path: root/drivers
2014-02-18drm/radeon/dpm: move platform caps fetching to a separate functionAlex Deucher
It's needed by by both the asic specific functions and the extended table parser. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-18drm/radeon: add callback for setting vce clocksAlex Deucher
Similar to uvd clock setting. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-18drm/radeon: add VCE version parsing and checkingChristian König
Also make the result available to userspace. Signed-off-by: Christian König <christian.koenig@amd.com>
2014-02-18drm/radeon: add VCE ring queryChristian König
2014-02-18drm/radeon: initial VCE support v4Christian König
Only VCE 2.0 support so far. v2: squashing multiple patches into this one v3: add IRQ support for CIK, major cleanups, basic code documentation v4: remove HAINAN from chipset list Signed-off-by: Christian König <christian.koenig@amd.com>
2014-02-18drm/radeon: fix CP semaphores on CIKChristian König
The CP semaphore queue on CIK has a bug that triggers if uncompleted waits use the same address while a signal is still pending. Work around this by using different addresses for each sync. Signed-off-by: Christian König <christian.koenig@amd.com> Cc: stable@vger.kernel.org
2014-02-06drm/radeon: add missing include in btc_dpm.cAlex Deucher
Fixes a compile error with debugfs disabled. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-06drm/radeon/dpm: fix uninitialized read from stack in kv_dpm_late_enableDave Jones
If we take the false branch of the if quoted in the diff below, we end up doing a return ret, without ever having initialized it. Picked up by coverity. Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-06drm/radeon: remove useless returnAlex Deucher
2014-02-06drm/radeon/dpm: use stored max_vddc rather than looking it upAlex Deucher
When we parse the power tables use the stored mac_vddc value rather than lookig it up manually each time. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-06drm/radeon/dpm: use the driver state for dpm debugfsAlex Deucher
For btc and newer, we may modify the power state depending on the circumstances. Use the modified state rather than the base state. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-06drm/radeon: fix UVD IRQ support on 7xxAlex Deucher
Otherwise decoding isn't really useable. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-02-06drm/radeon: fix UVD IRQ support on SIChristian König
Otherwise decoding isn't really useable. bug: https://bugs.freedesktop.org/show_bug.cgi?id=71448 Signed-off-by: Christian König <christian.koenig@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-02-06drm/radeon: allow geom rings to be setup on r600/r700 (v2)Dave Airlie
the evergreen CS parser has allowed this for a while, just port the code to the r600 one. This is required before geom shaders can be made work. v2: agd5f: minor cleanup and add additional 7xx reg. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-02-06Merge tag 'vmwgfx-fixes-3.14-2014-02-05' of ↵Dave Airlie
git://people.freedesktop.org/~thomash/linux into drm-next A couple of vmwgfx fixes together with missing bits of legacy device emulation to facilitate old user-space drivers on new devices. The shader emulation bits are a bit large, but since they mostly touch the new device code, regressions are unlikely. I figure the gain of having this from the start clearly outweighs the risc of adding these bits at this point. Pull request of 2014-02-05 * tag 'vmwgfx-fixes-3.14-2014-02-05' of git://people.freedesktop.org/~thomash/linux: vmwgfx: Fix unitialized stack read in vmw_setup_otable_base drm/vmwgfx: Reemit context bindings when necessary v2 drm/vmwgfx: Detect old user-space drivers and set up legacy emulation v2 drm/vmwgfx: Emulate legacy shaders on guest-backed devices v2 drm/vmwgfx: Fix legacy surface reference size copyback drm/vmwgfx: Fix SET_SHADER_CONST emulation on guest-backed devices drm/vmwgfx: Fix regression caused by "drm/ttm: make ttm reservation calls behave like reservation calls" drm/vmwgfx: Don't commit staged bindings if execbuf fails
2014-02-06Merge tag 'ttm-fixes-3.14-2014-02-05' of ↵Dave Airlie
git://people.freedesktop.org/~thomash/linux into drm-next Two ttm regression fixes. Pull request of 2014-02-05 * tag 'ttm-fixes-3.14-2014-02-05' of git://people.freedesktop.org/~thomash/linux: drm/ttm: Don't clear page metadata of imported sg pages drm/ttm: Fix TTM object open regression
2014-02-06drm/mgag200,ast,cirrus: fix regression with drm_can_sleep conversionDave Airlie
I totally sign inverted my way out of this one. Cc: stable@vger.kernel.org Reported-by: "Sabrina Dubroca" <sd@queasysnail.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-02-05drm/ttm: Don't clear page metadata of imported sg pagesThomas Hellstrom
These page pointers shouldn't be visible to TTM in the first place, but until we fix that up, don't clear the page metadata because that will upset the exporter. Reported-and-tested-by: Cristoph Haag <haagch.christoph@googleemail.com> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/ttm: Fix TTM object open regressionThomas Hellstrom
