path: root/drivers
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Correct comments in genrtc.c to refer to correct /proc file.Robert P. J. Day
Correct documentation in genrtc.c to refer to the correct /proc file that's used to export information: /proc/driver/rtc. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix more "deprecated" spellos.Randy Dunlap
Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix "deprecated" typoes.Robert P. J. Day
Fix remaining misspellings of "depreciated" to "deprecated." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09devres: kernel-doc and DocBookRandy Dunlap
Make devres.c ready for adding to DocBook. Add devres.c to DocBook. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08applesmc: Use standard sysfs names for labelsJean Delvare
We have a standard suffix to associate a designation string to a sensor: _label. Use it instead of _position so that libsensors will catch it. (This isn't implemented yet, but should be soon.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Nicolas Boichat <nicolas@boichat.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08applesmc: Use the address as platform device IDJean Delvare
Let the applesmc device export its address to userspace. libsensors needs this to recognize the device and give it a unique ID. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Nicolas Boichat <nicolas@boichat.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08usb_gigaset: don't kmalloc(0)Tilman Schmidt
Zero-sized allocations are pointless anyway, and the SLUB allocator complains about them, so stop doing that. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix unnecesary meminitYasunori Goto
This is to fix unnecessary __meminit definition. These are exported for kernel modules. I compiled on ia64/x86-64 with memory hotplug on/off. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Optimize fault kprobe handling just like powerpc. [SPARC]: Wire up utimensat syscall. [SPARC64]: Fix request_irq() ignored result warnings in PCI controller code. [SPARC64]: Kill asm-sparc64/pbm.h [ATYFB]: Fix sparc includes. [QLA2XXX]: Fix build on sparc. [SPARC64]: Removal of trivial pci_controller_info uses. [SPARC64]: Move index info pci_pbm_info. [SPARC64]: Move {setup,teardown}_msi_irq into pci_pbm_info. [SPARC64]: Move pci_ops into pci_pbm_info. [SPARC64] SBUS: Error interrupt registry cleanups. [SPARC64] PCI: Use root list of pbm's instead of pci_controller_info's [SPARC64] PCI: Kill PROM_PCIRNG_MAX and PROM_PCIIMAP_MAX. [SPARC64] PCI: Use common routine to fetch PBM properties.
2007-05-08Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (58 commits) [SCSI] zfcp: clear boxed flag on unit reopen. [SCSI] zfcp: clear adapter failed flag if an fsf request times out. [SCSI] zfcp: rework request ID management. [SCSI] zfcp: Fix deadlock between zfcp ERP and SCSI [SCSI] zfcp: Locking for req_no and req_seq_no [SCSI] zfcp: print S_ID and D_ID with 3 bytes [SCSI] ipr: Use PCI-E reset API for new ipr adapter [SCSI] qla2xxx: Update version number to 8.01.07-k7. [SCSI] qla2xxx: Add MSI support. [SCSI] qla2xxx: Correct pci_set_msi() usage semantics. [SCSI] qla2xxx: Attempt to stop firmware only if it had been previously executed. [SCSI] qla2xxx: Honor NVRAM port-down-retry-count settings. [SCSI] qla2xxx: Error-out during probe() if we're unable to complete HBA initialization. [SCSI] zfcp: Stop system after memory corruption [SCSI] mesh: cleanup variable usage in interrupt handler [SCSI] megaraid: replace yield() with cond_resched() [SCSI] megaraid: fix warnings when CONFIG_PROC_FS=n [SCSI] aacraid: correct SUN products to README [SCSI] aacraid: superfluous adapter reset for IBM 8 series ServeRAID controllers [SCSI] aacraid: kexec fix (reset interrupt handler) ...
2007-05-08[ATYFB]: Fix sparc includes.David S. Miller
No need to use asm/pbm.h here. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08[QLA2XXX]: Fix build on sparc.David S. Miller
We now use pci_device_to_OF_node() to get properties and of_get_property() returns const pointers. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08mmc: use lock instead of claim in debug checkPierre Ossman
As mmc_detect_change() can be called from irq context, using claim (which can sleep) is inherently unsafe. Use the host spinlock instead, which also is faster. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-08mmc: Use menuconfig objectsJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-08disable socket power in adapter driver instead of media oneAlex Dubov
Socket power must be fully controlled by adapter driver. This also prevents unnecessary power-off of the socket when media driver is unloaded, yet media remains in the socket. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-08Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: (32 commits) Use menuconfig objects - hwmon hwmon/smsc47b397: Use dynamic sysfs callbacks hwmon/smsc47b397: Convert to a platform driver hwmon/w83781d: Deprecate W83627HF support hwmon/w83781d: Use dynamic sysfs callbacks hwmon/w83781d: Be less i2c_client-centric hwmon/w83781d: Clean up conversion macros hwmon/w83781d: No longer use i2c-isa hwmon/ams: Do not print error on systems without apple motion sensor hwmon/ams: Fix I2C read retry logic hwmon: New AD7416, AD7417 and AD7418 driver hwmon/coretemp: Add documentation hwmon: New coretemp driver i386: Use functions from library in msr driver i386: Add safe variants of rdmsr_on_cpu and wrmsr_on_cpu hwmon/lm75: Use dynamic sysfs callbacks hwmon/lm78: Use dynamic sysfs callbacks hwmon/lm78: Be less i2c_client-centric hwmon/lm78: No longer use i2c-isa hwmon: New max6650 driver ...
