path: root/drivers
2008-10-31amd8111e: fix dma_free_coherent contextChunbo Luo
Acoording commit aa24886e379d2b641c5117e178b15ce1d5d366ba, dma_free_coherent() need irqs enabled. This patch fix following warning messages: WARNING: at linux/arch/x86/kernel/pci-dma.c:376 dma_free_coherent+0xaa/0xb0() Call Trace: [<ffffffff8023f80f>] warn_on_slowpath+0x5f/0x90 [<ffffffff80496ffa>] ? __kfree_skb+0x3a/0xa0 [<ffffffff802a4723>] ? discard_slab+0x23/0x40 [<ffffffff8021274a>] dma_free_coherent+0xaa/0xb0 [<ffffffff8043668f>] amd8111e_close+0x10f/0x1b0 [<ffffffff8049f3ae>] dev_close+0x5e/0xb0 [<ffffffff8049efa1>] dev_change_flags+0xa1/0x1e0 [<ffffffff806b2171>] ic_close_devs+0x36/0x4e [<ffffffff806b29ee>] ip_auto_config+0x581/0x10f3 [<ffffffff803a6e19>] ? kobject_add+0x69/0x90 [<ffffffff803a698a>] ? kobject_get+0x1a/0x30 [<ffffffff803a785b>] ? kobject_uevent+0xb/0x10 [<ffffffff803a6c62>] ? kset_register+0x52/0x60 [<ffffffff803a6f9b>] ? kset_create_and_add+0x6b/0xa0 [<ffffffff804e2e74>] ? tcp_ca_find+0x24/0x50 [<ffffffff806b246d>] ? ip_auto_config+0x0/0x10f3 [<ffffffff8020903c>] _stext+0x3c/0x150 [<ffffffff802772d3>] ? register_irq_proc+0xd3/0xf0 [<ffffffff802f0000>] ? mb_cache_create+0x80/0x1f0 [<ffffffff80688693>] kernel_init+0x141/0x1b8 [<ffffffff80688552>] ? kernel_init+0x0/0x1b8 [<ffffffff8020d609>] child_rip+0xa/0x11 [<ffffffff80688552>] ? kernel_init+0x0/0x1b8 [<ffffffff80688552>] ? kernel_init+0x0/0x1b8 [<ffffffff8020d5ff>] ? child_rip+0x0/0x11 Signed-off-by: Chunbo Luo <chunbo.luo@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31atl1: fix vlan tag regressionJay Cliburn
Commit 401c0aabec4b97320f962a0161a846d230a6f7aa introduced a regression in the atl1 driver by storing the VLAN tag in the wrong TX descriptor field. This patch causes the VLAN tag to be stored in its proper location. Tested-by: Ramon Casellas <ramon.casellas@cttc.es> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31SMC91x: delete unused local variable "lp"Mike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31myri10ge: fix stop/go mmio orderingBrice Goglin
Use mmiowb() to ensure "stop" and "go" commands are sent in order on ia64. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31bonding: fix panic when taking bond interface down before removing moduleAndy Gospodarek
A panic was discovered with bonding when using mode 5 or 6 and trying to remove the slaves from the bond after the interface was taken down. When calling 'ifconfig bond0 down' the following happens: bond_close() bond_alb_deinitialize() tlb_deinitialize() kfree(bond_info->tx_hashtbl) bond_info->tx_hashtbl = NULL Unfortunately if there are still slaves in the bond, when removing the module the following happens: bonding_exit() bond_free_all() bond_release_all() bond_alb_deinit_slave() tlb_clear_slave() tx_hash_table = BOND_ALB_INFO(bond).tx_hashtbl u32 next_index = tx_hash_table[index].next As you might guess we panic when trying to access a few entries into the table that no longer exists. I experimented with several options (like moving the calls to tlb_deinitialize somewhere else), but it really makes the most sense to be part of the bond_close routine. It also didn't seem logical move tlb_clear_slave around too much, so the simplest option seems to add a check in tlb_clear_slave to make sure we haven't already wiped the tx_hashtbl away before searching for all the non-existent hash-table entries that used to point to the slave as the output interface. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31bonding: Clean up resource leaksJay Vosburgh
This patch reworks the resource free logic performed at the time a bonding device is released. This (a) closes two resource leaks, one for workqueues and one for multicast lists, and (b) improves commonality of code between the "destroy one" and "destroy all" paths by performing final free activity via destructor instead of explicitly (and differently) in each path. "Sean E. Millichamp" <sean@bruenor.org> reported the workqueue leak, and included a different patch. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31bonding: fix miimon failure counterJay Vosburgh
During the rework of the mii monitor for: commit f0c76d61779b153dbfb955db3f144c62d02173c2 Author: Jay Vosburgh <fubar@us.ibm.com> Date: Wed Jul 2 18:21:58 2008 -0700 bonding: refactor mii monitor I left out the increment of the link failure counter. This patch corrects that omission. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-28amd8111e: Fix rx return codeChris Friesen
The amd8111e rx poll routine currently mishandles the case when we process exactly the number of packets specified in the budget. This patch is basically as suggested by David Miller. Signed-off-by: Chris Friesen <cfriesen@nortel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28Merge branch 'davem-fixes' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-10-27p54: fix build warningsChristian Lamparter
