This code is no longer used now that mach-msm has been removed.
Delete it.
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Now that we are using components in omapdss, there's no need for
separate handling of dss and dispc driver init. Thus we can move the dss
and dispc init and unit func pointers to the lists we use for the other
dss submodules.
We can now also handle errors returned by the registration functions
properly: if registering a driver fails, we can stop processing and
return the error.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
omapdss kernel module contains drivers for multiple devices, one for
each DSS submodule. The probing we have at the moment is a mess, and
doesn't give us proper deferred probing nor ensure that all the devices
are probed before omapfb/omapdrm start using omapdss.
This patch solves the mess by using the component system for DSS
submodules.
The changes to all DSS submodules (dispc, dpi, dsi, hdmi4/5, rfbi, sdi,
venc) are the same: probe & remove functions are changed to bind &
unbind, and new probe & remove functions are added which call
component_add/del.
The dss_core driver (dss.c) acts as a component master. Adding and
matching the components is simple: all dss device's child devices are
added as components.
However, we do have some dependencies between the drivers. The order in
which they should be probed is reflected by the list in core.c
(dss_output_drv_reg_funcs). The drivers are registered in that order,
which causes the components to be added in that order, which makes the
components to be bound in that order. This feels a bit fragile, and we
probably should improve the code to manage binds in random order.
However, for now, this works fine.
We have a list of function pointers to dss submodule uninit functions.
It makes sense to do the uninit in the reverse order to init, but that
is not currently the case.
This patch reorders the uninit calls to be the reverse of init order.
The following patches will add component handling to omapdss, improving
the handling of deferred probing. However, at the moment we're using
quite a lot of __inits and __exits in the driver, which prevent normal
dynamic probing and removal.
This patch removes most of the uses of __init and __exit, so that we can
register drivers after module init, and so that we can unregister
drivers even if the module is built-in.
The return value of dss_init_ports() is not handled at all, causing
crashes later if the call failed.
This patch adds the error handling, and we also move the call to a
slightly earlier place to make bailing out easier.
Refactor dss probe function by extracting the setup for video plls into
a separate function. The call to this function is also moved to a
slightly earlier phase, so that in error case we can bail out more
easily.
We have a flag, 'dss_initialized', which tells omapfb and omapdrm if
omapdss is available. At the moment it can be set even if the dss
submodules are not all ready, in case something gets deferred.
Move the flag to dss_core driver so that it'll signal the availability
of the dss drivers move accurately.
For now, it'll signal that dss_core is ready, which is not quite correct
but still better than previously. The following patches will add
component system to omapdss, and after those patches 'dss_initialized'
will signal that all the submodules are ready.
fb_videomode_from_videomode() may fail, but of_get_fb_videomode()
silently covers this fact. Instead, trow the error code to the
caller.
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
This driver uses the same area for MTRR as for the ioremap_wc(), if
anything it just uses a smaller size in case MTRR reservation fails.
ioremap_wc() API is already used to take advantage of architecture
write-combining when available.
Convert the driver from using the x86 specific MTRR code to
the architecture agnostic arch_phys_wc_add(). arch_phys_wc_add()
will avoid MTRR if write-combining is available.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture specific and on
x86 its replaced by PAT
c) Help with the goal of eventually using _PAGE_CACHE_UC over
_PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
de33c442e titled "x86 PAT: fix performance drop for glx,
use UC minus for ioremap(), ioremap_nocache() and
pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the #ifdery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get
an MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Generated-by: Coccinelle SmPL
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Rob Clark <robdclark@gmail.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: linux-fbdev@vger.kernel.org
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
The MTRR added was never being deleted, in order to store the
MTRR cookie we need to make use of the private info->par so we
create a struct for this. This driver was already using the extra
space typically used for info->par for the info->pseudo_palette
which typically used stuffed on driver's own private structs
(the respective info->par), so we just move the pseudo_palette
into the private struct as well.
No other video driver uses MTRR types except for MTRR_TYPE_WRCOMB,
the other MTRR types were implemented and supported here but with
no real good reason. The ioremap() APIs are architecture agnostic and
at least on x86 PAT is a new design that extends MTRRs and
can replace it in a much cleaner way, where so long as the
proper ioremap_wc() or variant API is used the right thing will
be done behind the scenes. This is the only driver left using the
other MTRR types -- and since there is no good reason for it now
rip them out.
The platform_device_id is not modified by the driver and core uses it as
const.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
const.
Since kobject_init_and_add takes a format string, make sure that the
passed in name cannot be accidentally parsed.
Merge arch/ changes for TI's DRA7 SoC Display Subsystem.
DESHDCP clock is needed on DRA7 based SoCs to enable the DSS IP. That
clock is an odd one, as it is not supposed to be any kind of core clock
for DSS, and we don't even support HDCP, but the clock is still needed
even for the HWMOD framework to be able to reset the DSS IP.
