This patch adds the support for predefined multiple block r/w.
dw_mmc can support MMC_CAP_CMD23 capability.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Acked-by: Will Newton <will.newton@imgtec.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
This patch adds another capabilities field for MMC_CAPS2_XXX.
This patch modifies dw_mmc to use dev_pm_ops.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: James Hogan <james.hogan@imgtec.com>
Kill block requests when the host realizes that the card is
removed from the slot and is sure that subsequent requests
are bound to fail. Do this silently so that the block
layer doesn't output unnecessary error messages.
Signed-off-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
c31b50e (mmc: core: Use delayed work in clock gating framework,
2011-11-14) missed a few things during review:
o A useless pr_info()
o milliseconds was written as two words
o The sysfs file had units in its output
Fix all three problems.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Sujit Reddy Thumma <sthumma@codeaurora.org>
Enable boot partitions to be read-only locked until next power on via
a sysfs entry. There will be one sysfs entry for each boot partition:
/sys/block/mmcblkXbootY/ro_lock_until_next_power_on
Each boot partition is locked by writing 1 to its file.
Signed-off-by: Johan Rudholm <johan.rudholm@stericsson.com>
Signed-off-by: John Beckett <john.beckett@stericsson.com>
sdhci-s3c updates pm_caps from platform data for SDIO PM.
Signed-off-by: Sangwook Lee <sangwook.lee@samsung.com>
Add a function mmc_detect_card_removed() which upper layers can use to
determine immediately if a card has been removed. This function should
be called after an I/O request fails so that all queued I/O requests
can be errored out immediately instead of waiting for the card device
to be removed.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
This patch converts the drivers in drivers/mmc/host/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Acked-by: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Acked-by: David Brown <davidb@codeaurora.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
// <smpl>
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
// </smpl>
Replace ilog2(__rounddown_pow_of_two(x)) with the equivalent but much
simpler fls(x) - 1.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
If the read or write buffer size associated with the command sent
through the mmc_blk_ioctl is zero, do not prepare data buffer.
This enables a ioctl(2) call to for instance send a MMC_SWITCH to set
a byte in the ext_csd.
1ms is enough for hardware to change the clock to stable.
100ms is too long in the tasklet.
Signed-off-by: Tony Lin <tony.lin@freescale.com>
CC: Xiaobo Xie <X.Xie@freescale.com>
CC: Anton Vorontsov <avorontsov@ru.mvista.com>
If max_seg_size is unaligned, mmc_test_map_sg() may create sg element
sizes that are not aligned with 512 byte. Fix, align max_seg_size at
mmc_test_area_init().
Signed-off-by: Per Forlin <per.forlin@stericsson.com>
This patch adds support for sdio UHS cards per the version 3.0
spec.
UHS mode is only enabled for version 3.0 cards when both the
host and the controller support UHS modes.
1.8v signaling support is removed if both the card and the
host do not support UHS. This is done to maintain
compatibility and some system/card combinations break when
1.8v signaling is enabled when the host does not support UHS.
Signed-off-by: Philip Rakity <prakity@marvell.com>
Signed-off-by: Aaron Lu <Aaron.lu@amd.com>
Reviewed-by: Arindam Nath <arindam.nath@amd.com>
Tested-by: Bing Zhao <bzhao@marvell.com>
Suspend/Resume is missing from sdhci-spear driver. This patch adds
support for suspend/resume for this driver.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Current clock gating framework disables the MCI clock as soon as the
request is completed and enables it when a request arrives. This aggressive
clock gating framework, when enabled, cause following issues:
When there are back-to-back requests from the Queue layer, we unnecessarily
end up disabling and enabling the clocks between these requests since 8MCLK
clock cycles is a very short duration compared to the time delay between
back to back requests reaching the MMC layer. This overhead can effect the
overall performance depending on how long the clock enable and disable
calls take which is platform dependent. For example on some platforms we
can have clock control not on the local processor, but on a different
subsystem and the time taken to perform the clock enable/disable can add
significant overhead.
Also if the host controller driver decides to disable the host clock too
when mmc_set_ios function is called with ios.clock=0, it adds additional
delay and it is highly possible that the next request had already arrived
and unnecessarily blocked in enabling the clocks. This is seen frequently
when the processor is executing at high speeds and in multi-core platforms
thus reduces the overall throughput compared to if clock gating is
disabled.
