path: root/drivers
2010-02-03sfc: Enable autonegotiated flow-control by default if supportedSteve Hodgson
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Handle firmware assertion failure while resettingSteve Hodgson
This allows the driver to recover if the MC firmware has crashed due to an assertion failure. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03sfc: Update MCDI protocol definitionsBen Hutchings
2010-02-03drivers/net/amd8111e.c: Fix continuation line formatsJoe Perches
String constants that are continued on subsequent lines with \ are not good. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03can: add support for CAN interface cards based on the PLX90xx PCI bridgePavel Cheblakov
This driver is for CAN interface cards based on the PLX90xx PCI bridge. Driver supports now: - Adlink PCI-7841/cPCI-7841 card (http://www.adlinktech.com/) - Adlink PCI-7841/cPCI-7841 SE card - Marathon CAN-bus-PCI card (http://www.marathon.ru/) - TEWS TECHNOLOGIES TPMC810 card (http://www.tews.com/) Changes since v1: - Added some defines for static inline int plx_pci_check_sja1000(...) - static struct pci_device_id plx_pci_tbl[] replaced by static DEFINE_PCI_DEVICE_TABLE(plx_pci_tbl) - Typo fixed Signed-off-by: Pavel Cheblakov <P.B.Cheblakov@inp.nsk.su> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03cxgb3: add memory barriersDivy Le Ray
Add memory barriers to fix crashes observed on newest PowerPC platforms. The HW and driver state of the receive rings were getting out of sync. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03MCS7830 USB-Ether: resume _with_ working link, via .reset_resume supportAndreas Mohr
ChangeLog: Implement .reset_resume support to retain a live network connection during suspend despite USB power loss. - rework operation to reference cached data in mcs7830_data and netdev->dev_addr - update netdev->dev_addr only in case new MAC was set successfully . Tests done: . ethtool -d pre-/post-suspend: register values match . running ssh session suspend, resume: works . ifdown device, suspend, resume: works . ifup, suspend, unplug, resume: WORKS (eth1 is removed, re-ifup of eth1 after card replug works) . verified identical MAC in ifconfig post-resume (ok, should be verified on network side to be fully certain...) Keywords: suspend resume network connection dead interface down Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03MCS7830 USB-Ether: change register defineAndreas Mohr
ChangeLog: - rename register, add comment Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03MCS7830 USB-Ether: Spelling correctionsAndreas Mohr
ChangeLog: - spelling corrections / whitespace Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03MCS7830 USB-Ether: add Rx error supportAndreas Mohr
ChangeLog: - evaluate Rx error statistics from trailing Rx status byte - add driver TODO list - add myself to authors Quilt series run-tested, based on 2.6.33-rc4 (net-2.6.git mcs7830 has idle history, should be good to go). Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: add loopback diagnostic testAmit Kumar Salecha
Loopback test (offline) added in ethtool self test. o Set device in loopback mode o Send packets o Process receive packets in qlcnic_process_rcv_ring_diag() o Compare packets o Reset device in normal mode. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: add interrupt diagnostic testAmit Kumar Salecha
Interrupt test (offline) added in ethtool self test. Register a temporary interrupt handler and then send command to fw to raise an interrupt. Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: support LED blink for device identificationSucheta Chakraborty
Added support of device identification by blinking LED for specified time. Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: protect resoruce cleanup by rtnl lockAmit Kumar Salecha
o context resources can be in used, while resoruce cleanup is in progress, during fw recover. o Null pointer execption can occur in send_cmd_desc, if fw recovery module frees tx ring without rtnl lock. o Same applies to ethtool register dump and FW health registers should be dump in any case. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: clear device reset state after fw recoveryAmit Kumar Salecha
o After firmware recovery, clear device reset state transition register. Otherwise firmware reload can occur unnecessary. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: add ethernet identifier in board infoAmit Kumar Salecha
Added missing identifier that distinguishes between FCOE/ISCSI/ETHERNET functions. Signed-off-by: Rajesh K Borundia <rajesh.borundia@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02qlcnic: use DEFINE_PCI_DEVICE_TABLEAmit Kumar Salecha
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02sky2: Fix TX_MAP_PAGE misspellingJarek Poplawski
Btw of the dma-debug problem reported by Michael Breuer I spotted a tiny misspelling in TX_MAP_PAGE definition introduced by commit 6b84dacadbdc3. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02virtio_net: Defer skb allocation in receive path Date: Wed, 13 Jan 2010 ↵Shirley Ma
12:53:38 -0800 virtio_net receives packets from its pre-allocated vring buffers, then it delivers these packets to upper layer protocols as skb buffs. So it's not necessary to pre-allocate skb for each mergable buffer, then frees extra skbs when buffers are merged into a large packet. This patch has deferred skb allocation in receiving packets for both big packets and mergeable buffers to reduce skb pre-allocations and skb frees. It frees unused buffers by calling detach_unused_buf in vring, so recv skb queue is not needed. Signed-off-by: Shirley Ma <xma@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02virtio: Add ability to detach unused buffers from vringsShirley Ma
There's currently no way for a virtio driver to ask for unused buffers, so it has to keep a list itself to reclaim them at shutdown. This is redundant, since virtio_ring stores that information. So add a new hook to do this. Signed-off-by: Shirley Ma <xma@us.ibm.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02net/irda: sh_sir: Add SuperH IrDA driverKuninori Morimoto
