Patch and mail from both MikeC and HannesR:
Before we're trying to send a PDU we have to check whether a TMF
is active. If so and if the PDU will be affected by the TMF
we should allow only Data-out PDUs to be sent.
If fast_abort is set, no Data-out PDUs will be sent while
a LUN reset is being processed for a affected LUN.
fast_abort is now ingored during a ABORT TASK tmf. We will not
send any Data-outs for a task if the task is being aborted.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
For some reason we used to check for the the immediate bit
set and the opcocde in many places instead of just masking
the opcode. In the passthrough code this is a problem
because userspace may or may not have set the immediate bit
and it does not have to. This fixes up the opcode checks
in the passthrough code, so we mask off the opcode then
check against the iscsi proto definition like is done in
other places.
This just has bnx2i use the iscsi_suspend_queue helper.
The suspend works as follows:
When ep_poll has succeeed iscsid will call conn_bind, the LLD will
then call iscsi_conn_bind which will clear the suspend bit.
When ep_disconnect is called (or if there is a conn error) we set
the suspend bit. For the ep_disconnect case I added a helper
in the previous kernel that will take the session lock to make sure
iscsi_queuecommand/xmit_task is not running and it will set
the suspend bit.
Acked-by: Anil Veerabhadrappa <anilgv@broadcom.com>
Four models, OPEN-/DF400/DF500/DISK-SUBSYSTEM, can handle REPORT_LUN,
and the BLIST_REPORTLUN2 flag needs to be set. And DF600 doesn't require
any flags because it returns ANSI 03h (SPC).
Signed-off-by: Takahiro Yasui <tyasui@redhat.com>
The scsi ioctl code path was missing scsi target reset
support. This patch just adds it.
If the port state is blocked and the fast io fail tmo has
fired then this patch will fail bsg requests immediately.
This is needed if userspace is sending IOs to test the transport
like with fcping, so it will not have to wait for the dev loss tmo.
With this patch he bsg req fast io fail code behaves like the normal
and sg io/passthrough fast io fail.
Acked-By: James Smart <james.smart@emulex.com>
Allocate right size for bitmap tag,fix error goto and cleanup print
message and undocable commemts. patch attached.
Signed-off-by: Lindar Liu <lindar_liu@usish.com>
Signed-off-by: Jack Wang <jack_wang@usish.com>
We set interupt cascading count of outbound queue to get better
performance, correct some unnecessary return values and some noisy
print messages. patch attached.
Some of our virtual SCSI hosts don't have a proper bus parent at the
top, which can be a problem for doing DMA on them
This patch makes the host device cache a pointer to the physical bus
device and provides an extra API for setting it (the normal API picks
it up from the parent). This patch also modifies the qla2xxx and lpfc
vport logic to use the new DMA host setting API.
Cc: Stable Tree <stable@kernel.org>
Create the sysfs file, dh_state even if the new SCSI device is not
in the any of the device handler's internal lists.
Signed-Off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Acked-by: Hannes Reinecke <hare@suse.de>
`+' has a higher precedence than `?' so the condition always
evaluates to true and this is preprocessed to `7*((ql) - 1)'
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The FC-LS spec. says ELS timeouts should be 2 x R_A_TOV.
The FC-GS spec. says CT timeouts should be 3 x R_A_TOV.
We've been using E_D_TOV for both of those.
Change for all ELS and CT requests except FLOGI, which we
leave at 2 seconds (using E_D_TOV). One could argue that
R_A_TOV is locally determined until after FLOGI succeeds.
This does change FLOGI for vports which becomes FDISC.
This does not change the REC/SRR timeout which is 2 seconds.
Signed-off-by: Joe Eykholt <jeykholt@cisco.com>
Signed-off-by: Robert Love <robert.w.love@intel.com>
According to the FC-BB-5 Rev2.0, 7.8.6.2, we should not pad FIP keep-alive
frames.
Signed-off-by: Yi Zou <yi.zou@intel.com>
All exches must be freed before its EM mempool destroyed in this
case but currently some exches could be still pending in their
scheduled delayed work after EM mempool is destroyed causing
this issue discussed and reported in this latest email thread:-
http://www.open-fcoe.org/pipermail/devel/2009-October/004788.html
This patch fixes this issue by adding dedicated work queue thread
fc_exch_workqueue for exch delayed work and then flush this work
queue before destroying EM mempool.
