path: root/drivers
2009-10-29[SCSI] mpt2sas: Freeze the sdev IO queue when firmware sends internal dev resetKashyap, Desai
When receiving the MPI2_EVENT_SAS_DEV_STAT_RC_INTERNAL_DEVICE_RESET event, the driver will set the tm_busy flag in the sdev private host data, When tm_busy flag is set, the driver will return SCSI_MLQUEUE_DEVICE_BUSY, effectly freezing the IO to the device. The tm_busy flag is cleared with the MPI2_EVENT_SAS_DEV_STAT_RC_CMP_INTERNAL_DEV_RESET event. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas : PPC (power pc) endian bug fix'sKashyap, Desai
(1) EEDP(End to End data protection) was not working. This was due to not setting EEDP BlockSize and Flags to little endian format in the message frame. (2) Some expander sysfs attributes were not getting set properly. The sas format was not getting set due to endian issues with sas_format field in the struct rep_manu_reply. Since sas_format was not set properly, the component_vendor_id, component_revision_id, and component_id were not set. (3) In _transport_smp_handler: we don't need to convert the smid from little endian to cpu prior to calling mpt2sas_base_free_smid, because its allready in cpu format. (4) Some loginfos and ioc status were not xonverted from little endian to cpu. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: mpt2sas_base_get_sense_buffer_dma should be returning little ↵Kashyap, Desai
endian cpu_to_le64 when calculating the physical dma address. This will properly handle endianess on big endian systems. The return value of this function was changed from dma_addr_t to __le64. Remove the typecasting of u32 when setting the SenseBufferLowAddress, since its already in __le32 format. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Return DID_TRANSPORT_DISRUPTED in nexus ↵Kashyap, Desai
loss,SCSI_MLQUEUE_DEVICE_BUSY if device is busy 1 Its observed that the OS was sending request to the driver after it had been put into blocking state, so the driver was modified to return SCSI_MLQUEUE_DEVICE_BUSY. 2. Driver will return DID_TRANSPORT_DISRUPTED when sdev is haivng nexus loss. This occurrs when sdev is blocked, between the MPI2_EVENT_SAS_TOPO_RC_DELAY_NOT_RESPONDING and MPI2_EVENT_SAS_TOPO_RC_TARG_NOT_RESPONDING events. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Retrieve the ioc facts prior to putting the controller into ↵Kashyap, Desai
READY state The driver needs to retrieve the ioc facts prior to putting the controller into READY state. The current design is calling ioc facts after putting the controller into READY state, which means the driver is sending a diag reset instead of message unit reset becuase the capability information is not yet available. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Added new info messages for IR and Expander events.Kashyap, Desai
(1) for the MPI2_EVENT_IR_OPERATION_STATUS event, add support to print "background init" or "make data consistent" for debugging purposes. If the RAIDOperation is set to a value not defined, then don't print anything (2) for the MPI2_EVENT_SAS_DEVICE_STATUS_CHANGE event, add support to print "expander reduced functionality" and "expander reduced functionality complete", which are new events. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Limit the max_depth to 32 for SATA devices which are not ↵Kashyap, Desai
part of volume Added sanity check in _scsih_change_queue_depth to limit the max_depth to 32 for SATA devices. This is only for physical devices not part of a volume. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Added support to set the TimeStamp when sending ioc_initKashyap, Desai
Added support to set the TimeStamp when sending ioc_init. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Add Extended Type for Diagnostic Buffer supportKashyap, Desai
Added tests for registry entries of EXBuffSize, EXImmed, and EXType to support the new Extended diag buffer type. Modified code where necessary to handle the new ExtendedType field in the F/W diagnostic Post and Release messages. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Added command line option diag_buffer_enable.Kashyap, Desai
Added command line option diag_buffer_enable. When the command line option is set, the driver will automatically post diag buffers at driver load time. The command line option diag_buffer_enable is bitwise, so it's possible to enable both and/or snapshot + trace buffers. For trace, the driver will allocate 1MB buffer, whereas for snapshot its 2MB. The purpose for this is so the enduser doesn't have to manually use an application to setup diag buffers for debugging firmware related issues. Here is some examples trace: # insmod mpt2sas.ko diag_buffer_enable=1 snapshot: # insmod mpt2sas.ko diag_buffer_enable=2 both trace and snapshot: # insmod mpt2sas.ko diag_buffer_enable=3 Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Fixed some of the commentKashyap, Desai
Fixed some of the comments sections for some of the function so "@ioc: pointer to scsi command object" was changed to "@ioc: per adapter object" Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Support for stopping driver when Firmware encountersKashyap, Desai
