path: root/drivers
2010-10-11ath9k: add compile time checking for the size of the channel listFelix Fietkau
This prevents random memory corruption if the number of channels ever gets changed without an update to the internal channel array size. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-11ath5k: use the common cycle counter / listen time implementationFelix Fietkau
Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-11ath9k_hw: move the cycle counter tracking to athFelix Fietkau
Instead of keeping track of wraparound, clear the counters on every access and keep separate deltas for ANI and later survey use. Also moves the function for calculating the 'listen time' for ANI Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-11ath5k: store the clock rate in common data on channel changesFelix Fietkau
2010-10-11ath9k_hw: store the clock rate in common data on channel changesFelix Fietkau
2010-10-11ath5k: Adjust opmode when interfaces are removed.Ben Greear
Otherwise, if there is an AP and a STATION, and AP is removed, the NIC will not revert back to STATION mode. Reported-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-11ath5k: Print out opmode in debugfs.Ben Greear
Helps debug multi-VIF scenarios. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-11Merge branch 'wireless-next' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/luca/wl12xx
2010-10-08wl1271: sdio: add suspend/resume supportOhad Ben-Cohen
Add required suspend/resume support to prevent the SDIO core from removing our card completely during system suspend. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-10-08wl1271: sdio: enable runtime PMOhad Ben-Cohen
Enable runtime PM for the wl1271 SDIO device. We request power whenever the WLAN interface is brought up, and release it after the WLAN interface is taken down. As a result, power is released immediately after probe returns, since at that point power has not been explicitly requested yet (i.e. the WLAN interface is still down). Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Tested-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-10-07iwlagn: add temperature offset calib for 6000g2Shanyu Zhao
6000g2 devices need to have temperature offset calibration. The runtime uCode needs to receive the calibration results just like BB and LO calibration. To do this, driver reads the offset value from NVM and send it to uCode after runtime uCode is alive. Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlagn: fix default calibration table sizeShanyu Zhao
iwlagn driver uses the IWL_MAX_STANDARD_PHY_CALIBRATE_TBL_SIZE as the chain noise reset calibration index and IWL_MAX_STANDARD_PHY_CALIBRATE_TBL_SIZE+1 as the chain noise gain calibration index, if not specified by the TLV value in the new firmware format. However, this is broken if we need to add more calibrations like the temperature offset calibration because we increased IWL_MAX_STANDARD_PHY_CALIBRATE_TBL_SIZE by 1. To fix this issue, define IWL_DEFAULT_STANDARD_PHY_CALIBRATE_TBL_SIZE and use it as the calibration index instead. We still keep the IWL_MAX_STANDARD_PHY_CALIBRATE_TBL_SIZE as a sanity check for the TLV value given by ucode. Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlagn: no version check for experimental uCodeWey-Yi Guy
For experimental uCode, it should work with the driver if driver has experimental uCode support option enabled; remove the API version checking. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: fix dual-mode scanningJohannes Berg
The recent scanning code shuffle accidentally moved the SCAN_HW bit setting _after_ the PAN parameters are modified, which means that they don't take the scan into account -- fix that. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove iwl_check_bitsJohannes Berg
The function is used exactly once, and the caller doesn't even need the special check, it can be simplified to a simple bit check. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: clean up declarationsJohannes Berg
A number of declarations in iwl-core.h should be in agn specific files, and also rename the iwl-calib.h file to iwl-agn-calib.h to better reflect that it belongs to agn. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove apm_ops.stopJohannes Berg
Since all devices share the same operation here, there's no need to call it indirectly. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove set_pwr_src operationJohannes Berg
The set_pwr_src operation is only ever used from within the same sub-driver that it is declared in, so it can just be called directly instead of being an operation. Also, it is never called to set the power source to V_aux, so change the two functions accordingly (but keep the V_aux code for documentation purposes in a comment). Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove set_ct_kill operationJohannes Berg
This operation is only ever called from set_hw_params, which is also already based on the config/ops, so that there's no need to have a separate set_ct_kill op and we can just call the right ct_threshold function. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move iwl_dump_fh to agnJohannes Berg
The iwl_dump_fh function is only used by the agn module, so it can be there instead of being exported by the core. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move iwl_dump_csr to agnJohannes Berg
The iwl_dump_csr function is only used within the agn module, so it can be moved there instead of being exported by the core. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move iwl_toggle_rx_ant to agnJohannes Berg
The iwl_toggle_tx_ant function is only used by agn code, so it can be moved into the agn module instead of being exported from the core. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove agn rates info thereJohannes Berg
Code and data related to agn bitrates can be part of the agn module rather than being in the core module. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove spurious exportsJohannes Berg
A number of exports, especially related to thermal throttling, are unnecessary because the code lives in the same module that it is used in, so remove them. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move tx fail code to agnJohannes Berg
The code to print out TX failure reasons is AGN specific, so it can be in the AGN module. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move agn specific station code thereJohannes Berg
