path: root/drivers
2011-04-27Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: ACPI / PM: Avoid infinite recurrence while registering power resources PM / Wakeup: Fix initialization of wakeup-related device sysfs files
2011-04-27Merge branch 'spell-fix' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'spell-fix' of git://git.profusion.mobi/users/lucas/linux-2.6: Revert wrong fixes for common misspellings
2011-04-27Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits) [media] media: vb2: correct queue initialization order [media] media: vb2: fix incorrect v4l2_buffer->flags handling [media] s5p-fimc: Add support for the buffer timestamps and sequence [media] s5p-fimc: Fix bytesperline and plane payload setup [media] s5p-fimc: Do not allow changing format after REQBUFS [media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4 [media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet [media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet [media] tda18271: fix bad calculation of main post divider byte [media] tda18271: prog_cal and prog_tab variables should be s32, not u8 [media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init [media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails [media] v4l: Don't register media entities for subdev device nodes [media] omap3isp: Don't increment node entity use count when poweron fails [media] omap3isp: lane shifter support [media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts [media] media: add missing 8-bit bayer formats and Y12 [media] v4l: add V4L2_PIX_FMT_Y12 format cx23885: Fix stv0367 Kconfig dependency [media] omap3isp: Use isp xclk defines ... Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
2011-04-26Revert wrong fixes for common misspellingsLucas De Marchi
These changes were incorrectly fixed by codespell. They were now manually corrected. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
2011-04-26Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: amd64_edac: Erratum #637 workaround amd64_edac: Factor in CC6 save area amd64_edac: Remove node interleave warning EDAC: Remove debugging output in scrub rate handling
2011-04-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: iTCO_wdt: TCO Watchdog patch for Intel Panther Point PCH
2011-04-26Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] kvm-390: Let kernel exit SIE instruction on work [S390] dasd: check sense type in device change handler [S390] pfault: fix token handling [S390] qdio: reset error states immediately [S390] fix page table walk for changing page attributes [S390] prng: prevent access beyond end of stack [S390] dasd: fix race between open and offline
2011-04-26amd64_edac: Erratum #637 workaroundBorislav Petkov
F15h CPUs may report a non-DRAM address when reporting an error address belonging to a CC6 state save area. Add a workaround to detect this condition and compute the actual DRAM address of the error as documented in the Revision Guide for AMD Family 15h Models 00h-0Fh Processors. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-04-26amd64_edac: Factor in CC6 save areaBorislav Petkov
F15h and later use a portion of DRAM as a CC6 storage area. BIOS programs D18F1x[17C:140,7C:40] DRAM Base/Limit accordingly by subtracting the storage area from the DRAM limit setting. However, in order for edac to consider that part of DRAM too, we need to include it into the per-node range. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-04-26amd64_edac: Remove node interleave warningBorislav Petkov
This warning was wrongfully added for a normal condition - intlvsel actually selects the destination node when node interleaving is enabled and it is not a mismatch. For a detailed example, see section 2.8.10.2 "Node Interleaving" in F10h BKDG. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-04-26watchdog: iTCO_wdt: TCO Watchdog patch for Intel Panther Point PCHSeth Heasley
This patch adds the TCO Watchdog DeviceIDs for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-04-26ACPI / PM: Avoid infinite recurrence while registering power resourcesRafael J. Wysocki
There is at least one BIOS with a DSDT containing a power resource object with a _PR0 entry pointing back to that power resource. In consequence, while registering that power resource acpi_bus_get_power_flags() sees that it depends on itself and tries to register it again, which leads to an infinitely deep recurrence. This problem was introduced by commit bf325f9538d8c89312be305b9779e (ACPI / PM: Register power resource devices as soon as they are needed). To fix this problem use the observation that power resources cannot be power manageable and prevent acpi_bus_get_power_flags() from being called for power resource objects. References: https://bugzilla.kernel.org/show_bug.cgi?id=31872 Reported-and-tested-by: Pascal Dormeau <pdormeau@free.fr> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Len Brown <lenb@kernel.org> Cc: stable@kernel.org
2011-04-26PM / Wakeup: Fix initialization of wakeup-related device sysfs filesRafael J. Wysocki