Added command line option and shost sysfs attribute called mpt2sas_fwfault_debug. When enduser writes a "1" to this parameter, this will enable support in the driver for debugging firmware timeout related issues. This handling was added in three areas (a) scsi error handling callback called task_abort, (b) IOCTL interface, and (c) other timeouts that result in diag resets, such as manufacturing config pages. When this support is enabled, the driver will provide dump_stack to console, halt controller firmware, and panic driver. The end user probably would want to setup serial console redirection so the dump stack can be seen. Here are the three methods for enable this support: (a) # insmod mpt2sas.ko mpt2sas_fwfault_debug=1 (b) # echo 1 > /sys/module/mpt2sas/parameters/mpt2sas_fwfault_debug (c) # echo 1 > /sys/class/scsi_host/host#/fwfault_debug (where # is the host number) Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Adding MPI Headers - revision LKashyap, Desai
The new headers contain the following changes: (1) Added IO Unit Page 7. (2) Added new device ids for SAS2208. (3) Added SAS IO Unit Page 5. (4) Added partial and slumber power management capable flags to SAS Device Page 0 Flags field. (5) Added PhyInfo defines for power condition. (6) Added Ethernet configuration pages. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: New device SAS2208 support is addedKashyap, Desai
Added device ids range for { 0x80 - 87 } , modified mpi/mpi2_cnfg.h containing MPI2_MFGPAGE_DEVID_SAS2208_X. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Add support in the driver to check for valid response infoKashyap, Desai
Add support in the driver to check for valid response info in the scsi state, then check to see if the response code is MPI2_SCSITASKMGMT_RSP_INVALID_FRAME; when this condition occurrs, the driver will return DID_SOFT_ERROR. A return code of DID_SOFT_ERROR will result in a retry at the scsi-mid layer level. An additional change added to obtain the response code from the 1st byte of the response info instead of last. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Expander remove fails when it is processing another expander ↵Kashyap, Desai
add. This handles the case where driver receives a expander removal event while it is in the middle of processing an expander add event. The existing implementation will stop processing futher device adds when a expander delete arrives on top of add expander add. Due to a sanity check in the driver, the devices there were not added, were never handshaked to firmware with the device removal handshake protocal. Since the driver didnt' do the handshake, the controller never provide further add events. To fix this issue, the sanity check was removed so the driver will always do the device removal handshake protocal. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29[SCSI] mpt2sas: Driver will use sas address instead of handle as a lookupKashyap, Desai
The device driver was not handling updating device handles in all cases across diag resets. To fix this issue, the driver is converted to using sas address instead of handle as a lookup reference to the parent expander or sas_host. Also, for both expanders and sas host, the phy handle will be one unique handle. In the sas host case, the phy handle can be different for every phy, so the change is to set the handle to the handle of the first phy; every phy will be one single sas address(phy 0) instead of a different sas address for every phy(previous implementation). So making one consistent sas address for all the direct attachedports to the sas host, will make it better user experience when using udev /dev/disk/by-path dev nodes Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Eric Moore <Eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6: ide: Serialize CMD643 and CMD646 to fix a hardware bug with SSD
2009-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits) net: Fix 'Re: PACKET_TX_RING: packet size is too long' netdev: usb: dm9601.c can drive a device not supported yet, add support for it qlge: Fix firmware mailbox command timeout. qlge: Fix EEH handling. AF_RAW: Augment raw_send_hdrinc to expand skb to fit iphdr->ihl (v2) bonding: fix a race condition in calls to slave MII ioctls virtio-net: fix data corruption with OOM sfc: Set ip_summed correctly for page buffers passed to GRO cnic: Fix L2CTX_STATUSB_NUM offset in context memory. MAINTAINERS: rt2x00 list is moderated airo: Reorder tests, check bounds before element mac80211: fix for incorrect sequence number on hostapd injected frames libertas spi: fix sparse errors mac80211: trivial: fix spelling in mesh_hwmp cfg80211: sme: deauthenticate on assoc failure mac80211: keep auth state when assoc fails mac80211: fix ibss joining b43: add 'struct b43_wl' missing declaration b43: Fix Bugzilla #14181 and the bug from the previous 'fix' rt2x00: Fix crypto in TX frame for rt2800usb ...
