path: root/drivers
2009-06-16V4L/DVB (11769): cx23885: add ATSC/QAM tuning support for Hauppauge ↵Michael Krufky
WinTV-HVR1275 Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11768): cx23885: add ATSC/QAM tuning support for Hauppauge ↵Michael Krufky
WinTV-HVR1270 Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11767): cx23885: Add preliminary support for the HVR1270Steven Toth
The patch means the board will be recognised, and the parts brought out of reset correctly. This patches depends on the centralized GPIO patch to be merged. What's missing before the HVR-1270 will function for DTV? The model# needs to be added to avoid 'unknown model' output and the LG3305/Tuner need to be attached in cx23885-dvb.c Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11766): cx23885: mark functions encoder_on_port[bc] as static inlineMichael Krufky
2009-06-16V4L/DVB (11765): cx23885: Add generic functions for driving GPIO'sSteven Toth
The GPIO's on the product can be in one of three places. To date we've mainly used the GPIO's on the bridge itself, and once on the encoder. Rather than having the complexity of multiple GPIO writes/reads from isolated placed in the driver we'll route them through this function, so we can make intelligent decisions about 1) Where the GPIO lives and 2) Whether it conflicts (based on board) with some other function to avoid bugs. Signed-off-by: Steven Toth <stoth@kernellabs.com> Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11763): dvb-ttpci: Some whitespace adjustmentsOliver Endriss
Some whitespace adjustments. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11762): dvb-ttpci: Fixed return code of av7110_av_start_playOliver Endriss
av7110_av_start_play() should return 0 on success. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11761): dvb-ttpci: Fixed VIDEO_SLOWMOTION ioctlOliver Endriss
Fixed VIDEO_SLOWMOTION ioctl. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11760): dvb-ttpci: Check transport error indicator flagOliver Endriss
Discard PES packet if transport error indicator flag is set. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11759): dvb-ttpci: Add TS replay capabilityOliver Endriss
Implemented TS replay capability. audio/video devices are able to process PES and TS data now. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11758): 2: handle unregister for non-I2C buildsRandy Dunlap
Build fails when CONFIG_I2C=n, so handle that case in the if block: drivers/built-in.o: In function `v4l2_device_unregister': (.text+0x157821): undefined reference to `i2c_unregister_device' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11701): pvrusb2: Ensure the PVRUSB2 disabled the i2c gate on the ↵Steven Toth
tda10048. ... else DVB-T tuning will not work. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11700): tda10048: Added option to block i2c gate control from other ↵Steven Toth
drivers. Currently, DVB-T is broken and this fixes it. The PVRUSB2 has an odd I2C bus configuration where opening the i2c gate on the digital and analog demod causes the tuner to fail. This needs to be protected against for the PVRUSB2. Signed-off-by: Steven Toth <stoth@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11677): radio-fm16: fix g_tuner.Hans Verkuil
g_tuner handled capability, audmode and rxsubchans incorrectly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11676): radio-fm16: cleanupsHans Verkuil
Remove bogus flags field Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11756): soc_camera: depends on I2CRandy Dunlap
soc_camera uses i2c_*() functions and has build errors when CONFIG_I2C=n: ERROR: "i2c_new_device" [drivers/media/video/soc_camera.ko] undefined! ERROR: "i2c_get_adapter" [drivers/media/video/soc_camera.ko] undefined! ERROR: "i2c_put_adapter" [drivers/media/video/soc_camera.ko] undefined! ERROR: "i2c_unregister_device" [drivers/media/video/soc_camera.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11753): tveeprom: Point the TCL MNM05-4 tuner entry to an actual ↵Andy Walls
tuner definition The TCL MNM05-04 is used on some HVR-1600 models. It appears to be similar to the TCL MFMN05-4 but without FM radio. The TUNER_PHILIPS_FM1236_MK3 tuner definition appears to be the proper existing tuner definition to use for this tuner. Reported-by: Matt Beadon <matt.beadon@gmail.com> Tested-by: Matt Beadon <matt.beadon@gmail.com> Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11752): cx18: Add missing newline to tuner detection error messageAndy Walls
2009-06-16V4L/DVB (11750): pvrusb2: Allocate a routing ID for future support of ↵Mike Isely
