- Group declarations for separate files (drm_bridge.c, drm_edid.c)
- Move declarations only used within drm.ko to drm_crtc_internal.h
- drm_property_type_valid to drm_crtc.c, its only callsite
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Emil Velikov <emil.l.velikov@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466499262-18717-2-git-send-email-daniel.vetter@ffwll.ch
There can only be one current master, and it's for the overall device.
Render/control minors don't support master-based auth at all.
This simplifies the master logic a lot, at least in my eyes: All these
additional pointer chases are just confusing.
While doing the conversion I spotted some locking fail:
- drm_lock/drm_auth check dev->master without holding the
master_mutex. This is fallout from
commit c996fd0b956450563454e7ccc97a82ca31f9d043
Author: Thomas Hellstrom <thellstrom@vmware.com>
Date: Tue Feb 25 19:57:44 2014 +0100
drm: Protect the master management with a drm_device::master_mutex v3
but I honestly don't care one bit about those old legacy drivers
using this.
- debugfs name info should just grab master_mutex.
- And the fbdev helper looked at it to figure out whether someone is
using KMS. We just need a consistent value, so READ_ONCE. Aside: We
should probably check if anyone has opened a control node too, but I
guess current userspace doesn't really do that yet.
v2: Balance locking, reported by Julia.
v3: Rebase on top of Chris' oops fixes.
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> (v2)
Reviewed-by: Emil Velikov <emil.l.velikov@gmail.com> (v2)
Link: http://patchwork.freedesktop.org/patch/msgid/1466499262-18717-1-git-send-email-daniel.vetter@ffwll.ch
Use drm_dev_alloc() and drm_dev_register() instead of .load()
To simplify init sequence only create fbdev when requested
in output_poll_changed().
version 2:
remove call to drm_connector_unregister_all() and
drm_dev_set_unique()
Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: http://patchwork.freedesktop.org/patch/msgid/1466514580-15194-4-git-send-email-benjamin.gaignard@linaro.org
Make sti driver use register callback to move debugfs
initialization out of sub-components creation.
This will allow to convert driver .load() to
drm_dev_alloc() and drm_dev_register().
sti_compositor bring up 2 crtc but only one debugfs init is
needed so use drm_crtc_index to do it on the first one.
This can't be done in sti_drv because only sti_compositor have
access to the devices.
It is almost the same for sti_encoder which handle multiple
encoder while one only debugfs entry is needed so add a boolean
to avoid multiple debugfs initialization
Link: http://patchwork.freedesktop.org/patch/msgid/1466514580-15194-3-git-send-email-benjamin.gaignard@linaro.org
- inline functions need to be static inline, otherwise gcc can opt to
not inline and the linker gets unhappy.
- no forward decls for inline functions, just include the right headers.
Cc: Oded Gabbay <oded.gabbay@gmail.com>
Cc: Ben Goz <ben.goz@amd.com>
Reviewed-by: Oded Gabbay <oded.gabbay@gmail.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466500235-21282-2-git-send-email-daniel.vetter@ffwll.ch
Like what has been done for connectors add callbacks on encoder,
crtc and plane to let driver do actions after drm device registration.
Correspondingly, add callbacks called before unregister drm device.
version 2:
add drm_modeset_register_all() and drm_modeset_unregister_all()
to centralize all calls
version 3:
in error case unwind registers in drm_modeset_register_all
fix uninitialed return value
inverse order of unregistration in drm_modeset_unregister_all
version 4:
move function definitions in drm_crtc_internal.h
remove not needed documentation
Link: http://patchwork.freedesktop.org/patch/msgid/1466519829-4000-1-git-send-email-benjamin.gaignard@linaro.org
Commit 7566e247672d ("drm/fsl-dcu: handle initialization errors properly")
introduced error handling during initialization, but with a wrong cleanup
order.
Replace the error handling with the generic cleanup function
drm_mode_config_cleanup.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20160619021543.23587-1-stefan@agner.ch
We get a harmless build warning when trying to use the mediatek DRM
driver with IOMMU support disabled:
warning: (DRM_MEDIATEK) selects IOMMU_DMA which has unmet direct dependencies (IOMMU_SUPPORT)
However, the IOMMU_DMA symbol is not meant to be used by drivers at all,
and this driver doesn't seem to have a strict dependency on it other
than using the mediatek IOMMU driver that does.
