Four minor merge conflicts:
1) qca_spi.c renamed the local variable used for the SPI device
from spi_device to spi, meanwhile the spi_set_drvdata() call
got moved further up in the probe function.
2) Two changes were both adding new members to codel params
structure, and thus we had overlapping changes to the
initializer function.
3) 'net' was making a fix to sk_release_kernel() which is
completely removed in 'net-next'.
4) In net_namespace.c, the rtnl_net_fill() call for GET operations
had the command value fixed, meanwhile 'net-next' adjusted the
argument signature a bit.
This also matches example merge resolutions posted by Stephen
Rothwell over the past two days.
Fix missing copy_from_user in macvtap SIOCSIFHWADDR ioctl.
Signed-off-by: Justin Cormack <justin@netbsd.org>
Older gcc versions (e.g. gcc version 4.4.6) don't like anonymous unions
which was causing build issues on the newly added switchdev attr/obj
structs. Fix this by using named union on structs.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Reported-by: Or Gerlitz <ogerlitz@mellanox.com>
And let driver convert it to host-byte order as needed.
Pull networking fixes from David Miller:
1) Handle max TX power properly wrt VIFs and the MAC in iwlwifi, from
Avri Altman.
2) Use the correct FW API for scan completions in iwlwifi, from Avraham
Stern.
3) FW monitor in iwlwifi accidently uses unmapped memory, fix from Liad
Kaufman.
4) rhashtable conversion of mac80211 station table was buggy, the
virtual interface was not taken into account. Fix from Johannes
Berg.
5) Fix deadlock in rtlwifi by not using a zero timeout for
usb_control_msg(), from Larry Finger.
6) Update reordering state before calculating loss detection, from
Yuchung Cheng.
7) Fix off by one in bluetooth firmward parsing, from Dan Carpenter.
8) Fix extended frame handling in xiling_can driver, from Jeppe
Ledet-Pedersen.
9) Fix CODEL packet scheduler behavior in the presence of TSO packets,
from Eric Dumazet.
10) Fix NAPI budget testing in fm10k driver, from Alexander Duyck.
11) macvlan needs to propagate promisc settings down the the lower
device, from Vlad Yasevich.
12) igb driver can oops when changing number of rings, from Toshiaki
Makita.
13) Source specific default routes not handled properly in ipv6, from
Markus Stenberg.
14) Use after free in tc_ctl_tfilter(), from WANG Cong.
15) Use softirq spinlocking in netxen driver, from Tony Camuso.
16) Two ARM bpf JIT fixes from Nicolas Schichan.
17) Handle MSG_DONTWAIT properly in ring based AF_PACKET sends, from
Mathias Kretschmer.
18) Fix x86 bpf JIT implementation of FROM_{BE16,LE16,LE32}, from Alexei
Starovoitov.
19) ll_temac driver DMA maps TX packet header with incorrect length, fix
from Michal Simek.
20) We removed pm_qos bits from netdevice.h, but some indirect
references remained. Kill them. From David Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
net: Remove remaining remnants of pm_qos from netdevice.h
e1000e: Add pm_qos header
net: phy: micrel: Fix regression in kszphy_probe
net: ll_temac: Fix DMA map size bug
x86: bpf_jit: fix FROM_BE16 and FROM_LE16/32 instructions
netns: return RTM_NEWNSID instead of RTM_GETNSID on a get
Update be2net maintainers' email addresses
net_sched: gred: use correct backlog value in WRED mode
pppoe: drop pppoe device in pppoe_unbind_sock_work
net: qca_spi: Fix possible race during probe
net: mdio-gpio: Allow for unspecified bus id
af_packet / TX_RING not fully non-blocking (w/ MSG_DONTWAIT).
bnx2x: limit fw delay in kdump to 5s after boot
ARM: net: delegate filter to kernel interpreter when imm_offset() return value can't fit into 12bits.
ARM: net fix emit_udiv() for BPF_ALU | BPF_DIV | BPF_K intruction.
mpls: Change reserved label names to be consistent with netbsd
usbnet: avoid integer overflow in start_xmit
netxen_nic: use spin_[un]lock_bh around tx_clean_lock (2)
net: xgene_enet: Set hardware dependency
net: amd-xgbe: Add hardware dependency
Commit e2c6544829f moved pm_qos_req to e1000_adapter. Add the header file
that defines the struct.
Signed-off-by: David Ahern <dsahern@gmail.com>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Don't do clock-mode-select if clk == NULL,
since when building without CONFIG_HAVE_CLK,
clk_get returns NULL and clk_get_rate returns 0.
Doing clock-mode-select in this cause causes kszphy_probe to
return -EINVAL and thus prevents the device from being probed.