Terratec Grabster AV400 Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11748): pvrusb2: Don't use the internal i2c client listJean Delvare
The i2c core used to maintain a list of client for each adapter. This is a duplication of what the driver core already does, so this list will be removed as part of a future cleanup. Anyone using this list must stop doing so. For pvrusb2, I propose the following change, which should lead to an equally informative output. The only difference is that i2c clients which are not a v4l2 subdev won't show up, but I guess this case is not supposed to happen anyway. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11747): pvrusb2: Bump up version advertised through v4l interfaceMike Isely
Kick up the pvrusb2 version number advertised through the v4l interface. This value really has almost no meaning because I don't make a serious attempt to version the driver in this manner (otherwise this one line becomes a nasty hotspot of changes and merge conflicts). The value that is here is really a historical thing. However Hans Verkuil thought it might be a good idea to bump up the number anyway right now since the driver's mechanism for communicating with the v4l core has pretty much completely changed. Sending out a Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11746): pvrusb2: Set ir_video autoloading to default disabledMike Isely
This sets the disable_autoload_ir_video module option to being set, which disables any attempt by the driver to autoload IR support. This changes preserves previous behavior, for now. This change can be set back concurrent with other changes that finally update i2c-kbd-i2c to use the new i2c binding model. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11745): pvrusb2: Update to work with upcoming ir_video changes in ↵Mike Isely
v4l-dvb core The ir-kbd-i2c module is about to be updated to match the new style i2c binding model. These pvrusb2 changes maintain compatibility with that change. Note that this does not actually break anything even without the expected ir-kbd-i2c changes yet because previously the pvrusb2 didn't autoload ir-kbd-i2c anyway. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11744): pvrusb2: Select, track, and report IR scheme in use with ↵Mike Isely
the device This change defines all possible "IR schemes" related to the pvrusb2 driver, on a per-device basis. That information is then set according to the hardware in use. The idea here is to make possible a more intelligent future decision on which, if any, IR receiver driver might be loaded during initialization. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11743): Analog Devices ADV7343 video encoder driverChaithrika U S
Add ADV7343 I2C based video encoder driver. This follows the v4l2-subdev framework. This driver has been tested on TI DM646x EVM. It has been tested for Composite and Component outputs. Updates as per review by Mauro Chehab, added support for more standards supported by the encoder. Also adding the missed out signed-offs.Tested only NTSC and PAL standards. [hverkuil@xs4all.nl: s_routing API changed, updated driver to use new API] Signed-off-by: Manjunath Hadli <mrh@ti.com> Signed-off-by: Brijesh Jadav <brijesh.j@ti.com> Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11742): TI THS7303 video amplifier driver codeChaithrika U S
This patch adds driver for TI THS7303 video amplifier. This driver is implemented as a v4l2 sub device. Tested on TI DM646x EVM. This version has updates based on review comments by Mauro Chehab. Signed-off-by: Chaithrika U S <chaithrika@ti.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11741): zoran: Fix &&/|| typoRoel Kluin
Fix &&/|| typo. `default_norm' can be 0 (PAL), 1 (NTSC) or 2 (SECAM), the condition tested was impossible. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB: cleanup redundant tests on unsignedRoel Kluin
Remove redundant tests on unsigned. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11739): remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11737): Drop stray references to i2c_probeJean Delvare
The new i2c binding model doesn't use i2c_probe. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11736): videobuf: modify return value of VIDIOC_REQBUFS ioctlNémeth Márton
The V4L2 ioctls usually return 0 when the operation was successful and -1 in case of error. Currently VIDIOC_REQBUFS returns the number of buffers which is redundant because this information is available in count field of struct v4l2_requestbuffers. The V4L2 API specification, revision 0.24 [1] explicitly specifies for VIDIOC_REQBUFS that the return value shall be 0 on success. The patch was tested with v4l-test 0.13 [2] with vivi driver. References: [1] V4L2 API specification, revision 0.24 http://v4l2spec.bytesex.org/spec/r13696.htm [2] v4l-test: Test environment for Video For Linux Two API http://v4l-test.sourceforge.net/ Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11735): Enables the Winfast TV2000 XP Global TV IRPieter Van Schaik