This is very simple IrDA SIR driver for SuperH. This driver was tested by irdaping/ircp on SH7724 EcoVec24 board Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/xircom_cb.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove DRV_NAME and xircom_cb from pr_<level> Convert embedded function names in logging messages to %s, __func__ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/winbond-840.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Convert %d.%d.%d.%d to %pI4 Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/uli526x.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove DRV_NAME from logging messages Add do {} while(0) to ULI526X_DBUG macro Make SHOW_MEDIA_TYPE macro more readable Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/timer.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/pnic2.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip/pnic.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip/media.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip/interrupt.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip/eeprom.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip/dmfe.c: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where a dev is available Convert printks to pr_<level> where not Coalesce format strings Change print formats with %d.dx to %0dx Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Remove 'DRV_NAME ": ' from logging messages Convert commented out printks to pr_debug Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-31tulip/de2104x.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip/21142.c: Use dev_<level> and pr_<level>Joe Perches
2010-01-31tulip_core: Use dev_<level> and pr_<level>Joe Perches
Convert printks to dev_<level> where appropriate Convert printks to pr_<level> Change print formats with %d.dx to %0dx Coalesce long formats Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28net: merge fixup for qlge_mainStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28Merge branch 'master' of ↵David S. Miller
2010-01-28netdev: remove HAVE_ leftoversAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28bonding: bond_open error return valuestephen hemminger
The convention for API functions in kernel is to return errno value; bond_open would return -1 if alb setup failed. The only reason that could happen is if kmalloc() failed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28ixgbe: if ixgbe_copy_dcb_cfg is going to fail learn about it earlyJohn Fastabend
Call ixgbe_copy_dcb_cfg() earlier in the ixgbe_dcbnl_set_all() so that we can learn if this is going to fail as early as possible. Previously, ixgbe_down or ixgbe_close were being called before this check and the IXGBE_RESETTING bit was being set and cleared. Worse if this failed the corresponding ixgbe_up/ndo_open would not called. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28ixgbe: set the correct DCB bit for pg tx settingsJohn Fastabend
Set the correct bit BIT_PG_TX when tx PG settings are set. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: PJ Waskiewicz <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28igbvf: fix issue w/ mapped_as_page being left set after unmapAlexander Duyck
This change fixes an issue in igbvf with mapped_as_page being left set after a page is unmapped which results in buffers which are mapped via map single being unmapped as page. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28drivers/net: ks8851_mll ethernet network driverChoi, David
Hello David Miller, I fix a bug in ks8851_mll driver, which has existed since 2.6.32-rc6. >From : David J. Choi <david.choi@micrel.com> Fix a bug that the data pointers in the interrupt handler are set wrong, which is related with the 5th parameter of request_irq(). Signed-off-by : David J. Choi <david.choi@micrel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28be2net: Bug fix to support newer generation of BE ASICAjit Khaparde
Bug fix in be2net for newer generation of BladeEngine ASIC. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26starfire: clean up properly if firmware loading failsBen Hutchings
netdev_open() will return without cleaning up net device or hardware state if firmware loading fails. This results in a BUG() on a second attempt to bring the interface up, reported in <http://bugzilla.kernel.org/show_bug.cgi?id=15091>, and probably has even worse effects if the driver is removed afterwards. Call netdev_close() to clean up on failure. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15091 Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reported-by: Michael Moffatt <michael@moffatt.org.nz> Tested-by: Michael Moffatt <michael@moffatt.org.nz> Cc: "David S. Miller" <davem@davemloft.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-26ariadne: Fix build.David S. Miller
References removed HAVE_MULTICAST. Reporeted-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25virtio_net: Make delayed refill more reliableHerbert Xu
I have seen RX stalls on a machine that experienced a suspected OOM. After the stall, the RX buffer is empty on the guest side and there are exactly 16 entries available on the host side. As the number of entries is less than that required by a maximal skb, the host cannot proceed. The guest did not have a refill job scheduled. My diagnosis is that an OOM had occured, with the delayed refill job scheduled. The job was able to allocate at least one skb, but not enough to overcome the minimum required by the host to proceed. As the refill job would only reschedule itself if it failed completely to allocate any skbs, this would lead to an RX stall. The following patch removes this stall possibility by always rescheduling the refill job until the ring is totally refilled. Testing has shown that the RX stall no longer occurs whereas previously it would occur within a day. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25sfc: Use fixed-size buffers for MCDI NVRAM requestsBen Hutchings
The low-level MCDI code always uses 32-bit MMIO operations, and callers must pad input and output buffers to multiples of 4 bytes. The MCDI NVRAM functions are not doing this. Also, their buffers are declared as variable-length arrays with no explicit maximum length. Switch to a fixed buffer size based on the chunk size used by the MTD driver (which is a multiple of 4). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25sfc: Add workspace for GMAC bug workaround to MCDI MAC_STATS bufferGuido Barzini
Due to a hardware bug in the SFC9000 family, the firmware must transfer raw GMAC statistics to host memory before aggregating them into the cooked (speed-independent) MAC statistics. Extend the stats buffer to support this. The length of the buffer is explicit in the MAC_STATS command, so this change is backward-compatible on both sides. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-25qlge: Only free resources if they were allocatedBreno Leitao
Currently qlge tries to release regions even if they were not allocated. This causes messages like the following in the kernel log Trying to free nonexistent resource <00000000006af400-00000000006af4ff> Trying to free nonexistent resource <00003c04ff9f4000-00003c04ff9f7fff> Trying to free nonexistent resource <00003c04ffc00000-00003c04ffcfffff> This patch fixes the goto logic in order to not release the resources if they were not allocated. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
