path: root/drivers
2007-05-08Add a new deferrable delayed work initVenki Pallipadi
Add a new deferrable delayed work init. This can be used to schedule work that are 'unimportant' when CPU is idle and can be called later, when CPU eventually comes out of idle. Use this init in cpufreq ondemand governor. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08layered parport code uses parport->devDavid Brownell
Update some of the layered parport_driver code to use parport->dev: - i2c-parport (parent of i2c_adapter) - spi_butterfly (parent of spi_master, allowing cruft removal) - lp (creating class_device) - ppdev (parent of parportN device) - tipar (creating class_device) There are still drivers that should be updated, like some of the input drivers; but they won't be any worse off than they are today. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08legacy PC parports support parport->devJean Delvare
Give legacy parallel ports a platform device in the device tree. This is a quick and dirty implementation; it doesn't actually convert the legacy parport code to the device driver model (by splitting out probing from device creation). But at least parallel port device drivers will finally have a device to work with. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08parport->dev driver model supportDavid Brownell
Currently a parport_driver can't get a handle on the device node for the underlying parport (PNPACPI, PCI, etc). That prevents correct placement of sysfs child nodes, which can affect things like power management. This patch adds a field to "struct parport" pointing to that device node, and updates non-legacy port drivers to initialize that device pointer. That field replaces the analagous PCI-only support in parport_pc. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Protect tty drivers list with tty_mutexAlexey Dobriyan
Additions and removal from tty_drivers list were just done as well as iterating on it for /proc/tty/drivers generation. testing: modprobe/rmmod loop of simple module which does nothing but tty_register_driver() vs cat /proc/tty/drivers loop BUG: unable to handle kernel paging request at virtual address 6b6b6b6b printing eip: c01cefa7 *pde = 00000000 Oops: 0000 [#1] PREEMPT last sysfs file: devices/pci0000:00/0000:00:1d.7/usb5/5-0:1.0/bInterfaceProtocol Modules linked in: ohci_hcd af_packet e1000 ehci_hcd uhci_hcd usbcore xfs CPU: 0 EIP: 0060:[<c01cefa7>] Not tainted VLI EFLAGS: 00010297 (2.6.21-rc4-mm1 #4) EIP is at vsnprintf+0x3a4/0x5fc eax: 6b6b6b6b ebx: f6cb50f2 ecx: 6b6b6b6b edx: fffffffe esi: c0354700 edi: f6cb6000 ebp: 6b6b6b6b esp: f31f5e68 ds: 007b es: 007b fs: 00d8 gs: 0033 ss: 0068 Process cat (pid: 31864, ti=f31f4000 task=c1998030 task.ti=f31f4000) Stack: 00000000 c0103f20 c013003a c0103f20 00000000 f6cb50da 0000000a 00000f0e f6cb50f2 00000010 00000014 ffffffff ffffffff 00000007 c0354753 f6cb50f2 f73e39dc f73e39dc 00000001 c0175416 f31f5ed8 f31f5ed4 0ee00000 f32090bc Call Trace: [<c0103f20>] restore_nocheck+0x12/0x15 [<c013003a>] mark_held_locks+0x6d/0x86 [<c0103f20>] restore_nocheck+0x12/0x15 [<c0175416>] seq_printf+0x2e/0x52 [<c0192895>] show_tty_range+0x35/0x1f3 [<c0175416>] seq_printf+0x2e/0x52 [<c0192add>] show_tty_driver+0x8a/0x1d9 [<c01758f6>] seq_read+0x70/0x2ba [<c0175886>] seq_read+0x0/0x2ba [<c018d8e6>] proc_reg_read+0x63/0x9f [<c015e764>] vfs_read+0x7d/0xb5 [<c018d883>] proc_reg_read+0x0/0x9f [<c015eab1>] sys_read+0x41/0x6a [<c0103e4e>] sysenter_past_esp+0x5f/0x99 ======================= Code: 00 8b 4d 04 e9 44 ff ff ff 8d 4d 04 89 4c 24 50 8b 6d 00 81 fd ff 0f 00 00 b8 a4 c1 35 c0 0f 46 e8 8b 54 24 2c 89 e9 89 c8 eb 06 <80> 38 00 74 07 40 4a 83 fa ff 75 f4 29 c8 89 c6 8b 44 24 28 89 EIP: [<c01cefa7>] vsnprintf+0x3a4/0x5fc SS:ESP 0068:f31f5e68 Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Remove do_sync_file_range()Mark Fasheh
Remove do_sync_file_range() and convert callers to just use do_sync_mapping_range(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cs5535_gpio, add MODULE_DEVICE_TABLEJiri Slaby
cs5535_gpio, add MODULE_DEVICE_TABLE Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ben Gardner <bgardner@wabtec.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: rocket, add MODULE_DEVICE_TABLEJiri Slaby
rocket, add MODULE_DEVICE_TABLE Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tty: introduce no_tty and use it in selinuxEric W. Biederman
