path: root/fs/aio.c
2013-12-08aio: restore locking of ioctx list on removalMateusz Guzik
Commit 36f5588905c10a8c4568a210d601fe8c3c27e0f0 "aio: refcounting cleanup" resulted in ioctx_lock not being held during ctx removal, leaving the list susceptible to corruptions. In mainline kernel the issue went away as a side effect of db446a08c23d5475e6b08c87acca79ebb20f283c "aio: convert the ioctx list to table lookup v3". Fix the problem by restoring appropriate locking. Signed-off-by: Mateusz Guzik <mguzik@redhat.com> Reported-by: Eryu Guan <eguan@redhat.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Kent Overstreet <kmo@daterainc.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-12aio: fix io_destroy() regression by using call_rcu()Kent Overstreet
There was a regression introduced by 36f5588905c1 ("aio: refcounting cleanup"), reported by Jens Axboe - the refcounting cleanup switched to using RCU in the shutdown path, but the synchronize_rcu() was done in the context of the io_destroy() syscall greatly increasing the time it could block. This patch switches it to call_rcu() and makes shutdown asynchronous (more asynchronous than it was originally; before the refcount changes io_destroy() would still wait on pending kiocbs). Note that there's a global quota on the max outstanding kiocbs, and that quota must be manipulated synchronously; otherwise io_setup() could return -EAGAIN when there isn't quota available, and userspace won't have any way of waiting until shutdown of the old kioctxs has finished (besides busy looping). So we release our quota before kioctx shutdown has finished, which should be fine since the quota never corresponded to anything real anyways. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Reported-by: Jens Axboe <axboe@kernel.dk> Tested-by: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Tested-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24aio: fix kioctx not being freed after cancellation at exit timeBenjamin LaHaise
The recent changes overhauling fs/aio.c introduced a bug that results in the kioctx not being freed when outstanding kiocbs are cancelled at exit_aio() time. Specifically, a kiocb that is cancelled has its completion events discarded by batch_complete_aio(), which then fails to wake up the process stuck in free_ioctx(). Fix this by modifying the wait_event() condition in free_ioctx() appropriately. This patch was tested with the cancel operation in the thread based code posted yesterday. [akpm@linux-foundation.org: fix build] Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Kent Overstreet <koverstreet@google.com> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Zach Brown <zab@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24aio: fix io_getevents documentationJeff Moyer
In reviewing man pages, I noticed that io_getevents is documented to update the timeout that gets passed into the library call. This doesn't happen in kernel space or in the library (even though it's documented to do so in both places). Unless there is objection, I'd like to fix the comments/docs to match the code (I will also update the man page upon consensus). Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Acked-by: Cyril Hrubis <chrubis@suse.cz> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: kill ki_retryKent Overstreet
Thanks to Zach Brown's work to rip out the retry infrastructure, we don't need this anymore - ki_retry was only called right after the kiocb was initialized. This also refactors and trims some duplicated code, as well as cleaning up the refcounting/error handling a bit. [akpm@linux-foundation.org: use fmode_t in aio_run_iocb()] [akpm@linux-foundation.org: fix file_start_write/file_end_write tests] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: kill ki_keyKent Overstreet
ki_key wasn't actually used for anything previously - it was always 0. Drop it to trim struct kiocb a bit. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: give shared kioctx fields their own cachelinesKent Overstreet
[akpm@linux-foundation.org: make reqs_active __cacheline_aligned_in_smp] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: kill struct aio_ring_infoKent Overstreet
struct aio_ring_info was kind of odd, the only place it's used is where it's embedded in struct kioctx - there's no real need for it. The next patch rearranges struct kioctx and puts various things on their own cachelines - getting rid of struct aio_ring_info now makes that reordering a bit clearer. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: kill batch allocationKent Overstreet
Previously, allocating a kiocb required touching quite a few global (well, per kioctx) cachelines... so batching up allocation to amortize those was worthwhile. But we've gotten rid of some of those, and in another couple of patches kiocb allocation won't require writing to any shared cachelines, so that means we can just rip this code out. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: change reqs_active to include unreaped completionsKent Overstreet
The aio code tries really hard to avoid having to deal with the completion ringbuffer overflowing. To do that, it has to keep track of the number of outstanding kiocbs, and the number of completions currently in the ringbuffer - and it's got to check that every time we allocate a kiocb. Ouch. But - we can improve this quite a bit if we just change reqs_active to mean "number of outstanding requests and unreaped completions" - that means kiocb allocation doesn't have to look at the ringbuffer, which is a fairly significant win. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: use cancellation list lazilyKent Overstreet
Cancelling kiocbs requires adding them to a per kioctx linked list, which is one of the few things we need to take the kioctx lock for in the fast path. But most kiocbs can't be cancelled - so if we just do this lazily, we can avoid quite a bit of locking overhead. While we're at it, instead of using a flag bit switch to using ki_cancel itself to indicate that a kiocb has been cancelled/completed. This lets us get rid of ki_flags entirely. [akpm@linux-foundation.org: remove buggy BUG()] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: use flush_dcache_page()Kent Overstreet
