This patch contains an attempt to properly build hostap.o without
#include'ing C files.
WIRELESS_EXT < 18 will never be true in the kernel.
ESSIDs can technically include NULL characters. Drivers should not be
adjusting the length of the ESSID before reporting it in their
SIOCGIWESSID handlers. Breaks stuff like wpa_supplicant. Note that ipw
drivers, which seem to currently be the "most correct", don't have this
problem.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Host AP driver has code to support writing firmware to non-volatile
memory, a.k.a. flash. This code has been extensively tested when Host
AP was a standalone driver.
Add a configuration option to the kernel to allow enabling this
functionality. Improve the description of the RAM download option.
Mention cards that require it. Remove obsolete scary comment.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Drivers should not sleep for very long inside an ioctl -
so return EAGAIN and let wpa_supplicant handle the problem.
Signed-off-by: Olaf Kirch <okir@suse.de>
dev_kfree_skb should not be used with interrupts disabled. Change to
use dev_kfree_skb_irq instead.
Signed-off-by: Graham Gower <graham.gower@gmail.com>
The following makes drivers/char/watchdog/sa1100_wdt.c sparse clean.
Signed-off-by: Ian Campbell <icampbell@arcom.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Fix the following warning which was introduced in 2.6.15-git8 by
commit 7408187d223f63d46a13b6a35b8f96b032c2f623:
CC [M] drivers/media/video/zoran_card.o
drivers/media/video/zoran_card.c: In function `zr36057_init':
drivers/media/video/zoran_card.c:1053: warning: assignment makes integer from pointer without a cast
Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net>
This makes it possible to build kernels for PReP and/or CHRP
with ARCH=ppc by removing the (non-building) powermac support.
It's now also possible to select PReP and CHRP independently.
Powermac users should now build with ARCH=powerpc instead of
ARCH=ppc. (This does mean that it is no longer possible to
build a 32-bit kernel for a G5.)
Un-inline two functions in the pktcdvd driver. This makes the compiled code
172 bytes smaller on my system.
Signed-off-by: Peter Osterlund <petero2@telia.com>
No need for a file argument. If we'd really need it it's in vma->vm_file
already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but
the kernel alrady did that.
Signed-off-by: Antonino Daplas <adaplas@pol.net>
The ioctl and file arguments to ->fb_mmap are totally unused and there's not
reason a driver should need them.
Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap.
Seems that the CS5530A chip used in Geode GX1 systems has some crazy feature
that causes SMI traps when accessing the PCI configuration space of the video
device. Various GX1 BIOSes seem to use this 'feature' to hide the real BARs
of the device. This patch disables these traps (in an early PCI fixup) so
that Linux sees the real, physical BARs and not the virtual ones provided by
the BIOS.
This should allow the GX1 framebuffer driver to work on more systems that have
different BIOSes as the driver no longer guesses at what the virtual BARs
mean.
I'm not entirely sure it the correct solution as I can neither test regular
VGA console nor the X's 'cyrix' video driver so there might be some breakage
there -- probably best to get some more testers before applying it.
On a Dell Latitude CPi-A I noticed a strangeness wrt. the handling of an
external monitor by the neomagic framebuffer driver, namely when the laptop is
docked in a C/Dock II with the lid shut.
A cold boot would result in the BIOS configuring the video chip to use the
"external monitor only" mode, yet neofb would default to "internal LCD only".
An attempt for a quick fix by using the Fn-F8 keystroke to toggle the display
combination modes resulted in a reproductible hard lock, powering down being
the only solution.
The attached patch makes neofb probe the register for the current display
mode, using that value as a default if nothing was specified as kernel/module
parameter.
This patch adds support for the Intel IXDP2351 to the CS89x0 driver.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
cs89x0 inconsistently used 'int' and 'u32' for device register data.
As the cs89x0 is a 16-bit chip, change the I/O accessors over to 'u16'.
(Spotted by Deepak Saxena.)
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Credit Dmitry Pervushin for the PNX010X platform support.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=5854
Root cause:
The dell_rbu driver creates entries in /sys/class/firmware/dell_rbu/ by
calling request_firmware_nowait (without hotplug ) this function inturn
starts a kernel thread which creates the entries in
/sys/class/firmware/dell_rbu/loading , data and the thread waits on the
user action to return control back to the callback fucntion of dell_rbu.
The thread calls wait_on_completion which puts it in a D state until the
user action happens. If there is no user action happening the load average
goes up as the thread D state is taken in to account. Also after
downloading the BIOS image the enrties go away momentarily but they are
recreated from the callback function in dell_rbu. This causes the thread
to get recreated causing the load average to permenently stay around 1.