On Saturday 25 October 2008 10:24:10 Johannes Berg wrote: > just FYI in case you haven't seen them. the p54 one looks like a genuine > problem. > > drivers/net/wireless/p54/p54common.c: In function ‘p54_parse_eeprom’: > drivers/net/wireless/p54/p54common.c:325: warning: ‘synth’ may be used uninitialized in this function There you go. Yes, it is a genuine problem, if the device's eeprom is screwed really up. Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27ath5k: Reset key cache on interface up, thus fixing resumeElias Oltmanns
After a s2ram / resume cycle, resetting the key cache does not work unless it is deferred until after the hardware has been reinitialised by a call to ath5k_hw_reset(). This fixes a regression introduced by "ath5k: fix suspend-related oops on rmmod". Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27p54: fix misbehavings when firmware can't be foundChristian Lamparter
This patch fixes a double-free error in p54pci ( http://bugzilla.kernel.org/show_bug.cgi?id=11782 ) Trying to free already-free IRQ 10 Pid: 108, comm: pccardd Not tainted 2.6.27-05577-g0cfd810-dirty #1 Call Trace:  [<c01265dc>] free_irq+0xad/0xb9  [<c01050dd>] dma_generic_alloc_coherent+0x0/0xd7  [<c01ba8e6>] p54p_stop+0x4a/0x1fa  [<c01050dd>] dma_generic_alloc_coherent+0x0/0xd7  [<c02348c5>] p54p_probe+0x23e/0x302 Tested-by: Sean Young Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27dm9601: runtime mac address change supportPeter Korsgaard
Implement set_mac_address for runtime mac address change. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27via-velocity: use driver string instead of dev->name before register_netdev()Sven Hartge
This patch corrects a message bug in the via-velocity driver which bothered me for some time. The messages printed during device init look like the following: [ 8.486422] eth%d: set value of parameter Wake On Lan options to 0 ^^! [ 8.487340] eth0: VIA Networking Velocity Family Gigabit Ethernet Adapter Note the unresolved format string. dev->name is unavailable before register_netdev, so use dev_driver_string(&pdev->dev), which is also consistent with other drivers. "char *devname" parameters had to be converted to "const char *devname" to be consistent with dev_driver_string return value. Signed-off-by: Sven Hartge <sven@svenhartge.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27drivers/net/wan/syncppp: Fix unused-var warningsJeff Garzik
Fix !CONFIG_INET warnings. Spotted, and original patch authored by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27mlx4: Setting the correct offset for default mac addressYevgeny Petrilin
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27mlx4_en: remove duplicated #includeHuang Weiyi
Removed duplicated #include <linux/cpumask.h> in drivers/net/mlx4/en_main.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ibm_newemac: Fix typo in flow control config optionJosh Boyer
The recent build fix for ibm_newemac has a typo in the config option #ifdef used for disabling flow control. This corrects it to the proper Kconfig option name. Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ehea: Detect 16GB hugepages for firmware restrictionThomas Klein
All kernel memory which is used for kernel/hardware data transfer must be registered with firmware using "memory regions". 16GB hugepages may not be part of a memory region due to firmware restrictions. This patch modifies the walk_memory_resource callback fn to filter hugepages and add only standard memory to the busmap which is later on used for MR registration. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27dmfe: check pci_alloc_consistent errorsFUJITA Tomonori
We need to check the address that pci_alloc_consistent() returns since it might fail. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27qeth: avoid skb_under_panic for malformatted inbound dataUrsula Braun
To make the qeth driver more robust in case of malformatted inbound packets due to hardware problems, an additional check for OSN-card-type is added for OSN-type packets. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27qeth: remove unnecessary support ckeck in sysfs route6Frank Blaschka
Removing this check improves usability because you do not have to set the device online to initially set ipv6 routing option. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27qeth: fix offset error in non prealloc header pathFrank Blaschka
For the non preallocated qeth header code path we should not change the header length. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27qeth: remove non-recover-thread checkingsUrsula Braun
IP-threads have been removed from the qeth driver. Only the recover-thread is left over. This makes checkings for non-recover threads superfluous. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-26libertas: free sk_buff with kfree_skbSergio Luis