By duplicating a little bit of code between 3945 and agn, we can move a lot of code into an agn specific station management file and thus reduce the amount of code in core that is dead to 3945. before: text data bss dec hex filename 212886 3872 96 216854 34f16 iwlcore.ko 620542 10448 304 631294 9a1fe iwlagn.ko 314013 3264 196 317473 4d821 iwl3945.ko after: text data bss dec hex filename 202857 3872 92 206821 327e5 iwlcore.ko 629102 10448 308 639858 9c372 iwlagn.ko 314240 3264 196 317700 4d904 iwl3945.ko delta: -10029 iwlcore.ko 8560 iwlagn.ko 227 iwl3945.ko so it's a net win even if you have both loaded, likely because a lot of EXPORT_SYMBOLs go away. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: remove verify_signature eeprom operationJohannes Berg
All drivers share the same implementation, so there's no need to call this via a function pointer nor to export it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: rename iwl_mac_beacon_updateJohannes Berg
Rename iwl_mac_beacon_update to iwlcore_beacon_update and make the calling convention a bit different. The old name with _mac_ indicated that it was a mac80211 callback, but that's no longer true. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: move chain settings to agnJohannes Berg
The core module doesn't need to carry around the code for chain settings that is used for HT drivers (agn) only. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwl3945: use iwl3945_commit_rxonJohannes Berg
There's no need to go via the indirect function call from within the 3945 subdriver. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlwifi: introduce post_scan hookJohannes Berg
The different drivers need to do different things after a scan, so create a post_scan hook to allow them to do this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07iwlagn: rename iwl_commit_rxonJohannes Berg
iwl_commit_rxon really should be named iwlagn_commit_rxon, so rename it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-07ath9k_hw: Fix hw reset failure with HTC driverRajkumar Manoharan
The following commit removed DISABLE_REGWRITE_BUFFER ops. The unnecessary REGWRITE_BUFFER_FLUSH was not removed properly which is causing failure on hw reset. Author: Felix Fietkau <nbd@openwrt.org> Date: Tue Oct 5 12:03:42 2010 +0200 ath9k_hw: clean up register write buffering Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-07wl1271: Support FEM autodetectionJuuso Oikarinen
In the NVS/INI-parameters for the driver/firmware there is the FEM (front end module) selection option, which may configure the hardware FEM via autodetection or manual selection. So far, there has been support for manual selection only. Add support for FEM autodetection. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-07Merge branch 'wireless-next-2.6' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
2010-10-07Revert "rtl8180: use NAPI for bottom-half processing"John W. Linville
This reverts commit 030725d2c7c1fafec7ede618647bf30ed79601f0. This commit relies on commit 5ed3bc7288487bd4f891f420a07319e0b538b4fe ("mac80211: use netif_receive_skb in ieee80211_tx_status callpath") Unfortunately not all drivers are calling ieee80211_tx_status from a compatible context, so that commit needs to be reverted in 2.6.36. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06iwlagn: add define for MODULE_FIRMWAREWey-Yi Guy
Adding MODULE_FIRMWARE define for 130 series of devices Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-06iwlagn: fix module firmware name for 130 series deviceWey-Yi Guy
130 series device should use firmware name with 130 in it. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-10-06Revert "iwlwifi: do not perferm force reset while doing scan"Stanislaw Gruszka
This reverts commit 7acc7c683a747689aaaaad4fce1683fc3f85e552. It was applied to avoid possible warning in ieee80211_restart_hw, however reason of the warning were races in mac80211, currently hopefully fixed. Not reseting device when performing scan is bad for two reasons. When forcing reset from iwl_check_stuck_queue(), in case of fail, reset will be repeated until scan finish. But since firmware is in bad shape, scan only finish after scan_check work (about 7s). So we will delay the reset, what is not good behaviour. When forcing reset from iwl_recover_from_statistics(), we will not repeat the reset, so we will not perform reset at all when needed. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06b43: N-PHY: don't duplicate setting channel in shared memoryRafał Miłecki
It's already set in PHY common code. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06b43: define B43_SHM_SH_CHAN_40MHZRafał Miłecki
2010-10-06b43: N-PHY: simplify channel switchingRafał Miłecki
2010-10-06cfg80211/mac80211: allow per-station GTKsJohannes Berg
This adds API to allow adding per-station GTKs, updates mac80211 to support it, and also allows drivers to remove a key from hwaccel again when this may be necessary due to multiple GTKs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k: Introduce a wrapper for power save disable.Senthil Balasubramanian
Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k: remove unnecessary power save flags.Senthil Balasubramanian
drv_config callback is called only after the ack for the nullframe is received and so driver need not do anything special for this. So remove NULLFUNC_COMPLETED, PS_ENABLED flags and bf_isnullfunc flags from ath9k as mac80211 already handles them properly. Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k_hw: merge ath9k_hw_ani_monitor_old and ath9k_hw_ani_monitor_newFelix Fietkau
After the last rounds of cleanup, these functions are now functionally equivalent and can thus be merged. Also get rid of some excessive (and redundant) debug messages. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k_hw: remove function pointer abstraction for internal ANI opsFelix Fietkau
The code gets more concise and readable when making the new ANI functions fall back to the old ones if ANI v2 is disabled. This also makes further code cleanup easier. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k_hw: remove code duplication in phy error counter handlingFelix Fietkau
Split out the PHY error counter update from ath9k_hw_ani_monitor_*, reuse it in ath9k_hw_proc_mib_event (merged from ath9k_hw_proc_mib_event_old and ath9k_hw_proc_mib_event_new). Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k_hw: clean up ANI state handlingFelix Fietkau
ANI state is kept per channel, so instead of keeping an array of ANI states with an arbitrary size of 255, move the ANI state into the channel struct. Move some config settings that are not per-channel out of the per-channel struct to save some memory. With those changes, ath9k_ani_restart_old and ath9k_ani_restart_new can be merged into a single function. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-06ath9k_hw: add a helper function to check for the new ANI implementationFelix Fietkau