The original code (before regression) would return 0
when building without CONFIG_HAVE_CLK.
Cc: stable <stable@vger.kernel.org> # 3.18+
Fixes: 1fadee0c3645 ("net/phy: micrel: Add clock support for
KSZ8021/KSZ8031")
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Niklas Cassel <niklass@axis.com>
DMA allocates skb->len instead of headlen
which is used for DMA.
Cleanup few MACROS left out in t4_hw.h to be consistent with the
existing ones. Also replace few hardcoded values with MACROS. Also
update comments for some code
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
Based on the information given to this driver (via the xmit_more skb flag),
we can defer signaling the host if more packets are on the way. This will help
make the host more efficient since it can potentially process a larger batch of
packets. Implement this optimization.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Similarly to the TX path, allow the RX path to be configured with both
'rx-frames' and 'rx-usecs' coalescing parameters.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Add the ability to configure both 'tx-frames' which controls how many frames
are doing to trigger a single interrupt and 'tx-usecs' which dictates how long
to wait before an interrupt should be services.
Since our timer resolution is close to 8.192 us, we round up to the nearest
value the 'tx-usecs' timeout value.
The macvtap driver tries to emulate all the ioctls supported by a normal
tun/tap driver, however it was missing the generic SIOCGIFHWADDR and
SIOCSIFHWADDR ioctls to get and set the mac address that are supported
by tun/tap. This patch adds these.
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma
Pull rdma fixes from Doug Ledford:
- update MAINTAINERS git repo pointer
- printk garbage fix
- fix for qib and iw_cxgb4 bugs introduced in 4.1 window
- fix for an older iWARP netlink bug
- fix a memcpy issue in ehca driver
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma:
infiniband: Remove duplicated KERN_<LEVEL> from pr_<level> uses
IB/qib: fix test of unsigned variable
RDMA/core: Fix for parsing netlink string attribute
MAINTAINERS: update the official rdma git repo
iw_cxgb4: use wildcard mapping for getting remote addr info
IB/ehca: use correct destination for memcpy
Pull power supply and reset fixes from Sebastian Reichel:
"misc fixes"
* tag 'for-v4.1-rc' of git://git.infradead.org/battery-2.6:
power: bq27x00_battery: Add missing MODULE_ALIAS
power: reset: Add MFD_SYSCON depends for brcmstb
power: reset: ltc2952: Remove bogus hrtimer_start() return value checks
power_supply: fix oops in collie_battery driver
power/reset: at91: fix return value check in at91_reset_platform_probe()
MAINTAINERS: Add me as maintainer of Nokia N900 power supply drivers
axp288_fuel_gauge: Add original author details
Well almost clean: ignore the CHECKs for space after cast operator and some
longer-than-80 char cases where for readability it's better to keep as-is.
Acked-by: Jiri Pirko <jiri@resnulli.us>
Roopa said remove the feature flag for this series and she'll work on
bringing it back if needed at a later date.
The IPv4 FIB ops convert nicely to the switchdev objs and we're left with
only four switchdev ops: port get/set and port add/del. Other objs will
follow, such as FDB. So go ahead and convert IPv4 FIB over to switchdev
obj for consistency, anticipating more objs to come.
Rocker, bonding and team and switch over to the new
switchdev_port_bridge_dellink to avoid duplicating code in each driver.
Rocker, bonding, and team can now use the switchdev bridge setlink to parse
raw netlink; no need to duplicate this code in each driver.
rocker: use switchdev get/set attr for bridge port flags
STP update is just a settable port attribute, so convert
switchdev_port_stp_update to an attr set.
For DSA, the prepare phase is skipped and STP updates are only done in the
commit phase. This is because currently the DSA drivers don't need to
allocate any memory for STP updates and the STP update will not fail to HW
(unless something horrible goes wrong on the MDIO bus, in which case the
prepare phase wouldn't have been able to predict anyway).
For rocker, support prepare-commit transaction model for setting attributes
(and for adding objects). This requires rocker to preallocate memory
needed for the commit up front in the prepare phase. Since rtnl_lock is
held between prepare-commit, store the allocated memory on a queue hanging
off of the rocker_port. Also, in prepare phase, do everything right up to
calling into HW. The same code paths are tranversed in the driver for both
prepare and commit phases. In some cases, any state modified in the
prepare phase must be reverted before returning so the commit phase makes
the same decisions.
As a consequence of holding rtnl_lock in process context for all attr sets
(and obj adds), all memory is GFP_KERNEL allocated and we don't need to
busy spin waiting for the device to complete the command. So the bulk of
this patch is simplifying the memory allocations to only use GFP_KERNEL and
to remove the nowait flag and busy spin loop.