While researching the tty layer pid leaks I found a weird case in selinux when we drop a controlling tty because of inadequate permissions we don't do the normal hangup processing. Which is a problem if it happens the session leader has exec'd something that can no longer access the tty. We already have code in the kernel to handle this case in the form of the TIOCNOTTY ioctl. So this patch factors out a helper function that is the essence of that ioctl and calls it from the selinux code. This removes the inconsistency in handling dropping of a controlling tty and who knows it might even make some part of user space happy because it received a SIGHUP it was expecting. In addition since this removes the last user of proc_set_tty outside of tty_io.c proc_set_tty is made static and removed from tty.h Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tty: simplify calling of put_pid.Eric W. Biederman
This patch should contain no functional changes. At some point I got confused and thought put_pid could not be called while a spin lock was held. While it may be nice to avoid that to reduce lock hold times put_pid can be safely called while we hold a spin lock. This patch removes all of the complications from the code introduced by my misunderstanding, making the code a little more readable. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tty: remove unnecessary export of proc_clear_ttyEric W. Biederman
All of the users of proc_clear_tty are compiled into the kernel so exporting this symbol appears gratuitous. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fixes and cleanups for earlyprintk aka boot consoleGerd Hoffmann
The console subsystem already has an idea of a boot console, using the CON_BOOT flag. The implementation has some flaws though. The major problem is that presence of a boot console makes register_console() ignore any other console devices (unless explicitly specified on the kernel command line). This patch fixes the console selection code to *not* consider a boot console a full-featured one, so the first non-boot console registering will become the default console instead. This way the unregister call for the boot console in the register_console() function actually triggers and the handover from the boot console to the real console device works smoothly. Added a printk for the handover, so you know which console device the output goes to when the boot console stops printing messages. The disable_early_printk() call is obsolete with that patch, explicitly disabling the early console isn't needed any more as it works automagically with that patch. I've walked through the tree, dropped all disable_early_printk() instances found below arch/ and tagged the consoles with CON_BOOT if needed. The code is tested on x86, sh (thanks to Paul) and mips (thanks to Ralf). Changes to last version: Rediffed against -rc3, adapted to mips cleanups by Ralf, fixed "udbg-immortal" cmd line arg on powerpc. Signed-off-by: Gerd Hoffmann <kraxel@exsuse.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Andi Kleen <ak@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: add RTC class driver for the Maxim MAX6900Dale Farnsworth
Signed-off-by: Dale Farnsworth.org <dale@farnsworth.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08RTC: add rtc-rs5c313 driverNobuhiro Iwamatsu
Add an RTC driver for Ricoh RS5C313 RTC chip. [akpm@linux-foundation.org: Zillions of coding-style fixes] [akpm@linux-foundation.org: build fixes] Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Subject: jsm driver fix for linuxpps supportLen Sorensen
The jsm driver doesn't currently use the uart_handle_*_change helper functions, which are the obvious place for things like linuxpps to tie into (which it now does of course), and as a result the jsm driver can not be used with linuxpps and anything else that ties into the serial_core helper functions. This patch adds calls to these helper functions whenever the value they manage changes. That actual storage of the state is not modified since the jsm driver caches the current settings (The 8250 driver reads them everytime a user asks for the state), and only updates them whenever they change. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Cc: Scott H Kilau <Scott_Kilau@digi.com> Cc: Wendy Xiong <wendyx@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Small fixes for jsm driverLen Sorensen
The jsm driver fails when you try to use the TIOCSSERIAL ioctl. The reason is that the driver never sets uart_port.uartclk, causing the data received using TIOCGSERIAL to not match the internal state of the driver. This patch fixes this problem by settings the uartclk to the value used by the serial_core (16 times the baud base). Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Cc: Scott H Kilau <Scott_Kilau@digi.com> Cc: Wendy Xiong <wendyx@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08cyclades: remove custom typesKlaus Kudielka
