path: root/drivers
2014-04-03rtc: sunxi: change compatiblesMaxime Ripard
The Allwinner A10 compatibles were following a slightly different compatible patterns than the rest of the SoCs for historical reasons. Change the compatibles to match the other pattern in the RTC driver for consistency. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: mc13xxx: make rtc_read_time() more readableAlexander Shiyan
Remove unnecessary locks when reading the time and make the read operation until the values of day matched between reading the seconds, it will make the mc13xxx_rtc_read_time() procedure more readable. Additionally, patch introduced a "seconds in a day" definition. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: mc13xxx: change RTC validation schemeAlexander Shiyan
Datasheet says: "When the VSRTC voltage drops to the range of 0.9 - 0.8V, the RTCPORB reset signal is generated and the contents of the RTC will be reset. <skip>. To inform the processor that the contents of the RTC are no longer valid due to the reset, a timer reset interrupt function is implemented with the RTCRSTI bit." This patch makes the RTC valid by default until RTCRST interrupt occurs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: mc13xxx: fix 1Hz interruptAlexander Shiyan
1Hz interrupt is never unmasked, so no interrupts appears. This patch fix this issue. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: mc13xxx: simplify alarm_irq_enable()Alexander Shiyan
This patch removes excess layer for alarm_irq_enable() function. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: mc13xxx: request IRQs after RTC registrationAlexander Shiyan
Interrupts can appear after request_irq and interrupt handlers can use the RTC device, but currently we register RTC after IRQs. This patch changes this order and simplify error path a bit. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: mc13xxx: remove __exit_p()Alexander Shiyan
Since we no longer allow building without hotplug, the mc13xxx_rtc_remove() function is always present and we should not use __exit_p() to refer to it. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-ds1307.c: add alarm support for mcp7941x chipsSimon Guinot
Add alarm support for the Microchip RTC devices MCP794xx. Note that two programmable alarms are provided by the chip but only one is used by the driver. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-ds1307.c: fix sysfs wakealarm attribute creationSimon Guinot
In order to allow the creation of the sysfs attribute wakealarm, this patch moves the device_set_wakeup_capable() call above the RTC device registration. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Gregory Clement <gregory.clement@free-electrons.com> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-sirfsoc.c: fix kernel panic of backing from hibernationXianglong Du
RTC settings will be lost if power supply is cut off after hibernation finished, but the current "restore" function does not restore RTC related settings, this causes rtc_read_time failure and kernel panic: rtc rtc0: **** DPM device timeout **** Stack trace: unwind_backtrace+0x0/0xf4 show_stack+0x10/0x14 dpm_wd_handler+0x24/0x28 call_timer_fn.isra.33+0x24/0x88 run_timer_softirq+0x178/0x1f0 __do_softirq+0x120/0x200 do_softirq+0x54/0x5c irq_exit+0x9c/0xd0 handle_IRQ+0x44/0x90 __irq_svc+0x40/0x70 _raw_spin_unlock_irqrestore+0x10/0x48 sirfsoc_rtc_iobrg_readl+0x34/0x3c sirfsoc_rtc_read_time+0x24/0x48 __rtc_read_time.isra.3+0x48/0x5c rtc_read_time+0x30/0x44 rtc_resume.part.9+0x20/0x104 rtc_resume+0x5c/0x64 dpm_run_callback.isra.4+0x2c/0x74 device_resume+0x9c/0x144 dpm_resume+0x100/0x224 hibernation_snapshot+0x170/0x398 hibernate+0x13c/0x1d8 state_store+0xb4/0xb8 kobj_attr_store+0x14/0x20 sysfs_write_file+0x160/0x190 vfs_write+0xb4/0x194 SyS_write+0x3c/0x78 this patch uses SIMPLE_DEV_PM_OPS() to make restore() execute the existing resume() function which will restore the set of RTC. Signed-off-by: Xianglong Du <Xianglong.Du@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-da9052.c: remove redundant private structure fieldAnthony Olech
Remove redundant irq field in private rtc structure. Signed-off-by: Anthony Olech <anthony.olech.opensource@diasemi.com> Acked-by: David Dajun Chen <david.chen@diasemi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-isl12057.c: remove duplicate includeSachin Kamat