2009-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: order used ring after used index read virtio-pci: fix per-vq MSI-X request logic
2009-10-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: Revert "PCI: get larger bridge ranges when space is available"
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: mlx4_core: Add a new supported 40 GigE device ID
2009-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] zfcp: Flush SCSI registration work when adding unit [SCSI] zfcp: Fix timer initialization for ct and els requests [SCSI] zfcp: Warn about storage devices with broken PLOGI data [SCSI] zfcp: Handle WWPN mismatch in PLOGI payload [SCSI] zfcp: fix kfree handling in zfcp_init_device_setup [SCSI] fix memory leak in initialization
2009-10-29Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/kms: fix kms/fbdev colormap support properly. drm: Add the basic check for the detailed timing in EDID drm/radeon/kms: ignore vga arbiter return.
2009-10-29ray_cs: Fix copy_from_user handlingAlan Cox
I've not touched the other stuff here but the word "locking" comes to mind. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29dpt_i2o: Fix up copy*userAlan Cox
2009-10-29Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ppc64: Use preempt_schedule_irq instead of preempt_schedule powerpc: Minor cleanup to lib/Kconfig.debug powerpc: Minor cleanup to sound/ppc/Kconfig powerpc: Minor cleanup to init/Kconfig powerpc: Limit memory hotplug support to PPC64 Book-3S machines powerpc: Limit hugetlbfs support to PPC64 Book-3S machines powerpc: Fix compile errors found by new ppc64e_defconfig powerpc: Add a Book-3E 64-bit defconfig powerpc/booke: Fix xmon single step on PowerPC Book-E powerpc: Align vDSO base address powerpc: Fix segment mapping in vdso32 powerpc/iseries: Remove compiler version dependent hack powerpc/perf_events: Fix priority of MSR HV vs PR bits powerpc/5200: Update defconfigs drivers/serial/mpc52xx_uart.c: Use UPIO_MEM rather than SERIAL_IO_MEM powerpc/boot/dts: drop obsolete 'fsl5200-clocking' of: Remove nested function mpc5200: support for the MAN mpc5200 based board mucmc52 mpc5200: support for the MAN mpc5200 based board uc101
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: Do not dereference null pointer in twl4030 error path mfd: Always initialise WM831x IRQ mutex
2009-10-29Merge branch 'for-linus' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubi-2.6: UBI: fix check on unsigned long UBI: fix backward compatibility
2009-10-29Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (it87) Fix VID reading on IT8718F/IT8720F hwmon: (dme1737) No vid attributes for SCH311x hwmon: (fschmd) Fix check on unsigned in watchdog_write() hwmon: (coretemp) Maintainer update
2009-10-29Merge branch 'urgent-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6 * 'urgent-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: do not load the pd6729 driver if io_base is NULL pcmcia: Fix possible printk format warnings pcmcia: do not try to store more than 4 version strings pcmcia: pccard_read_tuple and TUPLE_RETURN_COMMON cleanup pcmcia: properly close previous dev_printk if kzalloc fails in do_io_probe pcmcia: fix controller printk format warnings
2009-10-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits) ARM: Fix lubbock defconfig build ARM: 5769/1: CPU_ARM920T: remove dead Maverick EP9312 URL ARM: 5768/1: ep93xx: remove dead code in ep93xx_gpio_ab_irq_handler() ARM: 5767/1: ep93xx: remove ep93xx_init_time() prototype ARM: 5765/1: Updated U300 defconfig ARM: 5766/1: Fix watchdog enabling for AT91SAM9G45 ARM: 5764/1: bcmring: add oprofile pmu support [ARM] pxa/spitz: add gpio button support (fixes regression) [ARM] pxa/cm-x300: fix mmc numbering ARM: 5763/1: ARM: SMP: Fix the BUG with CONFIG_PREEMPT enabled ARM: 5760/1: ep93xx: fix build error in edb93xx.c ARM: 5759/1: Add register information of threads to coredump ARM: 5757/1: Thumb-2: Correct "mov.w pc, lr" instruction which is unpredictable MXC: fix reset for mx31, mx35 and mx27 SoCs fix pcm037_eet compilation with the new SPI driver fix compilation of i.MX31 platforms pcm970 mmc: Fix ro switch pcm038: Add SPI/MC13783 support mx25: Add missing copyright / license header mx25pdk: remove nand support as it is not present in current tree ...
