path: root/fs/afs/rxrpc.c
2007-07-20AFS: Use patched rxrpc_kernel_send_data() correctlyDavid Howells
Fix afs_send_simple_reply() to accept a greater-than-zero return value from rxrpc_kernel_send_data() as being a successful return rather than thinking it an error and aborting the call. rxrpc_kernel_send_data() previously returned zero incorrectly when it worked successfully, but has been patched to return the number of bytes it transmitted. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AFS: further write support fixesDavid Howells
Further fixes for AFS write support: (1) The afs_send_pages() outer loop must do an extra iteration if it ends with 'first == last' because 'last' is inclusive in the page set otherwise it fails to send the last page and complete the RxRPC op under some circumstances. (2) Similarly, the outer loop in afs_pages_written_back() must also do an extra iteration if it ends with 'first == last', otherwise it fails to clear PG_writeback on the last page under some circumstances. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: implement basic file write supportDavid Howells
Implement support for writing to regular AFS files, including: (1) write (2) truncate (3) fsync, fdatasync (4) chmod, chown, chgrp, utime. AFS writeback attempts to batch writes into as chunks as large as it can manage up to the point that it writes back 65535 pages in one chunk or it meets a locked page. Furthermore, if a page has been written to using a particular key, then should another write to that page use some other key, the first write will be flushed before the second is allowed to take place. If the first write fails due to a security error, then the page will be scrapped and reread before the second write takes place. If a page is dirty and the callback on it is broken by the server, then the dirty data is not discarded (same behaviour as NFS). Shared-writable mappings are not supported by this patch. [akpm@linux-foundation.org: fix a bunch of warnings] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27[AF_RXRPC/AFS]: Arch-specific fixes.David Howells
Fixes for various arch compilation problems: (*) Missing module exports. (*) Variable name collision when rxkad and af_rxrpc both built in (rxrpc_debug). (*) Large constant representation problem (AFS_UUID_TO_UNIX_TIME). (*) Configuration dependencies. (*) printk() format warnings. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add support for the CB.GetCapabilities operation.David Howells
Add support for the CB.GetCapabilities operation with which the fileserver can ask the client for the following information: (1) The list of network interfaces it has available as IPv4 address + netmask plus the MTUs. (2) The client's UUID. (3) The extended capabilities of the client, for which the only current one is unified error mapping (abort code interpretation). To support this, the patch adds the following routines to AFS: (1) A function to iterate through all the network interfaces using RTNETLINK to extract IPv4 addresses and MTUs. (2) A function to iterate through all the network interfaces using RTNETLINK to pull out the MAC address of the lowest index interface to use in UUID construction. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add security support.David Howells
Add security support to the AFS filesystem. Kerberos IV tickets are added as RxRPC keys are added to the session keyring with the klog program. open() and other VFS operations then find this ticket with request_key() and either use it immediately (eg: mkdir, unlink) or attach it to a file descriptor (open). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
