path: root/drivers
2012-11-15ACPICA: Update local C library module comments for ASCII tableBob Moore
Improve the commenting of the table. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix for predefined name loop during ACPICA initializationRobert Moore
If a name cannot be created, simply continue on to the next name. Do not attempt to use the name, do not abort. With assistance from Colin Ian King. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix some typos in commentsBob Moore
No functional changes. Some small fixes within commments. Colin Ian King. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: ACPICA core: Cleanup empty lines at file start and endBob Moore
Maintenance for source code consistency. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Audit/update for ACPICA return macros and debug depth counterBob Moore
1) Ensure that all functions that use the various TRACE macros also use the appropriate ACPICA return macros. 2) Ensure that all normal return statements surround the return expression (value) with parens. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix unmerged acmacros.h divergences.Lv Zheng
The 20121018 release depends on some unmerged acmaros.h fixes. This patch includes the fixes made on acmaros.h that will not affect the generated vmlinux binary. This patch will not affect the generated vmlinux binary. This will decrease 157 lines of 20120913 divergence.diff. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix indent caused divergences.Lv Zheng
New version of "indent" program will generate different outputs that will lead to the divergences between the Linux and the ACPICA. This patch fixes such divergences caused by the "indent" program. The version of the "indent" used for this patch is "GNU indent 2.2.11". This patch will not affect the generated vmlinux binary. This will decrease 581 lines of 20120913 divergence.diff. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix AcpiSrc caused divergences.Lv Zheng
There are definitions that can been converted into new styles by the recent AcpiSrc while they remain the old styles in the Linux. This patch fixes those definitions that will be converted by the AcpiSrc. This patch will not affect the generated vmlinux binary. This will decrease 97 lines of 20120913 divergence.diff. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix divergences of definition conflicts.Lv Zheng
There are conflicts in the "acpi_device_id*" definitions between the Linux and the ACPICA. The definitions of acpi_device_id* in ACPICA have been changed to the "acpi_pnp_device_id*". This patch changes the corresponding "acpica_device_id*" definitiions in the Linux. This patch will not affect the generated vmlinx binary. This will decrease 298 lines of 20120913 divergence.diff. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix unmerged debugger divergences.Lv Zheng
Debugger improvements in ACPICA are always ignored by ACPICA Linux release. This will lead to divergences between Linux and ACPICA. This patch fixes such unmerged debugger updates. Following patches are included: 1. Fixed a couple compiler warnings for extra extern Wed, 14 Mar 2007 21:12:19 +0000 2. Cleanup for internal Reference Object. Wed, 27 Aug 2008 10:11:30 -0700 3. Debugger: Lock method args for multithread command. Fri, 24 Apr 2009 12:28:49 -0700 4. Debugger: Add max count argument for Batch command. Tue, 29 Sep 2009 12:31:58 -0700 5. Add new host interfaces for _OSI support. Thu, 5 Aug 2010 14:18:28 -0700 6. Increase debugger buffer size for method return objects. Wed, 17 Nov 2010 13:48:30 -0800 7. Debugger: Add command to display status of global handlers. Tue, 25 Jan 2011 13:47:58 -0800 8. Debugger: Split large dbcmds.c file. Wed, 26 Jan 2011 13:03:41 -0800 9. Debugger/AcpiExec: Add support to pass complex args to methods. Tue, 17 May 2011 13:33:39 -0700 10.Debugger: Add Template command to dump resource templates. Fri, 28 Oct 2011 14:18:51 -0700 11.Support for custom ACPICA build for ACPI 5.0 reduced hardware. Wed, 1 Feb 2012 13:18:17 -0800 12.Debugger: Improve command help support. Wed, 15 Feb 2012 07:59:26 -0800 13.Update ACPI_HW_DEPENDENT* macro invocations. Wed, 15 Feb 2012 08:14:08 -0800 14.Debugger: Rename function to simplify source code conversion. Wed, 13 Jun 2012 14:23:06 -0700 15.Debugger: Enhance "Tables" and "Unload" commands. Fri, 29 Jun 2012 13:10:58 -0700 16.Debugger: update prototype for AcpiDbSleep function. Fri, 17 Aug 2012 13:43:02 -0700 This patch will not affect the generated vmlinx binary. This will decrease 264 lines of 20120913 divergence.diff. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix unmerged utility divergences.Lv Zheng
Utility improvements in ACPICA are partial ignored by ACPICA Linux release. This will lead to divergences between Linux and ACPICA. This patch ports the entire "utility" into Linux and makes them igored in the compilation stage by "ACPI_FUTURE_USAGE". The following "Utility" files have been ported into the Linux: drivers/acpi/uttrack.c drivers/acpi/utcache.c drivers/acpi/utids.c This patch will not affect the generated vmlinx binary. This will decrease 274 lines of 20120913 divergence.diff. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15Cleanup of invalid ACPI name handling and repairBob Moore
