Allow for SS+ USB
Signed-off-by: Oliver Neukum <ONeukum@suse.com>
Allow for SS+ USB
Configure and enable various tunnels on the
adapter after PF start.
This change was missed as a part of
'commit 464f664501816ef5fbbc00b8de96f4ae5a1c9325
("qed: Add infrastructure support for tunneling")'
Signed-off-by: Manish Chopra <manish.chopra@qlogic.com>
Signed-off-by: Yuval Mintz <yuval.mintz@qlogic.com>
Remove old init callback which now contains only a call to
socfpga_dwmac_setup(). Also rename socfpga_dwmac_setup() to indicate
what the function really does.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
Tested-by: Marek Vasut <marex@denx.de>
Calling phy_resume() should only be need during driver resume to
workaround a hardware errata.
The dwmac-socfpga driver needs to control the reset usually managed
by the core driver to set the PHY mode. Take a copy of the reset
handle from core priv data so it can be used by the driver later.
This also allow us to move reset handling into socfpga_dwmac_setup()
where the code that needs it is located.
Implement the needed PM callbacks in the driver instead of
relying on the init/exit hooks in stmmac_platform. This gives
the driver more flexibility in how the code is organized.
Eventually the init/exit callbacks will be deprecated in favor
of the standard PM callbacks and driver remove function.
Change stmmac_remove/resume/suspend to take a device pointer so
they can be used directly by drivers that doesn't need to perform
anything device specific.
This lets us remove the PCI pm functions and later simplifiy the
platform drivers.
The ethtool api {get|set}_settings is deprecated.
We move the fec_mpc52xx driver to new api {get|set}_link_ksettings.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
We move the fs-enet driver to new api {get|set}_link_ksettings.
We move the ucc driver to new api {get|set}_link_ksettings.
We move the gianfar driver to new api {get|set}_link_ksettings.
The xgene_cle_ops structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Iyappan Subramanian <isubramanian@apm.com>
Aligning the reception data size is not required.
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
Signed-off-by: Yoshihiro Kaneko <ykaneko0929@gmail.com>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next
Kalle Valo says:
wireless-drivers patches for 4.7
Major changes:
brcmfmac
* add support for nl80211 BSS_SELECT feature
mwifiex
* add platform specific wakeup interrupt support
ath10k
* implement set_tsf() for 10.2.4 branch
* remove rare MSI range support
* remove deprecated firmware API 1 support
ath9k
* add module parameter to invert LED polarity
wcn36xx
* fixes to get the driver properly working on Dragonboard 410c
This patch gets ethernet to CPU channel (prefetch buffer number) from
the newly added 'channel' property, thus decoupling Linux driver from
resource management.
Signed-off-by: Iyappan Subramanian <isubramanian@apm.com>
This patch adds the qede implementation for internal loopback test.
Signed-off-by: Sudarsana Reddy Kalluru <sudarsana.kalluru@qlogic.com>
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
This patch adds the qede ethtool support for the following tests:
- interrupt test
- memory test
- register test
- clock test
This patch adds the functionality and APIs needed for selftests.
It adds the ability to configure the link-mode which is required for the
implementation of loopback tests. It adds the APIs for clock test,
register test, interrupt test and memory test.
The dsa_switch structure ds is actually needed in very few places,
mostly during setup of the switch. The private structure ps is however
needed nearly everywhere. Pass ps, not ds internally.
[vd: rebased Andrew's patch.]
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/next-queue
Jeff Kirsher says:
40GbE Intel Wired LAN Driver Updates 2016-05-01
This series contains updates to i40e and i40evf.
The theme of this series is code reduction, with several code cleanups in
this series. Starting with Neerav's removal of the code that implemented
the HMC AQ APIs and calls, since they are now obsolete and not supported
by firmware.
Anjali changes the default of VFs to make sure they are not trusted or
privileged until its explicitly set for trust through the new NDO op
interface. Also limited the number of MAC and VLAN addresses a VF can
add if it is untrusted/privileged.
Carolyn syncs the VF code for the changes made to the PF for the RSS
hash tuple settings, which ends up cleaning up much of the existing code.
Jesse cleans up compiler warnings which were found with gcc's W=2 option.
Then removed duplicate code, especially since only one copy was actually
being used.
Jacob addresses an issue which was found when testing GCC 6's which
happens to produce new warnings when you left shift a signed value
beyond the storage sizeof the type. The converts i40e & i40evf to use
the BIT() macro more consistently.
Alex actually bucks the trend of code removal by adding support for
both drivers to use GSO_PARTIAL so that segmentation of frames with
checksums enabled in outer headers is supported. Fortunately it does
not take much to add this support!