The cancel_delayed_work_sync cannot be called during final
fc_exch_reset due to lport and exch locking ordering, so removes
related comment block not relevant any more with this patch.
Reported-by: Joe Eykholt <jeykholt@cisco.com>
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
There are cases outside of our control that may result in a transmit
skb being linearized in dev_queue_xmit. There are a couple of bugs
in libfc/fcoe that can result in a panic at that point. This patch
contains two fixes to prevent those panics.
1) use fast cloning instead of shared skbs with dev_queue_xmit
dev_queue_xmit doen't want shared skbuffs being passed in, and
__skb_linearize will BUG if the skb is shared. FCoE is holding an extra
reference around the call to dev_queue_xmit, so that when it returns an
error code indicating the frame has been dropped it can maintain it's
own backlog and retransmit. Switch to using fast skb cloning for this
instead.
2) don't append compound pages as > PAGE_SIZE skb fragments
fc_fcp_send_data will append pages from a scatterlist to the nr_frags[]
if the netdev supports it. But, it's using > PAGE_SIZE compound pages
as a single skb_frag. In the highmem linearize case that page will be
passed to kmap_atomic to get a mapping to copy out of, but
kmap_atomic will only allow access to the first PAGE_SIZE part.
The memcpy will keep going and cause a page fault once is crosses the
first boundary.
If fc_fcp_send_data uses linear buffers from the start, it calls
kmap_atomic one PAGE_SIZE at a time. That same logic needs to be
applied when setting up skb_frags.
Signed-off-by: Chris Leech <christopher.leech@intel.com>
If the underlying netdev is a VLAN device, make sure the VLAN ID is integrated
into the WWNN/WWPN name generation. Also added/updated the comments to reflect
this change.
DID_NO_CONNECT is not a nice value to use for pkt alloc failures,
because you can probably retry and IO will become available again.
For the device reset callout, we do not want to set the scsi command
result for the above reason, and because we do not need to set
the scsi_cmd->result in this path. We and other drivers do not set it
for success for example, and we do not set it for other failure.
And scsi-ml does not send every command through this path, and it is
not expecting us to use the scsi_cmnd struct like a cmd coming thruogh
queuecommand. I think it is more for storage in case we need a cmd
struct for a tmf and to give us certain params like the LUN.
Patch was made over scsi-misc today.
We are still using netdev->dev_addr to generate lport's WWNN/WWPN even if the
LLD has support for NETDEV_HW_ADDR_T_SAN. Instead, we should just use the
fip->ctl_src_addr, which is the NETDEV_HW_ADDR_T_SAN if LLD supports it or it
is just the netdev->dev_addr if it does not.
Make sure we are get the SAN MAC address from the real netdev if the input
netdev is a VLAN device.
This was fixed before in 7a7f0c7 but it's introduced again recently.
Add initialization of .bsg_request in the scsi_transport_fc
template so that fcping works.
Customers and certification tests have pointed out that we don't
show up on the switch management software as an initiator.
On some MDS switches 'show fcns database' command shows libfc
initiators as 'fcp' not 'fcp:init' like other initiators.
On others switches, I think the switch gets the features by doing a PRLI,
but it may be only certain models or under certain configurations.
Fix this by registering our FC4 features with the RFF_ID CT request
after local port login and after the RFT_ID.
Use libfcoe as a common FIP implementation with fcoe.
FIP or non-FIP mode is fully automatic if the firmware
supports and enables it.
Even if FIP is not supported, this uses libfcoe for the non-FIP
handling of FLOGI and its response.
Use the new lport_set_port_id() notification to capture
successful FLOGI responses and port_id resets.
While transitioning between Ethernet and FC mode, all rx and
tx FC frames are queued. In Ethernet mode, all frames are
passed to the exchange manager to capture FLOGI responses.
Change to set data_src_addr to the ctl_src_addr whenever it
would have previously been zero because we're not logged in.
This seems safer so we'll never send a frame with a 0 source MAC.
This also eliminates a special case for sending FLOGI frames.
There was a locking problem where the fip->lock was held during
the call to update_mac(). The rtnl_lock() must be taken before
the fip->lock, not the other way around. This fixes that.
