net_poll support for eHEA added
Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
The Coverity checker noted that we've already dereferenced "dev" when we
check whether it's NULL.
Since it's impossible that "dev" is NULL at this place this patch
removes the NULL check.
This is a change to remove a local hack in favour to __maybe_unused that
has been recently added.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
phy_read() returns a negative number if there's an error, but the
error-checking code in the Vitesse driver's config_intr function
triggers if phy_read() returns non-zero. Correct that.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Reduced allocation size for rx skb buffers, from 2308 bytes to
1356 per buffer.
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp>
Use constants already provided by the kernel for ethernet related lengths.
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
s/dam/dma
Change the threshold number of descriptors used to trigger CMB writes.
The vendor reports that under certain conditions this will reduce the
number of unnecessary tx interrupts and improve rx performance.
This change is lifted directly from vendor version 1.2.40.2 of the L1
driver.
The DMA engine setup contains a typo that can result in an incorrect
dmaw_block setting.
Change tpd_avail() to atl1_tpd_avail().
Fixed rare issue that 'lv1_net_start_rx_dma failed, status=-9" was shown
in dmesg. This meant restarting rx DMA had been rejected by the hypervisor.
This issue would caused if the guest os requested starting DMA when
the hypervisor thought the DMA was in progress.
The state machine for DMA status of the hypervisor would be updated
by processing interrupt in the hypervisor.
Thus we should wait for the interrupt delivery before restarting
DMA.
Removed use of netif_poll_enable() in open function.
Use net_device name for registration of irq as many network drivers do.
Removed the statistics information from private structre.
Instead, use net_device_stats in net_device structure.
Removed conditional ethtool support. Always enabled.
Removed defines no longer used.
gelic: TX descriptor handling cleanup
- Emitted return value of NETDEV_TX_LOCKED when DMA map or kick
failure.
Now it would free the skb, update drop packet statistics
and return OK. Requested from Jeff Garzik.
- Enable tx queue if number of free descriptors are more than 2
- Fixed descriptor leak if dma map for second descriptor failed
- Stopped calling xmit handler from interrupt handler in order
to recheck tx queue. Instead, call appropriate helper functions.
- Removed the embarrassing definition which was used in only one
place.
- Fixed wrong initialization of dmac_cmd_status.
Fixed the bug that calculation of the address of rx descriptor was
wrong.
The firmware should be loaded after resetting hardware during PCI probe,
besides module unload. This fixes issue with 2nd port of multiport adapter
on powerpc blades. This patch also fixes a bug that PCI resources are not
freed if dma watchdog shutdown failed. The dma watchdog poll messages
during module unload are also suppressed.
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
Signed-off-by: Milan Bag <mbag@netxen.com>
Signed-off-by: Wen Xiong <wenxiong@us.ibm.com>
Adds netif message level control to the ucc_geth driver. The level can
be set by module parameter and ethtool.
Signed-off-by: Li Yang <leoli@freescale.com>
The patch enables statistics in ucc_geth and adds ethtool support to
ucc_geth driver.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/ehca: Support small QP queues
IB/ehca: Make internal_create/destroy_qp() static
IB/ehca: Move ehca2ib_return_code() out of line
IB/ehca: Generate async event when SRQ limit reached
IB/ehca: Support large page MRs
IB/mlx4: Fix error path in create_qp_common()
mlx4_core: Change command token on timeout
IB/mthca: Change command token on timeout
IB/ipath: Remove ipath_layer dead code
IB/mlx4: Fix leaks in __mlx4_ib_modify_qp
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits)
[SCSI] libsas: make ATA functions selectable by a config option
[SCSI] bsg: unexport sg v3 helper functions
[SCSI] bsg: fix bsg_unregister_queue
[SCSI] bsg: make class backlinks
[SCSI] 3w-9xxx: add support for 9690SA
[SCSI] bsg: fix bsg_register_queue error path
[SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275.
[SCSI] libsas: fix scr_read/write users and update the libata documentation
[SCSI] mpt fusion: update Kconfig help
[SCSI] scsi_transport_sas: add destructor for bsg
[SCSI] iscsi_tcp: buggered kmalloc()
[SCSI] qla2xxx: Update version number to 8.02.00-k2.
[SCSI] qla2xxx: Add ISP25XX support.
[SCSI] qla2xxx: Use pci_try_set_mwi().
[SCSI] qla2xxx: Use PCI-X/PCI-Express read control interfaces.
