via autofs4_follow_link(). In revalidate, after the mount point directory is created, but before the mount is done, the check in try_to_fill_dentry() can can fail to send the dentry to the wait queue since the dentry is positive and the lookup flags may contain only LOOKUP_FOLLOW. Although we don't trigger a mount for the LOOKUP_FOLLOW flag, if ther's one pending we might as well wait and use the mounted dentry for the lookup. In autofs4_follow_link() the dentry is not checked to see if it is pending so it may fail to call try_to_fill_dentry() and not wait for mount completion. A dentry that is pending must always be sent to the wait queue. Signed-off-by: Ian Kent <raven@themaw.net> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: cleanup redundant readir codeIan Kent
The mount triggering functionality of readdir and related functions is no longer used (and is quite broken as well). The unused portions have been removed. Signed-off-by: Ian Kent <raven@themaw.net> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: use lookup intent flags to trigger mountsIan Kent
When an open(2) call is made on an autofs mount point directory that already exists and the O_DIRECTORY flag is not used the needed mount callback to the daemon is not done. This leads to the path walk continuing resulting in a callback to the daemon with an incorrect key. open(2) is called without O_DIRECTORY by the "find" utility but this should be handled properly anyway. This happens because autofs needs to use the lookup flags to decide when to callback to the daemon to perform a mount to prevent mount storms. For example, an autofs indirect mount map that has the "browse" option will have the mount point directories are pre-created and the stat(2) call made by a color ls against each directory will cause all these directories to be mounted. It is unfortunate we need to resort to this but mount maps can be quite large. Additionally, if a user manually umounts an autofs indirect mount the directory isn't removed which also leads to this situation. To resolve this autofs needs to use the lookup intent flags to enable it to make this decision. This patch adds this check and triggers a call back if any of the lookup intent flags are set as all these calls warrant a mount attempt be requested. I know that external VFS code which uses the lookup flags is something that the VFS would like to eliminate but I have no choice as I can't see any other way to do this. A VFS dentry or inode operation callback which returns the lookup "type" (requires a definition) would be sufficient. But this change is needed now and I'm not aware of the form that coming VFS changes will take so I'm not willing to propose anything along these lines. If anyone can provide an alternate method I would be happy to use it. [akpm@linux-foundation.org: fix build for concurrent VFS changes] Signed-off-by: Ian Kent <raven@themaw.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: don't release directory mutex if called in oz_modeIan Kent
Since we now delay hashing of dentrys until the ->mkdir() call, droping and re-taking the directory mutex within the ->lookup() function when we are being called by user space is not needed. This can lead to a race when other processes are attempting to access the same directory during mount point directory creation. In this case we need to hang onto the mutex to ensure we don't get user processes trying to create a mount request for a newly created dentry after the mount point entry has already been created. This ensures that when we need to check a dentry passed to autofs4_wait(), if it is hashed, it is always the mount point dentry and not a new dentry created by another lookup during directory creation. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: fix symlink name allocationIan Kent
The length of the symlink name has been moved but it needs to be set before allocating space for it in the dentry info struct. This corrects a mistake in a recent patch. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: use look aside list for lookupsIan Kent
A while ago a patch to resolve a deadlock during directory creation was merged. This delayed the hashing of lookup dentrys until the ->mkdir() (or ->symlink()) operation completed to ensure we always went through ->lookup() instead of also having processes go through ->revalidate() so our VFS locking remained consistent. Now we are seeing a couple of side affects of that change in situations with heavy mount activity. Two cases have been identified: 1) When a mount request is triggered, due to the delayed hashing, the directory created by user space for the mount point doesn't have the DCACHE_AUTOFS_PENDING flag set. In the case of an autofs multi-mount where a tree of mount point directories are created this can lead to the path walk continuing rather than the dentry being sent to the wait queue to wait for request completion. This is because, if the pending flag isn't set, the criteria for deciding this is a mount in progress fails to hold, namely that the dentry is not a mount point and has no subdirectories. 