path: root/drivers
2008-06-04MTD/JFFS2: remove CVS keywordsAdrian Bunk
Once upon a time, the MTD repository was using CVS. This patch therefore removes all usages of the no longer updated CVS keywords from the MTD code. This also includes code that printed them to the user. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [NAND] nandsim: allow for 64-bit sizeAdrian Hunter
Amend nandsim so that it does not assume 32-bit flash size. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [NAND] nandsim: fix overridesizeAdrian Hunter
2008-06-04[MTD] [NAND] nandsim: fix size bugAdrian Hunter
2008-06-04[MTD] [OneNAND] Check the ECC status first instead of controllerKyungmin Park
To get the correct information in case of power off recovery, it should read ECC status first Also remove previous workaround method. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] DataFlash: use proper typesDavid Woodhouse
2008-06-04[MTD] DataFlash: fix bug - ATMEL AT45DF321D spi flash card fails to be ↵Michael Hennerich
copied to (v2) - Add support for binary page size DataFlashes. - The driver now prints out pagesize and erasesize. Printout valuable information for creating flash filesystems. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] use list_for_each_entry() in del_mtd_device()matthias@kaehlcke.net
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] use list_for_each_entry() in add_mtd_device()matthias@kaehlcke.net
2008-06-04[MTD] [NAND] excite_nandflash: simplify code using ARRAY_SIZE() macro.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [NAND] fix 2 "unused variable" warnings in cafe_nand.cToralf Förster
Signed-off-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [NOR] Add support for Eon EN29SL800B[BT] NOR flash chipsMike Rapoport
This patch add support for non-CFI Eon EN29SL800B[BT] NOR flash chips. The Eon chips have manufacturer ID in the first bank, therefore this patch depends on support for flash chips with ID in bank other than 0. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [NOR] Add support for flash chips with ID in bank other than 0Mike Rapoport
According to JEDEC "Standard Manufacturer's Identification Code" (http://www.jedec.org/download/search/jep106W.pdf) several first banks of NOR flash can contain 0x7f instead of actual ID. This patch adds support for reading manufacturer ID from banks other than 0. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-04[MTD] [NOR] Add support for AMD AM29SL800D[BT] NOR flash chipsMike Rapoport
2008-05-14[MTD] [NOR] Support for M50FLW080A and M50FLW080BNate Case
Add support for M50FLW080A and M50FLW080B revisions of LPC flash devices. Signed-off-by: Aaron Lindner <alindner@xes-inc.com> Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-06[MTD] [NOR] Remove cfi_cmdset_0001.c erase suspend fixup typoAlexander Belyakov
Fix typo in erase suspend while write fixup code leading to compile time error if CMDSET0001_DISABLE_ERASE_SUSPEND_ON_WRITE was defined. drivers/mtd/chips/cfi_cmdset_0001.c: In function 'fixup_intel_strataflash': drivers/mtd/chips/cfi_cmdset_0001.c:212: error: 'struct cfi_pri_amdstd' has no member named 'SuspendCmdSupport' Signed-off-by: Alexander Belyakov <abelyako@googlemail.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [MTD][NOR] Add physical address to point() method [JFFS2] Track parent inode for directories (for NFS export) [JFFS2] Invert last argument of jffs2_gc_fetch_inode(), make it boolean. [JFFS2] Quiet lockdep false positive. [JFFS2] Clean up jffs2_alloc_inode() and jffs2_i_init_once() [MTD] Delete long-unused jedec.h header file. [MTD] [NAND] at91_nand: use at91_nand_{en,dis}able consistently.
