path: root/drivers
2009-11-12mxc nand: simplify command processingSascha Hauer
Instead of having two switch/case with other operations in between, use only one switch/case Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-11-12mxc nand: use buffersSascha Hauer
The NAND controller has some limitations how to access the internal buffers. It only allows 32 bit accesses. The driver used to work around this by having special alignment aware copy routines. We now copy the whole page to a buffer in memory and let the access functions use this buffer. This simplifies the driver. A bonnie++ test showed that this has no negative performance impact on the driver. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-11-12mxc nand: use resource_size()Sascha Hauer
2009-11-12mxc nand: remove dead codeSascha Hauer
2009-11-12mxc nand: remove debug paramSascha Hauer
2009-11-12mxc_nand: introduce mxc_do_addr_cycleSascha Hauer
This factors the address cycle to a seperate function. This becomes useful in a later patch where we can simplify the command processing by making use of this function. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-11-12mxc_nand: merge send_read_page and send_prog_pageSascha Hauer
2009-11-12mxc_nand: cleanup initializationSascha Hauer
The oob layout was initialized several times. Instead, use a smallpage layout by default and switch to a largepage afterwards if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-11-12mxc_nand: cleanup eccoob descriptionsSascha Hauer
The original Freescale driver used to have eccoob descriptions like this: static struct nand_ecclayout nand_hw_eccoob_8 = { .eccbytes = 5, .eccpos = {6, 7, 8, 9, 10}, .oobfree = {{0, 5}, {11, 5}} }; static struct nand_ecclayout nand_hw_eccoob_16 = { .eccbytes = 5, .eccpos = {6, 7, 8, 9, 10}, .oobfree = {{0, 6}, {12, 4}} }; The former was used for 8bit flashes and the latter for 16bit flashes. They honored the fact that the bad block marker on 8bit flashes is on byte 5 while on 16bit flashes it is on byte 11. In the Kernel driver this was copied wrong and we ended up with two identical descriptions. Change it so that we have only one description which leaves byte 5 and byte 11 unspecified so that it won't be used by others. Also, rename the descriptions to nand_hw_eccoob_smallpage and nand_hw_eccoob_largepage so that it can't be confused with Nand chip bus widths (what actually happened in this driver) Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-10-21mtd: Fix compile failure and error path in physmap.cH Hartley Sweeten
Commit 4b56ffcacee937a85bf39e14872dd141e23ee85f ("mtd: Fix kernel NULL pointer dereference in physmap.c") introduced a couple of bugs. It neglected to run the loop of map_destroy() calls in physmap_flash_remove(), if !info->cmtd, which would happen if that function was called to clean up errors during probe. It also failed to compile if CONFIG_MTD_PARTITIONS was not defined. Reported-By: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-20Revert "mtd: mxc_nand: fix 2KiB pagesize NAND on i.MX27"David Woodhouse
This reverts commit 71b7d0d90d536ae4e70929cc59a1a9f6ba457c6c. The problem which that commit attempted to fix was a bootloader issue, which had been misunderstood. The 'fix' causes lots of false bad blocks for existing users with sane firmware. Thanks to Mathieu Berland for diagnosing the problem coherently. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-20mtd_blkdevs.c: quiet a "symbol shadows" sparse warninghartleys
In register_mtd_blktrans(), the symbol 'ret' is already declared as an int at the start of the function. The inner loop declaration is unnecessary. Quiets the following sparse warning: warning: symbol 'ret' shadows an earlier one Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-20mtd: add bcmring nand driverLeo (Hao) Chen
Signed-off-by: Leo Hao Chen <leochen@broadcom.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-20mtd: Fix kernel NULL pointer dereference in physmap.cH Hartley Sweeten
During the probe for physmap platform flash devices there are a number error exit conditions that all do a goto err_out which then calls physmap_flash_remove(). In that function one of the cleanup steps is: #ifdef CONFIG_MTD_CONCAT if (info->cmtd != info->mtd[0]) mtd_concat_destroy(info->cmtd); #endif This test will succeed since info->cmtd == NULL and info->mtd[0] is valid. Fix this by exiting the remove function when info->cmtd == NULL. Also, cleanup the #ifdef CONFIG_MTD_PARTITIONS stuff by using mtd_has_partitions(). Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-20mtd: plat_nand: request memory resource before doing ioremapH Hartley Sweeten
