path: root/drivers
2013-04-10rt2x00: error in configurations with mesh support disabledFelix Fietkau
commit 6ef9e2f6d12ce9e2120916804d2ddd46b954a70b upstream. If CONFIG_MAC80211_MESH is not set, cfg80211 will now allow advertising interface combinations with NL80211_IFTYPE_MESH_POINT present. Add appropriate ifdefs to avoid running into errors. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> [lxiang: Backported for 3.4-stable. Removed code of simultaneous AP and mesh mode added in 4a5fc6d 3.9-rc1.] Signed-off-by: Lingzhu Xiang <lxiang@redhat.com> Reviewed-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10ixgbe: fix registration order of driver and DCA nofiticationJakub Kicinski
commit f01fc1a82c2ee68726b400fadb156bd623b5f2f1 upstream. ixgbe_notify_dca cannot be called before driver registration because it expects driver's klist_devices to be allocated and initialized. While on it make sure debugfs files are removed when registration fails. Signed-off-by: Jakub Kicinski <jakub.kicinski@intel.com> Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 3.2: no debugfs support] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10EISA/PCI: Init EISA early, before PNPYinghai Lu
commit c5fb301ae83bec6892e54984e6ec765c47df8e10 upstream. Matthew reported kernels fail the pci_eisa probe and are later successful with the virtual_eisa_root_init force probe without slot0. The reason for that is: PNP probing is before pci_eisa_init gets called as pci_eisa_init is called via pci_driver. pnp 00:0f has 0xc80 - 0xc84 reserved. [ 9.700409] pnp 00:0f: [io 0x0c80-0x0c84] so eisa_probe will fail from pci_eisa_init ==>eisa_root_register ==>eisa_probe path. as force_probe is not set in pci_eisa_root, it will bail early when slot0 is not probed and initialized. Try to use subsys_initcall_sync instead, and will keep following sequence: pci_subsys_init pci_eisa_init_early pnpacpi_init/isapnp_init After this patch EISA can be initialized properly, and PNP overlapping resource will not be reserved. [ 10.104434] system 00:0f: [io 0x0c80-0x0c84] could not be reserved Reported-by: Matthew Whitehead <mwhitehe@redhat.com> Tested-by: Matthew Whitehead <mwhitehe@redhat.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10spi/mpc512x-psc: optionally keep PSC SS asserted across xfer segmenstsAnatolij Gustschin
commit 1ad849aee5f53353ed88d9cd3d68a51b03a7d44f upstream. Some SPI slave devices require asserted chip select signal across multiple transfer segments of an SPI message. Currently the driver always de-asserts the internal SS signal for every single transfer segment of the message and ignores the 'cs_change' flag of the transfer description. Disable the internal chip select (SS) only if this is needed and indicated by the 'cs_change' flag. Without this change, each partial transfer of a surrounding multi-part SPI transaction might erroneously change the SS signal, which might prevent slaves from answering the request that was sent in a previous transfer segment because the transaction could be considered aborted (SS was de-asserted before reading the response). Reported-by: Gerhard Sittig <gerhard.sittig@ifm.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10virtio: console: add locking around c_ovq operationsAmit Shah
commit 9ba5c80b1aea8648a3efe5f22dc1f7cacdfbeeb8 upstream. When multiple ovq operations are being performed (lots of open/close operations on virtio_console fds), the __send_control_msg() function can get confused without locking. A simple recipe to cause badness is: * create a QEMU VM with two virtio-serial ports * in the guest, do while true;do echo abc >/dev/vport0p1;done while true;do echo edf >/dev/vport0p2;done In one run, this caused a panic in __send_control_msg(). In another, I got virtio_console virtio0: control-o:id 0 is not a head! This also results repeated messages similar to these on the host: qemu-kvm: virtio-serial-bus: Unexpected port id 478762112 for device virtio-serial-bus.0 qemu-kvm: virtio-serial-bus: Unexpected port id 478762368 for device virtio-serial-bus.0 Reported-by: FuXiangChun <xfu@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Reviewed-by: Asias He <asias@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10virtio: console: rename cvq_lock to c_ivq_lockAmit Shah