2008-05-01[MTD][NOR] Add physical address to point() methodJared Hulbert
Adding the ability to get a physical address from point() in addition to virtual address. This physical address is required for XIP of userspace code from flash. Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Reviewed-by: Jörn Engel <joern@logfs.org> Acked-by: Nicolas Pitre <nico@cam.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ide: fix early setup of hwif->host_flags
2008-05-01Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: hwmon: (adt7473) minor cleanup / refactoring hwmon: (asb100) Remove some dead code hwmon: (lm75) Fix an incorrect comment hwmon: (w83793) VID and VRM handling cleanups hwmon: (w83l785ts) Don't ask the user to report failures hwmon: (smsc47b397) add a new chip id (0x8c)
2008-05-01m68knommu: fix FEC driver lockingSebastian Siewior
It's easy: grab locks before talking to hardware and realease them afterwards. The one big lock has been splitted into a hw_lock and mii_lock. Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01m68knommu: kill warnings in FEC driverSebastian Siewior
linux-2.6-mk68/drivers/net/fec.c: In function 'fec_enet_module_init': linux-2.6-mk68/drivers/net/fec.c:2627: warning: unused variable 'j' linux-2.6-mk68/drivers/net/fec.c: At top level: linux-2.6-mk68/drivers/net/fec.c:2136: warning: 'mii_link_interrupt' defined but not used Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01m68knommu: remove unused interrupts in FEC driverGreg Ungerer
Remove the acquisition of unused interrupt types. We don't need to register all the TX and RX varients used on some ColdFire FEC hardware. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01m68knommu: fix ColdFire 5272 fec driver hash registersGreg Ungerer
Renamed the 5272 hash_table registers to match the "grp" hash_table registers of the other ColdFire parts. They are actually a group hash. The makes for consistent setup across all ColdFire parts. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01drivers/scsi/mvsas.c: fix printk warningsAndrew Morton
drivers/scsi/mvsas.c: In function `mvs_update_phyinfo': drivers/scsi/mvsas.c:2822: warning: long long unsigned int format, u64 arg (arg 5) drivers/scsi/mvsas.c:2822: warning: long long unsigned int format, u64 arg (arg 6) We do not know what type the arch uses to implement u64. Cc: Ke Wei <kewei@marvell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01drivers/scsi/ncr53c8xx.c: fix warningAndrew Morton
drivers/scsi/ncr53c8xx.c: In function 'process_waiting_list': drivers/scsi/ncr53c8xx.c:8225: warning: suggest parentheses around assignment used as truth value recently added by commit 172c122df5186e7cbd413d61757ff90267331002 Author: Harvey Harrison <harvey.harrison@gmail.com> Date: Mon Apr 28 16:50:03 2008 -0700 scsi: fix integer as NULL pointer warnings Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01drivers-char-synclinkc-inbreak-mgsl_put_char-fixAndrew Morton
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01drivers/char/synclink.c: unbreak mgsl_put_char()Andrew Morton
Repair the effects of commit 55da77899c1472d83452c914fa179d00ea96df65 Author: Alan Cox <alan@lxorguk.ukuu.org.uk> Date: Wed Apr 30 00:54:07 2008 -0700 synclink series: switch to int put_char method Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Jiri Slaby <jirislaby@gmail.com> drivers/char/synclink_gt.c: In function 'put_char': drivers/char/synclink_gt.c:919: warning: 'ret' may be used uninitialized in this function and do some whitespace repair and unneeded-cast-removal in there as well. Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01cpu: change cpu_sys_devices from array to per_cpu variableMike Travis
Change cpu_sys_devices from array to per_cpu variable in drivers/base/cpu.c. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01cciss: assign PDE->data before gluing PDE into /proc treeDenis V. Lunev
Simply replace proc_create and further data assigned with proc_create_data. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Mike Miller <mike.miller@hp.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01gpio: pca953x: add support for pca9555 I2C I/O expanderWill Newton
Add support for pca9555 I2C I/O expander. As the comment suggests this part is software compatible with the pca9539. Signed-off-by: Will Newton <will.newton@imgtec.com> Cc: "eric miao" <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01spi_s3c24xx signedness fixMatthew Wilcox
On Fri, Apr 18, 2008 at 09:08:55PM +0200, Julia Lawall wrote: > I found 63 occurrences of this problem with the following semantic match > (http://www.emn.fr/x-info/coccinelle/): > > @@ unsigned int i; @@ > > * i < 0 > Since this one's always in the range 0-255, it could probably be made signed, but it's just as easy to make it work unsigned. Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01spi_bfin5xx: use PIO for full duplex, not DMAVitja Makarov