Implemented a change/cleanup for the handling of invalid ACPI names. Names are now validated and repaired only when 1) entering a new name into the namespace and 2) disassembling a named AML opcode. A warning is only displayed in debug mode or when the interpreter is in "strict" mode, since some working machines do in fact contain invalid ACPI names. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Bug fixes galore, mostly in drivers as is often the case: 1) USB gadget and cdc_eem drivers need adjustments to their frame size lengths in order to handle VLANs correctly. From Ian Coolidge. 2) TIPC and several network drivers erroneously call tasklet_disable before tasklet_kill, fix from Xiaotian Feng. 3) r8169 driver needs to apply the WOL suspend quirk to more chipsets, fix from Cyril Brulebois. 4) Fix multicast filters on RTL_GIGA_MAC_VER_35 r8169 chips, from Nathan Walp. 5) FDB netlink dumps should use RTM_NEWNEIGH as the message type, not zero. From John Fastabend. 6) Fix smsc95xx tx checksum offload on big-endian, from Steve Glendinning. 7) __inet_diag_dump() needs to repsect and report the error value returned from inet_diag_lock_handler() rather than ignore it. Otherwise if an inet diag handler is not available for a particular protocol, we essentially report success instead of giving an error indication. Fix from Cyrill Gorcunov. 8) When the QFQ packet scheduler sees TSO/GSO packets it does not handle things properly, and in fact ends up corrupting it's datastructures as well as mis-schedule packets. Fix from Paolo Valente. 9) Fix oopser in skb_loop_sk(), from Eric Leblond. 10) CXGB4 passes partially uninitialized datastructures in to FW commands, fix from Vipul Pandya. 11) When we send unsolicited ipv6 neighbour advertisements, we should send them to the link-local allnodes multicast address, as per RFC4861. Fix from Hannes Frederic Sowa. 12) There is some kind of bug in the usbnet's kevent deferral mechanism, but more immediately when it triggers an uncontrolled stream of kernel messages spam the log. Rate limit the error log message triggered when this problem occurs, as sending thousands of error messages into the kernel log doesn't help matters at all, and in fact makes further diagnosis more difficult. From Steve Glendinning. 13) Fix gianfar restore from hibernation, from Wang Dongsheng. 14) The netlink message attribute sizes are wrong in the ipv6 GRE driver, it was using the size of ipv4 addresses instead of ipv6 ones :-) Fix from Nicolas Dichtel." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: gre6: fix rtnl dump messages gianfar: ethernet vanishes after restoring from hibernation usbnet: ratelimit kevent may have been dropped warnings ipv6: send unsolicited neighbour advertisements to all-nodes net: usb: cdc_eem: Fix rx skb allocation for 802.1Q VLANs usb: gadget: g_ether: fix frame size check for 802.1Q cxgb4: Fix initialization of SGE_CONTROL register isdn: Make CONFIG_ISDN depend on CONFIG_NETDEVICES cxgb4: Initialize data structures before using. af-packet: fix oops when socket is not present pkt_sched: enable QFQ to support TSO/GSO net: inet_diag -- Return error code if protocol handler is missed net: bnx2x: Fix typo in bnx2x driver smsc95xx: fix tx checksum offload for big endian rtnetlink: Use nlmsg type RTM_NEWNEIGH from dflt fdb dump ptp: update adjfreq callback description r8169: allow multicast packets on sub-8168f chipset. r8169: Fix WoL on RTL8168d/8111d. drivers/net: use tasklet_kill in device remove/close process tipc: do not use tasklet_disable before tasklet_kill
2012-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: "Several build/bug fixes for sparc, including: 1) Configuring a mix of static vs. modular sparc64 crypto modules didn't work, remove an ill-conceived attempt to only have to build the device match table for these drivers once to fix the problem. Reported by Meelis Roos. 2) Make the montgomery multiple/square and mpmul instructions actually usable in 32-bit tasks. Essentially this involves providing 32-bit userspace with a way to use a 64-bit stack when it needs to. 3) Our sparc64 atomic backoffs don't yield cpu strands properly on Niagara chips. Use pause instruction when available to achieve this, otherwise use a benign instruction we know blocks the strand for some time. 4) Wire up kcmp 5) Fix the build of various drivers by removing the unnecessary blocking of OF_GPIO when SPARC. 6) Fix unintended regression wherein of_address_to_resource stopped being provided. Fix from Andreas Larsson. 7) Fix NULL dereference in leon_handle_ext_irq(), also from Andreas Larsson." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix build with mix of modular vs. non-modular crypto drivers. sparc: Support atomic64_dec_if_positive properly. of/address: sparc: Declare of_address_to_resource() as an extern function for sparc again sparc32, leon: Check for existent irq_map entry in leon_handle_ext_irq sparc: Add sparc support for platform_get_irq() sparc: Allow OF_GPIO on sparc. qlogicpti: Fix build warning. sparc: Wire up sys_kcmp. sparc64: Improvde documentation and readability of atomic backoff code. sparc64: Use pause instruction when available. sparc64: Fix cpu strand yielding. sparc64: Make montmul/montsqr/mpmul usable in 32-bit threads.
