znet was including "wireless/i82593.h" (which is a bit wierd), and I
missed that when I relocated i82593.h to drivers/staging/wavelan. Since
I don't have ISA turned-on in my normal .config, I didn't see the build
failures -- mea culpa!
As a holdover from earlier code when we used to set
the power limit to '0' after a reset to configure the
default transmit power, ath5k interprets txpower=0 as
12.5 dBm. Fix that by just passing 0 through.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=14567
Cc: stable@kernel.org
Reported-by: Daniel Folkers <daniel.folkers@task24.nl>
Tested-by: Daniel Folkers <daniel.folkers@task24.nl>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
rndis_wlan didn't know about NL80211_AUTHTYPE_AUTOMATIC and simple
setup with 'iwconfig wlan essid no-encrypt' would fail (ENOSUPP).
v2: use NDIS_80211_AUTH_AUTO_SWITCH instead of _OPEN.
This will make device try shared key auth first, then open.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Please be gentle, I'm a fs developer and this is my first foray into drivers, as
I'm tired of building ralinks driver everytime I update my kernel. Whenever I
load the rt2800pci driver my box bogs down, and a few printk's later I
discovered its because I was getting 10's of thousands of TBTT interrupts a
second. I discovered this was because we were setting the beacon timer to 0,
which is apparently what TBTT keys off of. It seems to me that we should only
be enabling TBTT when we are in a beacon transmitting mode, which from what I
can tell is in AD-HOC and other such modes where the mac80211 layer would have
given us a proper beacon_int to set the beacon timer to instead of 0. So this
is my fix, only enable TBTT if our sync mode is for beacon. This makes it so my
box doesn't die everytime I load the rt2800pci driver. Let me know if this is
acceptable, I just learned all these terms about 15 minutes ago via wikipedia,
so I really am not familiar with how this stuff is supposed to work. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
This patch fixes a regression introduced in
"ath9k: avoid the copy skb->cb on every RX'd skb"
With that change, the rx status in skb->cb was left uninitialized
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Current tree hits a BUG_ON in rt2x00_regbusy_read, because the eFuse EEPROM
reading code of rt2800lib uses the function without the csr_mutex locked.
Fix this by locking the csr_mutex for the of the EEPROM reading cycly and
using the _lock variants of the register reading and writing functions.
This also introcudes the register_read_lock function pointer in the
rt2800_ops structure.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Some drivers (rt2800* most notably) cannot set the RF and RT chipset in
the correct order to have the information logging in rt2x00_set_chip
be correct.
Fix this by decoupling the setting of the chipset information from the
logging of the chipset information so that drivers can determine
themselves when all information is set.
Ensure RF302x and RF2020 chipsets are handled properly in rt2800lib
for the rt3090 chipset.
Mirror the legacy Ralink driver with respect to rt2800 RF register
programming. Execute rt2800_config_channel_rt3x for all RF2020,
RF3020, RF3021 & RF3022 chipsets when operating on RT3070 devices.
fix some typos and punctuation in comments
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
[bart: ported the change from the older patch for rt2800usb & rt61pci]
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
The bit value of AR_GPIO_INPUT_EN_VAL_BT_PRIORITY_BB is wrong, it should
be 0x400 and the number of bits to be right shifted is 10. Having this
wrong value in 0x4054 sometimes affects bt quality on btcoex environment.
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
Allow rt2800usb to properly detect RT307X based devices, and set the appropriate chipset values.
Signed-off-by: Gertjan van Wingede <gwingerde@gmail.com>
Fix a type in rt2800_config_channel_rt3x. The second write to RF
register 2 should be to RF register 3. This is confirmed by the
legacy Ralink code.
For my Linksys WUSB11 at76c503-i3861 device, scanning fails without
probe_delay, min_channel_time, and max_channel_time specified for the
scan request. These values were found by checking scan requests from
the at76_usb driver.
Signed-off-by: Jason Andryuk <jandryuk@gmail.com>
Acked-by: Kalle Valo <kalle.valo@iki.fi>
As mentioned on the linux-wireless mailing list, the current copyright
statements in the rt2x00 are meaningless, as the rt2x00 project is
not even a formal legal entity. Therefore it is better to replace
the existing copyright statements with copyright statements for the
people that actually wrote the code.
Note: Updated to the best of my knowledge with respect to who
contributed considerable amounts of code.
CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Link tuning code from the legacy rt2570 driver turned out to be
harmful and got disabled by the commit d06193f ("rt2x00: Disable
link tuning in rt2500usb") in August 2008.