free sk_buff with kfree_skb, instead of kree Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-26btsdio: free sk_buff with kfree_skbSergio Luis
2008-10-26Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: allow extended partitions on md devices. md: use sysfs_notify_dirent to notify changes to md/dev-xxx/state md: use sysfs_notify_dirent to notify changes to md/array_state
2008-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: psmouse - add support for Elantech touchpads Input: i8042 - add Blue FB5601 to noloop exception table
2008-10-26Merge branch 'for-linus' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-mfd: mfd: Make WM8400 depend on I2C until SPI is submitted mfd: add missing Kconfig entry for da903x
2008-10-26Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: uwb: build UWB before USB/WUSB
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: Add support for Sony Vaio VGX-TP1E HID: fix lock imbalance in hiddev HID: fix lock imbalance in hidraw HID: fix hidbus/appletouch device binding regression HID: add hid_type to general hid struct HID: quirk for OLED devices present in ASUS G50/G70/G71 HID: Remove "default m" for Thrustmaster and Zeroplus HID: fix hidraw_exit section mismatch HID: add support for another Gyration remote control Revert "HID: Invert HWHEEL mappings for some Logitech mice"
2008-10-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: leds-hp-disk: fix build warning ACPI: Oops in ACPI with git latest ACPI suspend: build fix for ACPI_SLEEP=n && XEN_SAVE_RESTORE=y. toshiba_acpi: always call input_sync() after input_report_switch() ACPI: Always report a sync event after a lid state change ACPI: cpufreq, processor: fix compile error in drivers/acpi/processor_perflib.c i7300_idle: Fix compile warning CONFIG_I7300_IDLE_IOAT_CHANNEL not defined i7300_idle: Cleanup based review comments i7300_idle: Disable ioat channel only on platforms where ile driver can load
2008-10-26m68k: Disable Amiga serial console support if modularGeert Uytterhoeven
If CONFIG_AMIGA_BUILTIN_SERIAL=m, I get the following warnings: | drivers/char/amiserial.c: At top level: | drivers/char/amiserial.c:2138: warning: data definition has no type or storage class | drivers/char/amiserial.c:2138: warning: type defaults to 'int' in declaration of 'console_initcall' | drivers/char/amiserial.c:2138: warning: parameter names (without types) in function declaration | drivers/char/amiserial.c:2134: warning: 'amiserial_console_init' defined but not used because console_initcall() is not defined (nor really sensible) in the modular case. So disable serial console support if the driver is modular. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (abituguru3) enable DMI probing feature on AW9D-MAX hwmon: (abituguru3) Cosmetic whitespace fixes hwmon: (adt7473) Fix voltage conversion routines hwmon: (lm90) Add support for the LM99 16 degree offset hwmon: (lm90) Fix handling of hysteresis value hwmon-vid: Add support for AMD family 10h CPUs hwmon: (w83781d) Fix linking when built-in
2008-10-26r8169: revert "read MAC address from EEPROM on init"Francois Romieu
This reverts commit 7bf6bf4803df1adc927f585168d2135fb019c698. The code has both a short existence and an increasing track of failures despite some work to amend it for -rc1. It is not just a matter of reading the eeprom: sometimes the eeprom is read correctly, then the mac address is not written correctly back into the mac registers. Some chipsets seem to work reliably but it is not clear at this point if the code can simply be made to work on a per-chipset basis and post -rc1 is not the place where I want to experiment these things. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26arm ide breakageAl Viro
a) semicolon before the function body is a bad idea b) it's const struct foo, not struct const foo c) incidentally, it's ecard_remove_driver(), not ecard_unregister_driver() d) compiling is occasionally useful. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26hwmon: (abituguru3) enable DMI probing feature on AW9D-MAXAlistair John Strachan
Switch the AW9D-MAX over from port probing to the preferred DMI probe method. Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk> Tested-by: Justin Piszcz <jpiszcz@lucidpixels.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-26hwmon: (abituguru3) Cosmetic whitespace fixesAlistair John Strachan
As the probable result of zealous copy/pasting, many supported boards contain sensor names with trailing whitespace. Though this is not a huge problem, it is inconsistent with other sensor names, and with other similar hwmon drivers. Additionally, the DMI nag message added in 2.6.27 was missing a space between two sentence fragments -- might as well clean that up too. Doesn't alter any kernel text, just data. Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk> Reported-by: Justin Piszcz <jpiszcz@lucidpixels.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-26hwmon: (adt7473) Fix voltage conversion routinesJean Delvare