Since we also want to be able to do compile tests with the driver on
other platforms, the IOMMU_DMA symbol should not be selected here.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Link: http://patchwork.freedesktop.org/patch/msgid/1462997501-982363-1-git-send-email-arnd@arndb.de
Rockchip just blew up here on testing, because I removed some "is this
crtc already disabled/enabled" state tracking from callbacks (not needed
with atomic). Turns out that was needed to work around rockchip still
calling legacy helper code.
Since me explaining on irc/mailing-list plus kerneldoc isn't enough,
be more verbose and add dmesg output. Not that anyone actually reads that,
either.
Cc: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1465388359-8070-26-git-send-email-daniel.vetter@ffwll.ch
Up to now, the recommendation was for drivers to call drm_dev_register()
followed by drm_connector_register_all(). Now that
drm_connector_register() is safe against multiple invocations, we can
move drm_connector_register_all() to drm_dev_register() and not suffer
from any backwards compatibility issues with drivers not following the
more rigorous init ordering.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: David Airlie <airlied@linux.ie>
Cc: dri-devel@lists.freedesktop.org
Cc: linux-renesas-soc@vger.kernel.org
Tested-by: Archit Taneja <architt@codeaurora.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-8-git-send-email-chris@chris-wilson.co.uk
Cc: Rob Clark <robdclark@gmail.com>
Cc: linux-arm-msm@vger.kernel.org
Cc: freedreno@lists.freedesktop.org
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-7-git-send-email-chris@chris-wilson.co.uk
Cc: Matthias Brugger <matthias.bgg@gmail.com>
Cc: linux-mediatek@lists.infradead.org
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-6-git-send-email-chris@chris-wilson.co.uk
Cc: Xinliang Liu <z.liuxinliang@hisilicon.com>
Cc: Xinwei Kong <kong.kongxinwei@hisilicon.com>
Cc: Chen Feng <puck.chen@hisilicon.com>
Acked-by: Xinliang Liu <z.liuxinliang@hisilicon.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-5-git-send-email-chris@chris-wilson.co.uk
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-4-git-send-email-chris@chris-wilson.co.uk
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-3-git-send-email-chris@chris-wilson.co.uk
Currently the driver calls drm_dev_register() directly after allocating
the DRM device and then continues with further initialization. This is
incorrect, because drm_dev_register() is supposed to be called after all
initialization is done. This problem was masked by the fact that
drm_dev_register() did not use to do anything special before, but
recently it started to call drm_connector_register_all(), which leads to
a crash if the driver is not fully initialized.
This patch fixes the problem by moving the call to drm_dev_register() to
the end of the initialization sequence and also removing the, now
unnecessary, call to drm_connector_register_all() from driver code.
Fixes: f706974a69b6 ("drm/rockchip: Drop drm_driver.load/unload callbacks")
Signed-off-by: Tomasz Figa <tfiga@chromium.org>
[danvet: Fix up cleanup labels a bit.]
Link: http://patchwork.freedesktop.org/patch/msgid/1466483254-35373-1-git-send-email-tfiga@chromium.org
It's a legacy helper function which won't do good with atomic helpers.
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1465510479-21180-1-git-send-email-daniel.vetter@ffwll.ch
Again this is neatly protected by the dev->master_mutex now. There is
a driver callback both for set and drop, but it's only used by vmwgfx.
And vmwgfx has it's own solid locking for shared resources (besides
dev->master_mutex), hence is all safe. Let's drop another place where
the drm legacy bkl is used.
Link: http://patchwork.freedesktop.org/patch/msgid/1466148814-8194-6-git-send-email-daniel.vetter@ffwll.ch
All protected by dev->master_mutex. And there's no driver callbacks,
which means no need to sync with old dri1 horror show drivers at all.
Hence safe to drop the drm legacy BKL from these paths.
Link: http://patchwork.freedesktop.org/patch/msgid/1466148814-8194-5-git-send-email-daniel.vetter@ffwll.ch
Simplifies cleanup, and there's no reason drivers should ever care
about authmagic at all - it's all handled in the core.