Switch from private uclong, etc over to standard types. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fix cyclades.h for x86_64 (and probably others)Klaus Kudielka
At least on x86_64 the present cyclades.h is broken due to the wrong size of uclong. This affects, of course, both the kernel and the user-level utilities. The symptom is that cyzload refuses to load the firmware. I also managed to freeze the machine when unloading the module. The patch below fixes this in an architecture-independent way. I have tested it with 2.6.19 and the driver works fine again with a Cyclades-Z on an Athlon 64 X2. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08drivers/char/synclink.c: check kmalloc() return valueAmit Choudhary
Signed-off-by: Amit Choudhary <amit2030@gmail.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08remove unused header file: drivers/char/digi.hRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08remove unused header file: drivers/message/i2o/i2o_lan.hRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08virtual_eisa_root_init() should be __initAndrew Morton
WARNING: vmlinux - Section mismatch: reference to .init.text:eisa_root_register from .text between 'virtual_eisa_root_init' (at offset 0xc026b80f) and 'cpufreq_debug_disable_ratelimit' Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rocket: remove modversions includeRobert P. J. Day
It misspelled "MODVERSIONS" preprocessor variable with "CONFIG_MODVERSIONS". Just kill it all. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08floppy: handle device_create_file() failure while initDmitriy Monakhov
This patch kills the "ignoring return value of 'device_create_file'" warning message. Signed-off-by: Monakhov Dmitriy <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08replace pci_find_device in drivers/telephony/ixj.cSurya
Cleaning up of pci_find_device in drivers/telephony/ixj.c. Signed-off-by: Surya Prabhakar <surya.prabhakar@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tpm_infineon: add support for devices in mmio spaceAlex Williamson
tAdd adds support for devices living in MMIO space to the Infineon TPM driver. These can be found on some of the newer HP ia64 systems. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Acked-by: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08init dma masks in pnp_devDavid Brownell
PNP now initializes device dma masks, which prevents oopses when generic dma calls are made using pnp device nodes. This assumes PNP only uses ISA DMA, with 24 bit addresses; and that it's safe to init those masks for all devices (rather than finding out which devices have been assigned DMA channels, and handling only those). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Adam Belay <abelay@novell.com> Cc: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Use stop_machine_run in the Intel RNG driverPrarit Bhargava
Replace call_smp_function with stop_machine_run in the Intel RNG driver. CPU A has done read_lock(&lock) CPU B has done write_lock_irq(&lock) and is waiting for A to release the lock. A third CPU calls call_smp_function and issues the IPI. CPU A takes CPU C's IPI. CPU B is waiting with interrupts disabled and does not see the IPI. CPU C is stuck waiting for CPU B to respond to the IPI. Deadlock. The solution is to use stop_machine_run instead of call_smp_function (call_smp_function should not be called in situations where the CPUs may be suspended). [haruo.tomita@toshiba.co.jp: fix a typo in mod_init()] [haruo.tomita@toshiba.co.jp: fix memory leak] Signed-off-by: Prarit Bhargava <prarit@redhat.com> Cc: Jan Beulich <jbeulich@novell.com> Cc: "Tomita, Haruo" <haruo.tomita@toshiba.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Apple SMC driver (hardware monitoring and control)Nicolas Boichat
This driver provides support for the Apple System Management Controller, which provides an accelerometer (Apple Sudden Motion Sensor), light sensors, temperature sensors, keyboard backlight control and fan control. Only Intel-based Apple's computers are supported (MacBook Pro, MacBook, MacMini). [bunk@stusta.de: make drivers/hwmon/applesmc.c:backlight_work stati] [khali@linux-fr.org: fix temperature attribute file names] Signed-off-by: Nicolas Boichat <nicolas@boichat.ch> Cc: Jean Delvare <khali@linux-fr.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08drivers/char/hvc_console.c: cleanupsAdrian Bunk
