path: root/drivers
2010-01-07stmmac: do not call fix_mac_speed if NULLGiuseppe CAVALLARO
On some platforms, fix_mac_speed is used for configuring some sysconf registers according to the working speed. This patch fixes the fix_mac_speed invocation that cannot be done if it is a NULL pointer. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07stmmac: perform hw bus configurationGiuseppe CAVALLARO
On some platforms it can be required a different configuration of the bus. This can be done by invoking the bus_setup. It is defined for all the platforms that needs this kind of configuration. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07stmmac: rewiew platform dataGiuseppe CAVALLARO
This patch rewiews and reorganises all the data come from the platform removing any dependency from the stm code. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07stmmac: convert unicast addr list to list_headGiuseppe CAVALLARO
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. Note: this patch also removes a debug printk used for displaying the mac addresses. Indeed, it's is possible to dump the registers with ethtool. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07stmmac: use MII_BUS_ID_SIZE instead of BUS_ID_SIZEGiuseppe CAVALLARO
2010-01-07drivers/net/skfp/skfddi.c: use %pMF to show MAC addresshartleys
Use the %pMF kernel extension to display the MAC address. The address will still be displayed in the FDDI Canonical format. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/defxx.c: use %pMF to show MAC addresshartleys
Use the %pMF kernel extension to display the MAC address. The address will still be displayed in the FDDI Canonical format. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/message/i2o/i2o_proc.c: use %pM to show MAC addressH Hartley Sweeten
Use the %pM kernel extension to display the MAC address. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/infiniband/hw/cxgb3/iwch_cm.c: use %pM to show MAC addressH Hartley Sweeten
Use the %pM kernel extension to display the MAC address. The only difference in the output is that the MAC address is shown in the usual colon-separated hex notation. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/wimax/i2400m/driver.c: use %pM to show MAC addresshartleys
Use the %pM kernel extension to display the MAC address. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/qlge/qlge_main.c: use %pM to show MAC addresshartleys
2010-01-07drivers/net/atl1e/atl1e_main.c: use %pM to show MAC addresshartleys
Use the %pM kernel extension to display the MAC address. The only difference in the output is that the MAC address is shown in the usual colon-separated hex notation. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/wimax/i2400m/fw.c: use %pM to show MAC addresshartleys
2010-01-07drivers/net/atl1c/atl1c_main.c: use %pM to show MAC addresshartleys
2010-01-07drivers/net/vxge/vxge-main.c: use %pM to show MAC addresshartleys
2010-01-07drivers/media/dvb/dvb-core/dvb_net.c: use %pM to show MAC addresshartleys
Use the %pM kernel extension to display the MAC address and mask. The only difference in the output is that the output is shown in the usual colon-separated hex notation. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/atm/lanai.c: use %pM to show MAC addresshartleys
2010-01-07drivers/atm/fore200e.c: use %pM to show MAC addresshartleys
2010-01-07drivers/firmware/iscsi_ibft.c: use %pM to show MAC addresshartleys
Use the %pM kernel extension to display the MAC address. Also, remove the 'mac' variable and use nic->mac directly. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/atm/idt77252.c: use %pM to show MAC addresshartleys
2010-01-07drivers/net/ixgbe/ixgbe_common.c: use %pM to show MAC addresshartleys
2010-01-07drivers/atm/nicstar.c: use %pM to show MAC addresshartleys
2010-01-078139too: make PCI device ids constantMárton Németh
The id_table field of the struct pci_driver is constant in <linux/pci.h> so it is worth to make pci_device_id also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Márton Németh <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06drivers/net/mac8390.c: Add mac8390_init functionJoe Perches
Reduce indentation, make code a little neater. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06drivers/net/mac8390.c: Checkpatch cleanupsJoe Perches
Use #include <linux/ not #include <asm/ Add spaces after arguments Comment neatening Make a couple of arrays static const Align function arguments Wrap text at 80 columns where reasonable Cuddle brace else Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06drivers/net/mac8390.c: Convert printk(KERN_<level> to pr_<level>(Joe Perches
Use printk_once Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Convert printks without KERN_<level> to pr_info and pr_cont Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06drivers/net/mac8390.c: Remove useless memcpy castingJoe Perches
2010-01-06drivers/net/mac8390.c: Indent case labelsJoe Perches
