path: root/drivers
2011-06-06be2net: Fix Rx pause counter for lancerSelvin Xavier
Fixed Rx pause counter for Lancer. Swapping hi and lo words. Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com> Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06qlge: remove unecessary if statementGreg Dietsche
the code always returns 'status' regardless, so if(status) check is unecessary. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06enic: Add support for MTU change via port profile on a dynamic vnicRoopa Prabhu
enic driver gets MTU change notifications for MTU changes in the port profile associated to a dynamic vnic. This patch adds support in enic driver to set new MTU on the dynamic vnic and dynamically adjust its buffers with new MTU size in response to such notifications. Signed-off-by: Roopa Prabhu <roprabhu@cisco.com> Signed-off-by: Vasanthy Kolluri <vkolluri@cisco.com> Signed-off-by: David Wang <dwang2@cisco.com> Signed-off-by: Christian Benvenuti <benve@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06macvlan: add VLAN filters to lowerdevJohn Fastabend
Stacking VLANs on top of the macvlan device does not work if the lowerdev device is using vlan filters set by NETIF_F_HW_VLAN_FILTER. Add ndo ops to pass vlan calls to lowerdev. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-05drivers/net: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-04Merge branch 'master' of ↵David S. Miller
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] Fix oops caused by queue refcounting failure
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) tg3: Fix tg3_skb_error_unmap() net: tracepoint of net_dev_xmit sees freed skb and causes panic drivers/net/can/flexcan.c: add missing clk_put net: dm9000: Get the chip in a known good state before enabling interrupts drivers/net/davinci_emac.c: add missing clk_put af-packet: Add flag to distinguish VID 0 from no-vlan. caif: Fix race when conditionally taking rtnl lock usbnet/cdc_ncm: add missing .reset_resume hook vlan: fix typo in vlan_dev_hard_start_xmit() net/ipv4: Check for mistakenly passed in non-IPv4 address iwl4965: correctly validate temperature value bluetooth l2cap: fix locking in l2cap_global_chan_by_psm ath9k: fix two more bugs in tx power cfg80211: don't drop p2p probe responses Revert "net: fix section mismatches" drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run() sctp: stop pending timers and purge queues when peer restart asoc drivers/net: ks8842 Fix crash on received packet when in PIO mode. ip_options_compile: properly handle unaligned pointer iwlagn: fix incorrect PCI subsystem id for 6150 devices ...
2011-06-04Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: Use hlist_entry() for io_context.cic_list.first cfq-iosched: Remove bogus check in queue_fail path xen/blkback: potential null dereference in error handling xen/blkback: don't call vbd_size() if bd_disk is NULL block: blkdev_get() should access ->bd_disk only after success CFQ: Fix typo and remove unnecessary semicolon block: remove unwanted semicolons Revert "block: Remove extra discard_alignment from hd_struct." nbd: adjust 'max_part' according to part_shift nbd: limit module parameters to a sane value nbd: pass MSG_* flags to kernel_recvmsg() block: improve the bio_add_page() and bio_add_pc_page() descriptions
2011-06-04Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: dmaengine: shdma: fix a regression: initialise DMA channels for memcpy dmaengine: shdma: Fix up fallout from runtime PM changes. Revert "clocksource: sh_cmt: Runtime PM support" Revert "clocksource: sh_tmu: Runtime PM support" sh: Fix up asm-generic/ptrace.h fallout. sh64: Move from P1SEG to CAC_ADDR for consistent sync. sh64: asm/pgtable.h needs asm/mmu.h sh: asm/tlb.h needs linux/swap.h sh: mark DMA slave ID 0 as invalid sh: Update shmin to reflect PIO dependency. sh: arch/sh/kernel/process_32.c needs linux/prefetch.h. sh: add MMCIF runtime PM support on ecovec sh: switch ap325rxa to dynamically manage the platform camera
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-03Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-03netxen: suppress false lro warning messagesSucheta Chakraborty
When interface is down, driver prints false warning messages during lro configuration through ethtool. Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-03tg3: Fix tg3_skb_error_unmap()Matt Carlson
This function attempts to free one fragment beyond the number of fragments that were actually mapped. This patch brings back the limit to the correct spot. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Tested-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sungem: Spring cleaning and GRO supportBenjamin Herrenschmidt
This patch simplifies the logic and locking in sungem significantly: - LLTX is gone, all private locks are gone, mutex is gone - We don't poll the PHY while the interface is down - The above allowed me to get rid of a pile of state flags using the proper interface state provided by the networking stack when needed and overall simplify the driver a lot - Allocate the bulk of RX skbs at init time using GFP_KERNEL - Fix a bug where the dev->features were set after register_netdev() - Added GRO while at it Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02bonding: allow all slave speedsJiri Pirko
