Implement the set_baudrate callback for hci_intel.
- Controller requires a read Intel version command before updating
its baudrate.
- The operation consists in an async cmd since the controller does
not respond at the same speed.
- Wait 100ms to let the controller change its baudrate.
- Clear RTS until we change our own UART speed
Manage speed change in the setup function, we need to restore the oper
speed once chip has booted on patched firmware.
Signed-off-by: Loic Poulain <loic.poulain@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Packets with a variable length value equal to zero were not received.
Since no more data expected (and input buffer entirely consumed), we
need to complete/forward the packet immediately instead of waiting for
more data.
This change ensures we will get driver name as 'btmrvl_sdio'
in udev event.
Signed-off-by: Shengzhen Li <szli@marvell.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
We should not sleep while holding a spinlock.
bcm_gpio_set_power is called while holding the bcm_device_list lock.
Only for packets with first ethertype set to IPv4/6 for now.
Signed-off-by: Achiad Shochat <achiad@mellanox.com>
Only rx/tx pause settings.
Autoneg setting is currently not supported.
- Port speed settings are applied by the device only upon
port admin status transition from DOWN to UP.
So we enforce this transition regardless of the port's
current operation state (which may be occasionally DOWN if
for example the network cable is disconnected).
- Fix the PORT_UP/DOWN device interface enum
- Set the local_port bit in the device PAOS register
- EXPORT the PAOS (Port Administrative and Operational Status)
register set/query access functions.
- Change the maximum LRO session size from 16KB to 64KB
- Reduce the LRO session timeout from 512us to 32us in
order to reduce the TCP latency of non-LRO'ed flows.
- Fix skb_shinfo(skb)->gso_size and set skb_shinfo(skb)->gso_type.
- Fix a bug accessing un-initialized mdev pointer.
We un-intentionally limited the minimum rings size too much.
TX minimum ring size reduced from 128 to 64.
RX minimum ring size reduced from 128 to 2.
- get_rxfh_key_size
- get_rxfh_indir_size
- get/set_rxfh indirection table and RSS Toeplitz hash key
- get_rxnfc
The indirection table size was defined by a variable that
was actually assigned a constant value.
Since we do not have any forseen intension to make it configurable
we simply made it a constant.
We also limit the number of channels such that the RSS indirection
table could always populate all RX rings.
No need to generate a unique key per TIR.
Generating a single key per netdev and copying it to all
its TIRs.
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-08-16
Here's what's likely the last bluetooth-next pull request for 4.3:
- 6lowpan/802.15.4 refactoring, cleanups & fixes
- Document 6lowpan netdev usage in Documentation/networking/6lowpan.txt
- Support for UART based QCA Bluetooth controllers
- Power management support for Broeadcom Bluetooth controllers
- Change LE connection initiation to always use passive scanning first
- Support for new Silicon Wave USB ID
Please let me know if there are any issues pulling. Thanks.
devcmd is an interface for driver to communicate with fw/adaptor. It
involves writing data to hardware registers and waiting for the result.
This mechanism does not scale well. The queuing of "no wait" devcmds is
done in firmware memory rather than on the host. Firmware memory is a
rather more scarce and valuable resource than host memory. A devcmd storm
from one vf can disrupt the service on other pf/vf. The lack of flow
control allows for possible denial of server from one VM to another.
Devcmd2 uses work queue to post the devcmds, just like tx work queue. This
allows better flow control.
Initialize devcmd2, if fails we fall back to devcmd1.
Also change the driver version.
Signed-off-by: N V V Satyanarayana Reddy <nalreddy@cisco.com>
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
Add devcmd resources to vnic_res_type. Add data types used by devcmd.
pr_info does not give any details about the interface involved. This patch
uses netdev_info for printing the message. Use dev_info where netdev is not
ready.