commit 165b1b8bbc17c9469b053bab78b11b7cbce6d161 upstream. The cvq_lock was taken for the c_ivq. Rename the lock to make that obvious. We'll also add a lock around the c_ovq in the next commit, so there's no ambiguity. Signed-off-by: Amit Shah <amit.shah@redhat.com> Reviewed-by: Asias He <asias@redhat.com> Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> [bwh: Backported to 3.2: - Adjust context - Drop change to virtcons_restore()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10usb: ftdi_sio: Add support for Mitsubishi FX-USB-AW/-BDKonstantin Holoborodko
commit 482b0b5d82bd916cc0c55a2abf65bdc69023b843 upstream. It enhances the driver for FTDI-based USB serial adapters to recognize Mitsubishi Electric Corp. USB/RS422 Converters as FT232BM chips and support them. https://search.meau.com/?q=FX-USB-AW Signed-off-by: Konstantin Holoborodko <klh.kernel@gmail.com> Tested-by: Konstantin Holoborodko <klh.kernel@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10tg3: fix length overflow in VPD firmware parsingKees Cook
commit 715230a44310a8cf66fbfb5a46f9a62a9b2de424 upstream. Commit 184b89044fb6e2a74611dafa69b1dce0d98612c6 ("tg3: Use VPD fw version when present") introduced VPD parsing that contained a potential length overflow. Limit the hardware's reported firmware string length (max 255 bytes) to stay inside the driver's firmware string length (32 bytes). On overflow, truncate the formatted firmware string instead of potentially overwriting portions of the tg3 struct. http://cansecwest.com/slides/2013/PrivateCore%20CSW%202013.pdf Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Oded Horovitz <oded@privatecore.com> Reported-by: Brad Spengler <spender@grsecurity.net> Cc: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10b43: A fix for DMA transmission sequence errorsIestyn C. Elfick
commit b251412db99ccd4495ce372fec7daee27bf06923 upstream. Intermittently, b43 will report "Out of order TX status report on DMA ring". When this happens, the driver must be reset before communication can resume. The cause of the problem is believed to be an error in the closed-source firmware; however, all versions of the firmware are affected. This change uses the observation that the expected status is always 2 less than the observed value, and supplies a fake status report to skip one header/data pair. Not all devices suffer from this problem, but it can occur several times per second under heavy load. As each occurence kills the unmodified driver, this patch makes if possible for the affected devices to function. The patch logs only the first instance of the reset operation to prevent spamming the logs. Tested-by: Chris Vine <chris@cvine.freeserve.co.uk> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10can: sja1000: fix define conflict on SHMarc Kleine-Budde
commit f901b6bc404b67d96eca739857c097e022727b71 upstream. Thias patch fixes a define conflict between the SH architecture and the sja1000 driver: drivers/net/can/sja1000/sja1000.h:59:0: warning: "REG_SR" redefined [enabled by default] arch/sh/include/asm/ptrace_32.h:25:0: note: this is the location of the previous definition A SJA1000_ prefix is added to the offending sja1000 define only, to make a minimal patch suited for stable. A later patch will add a SJA1000_ prefix to all defines in sja1000.h. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10iommu/amd: Make sure dma_ops are set for hotplug devicesJoerg Roedel
commit c2a2876e863356b092967ea62bebdb4dd663af80 upstream. There is a bug introduced with commit 27c2127 that causes devices which are hot unplugged and then hot-replugged to not have per-device dma_ops set. This causes these devices to not function correctly. Fixed with this patch. Reported-by: Andreas Degert <andreas.degert@googlemail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10vt: synchronize_rcu() under spinlock is not nice...Al Viro
commit e8cd81693bbbb15db57d3c9aa7dd90eda4842874 upstream. vcs_poll_data_free() calls unregister_vt_notifier(), which calls atomic_notifier_chain_unregister(), which calls synchronize_rcu(). Do it *after* we'd dropped ->f_lock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10staging: comedi: s626: fix continuous acquisitionIan Abbott