Commit drm/ttm: ttm object security fixes for render nodes introduced a regression where, if a TTM object was opened multiple times from the same open file, the caller would spin uninterruptibly in the kernel. Fix this. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05vmwgfx: Fix unitialized stack read in vmw_setup_otable_baseDave Jones
One of the error paths in vmw_setup_otable_base causes us to return with 'ret' having never been set to anything causing us to return whatever was on the stack. Found with Coverity Signed-off-by: Dave Jones <davej@fedoraproject.org> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2014-02-05drm/vmwgfx: Reemit context bindings when necessary v2Thomas Hellstrom
When a context is first referenced in the command stream, make sure that all scrubbed (as a result of eviction) bindings are re-emitted. Also make sure that all bound resources are put on the resource validate list. This is needed for legacy emulation, since legacy user-space drivers will typically not re-emit shader bindings. It also removes the requirement for user-space drivers to re-emit render-target- and texture bindings. Makes suspend and hibernate now also work with legacy user-space drivers on guest-backed devices. v2: Don't rebind on legacy devices. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/vmwgfx: Detect old user-space drivers and set up legacy emulation v2Thomas Hellstrom
GB aware mesa userspace drivers are detected by the fact that they are calling the vmw getparam ioctl querying DRM_VMW_PARAM_HW_CAPS to detect whether the device is Guest-backed object capable. For other drivers, lie about hardware version and send the 3D capabilities in a format they expect. v2: Use DRM_VMW_PARAM_MAX_MOB_MEMORY to detect gb awareness, Make sure we don't ovwerwrite bounce buffer or write past user-space buffer indicated size. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/vmwgfx: Emulate legacy shaders on guest-backed devices v2Thomas Hellstrom
Command stream legacy shader creation and destruction is replaced by NOPs in the command stream, and instead guest-backed shaders are created and destroyed as part of the command validation process. v2: Removed some stray debug messages. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/vmwgfx: Fix legacy surface reference size copybackThomas Hellstrom
Surfaces created using the guest-backed surface interface only keeps the base mip size, so only copy that if the legacy surface reference ioctl requests the size information. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/vmwgfx: Fix SET_SHADER_CONST emulation on guest-backed devicesThomas Hellstrom
Emulate the SET_SHADER_CONST legacy command on guest-backed devices by issuing a SET_GB_SHADERCONSTS_INLINE command. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/vmwgfx: Fix regression caused by "drm/ttm: make ttm reservation calls ↵Thomas Hellstrom
behave like reservation calls" The call to ttm_eu_backoff_reservation() as part of an error path would cause a lock imbalance if the reservation ticket was not initialized. This error is easily triggered from user-space by submitting a bogus command stream. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com> Cc: stable@vger.kernel.org Cc: Maarten Lankhorst <maarten.lankhorst@canonical.com> Cc: Jerome Glisse <jglisse@redhat.com> Cc: Dave Airlie <airlied@redhat.com>
2014-02-05drm/vmwgfx: Don't commit staged bindings if execbuf failsThomas Hellstrom
If execbuf fails and binding commands are never sent to the device, don't commit the staged context bindings to the tracker. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
2014-02-05drm/mgag200: fix typo causing bw limits to be ignored on some chipsDave Airlie
mode->mdev otherwise the bw limits never kick in. Reported in RHEL testing. Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-02-02parisc/sti_console: prefer Linux fonts over built-in ROM fontsHelge Deller
The built-in ROM fonts lack many necessary ASCII characters, which is why it makes sens to prefer the Linux fonts instead if they are available. This makes consoles on STI graphics cards which are not supported by the stifb driver (e.g. Visualize FXe) looks much nicer. Signed-off-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v3.13
2014-02-02Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon kconfig fixes from Jean Delvare. * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: Fix SENSORS_TMP102 dependencies to eliminate build errors hwmon: Fix SENSORS_LM75 dependencies to eliminate build errors