Fix:
The dell_rbu also creates the entry
/sys/devices/platform/dell_rbu/image_type at driver load time. The image
type by default is mono if required the user can echo packet to image_type
to make the BIOS update mechanism using packets. Also by echoing init in
to image_type the /sys/class/firmware/dell_rbu entries can be created.
The driver code was changed to not create /sys/class/firmware/dell_rbu
entries during load time, and also to not create the above entries from the
callback function. The entries are only created by echoing init to
/sys/devices/platform/dell_rbu/image_type The user now needs to create the
entries to download the image monolithic or packet. This fixes the issue
since the kernel thread only is created when ever the user is ready to
download the BIOS image; this minimizes the life span of the kernel thread
and the load average goes back to normal.
Signed off by Abhay Salunke <abhay_salunke@dell.com>
The QUEUE_ORDERED_* numbers got renumbered and by accident the dasd driver
was changed to use QUEUE_ORDERED_DRAIN instead of QUEUE_ORDERED_TAG.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
The chps[] array in struct channel_subsystem is one too short; therefore the
code doesn't realize the chpid ff is already known. When several devices on
chpid ff become available, the message "new_channel_path: could not register
ff" is displayed for every device but the first one.
Add the missing third argument to the blk_queue_ordered call and use the
constant QUEUE_ORDERED_DRAIN instead of "1".
Add support for the PowerPC MPC83xx watchdog. The MPC83xx has a simple
watchdog that once enabled it can not be stopped, has some simple timeout
range selection, and the ability to either reset the processor or take a
machine check.
Signed-off-by: Dave Updegraff <dave@cray.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
This is a 2.6 patch that adds support for the watchdog timer built into the
EPX-C3 single board computer manufactured by Winsystems, Inc.
Driver details:
This is for x86 only. This watchdog is pretty basic and simple. It is
only configurable via jumpers on the SBC, and it only has either a 1.5s or
200s interval. The watchdog can either be auto-configured to start as soon
as the machine powers up (bad idea for the 1.5s interval!) or it can be
enabled and disabled by writing to io port 0x1ee. Petting the watchdog
involves writing any value to io port 0x1ef.
The only unfortunate thing about this watchdog (and it is not at all
uncommmon in watchdogs that linux supports) is that it is not a PCI or
ISA-PNP device and as such it isn't at all probeable. Either the watchdog
exists as 2 bytes at 0x1ee, or it doesn't. Thus, using this driver on a
machine that doesn't have that watchdog can potentially hang/crash the
system, etc. So only use this driver if you in fact are on a Winsystems
EPX-C3 SBC.
Anyway this driver fits into the already-existing watchdog framework quite
nicely and I already tested it on my EPX-C3 and it works like a charm.
Signed-off-by: Calin A. Culianu <calin@ajvar.org>
Remove the "inline" keyword from a bunch of big functions in the kernel with
the goal of shrinking it by 30kb to 40kb
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Add driver support for a 2 port PCI IOC3-based serial card on Altix boxes:
This is a re-submission. On the original submission I was asked to
organize the code so that the MIPS ioc3 ethernet and serial parts could be
used with this driver. Stanislaw Skowronek was kind enough to provide the
shim layer for this - thanks Stanislaw. This patch includes the shim layer
and the Altix PCI ioc3 serial driver. The MIPS merged ioc3 ethernet and
serial support is forthcoming.
Signed-off-by: Patrick Gefre <pfg@sgi.com>
This patch removes pointless parentheses from return statements.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
Remove the last occurence of LOCAL_END_REQUEST.
Signed-off-by: Domen Puncer <domen@coderock.org>
shadow.cabi.net does no longer exist.
This patch removes some outdated information about the ftape driver like
pointers to no longer existing webpages from Kconfig files.
s/remvoed/removed/
Signed-off-by: Alex Shepard <ashepard@u.washington.edu>
tmp_buf_sem sems to be a common name for something completely unused...
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> ("usb portion")
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Given the semantic changes in both the device-model and
fc-transport APIs, the driver's handling of port-type RSCNs
via a series of ADISCs and PLOGIs can cause series of
badness ranging from unexpectedly device loss to devices not
being discovered.
In the interim, disable (via a module-parameter) this
feature and allow RSCN management to continue to occur
within the driver's DPC thread.
Similarly to other ISPs, set execution throttle to maximum
allowed value since 'throttling' is done on a per-lun basis
via queue-depth.
Simplify essentially duplicate load RISC RAM implementation
in qla2x00_load_ram_ext() and qla2x00_load_ram().