It turns out that some PCI devices are only found to be wakeup-capable during registration, in which case, when device_set_wakeup_capable() is called, device_is_registered() already returns 'true' for the given device, but dpm_sysfs_add() hasn't been called for it yet. This leads to situations in which the device's power.can_wakeup flag is not set as requested because of failing wakeup_sysfs_add() and its wakeup-related sysfs files are not created, although they should be present. This is a post-2.6.38 regression introduced by commit cb8f51bdadb7969139c2e39c2defd4cde98c1 (PM: Do not create wakeup sysfs files for devices that cannot wake up). To work around this problem initialize the device's power.entry field to an empty list head and make device_set_wakeup_capable() check if it is still empty before attempting to add the devices wakeup-related sysfs files with wakeup_sysfs_add(). Namely, if power.entry is still empty at this point, device_pm_add() hasn't been called yet for the device and its wakeup-related files will be created later, so device_set_wakeup_capable() doesn't have to create them. Reported-and-tested-by: Tino Keitel <tino.keitel@tikei.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-25Merge branch 'for-torvalds' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson * 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson: rtc: fix coh901331 startup crash mach-ux500: fix i2c0 device setup regression
2011-04-24libata: ahci_start_engine compliant to AHCI specJian Peng
At the end of section 10.1 of AHCI spec (rev 1.3), it states Software shall not set PxCMD.ST to 1 until it is determined that a functoinal device is present on the port as determined by PxTFD.STS.BSY=0, PxTFD.STS.DRQ=0 and PxSSTS.DET=3h Even though most AHCI host controller works without this check, specific controller will fail under this condition. Signed-off-by: Jian Peng <jipeng2005@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24ata: pata_at91.c bugfix for initial_timing initialisationIgor Plyatov
The "struct ata_timing" must contain 10 members, but ".dmack_hold" member was forgotten for "initial_timing" initialisation. This patch fixes such a problem. Signed-off-by: Igor Plyatov <plyatov@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24ata: pata_at91.c bugfix for high master clockIgor Plyatov
The AT91SAM9 microcontrollers with master clock higher then 105 MHz and PIO0, have overflow of the NCS_RD_PULSE value in the MSB. This lead to "NCS_RD_PULSE" pulse longer then "NRD_CYCLE" pulse and driver does not detect ATA device. Signed-off-by: Igor Plyatov <plyatov@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24ahci: AHCI-mode SATA patch for Intel Panther Point DeviceIDsSeth Heasley
The previously submitted patch was word-wrapped. This patch adds the AHCI-mode SATA DeviceIDs for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24ata_piix: IDE-mode SATA patch for Intel Panther Point DeviceIDsSeth Heasley
The previously submitted patch was word-wrapped. This patch adds the IDE-mode SATA DeviceIDs for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24libata: Pioneer DVR-216D can't do SETXFERJeff Mahoney
Commit 4a5610a04d415ed94af75bb1159d2621d62c8328 fixed an issue with the Pioneer DVR-212D not handling SETXFER correctly. An openSUSE user reported a similar issue with his DVR-216D that the NOSETXFER horkage worked around for him as well. This patch adds the DVR-216D (1.08) to the horkage list for NOSETXFER. The issue was reported at: https://bugzilla.novell.com/show_bug.cgi?id=679143 Reported-by: Volodymyr Kyrychenko <vladimir.kirichenko@gmail.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24ahci: don't enable port irq before handler is registeredMaxime Bizon
The ahci_pmp_attach() & ahci_pmp_detach() unmask port irqs, but they are also called during port initialization, before ahci host irq handler is registered. On ce4100 platform, this sometimes triggers "irq 4: nobody cared" message when loading driver. Fixed this by not touching the register if the port is in frozen state, and mark all uninitialized port as frozen. Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Acked-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24libata: Implement ATA_FLAG_NO_DIPM and apply it to mcp65Tejun Heo
NVIDIA mcp65 familiy of controllers cause command timeouts when DIPM is used. Implement ATA_FLAG_NO_DIPM and apply it. This problem was reported by Stefan Bader in the following thread. http://thread.gmane.org/gmane.linux.ide/48841 stable: applicable to 2.6.37 and 38. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stefan Bader <stefan.bader@canonical.com> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-24ahci: EM supported message type sysfs attributeHannes Reinecke
This patch adds an sysfs attribute 'em_message_supported' to the ahci host device which prints out the supported enclosure management message types. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2011-04-23Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM: Add missing syscore_suspend() and syscore_resume() calls PM: Fix error code paths executed after failing syscore_suspend()
2011-04-22Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty/n_gsm: fix bug in CRC calculation for gsm1 mode serial/imx: read cts state only after acking cts change irq parport_pc.c: correctly release the requested region for the IT887x
2011-04-21Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cd block: don't propagate unlisted DISK_EVENTs to userland elevator: check for ELEVATOR_INSERT_SORT_MERGE in !elvpriv case too
2011-04-21ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cdTejun Heo
check_events() implementations in both ide-gd and ide-cd are inadequate for in-kernel event polling. Both generate media change events continuously when certain conditions are met causing infinite event loop between the driver and userland event handler. As disk event now supports suppression of unlisted events, simply de-listing DISK_EVENT_MEDIA_CHANGE from disk->events resolves the problem. Internal handling around media revalidation will behave the same while userland will fall back to userland event polling after detecting the device doesn't support disk events. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jens Axboe <jaxboe@fusionio.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21raid5: fix build error, sector_t usageRandy Dunlap