2014-02-02Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's a set of patches for (hopefully) -rc1. Some of them are fixes, but a good number of them also do things such as enable new drivers in the defconfigs for platforms that have such devices, increases coverage of the multiplatform defconfig and some DTS changes that plumbs up some of the devices that now have bindings and driver support. The commit dates are recent; we've mostly collected these fixes in the last few days but I also had to rebuild the branch yesterday to sort out some internal conflicts which reset the timestamps. The changes should have been tested by each platform maintainer already (and few of them have cross-platform impact) so I'm personally not too concerned by it at this time" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: multi_v7_defconfig: remove redundant entries and re-enable TI_EDMA ARM: multi_v7_defconfig: add mvebu drivers clocksource: kona: Add basic use of external clock drivers: bus: fix CCI driver kcalloc call parameters swap ARM: dts: bcm28155-ap: Fix Card Detection GPIO ARM: multi_v7_defconfig: Select CONFIG_AT803X_PHY ARM: keystone: config: fix build warning when CONFIG_DMADEVICES is not set MAINTAINERS: ARM: SiRF: use regex patterns to involve all SiRF drivers ARM: dts: zynq: Add SDHCI nodes ARM: hisi: don't select SMP ARM: tegra: rebuild tegra_defconfig to add DEBUG_FS ARM: multi_v7: copy most options from tegra_defconfig ARM: iop32x: fix power off handling for the EM7210 board ARM: integrator: restore static map on the CP ARM: msm_defconfig: Enable MSM clock drivers ARM: dts: msm: Add clock controller nodes and hook into uart ARM: OMAP4+: move errata initialization to omap4_pm_init_early ARM: OMAP4460: cpuidle: Extend PM_OMAP4_ROM_SMP_BOOT_ERRATUM_GICD on cpuidle ARM: mvebu: fix compilation warning on Armada 370 (i.e. non-SMP) ARM: shmobile: r8a7790.dtsi: ficx i2c[0-3] clock reference ...
2014-02-02hwmon: Fix SENSORS_TMP102 dependencies to eliminate build errorsJean Delvare
Similar to what was done for the lm75 driver. Add depends on THERMAL since that is what provides the register/unregister functions above, but only if THERMAL_OF was selected as this is an optional feature of the driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Randy Dunlap <rdunlap@infradead.org> Acked-by: Eduardo Valentin <eduardo.valentin@ti.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2014-02-02hwmon: Fix SENSORS_LM75 dependencies to eliminate build errorsJean Delvare
Based on an earlier attempt by Randy Dunlap. Fix SENSORS_LM75 dependencies to eliminate build errors: drivers/built-in.o: In function `lm75_remove': lm75.c:(.text+0x12bd8c): undefined reference to `thermal_zone_of_sensor_unregister' drivers/built-in.o: In function `lm75_probe': lm75.c:(.text+0x12c123): undefined reference to `thermal_zone_of_sensor_register' Add depends on THERMAL since that is what provides the register/unregister functions above, but only if THERMAL_OF was selected as this is an optional feature of the driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Randy Dunlap <rdunlap@infradead.org> Acked-by: Eduardo Valentin <eduardo.valentin@ti.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2014-02-01Merge tag 'staging-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull rtl8812ae staging wireless driver from Greg KH: "Here's a single staging driver for a wireless chipset that has shown up in the SteamBox hardware. It is merged separately from the "main" staging pull request to sync up with the wireless api changes that came in from the networking tree. It's self-contained and works for me and others. Larry will be replacing it with a "real" driver for 3.15, but for now this one is needed" * tag 'staging-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8821ae: Enable build by reverting BROKEN marking staging: r8821ae: Fix build problems Staging: rtl8812ae: disable due to build errors Staging: rtl8821ae: add TODO file Staging: rtl8821ae: removed unused functions and variables Staging: rtl8821ae: rc.c: fix up function prototypes Staging: rtl8812ae: Add Realtek 8821 PCI WIFI driver
2014-02-01Revert "PCI: Remove from bus_list and release resources in pci_release_dev()"Rafael J. Wysocki
Revert commit ef83b0781a73 "PCI: Remove from bus_list and release resources in pci_release_dev()" that made some nasty race conditions become possible. For example, if a Thunderbolt link is unplugged and then replugged immediately, the pci_release_dev() resulting from the hot-remove code path may be racing with the hot-add code path which after that commit causes various kinds of breakage to happen (up to and including a hard crash of the whole system). Moreover, the problem that commit ef83b0781a73 attempted to address cannot happen any more after commit 8a4c5c329de7 "PCI: Check parent kobject in pci_destroy_dev()", because pci_destroy_dev() will now return immediately if it has already been executed for the given device. Note, however, that the invocation of msi_remove_pci_irq_vectors() removed by commit ef83b0781a73 from pci_free_resources() along with the other changes made by it is not added back because of subsequent code changes depending on that modification. Fixes: ef83b0781a73 (PCI: Remove from bus_list and release resources in pci_release_dev()) Reported-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-31clocksource: kona: Add basic use of external clockTim Kryger
