- add pr_fmt.
- convert printks to pr_<level>
- add if (0) and printf argument checking to cdinfo
- coalesce consecutive printks to single pr_
- fix a typo "back ground" to "background"
- convert printks without level to pr_info
- remove VIOCD_ prefixes and use pr_fmt/pr_<level>
- add a missing newline to an OS/400 message
Folded in tab indentation fix from Andrew.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Fix extra brace typo that is causing build errors.
Allocating a fixed payload for discard requests always was a horrible hack,
and it's not coming to byte us when adding support for discard in DM/MD.
So change the code to leave the allocation of a payload to the lowlevel
driver. Unfortunately that means we'll need another hack, which allows
us to update the various block layer length fields indicating that we
have a payload. Instead of hiding this in sd.c, which we already partially
do for UNMAP support add a documented helper in the core block layer for it.
Acked-by: Mike Snitzer <snitzer@redhat.com>
On compilation, gcc correctly detects that we do not handle
all types:
In function ‘blk_done’:
warning: enumeration value ‘REQ_TYPE_FS’ not handled in switch
warning: enumeration value ‘REQ_TYPE_SENSE’ not handled in switch
warning: enumeration value ‘REQ_TYPE_PM_SUSPEND’ not handled in switch
warning: enumeration value ‘REQ_TYPE_PM_RESUME’ not handled in switch
warning: enumeration value ‘REQ_TYPE_PM_SHUTDOWN’ not handled in switch
warning: enumeration value ‘REQ_TYPE_LINUX_BLOCK’ not handled in switch
warning: enumeration value ‘REQ_TYPE_ATA_TASKFILE’ not handled in switch
warning: enumeration value ‘REQ_TYPE_ATA_PC’ not handled in switch
which is a bit pointless since this is at the end of the request
processessing. Add a default case that just breaks out.
Remove the current bio flags and reuse the request flags for the bio, too.
This allows to more easily trace the type of I/O from the filesystem
down to the block driver. There were two flags in the bio that were
missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've
renamed two request flags that had a superflous RW in them.
Note that the flags are in bio.h despite having the REQ_ name - as
blkdev.h includes bio.h that is the only way to go for now.
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in
struct requests. This allows much easier grepping for different request
types instead of unwinding through macros.
We can safely remove ISA_DMA_THRESHOLD usage in aha1542. aha1542 uses
ISA_DMA_THRESHOLD to see if:
- the buffers in scatter/list are below 16MB.
- scsi_host is below 16MB.
Both checkings were added in the ancient times but aren't necessary
nowadays since we properly bounce the buffers and allocate scsi_host
below 16MB with non-zero unchecked_isa_dma.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: James Bottomley <James.Bottomley@suse.de>
Convert assertions to use WARN(). There are several error checks in the
code for things that should never happen. Convert them to standard
warnings so kerneloops.org will see them.
Convert wait loops to use wait_event_ macros.
Ioctl cmd value is unsigned, so change normalize_ioctl
As reported by sparse, cmos attribute is local.
The usage_count was being protected by a lock which was only there to
create an atomic counter.
The first thing the floppy does is read block 0 to test geometry and to
test for disk presence. If disk is not present this causes a console
warning message about failed I/O. Set flag to silence.
These routines are all big enough that is better to let the compiler
decide to inline or not.
Set debug jiffies offset at initialization. Avoids wierd values showing
up if debugging enabled.
Change the command padding on 32-bit systems to 0 since setting it to 32
has the identical effect.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Remove a debug statement left behind by accident Ths debug statement got
left behind. It was commented out after use but not deleted.
The definition of next_command also ended up in wrong place It ended up
inside an "#ifdef CONFIG_PROCFS". Already caught by Randy Dunlap and a
couple others. Tried to put it somewhere that made sense.
call to put_controller_in_performant_mode was in the wrong place
The call inadvertently ended up in an error path.
Make sure we register the performant mode interrupt Another blunder.
Seemed to work because the call to put_controller_into_performant_mode was
never called.
Add support for new controllers due out next year. HP must continue to
support new controllers in older distros. All vendors require support be
upstream. These controllers support only 16 commands in simple mode but
can support up to 1024 in performant mode. See patch 5/6/ We have no
marketing names yet.
Add a mode of controller operation called Performant Mode. Even though
cciss has been deprecated in favor of hpsa there are new controllers due
out next year that HP must support in older vendor distros. Vendors
require all fixes/features be upstream. These new controllers support
only 16 commands in simple mode but support up to 1024 in performant mode.
This requires us to add this support at this late date.
The performant mode transport minimizes host PCI accesses by performinf
many completions per read. PCI writes are posted so the host can write
then immediately get off the bus not waiting for the writwe to complete to
the target. In the context of performant mode the host read out to a
controller pulls all posted writes into host memory ensuring the reply
queue is coherent.
