path: root/drivers
2006-04-26Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] pxamci: fix data timeout calculation
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] fix leak in activate_ep_files()Al Viro
2006-04-26Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] splice: add ->splice_write support for /dev/null [PATCH] splice: rearrange moving to/from pipe helpers [PATCH] Add support for the sys_vmsplice syscall [PATCH] splice: fix offset problems [PATCH] splice: fix min() warning
2006-04-26[PATCH] splice: add ->splice_write support for /dev/nullJens Axboe
Useful for testing. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-26[PATCH] forcedeth: fix initializationAyaz Abdulla
This patch fixes the nic initialization. If the nic was in low power mode, it brings it back to normal power. Also, it utilizes a new hardware reset during the init. I am resending based on feedback, I corrected the register size mapping and delay after posted write. Signed-Off-By: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-26[PATCH] sky2: version 1.2Stephen Hemminger
Update to version 1.2 Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-26[PATCH] sky2: reset function can be devinitStephen Hemminger
The sky2_reset function only called from sky2_probe. Maybe the compiler was smart enough to figure this out already. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-26[PATCH] sky2: use ALIGN() macroStephen Hemminger
The ALIGN() macro in kernel.h does the same math that the sky2 driver was using for padding. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-26[PATCH] sky2: add fake idle irq timerStephen Hemminger
Add an fake NAPI schedule once a second. This is an attempt to work around for broken configurations with edge-triggered interrupts. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-26[PATCH] sky2: reschedule if irq still pendingStephen Hemminger
This is a workaround for the case edge-triggered irq's. Several users seem to have broken configurations sharing edge-triggered irq's. To avoid losing IRQ's, reshedule if more work arrives. The changes to netdevice.h are to extract the part that puts device back in list into separate inline. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-26Merge branch 'upstream-fixes' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
2006-04-26Merge branch 'skb_truesize' of ↵Jeff Garzik
git://lost.foo-projects.org/~ahkok/git/linux-2.6 into upstream-fixes
2006-04-26Merge branch 'master' into upstream-fixesJeff Garzik
2006-04-25e1000: Update truesize with the length of the packet for packet splitAuke Kok
Update skb with the real packet size. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: John Ronciak <john.ronciak@intel.com>
2006-04-24[PATCH] bcm43xx: make PIO mode usableMichael Buesch
This patch fixes PIO mode on the softmac bcm43xx driver. (A dscape patch will follow). It mainly fixes endianess issues. This patch is tested on PowerPC32 and i386. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[PATCH] Fix crash on big-endian systems during scanPavel Roskin
The original code was doing arithmetics on a little-endian value. Reported by Stelios Koroneos <stelios@stelioscellar.com> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[MMC] pxamci: fix data timeout calculationRussell King
The MMC layer gives us two parts for the timeout calculation - a fixed timeout in nanoseconds, and a card clock-speed dependent part. The PXA MMC hardware allows for a timeout based on the fixed host clock speed only. This resulted in some cards being given a short timeout, and therefore failing to work. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] MAINTAINERS [PARISC] Make ioremap default to _nocache [PARISC] Add new entries to the syscall table [PARISC] Further work for multiple page sizes [PARISC] Fix up hil_kbd.c mismerge [PARISC] defconfig updates [PARISC] Document that we tolerate "Relaxed Ordering" [PARISC] Misc. janitorial work [PARISC] EISA regions must be mapped NO_CACHE [PARISC] OSS ad1889: Match register names with ALSA driver
2006-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-fixes-2.6: [PATCH] pcmcia/pcmcia_resource.c: fix crash when using Cardbus cards [PATCH] vrc4171: update config [PATCH] pcmcia: fix oops in static mapping case [PATCH] pcmcia: remove unneeded forward declarations [PATCH] pcmcia: do not set dev_node to NULL too early [PATCH] pcmcia: fix comment for pcmcia_load_firmware [PATCH] pcmcia: unload second device first [PATCH] pcmcia: add new ID to pcnet_cs
2006-04-23Merge branch 'drm-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: possible cleanups drm: fixup r300 scratch on BE machines
2006-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-merge: powerpc: Fix define_machine so machine_is() works from modules powerpc/ppc: export strncasecmp [PATCH] powerpc: fix oops in alsa powermac driver [PATCH] powerpc: update {g5,iseries,pseries}_defconfigs [PATCH] ppc: Fix powersave code on arch/ppc [PATCH] powerpc/cell: remove BUILD_BUG_ON and add sys_tee to spu_syscall_table [PATCH] powermac: Fix i2c on keywest based chips [PATCH] powerpc: Lower threshold for DART enablement to 1GB [PATCH] powerpc: IOMMU support for honoring dma_mask
2006-04-23drm: possible cleanupsDave Airlie