2007-05-08Merge branch 'reset-seq' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'reset-seq' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata reset-seq] build and merge fixes libata: reimplement reset sequencing libata: improve ata_std_prereset() libata: improve 0xff status handling libata: add deadline support to prereset and reset methods
2007-05-08Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (40 commits) [netdrvr] atl1: fix build pasemi_mac: Use local-mac-address instead of mac-address if available pasemi_mac: PHY support pasemi_mac: Add msglevel support and "debug" module param pasemi_mac: Logic cleanup / rx performance improvements pasemi_mac: Minor cleanup / define fixes pasemi_mac: Add SKB reuse / copy-break pasemi_mac: Timer and interrupt fixes pasemi_mac: Abstract and fix up interrupt restart routines pasemi_mac: Move the IRQ mapping from the PCI layer to the driver tc35815: Remove unnecessary skb->dev assignment drivers/net/dm9000: Convert to generic boolean AT91RM9200 Ethernet: Fix multicast addressing AT91RM9200 Ethernet: Support additional PHYs PCMCIA-NETDEV : xirc2ps_cs: bugfix of multicast code sky2: re-enable 88E8056 for most motherboards MIPS: Drop unnecessary CONFIG_ISA from RBTX49XX ne: MIPS: Use platform_driver for ne on RBTX49XX ne: Add NEEDS_PORTLIST to control ISA auto-probe ne: Misc fixes for platform driver. ... Fix conflict in drivers/net/pasemi_mac.c (get_property() got renamed to of_get_property()) manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'drm-patches' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6: via: Make sure we flush write-combining using a follow-up read. via: Try to improve command-buffer chaining. drm: remove old taskqueue remnant drm: rename badly named define and cleanup ioctl code spacing radeon: Don't mess up page flipping when a file descriptor is closed. drm/radeon: upgrade to 1.27 - make PCI GART more flexible
2007-05-08Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: Input: move USB miscellaneous devices under drivers/input/misc Input: move USB mice under drivers/input/mouse Input: move USB gamepads under drivers/input/joystick Input: move USB touchscreens under drivers/input/touchscreen Input: move USB tablets under drivers/input/tablet Input: i8042 - fix AUX port detection with some chips Input: aaed2000_kbd - convert to use polldev library Input: drivers/usb/input - usb_buffer_free() cleanup Input: synaptics - don't complain about failed resets Input: pull input.h into uinpit.h Input: drivers/usb/input - fix sparse warnings (signedness) Input: evdev - fix some sparse warnings (signedness, shadowing) Input: drivers/joystick - fix various sparse warnings Input: force feedback - make sure effect is present before playing
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08sm501fb printk warning fixesAndrew Morton
drivers/video/sm501fb.c: In function 'sm501fb_cursor': drivers/video/sm501fb.c:992: warning: format '%08x' expects type 'unsigned int', but argument 3 has type 'long unsigned int' drivers/video/sm501fb.c:992: warning: format '%08x' expects type 'unsigned int', but argument 4 has type 'long unsigned int' Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08xilinxfb: xilinx framebuffer device driverAndrei Konovalov
Add support for the video controller IP block included into Xilinx ML300 and ML403 reference designs. Signed-off-by: Andrei Konovalov <akonovalov@ru.mvista.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: fix of jumps in pm2fb_probeKrzysztof Helt
This patch fixes incorrect targets of jumps when an error occurs in the pm2fb_probe. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08skeletonfb: improvementsKrzysztof Helt
This patch adds a macro to register PCI ids table and corrects type of xxxfb_fix variable to avoid modpost warnings. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: removal of pm2fb_par fieldsKrzysztof Helt
This patch removes two redundant fields in the pm2fb_par structure. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08skeletonfb: more correctionsKrzysztof Helt
More corrections to skeletonfb.c file: - fixed types of more arguments - removed returned values in void functions - removed not existing fb_poll function - fixed closing comment typo - corrected misleading constant name ADDR Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-By: James Simmons <jsimmons@infradead.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vga16fb: actually support widths in multiples of 8Antonino A. Daplas
vga16fb does not just support 8-pixel wide rectangles, but rectangles with widths in multiples of 8. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vgacon: disallow console operations when in KD_GRAPHICS modeAntonino A. Daplas
Reported by James Pearson as: boot to run level 3 if not root, then make sure /dev/console is writeable login and type: setterm -blank 0 start X type into an xterm: while true; do echo "" > /dev/console; usleep 100000; done while the above loop is running switch to the text console and back again (Ctrl-Alt-F1 then Ctrl-Alt-F7) ... and the screen will be shifting (and wrapping) to the left. This problem stems from continuously writing text to the system console (which is in KD_TEXT mode) while the foreground console is in KD_GRAPHICS mode. Somewhere along the way, console printing got confused and omitted the KD_GRAPHICS/KD_TEXT test. Thus, vgacon attempted to scroll the screen of X, which causes X to shift. Fix by disallowing vgacon to touch the hardware when the vc is in KD_GRAPHICS mode. A definitive fix entails a full audit of the console code. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Use menuconfig objects II: video/logoJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: accelerated fillrect and copyareaKrzysztof Helt