2012-11-10Merge tag 'stable/for-linus-3.7-rc5-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen fixes from Konrad Rzeszutek Wilk: "There are three ARM compile fixes (we forgot to export certain functions and if the drivers are built as an module - we go belly-up). There is also an mismatch of irq_enter() / exit_idle() calls sequence which were fixed some time ago in other piece of codes, but failed to appear in the Xen code. Lastly a fix for to help in the field with troubleshooting in case we cannot get the appropriate parameter and also fallback code when working with very old hypervisors." Bug-fixes: - Fix compile issues on ARM. - Fix hypercall fallback code for old hypervisors. - Print out which HVM parameter failed if it fails. - Fix idle notifier call after irq_enter. * tag 'stable/for-linus-3.7-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/arm: Fix compile errors when drivers are compiled as modules (export more). xen/arm: Fix compile errors when drivers are compiled as modules. xen/generic: Disable fallback build on ARM. xen/events: fix RCU warning, or Call idle notifier after irq_enter() xen/hvm: If we fail to fetch an HVM parameter print out which flag it is. xen/hypercall: fix hypercall fallback code for very old hypervisors
2012-11-09sparc: Add sparc support for platform_get_irq()Andreas Larsson
This adds sparc support for platform_get_irq that in the normal case use platform_get_resource() to get an irq. This standard approach fails for sparc as there are no resources of type IORESOURCE_IRQ for irqs for sparc. Cross platform drivers can then use this standard platform function and work on sparc instead of having to have a special case for sparc. Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09gianfar: ethernet vanishes after restoring from hibernationWang Dongsheng
If a gianfar ethernet device is down prior to hibernating a system, it will no longer be present upon system restore. For example: ~# ifconfig eth0 down ~# echo disk > /sys/power/state <trigger a restore from hibernation> ~# ifconfig eth0 up SIOCSIFFLAGS: No such device This happens because the restore function bails out early upon finding devices that were not up at hibernation. In doing so, it never gets to the netif_device_attach call at the end of the restore function. Adding the netif_device_attach as done here also makes the gfar_restore code consistent with what is done in the gfar_resume code. Cc: Claudiu Manoil <claudiu.manoil@freescale.com> Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Claudiu Manoil <claudiu.manoil@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09usbnet: ratelimit kevent may have been dropped warningsSteve Glendinning
when something goes wrong, a flood of these messages can be generated by usbnet (thousands per second). This doesn't generally *help* the condition so this patch ratelimits the rate of their generation. There's an underlying problem in usbnet's kevent deferral mechanism which needs fixing, specifically that events *can* get dropped and not handled. This patch doesn't address this, but just mitigates fallout caused by the current implemention. Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-09Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes (again) from Dave Airlie: "dropped the ball on a vmware patch, so two more fixes for vmwgfx are here, one for hibernate issue, one for a BUG trigger." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/vmwgfx: Fix a case where the code would BUG when trying to pin GMR memory drm/vmwgfx: Fix hibernation device reset
2012-11-09Merge tag '3.7-pci-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "Power management: - PCI/PM: Fix proc config reg access for D3cold and bridge suspending - PCI/PM: Resume device before shutdown - PCI/PM: Fix deadlock when unbinding device if parent in D3cold Hotplug: - PCI/portdrv: Don't create hotplug slots unless port supports hotplug" * tag '3.7-pci-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI/portdrv: Don't create hotplug slots unless port supports hotplug PCI/PM: Fix proc config reg access for D3cold and bridge suspending PCI/PM: Resume device before shutdown PCI/PM: Fix deadlock when unbinding device if parent in D3cold