This wasn't causing problems before because it's not needed on x86, but it is needed on other architectures. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: make aio_read_evt() more efficient, convert to hrtimersKent Overstreet
Previously, aio_read_event() pulled a single completion off the ringbuffer at a time, locking and unlocking each time. Change it to pull off as many events as it can at a time, and copy them directly to userspace. This also fixes a bug where if copying the event to userspace failed, we'd lose the event. Also convert it to wait_event_interruptible_hrtimeout(), which simplifies it quite a bit. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: refcounting cleanupKent Overstreet
The usage of ctx->dead was fubar - it makes no sense to explicitly check it all over the place, especially when we're already using RCU. Now, ctx->dead only indicates whether we've dropped the initial refcount. The new teardown sequence is: set ctx->dead hlist_del_rcu(); synchronize_rcu(); Now we know no system calls can take a new ref, and it's safe to drop the initial ref: put_ioctx(); We also need to ensure there are no more outstanding kiocbs. This was done incorrectly - it was being done in kill_ctx(), and before dropping the initial refcount. At this point, other syscalls may still be submitting kiocbs! Now, we cancel and wait for outstanding kiocbs in free_ioctx(), after kioctx->users has dropped to 0 and we know no more iocbs could be submitted. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: make aio_put_req() locklessKent Overstreet
Freeing a kiocb needed to touch the kioctx for three things: * Pull it off the reqs_active list * Decrementing reqs_active * Issuing a wakeup, if the kioctx was in the process of being freed. This patch moves these to aio_complete(), for a couple reasons: * aio_complete() already has to issue the wakeup, so if we drop the kioctx refcount before aio_complete does its wakeup we don't have to do it twice. * aio_complete currently has to take the kioctx lock, so it makes sense for it to pull the kiocb off the reqs_active list too. * A later patch is going to change reqs_active to include unreaped completions - this will mean allocating a kiocb doesn't have to look at the ringbuffer. So taking the decrement of reqs_active out of kiocb_free() is useful prep work for that patch. This doesn't really affect cancellation, since existing (usb) code that implements a cancel function still calls aio_complete() - we just have to make sure that aio_complete does the necessary teardown for cancelled kiocbs. It does affect code paths where we free kiocbs that were never submitted; they need to decrement reqs_active and pull the kiocb off the reqs_active list. This occurs in two places: kiocb_batch_free(), which is going away in a later patch, and the error path in io_submit_one. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: do fget() after aio_get_req()Kent Overstreet
aio_get_req() will fail if we have the maximum number of requests outstanding, which depending on the application may not be uncommon. So avoid doing an unnecessary fget(). Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: dprintk() -> pr_debug()Kent Overstreet
Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: move private stuff out of aio.hKent Overstreet
2013-05-07aio: add kiocb_cancel()Kent Overstreet
Minor refactoring, to get rid of some duplicated code [akpm@linux-foundation.org: fix warning] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: kill return value of aio_complete()Kent Overstreet
Nothing used the return value, and it probably wasn't possible to use it safely for the locked versions (aio_complete(), aio_put_req()). Just kill it. Signed-off-by: Kent Overstreet <koverstreet@google.com> Acked-by: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: remove retry-based AIOZach Brown
This removes the retry-based AIO infrastructure now that nothing in tree is using it. We want to remove retry-based AIO because it is fundemantally unsafe. It retries IO submission from a kernel thread that has only assumed the mm of the submitting task. All other task_struct references in the IO submission path will see the kernel thread, not the submitting task. This design flaw means that nothing of any meaningful complexity can use retry-based AIO. This removes all the code and data associated with the retry machinery. The most significant benefit of this is the removal of the locking around the unused run list in the submission path. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Signed-off-by: Zach Brown <zab@redhat.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-26aio: fix possible invalid memory access when DEBUG is enabledZhao Hongjiang
dprintk() shouldn't access @ring after it's unmapped. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-09lift sb_start_write/sb_end_write out of ->aio_write()Al Viro
2013-03-03make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protectAl Viro
... and switch i386 to HAVE_SYSCALL_WRAPPERS, killing open-coded uses of asmlinkage_protect() in a bunch of syscalls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: make do_mmap_pgoff return populate as a size in bytes, not as a boolMichel Lespinasse
do_mmap_pgoff() rounds up the desired size to the next PAGE_SIZE multiple, however there was no equivalent code in mm_populate(), which caused issues. This could be fixed by introduced the same rounding in mm_populate(), however I think it's preferable to make do_mmap_pgoff() return populate as a size rather than as a boolean, so we don't have to duplicate the size rounding logic in mm_populate(). Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Greg Ungerer <gregungerer@westnet.com.au> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm: introduce mm_populate() for populating new vmasMichel Lespinasse