Fix this by delaying turning off the clocks by posting request on
delayed workqueue. Also cancel the unscheduled pending work, if any,
when there is access to card.
sysfs entry is provided to tune the delay as needed, default
value set to 200ms.
No functional change; adds macros for card manufacturer IDs.
Cc: Andrei E. Warkentin <andrey.warkentin@gmail.com>
Cc: Stefan Nilsson XK <stefan.xk.nilsson@stericsson.com>
This patch is to expose the actual SDCLK frequency in
/sys/kernel/debug/mmcX/ios entry.
For example, if the max clk for a normal speed card is 20MHz this
is reported in /sys/kernel/debug/mmcX/ios. Unfortunately the actual
SDCLK frequency (i.e. Baseclock / divisor) is not reported at all:
for example, in that case, on Arasan HC, it should be 48/4=12 (MHz).
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
This patch allows any block size to be set on the SDIO link,
and still have an arbitrary sized packet (adjusted in size by
using sdio_align_size) transferred in an optimal way
(preferably one transfer).
Previously if the block size was larger than the default of
512 bytes and the transfer size was exactly one block size
(possibly thanks to using sdio_align_size to get an optimal
transfer size), it was sent as a number of byte transfers instead
of one block transfer. Also if the number of blocks was
(max_blocks * N) + 1, the tranfer would be conducted with a number
of blocks and finished off with a number of byte transfers.
When doing this change it was also possible to break out the quirk
for broken byte mode in a much cleaner way, and collect the logic of
when to do byte or block transfer in one function instead of two.
Signed-off-by: Stefan Nilsson XK <stefan.xk.nilsson@stericsson.com>
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
Add new macros for the high speed 50MHz case, rather than having
a confusing reuse of the value for UHS SDR50, which is 100MHz.
Reported-by: Aaron Lu <aaron.lu@amd.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] omap3isp: Fix crash caused by subdevs now having a pointer to devnodes
* 'for-linus' of git://neil.brown.name/md:
md/bitmap: It is OK to clear bits during recovery.
md: don't give up looking for spares on first failure-to-add
md/raid5: ensure correct assessment of drives during degraded reshape.
md/linear: fix hot-add of devices to linear arrays.
commit d0a4bb492772ce5c4bdfba3744a99ed6f6fb238f introduced a
regression which is annoying but fairly harmless.
When writing to an array that is undergoing recovery (a spare
in being integrated into the array), writing to the array will
set bits in the bitmap, but they will not be cleared when the
write completes.
For bits covering areas that have not been recovered yet this is not a
problem as the recovery will clear the bits. However bits set in
already-recovered region will stay set and never be cleared.
This doesn't risk data integrity. The only negatives are:
- next time there is a crash, more resyncing than necessary will
be done.
- the bitmap doesn't look clean, which is confusing.
While an array is recovering we don't want to update the
'events_cleared' setting in the bitmap but we do still want to clear
bits that have very recently been set - providing they were written to
the recovering device.
So split those two needs - which previously both depended on 'success'
and always clear the bit of the write went to all devices.
Signed-off-by: NeilBrown <neilb@suse.de>
Before performing a recovery we try to remove any spares that
might not be working, then add any that might have become relevant.
Currently we abort on the first spare that cannot be added.
This is a false optimisation.
It is conceivable that - depending on rules in the personality - a
subsequent spare might be accepted.
Also the loop does other things like count the available spares and
reset the 'recovery_offset' value.
If we abort early these might not happen properly.
So remove the early abort.
In particular if you have an array what is undergoing recovery and
which has extra spares, then the recovery may not restart after as
reboot as the could of 'spares' might end up as zero.
Reported-by: Anssi Hannula <anssi.hannula@iki.fi>
While reshaping a degraded array (as when reshaping a RAID0 by first
converting it to a degraded RAID4) we currently get confused about
which devices are in_sync. In most cases we get it right, but in the
region that is being reshaped we need to treat non-failed devices as
in-sync when we have the data but haven't actually written it out yet.