Since commit b74766a0a0fe ("phylib: don't return NULL
from get_phy_device()") in linux-next, phy_get_device() will return
ERR_PTR(-ENODEV) instead of NULL if the PHY device ID is all ones.
This causes problem with stmmac driver and likely some other drivers
which call mdiobus_register(). I triggered this bug on SoCFPGA MCVEVK
board with linux-next 20160427 and 20160428. In case of the stmmac, if
there is no PHY node specified in the DT for the stmmac block, the stmmac
driver ( drivers/net/ethernet/stmicro/stmmac/stmmac_mdio.c function
stmmac_mdio_register() ) will call mdiobus_register() , which will
register the MDIO bus and probe for the PHY.
The mdiobus_register() resp. __mdiobus_register() iterates over all of
the addresses on the MDIO bus and calls mdiobus_scan() for each of them,
which invokes get_phy_device(). Before the aforementioned patch, the
mdiobus_scan() would return NULL if no PHY was found on a given address
and mdiobus_register() would continue and try the next PHY address. Now,
mdiobus_scan() returns ERR_PTR(-ENODEV), which is caught by the
'if (IS_ERR(phydev))' condition and the loop exits immediately if the
PHY address does not contain PHY.
Repair this by explicitly checking for the ERR_PTR(-ENODEV) and if this
error comes around, continue with the next PHY address.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
This patch makes it so that i40e and i40evf can use GSO_PARTIAL to support
segmentation for frames with checksums enabled in outer headers. As a
result we can now send data over these types of tunnels at over 20Gb/s
versus the 12Gb/s that was previously possible on my system.
The advantage with the i40e parts is that this offload is mostly
transparent as the hardware still deals with the inner and/or outer IPv4
headers so the IP ID is still incrementing for both when this offload is
performed.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
GCC 6 has a new warning which will display when you attempt to left
shift a signed value beyond the storage size of the type. I40E_MASK
generates a mask value for 32bit registers. Properly typecast the mask
value and place the values in parenthesis to prevent macro expansion
issues.
Signed-off-by: Harshitha Ramamurthy <harshitha.ramamurthy@intel.com>
Add a device ID for X722.
Change-Id: I574f2345ab341de98a6a1c212d0603af853e48b0
Signed-off-by: Catherine Sullivan <catherine.sullivan@intel.com>
i40e_release_rx_desc was in two files, but was only used
and needed in txrx.c. Get rid of the extra copy.
Change-Id: I86e18239aa03531fc198b6c052847475084a9200
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
The driver was all over the place using signed or unsigned types
for vf_id, when it should always be signed.
This fixes warnings of type unsafe comparisons from gcc with W=2.
Change-Id: I2cb681f83d0f68ca124d2e4131e4ac0d9f8a6b22
Aggregate return warnings are when struct types are returned
and must be copied to the lvalue with a struct copy by the compiler.
This fixes warnings of type aggregate-return from gcc with W=2.
Change-Id: I896b1bf514544bf0faeb458869d79914b9f1b168
We have an uninitialized variable warning for valid_len for one case in
validate_vf_mesg. To fix this, just initialize it to 0 at the top of the
function and remove all of the now redundant assignments to 0 in the
individual cases.
Change-Id: Iacbd97f4c521ed8d662eef803a598d8707708cfd
This patch syncs the VF code for the changes made to the PF for the RSS
hash tuple settings. Since the VF still cannot change the RSS hash
settings, change the code to make this clear to the user. Previously,
the default settings were returned in this function. However, the
default can be changed by the PF so this does not make sense anymore.
Change-Id: I085eaf005fc7978b440d2a1bf2b2dd7cadaff39b
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Remove the code that implements the HMC AQ APIs and call these APIs.
This is done because these are obsolete APIs and are not supported
by firmware.
Change-ID: I5d771d8f37c3e16e7b0a972ff9b27e75aa2d05d4
Signed-off-by: Neerav Parikh <neerav.parikh@intel.com>
With this change a non trusted VF can never fall to promiscuous
mode when there is no room for a MAC/VLAN filter.
Change-Id: I8a155aa25c0bcdc6093414920c9ade4ee0bd20e8
Signed-off-by: Anjali Singhai Jain <anjali.singhai@intel.com>
If the VF is privileged/trusted it can do as it may please including
but not limited to hogging resources and playing unfair.
But if the VF is not privileged/trusted it still can add some number
(8) of MAC and VLAN addresses.
Other restrictions with respect to Port VLAN and normal VLAN still apply
to not privileged/trusted VF.
Change-Id: I3a9529201b184c8873e1ad2e300aff468c9e6296
Add a check whether the 'struct device_node' pointer passed to
of_mdiobus_register() is an available (aka enabled) node in the Device
Tree.