Change <sectors> from unsigned long long to sector_t. This matches its source field. ERROR: "__udivdi3" [drivers/md/raid456.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: console: Enable call to hvc_remove() on console port remove virtio_pci: Prevent double-free of pci regions after device hot-unplug virtio: Decrement avail idx on buffer detach
2011-04-21Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: agp: fix arbitrary kernel memory writes agp: fix OOM and buffer overflow drm/radeon/kms: fix IH writeback on r6xx+ on big endian machines
2011-04-21Merge branch 'drm-intel-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6 * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6: drm/i915: Initialise g4x watermarks for disabled pipes drm/i915: Sanitize the output registers after resume drm/i915/tv: Fix modeset flickering introduced in 7f58aabc3 drm/i915/tv: Only poll for TV connections drm/i915/tv: Remember the detected TV type
2011-04-21Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel_iommu: disable all VT-d PMRs when TXT launched intel-iommu: Fix get_domain_for_dev() error path intel-iommu: Unlink domain from iommu intel-iommu: Fix use after release during device attach
2011-04-21virtio: console: Enable call to hvc_remove() on console port removeAmit Shah
This call was disabled as hot-unplugging one virtconsole port led to another virtconsole port freezing. Upon testing it again, this now works, so enable it. In addition, a bug was found in qemu wherein removing a port of one type caused the guest output from another port to stop working. I doubt it was just this bug that caused it (since disabling the hvc_remove() call did allow other ports to continue working), but since it's all solved now, we're fine with hot-unplugging of virtconsole ports. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21virtio_pci: Prevent double-free of pci regions after device hot-unplugAmit Shah
In the case where a virtio-console port is in use (opened by a program) and a virtio-console device is removed, the port is kept around but all the virtio-related state is assumed to be gone. When the port is finally released (close() called), we call device_destroy() on the port's device. This results in the parent device's structures to be freed as well. This includes the PCI regions for the virtio-console PCI device. Once this is done, however, virtio_pci_release_dev() kicks in, as the last ref to the virtio device is now gone, and attempts to do pci_iounmap(pci_dev, vp_dev->ioaddr); pci_release_regions(pci_dev); pci_disable_device(pci_dev); which results in a double-free warning. Move the code that releases regions, etc., to the virtio_pci_remove() function, and all that's now left in release_dev is the final freeing of the vp_dev. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21virtio: Decrement avail idx on buffer detachAmit Shah
When detaching a buffer from a vq, the avail.idx value should be decremented as well. This was noticed by hot-unplugging a virtio console port and then plugging in a new one on the same number (re-using the vqs which were just 'disowned'). qemu reported 'Guest moved used index from 0 to 256' when any IO was attempted on the new port. CC: stable@kernel.org Reported-by: juzhang <juzhang@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21intel_iommu: disable all VT-d PMRs when TXT launchedJoseph Cihula
Intel VT-d Protected Memory Regions (PMRs) are supposed to be disabled, on each VT-d engine, after DMA remapping is enabled on the engines. This is because the behavior of having both enabled is not deterministic and because, if TXT has been used to launch the kernel, the PMRs may be programmed to cover memory regions that will be used for DMA. Under some circumstances (certain quirks detected, lack of multiple devices, etc.), the current code does not set up DMA remapping on some VT-d engines. In such cases it also skips disabling the PMRs. This causes failures when the kernel is launched with TXT (most often this occurs on the graphics engine and results in colored vertical bars on the display). This patch detects when the kernel has been launched with TXT and then disables the PMRs on all VT-d engines. In some cases where the reason that remapping is not being enabled is due to possible ACPI DMAR table errors, the VT-d engine addresses may not be correct and thus not able to be safely programmed even to disable PMRs. Because part of the TXT launch process is the verification of these addresses, it will always be safe to disable PMRs if the TXT launch has succeeded and hence only doing this in such cases. Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-04-21EDAC: Remove debugging output in scrub rate handlingMarkus Trippelsdorf
This patch removes superfluous debugging output in the sysfs scrub rate handler. It also consolidates the error handling in the scrub rate accessors. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-04-21agp: fix arbitrary kernel memory writesVasiliy Kulikov
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND, and it is not checked at all in case of AGPIOC_UNBIND. As a result, user with sufficient privileges (usually "video" group) may generate either local DoS or privilege escalation. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21agp: fix OOM and buffer overflowVasiliy Kulikov
