- Version update
Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com>
Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com>
- Printing the function's configured mode of operation.
- Disable fcs stripping. The minimum frame size that can be received by the
hardware is 57 Bytes. A 64 Byte Ethernet frame with the vlan tag and fcs
stripped will result in a 56 Byte frame which will lock up the receive
engine. The work around is to disable fcs stripping in the hardware which
is done with a firmware upgrade. The fixes are -
1. Ensure that the correct firmware version is used.
2. Decrement the indicated packet length of the receive packet by 4 bytes
(FCS length).
- Fixes in isr routine
Fixed crash with INTA mode during driver unload. Pass hldev to request_irq
instead of vdev.
Fixed Traffic failure with GRO in INTA mode. Pass the correct napi
context to gro functions.
- Removed the code to bounds check the mss value. The hardware does bounds checking and
will not allow an oversized mss to lockup the transmit path.
- Corrected Register map entry for xmac_link registers.
- Fixed the crash in rmmod after vpath open failed when trying to change mtu.
We should check for card status before continuing in device close.
- Fixed memory leak by freeing memory allocated for device_config.
- Removed ioremap of bar1 address
Driver needs only bar0 address for register access
- Removed references to bar1 and bar2 addresses
Replaced '0' by 'bar' in the probe function.
The 'bar' variable was already set to '0' and is already
used in pci_iomap(). This is cleaner and improves code
consistency.
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
Acked-by: Florian Fainelli <florian@openwrt.org>
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
almost no users in the tree; and the few that use them treat them
like NET_RX_DROP.
Eric Dumazet a écrit :
> Ingo Molnar a écrit :
>>> The following changes since commit 52989765629e7d182b4f146050ebba0abf2cb0b7:
>>> Linus Torvalds (1):
>>> Merge git://git.kernel.org/.../davem/net-2.6
>>> are available in the git repository at:
>>> master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6.git master
>> Hm, something in this lot quickly wrecked networking here - see the
>> tx timeout dump below. It starts with:
>> [ 351.004596] WARNING: at net/sched/sch_generic.c:246 dev_watchdog+0x10b/0x19c()
>> [ 351.011815] Hardware name: System Product Name
>> [ 351.016220] NETDEV WATCHDOG: eth0 (forcedeth): transmit queue 0 timed out
>> Config attached. Unfortunately i've got no time to do bisection
>> today.
> forcedeth might have a problem, in its netif_wake_queue() logic, but
> I could not see why a recent patch could make this problem visible now.
> CPU0/1: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ stepping 02
> is not a new cpu either :)
> forcedeth uses an internal tx_stop without appropriate barrier.
> Could you try following patch ?
> (random guess as I dont have much time right now)
We might have a race in napi_schedule(), leaving interrupts disabled forever.
I cannot test this patch, I dont have the hardware...
Tested-by: Ingo Molnar <mingo@elte.hu>
The call resource_size(res) returns res->end - res->start + 1 and thus the
second change is semantics-preserving. res_size is then used as the second
argument of a call to request_mem_region, and the memory allocated by this
call appears to be the same as what is released in the two calls to
release_mem_region. So the size argument for those calls should be
resource_size(size) as well. Alternatively, in the second call to
release_mem_region, the second argument could be res_size, as that variable
has already been initialized at the point of this call.
The problem was found using the following semantic patch:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
- res->end - res->start
+ BAD(resource_size(res))
// </smpl>
add new id (RIOS System PC CARD3 ETHERNET).
Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp>
This patch properly defines the maximum values for rx/tx coalescing timeouts.
Signed-off-by: Vlad Zolotarov <vladz@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Problem reported by Flavio Leitner <fleitner@redhat.com>:
When setting rx/tx coalescing timeout to the values less than 12 traffic was
stopped.
The FW supports coalescing in 12us granularity, and so value of less then 12
should be interpreted as disabling coalescing
It is currently possible for an asynchronous device unregister
to cause the same tun device to be unregistered twice. This
is because the unregister in tun_chr_close only checks whether
__tun_get(tfile) != NULL. This however has nothing to do with
whether the device has already been unregistered. All it tells
you is whether __tun_detach has been called.
This patch fixes this by using the most obvious thing to test
whether the device has been unregistered.
It also moves __tun_detach outside of rtnl_unlock since nothing
that it does requires that lock.