commit e4317ce877a31dbb9d96375391c1c4ad2210d637 upstream. For the s626 driver, there is a bug in the handling of asynchronous commands on the AI subdevice when the stop source is `TRIG_NONE`. The command should run continuously until cancelled, but the interrupt handler stops the command running after the first scan. The command set-up function `s626_ai_cmd()` contains this code: switch (cmd->stop_src) { case TRIG_COUNT: /* data arrives as one packet */ devpriv->ai_sample_count = cmd->stop_arg; devpriv->ai_continous = 0; break; case TRIG_NONE: /* continous acquisition */ devpriv->ai_continous = 1; devpriv->ai_sample_count = 0; break; } The interrupt handler `s626_irq_handler()` contains this code: if (!(devpriv->ai_continous)) devpriv->ai_sample_count--; if (devpriv->ai_sample_count <= 0) { devpriv->ai_cmd_running = 0; /* ... */ } So `devpriv->ai_sample_count` is only decremented for the `TRIG_COUNT` case, but `devpriv->ai_cmd_running` is set to 0 (and the command stopped) regardless. Fix this in `s626_ai_cmd()` by setting `devpriv->ai_sample_count = 1` for the `TRIG_NONE` case. The interrupt handler will not decrement it so it will remain greater than 0 and the check for stopping the acquisition will fail. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10usb: xhci: Fix TRB transfer length macro used for Event TRB.Vivek Gautam
commit 1c11a172cb30492f5f6a82c6e118fdcd9946c34f upstream. Use proper macro while extracting TRB transfer length from Transfer event TRBs. Adding a macro EVENT_TRB_LEN (bits 0:23) for the same, and use it instead of TRB_LEN (bits 0:16) in case of event TRBs. This patch should be backported to kernels as old as 2.6.31, that contain the commit b10de142119a676552df3f0d2e3a9d647036c26a "USB: xhci: Bulk transfer support". This patch will have issues applying to older kernels. Signed-off-by: Vivek gautam <gautam.vivek@samsung.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10IPoIB: Fix send lockup due to missed TX completionMike Marciniszyn
commit 1ee9e2aa7b31427303466776f455d43e5e3c9275 upstream. Commit f0dc117abdfa ("IPoIB: Fix TX queue lockup with mixed UD/CM traffic") attempts to solve an issue where unprocessed UD send completions can deadlock the netdev. The patch doesn't fully resolve the issue because if more than half the tx_outstanding's were UD and all of the destinations are RC reachable, arming the CQ doesn't solve the issue. This patch uses the IB_CQ_REPORT_MISSED_EVENTS on the ib_req_notify_cq(). If the rc is above 0, the UD send cq completion callback is called directly to re-arm the send completion timer. This issue is seen in very large parallel filesystem deployments and the patch has been shown to correct the issue. Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10xen-blkback: fix dispatch_rw_block_io() error pathJan Beulich
commit 0e5e098ac22dae38f957e951b70d3cf73beff0f7 upstream. Commit 7708992 ("xen/blkback: Seperate the bio allocation and the bio submission") consolidated the pendcnt updates to just a single write, neglecting the fact that the error path relied on it getting set to 1 up front (such that the decrement in __end_block_io_op() would actually drop the count to zero, triggering the necessary cleanup actions). Also remove a misleading and a stale (after said commit) comment. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10rtlwifi: usb: add missing freeing of skbuffJussi Kivilinna
commit 36ef0b473fbf43d5db23eea4616cc1d18cec245f upstream. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10ath9k_hw: revert chainmask to user configuration after calibrationFelix Fietkau
commit 74632d11a133b5baf6b9d622dd19d2f944d93d94 upstream. The commit 'ath9k_hw: fix calibration issues on chainmask that don't include chain 0' changed the hardware chainmask to the chip chainmask for the duration of the calibration, but the revert to user configuration in the reset path runs too early. That causes some issues with limiting the number of antennas (including spurious failure in hardware-generated packets). Fix this by reverting the chainmask after the essential parts of the calibration that need the workaround, and before NF calibration is run. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Reported-by: Wojciech Dubowik <Wojciech.Dubowik@neratec.com> Tested-by: Wojciech Dubowik <Wojciech.Dubowik@neratec.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for Dell[QCA 0cf3:817a]Ming Lei
