The previous '#ifndef MODULE' block did not cover all the
static-build-only code. Now it does.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
airo:
* fix oops, if !CONFIG_PROC_FS (create_proc_entry always returns NULL)
* handle pci_register_driver() failure. if it fails, we really do
want to exit, rather than (as a comment indicates) return success
because-we-are-a-library.
* #if 0 have_isa_dev variable, which is assigned a value but never used
ipw2100:
* handle sysfs_create_group() failure
* handle driver_create_file() failure
The recent __must_check stuff flagged some error handling bugs.
phy/fixed.c:
* handle device_bind_driver() failure
phy/phy_device.c:
* release rwsem upon failure
The ->flags in struct request was split into two variables, in a recent
changeset. The merge of this change forgot to update SCSI's libsas,
probably because libsas was a very recent merge.
* 'block' of git://brick.kernel.dk/data/git/linux-2.6-block: (67 commits)
[PATCH] blk_queue_start_tag() shared map race fix
[PATCH] Update axboe@suse.de email address
[PATCH] fix creating zero sized bio mempools in low memory system
[PATCH] CONFIG_BLOCK: blk_congestion_wait() fix
[PATCH] CONFIG_BLOCK internal.h cleanups
[PATCH] BLOCK: Make USB storage depend on SCSI rather than selecting it [try #6]
[PATCH] BLOCK: Make it possible to disable the block layer [try #6]
[PATCH] BLOCK: Remove no-longer necessary linux/buffer_head.h inclusions [try #6]
[PATCH] BLOCK: Remove no-longer necessary linux/mpage.h inclusions [try #6]
[PATCH] BLOCK: Move the msdos device ioctl compat stuff to the msdos driver [try #6]
[PATCH] BLOCK: Move the Ext3 device ioctl compat stuff to the Ext3 driver [try #6]
[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver [try #6]
[PATCH] BLOCK: Move the ReiserFS device ioctl compat stuff to the ReiserFS driver [try #6]
[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]
[PATCH] BLOCK: Move the loop device ioctl compat stuff to the loop driver [try #6]
[PATCH] BLOCK: Move __invalidate_device() to block_dev.c [try #6]
[PATCH] BLOCK: Dissociate generic_writepages() from mpage stuff [try #6]
[PATCH] BLOCK: Remove dependence on existence of blockdev_superblock [try #6]
[PATCH] BLOCK: Move extern declarations out of fs/*.c into header files [try #6]
[PATCH] BLOCK: Don't call block_sync_page() from AFS [try #6]
This makes CONFIG_USB_STORAGE depend on CONFIG_SCSI rather than selecting it,
as selecting it makes CONFIG_USB_STORAGE override the dependencies of SCSI,
causing it to turn on even if they aren't all met.
Signed-Off-By: David Howells <dhowells@redhat.com>
Make it possible to disable the block layer. Not all embedded devices require
it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require
the block layer to be present.
This patch does the following:
(*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev
support.
(*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls
an item that uses the block layer. This includes:
(*) Block I/O tracing.
(*) Disk partition code.
(*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS.
(*) The SCSI layer. As far as I can tell, even SCSI chardevs use the
block layer to do scheduling. Some drivers that use SCSI facilities -
such as USB storage - end up disabled indirectly from this.
(*) Various block-based device drivers, such as IDE and the old CDROM
drivers.
(*) MTD blockdev handling and FTL.
(*) JFFS - which uses set_bdev_super(), something it could avoid doing by
taking a leaf out of JFFS2's book.
(*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and
linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is,
however, still used in places, and so is still available.
(*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and
parts of linux/fs.h.
(*) Makes a number of files in fs/ contingent on CONFIG_BLOCK.
(*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK.
(*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK
is not enabled.
(*) fs/no-block.c is created to hold out-of-line stubs and things that are
required when CONFIG_BLOCK is not set:
(*) Default blockdev file operations (to give error ENODEV on opening).
(*) Makes some /proc changes:
(*) /proc/devices does not list any blockdevs.
(*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK.
(*) Makes some compat ioctl handling contingent on CONFIG_BLOCK.
(*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if
given command other than Q_SYNC or if a special device is specified.
(*) In init/do_mounts.c, no reference is made to the blockdev routines if
CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2.
(*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return
error ENOSYS by way of cond_syscall if so).
(*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if
CONFIG_BLOCK is not set, since they can't then happen.
[try #6]
Move the loop device ioctl compat stuff from fs/compat_ioctl.c to the loop
driver so that the loop header file doesn't need to be included.