Commit 537a1bf059fa312355696fa6db80726e655e7f17 (fbdev: add mutex for
fb_mmap locking) introduces a ->mm_lock mutex for protecting smem
assignments. Unfortunately in the case of sm501fb these happen quite
early in the initialization code, well before the mutex_init() that takes
place in register_framebuffer(), leading to:
Badness at kernel/mutex.c:207
Pid : 1, Comm: swapper
CPU : 0 Not tainted (2.6.31-rc1-00284-g529ba0d-dirty #2273)
PC is at __mutex_lock_slowpath+0x72/0x1bc
PR is at __mutex_lock_slowpath+0x66/0x1bc
matroxfb appears to have the same issue and has solved it with an early
mutex_init(), so we do the same for sm501fb.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Cc: Krzysztof Helt <krzysztof.h1@wp.pl>
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: (27 commits)
parisc: use generic atomic64 on 32-bit
parisc: superio: fix build breakage
parisc: Fix PCI resource allocation on non-PAT SBA machines
parisc: perf: wire up sys_perf_counter_open
parisc: add task_pt_regs macro
parisc: wire sys_perf_counter_open to sys_ni_syscall
parisc: inventory.c, fix bloated stack frame
parisc: processor.c, fix bloated stack frame
parisc: fix compile warning in mm/init.c
parisc: remove dead code from sys_parisc32.c
parisc: wire up rt_tgsigqueueinfo
parisc: ensure broadcast tlb purge runs single threaded
parisc: fix "delay!" timer handling
parisc: fix mismatched parenthesis in memcpy.c
parisc: Fix gcc 4.4 warning in lba_pci.c
parisc: add parameter to read_cr16()
parisc: decode_exc.c should include kernel.h
parisc: remove obsolete hw_interrupt_type
parisc: fix irq compile bugs in arch/parisc/kernel/irq.c
parisc: advertise PCI devs after "assign_resources"
Manually fixed up trivial conflicts in tools/perf/perf.h due to addition
of SH vs HPPA perf-counter support.
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: fix pcap adc locking
mfd: sm501, fix lock imbalance
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
MIPS: Fix CONFIG_FLATMEM version of pfn_valid()
MIPS: Reorganize Cavium OCTEON PCI support.
Update Yoichi Yuasa's e-mail address
MIPS: Allow suspend and hibernation again on uniprocessor kernels.
MIPS: 64-bit: Fix o32 core dump
MIPS: BC47xx: Fix SSB irq setup
MIPS: CMP: Update sync-r4k for current kernel
MIPS: CMP: Move gcmp_probe to before the SMP ops
MIPS: CMP: activate CMP support
MIPS: CMP: Extend IPI handling to CPU number
MIPS: CMP: Extend the GIC IPI interrupts beyond 32
MIPS: Define __arch_swab64 for all mips r2 cpus
MIPS: Update VR41xx GPIO driver to use gpiolib
MIPS: Hookup new syscalls sys_rt_tgsigqueueinfo and sys_perf_counter_open.
MIPS: Malta: Remove unnecessary function prototypes
MIPS: MT: Remove unnecessary semicolons
MIPS: Add support for Texas Instruments AR7 System-on-a-Chip
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes:
kbuild: finally remove the obsolete variable $TOPDIR
gitignore: ignore scripts/ihex2fw
Kbuild: Disable the -Wformat-security gcc flag
gitignore: ignore gcov output files
kbuild: deb-pkg ship changelog
Add new __init_task_data macro to be used in arch init_task.c files.
asm-generic/vmlinux.lds.h: shuffle INIT_TASK* macro names in vmlinux.lds.h
Add new macros for page-aligned data and bss sections.
asm-generic/vmlinux.lds.h: Fix up RW_DATA_SECTION definition.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: don't merge requests of different failfast settings
cciss: Ignore stale commands after reboot
Occasionally we may see an interrupt without an event in the eq.
In intx, we currently see the event queue and return IRQ_NONE causing
a the irq to be disabled ("no one cared".) Instead, read the CEV_ISR
reg to check the existence of the interrupt.
Signed-off-by: Sathya Perla <sathyap@serverengines.com>
This workaround is required for an issue in hardware where noise on the
interconnect between the MAC and PHY could be generated by a lower power
mode (K1) at 1000Mbps resulting in bad packets. Disable K1 while at 1000
Mbps but keep it enabled for 10/100Mbps and when the cable is disconnected.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Some PHYs may require two reads of the PHY_STATUS register to determine the
link status. If the PHY is being accessed by another thread it is possible
the first read could timeout and fail. In this case, put a delay in so
the second read will pick up the correct link status.
Limit NVM writes to 4K sections to prevent NVM corruption on larger
sector allocations (up to 64K).
The driver was accessing register bits for features on parts that do
not support that feature. This could cause problems in the hardware.
A previous workaround for 82578 to avoid link stall causes some PHY
registers to get cleared inadvertently. Add a delay after all LCD resets
to make sure PHY registers are in a stable state before continuing. Also,
after resets check the EEC register for the state of PHY configuration
performed by the MAC for ICH9 and earlier parts (as done before), but check
the LAN_INIT_DONE bit in the STATUS register for ICH10 and newer parts (EEC
doesn't exist in these newer parts).