No need to check for 10, 100, 1000, 10000 explicitly. Just make this generic and check for invalid values only (similar check is in ethtool userspace app). This enables correct speed handling for slave devices with "nonstandard" speeds. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02[SCSI] Fix oops caused by queue refcounting failureJames Bottomley
In certain circumstances, we can get an oops from a torn down device. Most notably this is from CD roms trying to call scsi_ioctl. The root cause of the problem is the fact that after scsi_remove_device() has been called, the queue is fully torn down. This is actually wrong since the queue can be used until the sdev release function is called. Therefore, we add an extra reference to the queue which is released in sdev->release, so the queue always exists. Reported-by: Parag Warudkar <parag.lkml@gmail.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-06-02drivers/net/can/flexcan.c: add missing clk_putJulia Lawall
The failed_get label is used after the call to clk_get has succeeded, so it should be moved up above the call to clk_put. The failed_req labels doesn't do anything different than failed_get, so delete it. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02dmaengine: shdma: fix a regression: initialise DMA channels for memcpyGuennadi Liakhovetski
A recent patch has introduced a regression, where repeating a memcpy DMA test with shdma module unloading between them skips the DMA channel configuration. Fix this regression by always configuring the channel during its allocation. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-01net: dm9000: Get the chip in a known good state before enabling interruptsMark Brown
Currently the DM9000 driver requests the primary interrupt before it resets the chip and puts it into a known good state. This means that if the chip is asserting interrupt for some reason we can end up with a screaming IRQ that the interrupt handler is unable to deal with. Avoid this by only requesting the interrupt after we've reset the chip so we know what state it's in. This started manifesting itself on one of my boards in the past month or so, I suspect as a result of some core infrastructure changes removing some form of mitigation against bad behaviour here, even when things boot it seems that the new code brings the interface up more quickly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01drivers/net/davinci_emac.c: add missing clk_putJulia Lawall
Go to existing error handling code at the end of the function that calls clk_put. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01caif: Add CAIF HSI Link layer driverDmitry.Tarnyagin
This patch introduces the CAIF HSI Protocol Driver for the CAIF Link Layer. This driver implements a platform driver to accommodate for a platform specific HSI devices. A general platform driver is not possible as there are no HSI side Kernel API defined. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01usbnet/cdc_ncm: add missing .reset_resume hookStefan Metzmacher
This avoids messages like this after suspend: cdc_ncm 2-1.4:1.6: no reset_resume for driver cdc_ncm? cdc_ncm 2-1.4:1.7: no reset_resume for driver cdc_ncm? cdc_ncm 2-1.4:1.6: usb0: unregister 'cdc_ncm' usb-0000:00:1d.0-1.4, CDC NCM This is important for the Ericsson F5521gw GSM/UMTS modem. Otherwise modemmanager looses the fact that the cdc_ncm and cdc_acm devices belong together. The cdc_ether module does the same. Signed-off-by: Stefan Metzmacher <metze@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Fix off-by-one in RMRR setup intel-iommu: Add domain check in domain_remove_one_dev_info intel-iommu: Remove Host Bridge devices from identity mapping intel-iommu: Use coherent DMA mask when requested intel-iommu: Dont cache iova above 32bit intel-iommu: Speed up processing of the identity_mapping function intel-iommu: Check for identity mapping candidate using system dma mask intel-iommu: Only unlink device domains from iommu intel-iommu: Enable super page (2MiB, 1GiB, etc.) support intel-iommu: Flush unmaps at domain_exit intel-iommu: Remove obsolete comment from detect_intel_iommu intel-iommu: fix VT-d PMR disable for TXT on S3 resume
2011-06-02block: fix mismerge of the DISK_EVENT_MEDIA_CHANGE removalLinus Torvalds
Jens' back-merge commit 698567f3fa79 ("Merge commit 'v2.6.39' into for-2.6.40/core") was incorrectly done, and re-introduced the DISK_EVENT_MEDIA_CHANGE lines that had been removed earlier in commits - 9fd097b14918 ("block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers") - 7eec77a1816a ("ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cd") because of conflicts with the "g->flags" updates near-by by commit d4dc210f69bc ("block: don't block events on excl write for non-optical devices") As a result, we re-introduced the hanging behavior due to infinite disk media change reports. Tssk, tssk, people! Don't do back-merges at all, and *definitely* don't do them to hide merge conflicts from me - especially as I'm likely better at merging them than you are, since I do so many merges. Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-01bnx2x: Improve cl45 access methodsYaniv Rosner