It is a leftover from before the softirq completion was migrated
to the block layer.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (36 commits)
drm: Use register writes instead of BITBLT_MULTI packets for buffer swap blits
drm: use radeon specific names for radeon flags
drm: add device/vendor id to drm_device_t for compat with FreeBSD drivers
drm: allow multiple addMaps with the same 32-bit map offsset.
drm: fd.o Bug #7595: Avoid u32 overflows in radeon_check_and_fixup_offset().
drm: Fix hashtab implementation leaking illegal error codes to user space.
drm: domain changes broke ppc r200
drm: fixup setversion return codes..
drm: fixup i915 error codes
drm: realign sosme radeon code with drm git tree
drm: realign via driver with drm git tree
drm: remove hash tables on drm exit
drm: cleanups
drm: i810_dma.c: fix pointer arithmetic for 64-bit target
drm: avoid kernel oops in some error paths calling drm_lastclose
drm: allow detection of new VIA chipsets
drm: fix i965 build bug
drm: remove FALSE/TRUE that snuck in with simple memory manager changes.
drm: Add support for Intel i965G chipsets.
drm: add better explanation for i830/i915
Signed-off-by: Jens Axboe <axboe@suse.de>
After Christophs SCSI change, the only usage left is RQ_ACTIVE
and RQ_INACTIVE. The block layer sets RQ_INACTIVE right before freeing
the request, so any check for RQ_INACTIVE in a driver is a bug and
indicates use-after-free.
So kill/clean the remaining users, straight forward.
As the comments indicates in blkdev.h, we can fold it into ->end_io_data
usage as that is really what ->waiting is. Fixup the users of
blk_end_sync_rq().
Right now ->flags is a bit of a mess: some are request types, and
others are just modifiers. Clean this up by splitting it into
->cmd_type and ->cmd_flags. This allows introduction of generic
Linux block message types, useful for sending generic Linux commands
to block devices.
Delay the call to adapter->client_register() until after we are
certain that the client registration is a success. At this point the
client is fully initialized and we no longer hold the adapter->clist
mutex, so this should prevent the deadlocks if the client_register()
callback needs to take that mutex too, as is the case for the bttv
driver.
This fixes bug #7234.
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (180 commits)
V4L/DVB (4641): Trivial: use lowercase letters in hex subsystem ids
V4L/DVB (4639): Cx88: add autodetection for alternate revision of Leadtek PVR
V4L/DVB (4638): Basic DVB-T and analog TV support for the HVR1300.
V4L/DVB (4637): Add a default method for VIDIOC_G_PARM
V4L/DVB (4635): Extend bttv and saa7134 to check for both AGP and PCI PCI failure case
V4L/DVB (4634): Zr36120: implement pcipci checks
V4L/DVB (4632): Zoran: Implement pcipci failure check
V4L/DVB (4631): Av7110: remove V4L2_CAP_VBI_CAPTURE flag
V4L/DVB (4630): Av7110: FW_LOADER depemdency fixed
V4L/DVB (4629): Saa7134: add card support for Proteus Pro 2309
V4L/DVB (4628): Fix VIDIOC_ENUMSTD ioctl in videodev.c
V4L/DVB (4627): Vivi crashes with mplayer
V4L/DVB (4626): On saa7111/7113, LUMA_CTRL need a different value
V4L/DVB (4624): Tvaudio: Replaced kernel_thread() with kthread_run()
V4L/DVB (4622): Copy-paste bug in videodev.c
V4L/DVB (4620): Fix AGC configuration for MOD3000P-based boards
V4L/DVB (4619): Fixes some I2C dependencies on V4L devices
V4L/DVB (4617): Problem with dibusb-mb.c USB IDs
V4L/DVB (4616): [PATCH] Nebula DigiTV USB RC support
V4L/DVB (4614): Export symbol saa7134_tvaudio_setmute from saa7134 for saa7134-alsa
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (48 commits)
ieee1394: raw1394: arm functions slept in atomic context
ieee1394: sbp2: enable auto spin-up for all SBP-2 devices
MAINTAINERS: updates to IEEE 1394 subsystem maintainership
ieee1394: ohci1394: check for errors in suspend or resume
set power state of firewire host during suspend
ieee1394: ohci1394: more obvious endianess handling
ieee1394: ohci1394: fix endianess bug in debug message
ieee1394: sbp2: don't prefer MODE SENSE 10
ieee1394: nodemgr: grab class.subsys.rwsem in nodemgr_resume_ne
ieee1394: nodemgr: fix rwsem recursion
ieee1394: sbp2: more help in Kconfig
ieee1394: sbp2: prevent rare deadlock in shutdown
ieee1394: sbp2: update includes
ieee1394: sbp2: better handling of transport errors
ieee1394: sbp2: recheck node generation in sbp2_update
ieee1394: sbp2: safer agent reset in error handlers
ieee1394: sbp2: handle "sbp2util_node_write_no_wait failed"
CONFIG_PM=n slim: drivers/ieee1394/ohci1394.c
ieee1394: safer definition of empty macros
video1394: add poll file operation support
master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6
* 'intelfb-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6:
intelfbhw.c: intelfbhw_get_p1p2 defined but not used
intelfb: fix mtrr_reg signedness
intelfb: update doc and Kconfig (supported devices)
intelfb: add preliminary i2c support
intelfb: add vsync interrupt support
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[ATM]: [lec] use refcnt to protect lec_arp_entries outside lock
[ATM]: [lec] add reference counting to lec_arp entries
[ATM]: [lec] use work queue instead of timer for lec arp expiry
[ATM]: [lec] old_close is no longer used
[ATM]: [lec] convert lec_arp_table to hlist
[ATM]: [lec] header indent, comment and whitespace cleanup
[ATM]: [lec] indent, comment and whitespace cleanup [continued]
[SCTP]: Do not timestamp every SCTP packet.