- make needlessly global code static - remove the unused EXPORT_SYMBOL's Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ipmi: add pci remove handlingCorey Minyard
Add pci_remove handling to the driver, so it will clean up if the device is hot-removed. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ipmi: add new IPMI nmi watchdog handlingCorey Minyard
Convert over to the new NMI handling for getting IPMI watchdog timeouts via an NMI. This add config options to know if there is the ability to receive NMIs and if it has an NMI post processing call. Then it modifies the IPMI watchdog to take advantage of this so that it can know if an NMI comes in. It also adds testing that the IPMI NMI watchdog works. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ipmi: allow shared interruptsCorey Minyard
The IPMI driver used enable_irq and disable_irq when it got into situations where it couldn't allocate memory; it did this to avoid having the interrupt just lock the machine when it couldn't get memory to perform the transaction to disable the interrupt. This patch modifies the driver to not use disable_irq and enable_irq. It instead sends the messages to the BMC to perform this operation. It also makes sure interrupts are cleanly disabled when the interface is shut down and cleans up some shutdown things that are no longer necessary. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ipmi: add powerpc openfirmware sensingCorey Minyard
Add support for of_platform_driver to the ipmi_si module. When loading the module, the driver will be registered to of_platform. The driver will be probed for all devices with the type ipmi. It's supporting devices with compatible settings ipmi-kcs, ipmi-smic and ipmi-bt. Only ipmi-kcs could be tested. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Acked-by: Heiko J Schick <schihei@de.ibm.com> Signed-off-by: Corey Minyard <minyard@acm.org> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix section mismatch of memory hotplug related code.Yasunori Goto
This is to fix many section mismatches of code related to memory hotplug. I checked compile with memory hotplug on/off on ia64 and x86-64 box. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07[SCSI] esp_scsi: Fix section mismatch warnings.Martin Habets
Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-07[VIDEO] sunxvr2500: Fix PCI device ID table.David S. Miller
Noticed by Meelis Roos. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-07Merge branch 'drm-patches' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/i915: Add 965GM pci id update drm: just use io_remap_pfn_range on all archs.. drm: fix DRM_CONSISTENT mapping drm: fix up mmap locking in preparation for ttm changes drm: fix driver deadlock with AIGLX and reclaim_buffers_locked drm: fix warning in drm_fops.c drm: allow for more generic drm ioctls drm: fix alpha domain handling via: fix CX700 pci id drm: make drm_io_prot static. drm: remove via_mm.h drm: add missing NULL assignment drm/radeon: Fix u32 overflows when determining AGP base address in card space. drm: port over use_vmalloc code from git hashtab drm: fix crash with fops lock and fixup sarea/page size locking drm: bring bufs code from git tree. drm: move protection stuff into separate function drm: Use ARRAY_SIZE macro when appropriate drm: update README.drm (bugzilla #7933) drm: remove unused exports
2007-05-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NET]: rfkill: add support for input key to control wireless radio [NET] net/core: Fix error handling [TG3]: Update version and reldate. [TG3]: Eliminate spurious interrupts. [TG3]: Add ASPM workaround. [Bluetooth] Correct SCO buffer for another Broadcom based dongle [Bluetooth] Add support for Targus ACB10US USB dongle [Bluetooth] Disconnect L2CAP connection after last RFCOMM DLC [Bluetooth] Check that device is in rfcomm_dev_list before deleting [Bluetooth] Use in-kernel sockets API [Bluetooth] Attach host adapters to the Bluetooth bus [Bluetooth] Fix L2CAP and HCI setsockopt() information leaks