commit ebaf5795ef57a70a042ea259448a465024e2821d upstream. Add support for the AR9462 chip T: Bus=03 Lev=01 Prnt=01 Port=08 Cnt=01 Dev#= 5 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=0cf3 ProdID=817a Rev= 0.02 C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms Cc: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10HID: usbhid: fix build problemJiri Kosina
commit 570637dc8eeb2faba06228d497ff40bb019bcc93 upstream. Fix build problem caused by typo introduced by 620ae90ed8 ("HID: usbhid: quirk for MSI GX680R led panel"). Reported-by: fengguang.wu@intel.com Signed-off-by: Jiri Kosina <jkosina@suse.cz> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10HID: usbhid: quirk for MSI GX680R led panelJosh Boyer
commit 620ae90ed8ca8b6e40cb9e10279b4f5ef9f0ab81 upstream. This keyboard backlight device causes a 10 second delay to boot. Add it to the quirk list with HID_QUIRK_NO_INIT_REPORTS. This fixes Red Hat bugzilla https://bugzilla.redhat.com/show_bug.cgi?id=907221 Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10HID: usbhid: quirk for Realtek Multi-card readerJosh Boyer
commit 3d464d9b71ef2f2b40a4bc9dcf06794fd1be9d12 upstream. This device needs to be added to the quirks list with HID_QUIRK_NO_INIT_REPORTS, otherwise it causes 10 seconds timeout during report initialization. This fixes Red Hat bugzilla https://bugzilla.redhat.com/show_bug.cgi?id=806587 Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10tty: atmel_serial_probe(): index of atmel_ports[] fixPawel Wieczorkiewicz
commit 503bded92da283b2f31d87e054c4c6d30c3c2340 upstream. Index of atmel_ports[ATMEL_MAX_UART] should be smaller than ATMEL_MAX_UART. Signed-off-by: Pawel Wieczorkiewicz <wpawel@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for Dell[QCA 0cf3:0036]Ming Lei
commit d66629c1325399cf080ba8b2fb086c10e5439cdd upstream. Add support for the AR9462 chip T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 3 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=0cf3 ProdID=0036 Rev= 0.02 C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=01 I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms Cc: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Device 0cf3:3008 should map AR 3012Sunguk Lee
commit 94a32d10f47b637ae24b78b1ddc7ef0e8396fda4 upstream. T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=0cf3 ProdID=3008 Rev= 0.01 S: Manufacturer=Atheros Communications S: Product=Bluetooth USB Host Controller S: SerialNumber=Alaska Day 2006 C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms Signed-off-by: Sunguk Lee <d3m3vilurr@gmail.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for atheros 04ca:3004 device to ath3kJosh Boyer
commit 3f63c340a72f2872a9362245cb2e03f3d2bb73a6 upstream. Yet another version of the atheros bluetooth chipset T: Bus=01 Lev=02 Prnt=02 Port=03 Cnt=01 Dev#= 3 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=04ca ProdID=3004 Rev=00.01 S: Manufacturer=Atheros Communications S: Product=Bluetooth USB Host Controller S: SerialNumber=Alaska Day 2006 C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb This resolves https://bugzilla.redhat.com/show_bug.cgi?id=844750 Reported-by: niktr@mail.ru Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth device 04ca:3008 should use ath3kSergio Cambra
commit f4d6f7dce71a5da93da50272ff1670bf2f1146b1 upstream. Output of /sys/kernel/debug/usb/devices T: Bus=03 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=04ca ProdID=3008 Rev= 0.02 C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms Signed-off-by: Sergio Cambra <sergio@programatica.es> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for Foxconn / Hon Hai [0489:e056]AceLan Kao
commit 2582d529c44d12502a700f1c3db062b9f44679bc upstream. Add support for the AR9462 chip T: Bus=01 Lev=02 Prnt=02 Port=05 Cnt=01 Dev#= 4 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=0489 ProdID=e056 Rev=00.01 C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for Foxconn / Hon Hai [0489:e04e]AceLan Kao