There is no reason to keep this dead code any longer so remove it
(it can still be retrieved from the git history if necessary).
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
It is needed for at least RT3070 chip.
eFuse EEPROM is used also by USB chips (i.e. RT3070)
so move the needed code from rt2800pci to rt2800lib.
Rename RXD_W0_* defines to RXINFO_W0_* ones to match naming
used for TX descriptor and by the vendor driver.
Add rf_vals tables and rt2800_probe_hw_mode() to rt2800lib.
Enclose interface specific code in rt2800[pci,usb]_probe_hw_mode()
with rt2x00_intf_is_[pci,usb]() checks.
Move hw_mode information initialization code block before
HT information initialization one to match the ordering used
by rt2800pci's rt2800pci_probe_hw_mode().
rt2800pci's rf_vals[] copy was missing values for some channels.
Add rt2800_validate_eeprom() and rt2800_init_eeprom() to rt2800lib.
* Factor out common code from rt2800[pci,usb]_validate_eeprom()
to rt2800_validate_eeprom().
* Fix interface specific comment in rt2800[pci,usb]_validate_eeprom().
* Enclose interface specific code in rt2800[pci,usb]_init_eeprom()
ieee80211_rx_status->qual has been marked deprecated.
This allows us to remove several functions and fields which
were used to calculate a reasonable value for it.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Instead of assuming that all rt3090 devices will have an eFuse EEPROM,
do as the legacy Ralink driver, and detect at run-time whether an
eFuse EEPROM is present.
Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Jumbograms are frames put together linked together through
more than one descriptor. For example ath9k_htc will use this
to send from the target a large frame split up into 2 or more
segments. The driver then would be in charge of putting the
frame back together.
When jumbograms are constructed the rx_stats->rs_more will
bet set and rx_stats->rs_status will not have any valid content
as the actual status will only be avialable at the end of
the chained descriptors.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This is now deprecated and unused within mac80211, so time
to remove it as otherwise we'd be doing some unecessary
computations for nothing.
ath9k and ath9k_htc share a lot of common hardware characteristics.
They only differ in that ath9k_htc works with a target CPU and ath9k
works directly with the hardware. ath9k_htc will do *some* things in
the firmware, but a lot of others on the host.
The common 802.11n hardware code is already shared through the ath9k_hw
module. Common helpers amongst all Atheros drivers can use the ath module,
this includes ath5k and ar9170 as users. But there is some common driver
specific helpers which are not exactly hardware code which ath9k and
ath9k_htc can share. We'll be using ath9k_common for this to avoid
bloating the ath module and the common 802.11n hardware module ath9k_hw.
We start by sharing skb pre and post processing in preparation for a hand
off to mac80211.
Use a helper for the RX skb post processing,
ath9k_rx_skb_postprocess().
This will make sharing code easier between ath9k and ath9k_htc.
And change the return value to something more obvious.
While at it flip the order, seems easier to read and also
add some better description as to why we do this check.
ath5k is using the (csz - 1) twice as ath_rxbuf_alloc() already allocates
and moves skb->data accordingly. Remove the extra (csz -1).
This will also be used by ath9k_htc.
The skb->cb (control buffer, 48 bytes) is available to the skb
upon skb allocation. You can fill it up imediately after skb
allocation. ath9k was copying onto the skb->cb the data from the
processed skb for mac80211 from a stack struct ieee80211_rx_status
structure. This is unnecessary, instead use the skb->cb for the
rx status immediately after the skb becomes available and DMA
synched.
Additionally, avoid the copy of the skb->cb also for virtual wiphys
as skb_copy() will copy over the skb->cb for us as well.
This moves all the RX processing of RSSI into a helper,
ath_rx_prepare(). ath_rx_prepare() should now be really
easy to read and follow.
This moves the qual computing into a small helper,
ath9k_compute_qual()
ath9k_process_rate() now does all the rx status processing to
read the rate the hardware passed and translate it to whatever
mac80211 wants.
Its just a distraction when reading the code, instead use the
rx_stats->rs_rate directly.
This does sanity checking on the skb and RX status descriptor
prior to processing.
No need to use the private driver structure to get to an sband.
This will make it easier to share this code with ath9k_htc.
With the sc gone we can now just pass the common structure to
ath_rx_prepare().
This can be shared between ath9k and ath9k_htc. It will also
help with sharing routine helpers on the RX path.
This will be shared between ath9k and ath9k_htc.