Some of the structure definitions are in .c file to make them private to
that file. This patch moves the struct definition to .h file, So that their
definitions are accessible from other files.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Johannes Berg says:
Another pull request for the next cycle, this time with quite
a bit of content:
* mesh fixes/improvements from Alexis, Bob, Chun-Yeow and Jesse
* TDLS higher bandwidth support (Arik)
* OCB fixes from Bertold Van den Bergh
* suspend/resume fixes from Eliad
* dynamic SMPS support for minstrel-HT (Krishna Chaitanya)
* VHT bitrate mask support (Lorenzo Bianconi)
* better regulatory support for 5/10 MHz channels (Matthias May)
* basic support for MU-MIMO to avoid the multi-vif issue (Sara Sharon)
along with a number of other cleanups.
Commit 0b50dc4fc971 ("Convert smsc911x to use ACPI as well as DT") makes
the call to smsc911x_probe_config() unconditional, and no longer fails if
there is no device node. device_get_phy_mode() is called unconditionally,
and if there is no phy node configured returns an error code. This error
code is assigned to phy_interface, and interpreted elsewhere in the code
as valid phy mode. This in turn causes qemu to crash when running a
variant of realview_pb_defconfig.
qemu: hardware error: lan9118_read: Bad reg 0x86
Fixes: 0b50dc4fc971 ("Convert smsc911x to use ACPI as well as DT")
Cc: Jeremy Linton <jeremy.linton@arm.com>
Cc Graeme Gregory <graeme.gregory@linaro.org>
Management firmware tells driver in case bandwidth configuration for
a specific function exists, but [regretably] the same field has different
meanings depending on the multi-function mode - it can either be
a percentile value or an actual speed.
For newer multi-function modes current logic is incorrect -
driver understands values as actual speeds instead of percentages,
causing the resulting chip configuration to be incorrect.
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
This patch enables quirk handling for Silicon Wave based devices and
fixes kernel bug with id 42985.
T: Bus=01 Lev=01 Prnt=01 Port=07 Cnt=04 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0c10 ProdID=0000 Rev=15.00
S: Manufacturer=SiW
S: Product=SiW
S: SerialNumber=340A05F61100
C:* #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr= 50mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Peter Poklop <peter.poklop@gmail.com>
During hwsim_init_netlink(), we should call genl_unregister_family()
if failed on netlink_register_notifier() since the genetlink is
already registered.
Signed-off-by: Su Kang Yin <cantona@cantona.net>
debugfs_create_bool is asking to put u32 type pointer instead of bool
so that passing bool type with u32* cast will cause memory corruption
to read that value since it is handled by 4 bytes instead of 1 byte
inside.
Signed-off-by: Ben Young Tae Kim <ytkim@qca.qualcomm.com>
This driver borrows heavily from IPvlan and teaming drivers.
Routing domains (VRF-lite) are created by instantiating a VRF master
device with an associated table and enslaving all routed interfaces that
participate in the domain. As part of the enslavement, all connected
routes for the enslaved devices are moved to the table associated with
the VRF device. Outgoing sockets must bind to the VRF device to function.
Standard FIB rules bind the VRF device to tables and regular fib rule
processing is followed. Routed traffic through the box, is forwarded by
using the VRF device as the IIF and following the IIF rule to a table
that is mated with the VRF.
Example:
Create vrf 1:
ip link add vrf1 type vrf table 5
ip rule add iif vrf1 table 5
ip rule add oif vrf1 table 5
ip route add table 5 prohibit default
ip link set vrf1 up
Add interface to vrf 1:
ip link set eth1 master vrf1
Signed-off-by: Shrijeet Mukherjee <shm@cumulusnetworks.com>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
This commit changes the 802.1Q mode of each port from Disabled to
Secure. This enables the VLAN support, by checking the VTU entries on
ingress.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Implement port_pvid_set and port_vlan_add to add new entries in the VLAN
hardware table, and join ports to them.
The patch also implement the STU Get Next and Load Purge operations,
since it is required to have a valid STU entry for at least all VLANs.
Each VLAN has its own forwarding database, with FID num_ports+1 to 4095.