2) A mount request dentry is initially created negative and unhashed. It remains this way until the ->mkdir() callback completes. Since it is unhashed a fresh dentry is used when the user space mount request creates the mount point directory. This leaves the original dentry negative and unhashed. But revalidate has no way to tell the VFS that the dentry has changed, other than to force another ->lookup() by returning false, which is at best wastefull and at worst not possible. This results in an -ENOENT return from the original path walk when in fact the mount succeeded. To resolve this we need to ensure that the same dentry is used in all calls to ->lookup() during the course of a mount request. This patch achieves that by adding the initial dentry to a look aside list and removes it at ->mkdir() or ->symlink() completion (or when the dentry is released), since these are the only create operations autofs4 supports. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: revert - redo lookup in ttfdIan Kent
This patch series enables the use of a single dentry for lookups prior to the dentry being hashed and so we no longer need to redo the lookup. This patch reverts the patch of commit 033790449ba9c4dcf8478a87693d33df625c23b5. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24autofs4: don't make expiring dentry negativeIan Kent
Correct the error of making a positive dentry negative after it has been instantiated. The code that makes this error attempts to re-use the dentry from a concurrent expire and mount to resolve a race and the dentry used for the lookup must be negative for mounts to trigger in the required cases. The fact is that the dentry doesn't need to be re-used because all that is needed is to preserve the flag that indicates an expire is still incomplete at the time of the mount request. This change uses the the dentry to check the flag and wait for the expire to complete then discards it instead of attempting to re-use it. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01autofs: path_{get,put}() cleanupsJan Blunck
Here are some more places where path_{get,put}() can be used instead of dput()/mntput() pair. Besides that it fixes a bug in autofs4_mount_busy() where mntput() was called before dput(). Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01autofs4: fix incorrect return from root.c:try_to_fill_dentry()Jeff Moyer
Jeff Moyer has identified a case where the autofs4 function root.c:try_to_fill_dentry() can return -EBUSY when it should return 0. Jeff's description of the way this happens is: "automount starts an expire for directory d. after the callout to the daemon, but before the rmdir, another process tries to walk into the same directory. It puts itself onto the waitq, pending the expiration. When the expire finishes, the second process is woken up. In try_to_fill_dentry, it does this check: status = d_invalidate(dentry); if (status != -EBUSY) return -EAGAIN; And status is EBUSY. The dentry still has a non-zero d_inode, and the flags do not contain LOOKUP_CONTINUE or LOOKUP_DIRECTORY So, we fall through and return -EBUSY to the caller." Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01autofs4: fix execution order race in mount request codeJeff Moyer
Jeff Moyer has identified a race in due to an execution order dependency in the autofs4 function root.c:try_to_fill_dentry(). Jeff's description of this race is: "P1 does a lookup of /mount/submount/foo. Since the VFS can't find an entry for "foo" under /mount/submount, it calls into the autofs4 kernel module to allocate a new dentry, D1. The kernel creates a new waitq for this lookup and calls the daemon to perform the mount. The daemon performs a mkdir of the "foo" directory under /mount/submount, which ends up creating a *new* dentry, D2. Then, P2 does a lookup of /mount/submount/foo. The VFS path walking logic finds a dentry in the dcache, D2, and calls the revalidate function with this. In the autofs4 revalidate code, we then trigger a mount, since the dentry is an empty directory that isn't a mountpoint, and so set DCACHE_AUTOFS_PENDING and call into the wait code to trigger the mount. The wait code finds our existing waitq entry (since it is keyed off of the directory name) and adds itself to the list of waiters. After the daemon finishes the mount, it calls back into the kernel to release the waiters. When this happens, P1 is woken up and goes about clearing the DCACHE_AUTOFS_PENDING flag, but it does this in D1! So, given that P1 in our case is a program that will immediately try to access a file under /mount/submount/foo, we end up finding the dentry D2 which still has the pending flag set, and we set out to wait for a mount *again*! So, one way to address this is to re-do the lookup at the end of try_to_fill_dentry, and to clear the pending flag on the hashed dentry. This seems a sane approach to me." And Jeff's patch does this. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29autofs4: fix sparse warning in root.cHarvey Harrison
fs/autofs4/root.c:536:23: warning: symbol 'ino' shadows an earlier one fs/autofs4/root.c:510:22: originally declared here There is no need to redeclare, we are at the end of the loop and in the next iteration of the loop, ino will be reset. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: round up the APIPavel Emelianov