When an clock is specified in the device tree, enable it and use it to determine the external clock frequency. Signed-off-by: Tim Kryger <tim.kryger@linaro.org> Reviewed-by: Markus Mayer <markus.mayer@linaro.org> Reviewed-by: Matt Porter <matt.porter@linaro.org> Reviewed-by: Christian Daudt <bcm@fixthebug.org> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Christian Daudt <bcm@fixthebug.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-01-31Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - add support for SCSI Referrals (Hannes) - add support for T10 DIF into target core (nab + mkp) - add support for T10 DIF emulation in FILEIO + RAMDISK backends (Sagi + nab) - add support for T10 DIF -> bio_integrity passthrough in IBLOCK backend (nab) - prep changes to iser-target for >= v3.15 T10 DIF support (Sagi) - add support for qla2xxx N_Port ID Virtualization - NPIV (Saurav + Quinn) - allow percpu_ida_alloc() to receive task state bitmask (Kent) - fix >= v3.12 iscsi-target session reset hung task regression (nab) - fix >= v3.13 percpu_ref se_lun->lun_ref_active race (nab) - fix a long-standing network portal creation race (Andy)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (51 commits) target: Fix percpu_ref_put race in transport_lun_remove_cmd target/iscsi: Fix network portal creation race target: Report bad sector in sense data for DIF errors iscsi-target: Convert gfp_t parameter to task state bitmask iscsi-target: Fix connection reset hang with percpu_ida_alloc percpu_ida: Make percpu_ida_alloc + callers accept task state bitmask iscsi-target: Pre-allocate more tags to avoid ack starvation qla2xxx: Configure NPIV fc_vport via tcm_qla2xxx_npiv_make_lport qla2xxx: Enhancements to enable NPIV support for QLOGIC ISPs with TCM/LIO. qla2xxx: Fix scsi_host leak on qlt_lport_register callback failure IB/isert: pass scatterlist instead of cmd to fast_reg_mr routine IB/isert: Move fastreg descriptor creation to a function IB/isert: Avoid frwr notation, user fastreg IB/isert: seperate connection protection domains and dma MRs tcm_loop: Enable DIF/DIX modes in SCSI host LLD target/rd: Add DIF protection into rd_execute_rw target/rd: Add support for protection SGL setup + release target/rd: Refactor rd_build_device_space + rd_release_device_space target/file: Add DIF protection support to fd_execute_rw target/file: Add DIF protection init/format support ...
2014-01-31drivers: bus: fix CCI driver kcalloc call parameters swapLorenzo Pieralisi
This patch fixes a bug/typo in the CCI driver kcalloc usage that inadvertently swapped the parameters order in the kcalloc call and went unnoticed. Reported-by: Xia Feng <xiafeng@allwinnertech.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-01-31Merge tag 'mvebu-fixes-3.13-2' of git://git.infradead.org/linux-mvebu into fixesOlof Johansson
mvebu fixes for v3.13 (incremental #2) - allow building and booting DT and non-DT plat-orion SoCs - catch proper return value for kirkwood_pm_init() - properly check return of of_iomap to solve boot hangs (mirabox, others) - remove a compile warning on Armada 370 with non-SMP. * tag 'mvebu-fixes-3.13-2' of git://git.infradead.org/linux-mvebu: ARM: mvebu: fix compilation warning on Armada 370 (i.e. non-SMP) ARM: mvebu: Fix kernel hang in mvebu_soc_id_init() when of_iomap failed ARM: kirkwood: kirkwood_pm_init() should return void ARM: orion: provide C-style interrupt handler for MULTI_IRQ_HANDLER Signed-off-by: Olof Johansson <olof@lixom.net>
2014-01-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4) - a new dvb frontend for ds2103 chipset (m88ds2103) - a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf) - new drivers for R-Car VSP1 - a new radio driver: radio-raremono - a new tuner driver for ts2022 chipset (m88ts2022) - the analog part of em28xx is now a separate module that only load/runs if the device is not a pure digital TV device - added a staging driver for bcm2048 radio devices - the omap 2 video driver (omap24xx) was moved to staging. This driver is for an old hardware and uses a deprecated Kernel internal API. If nobody cares enough to fix it, it would be removed on a couple Kernel releases - the sn9c102 driver was moved to staging. This driver was replaced by gspca, and disabled on some distros, as almost all devices are known to work properly with gspca. It should be removed from kernel on a couple Kernel releases - lots of driver fixes, improvements and cleanups * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits) [media] media: v4l2-dev: fix video device index assignment [media] rc-core: reuse device numbers [media] em28xx-cards: properly initialize the device bitmap [media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c [media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c [media] Staging: media: Fix quoted string split across line in as102_fe.c [media] media: st-rc: Add reset support [media] m2m-deinterlace: fix allocated struct type [media] radio-usb-si4713: fix sparse non static symbol warnings [media] em28xx-audio: remove needless check before usb_free_coherent() [media] au0828: Fix sparse non static symbol warning Revert "[media] go7007-usb: only use go->dev after allocated" [media] em28xx-audio: provide an error code when URB submit fails [media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting [media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0 [media] em28xx: make 'em28xx_ctrl_ops' static em28xx-alsa: Fix error patch for init/fini [media] em28xx-audio: flush work at .fini [media] drxk: remove the option to load firmware asynchronously [media] em28xx: adjust period size at runtime ...