2009-10-29lis3: add support for the HP HDX 18Ian E. Morgan
I have an HP HDX 18 laptop, and noted that the configuration of the accelerometer needs to be x_inverted. Signed-off-by: Ian E. Morgan <penguin.wrangler@gmail.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29lis3: add support for the HP EliteBook 8530wÉric Piel
Correct orientation for HP EliteBook 8530w. Reported-by: Jörgen Jonssson <jorgen.jonsson@saitek.se> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29lis3: better support for hp 6730xPavel Herrmann
I have learned that the 6730b and 6730s have different accelerometer orientation, and have modified the driver accordingly (diff attached), while dropping the wild guess for AMD based 6735 having the same orientation as Intel based 6730 (this is not true for any other related series/family, thus is not probable for 673x). Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29cpuidle: always return with interrupts enabledKevin Hilman
In the case where cpuidle_idle_call() returns before changing state due to a need_resched(), it was returning with IRQs disabled. The idle path assumes that the platform specific idle code returns with interrupts enabled (although this too is undocumented AFAICT) and on ARM we have a WARN_ON(!(irqs_disabled()) when returning from the idle loop, so the user-visible effects were only a warning since interrupts were eventually re-enabled later. On x86, this same problem exists, but there is no WARN_ON() to detect it. As on ARM, the interrupts are eventually re-enabled, so I'm not sure of any actual bugs triggered by this. It's primarily a correctness/consistency fix. This patch ensures IRQs are (re)enabled before returning. Reported-by: Hemanth V <hemanthv@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Len Brown <len.brown@intel.com> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Tested-by: Martin Michlmayr <tbm@cyrius.com> Cc: <stable@kernel.org> [2.6.31.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29edac: i5100 fix initialization codeKeith Mannthey
Allow csrows to properly initialize when the topology only has active channels on 2 and 3. This new check allows proper detection and initialization in this topology. Only checking the first mrt that represented channels 0 and 1 is not sufficient. I also fixed up the related debug information path. I can submit as a 2nd patch if needed. Signed-off-by: Keith Mannthey <kmannth@us.ibm.com> Acked-by: Aristeu Rozanski <aris@ruivo.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29edac: i5400 fix missing CONFIG_PCI defineIra W. Snyder
When building without CONFIG_PCI the edac_pci_idx variable is unused, causing a build-time warning. Wrap the variable in #ifdef CONFIG_PCI, just like the rest of the PCI support. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29edac: i5400 fix csrow mappingJeff Roberson
The i5400 EDAC driver has several bugs with chip-select row computation which most likely lead to bugs in detailed error reporting. Attempts to contact the authors have gone mostly unanswered so I am presenting my diff here. I do not subscribe to lkml and would appreciate being kept in the cc. The most egregious problem was miscalculating the addresses of MTR registers after register 0 by assuming they are 32bit rather than 16. This caused the driver to miss half of the memories. Most motherboards tend to have only 8 dimm slots and not 16, so this may not have been noticed before. Further, the row calculations multiplied the number of dimms several times, ultimately ending up with a maximum row of 32. The chipset only supports 4 dimms in each of 4 channels, so csrow could not be higher than 4 unless you use a row per-rank with dual-rank dimms. I opted to eliminate this behavior as it is confusing to the user and the error reporting works by slot and not rank. This gives a much clearer view of memory by slot and channel in /sys. Signed-off-by: Jeff Roberson <jroberson@jroberson.net> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29twl4030-gpio: remove __devexit markings from remove funcMike Frysinger