Instead of setting CL45 mode for every CL45 access, apply it once during initialization. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Modify XGXS functionsYaniv Rosner
Modify XGXS functions to follow rest of PHY scheme. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Fix link status syncYaniv Rosner
Fix link status synchronization between the primary function, and rest functions. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Adjust BCM8726 module detection settingsYaniv Rosner
Move BCM8726 module detection code into a separate function to be called only once during initialization. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Fix grammar and relocate codeYaniv Rosner
This patch relocates some functions as a preparation for next patches, and also fixes some grammar mistakes. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Fix BCM84833 settingsYaniv Rosner
Fix BCM84833 register settings. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Fix over current port displayYaniv Rosner
On 57712 chip, port number is enumerated per engine, so it requires adjustment in port display to the user. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Add TX fault check for fiber PHYsYaniv Rosner
In case TX fault is detected on Fiber PHYs, declare the link as down until TX fault is gone. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Change return status typeYaniv Rosner
Change return status from u8 to int. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Fix port type displayYaniv Rosner
Display the current media type connected to the port in ethtool. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01bnx2x: Add new phy BCM8722Yaniv Rosner
Add support for new phy BCM8722. Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01iwl4965: correctly validate temperature valueStanislaw Gruszka
In some cases we can read wrong temperature value. If after that temperature value will not be updated to good one, we badly configure tx power parameters and device is unable to send a data. Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=35932 Cc: stable@kernel.org # 2.6.39+ Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01ath9k: fix two more bugs in tx powerDaniel Halperin
This is the same fix as commit 841051602e3fa18ea468fe5a177aa92b6eb44b56 Author: Matteo Croce <technoboy85@gmail.com> Date: Fri Dec 3 02:25:08 2010 +0100 The ath9k driver subtracts 3 dBm to the txpower as with two radios the signal power is doubled. The resulting value is assigned in an u16 which overflows and makes the card work at full power. in two more places. I grepped the ath tree and didn't find any others. Cc: stable@kernel.org Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01xen/blkback: potential null dereference in error handlingDan Carpenter
blkbk->pending_pages can be NULL here so I added a check for it. Signed-off-by: Dan Carpenter <error27@gmail.com> [v1: Redid the loop a bit] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-01xen/blkback: don't call vbd_size() if bd_disk is NULLLaszlo Ersek
...because vbd_size() dereferences bd_disk if bd_part is NULL. Signed-off-by: Laszlo Ersek<lersek@redhat.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-01intel-iommu: Fix off-by-one in RMRR setupDavid Woodhouse
We were mapping an extra byte (and hence usually an extra page): iommu_prepare_identity_map() expects to be given an 'end' argument which is the last byte to be mapped; not the first byte *not* to be mapped. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Add domain check in domain_remove_one_dev_infoMike Habeck
The comment in domain_remove_one_dev_info() states "No need to compare PCI domain; it has to be the same". But for the si_domain that isn't going to be true, as it consists of all the PCI devices that are identity mapped thus multiple PCI domains can be in si_domain. The code needs to validate the PCI domain too. Signed-off-by: Mike Habeck <habeck@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Remove Host Bridge devices from identity mappingMike Travis
When using the 1:1 (identity) PCI DMA remapping, PCI Host Bridge devices that do not use the IOMMU causes a kernel panic. Fix that by not inserting those devices into the si_domain. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Use coherent DMA mask when requestedMike Travis
The __intel_map_single function is not honoring the passed in DMA mask. This results in not using the coherent DMA mask when called from intel_alloc_coherent(). Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Dont cache iova above 32bitChris Wright