Add support for the VTU Load Purge operation and implement the
port_vlan_del driver function to remove a port from a VLAN entry, and
delete the VLAN if the given port was its last member.
Add an helper function to read the next valid VLAN entry for a given
port. It is used in the VID to FID conversion function to retrieve the
forwarding database assigned to a given VLAN port.
Finally update the FDB getnext operation to iterate on the next valid
port VLAN when the end of the current database is reached.
Implement the port_pvid_get and vlan_getnext driver functions required
to dump VLAN entries from the hardware, with the VTU Get Next operation.
Some functions and structure will be shared with STU operations, since
their table format are similar (e.g. STU data entries are accessible
with the same registers as VTU entries, except with an offset of 2).
Implement the VTU Flush operation (which also flushes the STU), so that
warm boots won't preserved old entries.
Handle TRACE_PKT, stack can sniff them on the first port
Add debubfs enrty to configure tracing for offload traffic like iWARP
& iSCSI for debugging purpose.
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
HWM_REVERSE() macro is unused, remove it.
Signed-off-by: yalin wang <yalin.wang2010@gmail.com>
Rocker driver tracks arp_tbl neighs to resolve IPv4 route nexthops. The
driver uses NETEVENT_NEIGH_UPDATE for neigh adds and updates, but there is
no event when the neigh is removed from the device (such as when the device
goes admin down). This patches hooks ndo_neigh_destroy so the driver can
know when a neigh is removed from the device. In response, the driver will
purge the neigh entry from its internal tbl.
I didn't find an in-tree users of ndo_neigh_destroy, so I'm not sure if
this ndo is vestigial or if there are out-of-tree users. In any case, it
does what I need here. An alternative design would be to generate
NETEVENT_NEIGH_UPDATE event when neigh is being destroyed, setting state to
NUD_NONE so driver knows neigh entry is dead.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
On sucessful probe, driver prints the switch ID. This patch changes the
format of the printed ID to match what's used in sysfs phys_switch_id node.
Add ACPI bindings for the smsc911x driver. Convert the DT specific calls
to nonspecific device* calls, This allows the driver to work
with both ACPI and DT configurations. Ethernet should now work when using
ACPI on ARM Juno.
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
Reviewed-by: Graeme Gregory <graeme.gregory@linaro.org>
OF has some helper functions for parsing MAC and PHY settings.
In cases where the platform is providing this information rather
than the device itself, there needs to be similar functions for ACPI.
These functions are slightly modified versions of the ones in
of_net which can use information provided via DT or ACPI.
As per Am335x Errata [1] Advisory 1.0.9, The CPSW C0_TX_PEND and
C0_RX_PEND interrupt outputs provide a single transmit interrupt
that combines transmit channel interrupts TXPEND[7:0] and a
single receive interrupt that combines receive channel interrupts
RXPEND[7:0]. The TXPEND[0] and RXPEND[0] interrupt outputs are
connected to the ARM Cortex-A8 interrupt controller (INTC) rather
than the C0_TX_PEND and C0_RX_PEND interrupt outputs. So even
though CPSW interrupt is cleared by writing appropriate values to
EOI register the interrupt is not cleared in IRQ controller. So
interrupt is still pending and CPU is struck in ISR, the
workaround is to disable the interrupts in ARM irq controller.
[1] http://www.ti.com/lit/er/sprz360f/sprz360f.pdf
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
drivers/net/ethernet/cavium/Kconfig
The cavium conflict was overlapping dependency
changes.
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
- two stable fixes for corruption seen in a snapshot of thinp metadata;
metadata snapshots aren't widely used but help provide a consistent
view of the metadata associated with an active thin-pool.