2012-11-09Merge tag 'mmc-fixes-for-3.7-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC fixes from Chris Ball: - sdhci: fix a NULL dereference at resume-time, seen on OLPC XO-4 - sdhci: fix against 3.7-rc1 for UHS modes without a vqmmc regulator - sdhci-of-esdhc: disable CMD23 on boards where it's broken - sdhci-s3c: fix against 3.7-rc1 for card detection with runtime PM - dw_mmc, omap_hsmmc: fix potential NULL derefs, compiler warnings * tag 'mmc-fixes-for-3.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: sdhci-s3c: fix the card detection in runtime-pm mmc: sdhci-s3c: use clk_prepare_enable and clk_disable_unprepare mmc: dw_mmc: constify dw_mci_idmac_ops in exynos back-end mmc: dw_mmc: fix modular build for exynos back-end mmc: sdhci: fix NULL dereference in sdhci_request() tuning mmc: sdhci: fix IS_ERR() checking of regulator_get() mmc: fix sdhci-dove probe/removal mmc: sh_mmcif: fix use after free mmc: sdhci-pci: fix 'Invalid iomem size' error message condition mmc: mxcmmc: Fix MODULE_ALIAS mmc: omap_hsmmc: fix NULL pointer dereference for dt boot mmc: omap_hsmmc: fix host reference after mmc_free_host mmc: dw_mmc: fix multiple drv_data NULL dereferences mmc: dw_mmc: enable controller interrupt before calling mmc_start_host mmc: sdhci-of-esdhc: disable CMD23 for some Freescale SoCs mmc: dw_mmc: remove _dev_info compile warning mmc: dw_mmc: convert the variable type of irq
2012-11-09drm/vmwgfx: Fix a case where the code would BUG when trying to pin GMR memoryThomas Hellstrom
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Brian Paul <brianp@vmware.com> Reviewed-by: Dmitry Torokhov <dtor@vmware.com> Cc: stable@vger.kernel.org Cc: linux-graphics-maintainer@vmware.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-11-09drm/vmwgfx: Fix hibernation device resetThomas Hellstrom
The device would not reset properly when resuming from hibernation. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Brian Paul <brianp@vmware.com> Reviewed-by: Dmitry Torokhov <dtor@vmware.com> Cc: stable@vger.kernel.org Cc: linux-graphics-maintainer@vmware.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-11-09Merge tag 'pinctrl-for-v3.7-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl fixes from Linus Walleij: - A set of SPEAr pinctrl fixes that recently arrived - A fixup for the Samsung/Exynos Kconfig deps * tag 'pinctrl-for-v3.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: samsung and exynos need to depend on OF && GPIOLIB pinctrl: SPEAr1340: Add clcd sleep mode pin configuration pinctrl: SPEAr1340: Make DDR reset & clock pads as gpio pinctrl: SPEAr1310: add register entries for enabling pad direction pinctrl: SPEAr1310: Separate out pci pins from pcie_sata pin group pinctrl: SPEAr1310: Fix value of PERIP_CFG reigster and MCIF_SEL_SHIFT pinctrl: SPEAr1310: fix clcd high resolution pin group name pinctrl: SPEAr320: Correct pad mux entries for rmii/smii pinctrl: SPEAr3xx: correct register space to configure pwm pinctrl: SPEAr: Don't update all non muxreg bits on pinctrl_disable
2012-11-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "A couple of bug fixes. I keep the fingers crossed that we now got transparent huge pages ready for prime time." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/cio: fix length calculation in idset.c s390/sclp: fix addressing mode clobber s390: Move css limits from drivers/s390/cio/ to include/asm/. s390/thp: respect page protection in pmd_none() and pmd_present() s390/mm: use pmd_large() instead of pmd_huge() s390/cio: suppress 2nd path verification during resume
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fix from Jiri Kosina: "This reverts a patch that causes regression in binding between HID devices and drivers during device unplug/replug cycle." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: hidraw: put old deallocation mechanism in place
Pull drm fixes from Dave Airlie: "Just radeon and nouveau, mostly regressions fixers, and a couple of radeon register checker fixes." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/nouveau: fix acpi edid retrieval drm/nvc0/disp: fix regression in vblank semaphore release drm/nv40/mpeg: fix context handling drm/nv40/graph: fix typo in type names drm/nv41/vm: fix typo in type name drm/radeon/si: add some missing regs to the VM reg checker drm/radeon/cayman: add some missing regs to the VM reg checker drm/radeon/dce3: switch back to old pll allocation order for discrete