This patch contains the following possible cleanups: - make the following needlessly global function static: - drm_bufs.c: drm_addbufs_fb() - remove the following unused EXPORT_SYMBOL's: - drm_agpsupport.c: drm_agp_bind_memory - drm_bufs.c: drm_rmmap_locked - drm_bufs.c: drm_rmmap - drm_stub.c: drm_get_dev Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-23drm: fixup r300 scratch on BE machinesDave Airlie
This fixes the r300 scratch stuff to work on PPC, from Ben Herrenschmidt on IRC. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-04-22[PATCH] tpm: add HID module parameterKylene Jo Hall
I recently found that not all BIOS manufacturers are using the specified generic PNP id in their TPM ACPI table entry. I have added the vendor specific IDs that I know about and added a module parameter that a user can specify another HID to the probe list if their device isn't being found by the default list. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: add interrupt module parameterKylene Jo Hall
This patch adds a boolean module parameter that allows the user to turn interrupt support on and off. The default behavior is to attempt to use interrupts. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: spacing cleanups 2Kylene Jo Hall
Fixes minor spacing issues. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm_infineon section fixupRandy Dunlap
Use __devexit_p() for the exit/remove function to protect against discarding it. WARNING: drivers/char/tpm/tpm_infineon.o - Section mismatch: reference to .exit.text:tpm_inf_pnp_remove from .data between 'tpm_inf_pnp' (at offset 0x20) and 'tpm_inf' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Kylene Jo Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: update bios log code for 1.2Kylene Jo Hall
The acpi table which contains the BIOS log events was updated for 1.2. There are now client and server modes as defined in the specifications with slightly different formats. Additionally, the start field was even too small for the 1.1 version but had been working anyway. This patch updates the code to deal with any of the three types of headers probperly (1.1, 1.2 client and 1.2 server). Signed-off-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: check mem start and lenKylene Jo Hall
The memory start and length values obtained from the ACPI entry need to be checked and filled in with the default values from the specification if they don't exist. This patch fills in the default values and uses them appropriately. Signed-off-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: tpm_infineon updated to latest interface changesMarcel Selhorst
Apply the latest changes in the TPM interface to the Infineon TPM-driver. Signed-off-by: Marcel Selhorst <selhorst@crypto.rub.de> Acked-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: use clear_bitKylene Jo Hall
Use set_bit() and clear_bit() for dev_mask manipulation. Signed-off-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: msecs_to_jiffies cleanupsKylene Jo Hall
The timeout and duration values used in the tpm driver are not exposed to userspace. This patch converts the storage units to jiffies with msecs_to_jiffies. They were always being used in jiffies so this simplifies things removing the need for calculation all over the place. The change necessitated a type change in the tpm_chip struct to hold jiffies. Signed-off-by: Kylie Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: driver for next generation TPM chipsLeendert van Doorn
The driver for the next generation of TPM chips version 1.2 including support for interrupts. The Trusted Computing Group has written the TPM Interface Specification (TIS) which defines a common interface for all manufacturer's 1.2 TPM's thus the name tpm_tis. Signed-off-by: Leendert van Doorn <leendert@watson.ibm.com> Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: new 1.2 sysfs filesKylene Jo Hall
Many of the sysfs files were calling the TPM_GetCapability command with array. Since for 1.2 more sysfs files of this type are coming I am generalizing the array so there can be one array and the unique parts can be filled in just before the command is called. This updated version of the patch breaks the multi-value sysfs file into separate files pointed out by Greg. It also addresses the code redundancy and ugliness in the tpm_show_* functions pointed out on another patch by Dave Hansen. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: command duration updateKylene Jo Hall
With the TPM 1.2 Specification, each command is classified as short, medium or long and the chip tells you the maximum amount of time for a response to each class of command. This patch provides and array of the classifications and a function to determine how long the response should be waited for. Also, it uses that information in the command processing to determine how long to poll for. The function is exported so the 1.2 driver can use the functionality to determine how long to wait for a DataAvailable interrupt if interrupts are being used. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: return chip from tpm_register_hardwareKylene Jo Hall
Changes in the 1.2 TPM Specification make it necessary to update some fields of the chip structure in the initialization function after it is registered with tpm.c thus tpm_register_hardware was modified to return a pointer to the structure. This patch makes that change and the associated changes in tpm_atmel and tpm_nsc. The changes to tpm_infineon will be coming in a patch from Marcel Selhorst. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: chip struct updateKylene Jo Hall