linux/rtc.h was included twice. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-jz4740: use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() in order to make the code simpler, and move 'struct resource *mem' from 'struct jz4740_rtc' to jz4740_rtc_probe() because the 'mem' variable is used only in jz4740_rtc_probe(). Also the redundant return value check of platform_get_resource() is removed, because the value is checked by devm_ioremap_resource(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-vt8500: use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() in order to make the code simpler, and move 'struct resource *res' from 'struct vt8500_rtc' to vt8500_rtc_probe() because the 'res' variable is used only in vt8500_rtc_probe(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-davinci: use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() in order to make the code simpler, and remove redundant return value check of platform_get_resource() because the value is checked by devm_ioremap_resource(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Kevin Hilman <khilman@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-coh901331: use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() in order to make the code simpler, and remove redundant return value check of platform_get_resource() because the value is checked by devm_ioremap_resource(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-spear: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-lpc32xx: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-sirfsoc: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: rtc-rx8025: remove unnecessary OOM messagesJingoo Han
2014-04-03rtc: rtc-pm8xxx: remove unnecessary OOM messagesJingoo Han
2014-04-03rtc: rtc-nuc900: remove unnecessary OOM messagesJingoo Han
2014-04-03rtc: rtc-moxart: remove unnecessary OOM messagesJingoo Han
2014-04-03rtc: rtc-ds1390: remove unnecessary OOM messagesJingoo Han
2014-04-03rtc: rtc-davinci: remove unnecessary OOM messagesJingoo Han
2014-04-03rtc: rtc-at32ap700x: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03drivers/rtc/rtc-imxdi.c: check the return value from clk_prepare_enable()Fabio Estevam
clk_prepare_enable() may fail, so let's check its return value and propagate it in the case of error. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03rtc: fix potential race conditionAlessandro Zummo
RTC drivers must not return an error after device registration. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Reported-by: Ales Novak <alnovak@suse.cz> Cc: Alexander Shiyan <shc_work@mail.ru> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Cc: Lee Jones <lee.jones@linaro.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: tps65217_bl: remove unnecessary OOM messagesJingoo Han
2014-04-03backlight: platform_lcd: remove unnecessary OOM messagesJingoo Han
2014-04-03backlight: lms283gf05: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: lm3533_bl: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: l4f00242t03: remove unnecessary OOM messagesJingoo Han
2014-04-03backlight: ili9320: remove unnecessary OOM messagesJingoo Han
2014-04-03backlight: ili922x: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: hx8357: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: corgi_lcd: remove unnecessary OOM messagesJingoo Han
2014-04-03backlight: adp8870: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: adp8860: remove unnecessary OOM messagesJingoo Han
2014-04-03backlight: aat2870: remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Jinyoung Park <jinyoungp@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: update backlight status when necessaryLiu Ying
We don't have to update a backlight status every time a blanking or unblanking event comes because the backlight status may have already been what we want. Another thought is that one backlight device may be shared by multiple framebuffers. We don't hope blanking one of the framebuffers may turn the backlight off for all the other framebuffers, since they are likely being active to display something. This patch makes the backlight status be updated only when the relevant backlight device's use count changes from zero to one or from one to zero. Signed-off-by: Liu Ying <Ying.Liu@freescale.com> Cc: Jingoo Han <jg1.han@samsung.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03backlight: update bd state & fb_blank properties when necessaryLiu Ying