2014-01-31Merge tag 'pm+acpi-3.14-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes and cleanups from Rafael Wysocki: - ACPI device hotplug fix preventing ACPI drivers from binding to device objects that acpi_bus_trim() has been called for and the devices represented by them may not be operational. - Recent cpufreq changes related to the "boost" (turbo) feature broke the acpi-cpufreq error code path causing a NULL pointer dereference to occur on some systems. Fix from Konrad Rzeszutek Wilk. - The log level of a CPU initialization error message added recently needs to be reduced, because the particular BIOS issue indicated by it turns out to be widespread and doesn't really matter for the majority of systems having it. From Jiang Liu. - The regulator API needs to be told to stay away from things on systems with ACPI BIOSes or it may conflict with the BIOS' own handling of voltage regulators. Fix from Mark Brown that works around a 3.13 regression in lm90 on PCs occuring if the regulator API is enabled. - Prevent the Exynos4 devfreq driver from being built on multiplatform, because it depends on things that aren't available during such builds. From Sachin Kamat. - Upstream ACPICA doesn't use the bool type as defined in the kernel, so modify the kernel's ACPICA code to follow the upstream in that respect (only one variable definition is affected) to reduce divergences between the two. From Lv Zheng. - Make the ACPI device PM code use ACPI_COMPANION() instead of its own routine doing the same thing (and invokng ACPI_COMPANION() in the process). - Modify some routines in the ACPI processor driver to follow the common convention and return negative integers on errors. From Hanjun Guo. * tag 'pm+acpi-3.14-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / scan: Clear match_driver flag in acpi_bus_trim() ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API acpi-cpufreq: De-register CPU notifier and free struct msr on error. ACPICA: Remove bool usage from ACPICA. PM / devfreq: Disable Exynos4 driver build on multiplatform ACPI / PM: Use ACPI_COMPANION() to get ACPI companions of devices ACPI / scan: reduce log level of "ACPI: \_PR_.CPU4: failed to get CPU APIC ID" ACPI / processor: Return specific error value when mapping lapic id
2014-01-31Merge tag 'stable/for-linus-3.14-rc0-late-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from Konrad Rzeszutek Wilk: "Bug-fixes for the new features that were added during this cycle. There are also two fixes for long-standing issues for which we have a solution: grant-table operations extra work that was not needed causing performance issues and the self balloon code was too aggressive causing OOMs. Details: - Xen ARM couldn't use the new FIFO events - Xen ARM couldn't use the SWIOTLB if compiled as 32-bit with 64-bit PCIe devices. - Grant table were doing needless M2P operations. - Ratchet down the self-balloon code so it won't OOM. - Fix misplaced kfree in Xen PVH error code paths" * tag 'stable/for-linus-3.14-rc0-late-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pvh: Fix misplaced kfree from xlated_setup_gnttab_pages drivers: xen: deaggressive selfballoon driver xen/grant-table: Avoid m2p_override during mapping xen/gnttab: Use phys_addr_t to describe the grant frame base address xen: swiotlb: handle sizeof(dma_addr_t) != sizeof(phys_addr_t) arm/xen: Initialize event channels earlier
2014-01-31Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull more KVM updates from Paolo Bonzini: "Second batch of KVM updates. Some minor x86 fixes, two s390 guest features that need some handling in the host, and all the PPC changes. The PPC changes include support for little-endian guests and enablement for new POWER8 features" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (45 commits) x86, kvm: correctly access the KVM_CPUID_FEATURES leaf at 0x40000101 x86, kvm: cache the base of the KVM cpuid leaves kvm: x86: move KVM_CAP_HYPERV_TIME outside #ifdef KVM: PPC: Book3S PR: Cope with doorbell interrupts KVM: PPC: Book3S HV: Add software abort codes for transactional memory KVM: PPC: Book3S HV: Add new state for transactional memory powerpc/Kconfig: Make TM select VSX and VMX KVM: PPC: Book3S HV: Basic little-endian guest support KVM: PPC: Book3S HV: Add support for DABRX register on POWER7 KVM: PPC: Book3S HV: Prepare for host using hypervisor doorbells KVM: PPC: Book3S HV: Handle new LPCR bits on POWER8 KVM: PPC: Book3S HV: Handle guest using doorbells for IPIs KVM: PPC: Book3S HV: Consolidate code that checks reason for wake from nap KVM: PPC: Book3S HV: Implement architecture compatibility modes for POWER8 KVM: PPC: Book3S HV: Add handler for HV facility unavailable KVM: PPC: Book3S HV: Flush the correct number of TLB sets on POWER8 KVM: PPC: Book3S HV: Context-switch new POWER8 SPRs KVM: PPC: Book3S HV: Align physical and virtual CPU thread numbers KVM: PPC: Book3S HV: Don't set DABR on POWER8 kvm/ppc: IRQ disabling cleanup ...