Add a request_mem_region() before doing the ioremap(). Also, use the resource_size macro instead of doing the end - start + 1 calc by hand. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-19pcmcia: convert pcmciamtd driver to use new CIS helpersDominik Brodowski
Convert the (broken) pcmciamtd driver to use the new CIS helpers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: maps: remove obsolete ipaq-flash driverDmitry Artamonow
This driver seems to be obsolete and broken for a long time. It depends on CONFIG_IPAQ_HANDHELD that simply doesn't exists anywhere in kernel. Also, it seems that none of machines it claims to support have any use of it: SA11xx-based iPAQs (h3100/h3600) use sa1100-flash iPAQ h5000 uses physmap-flash Jornada 720 uses sa1100-flash Jornada 560 and iPAQ h1910 are not in mainline Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: fix memory leak in mtd_dataflashH Hartley Sweeten
Fix a potential memory leak in mtd_dataflash driver. The private data that is allocated when registering a DataFlash device with the MTD subsystem is not released if an error occurs when add_mtd_partitions() or add_mtd_device() is called. Fix this by adding an error path. The memory is already released during a remove. Also, add a dev_set_drvdata(&spi->dev, NULL) before the kfree() so that the spi device does not reference invalid data. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: cleanup mtd_oobtestAkinobu Mita
- Remove unnecessary memset for bbt All entries will be initialized at a few lines below - Remove unnecessary initialization for mtd->erasesize - Use write_whole_device() Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: maps/sa1100: fix section mismatchDmitry Artamonow
Commit f0b1e589 changed sa1100_mtd_probe from __init to __devinit, but missed to correct sa1100_setup_mtd definition accordingly, which causes following warning: WARNING: vmlinux.o(.devinit.text+0xf4): Section mismatch in reference from the function sa1100_mtd_probe() to the function .init.text:sa1100_setup_mtd() The function __devinit sa1100_mtd_probe() references a function __init sa1100_setup_mtd(). If sa1100_setup_mtd is only used by sa1100_mtd_probe then annotate sa1100_setup_mtd with a matching annotation. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-17mtd: move mxcnd_remove to .exit.textUwe Kleine-König
The function mxcnd_remove is used only wrapped by __exit_p so define it using __exit. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sam Ravnborg <sam@ravnborg.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Vladimir Barinov <vova.barinov@gmail.com> Cc: Vladimir Barinov <vbarinov@embeddedalley.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-08mtd: atmel_nand: unused variable removedClaudio Scordino
Unused variable "eccpos" removed from atmel_nand driver. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-05mtd: make onenand_base.c compile againDavid Woodhouse
2009-10-05mtd: Standardising prints in onenand_base.cAmul Kumar Saha
This patch resolves all the prints present in onenand_base.c Primarily, it replaces the hard-coded function names in the prints, and makes use of __func__. Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-10-05mtd: nand: davinci: fix to use mask_ale from pdataHemant Pedanekar
Correct typo to use mask_ale from platform data when set to non-zero. Signed-off-by: Hemant Pedanekar <hemantp@ti.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-27mtd: Fix warning in sa1100-flash.cRussell King
drivers/mtd/maps/sa1100-flash.c: In function 'sa1100_probe_subdev': drivers/mtd/maps/sa1100-flash.c:214: warning: format '%d' expects type 'int', but argument 3 has type 'uint64_t' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24mtd: m25p80: disable SST software protection bits by defaultGraf Yang
The SST SPI flashes is like Atmel SPI flashes in that the software protection bits are set by default at power up, so clear them at init time. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24mtd/maps: gpio-addr-flash: depend on GPIO arch supportMike Frysinger
The driver requires gpio functionality, so make sure we depend on that in the Kconfig menu. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24mtd/maps: gpio-addr-flash: pull in linux/ headers rather than asm/Mike Frysinger
Now that there are linux/ versions of gpio.h and io.h, include those rather than hitting the asm/ versions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-24mtd: nand: fix htmldocs warningsJaswinder Singh Rajput