Fix voltage conversion routines. Based on an earlier patch from Paulius Zaleckas. According to the datasheet voltage is scaled with resistors and value 192 is nominal voltage. 0 is 0V. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Cc: Darrick J. Wong <djwong@us.ibm.com>
2008-10-26hwmon: (lm90) Add support for the LM99 16 degree offsetJean Delvare
The LM99 differs from the LM86, LM89 and LM90 in that it reports remote temperatures (temp2) 16 degrees lower than they really are. So far we have been cheating and handled this in userspace but it really should be handled by the driver directly. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org>
2008-10-26hwmon: (lm90) Fix handling of hysteresis valueJean Delvare
There are several problems in the way the hysteresis value is handled by the lm90 driver: * In show_temphyst(), specific handling of the MAX6646 is missing, so the hysteresis is reported incorrectly if the critical temperature is over 127 degrees C. * In set_temphyst(), the new hysteresis register value is written to the chip but data->temp_hyst isn't updated accordingly, so there is a short period of time (up to 2 seconds) where the old hystereris value will be returned while the new one is already active. * In set_temphyst(), the critical temperature which is used as a base to compute the value of the hysteresis register lacks device-specific handling. As a result, the value of the hysteresis register might be incorrect for the ADT7461 and MAX6646 chips. Fix these 3 bugs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Nate Case <ncase@xes-inc.com>
2008-10-26hwmon-vid: Add support for AMD family 10h CPUsJean Delvare
The AMD family 10h CPUs use the same VID decoding table as the family 0Fh CPUs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Rudolf Marek <r.marek@assembler.cz>
2008-10-26hwmon: (w83781d) Fix linking when built-inGeert Uytterhoeven
When w83781d is built-in, the final links fails with the following vague error message: `.exit.text' referenced in section `.init.text' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o w83781d_isa_unregister() cannot be marked __exit, as it's also called from sensors_w83781d_init(), which is marked __init. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-10-25Merge branch 'i7300_idle' into releaseLen Brown
2008-10-25leds-hp-disk: fix build warningLen Brown
drivers/leds/leds-hp-disk.c:59: warning: passing argument 4 of ‘acpi_evaluate_integer’ from incompatible pointer type Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-25ACPI: Oops in ACPI with git latestRafael J. Wysocki
ACPI Warning (nseval-0168): Insufficient arguments - method [_OSC] needs 5, found 4 [20080926] ACPI Warning (nspredef-0252): \_SB_.PCI0._OSC: Parameter count mismatch - ASL declared 5, expected 4 [20080926] ACPI Error (nspredef-0163): \_SB_.PCI0._OSC: Missing expected return value [20080926] BUG: unable to handle kernel NULL pointer dereference at 00000000 IP: [<c0237671>] acpi_run_osc+0xa1/0x170 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-25ACPI suspend: build fix for ACPI_SLEEP=n && XEN_SAVE_RESTORE=y.Rafael J. Wysocki
Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-25toshiba_acpi: always call input_sync() after input_report_switch()Len Brown
2008-10-25ACPI: Always report a sync event after a lid state changeGuillem Jover
Currently not always an EV_SYN event is reported to userland after the EV_SW SW_LID event has been sent. This is easy to verify by using “input-events” from input-utils and just closing and opening the lid. Signed-off-by: Guillem Jover <guillem.jover@nokia.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-25ACPI: cpufreq, processor: fix compile error in drivers/acpi/processor_perflib.cMiao Xie
When trying to build 2.6.28-rc1 on ia64, make aborts with: CC drivers/acpi/processor_perflib.o drivers/acpi/processor_perflib.c:41:28: error: asm/cpufeature.h: No such file or directory drivers/acpi/processor_perflib.c: In function ‘acpi_processor_get_performance_info’: drivers/acpi/processor_perflib.c:364: error: implicit declaration of function ‘boot_cpu_has’ drivers/acpi/processor_perflib.c:364: error: ‘X86_FEATURE_EST’ undeclared (first use in this function) drivers/acpi/processor_perflib.c:364: error: (Each undeclared identifier is reported only once drivers/acpi/processor_perflib.c:364: error: for each function it appears in.) make[2]: *** [drivers/acpi/processor_perflib.o] Error 1 make[1]: *** [drivers/acpi] Error 2 make: *** [drivers] Error 2 this patch fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Acked-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