To assist with chip management and better support the possibility of having multiple TPMs in the system of the same kind, the struct tpm_vendor_specific member of the tpm_chip was changed from a pointer to an instance. This patch changes that declaration and fixes up all accesses to the structure member except in tpm_infineon which is coming in a patch from Marcel Selhorst. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: reorganize sysfs filesKylene Jo Hall
Many of the sysfs files were calling the TPM_GetCapability command with array. Since for 1.2 more sysfs files of this type are coming I am generalizing the array so there can be one array and the unique parts can be filled in just before the command is called. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: spacing cleanupsKylene Jo Hall
The following patch set contains numerous changes to the base tpm driver (tpm.c) to support the next generation of TPM chips. The changes include new sysfs files because of more relevant data being available, a function to access the timeout and duration values for the chip, and changes to make use of those duration values. Duration in the TPM specification is defined as the maximum amount of time the chip could take to return the results. Commands are in one of three categories short, medium and long. Also included are cleanups of how the commands for the sysfs files are composed to reduce a bunch of redundant arrays. This patch: Fix minor spacing issues. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: fix missing stringKylene Jo Hall
A string corresponding to the tcpa_pc_event_id POST_CONTENTS was missing causing an overflow bug when access was attempted in the get_event_name function. This bug was found by Coverity. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] tpm: fix memory leakKylene Jo Hall
The eventname was kmalloc'd and not freed in the *_show functions. This bug was found by Coverity. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] Altix snsc: duplicate kobject fixakpm@osdl.org
from: Greg Howard <ghoward@sgi.com> Fix Altix system controller (snsc) device names to include the slot number of the blade whose associated system controller is the target of the device interface. Including the slot number avoids a problem we're currently having where slots within the same enclosure are attempting to create multiple kobjects with identical names. Signed-off-by: Greg Howard <ghoward@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] isdn4linux: Siemens Gigaset base driver: fix disconnect handlingTilman Schmidt
Fix a possible Oops in the Siemens Gigaset base driver when the device is unplugged while an ISDN connection is still active, and makes sure that the isdn4linux link level (LL) is properly informed if a connection is broken by the USB cable being unplugged. - Avoid unsafe checks of URB status fields outside the URB completion handlers, keep track of in-use URBs myself instead. - If an isochronous transfer URB completes with status==0, also check the status of the frame descriptors. - Verify length of interrupt messages received from the device. - Align the length limit on transmitted AT commands with the device documentation. - In case of AT response receive overrun, keep newly arrived instead of old unread data. - Remove redundant check of device ID in the USB probe function. - Correct and improve some comments and formatting. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Acked-by: Hansjoerg Lipp <hjlipp@web.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-22[PATCH] pcmcia/pcmcia_resource.c: fix crash when using Cardbus cardsDaniel Ritz
Using the old ioctl interface together with cardbus card gives a NULL pointer dereference since cardbus devices don't have a struct pcmcia_device. also s->io[0].res can be NULL as well. Fix is to move the pcmcia code after the cardbus code and to check for a null pointer. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-04-22[PATCH] vrc4171: update configYoichi Yuasa
This patch updates "depends on" for PCMCIA_VRC4171. CONFIG_VRC4171 has been removed, so replace it with CPU_VR41XX && ISA. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-04-22[PATCH] pcmcia: fix oops in static mapping caseDominik Brodowski
As static maps do not have IO resources, this setting oopses. However, as we do not ever read this value, we can safely remove it. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-04-22[PATCH] pcmcia: remove unneeded forward declarationsAndrew Morton
Also remove a couple of unneeded typecasts. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-04-22[PATCH] pcmcia: do not set dev_node to NULL too earlyDominik Brodowski
If we set dev_node to NULL too early, some drivers which used this to determine whether unregister_netdev() needs to be called fail when removing a PCMCIA card. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-04-22[PATCH] pcmcia: fix comment for pcmcia_load_firmwareKomuro
The comment of "pcmcia_load_firmware" is wrong: the firmware(*.cis) files reside in /lib/firmware/ _not_ /lib/firmware/cis/ . Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