The gpio_twl4030_probe() function calls gpio_twl4030_remove(), and the former has __devinit, so the latter cannot use __devexit. Otherwise we hit the section mismatch warning: WARNING: drivers/gpio/built-in.o(.devinit.text+0x71a): Section mismatch in reference from the function _gpio_twl4030_probe() to the function .devexit.text:_gpio_twl4030_remove() The function __devinit _gpio_twl4030_probe() references a function __devexit _gpio_twl4030_remove(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __devexit annotation of _gpio_twl4030_remove() so it may be used outside an exit section. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-298250_pci: add IBM Saturn serial cardBenjamin Herrenschmidt
The IBM Saturn serial card has only one port. Without that fixup, the kernel thinks it has two, which confuses userland setup and admin tools as well. [akpm@linux-foundation.org: fix pci-ids.h layout] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Alan Cox <alan@linux.intel.com> Cc: Michael Reed <mreed10@us.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29serial: add ADDI-DATA GmbH PCI-Express communication cards in 8250_pci.c and ↵Krauth.Julien
pci_ids.h Add support for ADDI-DATA GmbH PCI-Express communication cards: APCIe-7300 APCIe-7420 APCIe-7500 APCIe-7800 Warning: 8250_pci.c depends on pci_ids.h. 8250_pci.c Signed-off-by: Krauth Julien <Krauth.Julien@addi-data.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29atmel_serial: fix bad BUILD_BUG_ON() usageHaavard Skinnemoen
is_power_of_2() appears not to be constant enough for BUILD_BUG_ON() after the latest rework, so replace it with an open-coded test. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Jan Beulich <jbeulich@novell.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Alan Cox <alan@linux.intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29loop: fix NULL dereference if mount failsAlexey Dobriyan
Commit bb21488482bd36eae6b30b014d93619063773fd4 ("[PATCH] switch loop") started to pass NULL bdev to ioctl hook. Steps to reproduce: [boot with loop.max_part=1] [mount -o loop something so mount fails] BUG: unable to handle kernel NULL pointer dereference at 00000000000000b8 IP: [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 PGD 0 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/ACPI0003:00/power_supply/ACAD/online CPU 0 Modules linked in: zfs nvidia(P) [last unloaded: zfs] Pid: 15177, comm: mount Tainted: P 2.6.32-rc4-zfs #2 Satellite X200 RIP: 0010:[<ffffffff811486ee>] [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 RSP: 0018:ffff88003b3d5bb8 EFLAGS: 00010286 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 000000000000125f RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff88003b3d5ce8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 00007ffffffff000 R13: 0000000000000000 R14: ffff880071cef280 R15: 00000000000200da FS: 00007fd77cfe7740(0000) GS:ffff880001600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000000000b8 CR3: 0000000001001000 CR4: 00000000000026f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process mount (pid: 15177, threadinfo ffff88003b3d4000, task ffff88007572f920) Stack: ffff88003b3d5c38 ffffffff812f95f5 ffff88007eeb6600 0000000000000000 <0> 0000000000000000 ffff88003b3d5c18 ffffffff811547d9 ffff88001bf11ef0 <0> 7fffffffffffffff ffff88001bf11ee8 ffff88001bf11ef0 0000000000000000 Call Trace: [<ffffffff812f95f5>] ? schedule_timeout+0x1f5/0x250 [<ffffffff811547d9>] ? rb_insert_color+0x109/0x140 [<ffffffff812fb754>] ? _spin_unlock_irq+0x14/0x40 [<ffffffff812f84c6>] ? wait_for_common+0x66/0x170 [<ffffffff8105a280>] ? default_wake_function+0x0/0x10 [<ffffffff810f8258>] ioctl_by_bdev+0x38/0x50 [<ffffffff811d2481>] loop_clr_fd+0x1e1/0x210 [<ffffffff811d2522>] lo_release+0x72/0x80 [<ffffffff810f934c>] __blkdev_put+0x1ac/0x1d0 [<ffffffff810f937b>] blkdev_put+0xb/0x10 [<ffffffff810f93b9>] blkdev_close+0x39/0x60 [<ffffffff810ccef3>] __fput+0xd3/0x230 [<ffffffff810cd06d>] fput+0x1d/0x30 [<ffffffff810c9680>] filp_close+0x50/0x80 [<ffffffff81061f11>] put_files_struct+0x81/0x100 [<ffffffff81061fde>] exit_files+0x4e/0x60 [<ffffffff81063ec5>] do_exit+0x6b5/0x730 [<ffffffff8107b279>] ? up_read+0x9/0x10 [<ffffffff8104c86e>] ? do_page_fault+0x18e/0x2a0 [<ffffffff81063f81>] do_group_exit+0x41/0xc0 [<ffffffff81064012>] sys_exit_group+0x12/0x20 [<ffffffff81030deb>] system_call_fastpath+0x16/0x1b Code: f8 48 89 e5 48 81 ec 30 01 00 00 48 89 5d d8 4c 89 6d e8 4c 89 65 e0 4c 89 75 f0 4c 89 7d f8 48 89 bd e8 fe ff ff 49 89 cd 89 f3 <49> 8b 88 b8 00 00 00 81 fa 68 12 00 00 0f 84 57 05 00 00 0f 86 RIP [<ffffffff811486ee>] blkdev_ioctl+0x2e/0xa30 RSP <ffff88003b3d5bb8> CR2: 00000000000000b8 ---[ end trace c0b4d3c3118d1427 ]--- Fixing recursive fault but reboot is needed! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29omap_hsmmc: add missing probe handler hookRoger Quadros
The missing probe handler hook will never probe the driver. Add it back. Fixes broken MMC on OMAP. We use platform_driver_probe() API since omap_hsmmc is not a hot-pluggable device. Signed-off-by: Roger Quadros <ext-roger.quadros@nokia.com> Tested-by: Felipe Contreras <felipe.contreras@gmail.com> Tested-by: Tony Lindgren <tony@atomide.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Felipe Contreras <felipe.contreras@gmail.com> Cc: Denis Karpov <ext-denis.2.karpov@nokia.com> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: Greg KH <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29ide: Serialize CMD643 and CMD646 to fix a hardware bug with SSDMikulas Patocka
CMD646 corrupts data on concurrent transfers on both channels when IDE SSD is connected to one of the channels. Setup that demonstrates this hardware bug: Ultra 5, onboard CMD646, rev 3. /dev/hda is 8GB Seagate ST38410A in MWDMA2 /dev/hdd is 32GB SSD SiliconHardDisk in MWDMA2 - When reading /dev/hdd (for example with dd or fsck), reads from /dev/hda are corrupted, there are twiddled single bits 1->0 and some full 32-bit words corrupted, sometimes commands fail (which switches /dev/hda to PIO mode but the corruptions happen even in PIO). - Reads from /dev/hdd don't seem to be corrupted (i.e. fsck passes fine). - When I connected normal rotating harddisk to /dev/hdd, there was no corruption, so the corruption is something specific to SSD. - I tried the same setup on a PCI card with CMD649 and saw no corruption. This patch serializes the operation for CMD646 and 643 (I didn't test CMD643 but it may have the same hw bug too because it's earlier design). CMD649 is good. I don't know anything about CMD 648. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Tested-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29netdev: usb: dm9601.c can drive a device not supported yet, add support for itJanusz Krzysztofik
I found that the current version of drivers/net/usb/dm9601.c can be used to successfully drive a low-power, low-cost network adapter with USB ID 0a46:9000, based on a DM9000E chipset. As no device with this ID is yet present in the kernel, I have created a patch that adds support for the device to the dm9601 driver. Created and tested against linux-2.6.32-rc5. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29qlge: Fix firmware mailbox command timeout.Ron Mercer
The mailbox command process would only process a maximum of 5 unrelated firmware events while waiting for it's command completion status. It should process an unlimited number of events while waiting for a maximum of 5 seconds. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29qlge: Fix EEH handling.Ron Mercer
Clean up driver resources without touch the hardware. Add pci save/restore state. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Merge branch 'master' of ↵David S. Miller