Adds support to the remote control of the Winfast TV2000 XP Global TV capture card. A case statement was added in order to initialize the GPIO data structures as well as a case statement for handling the keys correctly when pressed. Thanks to Hermann and Mauro for all the help Signed-off-by: Pieter C van Schaik <vansterpc@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11734): remove hw reset of MPEG encoder when lost/found seq.Dmitri Belimov
When we capture signal from composite input offen lost and found syncro sequence. In this case the MPEG coder hardware reset after each lost/found event. The image has a lot of artefactes. This patch remove hardware reset of MPEG encoder. This is patch from our customer. I checked this. With my best regards, Dmitry. Signed-off-by: Alexey Osipov <lion-simba@pridelands.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11733): increase MPEG encoder timoutDmitri Belimov
If video has a lot of changes in frame, MPEG encoder need more time for coding process. Add new bigger timeout for encoder. This is patch from our customer. I checked this. Signed-off-by: Alexey Osipov <lion-simba@pridelands.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11732): saa7134: disable not yet existing IR and DVB support on the ↵hermann pitton
Compro T750 The Compro VideoMate T750 has no support for IR and DVB-T yet. Disable both to avoid fall through and confusing printouts. Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11731): buf-dma-contig: remove sync operationMagnus Damm
Remove the videobuf-dma-contig sync operation. Sync is only needed for noncoherent buffers, and since videobuf-dma-contig is built on coherent memory allocators the memory is by definition always in sync. Reported-by: Matthieu CASTET <matthieu.castet@parrot.com> Signed-off-by: Magnus Damm <damm@igel.co.jp> Reviewed-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11730): af9015: support for KWorld MC810Wen-chien Jesse Sung
Add USB ID (1b80:c810) for Kworld MC810. Signed-off-by: Wen-chien Jesse Sung <jesse@cola.voip.idv.tw> Acked-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB: cx23885/cymax2: binary/logical &/&& typoRoel Kluin
2009-06-16V4L/DVB (11724): firedtv: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11723): Link firmware to physical deviceJean Delvare
Use the physical device rather than the i2c adapter as the reference device when loading firmwares. This will prevent the sysfs name collision with i2c-dev that has been reported many times. I may have missed other drivers which need the same fix. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11720): gspca - sonixj: Webcam 06f8:3008 addedJani Monoses
Signed-off-by: Jani Monoses <jani@ubuntu.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11719): gspca - vc032x: mi1320_soc images are upside-downJean-Francois Moine
2009-06-16V4L/DVB (11718): gspca - vc032x: Bad pixelformat for mi1320_socJean-Francois Moine
2009-06-16V4L/DVB (11717): gspca - sonixj: Webcams with bridge sn9c128 addedJean-Francois Moine
2009-06-16V4L/DVB (11716): gspca - sonixj: Adjust some exchanges according to tracesJean-Francois Moine
2009-06-16V4L/DVB (11715): gspca - main: Set the number of packets per ISOC message.Jean-Francois Moine
The number of packets per isochronous message may now be set by the subdrivers (default value 32). Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11714): gspca - spca500 and sunplus: Change the 0x00 insertion ↵Jean-Francois Moine
mechanism. The new mechanism does not use any temporary buffer. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11713): gspca - ov534: Don't discard the images when no UVC EOFJean-Francois Moine
A new image may start without any UVC EOF in the last packet of the previous image. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11712): gspca - main: Set the current alternate setting only when ↵Jean-Francois Moine
needed Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11711): gspca - main: Fix a crash when no bandwidth availableJean-Francois Moine
When the bandwidth is not wide enough, the transfer endpoint may be set to the one of the alternate setting 0. This one may be null and this causes a divide by 0 oops. Reported-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