Now that fcoe_ctlr_recv_flog() is called only from the response handler
to a FLOGI request, some checking can be eliminated. Instead of calling
update_mac(), just fill in the granted_mac address for the passed-in
frame (skb).
Eliminate the passed-in source MAC address since it is also in the skb.
Also, in fcoe, call fcoe_set_src_mac() directly instead of going thru
the fip function pointer. This will generate less code.
Then, since fip isn't needed for LOGO response, use lport as the arg.
The libfc link up/down messages don't indicate which port is changing.
The Port ID will often be 0.
This is to notify the LLD when an FC_ID is assigned to the local port.
The fnic driver needs to push the assigned FC_ID to firmware.
It currently does this by intercepting the FLOGI responses, and
in order to make that code more common with FIP and NPIV, it
makes more sense to wait until the local port has completely
handled the FLOGI or FDISC response. Also, when we fix
point-to-point FC_ID assignment, we'll need this callback as well.
Add a call to the libfc template, which is called whenever
the local port FC_ID is being assigned. It defaults to
fc_lport_set_fid(), supplied by libfc.
As additional benefit of this function, the LLD may determine
the MAC address that caused the change by looking at the received frame.
We also print the assigned port ID as long as it isn't 0.
Setting port ID to 0 happens often in reset while retrying FLOGI,
and would be uninteresting. This replaces the previous message
which didn't identify the host adapter instance.
patch v2 note: changed one word in a comment. "intercepted" -> "provided".
Local port debug messages were using fc_els_resp_type() which showed
all CT responses as rejects.
Handle CT responses correctly based by inspecting fh_type.
I decided not to rename the function to keep the patch smaller.
We could call it just fc_resp_type() or fc_elsct_resp_type().
This patch adds a check to fail gracefully when the netdevice
is bonded. Previously, the error was detected but the stack
would continue to load. This resulted in a partially enabled
fcoe intance and errors when the fcoe instance was destroy.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Remove the two extra function decalartions in fcoe.c.
If link is up, but no FCF is selected, don't send any ELS frames.
This came up when an fnic received a multicast advertisement but
no solitited advertisments, so no FCF was selected. It tried
to send FLOGIs anyway.
The fnic driver with FIP is reporting link up, even though it's down.
When the interface is shut down by the switch, we receive a clear
virtual link, and set the state reported to libfc as down, although
we still report it up. Clearly wrong. That causes the subsequent
link down event not to be reported, and /sys shows the host "Online".
Currently, in FIP mode, if an FCF times out, then link to libfc
is reported as down, to stop FLOGIs. That interferes with the LLD
link down being reported.
Users really need to know the physical link information, to diagnose
cabling issues, so physical link status should be reported to libfc.
If the selected FCF needs to be reported, that should be done
separately, in a later patch.
FIP's fcoe_ctlr_recv() function was previously only called from
the soft IRQ in FCoE. It's not performance critical and is more
convenient for some drivers to call it from the IRQ level. Just
Change to use skb_queue()/dequeue() which uses spinlock_irqsave
instead of separate locking with _bh locks.
Use scsi host number to identify debug messages.
Previously, no instance information was given, so if multiple
ports were active, it became confusing.
Allow FIP to be disabled by the driver for devices
that want to use libfcoe in non-FIP mode.
The driver merely sets the fcoe_ctlr mode to the state which
should be entered when the link comes up. The default is auto.
No change is needed for fcoe.c which uses auto mode.
Adds last_can_queue_ramp_down_time and updates this on every
ramp down. If last_can_queue_ramp_down_time is not zero then
do ramp up on any IO completion in added fc_fcp_can_queue_ramp_up.
Reset last_can_queue_ramp_down_time to zero once can_queue
is ramped up to added max_can_queue limit, this is to avoid any
more ramp up attempts on subsequent IO completion.
The ramp down and up are skipped for FC_CAN_QUEUE_PERIOD
to avoid infrequent changes to can_queue, this required
keeping track of ramp up time also in last_can_queue_ramp_up_time.
Adds code to ramp down can_queue if lp->qfull is set, with added
new ramp up code the can_queue will be increased after
FC_CAN_QUEUE_PERIOD, therefore it is safe to do ramp down
without fsp in this case and will avoid thrash. This required
fc_fcp_can_queue_ramp_down locking change so that it can be
called with Scsi_Host lock held.