When creating new mappings using the MAP_POPULATE / MAP_LOCKED flags (or with MCL_FUTURE in effect), we want to populate the pages within the newly created vmas. This may take a while as we may have to read pages from disk, so ideally we want to do this outside of the write-locked mmap_sem region. This change introduces mm_populate(), which is used to defer populating such mappings until after the mmap_sem write lock has been released. This is implemented as a generalization of the former do_mlock_pages(), which accomplished the same task but was using during mlock() / mlockall(). Signed-off-by: Michel Lespinasse <walken@google.com> Reported-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Andy Lutomirski <luto@amacapital.net> Cc: Greg Ungerer <gregungerer@westnet.com.au> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-22aio: now fput() is OK from interrupt context; get rid of manual delayed __fput()Al Viro
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-06-01switch aio and shm to do_mmap_pgoff(), make do_mmap() staticAl Viro
after all, 0 bytes and 0 pages is the same thing... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-31aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()Christopher Yeoh
A cleanup of rw_copy_check_uvector and compat_rw_copy_check_uvector after changes made to support CMA in an earlier patch. Rather than having an additional check_access parameter to these functions, the first paramater type is overloaded to allow the caller to specify CHECK_IOVEC_ONLY which means check that the contents of the iovec are valid, but do not check the memory that they point to. This is used by process_vm_readv/writev where we need to validate that a iovec passed to the syscall is valid but do not want to check the memory that it points to at this point because it refers to an address space in another process. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-21vfs: make AIO use the proper rw_verify_area() area helpersLinus Torvalds
We had for some reason overlooked the AIO interface, and it didn't use the proper rw_verify_area() helper function that checks (for example) mandatory locking on the file, and that the size of the access doesn't cause us to overflow the provided offset limits etc. Instead, AIO did just the security_file_permission() thing (that rw_verify_area() also does) directly. This fixes it to do all the proper helper functions, which not only means that now mandatory file locking works with AIO too, we can actually remove lines of code. Reported-by: Manish Honap <manish_honap_vit@yahoo.co.in> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-21kill mm argument of vm_munmap()Al Viro
it's always current->mm Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-21aio: don't bother with unmapping when aio_free_ring() is coming from exit_aio()Al Viro
... since exit_mmap() is coming and it will munmap() everything anyway. In all other cases aio_free_ring() has ctx->mm == current->mm; moreover, all other callers of vm_munmap() have mm == current->mm, so this will allow us to get rid of mm argument of vm_munmap(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-20VM: add "vm_munmap()" helper functionLinus Torvalds
Like the vm_brk() function, this is the same as "do_munmap()", except it does the VM locking for the caller. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-31aio: take final put_ioctx() into callers of io_destroy()Al Viro
2012-03-31aio: merge aio_cancel_all() with wait_for_all_aios()Al Viro
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20aio: fix the comment in aio_kick_handler()Al Viro
It should've been changed when queue_work() became queue_delayed_work(..., 0) in there. It's always had been about not needing a delay, not about not using specific function... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20aio: don't bother with cancel_delayed_work() in exit_aio()Al Viro
__put_ioctx() will cover it anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20aio: use cancel_delayed_work_sync()Al Viro
2012-03-20aio: aio_nr_lock is taken only synchronously nowAl Viro
2012-03-20aio: aio_nr decrements don't need to be delayedAl Viro
we can do that right in __put_ioctx(); as the result, the loop in ioctx_alloc() can be killed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20aio: don't bother with async freeing on failure in ioctx_alloc()Al Viro
2012-03-20fs: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-09aio: fix the "too late munmap()" raceAl Viro
Current code has put_ioctx() called asynchronously from aio_fput_routine(); that's done *after* we have killed the request that used to pin ioctx, so there's nothing to stop io_destroy() waiting in wait_for_all_aios() from progressing. As the result, we can end up with async call of put_ioctx() being the last one and possibly happening during exit_mmap() or elf_core_dump(), neither of which expects stray munmap() being done to them... We do need to prevent _freeing_ ioctx until aio_fput_routine() is done with that, but that's all we care about - neither io_destroy() nor exit_aio() will progress past wait_for_all_aios() until aio_fput_routine() does really_put_req(), so the ioctx teardown won't be done until then and we don't care about the contents of ioctx past that point. Since actual freeing of these suckers is RCU-delayed, we don't need to bump ioctx refcount when request goes into list for async removal. All we need is rcu_read_lock held just over the ->ctx_lock-protected area in aio_fput_routine(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-09aio: fix io_setup/io_destroy raceAl Viro
Have ioctx_alloc() return an extra reference, so that caller would drop it on success and not bother with re-grabbing it on failure exit. The current code is obviously broken - io_destroy() from another thread that managed to guess the address io_setup() would've returned would free ioctx right under us; gets especially interesting if aio_context_t * we pass to io_setup() points to PROT_READ mapping, so put_user() fails and we end up doing io_destroy() on kioctx another thread has just got freed... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