2014-01-31drivers: xen: deaggressive selfballoon driverBob Liu
Current xen-selfballoon driver is too aggressive which may cause OOM be triggered more often. Eg. this bug reported by James: https://lkml.org/lkml/2013/11/21/158 There are two mainly reasons: 1) The original goal_page didn't consider some pages used by kernel space, like slab pages and pages used by device drivers. 2) The balloon driver may not give back memory to guest OS fast enough when the workload suddenly aquries a lot of physical memory. In both cases, the guest OS will suffer from memory pressure and OOM may be triggered. The fix is make xen-selfballoon driver not that aggressive by adding extra 10% of total ram pages to goal_page. It's more valuable to keep the guest system reliable and response faster than balloon out these 10% pages to XEN. Signed-off-by: Bob Liu <bob.liu@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-31xen/grant-table: Avoid m2p_override during mappingZoltan Kiss
The grant mapping API does m2p_override unnecessarily: only gntdev needs it, for blkback and future netback patches it just cause a lock contention, as those pages never go to userspace. Therefore this series does the following: - the original functions were renamed to __gnttab_[un]map_refs, with a new parameter m2p_override - based on m2p_override either they follow the original behaviour, or just set the private flag and call set_phys_to_machine - gnttab_[un]map_refs are now a wrapper to call __gnttab_[un]map_refs with m2p_override false - a new function gnttab_[un]map_refs_userspace provides the old behaviour It also removes a stray space from page.h and change ret to 0 if XENFEAT_auto_translated_physmap, as that is the only possible return value there. v2: - move the storing of the old mfn in page->index to gnttab_map_refs - move the function header update to a separate patch v3: - a new approach to retain old behaviour where it needed - squash the patches into one v4: - move out the common bits from m2p* functions, and pass pfn/mfn as parameter - clear page->private before doing anything with the page, so m2p_find_override won't race with this v5: - change return value handling in __gnttab_[un]map_refs - remove a stray space in page.h - add detail why ret = 0 now at some places v6: - don't pass pfn to m2p* functions, just get it locally Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> Suggested-by: David Vrabel <david.vrabel@citrix.com> Acked-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2014-01-30Merge tag 'upstream-3.14-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs updates from Artem Bityutskiy: - Improve the NOR erasure quirk - now it tries to do as little writes as possible, because the eraseblock may be in an "unstable" state and write operation sometimes causes NOR chip lock-ups. - Both UBI and UBIFS changes are now maintainer in one single tree, because the amount of changes dropped significantly. * tag 'upstream-3.14-rc1' of git://git.infradead.org/linux-ubifs: UBI: avoid program operation on NOR flash after erasure interrupted MAINTAINERS: keep UBI and UBIFS stuff in the same tree UBI: fix error return code
2014-01-30Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "A few hotfixes and various leftovers which were awaiting other merges. Mainly movement of zram into mm/" * emailed patches fron Andrew Morton <akpm@linux-foundation.org>: (25 commits) memcg: fix mutex not unlocked on memcg_create_kmem_cache fail path Documentation/filesystems/vfs.txt: update file_operations documentation mm, oom: base root bonus on current usage mm: don't lose the SOFT_DIRTY flag on mprotect mm/slub.c: fix page->_count corruption (again) mm/mempolicy.c: fix mempolicy printing in numa_maps zram: remove zram->lock in read path and change it with mutex zram: remove workqueue for freeing removed pending slot zram: introduce zram->tb_lock zram: use atomic operation for stat zram: remove unnecessary free zram: delay pending free request in read path zram: fix race between reset and flushing pending work zsmalloc: add maintainers zram: add zram maintainers zsmalloc: add copyright zram: add copyright zram: remove old private project comment zram: promote zram from staging zsmalloc: move it under mm ...