commit 3a61eda81ebcfc006ebb1496764299d53e5bf67f upstream. Add support for the AR9462 chip T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=0489 ProdID=e04e Rev=00.02 C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for GC-WB300D PCIe [04ca:3006] to ath3k.Daniel Schaal
commit 2c262b2a5235b7f5b18d4d58394511f76371d7cb upstream. T: Bus=02 Lev=02 Prnt=02 Port=06 Cnt=01 Dev#= 4 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=04ca ProdID=3006 Rev= 0.02 C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms Signed-off-by: Daniel Schaal <farbing@web.de> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10Bluetooth: Add support for IMC Networks [13d3:3393]AceLan Kao
commit eed307e290b96636def331375e065aca43f9069a upstream. Add support for the AR9462 chip T: Bus=02 Lev=02 Prnt=02 Port=04 Cnt=01 Dev#= 3 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=13d3 ProdID=3393 Rev=00.01 C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I: If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27efivars: pstore: Do not check size when erasing variableBen Hutchings
In 3.2, unlike mainline, efi_pstore_erase() calls efi_pstore_write() with a size of 0, as the underlying EFI interface treats a size of 0 as meaning deletion. This was not taken into account in my backport of commit d80a361d779a 'efi_pstore: Check remaining space with QueryVariableInfo() before writing data'. The size check should be omitted when erasing. Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27KMS: fix EDID detailed timing frame rateTorsten Duwe
commit c19b3b0f6eed552952845e4ad908dba2113d67b4 upstream. When KMS has parsed an EDID "detailed timing", it leaves the frame rate zeroed. Consecutive (debug-) output of that mode thus yields 0 for vsync. This simple fix also speeds up future invocations of drm_mode_vrefresh(). While it is debatable whether this qualifies as a -stable fix I'd apply it for consistency's sake; drm_helper_probe_single_connector_modes() does the same thing already for all probed modes. Signed-off-by: Torsten Duwe <duwe@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27KMS: fix EDID detailed timing vsync parsingTorsten Duwe
commit 16dad1d743d31a104a849c8944e6b9eb479f6cd7 upstream. EDID spreads some values across multiple bytes; bit-fiddling is needed to retrieve these. The current code to parse "detailed timings" has a cut&paste error that results in a vsync offset of at most 15 lines instead of 63. See http://en.wikipedia.org/wiki/EDID and in the "EDID Detailed Timing Descriptor" see bytes 10+11 show why that needs to be a left shift. Signed-off-by: Torsten Duwe <duwe@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27i2c: tegra: check the clk_prepare_enable() return valueLaxman Dewangan
commit 132c803f7b70b17322579f6f4f3f65cf68e55135 upstream. NVIDIA's Tegra SoC allows read/write of controller register only if controller clock is enabled. System hangs if read/write happens to registers without enabling clock. clk_prepare_enable() can be fail due to unknown reason and hence adding check for return value of this function. If this function success then only access register otherwise return to caller with error. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> [bwh: Backported to 3.2: - Adjust context - Keep calling clk_enable() directly] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27USB: serial: fix interface refcountingJohan Hovold
commit d7971051e4df825e0bc11b995e87bfe86355b8e5 upstream. Make sure the interface is not released before our serial device. Note that drivers are still not allowed to access the interface in any way that may interfere with another driver that may have gotten bound to the same interface after disconnect returns. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27USB: io_ti: fix get_icount for two port adaptersJohan Hovold
commit 5492bf3d5655b4954164f69c02955a7fca267611 upstream. Add missing get_icount field to two-port driver. The two-port driver was not updated when switching to the new icount interface in commit 0bca1b913aff ("tty: Convert the USB drivers to the new icount interface"). Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27USB: garmin_gps: fix memory leak on disconnectJohan Hovold