page_count is copied from userspace. agp_allocate_memory() tries to check whether this number is too big, but doesn't take into account the wrap case. Also agp_create_user_memory() doesn't check whether alloc_size is calculated from num_agp_pages variable without overflow. This may lead to allocation of too small buffer with following buffer overflow. Another problem in agp code is not addressed in the patch - kernel memory exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()). Each allocation is limited to 16KB, though, there is no per-process limit. This might lead to OOM situation, which is not even solved in case of the caller death by OOM killer - the memory is allocated for another (faked) process. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-20Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (max34440) Add driver documentation hwmon: (max16064) Add driver documentation hwmon: (max8688) Add driver documentation hwmon: (pmbus) Documentation updates hwmon: (smm665) Fix spelling error in driver documentation hwmon: (pmbus) Removed unused variable from struct pmbus_data hwmon: Add submitting-patches checklist to documentation
2011-04-20Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Update documentation for sync_min and sync_max entries md: Cleanup after raid45->raid0 takeover md: Fix dev_sectors on takeover from raid0 to raid4/5 md/raid5: remove setting of ->queue_lock
2011-04-20Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Remove the extra check in queue_requests_store block, blk-sysfs: Fix an err return path in blk_register_queue() block: remove stale kerneldoc member from __blk_run_queue() block: get rid of QUEUE_FLAG_REENTER cfq-iosched: read_lock() does not always imply rcu_read_lock() block: kill blk_flush_plug_list() export
2011-04-20rtc: fix coh901331 startup crashLinus Walleij
The rtc_device_register() call has changed semantics so that it will immediately call out to rtc_read_alarm() and since the callbacks require the drvdata to be set, we need to set it before the registration call to avoid NULL dereference. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-04-20[S390] dasd: check sense type in device change handlerStefan Weinhuber
When evaluating sense data in dasd_eckd_check_for_device_change, we must always check for the type of sense data in byte 27, bit 0, to make sure that the rest of the sense data is interpreted correctly. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-20[S390] qdio: reset error states immediatelyJan Glauber
The qdio hardware may surpress further interrupts as long as a SBAL is in the error state. That can lead to unnotified data in the SBALs following the error state. To prevent this behaviour change the SBAL[s] in error state immediately to another program owned state so interrupts are again received for further traffic on the device. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-20[S390] dasd: fix race between open and offlineStefan Weinhuber
The dasd_open function uses the private_data pointer of the gendisk to find the dasd_block structure that matches the gendisk. When a DASD device is set offline, we set the private_data pointer of the gendisk to NULL and later remove the dasd_block structure, but there is still a small race window, in which dasd_open could first read a pointer from the private_data field and then try to use it, after the structure has already been freed. To close this race window, we will store a pointer to the dasd_devmap structure of the base device in the private_data field. The devmap entries are not deleted, and we already have proper locking and reference counting in place, so that we can safely get from a devmap pointer to the dasd_device and dasd_block structures of the device. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-20md: Cleanup after raid45->raid0 takeoverKrzysztof Wojcik
Problem: After raid4->raid0 takeover operation, another takeover operation (e.g raid0->raid10) results "kernel oops". Root cause: Variables 'degraded' in mddev structure is not cleared on raid45->raid0 takeover. This patch reset this variable. Signed-off-by: Krzysztof Wojcik <krzysztof.wojcik@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-20md: Fix dev_sectors on takeover from raid0 to raid4/5NeilBrown
A raid0 array doesn't set 'dev_sectors' as each device might contribute a different number of sectors. So when converting to a RAID4 or RAID5 we need to set dev_sectors as they need the number. We have already verified that in fact all devices do contribute the same number of sectors, so use that number. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-20md/raid5: remove setting of ->queue_lockNeilBrown
We previously needed to set ->queue_lock to match the raid5 device_lock so we could safely use queue_flag_* operations (e.g. for plugging). which test the ->queue_lock is in fact locked. However that need has completely gone away and is unlikely to come back to remove this now-pointless setting. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-19Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: pll tweaks for r7xx drm/nouveau: fix allocation of notifier object drm/nouveau: fix notifier memory corruption bug drm/nouveau: fix pinning of notifier block drm/nouveau: populate ttm_alloced with false, when it's not drm/nouveau: fix nv30 pcie boards drm/nouveau: split ramin_lock into two locks, one hardirq safe drm/radeon/kms: adjust evergreen display watermark setup drm/radeon/kms: add connectors even if i2c fails drm/radeon/kms: fix bad shift in atom iio table parser