And with that, Ladies and Gentlemen, it's time to pop the champagen
and celebrate: dev->struct_mutex is now officially gone from modern
drivers, and if a driver is using gem_free_object_unlocked and doesn't
do anything else silly it's positively impossible to ever touch
dev->struct_mutex at runtime, anywhere.
Well except for the mutex_init on driver load ;-)
v2: Rebased.
Cc: Chris Wilson <chris@chris-wilson.co.uk> (v1)
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> (v1)
Link: http://patchwork.freedesktop.org/patch/msgid/1466148814-8194-4-git-send-email-daniel.vetter@ffwll.ch
It's related, and soon authmagic will also use the master_mutex.
There is an ever-so-slightly semantic change here:
- authmagic will only be cleaned up for primary_client drm_minors. But
it's impossible to create authmagic on render/control nodes, so this
is fine.
- The cleanup is moved down a bit in the release processing. Doesn't
matter at all since authmagic is purely internal logic used by the
core ioctl access checks, and when we're in a file's release
callback no one can do ioctls any more.
v2: Rebased.
Link: http://patchwork.freedesktop.org/patch/msgid/1466148814-8194-3-git-send-email-daniel.vetter@ffwll.ch
Another place gone where modern drivers could have hit
dev->struct_mutex.
To avoid too deeply nesting control flow rework it a bit.
v2: Review from Chris:
- remove spurious newline.
- fix file_priv->master like for the !file_priv->is_master case.
Link: http://patchwork.freedesktop.org/patch/msgid/1466148814-8194-2-git-send-email-daniel.vetter@ffwll.ch
If a driver does not have a parent, or never sets the unique name for
itself, then we may proceed to chase a NULL dereference through
debugfs/.../name.
Testcase: igt/vgem_basic/debugfs
Link: http://patchwork.freedesktop.org/patch/msgid/1466448813-23340-1-git-send-email-chris@chris-wilson.co.uk
The drm_pending_event can be freed by drm_send_event_locked, as a
result we should call trace_drm_vblank_event_delivered before this
to avoid hitting a user-after-free error when accessing the pid member:
[ 378.438497] BUG: KASAN: use-after-free in send_vblank_event+0xf0/0x310 [drm] at addr ffff8801ac7e50a0
[ 378.438500] Read of size 4 by task Xorg/1562
[ 378.438501] =============================================================================
[ 378.438504] BUG kmalloc-128 (Tainted: G B ): kasan: bad access detected
[ 378.438506] -----------------------------------------------------------------------------
[ 378.438509] INFO: Freed in 0x10001309c age=18446737369265680575 cpu=0 pid=0
[ 378.438541] drm_send_event_locked+0x207/0x2f0 [drm]
[ 378.438544] __slab_free+0x24c/0x650
[ 378.438546] kfree+0x3a2/0x760
[ 378.438578] drm_send_event_locked+0x207/0x2f0 [drm]
[ 378.438610] send_vblank_event+0xb7/0x310 [drm]
[ 378.438643] drm_crtc_send_vblank_event+0x130/0x1f0 [drm]
[ 378.438722] intel_atomic_commit_tail+0x23b5/0x53f0 [i915]
[ 378.438802] intel_atomic_commit+0xbae/0x12f0 [i915]
[ 378.438839] drm_atomic_commit+0xb0/0x120 [drm]
[ 378.438855] drm_atomic_helper_connector_dpms+0x339/0x5d0 [drm_kms_helper]
[ 378.438891] drm_mode_obj_set_property_ioctl+0x8f1/0xcc0 [drm]
[ 378.438927] drm_mode_connector_property_set_ioctl+0xf3/0x170 [drm]
[ 378.438959] drm_ioctl+0x2d7/0xae0 [drm]
[ 378.438962] do_vfs_ioctl+0x1c9/0x1280
[ 378.438964] SyS_ioctl+0x79/0x90
[ 378.438967] entry_SYSCALL_64_fastpath+0x1a/0xa4
Cc: Daniel Vetter <daniel.vetter@intel.com>
Signed-off-by: Matthew Auld <matthew.auld@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466440966-5410-1-git-send-email-matthew.auld@intel.com
There is only a single user of dma_buf_debugfs_create_file() and that
one got the function pointer cast wrong. With that one fixed, there is
no need to have a wrapper for debugfs_create_file(), just call it
directly.
