path: root/drivers
2006-04-14[SCSI] iscsi: fix up iscsi ehMike Christie
The current iscsi_tcp eh is not nicely setup for dm-multipath and performs some extra task management functions when they are not needed. The attached patch: - Fixes the TMF issues. If a session is rebuilt then we do not send aborts. - Fixes the problem where if the host reset fired, we would return SUCCESS even though we had not really done anything yet. This ends up causing problem with scsi_error.c's TUR. - If someone has turned on the userspace nop daemon code to try and detect network problems before the scsi command timeout we can now drop and clean up the session before the scsi command timesout and fires the eh speeding up the time it takes for a command to go from one patch to another. For network problems we fail the command with DID_BUS_BUSY so if failfast is set scsi_decide_disposition fails the command up to dm for it to try on another path. - And we had to add some basic iscsi session block code. Previously if we were trying to repair a session we would retrun a MLQUEUE code in the queuecommand. This worked but it was not the most efficient or pretty thing to do since it would take a while to relogin to the target. For iscsi_tcp/open-iscsi a lot of the iscsi error handler is in userspace the block code is pretty bare. We will be adding to that for qla4xxx. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-14[SCSI] iscsi: add sysfs attrs for uspace sync upMike Christie
For iscsi boot when going from initramfs to the real root we need to stop the userpsace iscsi daemon. To later restart it iscsid needs to be able to rebuild itself and part of that process is matching a session running the kernel with the iscsid representation. To do this the attached patch adds several required iscsi values. If the LLD does not provide them becuase, login is done in userspace, then the transport class and userspace set ths up for the LLD. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-14[SCSI] iscsi: rm kernel iscsi handles usage for session and connectionMike Christie
from hare@suse.de and michaelc@cs.wisc.edu hw iscsi like qla4xxx does not allocate a host per session and for userspace it is difficult to restart iscsid using the "iscsi handles" for the session and connection, so this patch just has the class or userspace allocate the id for the session and connection. Note: this breaks userspace and requires users to upgrade to the newest open-iscsi tools. Sorry about his but open-iscsi is still too new to say we have a stable user-kernel api and we were not good nough designers to know that other hw iscsi drivers and iscsid itself would need such changes. Actually we sorta did but at the time we did not have the HW available to us so we could only guess. Luckily, the only tools hooking into the class are the open-iscsi ones or other tools like iscsitart hook into the open-iscsi engine from userspace or prgroams like anaconda call our tools so they are not affected. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-14[SCSI] BLIST_ATTACH_PQ3 flagsKurt Garloff
Some devices report a peripheral qualifier of 3 for LUN 0; with the original code, we would still try a REPORT_LUNS scan (if SCSI level is >= 3 or if we have the BLIST_REPORTLUNS2 passed in), but NOT any sequential scan. Also, the device at LUN 0 (which is not connected according to the PQ) is not registered with the OS. Unfortunately, SANs exist that are SCSI-2 and do NOT support REPORT_LUNS, but report a unknown device with PQ 3 on LUN 0. We still need to scan them, and most probably we even need BLIST_SPARSELUN (and BLIST_LARGELUN). See the bug reference for an infamous example. This is patch 3/3: 3. Implement the blacklist flag BLIST_ATTACH_PQ3 that makes the scsi scanning code register PQ3 devices and continues scanning; only sg will attach thanks to scsi_bus_match(). Signed-off-by: Kurt Garloff <garloff@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-14[SCSI] Better log messages for PQ3 devsKurt Garloff
Some devices report a peripheral qualifier of 3 for LUN 0; with the original code, we would still try a REPORT_LUNS scan (if SCSI level is >= 3 or if we have the BLIST_REPORTLUNS2 passed in), but NOT any sequential scan. Also, the device at LUN 0 (which is not connected according to the PQ) is not registered with the OS. Unfortunately, SANs exist that are SCSI-2 and do NOT support REPORT_LUNS, but report a unknown device with PQ 3 on LUN 0. We still need to scan them, and most probably we even need BLIST_SPARSELUN (and BLIST_LARGELUN). See the bug reference for an infamous example. This patch 2/3: If a PQ3 device is found, log a message that describes the device (INQUIRY DATA and C:B:T:U tuple) and make a suggestion for blacklisting it. Signed-off-by: Kurt Garloff <garloff@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-14[SCSI] Try LUN 1 and use bflagsKurt Garloff