Rationale for doing this are cases where an Ethernet MAC provides a MDIO
bus controller and node, and an additional Ethernet MAC might be
connecting its PHY/switches to that first MDIO bus controller, while
still embedding one internally which is therefore marked as "disabled".
Instead of sprinkling checks like these in callers of
of_mdiobus_register(), do this in a central location.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Make sure a VF is not trusted/privileged until its explicitly
set for trust through the new NDO op interface.
Change-Id: I476385c290d2b4901d8fceb29de43546accdc499
Accelerated RFS requires that ntuple filtering is enabled via
ethtool and driver supports ndo_rx_flow_steer.
When the ntuple filtering is enabled, we modify the l3_l4 ttc
rules to point on the aRFS flow tables and when the filtering
is disabled, we modify the l3_l4 ttc rules to point on the RSS
TIRs.
Signed-off-by: Maor Gottlieb <maorg@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Implement ndo_rx_flow_steer ndo.
A new flow steering rule will be composed from the
skb 4-tuple and added to the hardware aRFS flow table.
Each rule is stored in an internal hash table, if such
skb 4-tuple rule already exists we update the corresponding
hardware steering rule with the new destination.
For garbage collection rps_may_expire_flow will be
invoked for a limited amount of old rules upon any
ndo_rx_flow_steer invocation.
Create the following four flow tables for aRFS usage:
1. IPv4 TCP - filtering 4-tuple of IPv4 TCP packets.
2. IPv6 TCP - filtering 4-tuple of IPv6 TCP packets.
3. IPv4 UDP - filtering 4-tuple of IPv4 UDP packets.
4. IPv6 UDP - filtering 4-tuple of IPv6 UDP packets.
Each flow table has two flow groups: one for the 4-tuple
filtering (full match) and the other contains * rule for miss rule.
Full match rule means a hit for aRFS and packet will be forwarded
to the dedicated RQ/Core, miss rule packets will be forwarded to
default RSS hashing.
Allocating CPU rmap and add entry for each IRQ.
CPU rmap is used in aRFS to get the RX queue number
of the RX completion interrupts.
Currently, the main flow table is used for two purposes:
One is to do mac filtering and the other is to classify
the packet l3-l4 header in order to steer the packet to
the right RSS TIR.
This design is very complex, for each configured mac address we
have to add eleven rules (rule for each traffic type), the same if the
device is put to promiscuous/allmulti mode.
This scheme isn't scalable for future features like aRFS.
In order to simplify it, the main flow table is split to two flow
tables:
1. l2 table - filter the packet dmac address, if there is a match
we forward to the ttc flow table.
2. TTC (Traffic Type Classifier) table - classify the traffic
type of the packet and steer the packet to the right TIR.
In this new design, when new mac address is added, the driver adds
only one flow rule instead of eleven.
Slightly refactor and re-order the flow steering structs,
tables and data-bases for better self-containment and
flexibility to add more future steering phases
(tables/rules/data bases) e.g: aRFS.
Changes:
1. Move the vlan DB and address DB into their table structs.
2. Rename steering table structs to unique format: mlx5e_*_table,
e.g: mlx5e_vlan_table.
Currently, namespace could be initialized only
with priorities with the same attributes.
Add support to initialize namespace with priorities
with different attributes(e.g. different number of levels).
Currently, consumers of the flow steering infrastructure can't
choose their own flow table levels and are limited to one
flow table per level. This just waste levels.
Instead, we introduce here the possibility to use multiple
flow tables in a level. The user is free to connect these
flow tables, while following the rule (FTEs in FT of level x
could only point to FTs of level y where y > x).
In addition this patch switch the order of the create/destroy
flow tables of the NIC(vlan and main).
Refactors the flow steering namespace creation,
by changing the name num_fts to num_levels.
When new flow table is created, the driver assign new level
to this flow table therefore the meaning is equivalent.
Since downstream patches will introduce the ability to create more
than one flow table per level, the name num_fts is no
longer accurate.
This API is used for modifying the flow rule destination.
This is needed for modifying the pointed flow table by the
traffic type classifier rules to point on the aRFS tables.
Introduce new TIRs for direct access per RQ.
Now we have 2 available kinds of TIRs:
- indirect TIR per traffic type, each points to one RQT (RSS RQT)
same as before.
- New direct TIR per RQ, each points to RQT with a size of one
that forwards packets to that RQ only.
Driver will open max channels (num cores) direct TIRs by default,
they will be filled with the actual RQs once channels are allocated.
Needed for downstream aRFS and ethtool direct steering functionalities.
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Hold the rtnl lock when calling vxlan_get_rx_port().
Fixes: b7aade15485a ("vxlan: break dependency with netdev drivers")
Signed-off-by: Matthew Finlay <matt@mellanox.com>
Reported-by: Alexander Duyck <alexander.duyck@gmail.com>