Mike Travis and Mike Habeck reported an issue where iova allocation would return a range that was larger than a device's dma mask. https://lkml.org/lkml/2011/3/29/423 The dmar initialization code will reserve all PCI MMIO regions and copy those reservations into a domain specific iova tree. It is possible for one of those regions to be above the dma mask of a device. It is typical to allocate iovas with a 32bit mask (despite device's dma mask possibly being larger) and cache the result until it exhausts the lower 32bit address space. Freeing the iova range that is >= the last iova in the lower 32bit range when there is still an iova above the 32bit range will corrupt the cached iova by pointing it to a region that is above 32bit. If that region is also larger than the device's dma mask, a subsequent allocation will return an unusable iova and cause dma failure. Simply don't cache an iova that is above the 32bit caching boundary. Reported-by: Mike Travis <travis@sgi.com> Reported-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Acked-by: Mike Travis <travis@sgi.com> Tested-by: Mike Habeck <habeck@sgi.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Speed up processing of the identity_mapping functionMike Travis
When there are a large count of PCI devices, and the pass through option for iommu is set, much time is spent in the identity_mapping function hunting though the iommu domains to check if a specific device is "identity mapped". Speed up the function by checking the cached info to see if it's mapped to the static identity domain. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Check for identity mapping candidate using system dma maskChris Wright
The identity mapping code appears to make the assumption that if the devices dma_mask is greater than 32bits the device can use identity mapping. But that is not true: take the case where we have a 40bit device in a 44bit architecture. The device can potentially receive a physical address that it will truncate and cause incorrect addresses to be used. Instead check to see if the device's dma_mask is large enough to address the system's dma_mask. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Only unlink device domains from iommuAlex Williamson
Commit a97590e5 added unlinking domains from iommus to reciprocate the iommu from domains unlinking that was already done. We actually want to only do this for device domains and never for the static identity map domain or VM domains. The SI domain is special and never freed, while VM domain->id lives in their own special address space, separate from iommu->domain_ids. In the current code, a VM can get domain->id zero, then mark that domain unused when unbound from pci-stub. This leads to DMAR write faults when the device is re-bound to the host driver. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Enable super page (2MiB, 1GiB, etc.) supportYouquan Song
There are no externally-visible changes with this. In the loop in the internal __domain_mapping() function, we simply detect if we are mapping: - size >= 2MiB, and - virtual address aligned to 2MiB, and - physical address aligned to 2MiB, and - on hardware that supports superpages. (and likewise for larger superpages). We automatically use a superpage for such mappings. We never have to worry about *breaking* superpages, since we trust that we will always *unmap* the same range that was mapped. So all we need to do is ensure that dma_pte_clear_range() will also cope with superpages. Adjust pfn_to_dma_pte() to take a superpage 'level' as an argument, so it can return a PTE at the appropriate level rather than always extending the page tables all the way down to level 1. Again, this is simplified by the fact that we should never encounter existing small pages when we're creating a mapping; any old mapping that used the same virtual range will have been entirely removed and its obsolete page tables freed. Provide an 'intel_iommu=sp_off' argument on the command line as a chicken bit. Not that it should ever be required. == The original commit seen in the iommu-2.6.git was Youquan's implementation (and completion) of my own half-baked code which I'd typed into an email. Followed by half a dozen subsequent 'fixes'. I've taken the unusual step of rewriting history and collapsing the original commits in order to keep the main history simpler, and make life easier for the people who are going to have to backport this to older kernels. And also so I can give it a more coherent commit comment which (hopefully) gives a better explanation of what's going on. The original sequence of commits leading to identical code was: Youquan Song (3): intel-iommu: super page support intel-iommu: Fix superpage alignment calculation error intel-iommu: Fix superpage level calculation error in dma_pfn_level_pte() David Woodhouse (4): intel-iommu: Precalculate superpage support for dmar_domain intel-iommu: Fix hardware_largepage_caps() intel-iommu: Fix inappropriate use of superpages in __domain_mapping() intel-iommu: Fix phys_pfn in __domain_mapping for sglist pages Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01kgdbts: only use new asm-generic/ptrace.h api when neededMike Frysinger
The new instruction_pointer_set helper is defined for people who have converted to asm-generic/ptrace.h, so don't use it generally unless the arch needs it (in which case it has been converted). This should fix building of kgdb tests for arches not yet converted. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