[SCTP]: Use correct mask when disabling PMTUD.
[SCTP]: Include sk_buff overhead while updating the peer's receive window.
[SCTP]: Enable Nagle algorithm by default.
[BNX2]: Disable MSI on 5706 if AMD 8132 bridge is present.
[NetLabel]: audit fixups due to delayed feedback
MSI is defined to be 32-bit write. The 5706 does 64-bit MSI writes
with byte enables disabled on the unused 32-bit word. This is legal
but causes problems on the AMD 8132 which will eventually stop
responding after a while.
Without this patch, the MSI test done by the driver during open will
pass, but MSI will eventually stop working after a few MSIs are
written by the device.
AMD believes this incompatibility is unique to the 5706, and
prefers to locally disable MSI rather than globally disabling it
using pci_msi_quirk.
Update version to 1.4.45.
Signed-off-by: Michael Chan <mchan@broadcom.com>
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: (33 commits)
IB/ipath: Fix lockdep error upon "ifconfig ibN down"
IB/ipath: Fix races with ib_resize_cq()
IB/ipath: Support new PCIE device, QLE7142
IB/ipath: Set CPU affinity early
IB/ipath: Fix EEPROM read when driver is compiled with -Os
IB/ipath: Fix and recover TXE piobuf and PBC parity errors
IB/ipath: Change HT CRC message to indicate how to resolve problem
IB/ipath: Clean up module exit code
IB/ipath: Call mtrr_del with correct arguments
IB/ipath: Flush RWQEs if access error or invalid error seen
IB/ipath: Improved support for PowerPC
IB/ipath: Drop unnecessary "(void *)" casts
IB/ipath: Support multiple simultaneous devices of different types
IB/ipath: Fix mismatch in shifts and masks for printing debug info
IB/ipath: Fix compiler warnings and errors on non-x86_64 systems
IB/ipath: Print more informative parity error messages
IB/ipath: Ensure that PD of MR matches PD of QP checking the Rkey
IB/ipath: RC and UC should validate SLID and DLID
IB/ipath: Only allow complete writes to flash
IB/ipath: Count SRQs properly
Fix undefined reference in i2c_sibyte_exit().
drivers/built-in.o: In function `i2c_sibyte_exit':
i2c-sibyte.c:(.exit.text+0x368): undefined reference to `i2c_del_bus'
i2c-sibyte.c:(.exit.text+0x368): relocation truncated to fit: R_MIPS_26 against `i2c_del_bus'
i2c-sibyte.c:(.exit.text+0x38c): undefined reference to `i2c_del_bus'
i2c-sibyte.c:(.exit.text+0x38c): relocation truncated to fit: R_MIPS_26 against `i2c_del_bus'
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
If you send a priority character (as is done for flow control) then the tty
driver can either have its own method for "jumping the queue" or the characrer
can be queued normally. In the latter case we call the write method but
without the atomic_write_lock taken elsewhere.
Make this consistent. Note that the send_xchar method if implemented remains
outside of the lock as it can jump ahead of a current write so must not be
locked out by it.
Signed-off-by: Alan Cox <alan@redhat.com>
in this case on some platforms
The driver has no business doing this work itself any more and hasn't for some
years. When the new speed stuff goes in this will break entirely so fix it up
ready.
Also remove a #if 0 around a comment....
If the chip detected "oscillator stop" condition, show an warning message.
And initialize it with the Epoch time instead of leaving it with unknown
date/time.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
For len equal to 4, we never call sppp_lcp_conf_parse_options(),
therefore rmagic does not get initialized.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Acked-by: Paul Fulghum <paulkf@microgate.com>
This patch limits the messages when ldisc open faulures happen. It happens
under memory pressure.