2012-11-09Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio and module fixes from Rusty Russell: "YA module signing build tweak, and two cc'd to stable." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio: Don't access index after unregister. modules: don't break modules_install on external modules with no key. module: fix out-by-one error in kallsyms
2012-11-09Merge branch 'drm-nouveau-fixes' of ↵Dave Airlie
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes just some misc regression fixes and typo fixes. * 'drm-nouveau-fixes' of git://anongit.freedesktop.org/git/nouveau/linux-2.6: drm/nouveau: fix acpi edid retrieval drm/nvc0/disp: fix regression in vblank semaphore release drm/nv40/mpeg: fix context handling drm/nv40/graph: fix typo in type names drm/nv41/vm: fix typo in type name
2012-11-09virtio: Don't access index after unregister.Cornelia Huck
Virtio wants to release used indices after the corresponding virtio device has been unregistered. However, virtio does not hold an extra reference, giving up its last reference with device_unregister(), making accessing dev->index afterwards invalid. I actually saw problems when testing my (not-yet-merged) virtio-ccw code: - device_add virtio-net,id=xxx -> creates device virtio<n> with n>0 - device_del xxx -> deletes virtio<n>, but calls ida_simple_remove with an index of 0 - device_add virtio-net,id=xxx -> tries to add virtio0, which is still in use... So let's save the index we want to release before calling device_unregister(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Cc: stable@kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-11-09drm/nouveau: fix acpi edid retrievalMaarten Lankhorst
Commit c0077061e7ea accidentally inverted the logic for nouveau_acpi_edid, causing it to only show a connector as connected when the edid could not be retrieved with acpi. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-11-09drm/nvc0/disp: fix regression in vblank semaphore releaseKelly Doran
Signed-off-by: Kelly Doran <kel.p.doran@gmail.com> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-11-09drm/nv40/mpeg: fix context handlingMarcin Slusarz
It slipped in thanks to typeless API. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-11-09drm/nv40/graph: fix typo in type namesMarcin Slusarz
nv04_graph_priv / nv04_graph_chan are not defined in this context... Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-11-09drm/nv41/vm: fix typo in type nameMarcin Slusarz
It's a miracle it compiles at all - nv04_vm_priv does not exist anywhere in the tree. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2012-11-08drm/radeon/si: add some missing regs to the VM reg checkerAlex Deucher
This register is needed for streamout to work properly. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
2012-11-08drm/radeon/cayman: add some missing regs to the VM reg checkerAlex Deucher
These regs were being wronly rejected leading to rendering issues. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=56876 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
2012-11-07net: usb: cdc_eem: Fix rx skb allocation for 802.1Q VLANsIan Coolidge
cdc_eem frames might need to contain 802.1Q VLAN Ethernet frames. URB/skb sizing from usbnet will default to the hard_mtu, so account for the VLAN header by expanding that via hard_header_len Signed-off-by: Ian Coolidge <iancoolidge@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07usb: gadget: g_ether: fix frame size check for 802.1QIan Coolidge
Checking skb->len against ETH_FRAME_LEN assumes a 1514 ethernet frame size. With an 802.1Q VLAN header, ethernet frame length can now be 1518. Validate frame length against that. Signed-off-by: Ian Coolidge <iancoolidge@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07cxgb4: Fix initialization of SGE_CONTROL registerVipul Pandya
INGPADBOUNDARY_MASK is already shifted. No need to shift it again. On reloading a driver it was resulting in a bad SGE FL MTU sizes [1536, 9088] error. This only causes an issue on systems that have L1 cache size of 32B, 128B, 512B, 2048B or 4096B. Signed-off-by: Jay Hernandez <jay@chelsio.com> Signed-off-by: Vipul Pandya <vipul@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07isdn: Make CONFIG_ISDN depend on CONFIG_NETDEVICESLee Jones