PHY loopback on 82578 fails to work as a result of flushing the packets
in the FIFO buffer in the link stall workaround. Don't perform the
workaround if in PHY loopback mode.
Wake-on-lan is currently only supported by 82599 KX4 devices, in all
other cases return a proper value from ixgbe_wol_exclusion function call.
Otherwise from ethtool we will be able to change wol options of
unsupported 8259x devices.
Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com>
Currently if we loaded the driver, insert an unsupported module, and then
attempt to "ifconfig up" the device it will be brought down but the netdev
would not be unregistered. This behavior is different than all other
code paths. This patch corrects that by down'ing the device and then
scheduling the sfp_config_module_task tasklet. The tasklet will detect
this condition (like it does with other code paths) and do the
unregister_netdev().
I also removed the log message as this condition (an unsupported SFP+
module) will be logged in sfp_config_module_task.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
The change to check the SFP+ module again on open() was
causing the XFP (non-SFP+) adapters to be rejected. We
only want to try and re-identify the SFP+ module if the
original probe found that this device was an SFP+ device.
So for this code path (driver loaded with SFP module, module
inserted, ifconfig up of the device) the type will be
ixgbe_phy_unknown for an unidentified SFP+ module. So we
only check if that is the case.
This problem also shows up on Copper devices.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
Several small fixes around negative test case of the insertion of a
IXGBE_ERR_NOT_SUPPORTED module.
- mdio45_probe call was always failing due to mdio.prtad not being
set. The function set to mdio.mdio_read was still working as we just
happen to always be at prtad == 0. This will allow us to set the phy_id
and phy.type correctly now.
- There was timing issue with i2c calls when initiated from a tasklet.
A small delay was added to allow the electrical oscillation to calm down.
- Logic change in ixgbe_sfp_task that allows NOT_SUPPORTED condition
to be recognized.
Some usage was only sizing a pointer rather than the data type.
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com>
We need to set/clear the mac address register when the link goes up/down
respectively. Without this both ports of a 2-port device can end up
with the same mac address in a bonding scenario.
The new ql_link_on() and ql_link_off() will also be used in handling
certain firmware events.
This addes functionality to set/clear the MAC address in the hardware
when the link goes up/down.
The MAC address register is persistent across function resets. In
bonding the same address can bounce from one port to the other. This
can cause packets to be delivered to the wrong port.
This patch clears the MAC address in the hardware when the link is down
and sets it when the link comes up.
It was found that pulling/pushing the cable from one port to another
causes the same MAC address to be in both ports.
The next patch in this series will use this functionality as well.
The caller will free acquired resouces if a failure occurs.
We were turning on the carrier without verifying the link was up.
This adds link up to the link initialize check before turning carrier
on.
Not clearing the routing bits can cause frames to erroneously get routed to
management processor.
The hardware semaphore covers the configuration register as well as the
ICB registers. The ICB high and low regs contain the address of the
initialization control block and the config register is used to signal
the hardware that a block is ready to be downloaded. Currently we were
only protecting the ICB regs. This changes expands to cover the config
register as well.
When doing an unexpected shutdown like kexec the cciss
firmware might still have some commands in flight, which
it is trying to complete.
The driver is doing it's best on resetting the HBA,
but sadly there's a firmware issue causing the firmware
_not_ to abort or drop old commands.
So the firmware will send us commands which we haven't
accounted for, causing the driver to panic.
With this patch we're just ignoring these commands as
there is nothing we could be doing with them anyway.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Acked-by: Mike Miller <mike.miller@hp.com>
Signed-off-by: Jens Axboe <axboe@carl.(none)>
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
The current ssb irq setup in ssb_mipscore_init has the problem that it
configures some device on some irq without checking that the irq is not
taken by an other device.
For example in my case PCI host is on irq 0 and IPSEC on irq 3.
The current code:
- store in dev->irq that IPSEC irq is 3 + 2
- do a set_irq 0->3 on PCI host
But now IPSEC irq is not routed anymore to the mips code and dev->irq is
wrong. This causes a problem described in [1].
This patch tries to solve the problem by making set_irq configure the
device we want to take the irq on the shared irq0. The previous example
becomes:
- do a set_irq 0->3 on PCI host:
- irq 3 is already taken by IPSEC. do a set_irq 3->0 on IPSEC
I also added some code to print the irq configuration after irq setup to
allow easier debugging. And I add extra checking in ssb_mips_irq to report
device without irq or device with not routed irq.
[1] http://www.danm.de/files/src/bcm5365p/REPORTED_DEVICES
Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr>
Acked-by : Michael Buesch <mb@bu3sch.de>
Tested-by: Florian Fainelli <florian@openwrt.org>
Signed-off-by: Yoichi Yuasa <yyuasa@linux.com>
Release the lock on error.
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com>
Add omitted unlock in sm501_unit_power.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