Reported-by: Adam Kwolek <adam.kwolek@intel.com>
commit d70ed2e4fafdbef0800e73942482bb075c21578b
broke hot-add to a linear array.
After that commit, metadata if not written to devices until they
have been fully integrated into the array as determined by
saved_raid_disk. That patch arranged to clear that field after
a recovery completed.
However for linear arrays, there is no recovery - the integration is
instantaneous. So we need to explicitly clear the saved_raid_disk
field.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
USB: Fix usb/isp1760 build on sparc
usb: gadget: epautoconf: do not change number of streams
usb: dwc3: core: fix cached revision on our structure
usb: musb: fix reset issue with full speed device
* 'upstream-linus' of git://github.com/jgarzik/libata-dev:
pata_of_platform: Add missing CONFIG_OF_IRQ dependency.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Add a flow_cache_flush_deferred function
ipv4: reintroduce route cache garbage collector
net: have ipconfig not wait if no dev is available
sctp: Do not account for sizeof(struct sk_buff) in estimated rwnd
asix: new device id
davinci-cpdma: fix locking issue in cpdma_chan_stop
sctp: fix incorrect overflow check on autoclose
r8169: fix Config2 MSIEnable bit setting.
llc: llc_cmsg_rcv was getting called after sk_eat_skb.
net: bpf_jit: fix an off-one bug in x86_64 cond jump target
iwlwifi: update SCD BC table for all SCD queues
Revert "Bluetooth: Revert: Fix L2CAP connection establishment"
Bluetooth: Clear RFCOMM session timer when disconnecting last channel
Bluetooth: Prevent uninitialized data access in L2CAP configuration
iwlwifi: allow to switch to HT40 if not associated
iwlwifi: tx_sync only on PAN context
mwifiex: avoid double list_del in command cancel path
ath9k: fix max phy rate at rate control init
nfc: signedness bug in __nci_request()
iwlwifi: do not set the sequence control bit is not needed
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: Include linux/io.h to jz4740-adc
mfd: Use request_threaded_irq for twl4030-irq instead of irq_set_chained_handler
mfd: Base interrupt for twl4030-irq must be one-shot
mfd: Handle tps65910 clear-mask correctly
mfd: add #ifdef CONFIG_DEBUG_FS guard for ab8500_debug_resources
mfd: Fix twl-core oops while calling twl_i2c_* for unbound driver
mfd: include linux/module.h for ab5500-debugfs
mfd: Update wm8994 active device checks for WM1811
mfd: Set tps6586x bits if new value is different from the old one
mfd: Set da903x bits if new value is different from the old one
mfd: Set adp5520 bits if new value is different from the old one
mfd: Add missed free_irq in da903x_remove
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus
* 'for-greg' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb:
This commit:
commit 8f5d621543cb064d2989fc223d3c2bc61a43981e
Author: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
Date: Mon Oct 10 18:06:54 2011 +0200
usb/isp1760: Let OF bindings depend on general CONFIG_OF instead of PPC_OF .
To be able to use the driver on other OF-aware architectures, too.
And add necessary OF related #includes to fix compilation error.
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
enabled the build on all CONFIG_OF architectures, but it cannot do
this.
This driver depends upon CONFIG_OF_IRQ but not all CONFIG_OF platforms
support that infrastructure, in particular Sparc does not so the
build fails.
Please push a patch like the following to Linus so that this code only
gets built where it actually should.
usb/isp1760: Add missing CONFIG_OF_IRQ dependency on OF code.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
* git://git.infradead.org/mtd-2.6:
mtd: plat_ram: call mtd_device_register only if partition data exists
mtd: pxa2xx-flash.c: It used to fall back to provided table.
mtd: gpmi: add missing include 'module.h'
mtd: ndfc: fix typo in structure dereference
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: vub300: fix type of firmware_rom_wait_states module parameter
Revert "mmc: enable runtime PM by default"
mmc: sdhci: remove "state" argument from sdhci_suspend_host
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
time/clocksource: Fix kernel-doc warnings
rtc: m41t80: Workaround broken alarm functionality
rtc: Expire alarms after the time is set.