It doesn't make much sense to enable ISDN services if you don't intend to connect to a network. Therefore insisting that ISDN depends on NETDEVICES seems logical. We can then remove any guards mentioning NETDEVICES inside all subordinate drivers. This also has the nice side-effect of fixing the warning below when ISDN_I4L && !CONFIG_NETDEVICES at compile time. This patch fixes: drivers/isdn/i4l/isdn_common.c: In function ‘isdn_ioctl’: drivers/isdn/i4l/isdn_common.c:1278:8: warning: unused variable ‘s’ [-Wunused-variable] Cc: Karsten Keil <isdn@linux-pingi.de> Cc: netdev@vger.kernel.org Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07cxgb4: Initialize data structures before using.Vipul Pandya
We should not assume reserve fields to be don't cares as fields may change. Clearing data structures before using. Signed-off-by: Jay Hernandez <jay@chelsio.com> Signed-off-by: Vipul Pandya <vipul@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-07mmc: sdhci-s3c: fix the card detection in runtime-pmSeungwon Jeon
If host clock is disabled, host cannot detect a card in case of using CD internal for detection. Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-07mmc: sdhci-s3c: use clk_prepare_enable and clk_disable_unprepareThomas Abraham
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare calls as required by common clock framework. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-07mmc: dw_mmc: constify dw_mci_idmac_ops in exynos back-endArnd Bergmann
The of_device_id match data is now marked as const and must not be modified. This changes the dw_mmc to mark all pointers passing the dw_mci_drv_data or dw_mci_dma_ops structures as const, and also marks the static definitions as const. drivers/mmc/host/dw_mmc-exynos.c: In function 'dw_mci_exynos_probe': drivers/mmc/host/dw_mmc-exynos.c:234:11: warning: assignment discards 'const' qualifier from pointer target type [enabled by default] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Abraham <thomas.abraham@linaro.org> Cc: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-07mmc: dw_mmc: fix modular build for exynos back-endArnd Bergmann
The MODULE_DEVICE_TABLE entry for dw_mci_exynos_match was incorrectly copied from the platform back-end, which causes this error when building the driver as a loadable module: drivers/mmc/host/dw_mmc-exynos.c: At top level: drivers/mmc/host/dw_mmc-exynos.c:226:34: error: '__mod_of_device_table' aliased to undefined symbol 'dw_mci_pltfm_match' This patch fixes the problem by just using the correct string. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Abraham <thomas.abraham@linaro.org> Cc: Will Newton <will.newton@imgtec.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-07mmc: sdhci: fix NULL dereference in sdhci_request() tuningChris Ball
Commit 473b095a72a9 ("mmc: sdhci: fix incorrect command used in tuning") introduced a NULL dereference at resume-time if an SD 3.0 host controller raises the SDHCI_NEEDS_TUNING flag while no card is inserted. Seen on an OLPC XO-4 with sdhci-pxav3, but presumably affects other controllers too. Signed-off-by: Chris Ball <cjb@laptop.org> Cc: stable <stable@vger.kernel.org> [3.3+]
2012-11-07mmc: sdhci: fix IS_ERR() checking of regulator_get()Kevin Liu
There are two problems here: The check for vmmc was printing an unnecessary pr_info() when host->vmmc is NULL. The intent of the check for vqmmc was to only remove UHS if we have a regulator that doesn't support the required voltage, but since IS_ERR() doesn't catch NULL, we were actually removing UHS modes if vqmmc isn't present at all -- since it isn't present for most users, this breaks UHS for them. This patch fixes that UHS regression in 3.7-rc1. Signed-off-by: Kevin Liu <kliu5@marvell.com> Signed-off-by: Bin Wang <binw@marvell.com> Reviewed-by: Philip Rakity <prakity@marvell.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-07mmc: fix sdhci-dove probe/removalRussell King - ARM Linux
1. Never ever publish a device in the system before it has been setup to a usable state. 2. Unregister the device _BEFORE_ taking away any resources it may be using. 3. Don't check clks against NULL. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2012-11-07mmc: sh_mmcif: fix use after freeGuennadi Liakhovetski
A recent commit "mmc: sh_mmcif: fix clock management" has introduced a use after free bug in sh_mmcif.c: in sh_mmcif_remove() the call to mmc_free_host() frees private driver data, therefore using it afterwards is a bug. Revert that hunk. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: stable@vger.kernel.org [3.6] Signed-off-by: Chris Ball <cjb@laptop.org>