As there's no support for multiple core clocks in the HWMOD framework,
we don't have any obvious place to enable this clock when DSS IP is
being enabled.
Furthermore, the HDMI on OMAP5 DSS is the same as on DRA7, and OMAP5
does not have any such clock configuration bit. This suggests that on
OMAP5 the DESHDCP clock is always enabled, and for DRA7 we have the
possibility to gate it.
So, as we don't have any clean way to enable and disable the clock
based on the need, this patch enables the clock at boot time, making it
work similarly to OMAP5.
Acked-by: Tero Kristo <t-kristo@ti.com>
Acked-by: Michael Turquette <mturquette@linaro.org>
There is a constraint in the OMAP4 HDMI IP that requires to use
the 8-channel code when transmitting more than two channels.
The constraint doesn't apply for OMAP5 so don't force the channel
allocation in the sound driver as it can be done specifically for
OMAP4 later in the hdmi4 core.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Acked-by: Mark Brown <broonie@kernel.org>
Downmix inhibit in HDMI_CORE_FC_AUDICONF3 register is in
bit 4 while CEA861_AUDIO_INFOFRAME_DB5_DM_INH sets bit 7.
As per TRM, HDMI_WP_AUDIO_CFG[2] LEFT_BEFORE = 0 is reserved,
so it must always be set to 1 (the first sample is the left).
OMAP4 HDMI IP uses the 8-channel layout with 8-channel speaker
allocation mask when transmitting more than two channels. But
the channel count field (CC) of the Audio InfoFrame's DB1 is
not updated for 8-channels.
As per HDMI Compliance Test 7.31 "Audio InfoFrame", CC = 7 is
required for 8-channels CA masks (0x13 and 0x1F).
Add a new Linux clock for DRA7 based SoCs to control DESHDCP clock.
Since 39b2bbe3d715 (gpio: add flags argument to gpiod_get*() functions)
which appeared in v3.17-rc1, the gpiod_get* functions take an additional
parameter that allows to specify direction and initial value for output.
Also make use of gpiod_get*_optional where applicable.
Apart from simplification of the affected drivers this is another step
towards making the flags argument to gpiod_get*() mandatory.
The driver doesn't use mtrr_add() or arch_phys_wc_add() but
since we know the framebuffer is isolated already on an
ioremap() we can take advantage of write combining for
performance where possible.
In this case there are a few motivations for this:
b) Help with the goal of eventually using _PAGE_CACHE_UC over
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: linux-geode@lists.infradead.org
Reviewed-by: Dave Airlie <airlied@redhat.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This driver uses the same area for MTRR as for the ioremap().
will avoid MTRR if write-combining is available, in order to
take advantage of that also ensure the ioremap'd area is requested
as write-combining.
an MTRR.
@ mtrr_found @
as write-combining.
an MTRR.
@ mtrr_found @
as write-combining.
an MTRR.
@ mtrr_found @
Cc: Dan Carpenter <dan.carpenter@oracle.com>
as write-combining.
an MTRR.
@ mtrr_found @
The same area used for MTRR is used for the ioremap() area.
as write-combining.
an MTRR.
@ mtrr_found @
as write-combining.
an MTRR.
@ mtrr_found @
as write-combining.
an MTRR.
@ mtrr_found @
Cc: Thomas Winischhofer <thomas@winischhofer.net>
as write-combining.
an MTRR.
@ mtrr_found @
This driver uses the same area for MTRR and ioremap().
as write-combining.
an MTRR.
@ mtrr_found @
as write-combining.
an MTRR.
@ mtrr_found @
This driver uses the same ioremap()'d area for the MTRR.
as write-combining.
an MTRR.
@ mtrr_found @
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Although this driver gives the framebuffer layer a different
size for the framebuffer it uses the entire aperture PCI BAR
size for the MTRR. Since the framebuffer is included in that
range and MTRR was used on the entire PCI BAR WC will have
been preferred on that range as well. This propagates the
WC preference on the same entire PCI BAR.
as write-combining.
an MTRR.
@ mtrr_found @
Cc: Maik Broemme <mbroemme@plusserver.de>
as write-combining.
an MTRR.