commit 618aa1068df29c37a58045fe940f9106664153fd upstream. Remove bogus disconnect test introduced by 95bef012e ("USB: more serial drivers writing after disconnect") which prevented queued data from being freed on disconnect. The possible IO it was supposed to prevent is long gone. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27efivars: Handle duplicate names from get_next_variable()Matt Fleming
commit e971318bbed610e28bb3fde9d548e6aaf0a6b02e upstream. Some firmware exhibits a bug where the same VariableName and VendorGuid values are returned on multiple invocations of GetNextVariableName(). See, https://bugzilla.kernel.org/show_bug.cgi?id=47631 As a consequence of such a bug, Andre reports hitting the following WARN_ON() in the sysfs code after updating the BIOS on his, "Gigabyte Technology Co., Ltd. To be filled by O.E.M./Z77X-UD3H, BIOS F19e 11/21/2012)" machine, [ 0.581554] EFI Variables Facility v0.08 2004-May-17 [ 0.584914] ------------[ cut here ]------------ [ 0.585639] WARNING: at /home/andre/linux/fs/sysfs/dir.c:536 sysfs_add_one+0xd4/0x100() [ 0.586381] Hardware name: To be filled by O.E.M. [ 0.587123] sysfs: cannot create duplicate filename '/firmware/efi/vars/SbAslBufferPtrVar-01f33c25-764d-43ea-aeea-6b5a41f3f3e8' [ 0.588694] Modules linked in: [ 0.589484] Pid: 1, comm: swapper/0 Not tainted 3.8.0+ #7 [ 0.590280] Call Trace: [ 0.591066] [<ffffffff81208954>] ? sysfs_add_one+0xd4/0x100 [ 0.591861] [<ffffffff810587bf>] warn_slowpath_common+0x7f/0xc0 [ 0.592650] [<ffffffff810588bc>] warn_slowpath_fmt+0x4c/0x50 [ 0.593429] [<ffffffff8134dd85>] ? strlcat+0x65/0x80 [ 0.594203] [<ffffffff81208954>] sysfs_add_one+0xd4/0x100 [ 0.594979] [<ffffffff81208b78>] create_dir+0x78/0xd0 [ 0.595753] [<ffffffff81208ec6>] sysfs_create_dir+0x86/0xe0 [ 0.596532] [<ffffffff81347e4c>] kobject_add_internal+0x9c/0x220 [ 0.597310] [<ffffffff81348307>] kobject_init_and_add+0x67/0x90 [ 0.598083] [<ffffffff81584a71>] ? efivar_create_sysfs_entry+0x61/0x1c0 [ 0.598859] [<ffffffff81584b2b>] efivar_create_sysfs_entry+0x11b/0x1c0 [ 0.599631] [<ffffffff8158517e>] register_efivars+0xde/0x420 [ 0.600395] [<ffffffff81d430a7>] ? edd_init+0x2f5/0x2f5 [ 0.601150] [<ffffffff81d4315f>] efivars_init+0xb8/0x104 [ 0.601903] [<ffffffff8100215a>] do_one_initcall+0x12a/0x180 [ 0.602659] [<ffffffff81d05d80>] kernel_init_freeable+0x13e/0x1c6 [ 0.603418] [<ffffffff81d05586>] ? loglevel+0x31/0x31 [ 0.604183] [<ffffffff816a6530>] ? rest_init+0x80/0x80 [ 0.604936] [<ffffffff816a653e>] kernel_init+0xe/0xf0 [ 0.605681] [<ffffffff816ce7ec>] ret_from_fork+0x7c/0xb0 [ 0.606414] [<ffffffff816a6530>] ? rest_init+0x80/0x80 [ 0.607143] ---[ end trace 1609741ab737eb29 ]--- There's not much we can do to work around and keep traversing the variable list once we hit this firmware bug. Our only solution is to terminate the loop because, as Lingzhu reports, some machines get stuck when they encounter duplicate names, > I had an IBM System x3100 M4 and x3850 X5 on which kernel would > get stuck in infinite loop creating duplicate sysfs files because, > for some reason, there are several duplicate boot entries in nvram > getting GetNextVariableName into a circle of iteration (with > period > 2). Also disable the workqueue, as efivar_update_sysfs_entries() uses GetNextVariableName() to figure out which variables have been created since the last iteration. That algorithm isn't going to work if GetNextVariableName() returns duplicates. Note that we don't disable EFI variable creation completely on the affected machines, it's just that any pstore dump-* files won't appear in sysfs until the next boot. Reported-by: Andre Heider <a.heider@gmail.com> Reported-by: Lingzhu Xiang <lxiang@redhat.com> Tested-by: Lingzhu Xiang <lxiang@redhat.com> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> [bwh: Backported to 3.2: reason is not checked in efi_pstore_write()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27efivars: explicitly calculate length of VariableNameMatt Fleming
