This patch cleans up some flow handler related document. It also
removes some blank lines.
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
Acked-by: Tomas Winkler <tomas.winkler@intel.com>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
The patch rewrites the mac80211 configure_filter handler to better mapping
mac80211 filter flags to iwlwifi hardware filter flags. We now can support
5 mac80211 filter flags: FIF_OTHER_BSS, FIF_ALLMULTI, FIF_PROMISC_IN_BSS,
FIF_BCN_PRBRESP_PROMISC and FIF_CONTROL. This patch also avoids reconnecting
if the filter flags are changed when the STA is associated. Because rx_assoc
is used when full rxon is not necessary.
Patch fixes checkpatch.pl errors for iwlwifi.
Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com>
use IWL_CCK_RATES_MASK and IWL_OFDM_RATES_MASK instead of
their values directly.
cc: Harvey Harrison <harvey.harrison@gmail.com>
This patch
1. Removes use once use only fc variables, they are useless after refactoring
ieee80211 frame control handlers
2. Other trivial cleanups
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
This patch moves code around and group most of the station
management code into iwl-sta.c
No functional changes (yet)
Patch aligns iwl3945_pci_probe with iwlwifi's iwl_pci_probe.
Added few comments and code simplified to make readable.
The callback function write_tx_data() can only fail
when our ENTRY_OWNER_DEVICE_DATA flag on a queue entry
failed to determine the entry was not available and
it is in fact still owned by the hardware.
This means that if that function fails the queue
must be stopped in mac80211.
When rt2x00queue_get_queue() returns NULL in the TX
path, it means mac80211 has passed us an invalid queue,
although this should be impossible, it shouldn't hurt
if we send mac80211 a signal to stop the queue either.
Both issues can simply be resolved by removing their
manual failure handler and making them use the failure path
provided in rt2x00mac_tx().
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
rt2500usb and rt73usb have different register word sizes,
for that reason the register access wrappers were never
moved into rt2x00usb.
With rt2800usb on its way, we should favor the 32bit
register access and move those wrappers into rt2x00usb.
That saves duplicate code, since only rt2500usb will
need the special 16bit wrappers.
All code which accessed indirect registers was similar
in respect to the for-loop, the given timeout, etc.
Move it into a seperate function, which for PCI drivers
can be moved into rt2x00pci.
This allows us to cleanup the cleanup the code further
by removing the goto statementsand making the codepath
look a bit nicer.
Call the ath5k pci driver struct "ath5k" too to be less
confusing in sysfs.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
This reverts commit 4a3e818181e1baf970e9232ca8b747e233176b87.
On request from Alan Cox.
This reverts commit 52429eb216385fdc6969c0112ba8b46cffefaaef.
This reverts commit 7ea3a9ad9bf360f746a7ad6fa72511a5c359490d.
This change forces the bits to 0 by using an &= operation with an inverted
mask of all options instead of using an |= with a value of 0.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
There is a reference to a Buffer Size extention bit that is unneded by
82575/82576 hardware. Since it is not needed it should be removed from the
code.
Since the netlink option for DCB is necessary to actually be useful,
simplified the Kconfig option. In addition, added useful help text for the
Kconfig option.
Add %pm to omit the colons when printing a mac address.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Made usb_drivers reset_resume function point to hso_resume this
fixes problems a usb reset is done when the network interface
is left idle for a few minutes. Possibly reset_resume should
initialise hardware more but this works in the common case.
Signed-off-by: Denis Joseph Barrow <D.Barow@option.com>
Makes TIOCM ioctls for Data Carrier Detect & related functions
work like /drivers/serial/serial-core.c potentially needed
for pppd & similar user programs.
A new structure hso_mutex_table had to be declared statically
& used as as hso_device mutex_lock(&serial->parent->mutex) etc
is freed in hso_serial_open & hso_serial_close by kref_put while
the mutex is still in use.
This is a substantial change but should make the driver much stabler.
Added check for IFF_UP in hso_resume, this should eliminate -EINVAL (-22)
errors caused from urb's being submitted twice, once by hso_resume
& once in hso_net_open, if suspend/resume USB power saving mode is enabled
Moved serial_open_count in hso_serial_open to
prevent crashes owing to the serial structure being made NULL
when hso_serial_close is called even though hso_serial_open
returned -ENODEV, Alan Cox pointed out this happens,
also put in sanity check in hso_serial_close
to check for a valid serial structure which should prevent
the most reproducable crash in the driver when the hso device
is disconnected while in use.
This use of netdev->priv is wrong.
The right way is:
alloc_netdev() with no memory for private data.
make netdev->ml_priv to point to c2_dev.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Acked-by: Roland Dreier <rolandd@cisco.com>
1. convert netdev->priv to netdev_priv().
2. make sbni_pci_probe() be static.
Freeing previously allocated buffers in case of error.
Signed-off-by: Jirka Pirko <jirka@pirko.cz>
Pointed out by Joe Perches. Error message after tx_ring allocation check was
wrong.
Signed-off-by: Jirka Pirko <jirka@jirka.pirko.cz>
Fixed typo when allocating rx_ring, tx_ring was checked for null instead.
Instead of using call by reference use the PTR_ERR macros to handle
return value with error case. Compile tested only.
Commit 4e4fd4e485ad63a9074ff09a9b53ffc7a5c594ec ("ne2k: convert to
net_device_ops") exported some ei_* symbols from the 8390 library,
but the axnet_cs driver defines local static versions of the same
functions.
Rename them to avoid the namespace conflict.
Reported by Stephen Rothwell.
Update myri10ge firmware headers.
Signed-off-by: Brice Goglin <brice@myri.com>
Update DCA sections closing comments.
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6
Currently the igb driver is experiencing a panic due to a null function
pointer being used during the cleanup of the ethtool looback test on
fiber/serdes parts. This patch prevents that and adds a check prior to
calling any phy function.
Clarrify reading PBA has no side-effect (clearing).
Add missing GPL license text.
Signed-off-by: Scott Feldman <scofeldm@cisco.com>
Add driver/firmware compatibility check.
Update firmware notify cmd to honor notify area size.
Add new version of init cmd.
Add link_down_cnt to notify area to track link down count.
Enable ethtool support for get/set_flags so LRO can be turned on/off
by fwding drivers such as the bridge driver. LRO is not compatible
with fwding drivers.
pc300too driver works around a bug in PCI9050 bridge. Unfortunately
it was doing that too late.
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