With no users left, we can remove dma_buf_debugfs_create_file().
While at it, simplify the error handling in dma_buf_init_debugfs()
slightly.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1466339491-12639-2-git-send-email-minipli@googlemail.com
Change the error handling in dma_buf_init_debugfs() to remove the
"dma_buf" directory if creating the "bufinfo" file fails. No need to
have an empty debugfs directory around.
The callback function dma_buf_describe() returns an int not void so the
function pointer cast in dma_buf_show() is wrong. dma_buf_describe() can
also fail when acquiring the mutex gets interrupted so always returning
0 in dma_buf_show() is wrong, too.
Fix both issues by avoiding the indirection via dma_buf_show() and call
dma_buf_describe() directly. Rename it to dma_buf_debug_show() to get it
in line with the other functions.
This type mismatch was caught by the PaX RAP plugin.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
The drm_dp_aux is associated with the intel_dp encoder and not the
connector. Since the encoder is destroyed before the connector,
attempting to free the drm_dp_aux from inside the connector cleanup
causes a use-after-free.
This was applied to the patch that CI was happy with, but in the
confusion of so many series trying to make CI happy, the unready
patch was plucked.
Fixes: c191eca110a3 ("drm/i915: Move intel_connector->unregister to connector->early_unregister")
Link: http://patchwork.freedesktop.org/patch/msgid/1466411357-730-1-git-send-email-chris@chris-wilson.co.uk
Currently the backlight is being unregistered in the unload phase (after
the display and its objects are unregistered). Move the backlight
unregistration into the analogous phase by performing it from the
connector unregistration, just prior to its deletion.
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466160034-12173-3-git-send-email-chris@chris-wilson.co.uk
We now have a connector->func that serves the same purpose as our own
intel_connector->unregister vfunc allowing us to unwrap ourselves and
use drm_connector_register() (and friends) as the central function.
Link: http://patchwork.freedesktop.org/patch/msgid/1466160034-12173-2-git-send-email-chris@chris-wilson.co.uk
0-day kbuilder found
[ 1.360244] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1.360972] IP: [<c14db9ad>] mutex_lock_nested+0x11f/0x2c3
[ 1.361512] *pde = 00000000
[ 1.361827] Oops: 0002 [#1]
[ 1.362123] Modules linked in:
[ 1.362451] CPU: 0 PID: 1 Comm: swapper Not tainted 4.7.0-rc2-00564-ge28cd4d #1
[ 1.363202] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Debian-1.8.2-1 04/01/2014
[ 1.364105] task: c03d0000 ti: d28da000 task.ti: d28da000
[ 1.364636] EIP: 0060:[<c14db9ad>] EFLAGS: 00210096 CPU: 0
[ 1.365215] EIP is at mutex_lock_nested+0x11f/0x2c3
[ 1.365703] EAX: 00000000 EBX: d39e8ae8 ECX: d39e8b14 EDX: c1361cf9
[ 1.366351] ESI: c03d0000 EDI: d28dbed0 EBP: d28dbeec ESP: d28dbec0
[ 1.367010] DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
[ 1.367534] CR0: 80050033 CR2: 00000000 CR3: 019a9000 CR4: 00000690
[ 1.368152] Stack:
[ 1.368356] d39e8b14 d39e8b24 c1361cf9 00200246 d39e8b14 00000000 11111111 d28dbed0
[ 1.369235] d39e8800 d39e8ae8 00000000 d28dbf08 c1361cf9 d28dbf0c c10b25be d39e8800
[ 1.370087] 00000000 00000000 d28dbf1c c135e37d fffffff4 ffffffff 00000000 d28dbf28
[ 1.371012] Call Trace:
[ 1.371272] [<c1361cf9>] ? drm_connector_register_all+0x1a/0x92