Switch ID is just a gettable port attribute. Convert switchdev op
switchdev_parent_id_get to a switchdev attr.
Note: for sysfs and netlink interfaces, SWITCHDEV_ATTR_PORT_PARENT_ID is
called with SWITCHDEV_F_NO_RECUSE to limit switch ID user-visiblity to only
port netdevs. So when a port is stacked under bond/bridge, the user can
only query switch id via the switch ports, but not via the upper devices
Turned out that "switchdev" sticks. So just unify all related terms to use
this prefix.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Acked-by: Andy Gospodarek <gospo@cumulusnetworks.com>
this prefix.
These KERN_<LEVEL> uses are unnecessary with pr_<level> and cause
bad logging output so remove them.
Acked-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Commit d4988623cc60 ("IB/qib: use arch_phys_wc_add()")
adjusted mtrr inititialization to use the new interface.
Unfortunately, the new interface returns a signed
value and the patch tested the unsigned wc_cookie.
Fix the issue by changing the type of wc_cookie to int. For
the success case the ret left at zero to avoid
a warning from the caller. For failure wc_cookie
is used as the ret.
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
The string iwpm_ulib_name is recorded in a nlmsg as a netlink attribute.
Without this fix parsing of the nlmsg by the userspace port mapper service fails
because of unknown attribute length, causing the port mapper service not to
register the client, which has sent the nlmsg.
Signed-off-by: Tatyana Nikolova <tatyana.e.nikolova@intel.com>
Cc: <stable@vger.kernel.org> #v3.16
Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
This change updates igb so that it will correctly perform the descriptor
count calculation. Previously it was taking NETDEV_FRAG_PAGE_MAX_SIZE
into account with isn't really correct since a different value is used to
determine the size of the pages used for TCP. That is actually determined
by SKB_FRAG_PAGE_ORDER.
For listening endpoints bound to the wildcard address, we need to pass
the wildcard address mapping to iwpm_get_remote_info() instead of the
mapped address of the new child connection.
Without this fix, and with iwarp port mapping enabled, each iw_cxgb4
connection that is spawned from a listening endpoint bound to the wildcard
address, will generate an annoying dmesg entry about failing to find
the remote address mapping info, and the connection state displayed in
debugfs under /sys/kernel/debug/iw_cxgb4/<pci-slot-no>/eps will not have
the peer's address/port mapping info. The connection still works though.
Fixes: 5b6b8fe ("RDMA/cxgb4: Report the actual address of the remote connecting peer")
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Reviewed-by: Tatyana Nikolova <Tatyana.E.Nikolova@intel.com>
Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Using an element of a struct as the address for the memcpy of the whole
struct may introduce a buffer overflow and does not help readability either
simply pass the real thing as first argument to memcpy.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi fixes from Mark Brown:
"A number of driver specific fixes (including several missing
dependencies for randconfig type cases) plus two core fixes.
One makes the setup_transfer() callback optional which unbreaks some
drivers which had been merged with it omitted due to local versions of
this patch and another ensures that we don't corrupt data by leaking
internal dummy buffers to callers, causing the callers to think they
allocated those buffers"
* tag 'spi-fix-v4.1-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: fsl-espi: fix behaviour for full-duplex xfers
spi: fsl-spi: fix devm_ioremap_resource() error case
spi: Kconfig: Add SOC_LS1021A to SPI_FSL_DSPI dependence
spi/omap2-mcpsi: Always call spi_finalize_current_message()
spi: fsl-spi: use devm_ioremap_resource() to map parameter ram on CPM1
spi: bitbang: Make setup_transfer() callback optional
spi: check tx_buf and rx_buf in spi_unmap_msg
spi: bcm2835: change timeout of polling driver to 1s
spi: bcm2835: Add GPIOLIB dependency
Use one return statement instead of two to simplify the code.
Both are returning the same value.
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu fixes from Joerg Roedel:
"Three fixes have queued up:
- reference count fix in the AMD IOMMUv2 driver
- sign extension fix in the ARM-SMMU driver
- build fix for rockchip driver with device tree"
* tag 'iommu-fixes-v4.1-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/arm-smmu: Fix sign-extension of upstream bus addresses at stage 1
iommu/rockchip: Fix build without CONFIG_OF
iommu/amd: Fix bug in put_pasid_state_wait
This enables the ethtool's "-d" and "--register-dump"
options for fec devices.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Rather big for fixes pull.
- SCC controllers never lived to see the light of the day. Both
libata and ide drivers removed.