2010-01-06phy: SMSC device Energy Detect power-down modeGiuseppe Cavallaro
SMSC Ethernet Transceivers (LAN88710, LAN8710, LAN8720, LAN8187, LAN8700, LAN83C185) provide a mechanism to conserve power when the device is not connected to an active link partner (Energy Detect Mode). So this patch enables the Energy Detect power-down mode for these Transceivers. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06qlge: Add napi gro frags interface.Ron Mercer
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06qlge: Add RX frame handlers for non-split frames.Ron Mercer
New handlers are added here to handle: 1) Small frames (<256 bytes) in a single small buffer. Allocate a new skb and copy the frame. 2) Large frame (>256 bytes) in a page chunk. Allocate an skb, tack it on frags, post to napi_gro_receive(). Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06qlge: Turn on RX header split based on platform.Ron Mercer
Using 4-byte aligned headers is problematic for some architectures. Since qlge uses 4-byte aligned rx buffers we split headers for these architectures into a separate buffer and then recopy to align on 2-byte boundary. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06sky2: Lock transmit queue while disabling deviceMike McCormack
netif_device_detach() does not take the tx_lock, so it's possible that a call to sky2_xmit_frame is still in progress after netif_device_detach() is complete. Take netif_tx_lock() to make sure all transmits have stopped while we're disabling the devices and that no other CPU is still transmitting a frame after we've disabling the device. Proposed fix for "sky2 panic under load" reported by Berck E. Nash. Signed-off-by: Mike McCormack <mikem@ring3k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06sky2: Refactor sky2_get_regs into two functionsMike McCormack
Separate code deciding which registers can be accessed out of sky2_get_regs in preparation for adding more conditions into it. Signed-off-by: Mike McCormack <mikem@ring3k.org> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03axnet_cs: remove unnecessary spin_unlock_irqrestoreKen Kawasaki
axnet_cs: remove unnecessary spin_unlock_irqrestore,spin_lock_irqsave. Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03drivers/net/cxgb3: Use kzalloc for allocating only one thingJulia Lawall
Use kzalloc rather than kcalloc(1,...) The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ @@ - kcalloc(1, + kzalloc( ...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03bonding: allow arp_ip_targets on separate vlans to use arp validationAndy Gospodarek
This allows a bond device to specify an arp_ip_target as a host that is not on the same vlan as the base bond device and still use arp validation. A configuration like this, now works: BONDING_OPTS="mode=active-backup arp_interval=1000 arp_ip_target=10.0.100.1 arp_validate=3" 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000 link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff 3: eth0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master bond0 qlen 1000 link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff 8: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff inet6 fe80::213:21ff:febe:33e9/64 scope link valid_lft forever preferred_lft forever 9: bond0.100@bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue link/ether 00:13:21:be:33:e9 brd ff:ff:ff:ff:ff:ff inet 10.0.100.2/24 brd 10.0.100.255 scope global bond0.100 inet6 fe80::213:21ff:febe:33e9/64 scope link valid_lft forever preferred_lft forever Ethernet Channel Bonding Driver: v3.6.0 (September 26, 2009) Bonding Mode: fault-tolerance (active-backup) Primary Slave: None Currently Active Slave: eth1 MII Status: up MII Polling Interval (ms): 0 Up Delay (ms): 0 Down Delay (ms): 0 ARP Polling Interval (ms): 1000 ARP IP target/s (n.n.n.n form): 10.0.100.1 Slave Interface: eth1 MII Status: up Link Failure Count: 1 Permanent HW addr: 00:40:05:30:ff:30 Slave Interface: eth0 MII Status: up Link Failure Count: 0 Permanent HW addr: 00:13:21:be:33:e9 Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-30Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6John W. Linville
Conflicts: drivers/net/wireless/libertas/scan.c
2009-12-29Subject: drivers/net/sh_eth.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/r8169.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/octeon/octeon_mgmt.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/smc911x.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/sunvnet.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/usb/catc.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/s390/net/qeth_l2_main.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/xilinx_emaclite.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/via-velocity.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/usb/rtl8150.c: use %pM to shown MAC addressH Hartley Sweeten
2009-12-29drivers/net/igbvf/netdev.c: use %pM to shown MAC addressH Hartley Sweeten