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
oprofile: Fix uninitialized memory access when writing to writing to oprofilefs
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/for-linus-fixes-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
Revert "xen/pv-on-hvm kexec: add xs_reset_watches to shutdown watches from old kernel"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
vmwgfx: Clip cliprects against screen boundaries in present and dirty
vmwgfx: Resend the cursor after legacy modeset
vmwgfx: Do better culling of presents
vmwgfx: Refactor kms code to use vmw_user_lookup_handle helper
vmwgfx: Add helper function to get surface or dmabuf
vmwgfx: Refactor cursor update
vmwgfx: Remove dmabuf check in present ioctl
vmwgfx: Use the revised fifo hw version register when present
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (31 commits)
Revert "[media] af9015: limit I2C access to keep FW happy"
[media] s5p-fimc: Fix camera input configuration in subdev operations
[media] m5mols: Fix logic in sanity check
[media] ati_remote: switch to single-byte scancodes
[media] V4L: mt9m111: fix uninitialised mutex
[media] V4L: omap1_camera: fix missing <linux/module.h> include
[media] V4L: mt9t112: use after free in mt9t112_probe()
[media] V4L: soc-camera: fix compiler warnings on 64-bit platforms
[media] s5p_mfc_enc: fix s/H264/H263/ typo
[media] omap_vout: Fix compile error in 3.1
[media] au0828: add missing models 72101, 72201 & 72261 to the model matrix
[media] au0828: add missing USB ID 2040:7213
[media] au0828: add missing USB ID 2040:7260
[media] [trivial] omap24xxcam-dma: Fix logical test
[media] omap_vout: fix crash if no driver for a display
[media] media: video: s5p-tv: fix build break
[media] omap3isp: fix compilation of ispvideo.c
[media] m5mols: Fix set_fmt to return proper pixel format code
[media] s5p-fimc: Use correct fourcc for RGB565 colour format
[media] s5p-fimc: Fail driver probing when sensor configuration is wrong
If the BMC gets reset, it will return 0x80 response errors.
In less than a week
# grep "Error 80 on cmd 22" /var/log/kernel |wc -l
378681
In this case, it is probably a good idea to restore the IPMI settings.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
Include linux/io.h to fix below build error:
CC drivers/mfd/jz4740-adc.o
drivers/mfd/jz4740-adc.c: In function 'jz4740_adc_irq_demux':
drivers/mfd/jz4740-adc.c:73: error: implicit declaration of function 'readb'
drivers/mfd/jz4740-adc.c: In function 'jz4740_adc_set_enabled':
drivers/mfd/jz4740-adc.c:110: error: implicit declaration of function 'writeb'
drivers/mfd/jz4740-adc.c: In function 'jz4740_adc_set_config':
drivers/mfd/jz4740-adc.c:146: error: implicit declaration of function 'readl'
drivers/mfd/jz4740-adc.c:151: error: implicit declaration of function 'writel'
drivers/mfd/jz4740-adc.c: In function 'jz4740_adc_probe':
drivers/mfd/jz4740-adc.c:249: error: implicit declaration of function 'ioremap_nocache'
drivers/mfd/jz4740-adc.c:249: warning: assignment makes pointer from integer without a cast
drivers/mfd/jz4740-adc.c:289: warning: passing argument 3 of 'mfd_add_devices' discards qualifiers from pointer target type
include/linux/mfd/core.h:93: note: expected 'struct mfd_cell *' but argument is of type 'const struct mfd_cell *'
drivers/mfd/jz4740-adc.c:299: error: implicit declaration of function 'iounmap'
make[2]: *** [drivers/mfd/jz4740-adc.o] Error 1
make[1]: *** [drivers/mfd] Error 2
make: *** [drivers] Error 2
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
irq_set_chained_handler sets 'desc->handle_irq'.
However this irq is called by handle_nested_irq from handle_twl4030_pih,
and that uses action->thread_fn.
So the handled set with irq_set_chained_handler is never called.
So change to use request_threaded_irq instead - that sets the correct field.
Tested on GTA04 Phoenux.
Tested-by: Felipe Contreras <felipe.contreras@gmail.com>
As the interrupt source is only cleared by the threaded interrupt
service routine, we need to make the base interrupt IRQF_ONESHOT.
Without this, the first interrupt from the TWL4030 cause the CPU to
enter an infinite loop trying to handle to interrupt but never
clearing it.