commit ec50bd32f1672d38ddce10fb1841cbfda89cfe9a upstream. It's not wise to assume VariableNameSize represents the length of VariableName, as not all firmware updates VariableNameSize in the same way (some don't update it at all if EFI_SUCCESS is returned). There are even implementations out there that update VariableNameSize with values that are both larger than the string returned in VariableName and smaller than the buffer passed to GetNextVariableName(), which resulted in the following bug report from Michael Schroeder, > On HP z220 system (firmware version 1.54), some EFI variables are > incorrectly named : > > ls -d /sys/firmware/efi/vars/*8be4d* | grep -v -- -8be returns > /sys/firmware/efi/vars/dbxDefault-pport8be4df61-93ca-11d2-aa0d-00e098032b8c > /sys/firmware/efi/vars/KEKDefault-pport8be4df61-93ca-11d2-aa0d-00e098032b8c > /sys/firmware/efi/vars/SecureBoot-pport8be4df61-93ca-11d2-aa0d-00e098032b8c > /sys/firmware/efi/vars/SetupMode-Information8be4df61-93ca-11d2-aa0d-00e098032b8c The issue here is that because we blindly use VariableNameSize without verifying its value, we can potentially read garbage values from the buffer containing VariableName if VariableNameSize is larger than the length of VariableName. Since VariableName is a string, we can calculate its size by searching for the terminating NULL character. Reported-by: Frederic Crozat <fcrozat@suse.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Michael Schroeder <mls@suse.com> Cc: Lee, Chun-Yi <jlee@suse.com> Cc: Lingzhu Xiang <lxiang@redhat.com> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27efi_pstore: Introducing workqueue updating sysfsSeiji Aguchi
commit a93bc0c6e07ed9bac44700280e65e2945d864fd4 upstream. [Problem] efi_pstore creates sysfs entries, which enable users to access to NVRAM, in a write callback. If a kernel panic happens in an interrupt context, it may fail because it could sleep due to dynamic memory allocations during creating sysfs entries. [Patch Description] This patch removes sysfs operations from a write callback by introducing a workqueue updating sysfs entries which is scheduled after the write callback is called. Also, the workqueue is kicked in a just oops case. A system will go down in other cases such as panic, clean shutdown and emergency restart. And we don't need to create sysfs entries because there is no chance for users to access to them. efi_pstore will be robust against a kernel panic in an interrupt context with this patch. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> [bwh: Backported to 3.2: - Adjust contest - Don't check reason in efi_pstore_write(), as it is not given as a parameter - Move up declaration of __efivars] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27efivars: Fix check for CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLEBen Hutchings
commit ca0ba26fbbd2d81c43085df49ce0abfe34535a90 upstream. The 'CONFIG_' prefix is not implicit in IS_ENABLED(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-03-27efivars: Add module parameter to disable use as a pstore backendSeth Forshee
commit ec0971ba5372a4dfa753f232449d23a8fd98490e upstream. We know that with some firmware implementations writing too much data to UEFI variables can lead to bricking machines. Recent changes attempt to address this issue, but for some it may still be prudent to avoid writing large amounts of data until the solution has been proven on a wide variety of hardware. Crash dumps or other data from pstore can potentially be a large data source. Add a pstore_module parameter to efivars to allow disabling its use as a backend for pstore. Also add a config option, CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE, to allow setting the default value of this paramter to true (i.e. disabled by default). Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27efivars: Allow disabling use as a pstore backendSeth Forshee
commit ed9dc8ce7a1c8115dba9483a9b51df8b63a2e0ef upstream. Add a new option, CONFIG_EFI_VARS_PSTORE, which can be set to N to avoid using efivars as a backend to pstore, as some users may want to compile out the code completely. Set the default to Y to maintain backwards compatability, since this feature has always been enabled until now. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27dm thin: fix discard corruptionJoe Thornber