Change the return type of our interrupt access routines to bool from
unsigned long. It makes more sense that way.
Check to see if h->msi[x]_vector is set. We need this for a following
patch. Without this check we process one interrupt then stop because in
msi[x] mode the interrupt pending bit is not set. Not sure why we didn't
encounter this before.
Simplify the interrupt handler code to more closely match hpsa and to
hopefully make it easier to follow.
Clean up some code where we subit our io. The same 5 lines appeared
several times. Also helps for a following patch.
* master.kernel.org:/home/rmk/linux-2.6-arm:
cyber2000fb: fix console in truecolor modes
cyber2000fb: fix machine hang on module load
SA1111: Eliminate use after free
ARM: Fix Versatile/Realview/VExpress MMC card detection sense
ARM: 6279/1: highmem: fix SMP preemption bug in kmap_high_l1_vipt
ARM: Add barriers to io{read,write}{8,16,32} accessors as well
ARM: 6273/1: Add barriers to the I/O accessors if ARM_DMA_MEM_BUFFERABLE
ARM: 6272/1: Convert L2x0 to use the IO relaxed operations
ARM: 6271/1: Introduce *_relaxed() I/O accessors
ARM: 6275/1: ux500: don't use writeb() in uncompress.h
ARM: 6270/1: clean files in arch/arm/boot/compressed/
ARM: Fix csum_partial_copy_from_user()
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/edid: Fix the HDTV hack sync adjustment
drm/radeon/kms: fix radeon mid power profile reporting
Return value was not set to 0 in setcolreg() with truecolor modes. This causes
fb_set_cmap() to abort after first color, resulting in blank palette - and
blank console in 24bpp and 32bpp modes.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
I was testing two CyberPro 2000 based PCI cards on x86 and the machine always
hanged completely when the cyber2000fb module was loaded. It seems that the
card hangs when some registers are accessed too quickly after writing RAMDAC
control register. With this patch, both card work.
Add delay after RAMDAC control register write to prevent hangs on module load.
The MMC card detection sense has become really confused with negations
at various levels, leading to some platforms not detecting inserted
cards. Fix this by converting everything to positive logic throughout,
thereby getting rid of these negations.
We're adjusting horizontal timings only here, moving vsync was just a
slavish translation of a typo in the X server.
Signed-off-by: Adam Jackson <ajax@redhat.com>
Fix incorrectly reporting 'default' power profile, when it is set to 'mid'.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] ibmvscsi: Fix oops when an interrupt is pending during probe
[SCSI] zfcp: Update status read mempool
[SCSI] zfcp: Do not wait for SBALs on stopped queue
[SCSI] zfcp: Fix check whether unchained ct_els is possible
[SCSI] ipr: fix resource path display and formatting
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
davinci: da850/omap-l138 evm: account for DEFDCDC{2,3} being tied high
regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH register
wm8350-regulator: fix wm8350_register_regulator error handling
ab3100: fix off-by-one value range checking for voltage selector
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
In TPS6507x, depending on the status of DEFDCDC{2,3} pin either
DEFDCDC{2,3}_LOW or DEFDCDC{2,3}_HIGH register needs to be read or
programmed to change the output voltage.
The current driver assumes DEFDCDC{2,3} pins are always tied low
and thus operates only on DEFDCDC{2,3}_LOW register. This need
not always be the case (as is found on OMAP-L138 EVM).
Unfortunately, software cannot read the status of DEFDCDC{2,3} pins.
So, this information is passed through platform data depending on
how the board is wired.
Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
When freeing a gpio that has not been exported, gpio_unexport() prints a
debug message when it should just fall through silently.
Example spurious message:
gpio_unexport: gpio0 status -22
Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk>
Cc: David Brownell <david-b@pacbell.net>
Acked-by: Uwe Kleine-K?nig <u.kleine-koenig@pengutronix.de>
Cc: Gregory Bean <gbean@codeaurora.org>
The MPC85xx EDAC driver is missing module device aliases, so the driver
won't load automatically on boot. This patch fixes the issue by adding
proper MODULE_DEVICE_TABLE() macros.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Dave Jiang <djiang@mvista.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Fix the logic while writing new date/time to the chip. The driver
incorrectly wrote back register values to different registers and even
with wrong mask. The patch adds clearing of the VLF register, which
should be cleared if all date/time values are set.