[ 1.371847] [<c1361cf9>] drm_connector_register_all+0x1a/0x92
[ 1.372421] [<c10b25be>] ? kstrdup+0x25/0x3a
[ 1.372863] [<c135e37d>] drm_dev_register+0x59/0x99
[ 1.373358] [<c195ea3e>] vgem_init+0x34/0x49
[ 1.373770] [<c195ea0a>] ? mipi_dsi_bus_init+0xf/0xf
[ 1.374257] [<c100048f>] do_one_initcall+0x7c/0xfd
[ 1.374754] [<c104b409>] ? parse_args+0x1fd/0x314
[ 1.375259] [<c1939c10>] ? kernel_init_freeable+0xd0/0x179
[ 1.375837] [<c1939c2c>] kernel_init_freeable+0xec/0x179
[ 1.376371] [<c14d66ea>] kernel_init+0x8/0xcb
[ 1.376806] [<c14debce>] ret_from_kernel_thread+0xe/0x30
[ 1.377322] [<c14d66e2>] ? rest_init+0x10e/0x10e
[ 1.377754] Code: 89 fa e8 71 c5 b7 ff 8b 4e 04 89 fa 89 d8 e8 8e c6 b7 ff 8d 43 2c 89 45 d4 8b 43 30 8d 4b 2c 89 45 e8 89 7b 30 89 4d e4 8b 55 dc <89> 38 8d 43 3c 89 75 ec e8 c9 dd b7 ff eb 0c 31 c0 87 03 48
+75
[ 1.380442] EIP: [<c14db9ad>] mutex_lock_nested+0x11f/0x2c3 SS:ESP 0068:d28dbec0
[ 1.381174] CR2: 0000000000000000
when loading the non-modesetting vGEM module. To prevent use of the
uninitialised dev->mode_config from drm_dev_register() we move the
drm_connector_register_all() under a DRIVER_MODESET guard. Longer term,
we probably want to initialise the embedded dev->mode_config automatically
from drm_dev_init() for all DRIVER_MODESET drivers.
v2: Also protect drm_dev_unregister.
Fixes: e28cd4d0a223 ("drm: Automatically register/unregister all connectors")
Cc: Emil Velikov <emil.l.velikov@gmail.com>
Testcase: igt/vgem_reload_basic
Link: http://patchwork.freedesktop.org/patch/msgid/1466257601-5656-1-git-send-email-chris@chris-wilson.co.uk
drm_plane_helper_check_update() needs to account for the plane rotation
for correct clipping/scaling calculations. Do so.
There was an earlier attempt [1] to add this into
intel_check_primary_plane() but I requested that it'd be put into the
helper instead. An updated patch never materialized AFAICS, so I went
ahead and cooked one up myself.
v2: Deal with new drm_plane_helper_check_update() callers
[1] https://patchwork.freedesktop.org/patch/65177/
Cc: Nabendu Maiti <nabendu.bikash.maiti@intel.com>
Cc: Noralf Trønnes <noralf@tronnes.org>
Cc: CK Hu <ck.hu@mediatek.com>
Cc: Mark Yao <mark.yao@rock-chips.com>
Cc: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1466172790-10025-1-git-send-email-ville.syrjala@linux.intel.com
As the drm_connector is now safe for multiple calls to
register/unregister, automatically perform a registration on all known
connectors drm drv_register (and unregister from drm_drv_unregister).
Drivers can still call drm_connector_register() and
drm_connector_unregister() individually, or defer as required.
Link: http://patchwork.freedesktop.org/patch/msgid/1466151923-1572-2-git-send-email-chris@chris-wilson.co.uk
When trying to split up the initialisation phase and the registration
phase, one immediate problem encountered is trying to use our own i2c
devices before registration with userspace (to read EDID during device
discovery). drm_dp_aux in particular only offers an interface for setting
up the device *after* we have exposed the connector via sysfs. In order
to break the chicken-and-egg problem, export drm_dp_aux_init() to
minimally prepare the i2c device for internal use before
drm_connector_register().
Cc: Dave Airlie <airlied@redhat.com>
Cc: Rafael Antognolli <rafael.antognolli@intel.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
[danvet: Amend kerneldoc slightly.]