2007-05-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SERIAL] sunsu: Fix section mismatch warnings. [SPARC64]: pgtable_cache_init() should be __init. [SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/prom.c [SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/pci.c [SPARC64]: Fix section mismatch warnings in arch/sparc64/kernel/console.c [MM]: sparse_init() should be __init. [SPARC64]: Update defconfig. [VIDEO]: Add Sun XVR-2500 framebuffer driver. [VIDEO]: Add Sun XVR-500 framebuffer driver. [SPARC64]: SUN4U PCI-E controller support. [SPARC]: Fix comment typo in smp4m_blackbox_current(). [SCSI] SUNESP: sun_esp.c needs linux/delay.h Fix up conflict in arch/sparc64/mm/init.c manually due to removal of pgtable_cache_init() through the -mm patches (even though that patch was also by David ;) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IPoIB: Convert to NAPI IB: Return "maybe missed event" hint from ib_req_notify_cq() IB: Add CQ comp_vector support IB/ipath: Fix a race condition when generating ACKs IB/ipath: Fix two more spin lock problems IB/fmr_pool: Add prefix to all printks IB/srp: Set proc_name IB/srp: Add orig_dgid sysfs attribute to scsi_host IPoIB/cm: Don't crash if remote side uses one QP for both directions RDMA/cxgb3: Support for new abort logic RDMA/cxgb3: Initialize cpu_idx field in cpl_close_listserv_req message RDMA/cxgb3: Fail qp creation if the requested max_inline is too large RDMA/cxgb3: Fix TERM codes IPoIB/cm: Fix error handling in ipoib_cm_dev_open() IB/ipath: Don't corrupt pending mmap list when unmapped objects are freed IB/mthca: Work around kernel QP starvation IB/ipath: Don't put QP in timeout queue if waiting to send IB/ipath: Don't call spin_lock_irq() from interrupt context
2007-05-07Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: (38 commits) sh: R7785RP board updates. sh: Update r7780rp defconfig. sh: Add die chain notifiers. sh: Fix APM emulation on hp6xx. sh: Wire up more IRQs for SH7709. sh: Solution Engine 7722 board support. sh: Fix r7780rp build. sh: kdump support. sh: Move clock reporting to its own proc entry. sh: Solution Engine SH7705 board and CPU updates. serial: sh-sci: Fix module clock refcount for serial console. serial: sh-sci: Fix module clock refcounting. sh: SH7722 clock framework support. sh: hp6xx pata_platform support. sh: Obey CONFIG_HZ for HZ definition. sh: Fix fstatat64() syscall. sh: se7780 PCI support. sh: SH7780 Solution Engine board support. sh: Add a dummy SH-4 PCIC fixup. sh: Tidy up L-BOX area5 addresses. ...
2007-05-07spi_s3c24xx.c: Fix buildArnaud Patard
Commit a836f5856ae46ccb2464ea76031ea05ae967b832 removes the shutdown member of the bitbang structure, breaking the build of spi_s3c24xx.c. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07rename TANBAC TB0219 configYoichi Yuasa
Rename config for TANBAC TB0219 GPIO support to something more appropriate. Fixes this: drivers/char/Kconfig:906:warning: type of 'TANBAC_TB0219' redefined from 'boolean' to 'tristate' drivers/char/Kconfig:907:warning: choice values currently only support a single prompt Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07ehci-ps3, ohci-ps3: fix compilationGeoff Levand
As seen on powerpc-cell et al: CC [M] drivers/usb/host/ehci-hcd.o In file included from drivers/usb/host/ehci-hcd.c:941: drivers/usb/host/ehci-ps3.c:79: error: conflicting types for 'dev_dbg' include/linux/device.h:576: error: previous definition of 'dev_dbg' was here make[4]: *** [drivers/usb/host/ehci-hcd.o] Error 1 CC [M] drivers/usb/host/ohci-hcd.o In file included from drivers/usb/host/ohci-hcd.c:921: drivers/usb/host/ohci-ps3.c:83: error: conflicting types for 'dev_dbg' include/linux/device.h:576: error: previous definition of 'dev_dbg' was here dev_dbg() will check format string for you in dummy case also, so remove buggers. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg KH <greg@kroah.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07cx88-video build fixAndrew Morton
alpha: drivers/media/video/cx88/cx88-video.c: In function 'cx8800_initdev': drivers/media/video/cx88/cx88-video.c:1782: error: 'DMA_32BIT_MASK' undeclared (first use in this function) drivers/media/video/cx88/cx88-video.c:1782: error: (Each undeclared identifier is reported only once drivers/media/video/cx88/cx88-video.c:1782: error: for each function it appears in.) Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07remove unused header file: drivers/serial/crisv10.hRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07remove software_suspend()Johannes Berg
Remove software_suspend() and all its users since pm_suspend(PM_SUSPEND_DISK) should be equivalent and there's no point in having two interfaces for the same thing. The patch also changes the valid_state function to return 0 (false) for PM_SUSPEND_DISK when SOFTWARE_SUSPEND is not configured instead of accepting it and having the whole thing fail later. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