Removes si->throttled and fsp state FC_SRB_NOMEM, not needed with
added ramp up code.
Currently can_queue is reduced only if frame alloc fails
during fc_fcp_send_data but frame alloc can fail at several
other places in FCP data path and can_queue needs to be
reduced for any FCP frame alloc failure.
This patch adds fc_fcp_frame_alloc for all FCP frame allocations
and if fc_frame_alloc fails in fc_fcp_frame_alloc then reduce
can_queue in fc_fcp_frame_alloc, this will reduce can_queue for
all FCP frame alloc failures.
This required moving fc_fcp_reduce_can_queue up, to build without
adding its prototype. Also renamed fc_fcp_reduce_can_queue to
fc_fcp_can_queue_ramp_down.
Removes fc_fcp_reduce_can_queue calling from fc_fcp_recv since
not needed with added fc_fcp_frame_alloc reducing can_queue.
Cleans up frame allocation APIs to have just single fc_frame_alloc API.
Removes _fc_frame_alloc, renames __fc_frame_alloc to _fc_frame_alloc.
Modifies fc_fcp_send_data for removed _fc_frame_alloc, fc_fcp_send_data
was the only user of removed _fc_frame_alloc.
Also Adds check in fc_frame_alloc to do mod by 4 for only non-zero
len value.
This patch is prep work to fix can_queue reducing in next patch.
Single fc_frame_alloc API helps in fixing can_queue reducing in
next patch.
Added kernel-doc comment blocks to all structures and functions.
Renamed fc_lport instances rom lp to lport to be inline with our
naming convention.
Renamed all misnamed net_device instances to netdev to be inline
with our naming convention.
Ensures that there are kernel-doc style comments for all
routines and structures.
There were also a few instances of fc_lport's named 'lp'
which were switched to 'lport' as per the libfc/libfcoe/fcoe
naming convention.
Also, emacs 'indent-region' and 'tabify' were ran on libfcoe.c.
This patch makes a variety of cleanup changes to all libfc files.
This patch adds kernel-doc headers to all functions lacking them
and attempts to better format existing headers. It also add kernel-doc
headers to structures.
This patch ensures that the current naming conventions for local ports,
remote ports and remote port private data is upheld in the following
manner.
struct instance (i.e. variable name)
fc_lport lport
fc_rport rport
fc_rport_libfc_priv rpriv
fc_rport_priv rdata
I also renamed dns_rp and ptp_rp to dns_rdata and ptp_rdata
respectively.
I used emacs 'indent-region' and 'tabify' on all libfc files
to correct spacing alignments.
I feel sorry for anyone attempting to review this patch.
This is the Open-FCoE implementation of the FC
passthrough support via bsg interface.
Passthrough support is added to both N_Ports and
VN_Ports.
Signed-off-by: Steve Ma <steve.ma@intel.com>
When handling the multi-frame responses of fc pass-thru requests,
a code segment similar to fc_fcp_recv_data (routine to receive
inbound SCSI data) is used in the response handler. This patch
is to add a routine, called fc_copy_buffer_to_sglist(), to handle
the common function of copying data from a buffer to a scatter-
gather list in order to avoid code duplication.
Allow a vport specific string to be appended to the port symbolic
name. The new symbolic name is sent to the name server after it
is set.
This currently messes with libhbalinux, which is looking for
the fcoe "fcoe <ver> over <ethX>" string and expects whatever
comes after the "over" to be a network interface name only.
Adds an EXPORT_SYMBOL to libfc for fc_frame_alloc_fill, which is
needed to allow fcoe to allocate a frame of variable length for
the RSPN request.
They all do the same thing, so combine them into a single function.
Register the fc_host symbolic name as the symbolic port name
with the fabric name server.
Register the fc_host symbolic name as the symbolic node name
One could interpret FC-GS-5 to say that an explicit RNN_ID is required
before RSNN_NN is allowed to succeed, which is why RNN_ID was not obsoleted
along with RPN_ID acording to this document:
ftp://ftp.t11.org/t11/member/fc/gs-5/05-546v2.pdf
RPN_ID has been obsolete per FC-GS-5 for several years. The port name is
registered implicitly as part of FLOGI, and it is undesirable for ports to
change a registered port name using RPN_ID while logged into the fabric.