Fixed following htmldocs warnings: DOCPROC Documentation/DocBook/mtdnand.xml Warning(drivers/mtd/nand/nand_base.c:769): No description found for parameter 'page' Warning(drivers/mtd/nand/nand_base.c:785): No description found for parameter 'page' Warning(drivers/mtd/nand/nand_base.c:824): No description found for parameter 'page' Warning(drivers/mtd/nand/nand_base.c:947): No description found for parameter 'page' Warning(drivers/mtd/nand/nand_base.c:996): No description found for parameter 'page' Warning(drivers/mtd/nand/nand_base.c:1040): No description found for parameter 'page' Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-23Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: (23 commits) intel-iommu: Disable PMRs after we enable translation, not before intel-iommu: Kill DMAR_BROKEN_GFX_WA option. intel-iommu: Fix integer wrap on 32 bit kernels intel-iommu: Fix integer overflow in dma_pte_{clear_range,free_pagetable}() intel-iommu: Limit DOMAIN_MAX_PFN to fit in an 'unsigned long' intel-iommu: Fix kernel hang if interrupt remapping disabled in BIOS intel-iommu: Disallow interrupt remapping if not all ioapics covered intel-iommu: include linux/dmi.h to use dmi_ routines pci/dmar: correct off-by-one error in dmar_fault() intel-iommu: Cope with yet another BIOS screwup causing crashes intel-iommu: iommu init error path bug fixes intel-iommu: Mark functions with __init USB: Work around BIOS bugs by quiescing USB controllers earlier ia64: IOMMU passthrough mode shouldn't trigger swiotlb init intel-iommu: make domain_add_dev_info() call domain_context_mapping() intel-iommu: Unify hardware and software passthrough support intel-iommu: Cope with broken HP DC7900 BIOS iommu=pt is a valid early param intel-iommu: double kfree() intel-iommu: Kill pointless intel_unmap_single() function ... Fixed up trivial include lines conflict in drivers/pci/intel-iommu.c
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (41 commits) regulator: Add some brief design documentation regulator: fix voltage range in da9034 ldo12 regulator/driver: be more specific in nanodoc for is_enabled regulator/lp3971: drop unnecessary initialization regulator: drop 'default n' regulator: fix typos regulator: fix calculation of voltage range in da9034_set_ldo12_voltage() regulator: update a filename in documentation drivers/regulator/Kconfig: fix typo (s/Usersapce/Userspace/) in REGULATOR_USERSPACE_CONSUMER description REGULATOR Handle positive returncode from enable regulator: tps650xx - build fixes for x86_64 Fix some regulator documentation Regulator: Adding TPS65023 and TPS6507x in Kconfig and Makefile Regulator: Add TPS6507x regulator driver Regulator: Add TPS65023 regulator driver regulator: userspace: use sysfs_create_group regulator: Add GPIO enable control to fixed voltage regulator driver Regulator: Implement list_voltage for pcf50633 regulator driver. regulator: regulator_enable() permission checking regulator: Push locking for regulator_is_enabled() out ...
2009-09-23Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (22 commits) [S390] Update default configuration. [S390] hibernate: Do real CPU swap at resume time [S390] dasd: tolerate devices that have no feature codes [S390] zcrypt: Do not add/remove devices in s/r callbacks [S390] hibernate: make sure pfn_is_nosave handles lowcore pages [S390] smp: introduce LC_ORDER and simplify lowcore handling [S390] ptrace: use common code for simple peek/poke operations [S390] fix disabled_wait inline assembly clobber list [S390] Change kernel_page_present coding style. [S390] hibernation: reset system after resume [S390] hibernation: fix guest page hinting related crash [S390] Get rid of init_module/delete_module compat functions. [S390] Convert sys_execve to function with parameters. [S390] Convert sys_clone to function with parameters. [S390] qdio: change state of all primed input buffers [S390] qdio: reduce per device debug messages [S390] cio: introduce consistent subchannel scanning [S390] cio: idset use actual number of ssids [S390] cio: dont kfree vmalloced memory [S390] cio: introduce css_settle ...
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: sbp2: remove a workaround for Momobay FX-3A firewire: sbp2: remove a workaround for Momobay FX-3A firewire: sbp2: fix status reception firewire: core: fix topology map response handler firewire: core: fix race with parallel PCI device probe firewire: core: header file cleanup firewire: ohci: fix Self ID Count register mask (safeguard against buffer overflow) ieee1394: raw1394: Do not leak memory on failed trylock.