- In some configurations, link power management policy changes
sometimes cause delayed spurious PHY events which can develop into
noticeable failures. This has been reported several times over the
years. Gabriele's patches suppress PHY events for a while after
LPM policy changes which should help most of these failures without
causing too much problem for hotplug use cases.
- A few controller specific fixes"
[ Hmm. I don't think removing SSC support is really a "fix", but hey, it
removes a lot of lines of code. Which I like. So ... good riddance ]
* 'for-4.1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci: avoton port-disable reset-quirk
ata: select DW_DMAC in case of SATA_DWC
libata: Blacklist queued TRIM on all Samsung 800-series
libata: Ignore spurious PHY event on LPM policy change
libata: Add helper to determine when PHY events should be ignored
ata: ahci_st: fixup layering violations / drvdata errors
Remove celleb-only SCC PATA drivers
Pull md bugfixes from Neil Brown:
"A few fixes for md.
Most of these are related to the new "batched stripe writeout", but
there are a few others"
* tag 'md/4.1-rc3-fixes' of git://neil.brown.name/md:
md/raid5: fix handling of degraded stripes in batches.
md/raid5: fix allocation of 'scribble' array.
md/raid5: don't record new size if resize_stripes fails.
md/raid5: avoid reading parity blocks for full-stripe write to degraded array
md/raid5: more incorrect BUG_ON in handle_stripe_fill.
md/raid5: new alloc_stripe() to allocate an initialize a stripe.
md-raid0: conditional mddev->queue access to suit dm-raid
After receiving a PADT and the socket is closed, user space will no
longer drop the reference to the pppoe device.
This leads to errors like this:
[ 488.570000] unregister_netdevice: waiting for eth0.2 to become free. Usage count = 2
Fixes: 287f3a943fe ("pppoe: Use workqueue to die properly when a PADT is received")
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Stage 1 translation is controlled by two sets of page tables (TTBR0 and
TTBR1) which grow up and down from zero respectively in the ARMv8
translation regime. For the SMMU, we only care about TTBR0 and, in the
case of a 48-bit virtual space, we expect to map virtual addresses 0x0
through to 0xffff_ffff_ffff.
Given that some masters may be incapable of emitting virtual addresses
targetting TTBR1 (e.g. because they sit on a 48-bit bus), the SMMU
architecture allows bit 47 to be sign-extended, halving the virtual
range of TTBR0 but allowing TTBR1 to be used. This is controlled by the
SEP field in TTBCR2.
The SMMU driver incorrectly enables this sign-extension feature, which
causes problems when userspace addresses are programmed into a master
device with the SMMU expecting to map the incoming transactions via
TTBR0; if the top bit of address is set, we will instead get a
translation fault since TTBR1 walks are disabled in the TTBCR.
This patch fixes the issue by disabling sign-extension of a fixed
virtual address bit and instead basing the behaviour on the upstream bus
size: the incoming address is zero extended unless the upstream bus is
only 49 bits wide, in which case bit 48 is used as the sign bit and is
replicated to the upper bits.
Cc: <stable@vger.kernel.org> # v4.0+
Reported-by: Varun Sethi <varun.sethi@freescale.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
'spi/fix/fsl-espi' into spi-linus
spi: Fixes for v4.1
A few driver fixes plus two changes for the core, one to make the
setup_transfer() callback optional which fixes crashes in some drivers
which were updated to use new interfaces without apparent testing and
one to ensure we don't expose the data buffers we use for dummy
transfers to drivers which avoids potential issues with multiple
accesses to them or reuse.
# gpg: Signature made Sat 25 Apr 2015 10:59:47 BST using RSA key ID 5D5487D0
# gpg: key CD7BEEBC: no public key for trusted key - skipped
# gpg: key CD7BEEBC marked as ultimately trusted
# gpg: key AF88CD16: no public key for trusted key - skipped
# gpg: key AF88CD16 marked as ultimately trusted
# gpg: key 16005C11: no public key for trusted key - skipped
# gpg: key 16005C11 marked as ultimately trusted
# gpg: key 5621E907: no public key for trusted key - skipped
# gpg: key 5621E907 marked as ultimately trusted
# gpg: key 5C6153AD: no public key for trusted key - skipped
# gpg: key 5C6153AD marked as ultimately trusted
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>"
# gpg: aka "Mark Brown <broonie@debian.org>"
# gpg: aka "Mark Brown <broonie@kernel.org>"
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>"
# gpg: aka "Mark Brown <broonie@linaro.org>"
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
Registering the netdev before setting the priv data is unsafe.
So fix this possible race by setting the priv data first.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Cc: <stable@vger.kernel.org> # v3.18+
Fixes: 291ab06e (net: qualcomm: new Ethernet over SPI driver for QCA7000)