We don't have to update the state and fb_blank properties of a backlight device every time a blanking or unblanking event comes because they may have already been what we want. Another thought is that one backlight device may be shared by multiple framebuffers. The backlight driver should take the backlight device as a resource shared by all the associated framebuffers. This patch adds some logic to record each framebuffer's backlight usage to determine the backlight device use count and whether the two properties should be updated or not. To be more specific, only one unblank operation on a certain blanked framebuffer may increase the backlight device's use count by one, while one blank operation on a certain unblanked framebuffer may decrease the use count by one, because the userspace is likely to unblank an unblanked framebuffer or blank a blanked framebuffer. Signed-off-by: Liu Ying <Ying.Liu@freescale.com> Cc: Jingoo Han <jg1.han@samsung.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto updates from Herbert Xu: "Here is the crypto update for 3.15: - Added 3DES driver for OMAP4/AM43xx - Added AVX2 acceleration for SHA - Added hash-only AEAD algorithms in caam - Removed tegra driver as it is not functioning and the hardware is too slow - Allow blkcipher walks over AEAD (needed for ARM) - Fixed unprotected FPU/SSE access in ghash-clmulni-intel - Fixed highmem crash in omap-sham - Add (zero entropy) randomness when initialising hardware RNGs - Fixed unaligned ahash comletion functions - Added soft module depedency for crc32c for initrds that use crc32c" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (60 commits) crypto: ghash-clmulni-intel - use C implementation for setkey() crypto: x86/sha1 - reduce size of the AVX2 asm implementation crypto: x86/sha1 - fix stack alignment of AVX2 variant crypto: x86/sha1 - re-enable the AVX variant crypto: sha - SHA1 transform x86_64 AVX2 crypto: crypto_wq - Fix late crypto work queue initialization crypto: caam - add missing key_dma unmap crypto: caam - add support for aead null encryption crypto: testmgr - add aead null encryption test vectors crypto: export NULL algorithms defines crypto: caam - remove error propagation handling crypto: hash - Simplify the ahash_finup implementation crypto: hash - Pull out the functions to save/restore request crypto: hash - Fix the pointer voodoo in unaligned ahash crypto: caam - Fix first parameter to caam_init_rng crypto: omap-sham - Map SG pages if they are HIGHMEM before accessing crypto: caam - Dynamic memory allocation for caam_rng_ctx object crypto: allow blkcipher walks over AEAD data crypto: remove direct blkcipher_walk dependency on transform hwrng: add randomness to system from rng sources ...
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: - substantial cleanup of the generic and transport layers, in the direction of an ultimate goal of making struct hid_device completely transport independent, by Benjamin Tissoires - cp2112 driver from David Barksdale - a lot of fixes and new hardware support (Dualshock 4) to hid-sony driver, by Frank Praznik - support for Win 8.1 multitouch protocol by Andrew Duggan - other smaller fixes / device ID additions * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (75 commits) HID: sony: fix force feedback mismerge HID: sony: Set the quriks flag for Bluetooth controllers HID: sony: Fix Sixaxis cable state detection HID: uhid: Add UHID_CREATE2 + UHID_INPUT2 HID: hyperv: fix _raw_request() prototype HID: hyperv: Implement a stub raw_request() entry point HID: hid-sensor-hub: fix sleeping function called from invalid context HID: multitouch: add support for Win 8.1 multitouch touchpads HID: remove hid_output_raw_report transport implementations HID: sony: do not rely on hid_output_raw_report HID: cp2112: remove the last hid_output_raw_report() call HID: cp2112: remove various hid_out_raw_report calls HID: multitouch: add support of other generic collections in hid-mt HID: multitouch: remove pen special handling HID: multitouch: remove registered devices with default behavior HID: hidp: Add a comment that some devices depend on the current behavior of uniq HID: sony: Prevent duplicate controller connections. HID: sony: Perform a boundry check on the sixaxis battery level index. HID: sony: Fix work queue issues HID: sony: Fix multi-line comment styling ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual rocket science -- mostly documentation and comment updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: sparse: fix comment doc: fix double words isdn: capi: fix "CAPI_VERSION" comment doc: DocBook: Fix typos in xml and template file Bluetooth: add module name for btwilink driver core: unexport static function create_syslog_header mmc: core: typo fix in printk specifier ARM: spear: clean up editing mistake net-sysfs: fix comment typo 'CONFIG_SYFS' doc: Insert MODULE_ in module-signing macros Documentation: update URL to hfsplus Technote 1150 gpio: update path to documentation ixgbe: Fix format string in ixgbe_fcoe. Kconfig: Remove useless "default N" lines user_namespace.c: Remove duplicated word in comment CREDITS: fix formatting treewide: Fix typo in Documentation/DocBook mm: Fix warning on make htmldocs caused by slab.c ata: ata-samsung_cf: cleanup in header file idr: remove unused prototype of idr_free()
2014-04-02Merge branch 'sched-idle-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull sched/idle changes from Ingo Molnar: "More idle code reorganization, to prepare for more integration. (Sent separately because it depended on pending timer work, which is now upstream)" * 'sched-idle-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/idle: Add more comments to the code sched/idle: Move idle conditions in cpuidle_idle main function sched/idle: Reorganize the idle loop cpuidle/idle: Move the cpuidle_idle_call function to idle.c idle/cpuidle: Split cpuidle_idle_call main function into smaller functions
2014-04-02Merge tag 'kvm-3.15-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Paolo Bonzini: "PPC and ARM do not have much going on this time. Most of the cool stuff, instead, is in s390 and (after a few releases) x86. ARM has some caching fixes and PPC has transactional memory support in guests. MIPS has some fixes, with more probably coming in 3.16 as QEMU will soon get support for MIPS KVM. For x86 there are optimizations for debug registers, which trigger on some Windows games, and other important fixes for Windows guests. We now expose to the guest Broadwell instruction set extensions and also Intel MPX. There's also a fix/workaround for OS X guests, nested virtualization features (preemption timer), and a couple kvmclock refinements. For s390, the main news is asynchronous page faults, together with improvements to IRQs (floating irqs and adapter irqs) that speed up virtio devices" * tag 'kvm-3.15-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (96 commits) KVM: PPC: Book3S HV: Save/restore host PMU registers that are new in POWER8 KVM: PPC: Book3S HV: Fix decrementer timeouts with non-zero TB offset KVM: PPC: Book3S HV: Don't use kvm_memslots() in real mode KVM: PPC: Book3S HV: Return ENODEV error rather than EIO KVM: PPC: Book3S: Trim top 4 bits of physical address in RTAS code KVM: PPC: Book3S HV: Add get/set_one_reg for new TM state KVM: PPC: Book3S HV: Add transactional memory support KVM: Specify byte order for KVM_EXIT_MMIO KVM: vmx: fix MPX detection KVM: PPC: Book3S HV: Fix KVM hang with CONFIG_KVM_XICS=n KVM: PPC: Book3S: Introduce hypervisor call H_GET_TCE KVM: PPC: Book3S HV: Fix incorrect userspace exit on ioeventfd write KVM: s390: clear local interrupts at cpu initial reset KVM: s390: Fix possible memory leak in SIGP functions KVM: s390: fix calculation of idle_mask array size KVM: s390: randomize sca address KVM: ioapic: reinject pending interrupts on KVM_SET_IRQCHIP KVM: Bump KVM_MAX_IRQ_ROUTES for s390 KVM: s390: irq routing for adapter interrupts. KVM: s390: adapter interrupt sources ...
2014-04-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "Nothing exciting: virtio-blk users might see a bit of a boost from the doubling of the default queue length though" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio-blk: base queue-depth on virtqueue ringsize or module param Revert a02bbb1ccfe8: MAINTAINERS: add virtio-dev ML for virtio virtio: fail adding buffer on broken queues. virtio-rng: don't crash if virtqueue is broken. virtio_balloon: don't crash if virtqueue is broken. virtio_blk: don't crash, report error if virtqueue is broken. virtio_net: don't crash if virtqueue is broken. virtio_balloon: don't softlockup on huge balloon changes. virtio: Use pci_enable_msix_exact() instead of pci_enable_msix() MAINTAINERS: virtio-dev is subscribers only tools/virtio: add a missing ) tools/virtio: fix missing kmemleak_ignore symbol tools/virtio: update internal copies of headers