Use PIO for full-duplex transfers, instead of DMA. Signed-off-by: Vitja Makarov <vitja.makarov@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01jsm: add new supported board to jsm serial driverScott Kilau
Add new PCI Express Neo/JSM board to the supported list of drivers in the JSM driver. Signed-off-by: Scott Kilau <scottk@digi.com> Acked-by: Ananda V <avenkat@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-018250: switch 8250 drivers to use _nocache ioremapsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01i8k: make fan multiplier tunable with a module parameterJochen Eisinger
The i8k driver multiplies the fan speed reported by the BIOS with a factor of 30. On my Dell Latitude D800, this factor is not required. I'd suggest to make this configurable. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01PNP: fix printk format warningsRandy Dunlap
next-20080430/drivers/pnp/pnpbios/rsparser.c:594: warning: format '%d' expects type 'int', but argument 4 has type 'resource_size_t' next-20080430/drivers/pnp/pnpbios/rsparser.c:605: warning: format '%d' expects type 'int', but argument 4 has type 'resource_size_t' [joe@perches.com: fix it] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01pcmcia: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-05-01drivers/pcmcia/soc_common.c: convert soc_pcmcia_sockets_lock into a mutex ↵Andrew Morton
and make it static Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01Alchemy Semi Au1000 pcmcia driver: convert pcmcia_sockets_lock in a mutexMatthias Kaehlcke
Alchemy Semi Au1000 pcmcia driver: The semaphore pcmcia_sockets_lock is used as a mutex, convert it to the mutex API (akpm: make it static too) Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01pcmcia: annotate cb_alloc with __refSam Ravnborg
cb_alloc() uses a function (pci_scan_slot) that will be annotated __devinit. Annotate cb_alloc() with __ref to tell modpost to ignore this reference. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01pcmcia: silence section mismatch warnings from pci_driver variablesSam Ravnborg
Silence following warnings: WARNING: drivers/pcmcia/built-in.o(.data+0x14e0): Section mismatch in reference from the variable pd6729_pci_drv to the function .devinit.text:pd6729_pci_probe() WARNING: drivers/pcmcia/built-in.o(.data+0x14e8): Section mismatch in reference from the variable pd6729_pci_drv to the function .devexit.text:pd6729_pci_remove() WARNING: drivers/pcmcia/built-in.o(.data+0x16c0): Section mismatch in reference from the variable i82092aa_pci_drv to the function .devinit.text:i82092aa_pci_probe() WARNING: drivers/pcmcia/built-in.o(.data+0x16c8): Section mismatch in reference from the variable i82092aa_pci_drv to the function .devexit.text:i82092aa_pci_remove() Rename the variables from *_drv to *_driver so modpost ignore the OK references to __devinit/__devexit functions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01pcmcia: silence section mismatch warnings from class_interface variablesSam Ravnborg
Silence the following warnings: WARNING: drivers/pcmcia/built-in.o(.data+0x6e8): Section mismatch in reference from the variable pcmcia_bus_interface to the function .devinit.text:pcmcia_bus_add_socket() WARNING: drivers/pcmcia/built-in.o(.data+0xa88): Section mismatch in reference from the variable pccard_rsrc_interface to the function .devinit.text:pccard_sysfs_add_rsrc() WARNING: drivers/pcmcia/built-in.o(.data+0xa90): Section mismatch in reference from the variable pccard_rsrc_interface to the function .devexit.text:pccard_sysfs_remove_rsrc() The variables of type class_interface contains references to __devinit and __devexit functions which is OK. Silence warnings by annotating the variables with __refdata. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01isdn: hysdn_procconf.c build fixIngo Molnar
x86.git randconfig testing found the following build error in latest -git: CC [M] drivers/isdn/hysdn/hysdn_procconf.o CC [M] drivers/isdn/hysdn/hysdn_init.o drivers/isdn/hysdn/hysdn_procconf.c: In function 'hysdn_procconf_init': drivers/isdn/hysdn/hysdn_procconf.c:408: error: too few arguments to function 'proc_create' with the following config: http://redhat.com/~mingo/misc/config-Wed_Apr_30_15_12_48_CEST_2008.bad Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: "Denis V. Lunev" <den@openvz.org> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01remove div_long_long_remRoman Zippel