Link: http://patchwork.freedesktop.org/patch/msgid/1466152398-20157-3-git-send-email-chris@chris-wilson.co.uk
Rather than have both drm_dp_aux lock within its transfer, and i2c to
lock around the transfer, use the same lock by filling in the locking
callbacks that i2c wants to use. We require our own hw_mutex as we
bypass i2c_transfer for drm_dp_dpcd_access().
Link: http://patchwork.freedesktop.org/patch/msgid/1466152398-20157-2-git-send-email-chris@chris-wilson.co.uk
Atomic drivers are supposed to do hw/sw state reset with the
drm_mode_config_reset() call right above it.
Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Acked-by: Benjamin Gaignard <benjamin.gaignard@linaro.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1464818821-5736-38-git-send-email-daniel.vetter@ffwll.ch
As we now can call drm_connector_unregister() multiple times, provide a
failsafe unregister for a connector when cleaning it up.
v2: Add a WARN to catch any connectors that are still visible to
userspace when we come to destoy them.
Link: http://patchwork.freedesktop.org/patch/msgid/1465993109-19523-5-git-send-email-chris@chris-wilson.co.uk
Protect against drivers that may try to register the connector more
than once, or who try to unregister it multiple times.
Link: http://patchwork.freedesktop.org/patch/msgid/1465993109-19523-4-git-send-email-chris@chris-wilson.co.uk
If a driver wants to more precisely control its initialisation and in
particular, defer registering its interfaces with userspace until after
everything is setup, it also needs to defer registering the connectors.
As some devices need more work during registration, add a callback so
that drivers can do additional work if required for a connector.
Correspondingly, we also require an unregister callback.
[danvet: go ocd and remvoe unecessary empty kerneldoc line.]
Link: http://patchwork.freedesktop.org/patch/msgid/1465993109-19523-3-git-send-email-chris@chris-wilson.co.uk
In order to allow drivers to pack their privates and drm_device into one
struct (e.g. for subclassing), export the initialisation routines for
struct drm_device.
v2: Missed return ret. That error path had only one job to do!
v3: Cross-referencing drm_dev_init/drm_dev_alloc in kerneldoc, fix
missed error code for goto err_minors.
Link: http://patchwork.freedesktop.org/patch/msgid/1465993109-19523-2-git-send-email-chris@chris-wilson.co.uk
The rockchip drm driver started using drm_gem_cma_vm_ops, but that might
not be part of the kernel, causing the link to fail:
drivers/gpu/built-in.o:(.data+0xb234): undefined reference to `drm_gem_cma_vm_ops'
This adds a Kconfig 'select' statement to enable it like the other
user do.
Fixes: 80f67cd80add ("drm/rockchip: Use cma gem vm ops")
Link: http://patchwork.freedesktop.org/patch/msgid/20160616122800.1174015-1-arnd@arndb.de
Like with drm_master_open protect it with a check for primary_client
to make it clear that this can't happen on render/control nodes.
Link: http://patchwork.freedesktop.org/patch/msgid/1465930269-7883-7-git-send-email-daniel.vetter@ffwll.ch
And pull out the primary_client check to make it really obvious that
this can't happen on control/render nodes. Bonus that we can avoid the
master lock in this case.
v2: Don't leak locks on error path (and simplify control flow while
at it), reported by Julia.
Link: http://patchwork.freedesktop.org/patch/msgid/1465930269-7883-6-git-send-email-daniel.vetter@ffwll.ch
For modern drivers pretty much the only thing drm_master does is
handling authentication for the primary/legacy drm_minor node. Instead
of having it all over drm files, move it all together into drm_auth.c.
This patch just does code-motion, follow up patches will also extract
the master logic from file open&release paths.
Reviewed-by: Chris Wilson Mchris@chris-wilson.co.uk>
Link: http://patchwork.freedesktop.org/patch/msgid/1465930269-7883-5-git-send-email-daniel.vetter@ffwll.ch
Master-based auth only exists for the legacy/primary drm_minor, hence
there can only be one per device. The goal here is to untangle the
epic dereference games of minor->master and master->minor which is
just massively confusing.
Link: http://patchwork.freedesktop.org/patch/msgid/1465930269-7883-4-git-send-email-daniel.vetter@ffwll.ch
A few things:
- Rename the cleanup function from drm_master_release to
drm_legacy_lock_release. It doesn't relase any master stuff, but
just the legacy hw lock.