This is a port of accelerated functions from 2.4 kernel. Only fillrect and copyarea are accelerated. Fillrect is not accelerated in 24-bit mode. [adaplas] Add appropriate flags Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: updatesOndrej Zajicek
Move s3fb_get_tilemax to svgalib.c as svga_get_tilemax, because it reports limitation of other code from svgalib (svga_settile, svga_tilecopy, ...) Limit font width to 8 pixels in 4 bpp mode. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: memclock setting correctionsKrzysztof Helt
This patch disables a memory clock setting if a board has been initialized by BIOS. This allows using the memory clock set by manufacturer of the board. This patch also sets default clock for 3dlabs Permedia 2V reference board's clock to 75MHz (BIOS setting for EONtronic Permedia 2Vboard), because the default 83MHz can be too high. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: reset transparency settingskrzysztof.h1@wp.pl
This patch resets transparency settings when depth changes. Otherwise the 16 and 24-bit modes work incorrectly after switching from 32-bit mode. Signed-off-by: Krzysztof Helt < krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbcon: check console-fb mapping in fbcon_get_requirementAntonino A. Daplas
- Check the console-to-fb mapping in fbcon_get_requirement(), otherwise the value returned may not be valid for the driver. - Minor cleanup Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: clean up exit patch of fb_set_varAntonino A. Daplas
Clean up exit patch of fb_set_var(): - consolidate all return values into a single local variable - ensure that return values are valid error codes - fix fb_set_var() returning success when fb_check_caps() failed Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08drivers/video/sis/: remove more kernel 2.4 codeAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08use mutex instead of semaphore in virtual console driverMatthias Kaehlcke
The virtual console driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: halve XCLK with Mobility and 32bit memoryVille Syrjala
Laptops with Rage Mobility and 32bit memory interface seem to require halved XCLK to operate correctly. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: reorganize clock initVille Syrjala
Reorganize atyfb clock init code so command line clock overrides are effective for all chips. The old code would silently ignore some of the command line clock overrides with some chips. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: increase SPLL delayVille Syrjala
Wait 5 ms instead of 500 us for the SPLL to lock. This matches the recommendation in mach64 programmer's guide. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: fix return value of nvidiafb_open()Antonino A. Daplas
Fix return value of nvidiafb_open(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vga: vgastate fixOndrej Zajicek
1) sets 'palette access disabled' during read from AR10. This is usually documented as needed for access AR01-AR0F, but on ARK Logic card it is needed for AR10 (otherwise read returns some nonsence and save_vga_text() returns before do anything). 2) do not restore AR10, because it was not changed during 3) remove modification of misc reg: /* force graphics mode */ vga_w(state->vgabase, VGA_MIS_W, misc | 1); as comment is misleading - LSB of misc reg does not set/reset graphics mode, but set color/mono adresses of CRT and some other regs. but these regs are not used during save/restore fonts. (it worked even when (misc | 1) was replaced by (misc & ~1) ). Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: implement fb_get_capsAntonino A. Daplas
Implement fb_get_caps(). This will allow the driver to tell upper layer that it can only support 256 8x16 bitmaps when in tileblitting mode (var->bits_per_pixel == 0); Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: fbcon: check if mode can handle new screenAntonino A. Daplas
Check if the mode can properly display the screen. This will be needed by drivers where the capability is not constant with each mode. The function fb_set_var() will query fbcon the requirement, then it will query the driver (via a new hook fb_get_caps()) its capability. If the driver's capability cannot handle fbcon's requirement, then fb_set_var() will fail. For example, if a particular driver supports 2 modes where: mode1 = can only display 8x16 bitmaps mode2 = can display any bitmap then if current mode = mode2 and current font = 12x22 fbset <mode1> /* mode1 cannot handle 12x22 */ fbset will fail Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: prevent triggering of softlockupDave Jones
If the chip locks up, we get into a long polling loop, where the softlockup detector kicks in. See https://bugzilla.redhat.com/bugzilla/attachment.cgi?id=151878 for an example. [adaplas] Chip lockup can occur at 3 points (flush, sync, and wait). Consolidate and allow the driver to go to safe mode cleanly. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08pm2fb: pixclock setting restrictionKrzysztof Helt
This patch adds restrictions to calculations of m, n and p factors which sets the pixclock for the Permedia 2V. I found during tests that synchronization is unstable if m (divisor) is bigger than half of the n (numerator). The patch disallows such settings combination. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