Some devices report a peripheral qualifier of 3 for LUN 0; with the original code, we would still try a REPORT_LUNS scan (if SCSI level is >= 3 or if we have the BLIST_REPORTLUNS2 passed in), but NOT any sequential scan. Also, the device at LUN 0 (which is not connected according to the PQ) is not registered with the OS. Unfortunately, SANs exist that are SCSI-2 and do NOT support REPORT_LUNS, but report a unknown device with PQ 3 on LUN 0. We still need to scan them, and most probably we even need BLIST_SPARSELUN (and BLIST_LARGELUN). See the bug reference for an infamous example. This is patch 1/3: If we end up in sequential scan, at least try LUN 1 for devices that reported a PQ of 3 for LUN 0. Also return blacklist flags, even for PQ3 devices. Signed-off-by: Kurt Garloff <garloff@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-12Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/mthca: Fix max_srq_sge returned by ib_query_device for Tavor devices IB/cache: Use correct pointer to calculate size IPoIB: Use spin_lock_irq() instead of spin_lock_irqsave() IPoIB: Close race in ipoib_flush_paths() IB/mthca: Disable tuning PCI read burst size IPoIB: Make send and receive queue sizes tunable IPoIB: Wait for join to finish before freeing mcast struct IB: simplify static rate encoding IPoIB: Consolidate private neighbour data handling IB/srp: Fix memory leak in options parsing IB/mthca: Always build debugging code unless CONFIG_EMBEDDED=y IPoIB: Always build debugging code unless CONFIG_EMBEDDED=y IB/mad: fix oops in cancel_mads
2006-04-12Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [PATCH] sata_mv: properly print HC registers
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: [PATCH] Use pci_set_consistent_dma_mask in ixgb driver [PATCH] sky2: bad memory reference on dual port cards [PATCH] mv643xx_eth: Fix tx_timeout to only conditionally wake tx queue [PATCH] mv643xx_eth: Always free completed tx descs on tx interrupt [PATCH] net drivers: fix section attributes for gcc [PATCH] remove drivers/net/hydra.h [PATCH] drivers/net/via-rhine.c: make a function static [netdrvr b44] trim trailing whitespace [PATCH] b44: increase version to 1.00 [PATCH] b44: disable default tx pause [PATCH] via-rhine: execute bounce buffers code on Rhine-I only [PATCH] network: axnet_cs.c: add missing 'PRIV' in ei_rx_overrun [PATCH] dlink pci cards using wrong driver
2006-04-12[PATCH] Use pci_set_consistent_dma_mask in ixgb driverAndreas Schwab
The ixgb driver is using pci_alloc_consistent, thus is should also use pci_set_consistent_dma_mask. This allows the driver to work on SGI systems. In case of an error during probing it should also disable the device again. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] sky2: bad memory reference on dual port cardsStephen Hemminger
Sky2 driver will oops referencing bad memory if used on a dual port card. The problem is accessing past end of MIB counter space. Applies for both 2.6.17 and 2.6.16 (with fuzz) Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] mv643xx_eth: Fix tx_timeout to only conditionally wake tx queueDale Farnsworth
After resetting the hardware on a tx_timeout, call netif_wake_queue() only if we have free tx descriptors. Also, attempt to recover if mv643xx_eth_start_xmit() is called when there are fewer free tx descriptors than expected. The BUG_ON() call we are replacing was hit on a tx_timeout that called netif_wake_queue(), indirectly via netif_device_attach(), even though we did not have enough free tx descriptors. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] mv643xx_eth: Always free completed tx descs on tx interruptBrent Cook
Fix the tx interrupt handler to free completed tx descriptors even when NAPI is enabled. Otherwise, the tx queue would fill up resulting in poor performance and "NETDEV WATCHDOG: <iface>: transmit timed out" messages. Signed-off-by: Brent Cook <bcook@bpointsys.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] net drivers: fix section attributes for gccRandy Dunlap
If CONFIG_HOTPLUG=n, gcc doesn't like some __initdata to be const (rodata) and other __initdata not const, so make the non-const __initdata const. gcc errors: drivers/net/bnx2.c:66: error: version causes a section type conflict drivers/net/starfire.c:338: error: version causes a section type conflict drivers/net/typhoon.c:137: error: version causes a section type conflict drivers/net/natsemi.c:241: error: version causes a section type conflict Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] remove drivers/net/hydra.hAdrian Bunk