2009-09-23Merge branch 'sfi-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 * 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6: SFI: remove unneeded includes sfi: Remove unused code SFI: Hook PCI MMCONFIG x86: add arch-specific SFI support SFI: add capability to parse ACPI tables SFI: add platform-independent core support SFI: create linux/sfi.h SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-23Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Clearly mark ACPI drivers as such i2c: Add driver for SMBus Control Method Interface i2c-pnx: Correct use of request_region/request_mem_region MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665 i2c-piix4: Add AMD SB900 SMBus device ID i2c/chips: Remove deprecated pcf8574 driver i2c/chips: Remove deprecated pca9539 driver i2c/chips: Remove deprecated pcf8575 driver gpio/pcf857x: Copy i2c_device_id from old pcf8574 driver i2c/scx200_acb: Provide more information on bus errors i2c: Provide compatibility links for i2c adapters i2c: Convert i2c adapters to bus devices i2c: Convert i2c clients to a device type i2c/tsl2550: Use combined SMBus transactions i2c-taos-evm: Switch echo off to improve performance i2c: Drop unused i2c_driver.id field
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (142 commits) USB: Fix sysfs paths in documentation USB: skeleton: fix coding style issues. USB: O_NONBLOCK in read path of skeleton USB: make usb-skeleton honor O_NONBLOCK in write path USB: skel_read really sucks royally USB: Add hub descriptor update hook for xHCI USB: xhci: Support USB hubs. USB: xhci: Set multi-TT field for LS/FS devices under hubs. USB: xhci: Set route string for all devices. USB: xhci: Fix command wait list handling. USB: xhci: Change how xHCI commands are handled. USB: xhci: Refactor input device context setup. USB: xhci: Endpoint representation refactoring. USB: gadget: ether needs to select CRC32 USB: fix USBTMC get_capabilities success handling USB: fix missing error check in probing USB: usbfs: add USBDEVFS_URB_BULK_CONTINUATION flag USB: support for autosuspend in sierra while online USB: ehci-dbgp,ehci: Allow dbpg to work with suspend/resume USB: ehci-dbgp,documentation: Documentation updates for ehci-dbgp ...
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: don't force VIRTIO_F_NOTIFY_ON_EMPTY lguest: cleanup for map_switcher() lguest: use PGDIR_SHIFT for PAE code to allow different PAGE_OFFSET lguest: use set_pte/set_pmd uniformly for real page table entries lguest: move panic notifier registration to its expected place. virtio_blk: add support for cache flush virtio: add virtio IDs file virtio: get rid of redundant VIRTIO_ID_9P definition virtio: make add_buf return capacity remaining virtio_pci: minor MSI-X cleanups
2009-09-23sisfb: change SiS_DDC_Port type to SISIOADDRESSAaro Koskinen
The patch enables the driver to be used on platforms such as ARM where an I/O address is a 32-bit memory address. The patch avoids the following kernel oops: debian:~# modprobe sisfb [ 73.070000] sisfb: Video ROM found [ 73.080000] sisfb: Video RAM at 0x80000000, mapped to 0xe0a00000, size 1024k [ 73.090000] sisfb: MMIO at 0x84080000, mapped to 0xe0b80000, size 256k [ 73.090000] sisfb: Memory heap starting at 800K, size 32K [ 73.360000] Unable to handle kernel paging request at virtual address 6e000844 [ 73.380000] pgd = df230000 [ 73.380000] [6e000844] *pgd=00000000 [ 73.380000] Internal error: Oops: 8f5 [#1] [ 73.380000] Modules linked in: sisfb(+) fb cfbcopyarea cfbimgblt cfbfillrect [ 73.380000] CPU: 0 Not tainted (2.6.31-iop32x #1) [ 73.380000] PC is at SiS_SetRegANDOR+0x10/0x38 [sisfb] [ 73.380000] LR is at SiS_SetSCLKHigh+0x38/0x94 [sisfb] [ 73.380000] pc : [<bf01dc00>] lr : [<bf0238f8>] psr: 60000013 [ 73.380000] sp : df38fd00 ip : 6e000000 fp : 00000002 [ 73.380000] r10: 00000108 r9 : 00000000 r8 : 00000108 [ 73.380000] r7 : df064258 r6 : 00000110 r5 : 6e000844 r4 : 0000010a [ 73.380000] r3 : 00000001 r2 : 0000000e r1 : 00000011 r0 : 00000844 [ 73.380000] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 73.380000] Control: 0000397f Table: bf230000 DAC: 00000015 [ 73.380000] Process modprobe (pid: 1849, stack limit = 0xdf38e270) [ 73.380000] Stack: (0xdf38fd00 to 0xdf390000) [ 73.380000] fd00: 0000010a 00000108 df064258 df064258 df064258 00000000 00000000 bf02c4e0 [ 73.380000] fd20: 00000114 bf02c50c 00000013 00000114 0000010a df064258 00000000 bf02c980 [ 73.380000] fd40: 00009c66 00000004 00000001 df064250 a0010000 a6a2a0a0 df064250 00000003 [ 73.380000] fd60: df064250 00000000 df064258 0000fffd 00000000 00000000 00000000 bf033948 [ 73.380000] fd80: 00000000 00000000 00000000 bf019e2c 00000000 df064a70 bf03b470 00010000 [ 73.380000] fda0: 00000000 df064250 00000000 df831c00 00000012 bf039f70 00000000 c00abed8 [ 73.380000] fdc0: 000008a6 000008a4 df0649b0 df064878 df064258 df064000 00000000 00000000 [ 73.380000] fde0: 00000001 00008000 00000001 00030000 df81c930 bf049f88 df831c00 00000000 [ 73.380000] fe00: bf049f58 df3952a0 c0447708 bf049f88 bf049fe0 c0191980 df831c00 c0191b10 [ 73.380000] fe20: df831c58 bf049f58 df831c00 bf04aca8 df3952a0 df831c58 df831c58 bf049f88 [ 73.380000] fe40: c01ba1b4 c01ba0a0 df831c58 df831c8c bf049f88 c01ba1b4 df3952a0 00000000 [ 73.380000] fe60: c03e265c c01ba240 00000000 df38fe78 bf049f88 c01b990c df812938 df81b8d0 [ 73.380000] fe80: df3952a0 df807780 00000000 00000060 bf049f88 c01b9224 bf0429c8 00000000 [ 73.380000] fea0: bf049f58 00000000 bf049f88 00000000 00000000 bf04aea8 00000000 c01ba4e4 [ 73.380000] fec0: e09861a0 bf049f58 00000000 bf049f88 00000000 c0191f20 00000000 00000000 [ 73.380000] fee0: c03f7bac bf04d418 0000fff2 0000fff1 bf04ad08 0002f260 0002f260 e0986038 [ 73.380000] ff00: e0986150 e098568b df143340 e0990280 00000036 c03d8b00 fffffffd 00000000 [ 73.380000] ff20: bf04acfc 00000000 fffffffc 0003cf4b 00018098 c03f7bac 00000000 bf04d000 [ 73.380000] ff40: df38e000 00000000 bedc0984 c00272a4 ffffffff c005bc88 00000000 00000000 [ 73.380000] ff60: 0003cf4b 0003cf4b 00018098 bf04acfc 00000000 c0027fe8 df38e000 00000000 [ 73.380000] ff80: bedc0984 c006882c 00001000 00000003 00000000 00009064 00000000 00008edc [ 73.380000] ffa0: 00000080 c0027e20 00009064 00000000 4014e000 0003cf4b 00018098 0003cf4b [ 73.380000] ffc0: 00009064 00000000 00008edc 00000080 00000000 00000000 40025000 bedc0984 [ 73.380000] ffe0: 00000000 bedc08fc 0000b6b0 400e8f34 60000010 4014e000 00000000 00000000 [ 73.380000] [<bf01dc00>] (SiS_SetRegANDOR+0x10/0x38 [sisfb]) from [<df064258>] (0xdf064258) [ 73.380000] Code: e92d0030 e20110ff e280546e e3a0c46e (e5c51000) [ 73.680000] ---[ end trace 62a93e01df37a5f2 ]--- Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23video: s3c_fb.c: fix build with CONFIG_HOTPLUG=nPeter Korsgaard
Fixes `s3c_fb_remove' referenced in section `.data' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o With CONFIG_HOTPLUG=n, functions marked with __devexit gets removed, so make sure we use __devexit_p when referencing pointers to them. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Ben Dooks <ben-linux@fluff.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23drivers/video/tmiofb.c: fix uninitialised return valueAndrew Morton
drivers/video/tmiofb.c: In function 'tmiofb_resume': drivers/video/tmiofb.c:977: warning: 'retval' may be used uninitialized in this function Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23vgacon: prevent vgacon_deinit from touching the hardware for inactive consoles.Francisco Jerez