The set of functions process_session, task_session, process_group and task_pgrp is confusing, as the names can be mixed with each other when looking at the code for a long time. The proposals are to * equip the functions that return the integer with _nr suffix to represent that fact, * and to make all functions work with task (not process) by making the common prefix of the same name. For monotony the routines signal_session() and set_signal_session() are replaced with task_session_nr() and set_task_session(), especially since they are only used with the explicit task->signal dereference. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22autofs4: deadlock during createIan Kent
Due to inconsistent locking in the VFS between calls to lookup and revalidate deadlock can occur in the automounter. The inconsistency is that the directory inode mutex is held for both lookup and revalidate calls when called via lookup_hash whereas it is held only for lookup during a path walk. Consequently, if the mutex is held during a call to revalidate autofs4 can't release the mutex to callback the daemon as it can't know whether it owns the mutex. This situation happens when a process tries to create a directory within an automount and a second process also tries to create the same directory between the lookup and the mkdir. Since the first process has dropped the mutex for the daemon callback, the second process takes it during revalidate leading to deadlock between the autofs daemon and the second process when the daemon tries to create the mount point directory. After spending quite a bit of time trying to resolve this on more than one occassion, using rather complex and ulgy approaches, it turns out that just delaying the hashing of the dentry until the create operation works fine. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Fix some coding-style errors in autofsSukadev Bhattiprolu
Fix coding style errors (extra spaces, long lines) in autofs and autofs4 files being modified for container/pidspace issues. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: <containers@lists.osdl.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-12[PATCH] autofs4: fix race in unhashed dentry codeJeff Mahoney
Commit f50b6f8691cae2e0064c499dd3ef3f31142987f0 introduced a race in autofs4 between autofs_lookup_unhashed() and autofs_dentry_release(). autofs_dentry_release() ends up clearing the ->dentry and ->inode members of autofs_info before removing it from the rehash list. The list is protected by the rehash lock in both functions, but since autofs_dentry_release() starts tearing the autofs_info struct down before removing it from the list, autofs_lookup_unhashed() can get a autofs_info with a NULL dentry. This patch moves the clearing of ->dentry and ->inode after the removal from the rehash list. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] autofs4: check for directory re-create in lookupIan Kent
This problem was identified and fixed some time ago by Jeff Moyer but it fell through the cracks somehow. It is possible that a user space application could remove and re-create a directory during a request. To avoid returning a failure from lookup incorrectly when our current dentry is unhashed we need to check if another positive, hashed dentry matching this one exists and if so return it instead of a fail. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] autofs4: fix another race between mount and expireIan Kent
Jeff Moyer has identified a race between mount and expire. What happens is that during an expire the situation can arise that a directory is removed and another lookup is done before the expire issues a completion status to the kernel module. In this case, since the the lookup gets a new dentry, it doesn't know that there is an expire in progress and when it posts its mount request, matches the existing expire request and waits for its completion. ENOENT is then returned to user space from lookup (as the dentry passed in is now unhashed) without having performed the mount request. The solution used here is to keep track of dentrys in this unhashed state and reuse them, if possible, in order to preserve the flags. Additionally, this infrastructure will provide the framework for the reintroduction of caching of mount fails removed earlier in development. Signed-off-by: Ian Kent <raven@themaw.net> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] autofs4: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the autofs4 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] autofs4: pending flag not cleared on mount failIan Kent
During testing I've found that the mount pending flag can be left set at exit from autofs4_lookup after a failed mount request. This shouldn't be allowed to happen and causes incorrect error returns. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] autofs4: autofs4_follow_link false negative fixIan Kent
The check for an empty directory in the autofs4_follow_link method fails occassionally due to old dentrys. We had the same problem autofs4_revalidate ages ago. I thought we wouldn't need this in autofs4_follow_link, silly me. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