Remove drivers/net/hydra.h which is both unused and covered by a 4 clause BSD licence (not by the UCB). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-By: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] drivers/net/via-rhine.c: make a function staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Roger Luethi <rl@hellgate.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] sata_mv: properly print HC registersDan Aloni
Currently it crashes when trying to dump the registers. This is an obvious one-liner fix I suppose. Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[netdrvr b44] trim trailing whitespaceJeff Garzik
2006-04-12[PATCH] b44: increase version to 1.00Gary Zambrano
2006-04-12[PATCH] b44: disable default tx pauseGary Zambrano
Disable default tx pause frame support. The b44 controller has a bug that generates excessive tx pause frames. Signed-off-by: Gary Zambrano <zambrano@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] via-rhine: execute bounce buffers code on Rhine-I onlyRoger Luethi
Patch suggested by Yang Wu (pin xue <pinxue@gmail.com>). Signed-off-by: Roger Luethi <rl@hellgate.ch> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] network: axnet_cs.c: add missing 'PRIV' in ei_rx_overrunKomuro
Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12[PATCH] dlink pci cards using wrong driverStephen Hemminger
This patch fixes the problem of some Dlink cards picking the wrong driver. It looks like these cards use Yukon 1 chipset, not Yukon 2. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-12IB/mthca: Fix max_srq_sge returned by ib_query_device for Tavor devicesJack Morgenstein
The driver allocates SRQ WQEs size with a power of 2 size both for Tavor and for memfree. For Tavor, however, the hardware only requires the WQE size to be a multiple of 16, not a power of 2, and the max number of scatter-gather allowed is reported accordingly by the firmware (and this is the value currently returned by ib_query_device() and ibv_query_device()). If the max number of scatter/gather entries reported by the FW is used when creating an SRQ, the creation will fail for Tavor, since the required WQE size will be increased to the next power of 2, which turns out to be larger than the device permitted max WQE size (which is not a power of 2). This patch reduces the reported SRQ max wqe size so that it can be used successfully in creating an SRQ on Tavor HCAs. Signed-off-by: Jack Morgenstein <jackm@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-04-11[ISDN]: Static overruns in drivers/isdn/i4l/isdn_ppp.cEric Sesterhenn
Coverity found some static overruns in isdn_ppp.c (bug id #519) At several places slot is compared <0 and > ISDN_MAX_CHANNELS and then used to index ippp_table[ISDN_MAX_CHANNELS] A value of slot = ISDN_MAX_CHANNELS would run over the end of the array. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11[WAN]: Remove broken and unmaintained Sangoma drivers.Adrian Bunk
The in-kernel Sangoma drivers are both not compiling and marked as BROKEN since at least kernel 2.6.0. Sangoma offers out-of-tree drivers, and David Mandelstam told me Sangoma does no longer maintain the in-kernel drivers and prefers to provide them as a separate installation package. This patch therefore removes these drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kconfig: fix typo in change count initialization kconfig: recenter menuconfig kconfig: revert conf behaviour change kconfig: fix default value for choice input kbuild: fix NULL dereference in scripts/mod/modpost.c kbuild: fix mode of checkstack.pl and other files. kbuild: rebuild initramfs if content of initramfs changes kbuild: properly pass options to hostcc when doing make O=.. kbuild: modules_install for external modules must not remove existing modules kbuild: fix make dir/ ver_linux: don't print reiser4progs version if none found kbuild: mips: fix sed regexp to generate asm-offset.h kbuild: fix building single targets with make O=.. single-target kbuild: use relative path to -I kbuild: fix unneeded rebuilds in drivers/net/chelsio after moving source tree kbuild: fix unneeded rebuilds in drivers/media/video after moving source tree kbuild: fix garbled text in modules.txt
2006-04-11[PATCH] Overrun in option-card USB driverMatthias Urlichs
Since the arrays are declared as in_urbs[N_IN_URB] and out_urbs[N_OUT_URB], both for loops go one over the end of the array. This fixes coverity id #555. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fbdev: Use logo with depth of 4 or less for static pseudocolorAntonino A. Daplas
Since the visual STATIC_PSEUDOCOLOR has a read-only colormap, use logos with 16 colors only since these logos use the console palette. This has a higher likelihood that the logo will display correctly. Signed-of-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] vesafb: Fix incorrect logo colors in x86_64Antonino A. Daplas