- Hide it in drm_lock.c, which allows us to make a few more functions
static in there. To avoid forward decl we need to shuffle the code a
bit though.
- Push the check for ->master into the function itself.
- Only call this for !DRIVER_MODESET.
End result: Another place that takes struct_mutex gone for good for
modern drivers.
v2: Remove leftover comment.
Link: http://patchwork.freedesktop.org/patch/msgid/1465930269-7883-3-git-send-email-daniel.vetter@ffwll.ch
GEM stopped using those a while ago, and no one should ever
need to use them again to debug legacy horror show drivers.
Nuke it all. Aside: It would kinda be nice if we'd have some
generic debugfs dumps for at least kms ...
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Acked-by: Emil Velikov <emil.l.velikov@gmail.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1465930269-7883-2-git-send-email-daniel.vetter@ffwll.ch
git://anongit.freedesktop.org/drm-intel into drm-next
- best_encoder cleanup from Boris.
- drm_simple_display_pipe helpers from Noralf. Looks really neat imo, and
there's 2-3 in-flight drivers which look like they could/should use it.
Anyway, with this we have now helpers and everything in place to write
drivers for simple hw with fewer complexity in the driver than what
fbdev would need. That was the last complaint I've heard from embedded
folks after we made atomic happen. Mission accomplished!
- nonblocking commit helpers for atomic, plus a bunch of driver patches
for that.
- Prep patch from Laurent for cleaned up pixel format functions.
- More of Gustavo's cleanup for drm vblank functions.
- and a few oddball things in between
Plus the merge of docs-next to prep the docbook->sphinx conversion as
discussed. Jon cc'ed as fyi.
* tag 'topic/drm-misc-2016-06-15' of git://anongit.freedesktop.org/drm-intel: (108 commits)
drm/atomic-helpers: Clear up cleanup_done a bit
drm/atomic-helpers: Stall on the right commit
drm/vmwgfx: use *_32_bits() macros
drm/virtio: Don't reinvent a flipping wheel
drm/i915: Fix missing unlock on error in i915_ppgtt_info()
drm/gma500: use drm_crtc_vblank_{on,off}()
drm/radeon: use crtc directly in drm_crtc_vblank_put()
drm/amdgpu: use crtc directly in drm_crtc_vblank_put()
drm/radeon: use drm_crtc_vblank_{on,off}()
drm/amdgpu: use drm_crtc_vblank_{on,off}()
drm: make drm_vblank_{get,put}() static
drm: remove legacy drm_arm_vblank_event()
drm: remove legacy drm_send_vblank_event()
drm/nouveau: replace legacy vblank helpers
drm/prime: fix error path deadlock fail
drm/dsi: Add uevent callback
drm: fb: cma: fix memory leak
drm: i915: Rely on the default ->best_encoder() behavior where appropriate
drm: Add helper for simple display pipeline
drm/bridge: dw-hdmi: Use drm_atomic_helper_best_encoder()
It's not obvious at first sight that this is a fastpath, make that
clearer with a goto. Fallout from a discussion with Liviu on irc.
v2: Drop bogus hunks that crept in.
v3: Make it compile.
Cc: Liviu.Dudau@arm.com
Acked-by: Liviu.Dudau@arm.com
Link: http://patchwork.freedesktop.org/patch/msgid/1465986266-2831-1-git-send-email-daniel.vetter@ffwll.ch
stall_checks carefully picked out the right commit to stall on, then
promptly used the wrong variable. Due to the break in the next loop
iteration this could be the 3rd commit, or if the list only has 2
entries commit would now point into the struct drm_crtc itself, at
some offset. Hilarity eventually ensues.
For added safety, also break right away instead of iterating once
more, but the real fix is waiting on stall_commit instead of commit.
Reported-and-tested-by: Liviu Dudau <Liviu.Dudau@arm.com>
Cc: Liviu Dudau <Liviu.Dudau@arm.com>
Reviewed-by: Liviu Dudau <Liviu.Dudau@arm.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1465926658-10110-1-git-send-email-daniel.vetter@ffwll.ch