2014-01-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The most notable new addition inside this pull request is the support for MIPS's latest and greatest core called "inter/proAptiv". The patch series describes this core as follows. "The interAptiv is a power-efficient multi-core microprocessor for use in system-on-chip (SoC) applications. The interAptiv combines a multi-threading pipeline with a coherence manager to deliver improved computational throughput and power efficiency. The interAptiv can contain one to four MIPS32R3 interAptiv cores, system level coherence manager with L2 cache, optional coherent I/O port, and optional floating point unit." The platform specific patches touch all 3 Broadcom families. It adds support for the new Broadcom/Netlogix XLP9xx Soc, building a common BCM63XX SMP kernel for all BCM63XX SoCs regardless of core type/count and full gpio button/led descriptions for BCM47xx. The rest of the series are cleanups and bug fixes that are MIPS generic and consist largely of changes that Imgtec/MIPS had published in their linux-mti-3.10.git stable tree. Random other cleanups and patches preparing code to be merged in 3.15" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) mips: select ARCH_MIGHT_HAVE_PC_SERIO mips: delete non-required instances of include <linux/init.h> MIPS: KVM: remove shadow_tlb code MIPS: KVM: use common EHINV aware UNIQUE_ENTRYHI mips/ide: flush dcache also if icache does not snoop dcache MIPS: BCM47XX: fix position of cpu_wait disabling MIPS: BCM63XX: select correct MIPS_L1_CACHE_SHIFT value MIPS: update MIPS_L1_CACHE_SHIFT based on MIPS_L1_CACHE_SHIFT_<N> MIPS: introduce MIPS_L1_CACHE_SHIFT_<N> MIPS: ZBOOT: gather string functions into string.c arch/mips/pci: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource bcma: gpio: don't cast u32 to unsigned long ssb: gpio: add own IRQ domain MIPS: BCM47XX: fix sparse warnings in board.c MIPS: BCM47XX: add board detection for Linksys WRT54GS V1 MIPS: BCM47XX: fix detection for some boards MIPS: BCM47XX: Enable buttons support on SSB MIPS: BCM47XX: Convert WNDR4500 to new syntax MIPS: BCM47XX: Use "timer" trigger for status LEDs ...
2014-01-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull more powerpc bits from Ben Herrenschmidt: "Here are a few more powerpc bits for this merge window. The bulk is made of two pull requests from Scott and Anatolij that I had missed previously (they arrived while I was away). Since both their branches are in -next independently, and the content has been around for a little while, they can still go in. The rest is mostly bug and regression fixes, a small series of cleanups to our pseries cpuidle code (including moving it to the right place), and one new cpuidle bakend for the powernv platform. I also wired up the new sched_attr syscalls" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (37 commits) powerpc: Wire up sched_setattr and sched_getattr syscalls powerpc/hugetlb: Replace __get_cpu_var with get_cpu_var powerpc: Make sure "cache" directory is removed when offlining cpu powerpc/mm: Fix mmap errno when MAP_FIXED is set and mapping exceeds the allowed address space powerpc/powernv/cpuidle: Back-end cpuidle driver for powernv platform. powerpc/pseries/cpuidle: smt-snooze-delay cleanup. powerpc/pseries/cpuidle: Remove MAX_IDLE_STATE macro. powerpc/pseries/cpuidle: Make cpuidle-pseries backend driver a non-module. powerpc/pseries/cpuidle: Use cpuidle_register() for initialisation. powerpc/pseries/cpuidle: Move processor_idle.c to drivers/cpuidle. powerpc: Fix 32-bit frames for signals delivered when transactional powerpc/iommu: Fix initialisation of DART iommu table powerpc/numa: Fix decimal permissions powerpc/mm: Fix compile error of pgtable-ppc64.h powerpc: Fix hw breakpoints on !HAVE_HW_BREAKPOINT configurations clk: corenet: Adds the clock binding powerpc/booke64: Guard e6500 tlb handler with CONFIG_PPC_FSL_BOOK3E powerpc/512x: dts: add MPC5125 clock specs powerpc/512x: clk: support MPC5121/5123/5125 SoC variants powerpc/512x: clk: enforce even SDHC divider values ...