@ mtrr_found @
Cc: Masanari Iida <standby24x7@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ralf/linux
Pull MIPS fixes from Ralf Baechle:
"MIPS fixes for 4.1 all across the tree"
* 'upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/ralf/linux:
MIPS: strnlen_user.S: Fix a CPU_DADDI_WORKAROUNDS regression
MIPS: BMIPS: Fix bmips_wr_vec()
MIPS: ath79: fix build problem if CONFIG_BLK_DEV_INITRD is not set
MIPS: Fuloong 2E: Replace CONFIG_USB_ISP1760_HCD by CONFIG_USB_ISP1760
MIPS: irq: Use DECLARE_BITMAP
ttyFDC: Fix to use native endian MMIO reads
MIPS: Fix CDMM to use native endian MMIO reads
Pull SCSI target fixes from Nicholas Bellinger:
"These are mostly minor fixes, with the exception of the following that
address fall-out from recent v4.1-rc1 changes:
- regression fix related to the big fabric API registration changes
and configfs_depend_item() usage, that required cherry-picking one
of HCH's patches from for-next to address the issue for v4.1 code.
- remaining TCM-USER -v2 related changes to enforce full CDB
passthrough from Andy + Ilias.
Also included is a target_core_pscsi driver fix from Andy that
addresses a long standing issue with a Scsi_Host reference being
leaked on PSCSI device shutdown"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iser-target: Fix error path in isert_create_pi_ctx()
target: Use a PASSTHROUGH flag instead of transport_types
target: Move passthrough CDB parsing into a common function
target/user: Only support full command pass-through
target/user: Update example code for new ABI requirements
target/pscsi: Don't leak scsi_host if hba is VIRTUAL_HOST
target: Fix se_tpg_tfo->tf_subsys regression + remove tf_subsystem
target: Drop signal_pending checks after interruptible lock acquire
target: Add missing parentheses
target: Fix bidi command handling
target/user: Disallow full passthrough (pass_level=0)
ISCSI: fix minor memory leak
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
"Some late hwmon patches, all headed for -stable
- fix sysfs attribute initialization in nct6775 and nct6683 drivers
- do not attempt to auto-detect tmp435 on I2C address 0x37
- ensure iio channel is of type IIO_VOLTAGE in ntc_thermistor driver"
* tag 'hwmon-for-linus-v4.1-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (nct6683) Add missing sysfs attribute initialization
hwmon: (nct6775) Add missing sysfs attribute initialization
hwmon: (tmp401) Do not auto-detect chip on I2C address 0x37
hwmon: (ntc_thermistor) Ensure iio channel is of type IIO_VOLTAGE
We don't assign pi_ctx to desc->pi_ctx until we're certain to succeed
in the function. That means the cleanup path should use the local
pi_ctx variable, not desc->pi_ctx.
This was detected by Coverity (CID 1260062).
Signed-off-by: Roland Dreier <roland@purestorage.com>
It seems like we only care if a transport is passthrough or not. Convert
transport_type to a flags field and replace TRANSPORT_PLUGIN_* with a
flag, TRANSPORT_FLAG_PASSTHROUGH.
Signed-off-by: Andy Grover <agrover@redhat.com>
Reviewed-by: Ilias Tsitsimpis <iliastsi@arrikto.com>
Aside from whether they handle BIDI ops or not, parsing of the CDB by
kernel and user SCSI passthrough modules should be identical. Move this
into a new passthrough_parse_cdb() and call it from tcm-pscsi and tcm-user.
Reported-by: Christoph Hellwig <hch@lst.de>
After much discussion, give up on only passing a subset of SCSI commands
to userspace and pass them all. Based on what pscsi is doing, make sure
to set SCF_SCSI_DATA_CDB for I/O ops, and define attributes identical to
pscsi.
Make hw_block_size configurable via dev param.
Remove mention of command filtering from tcmu-design.txt.
See https://bugzilla.redhat.com/show_bug.cgi?id=1025672
We need to put() the reference to the scsi host that we got in
pscsi_configure_device(). In VIRTUAL_HOST mode it is associated with
the dev_virt, not the hba_virt.
Cc: stable@vger.kernel.org # 2.6.38+
There is just one configfs subsystem in the target code, so we might as
well add two helpers to reference / unreference it from the core code
instead of passing pointers to it around.
This fixes a regression introduced for v4.1-rc1 with commit 9ac8928e6,
where configfs_depend_item() callers using se_tpg_tfo->tf_subsys would
fail, because the assignment from the original target_core_subsystem[]
is no longer happening at target_register_template() time.
(Fix target_core_exit_configfs pointer dereference - Sagi)
Reported-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
The following error message is seen when loading the nct6683 driver
with DEBUG_LOCK_ALLOC enabled.
BUG: key ffff88040b2f0030 not in .data!
WARNING: CPU: 0 PID: 186 at kernel/locking/lockdep.c:2988
lockdep_init_map+0x469/0x630()
DEBUG_LOCKS_WARN_ON(1)
Caused by a missing call to sysfs_attr_init() when initializing
sysfs attributes.
Reported-by: Alexey Orishko <alexey.orishko@gmail.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Cc: stable@vger.kernel.org # v3.18+
The following error message is seen when loading the nct6775 driver
sysfs attributes.
Cc: stable@vger.kernel.org # v3.12+