[SCSI] qla2xxx: Re-factor isp_operations to static structures.
[SCSI] qla2xxx: Validate mid-layer 'underflow' during check-condition handling.
[SCSI] qla2xxx: Correct setting of 'current' and 'supported' speeds during FDMI registration.
[SCSI] qla2xxx: Generalize iIDMA support.
[SCSI] qla2xxx: Generalize FW-Interface-2 support.
Not everyone wants libsas automatically to pull in libata. This patch
makes the behaviour configurable, so you can build libsas with or
without ATA support.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (60 commits)
[ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410
[ARM] 4523/1: S3C: Remove FIFO_MAX from uncompression headers
[ARM] 4522/1: S3C: split include/asm-arm/arch/memory.h
[ARM] 4521/2: S3C: Reorganise VA mapping headers
[ARM] 4520/1: S3C: Remove old VA values from static map
[ARM] 4519/1: S3C: split S3C2400 values out of S3C24XX map.h
[ARM] 4518/1: S3C: Rename watchdog configuration options
[ARM] 4517/1: S3C: Fix debug macros for ARM926 output
[ARM] 4516/1: S3C: Fix uncompressor serial output for ARM926
[ARM] 4515/1: S3C: Move uncompress code to plat-s3c
[ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UART
[ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT
[ARM] 4512/1: S3C: rename the debug macros for per-cpu updates
[ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU support
[ARM] 4510/1: S3C: split debug-macro support into plat-s3c
[ARM] 4509/1: S3C: Create initial arch/arm/plat-s3c
[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3c
[ARM] 4461/1: MXC platform and i.MX31ADS core support
[ARM] 4507/1: pxa2xx clock_event_device
[ARM] 4497/1: Only allow safe cache configurations on ARMv6 and later
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds:
leds: Convert from struct class_device to struct device
leds: leds-gpio for ngw100
leds: Add warning printks in error paths
leds: Fix trigger unregister_simple if register_simple fails
leds: Use menuconfig objects II - LED
leds: Teach leds-gpio to handle timer-unsafe GPIOs
leds: Add generic GPIO LED driver
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight:
leds: cr_bllcd.c: build fix
backlight: Convert from struct class_device to struct device
backlight: Fix order of Kconfig entries
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
[POWERPC] Clean up duplicate includes in drivers/macintosh/
[POWERPC] Quiet section mismatch warning on pcibios_setup
[POWERPC] init and exit markings for hvc_iseries
[POWERPC] Quiet section mismatch in hvc_rtas.c
[POWERPC] Constify of_platform_driver match_table
[POWERPC] hvcs: Make some things static and const
[POWERPC] Constify of_platform_driver name
[POWERPC] MPIC protected sources
[POWERPC] of_detach_node()'s device node argument cannot be const
[POWERPC] Fix ARCH=ppc builds
[POWERPC] mv64x60: Use mutex instead of semaphore
[POWERPC] Allow smp_call_function_single() to current cpu
[POWERPC] Allow exec faults on readable areas on classic 32-bit PowerPC
[POWERPC] Fix future firmware feature fixups function failure
[POWERPC] fix showing xmon help
[POWERPC] Make xmon_write accept a const buffer
[POWERPC] Fix misspelled "CONFIG_CHECK_CACHE_COHERENCY" Kconfig option.
[POWERPC] cell: CONFIG_SPE_BASE is a typo
Found by Sebastian Siewior and randconfig.
Signed-off-by: Avi Kivity <avi@qumranet.com>
'pxa' and 's3c' into devel
This patch moves items of the s3c24xx support into
a new plat-s3c directory for items that use the
s3c24xx support but are not directly s3c24xx
compatible, such as the s3c2400 and s3c6400.
git mv commands:
git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h
git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h
git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h
git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h
git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h
git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h
git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h
git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
WARNING: vmlinux.o(.text+0x2066f0): Section mismatch: reference to .init.text:.add_preferred_console (between '.hvc_rtas_console_init' and '.hvc_beat_put_chars')
Build fix for cr_bllcd.c
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
The file name is the signature, such as DSDT,
and the contents are the binary table image.
Some tables, such as the SSDT, can have multiple instances.
If just one, the file is SSDT, but if 3 instances,
for example, it will be SSDT1, SSDT2, SSDT3
All static tables (besides teh RSDP and RSDT themselves
are exported. Dynamic tables, such as SSDT op-regions that
are not declared in the RSDT, will be added in a subsequent patch.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Documentation/feature-removal-schedule.txt