commit f046f89a99ccfd9408b94c653374ff3065c7edb3 upstream. Fix a bug in dm_btree_remove that could leave leaf values with incorrect reference counts. The effect of this was that removal of a shared block could result in the space maps thinking the block was no longer used. More concretely, if you have a thin device and a snapshot of it, sending a discard to a shared region of the thin could corrupt the snapshot. Thinp uses a 2-level nested btree to store it's mappings. This first level is indexed by thin device, and the second level by logical block. Often when we're removing an entry in this mapping tree we need to rebalance nodes, which can involve shadowing them, possibly creating a copy if the block is shared. If we do create a copy then children of that node need to have their reference counts incremented. In this way reference counts percolate down the tree as shared trees diverge. The rebalance functions were incrementing the children at the appropriate time, but they were always assuming the children were internal nodes. This meant the leaf values (in our case packed block/flags entries) were not being incremented. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> [bwh: Backported to 3.2: bump target version numbers from 1.0.1 to 1.0.2] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27usb: gadget: udc-core: fix a regression during gadget driver unbindingAlan Stern
commit 511f3c5326eabe1ece35202a404c24c0aeacc246 upstream. This patch (as1666) fixes a regression in the UDC core. The core takes care of unbinding gadget drivers, and it does the unbinding before telling the UDC driver to turn off the controller hardware. When the call to the udc_stop callback is made, the gadget no longer has a driver. The callback routine should not be invoked with a pointer to the old driver; doing so can cause problems (such as use-after-free accesses in net2280). This patch should be applied, with appropriate context changes, to all the stable kernels going back to 3.1. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Felipe Balbi <balbi@ti.com> [bwh: Backported to 3.2: adjust context, indentation] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27USB: xhci - fix bit definitions for IMAN registerDmitry Torokhov
commit f8264340e694604863255cc0276491d17c402390 upstream. According to XHCI specification (5.5.2.1) the IP is bit 0 and IE is bit 1 of IMAN register. Previously their definitions were reversed. Even though there are no ill effects being observed from the swapped definitions (because IMAN_IP is RW1C and in legacy PCI case we come in with it already set to 1 so it was clearing itself even though we were setting IMAN_IE instead of IMAN_IP), we should still correct the values. This patch should be backported to kernels as old as 2.6.36, that contain the commit 4e833c0b87a30798e67f06120cecebef6ee9644c "xhci: don't re-enable IE constantly". Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27drm/radeon/benchmark: make sure bo blit copy exists before using itAlex Deucher
commit fa8d387dc3f62062a6b4afbbb2a3438094fd8584 upstream. Fixes a segfault on asics without a blit callback. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=62239 Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> [bwh: Backported to 3.2: s/copy\.blit/copy_blit/] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27usb-storage: add unusual_devs entry for Samsung YP-Z3 mp3 playerDmitry Artamonow
commit 29f86e66428ee083aec106cca1748dc63d98ce23 upstream. Device stucks on filesystem writes, unless following quirk is passed: echo 04e8:5136:m > /sys/module/usb_storage/parameters/quirks Add corresponding entry to unusual_devs.h Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27USB: xhci: correctly enable interruptsHannes Reinecke
commit 00eed9c814cb8f281be6f0f5d8f45025dc0a97eb upstream. xhci has its own interrupt enabling routine, which will try to use MSI-X/MSI if present. So the usb core shouldn't try to enable legacy interrupts; on some machines the xhci legacy IRQ setting is invalid. v3: Be careful to not break XHCI_BROKEN_MSI workaround (by trenn) Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Oliver Neukum <oneukum@suse.de> Cc: Thomas Renninger <trenn@suse.de> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Frederik Himpe <fhimpe@vub.ac.be> Cc: David Haerdeman <david@hardeman.nu> Cc: Alan Stern <stern@rowland.harvard.edu> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Reviewed-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