fbcon makes the (reasonable) assumption that it only needs to program the hardware once, when fbcon_init() is called for the foreground console. This doesn't always play well with vgacon because vgacon_deinit() is only doing its job when the last console it owns is closed (when switching from vgacon to fbcon, that's usually *after* fbcon_init() has set the new mode). Depending on the hardware this can cause the wrong framebuffer location to be scanned out (e.g. reproduced on nv05 with the nouveau framebuffer driver). Signed-off-by: Francisco Jerez <currojerez@riseup.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23fbcon: only unbind from console if successfully registeredIan Armstrong
Attempting to unload a framebuffer module calls unregister_framebuffer() which in turn gets fbcon to release it. If fbcon has no framebuffers linked to a console, it will also unbind itself from the console driver. However, if fbcon never registered itself as a console driver, the unbind will fail causing the framebuffer device entry to persist. In most cases this failure will result in an oops when attempting to access the now non-existent device. This patch ensures that the fbcon unbind request will succeed even if a bind was never done. It tracks if a successful bind ever occurred & will only attempt to unbind if needed. If there never was a bind, it simply returns with no error. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of CONFIG_FB_MATROX_32MBJean Delvare
CONFIG_FB_MATROX_32MB is always enabled, so there is no point in having ifdefs all around. And it is bad practice to use CONFIG_* as a name for something which is not a Kconfig option. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macro MINFO_FROMJean Delvare
With multihead support always enabled, macros MINFO_FROM and MINFO_FROM_INFO are no longer needed and make the code harder to read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macros WPMINFO and friendsJean Delvare
With multihead support always enabled, these macros are no longer needed and make the code harder to read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macros ACCESS_FBINFO and MINFOJean Delvare
2009-09-23matroxfb: make CONFIG_FB_MATROX_MULTIHEAD=y mandatoryJean Delvare
I would like to get rid of option CONFIG_FB_MATROX_MULTIHEAD and just always enable it. There are many reasons for doing this: * CONFIG_FB_MATROX_MULTIHEAD=y is what all x86 distributions do, so it definitely works or we would know by now. * Building the matroxfb driver with CONFIG_FB_MATROX_MULTIHEAD not set results in the following build warning: drivers/video/matrox/matroxfb_crtc2.c: In function 'matroxfb_dh_open': drivers/video/matrox/matroxfb_crtc2.c:265: warning: the address of 'matroxfb_global_mxinfo' will always evaluate as 'true' drivers/video/matrox/matroxfb_crtc2.c: In function 'matroxfb_dh_release': drivers/video/matrox/matroxfb_crtc2.c:285: warning: the address of 'matroxfb_global_mxinfo' will always evaluate as 'true' This is nothing to be worried about, the driver will work fine, but build warnings are still annoying. * The trick to get multihead support without CONFIG_FB_MATROX_MULTIHEAD, which is described in the config help text, no longer works: you can't load the same kernel module more than once. * I fail to see how CONFIG_FB_MATROX_MULTIHEAD=y would make the code significantly slower, contrary to what the help text says. A few extra parameters on the stack here and there can't really slow things down in comaprison to the rest of the code, and register access. * The driver built without CONFIG_FB_MATROX_MULTIHEAD is larger than the driver build with CONFIG_FB_MATROX_MULTIHEAD=y by 8%. * One less configuration option makes things simpler. We add options all the time, being able to remove one for once is nice. It improves testing coverage. And I don't think the Matrox adapters are still popular enough to warrant overdetailed configuration settings. * We should be able to unobfuscate the driver code quite a bit after this change (patches follow.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
