path: root/fs/afs/fsclient.c
2012-03-20afs: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-06-16AFS: Use i_generation not i_version for the vnode uniquifierDavid Howells
Store the AFS vnode uniquifier in the i_generation field, not the i_version field of the inode struct. i_version can then be given the AFS data version number. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2007-07-16AFS: implement file lockingDavid Howells
Implement file locking for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11AFS: implement statfsDavid Howells
Implement the statfs() op for AFS. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AFS: write support fixesDavid Howells
AFS write support fixes: (1) Support large files using the 64-bit file access operations if available on the server. (2) Use kmap_atomic() rather than kmap() in afs_prepare_page(). (3) Don't do stuff in afs_writepage() that's done by the caller. [akpm@linux-foundation.org: fix right shift count >= width of type] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: implement basic file write supportDavid Howells
Implement support for writing to regular AFS files, including: (1) write (2) truncate (3) fsync, fdatasync (4) chmod, chown, chgrp, utime. AFS writeback attempts to batch writes into as chunks as large as it can manage up to the point that it writes back 65535 pages in one chunk or it meets a locked page. Furthermore, if a page has been written to using a particular key, then should another write to that page use some other key, the first write will be flushed before the second is allowed to take place. If the first write fails due to a security error, then the page will be scrapped and reread before the second write takes place. If a page is dirty and the callback on it is broken by the server, then the dirty data is not discarded (same behaviour as NFS). Shared-writable mappings are not supported by this patch. [akpm@linux-foundation.org: fix a bunch of warnings] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: AFS fixupsDavid Howells
Make some miscellaneous changes to the AFS filesystem: (1) Assert RCU barriers on module exit to make sure RCU has finished with callbacks in this module. (2) Correctly handle the AFS server returning a zero-length read. (3) Split out data zapping calls into one function (afs_zap_data). (4) Rename some afs_file_*() functions to afs_*() where they apply to non-regular files too. (5) Be consistent about the presentation of volume ID:vnode ID in debugging output. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03[AFS/AF_RXRPC]: Miscellaneous fixes.David Howells
Make miscellaneous fixes to AFS and AF_RXRPC: (*) Make AF_RXRPC select KEYS rather than RXKAD or AFS_FS in Kconfig. (*) Don't use FS_BINARY_MOUNTDATA. (*) Remove a done 'TODO' item in a comemnt on afs_get_sb(). (*) Don't pass a void * as the page pointer argument of kmap_atomic() as this breaks on m68k. Patch from Geert Uytterhoeven <geert@linux-m68k.org>. (*) Use match_*() functions rather than doing my own parsing. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Fix u64 printing in debug logging.David S. Miller
Need 'unsigned long long' casts to quiet warnings on 64-bit platforms when using %ll on a u64. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add "directory write" support.David Howells
Add support for the create, link, symlink, unlink, mkdir, rmdir and rename VFS operations to the in-kernel AFS filesystem. Also: (1) Fix dentry and inode revalidation. d_revalidate should only look at state of the dentry. Revalidation of the contents of an inode pointed to by a dentry is now separate. (2) Fix afs_lookup() to hash negative dentries as well as positive ones. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add security support.David Howells
Add security support to the AFS filesystem. Kerberos IV tickets are added as RxRPC keys are added to the session keyring with the klog program. open() and other VFS operations then find this ticket with request_key() and either use it immediately (eg: mkdir, unlink) or attach it to a file descriptor (open). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Clean up the AFS sourcesDavid Howells
Clean up the AFS sources. Also remove references to AFS keys. RxRPC keys are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