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
Acked-by: Alan Cox <alan@redhat.com>
This change corrects the logic on the preprocessor conditionals that
include support for ISA port i/o (/dev/ioports) into the mem character
driver.
This fixes the following error when building for powerpc platforms with
CONFIG_PCI=n.
drivers/built-in.o: undefined reference to `pci_io_base'
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Acked-by: Linas Vepstas <lins@austin.ibm.com>
Forward port of the patch by Solar and ported by Julio.
Compiles, boots, and passes my looptorturetest.sh.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Julio Auto <mindvortex@gmail.com>
Cc: Solar Designer <solar@openwall.com>
Fix simple typo in RTC_HCTOSYS option.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Introduce the disable_irq_nosync_lockdep_irqsave() and
enable_irq_lockdep_irqrestore() APIs. These are needed for NE2000; basically
NE2000 calls disable_irq and enable_irq as locking against the IRQ handler,
but both in cases where interrupts are on and off. This means that lockdep
needs to track the old state of the virtual irq flags on disable_irq, and
restore these at enable_irq time.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
If your driver implements "break on" and "break off" this ensures you won't
get multiple overlapping requests or requests in parallel. If your driver
has its own break handling then its still your problem as the driver
author.
Break is also now serialized against writes from user space properly but no
new guarantees are made driver level about writes from the line discipline
itself (eg flow control or echo)
[akpm@osdl.org: build fix]
[akpm@osdl.org: warning fix]
Currently this module just returns 1 if anything on module init fails. Store
the error code of the different function calls and return their error on
problems.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
Cc: Greg KH <greg@kroah.com>
[ Fixed to not unregister twice on error ]
[akpm@osdl.org: fix]
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Arjan van de Ven <arjan@infradead.org>
Now we lock the set ioctl its trivial to lock the get one so the data
copied is consistent. At the moment we have the BKL here but this removes
the need for it and is a step in the right direction
Memory leaks can happen in the vc_resize() function in drivers/char/vt.c
because of the vc->vc_screenbuf variable overriding in vc_allocate(). The
kmemleak reported trace is as follows:
<__kmalloc>
<vc_resize>
<fbcon_init>
<visual_init>
<vc_allocate>
<con_open>
<tty_open>
<chrdev_open>
This patch no longer allocates a screen buffer in vc_allocate() if it was
already allocated by vc_resize().
Acked-by: "Antonino A. Daplas" <adaplas@pol.net>
Fix the Kconfig entry for console on AMBA PL011 to match the code.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
This can now be removed, since there is now a drivers/rtc/rtc-s3c.c driver.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Remove some code which is unneeded if CONFIG_PM=n.
Support SB600 SATA legacy IDE (DMA enable).
Signed-off-by: Anatoli Antonovitch <antonovi@ati.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This is an updated version of Eric Biederman's is_init() patch.
(http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and
replaces a few more instances of ->pid == 1 with is_init().
Further, is_init() checks pid and thus removes dependency on Eric's other
patches for now.
Eric's original description:
There are a lot of places in the kernel where we test for init
because we give it special properties. Most significantly init
must not die. This results in code all over the kernel test
->pid == 1.
Introduce is_init to capture this case.
With multiple pid spaces for all of the cases affected we are
looking for only the first process on the system, not some other
process that has pid == 1.
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: <lxc-devel@lists.sourceforge.net>
Acked-by: Paul Mackerras <paulus@samba.org>
The current kernel serializes console resizes but does not serialize the
resize against the tty structure updates. This means that while two
parallel resizes cannot mess up the console you can get incorrect results
reported.
Secondly while doing this I added vc_lock_resize() to lock and resize the
console. This leaves all knowledge of the console_sem in the vt/console
driver and kicks it out of the tty layer, which is good
Thirdly while doing this I decided I couldn't stand "disallocate" any
longer so I switched it to "deallocate".
Cc: Paul Fulghum <paulkf@microgate.com>
Fix utf-8 mode so alternate charset modes always work according to control
sequences interpreted in do_con_trol function preserving backward US-ASCII
and VT100 semigraphics compatibility.
Malformed utf-8 sequences are represented as sequences of replacement
glyphs,original codes or '?' as a last resort.
unicode-xterm, gnome-terminal, kconsole and other terminal emulators in
utf-8 mode respect acsc, enacs, rmacs sequences. Also I found that some
important system programs (from Debian distro) uses acsc in utf-8 mode -
dselect, aptitude, w3m for example.
Signed-off-by: Adam Tlalka <atlka@pg.gda.pl>