2014-01-30zram: remove zram->lock in read path and change it with mutexMinchan Kim
Finally, we separated zram->lock dependency from 32bit stat/ table handling so there is no reason to use rw_semaphore between read and write path so this patch removes the lock from read path totally and changes rw_semaphore with mutex. So, we could do old: read-read: OK read-write: NO write-write: NO Now: read-read: OK read-write: OK write-write: NO The below data proves mixed workload performs well 11 times and there is also enhance on write-write path because current rw-semaphore doesn't support SPIN_ON_OWNER. It's side effect but anyway good thing for us. Write-related tests perform better (from 61% to 1058%) but read path has good/bad(from -2.22% to 1.45%) but they are all marginal within stddev. CPU 12 iozone -t -T -l 12 -u 12 -r 16K -s 60M -I +Z -V 0 ==Initial write ==Initial write records: 10 records: 10 avg: 516189.16 avg: 839907.96 std: 22486.53 (4.36%) std: 47902.17 (5.70%) max: 546970.60 max: 909910.35 min: 481131.54 min: 751148.38 ==Rewrite ==Rewrite records: 10 records: 10 avg: 509527.98 avg: 1050156.37 std: 45799.94 (8.99%) std: 40695.44 (3.88%) max: 611574.27 max: 1111929.26 min: 443679.95 min: 980409.62 ==Read ==Read records: 10 records: 10 avg: 4408624.17 avg: 4472546.76 std: 281152.61 (6.38%) std: 163662.78 (3.66%) max: 4867888.66 max: 4727351.03 min: 4058347.69 min: 4126520.88 ==Re-read ==Re-read records: 10 records: 10 avg: 4462147.53 avg: 4363257.75 std: 283546.11 (6.35%) std: 247292.63 (5.67%) max: 4912894.44 max: 4677241.75 min: 4131386.50 min: 4035235.84 ==Reverse Read ==Reverse Read records: 10 records: 10 avg: 4565865.97 avg: 4485818.08 std: 313395.63 (6.86%) std: 248470.10 (5.54%) max: 5232749.16 max: 4789749.94 min: 4185809.62 min: 3963081.34 ==Stride read ==Stride read records: 10 records: 10 avg: 4515981.80 avg: 4418806.01 std: 211192.32 (4.68%) std: 212837.97 (4.82%) max: 4889287.28 max: 4686967.22 min: 4210362.00 min: 4083041.84 ==Random read ==Random read records: 10 records: 10 avg: 4410525.23 avg: 4387093.18 std: 236693.22 (5.37%) std: 235285.23 (5.36%) max: 4713698.47 max: 4669760.62 min: 4057163.62 min: 3952002.16 ==Mixed workload ==Mixed workload records: 10 records: 10 avg: 243234.25 avg: 2818677.27 std: 28505.07 (11.72%) std: 195569.70 (6.94%) max: 288905.23 max: 3126478.11 min: 212473.16 min: 2484150.69 ==Random write ==Random write records: 10 records: 10 avg: 555887.07 avg: 1053057.79 std: 70841.98 (12.74%) std: 35195.36 (3.34%) max: 683188.28 max: 1096125.73 min: 437299.57 min: 992481.93 ==Pwrite ==Pwrite records: 10 records: 10 avg: 501745.93 avg: 810363.09 std: 16373.54 (3.26%) std: 19245.01 (2.37%) max: 518724.52 max: 833359.70 min: 464208.73 min: 765501.87 ==Pread ==Pread records: 10 records: 10 avg: 4539894.60 avg: 4457680.58 std: 197094.66 (4.34%) std: 188965.60 (4.24%) max: 4877170.38 max: 4689905.53 min: 4226326.03 min: 4095739.72 Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Nitin Gupta <ngupta@vflare.org> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