Bugzilla Bug 6299: A pixel size of 8 bits produces wrong logo colors in x86_64. The driver has 2 methods for setting the color map, using the protected mode interface provided by the video BIOS and directly writing to the VGA registers. The former is not supported in x86_64 and the latter is enabled only in i386. Fix by enabling the latter method in x86_64 only if supported by the BIOS. If both methods are unsupported, change the visual of vesafb to STATIC_PSEUDOCOLOR. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] atyfb is bust on sparc32Andrew Morton
Heaps of build errors - disable it to keep sparc32 allmodconfig happy. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] video/aty/atyfb_base.c: fix an off-by-one errorAdrian Bunk
Fix an obvious of-by-one error spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] ISDN_DRV_GIGASET should select, not depend on CRC_CCITTAdrian Bunk
CRC_CCITT is an internal helper function that should be select'ed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn/gigaset/common.c: fix a memory leakAdrian Bunk
Fix a memory leak spotted by the Coverity checker if (!try_module_get(owner)). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] drivers/isdn/gigaset/common.c: small cleanupsAdrian Bunk
- make the needlessly global gigaset_get_cs_by_tty() static - remove the unused EXPORT_SYMBOL_GPL(gigaset_debugdrivers) Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: make some variables non-atomicTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Replace some atomic_t variables in the Gigaset drivers by non-atomic ones, using spinlocks instead to assure atomicity, as proposed in discussions on the linux-kernel mailing list. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: remove forward referencesTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Remove four unnecessary forward function declarations and an obsolete E-mail address from the Siemens Gigaset drivers. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: remove private version of ↵Tilman Schmidt
__skb_put() With Hansjoerg Lipp <hjlipp@web.de> Remove the private version of __skb_put() from the Siemens Gigaset drivers. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: mutex conversionTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Convert the semaphores used by the Gigaset drivers to mutexes. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: eliminate from_user argumentTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Eliminate the from_user argument from a debugging function, thus easing the job of sparse. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: uninlineTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Uninline a function which was slightly too big to warrant inlining. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: remove IFNULL macrosTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Remove the IFNULL debugging macros from the Gigaset drivers. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: sysfs usageTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Correct the way the Gigaset drivers create their sysfs entries. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: logging usageTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Improve error reporting of the Gigaset drivers, by using the dev_err/dev_warn/dev_info macros from device.h instead of err/warn/info from usb.h whereever possible. Also rename the private dbg macro to gig_dbg in order to avoid confusion with the macro of the same name in usb.h. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: timer usageTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Correct timer usage in the Gigaset drivers to take advantage of the existing setup_timer() function, and use milliseconds as unit. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: Kconfig correctionTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Remove the restriction to build the Gigaset drivers as modules only. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: code cleanupTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Source code formatting cleanups for the Siemens Gigaset drivers, such as line length, comments, removal of unused declarations, and typo corrections. It does not introduce any functional changes. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: VR41XX cleanupAlessandro Zummo
Clean up kconfig entry for the rtc-vr41xx. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: VR41XX driverYoichi Yuasa
This patch updates VR4100 series RTC driver. * This driver supports new RTC subsystem. * Simple set time/read time test worked fine. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: SA1100 cleanupAlessandro Zummo
- convert printks to dev_xxx - remove messages in excess Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