x86 is the only arch right now, which provides an optimized for div_long_long_rem and it has the downside that one has to be very careful that the divide doesn't overflow. The API is a little akward, as the arguments for the unsigned divide are signed. The signed version also doesn't handle a negative divisor and produces worse code on 64bit archs. There is little incentive to keep this API alive, so this converts the few users to the new API. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ide: fix early setup of hwif->host_flagsBartlomiej Zolnierkiewicz
On Thursday 01 May 2008, Jeremy Kerr wrote: > Hi all, > > On QS20 Cell machines, Linus' current git tree explodes on boot: > > SiI680: IDE controller (0x1095:0x0680 rev 0x02) at PCI slot > 0000:00:0a.0 > SiI680: BASE CLOCK == 133 > SiI680: 100% native mode on irq 51 > ide0: MMIO-DMA > ide1: MMIO-DMA > Unable to handle kernel paging request for data at address > 0xa000100081220080 > Faulting instruction address: 0xc000000000024748 > cpu 0x2: Vector: 300 (Data Access) at [c00000001e143420] > pc: c000000000024748: ._insw_ns+0x10/0x30 > lr: c000000000037fc4: .spiderpci_readsw+0x24/0x6c > sp: c00000001e1436a0 > msr: 9000000000001032 > dar: a000100081220080 > dsisr: 40000000 > current = 0xc00000003d060000 > paca = 0xc000000000623880 > pid = 1, comm = swapper > enter ? for help > [link register ] c000000000037fc4 .spiderpci_readsw+0x24/0x6c > [c00000001e1436a0] c00000000062ce63 (unreliable) > [c00000001e143730] c0000000000379d4 .iowa_readsw+0x78/0xa8 > [c00000001e1437c0] c000000000037a98 .iowa_insw+0x94/0xd4 > [c00000001e143850] c00000000022a190 .ata_input_data+0x298/0x2ec > [c00000001e143910] c00000000022b600 .try_to_identify+0x2c0/0x6d4 > [c00000001e1439d0] c00000000022bb54 .do_probe+0x140/0x35c > [c00000001e143a80] c00000000022bfbc .ide_probe_port+0x24c/0x670 > [c00000001e143b50] c00000000022d09c .ide_device_add_all+0x2ec/0x690 > [c00000001e143c00] c00000000022d4a4 .ide_device_add+0x64/0x74 > [c00000001e143c90] c00000000022f834 .ide_setup_pci_device+0x58/0x7c > [c00000001e143d30] c00000000038bdf8 > [c00000001e143e10] c000000000486fb0 .ide_scan_pcibus+0x8c/0x178 > [c00000001e143ea0] c000000000460c00 .kernel_init+0x1c4/0x344 > [c00000001e143f90] c000000000024a1c .kernel_thread+0x4c/0x68 > > It looks like we're trying to do PIO accesses (which appear to be > broken, but that's another issue) to this MMIO device. In > ata_input_data, we see that: > > u8 mmio = (hwif->host_flags & IDE_HFLAG_MMIO) ? 1 : 0; > > Gives mmio == 0. > > (what's the difference between hwif->mmio and ID_HFLAG_MMIO?) > > In the siimage driver, hwif->host flags is initially set up correctly > (host_flags includes IDE_HFLAG_MMIO), but we then *clear* this bit in > ide_init_port: > > hwif->host_flags = d->host_flags; > > where d is the struct ide_port_info for this chipset. In my case, > d->host_flags is 0x0. It looks like this will be the same for all of > the siimage chipsets. Don't over-write hwif->host_flags in ide_init_port(), some host drivers set IDE_HFLAG_MMIO or IDE_HFLAG_NO_IO_32BIT host flag early. Thanks to Jeremy Kerr for the excellent analysis of the bug. Reported-by: Jeremy Kerr <jk@ozlabs.org> Tested-by: Jeremy Kerr <jk@ozlabs.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ben Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-05-01Merge branch 'smsc47b397-new-id' into releaseMark M. Hoffman
2008-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes3 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes3: (21 commits) x86: numaq fix x86: 8K stacks by default x86: ioremap ram check fix x86: fix HT cpu booting on 32-bit x86: optimize inlining off x86: CONFIG_X86_ELAN fix x86: Kconfig fix x86 PAT: fix performance drop for glx, use UC minus for ioremap(), ioremap_nocache() and pci_mmap_page_range() x86: use defconfigs from x86/configs/* toshiba: use ioremap_cached revert: "x86: ioremap(), extend check to all RAM pages" x86: don't bother printing compat vdso address fix: x86: support for new UV apic x86: fix early-BUG message x86: iommu_sac_force can become static x86: add proper header for reboot_force x86 VISWS: build fix x86, voyager: fix ioremap_nocache() hpet: fix x86: unexport kmap_atomic_to_page ...
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: klist: fix coding style errors in klist.h and klist.c driver core: remove no longer used "struct class_device" pcmcia: remove pccard_sysfs_interface warnings devres: support addresses greater than an unsigned long via dev_ioremap kobject: do not copy vargs, just pass them around sysfs: sysfs_update_group stub for CONFIG_SYSFS=n DEBUGFS: Correct location of debugfs API documentation. driver core: warn about duplicate driver names on the same bus klist: implement klist_add_{after|before}() klist: implement KLIST_INIT() and DEFINE_KLIST() sysfs: Disallow truncation of files in sysfs
2008-04-30driver core: remove no longer used "struct class_device"Kay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