Signed-off-by: Rudolf Marek <rudolf.marek@sysgo.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: Martyn Welch <martyn.welch@gefanuc.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
A driver needs to be ready to take an interrupt as soon as it registers
an interrupt handler. I noticed the following oops when testing kdump:
ipr: IBM Power RAID SCSI Device Driver version: 2.5.0 (February 11, 2010)
ibmvscsi 30000002: SRP_VERSION: 16.a
Unable to handle kernel paging request for data at address 0x00000000
pc: c000000004085e34: .tasklet_action+0xf4/0x1dc
c000000004086fe4 .__do_softirq+0x16c/0x2c0
c00000000403138c .call_do_softirq+0x14/0x24
c00000000400ee14 .do_softirq+0xa0/0x104
c00000000408690c .irq_exit+0x70/0xd0
c00000000400f190 .do_IRQ+0x214/0x2a8
c000000004004804 hardware_interrupt_entry+0x1c/0x98
--- Exception: 501 (Hardware Interrupt) at c00000000400c544 .raw_local_irq_restore+0x48/0x54
c00000000465d2a8 ._raw_spin_unlock_irqrestore+0x74/0xa0
c0000000040e7f00 .__setup_irq+0x2ec/0x3f0
c0000000040e8198 .request_threaded_irq+0x194/0x22c
c00000000446d854 .rpavscsi_init_crq_queue+0x284/0x3f0
c00000000446c764 .ibmvscsi_probe+0x688/0x710
c00000000402903c .vio_bus_probe+0x37c/0x3e4
c000000004403f10 .driver_probe_device+0xec/0x1b8
c000000004404088 .__driver_attach+0xac/0xf4
c000000004403184 .bus_for_each_dev+0x98/0x104
c000000004403c98 .driver_attach+0x40/0x60
c0000000044026f0 .bus_add_driver+0x154/0x324
c0000000044045d0 .driver_register+0xe8/0x1ac
c00000000402b2a8 .vio_register_driver+0x54/0x74
c000000004933ea4 .ibmvscsi_module_init+0x80/0xc0
c000000004009834 .do_one_initcall+0x98/0x1d8
c0000000049005b4 .kernel_init+0x27c/0x33c
c000000004031550 .kernel_thread+0x54/0x70
srp_task needs to be setup before request_irq. The patch below fixes the oops.
Acked-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
* git://git.infradead.org/users/cbou/battery-2.6.35:
ds2782_battery: Rename get_current to fix build failure / name conflict
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
s2io: fixing DBG_PRINT() macro
ath9k: fix dma direction for map/unmap in ath_rx_tasklet
net: dev_forward_skb should call nf_reset
net sched: fix race in mirred device removal
tun: avoid BUG, dump packet on GSO errors
bonding: set device in RLB ARP packet handler
wimax/i2400m: Add PID & VID for Intel WiMAX 6250
ipv6: Don't add routes to ipv6 disabled interfaces.
net: Fix skb_copy_expand() handling of ->csum_start
net: Fix corruption of skb csum field in pskb_expand_head() of net/core/skbuff.c
macvtap: Limit packet queue length
ixgbe/igb: catch invalid VF settings
bnx2x: Advance a module version
bnx2x: Protect statistics ramrod and sequence number
bnx2x: Protect a SM state change
wireless: use netif_rx_ni in ieee80211_send_layer2_update
In the case of platform_device_add() fail, we should call
platform_device_put() instead of platform_device_del()
We use voltage selector as an array index for typ_voltages.
Thus the valid range for voltage selector should be 0..voltages_len-1.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Patch 9e39f7c5b311a306977c5471f9e2ce4c456aa038 changed the
DBG_PRINT() macro and the if clause was wrongly changed. It means
that currently all the DBG_PRINT are being printed, flooding the
kernel log buffer with things like:
s2io: eth6: Next block at: c0000000b9c90000
s2io: eth6: In Neterion Tx routine
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Acked-by: Sreenivasa Honnur <Sreenivasa.Honnur@neterion.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] powernow-k8: Limit Pstate transition latency check
[CPUFREQ] Fix PCC driver error path
[CPUFREQ] fix double freeing in error path of pcc-cpufreq
[CPUFREQ] pcc driver should check for pcch method before calling _OSC
[CPUFREQ] fix memory leak in cpufreq_add_dev
[CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)"
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus:
MIPS: Set io_map_base for several PCI bridges lacking it
MIPS: Alchemy: Define eth platform devices in the correct order
MIPS: BCM63xx: Prevent second enet registration on BCM6338
MIPS: Quit using undefined behavior of ADDU in 64-bit atomic operations.
MIPS: N32: Define getdents64.
MIPS: MTX-1: Fix PCI on the MeshCube and related boards
MIPS: Make init_vdso a subsys_initcall.
MIPS: "Fix" useless 'init_vdso successfully' message.
MIPS: PowerTV: Move register setup to before reading registers.
SOUND: Au1000: Fix section mismatch
VIDEO: Au1100fb: Fix section mismatch
VIDEO: PMAGB-B: Fix section mismatch
VIDEO: PMAG-BA: Fix section mismatch
NET: declance: Fix section mismatches
VIDEO. gbefb: Fix section mismatches.
Fix error from the last pull request. Making sure we shut the panel off
is more correct and saves power.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