- a dm-cache fix for the 4.2 "default" policy switch from "mq" to "smq"
* tag 'dm-4.2-fixes-5' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm cache policy smq: move 'dm-cache-default' module alias to SMQ
dm btree: add ref counting ops for the leaves of top level btrees
dm thin metadata: delete btrees when releasing metadata snapshot
Pull xen block driver fixes from Jens Axboe:
"A few small bug fixes for xen-blk{front,back} that have been sitting
over my vacation"
* 'for-linus' of git://git.kernel.dk/linux-block:
xen-blkback: replace work_pending with work_busy in purge_persistent_gnt()
xen-blkfront: don't add indirect pages to list when !feature_persistent
xen-blkfront: introduce blkfront_gather_backend_features()
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen bug fixes from David Vrabel:
- revert a fix from 4.2-rc5 that was causing lots of WARNING spam.
- fix a memory leak affecting backends in HVM guests.
- fix PV domU hang with certain configurations.
* tag 'for-linus-4.2-rc6-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/xenbus: Don't leak memory when unmapping the ring on HVM backend
Revert "xen/events/fifo: Handle linked events when closing a port"
x86/xen: build "Xen PV" APIC driver for domU as well
Pull networking fixes from David Miller:
1) Workaround hw bug when acquiring PCI bos ownership of iwlwifi
devices, from Emmanuel Grumbach.
2) Falling back to vmalloc in conntrack should not emit a warning, from
Pablo Neira Ayuso.
3) Fix NULL deref when rtlwifi driver is used as an AP, from Luis
Felipe Dominguez Vega.
4) Rocker doesn't free netdev on device removal, from Ido Schimmel.
5) UDP multicast early sock demux has route handling races, from Eric
Dumazet.
6) Fix L4 checksum handling in openvswitch, from Glenn Griffin.
7) Fix use-after-free in skb_set_peeked, from Herbert Xu.
8) Don't advertize NETIF_F_FRAGLIST in virtio_net driver, this can lead
to fraglists longer than the driver can support. From Jason Wang.
9) Fix mlx5 on non-4k-pagesize systems, from Carol L Soto.
10) Fix interrupt storm in bna driver, from Ivan Vecera.
11) Don't propagate -EBUSY from netlink_insert(), from Daniel Borkmann.
12) Fix inet request sock leak, from Eric Dumazet.
13) Fix TX interrupt masking and marking in TX descriptors of fs_enet
driver, from LEROY Christophe.
14) Get rid of rule optimizer in gianfar driver, it's buggy and unlikely
to get fixed any time soon. From Jakub Kicinski
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
cosa: missing error code on failure in probe()
gianfar: remove faulty filer optimizer
gianfar: correct list membership accounting
gianfar: correct filer table writing
bonding: Gratuitous ARP gets dropped when first slave added
net: dsa: Do not override PHY interface if already configured
net: fs_enet: mask interrupts for TX partial frames.
net: fs_enet: explicitly remove I flag on TX partial frames
inet: fix possible request socket leak
inet: fix races with reqsk timers
mkiss: Fix error handling in mkiss_open()
bnx2x: Free NVRAM lock at end of each page
bnx2x: Prevent null pointer dereference on SKB release
cxgb4: missing curly braces in t4_setup_debugfs()
net-timestamp: Update skb_complete_tx_timestamp comment
ipv6: don't reject link-local nexthop on other interface
netlink: make sure -EBUSY won't escape from netlink_insert
bna: fix interrupts storm caused by erroneous packets
net: mvpp2: replace TX coalescing interrupts with hrtimer
net: mvpp2: enable proper per-CPU TX buffers unmapping
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp
Pull EDAC fix from Borislav Petkov:
"A ppc4xx_edac fix for accessing ->csrows properly. This driver was
missed during the conversion a couple of years ago"
* tag 'edac_fix_for_4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC, ppc4xx: Access mci->csrows array elements properly
According to firmware engineers, the firmware has never required
these fields and the values have always been calculated, they were
just leftovers from a previous implementation.
Therefore remove the unnecessary calculation.
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
The commit
de3910eb79ac ("edac: change the mem allocation scheme to
make Documentation/kobject.txt happy")
changed the memory allocation for the csrows member. But ppc4xx_edac was
forgotten in the patch. Fix it.
Signed-off-by: Michael Walle <michael@walle.cc>
Cc: <stable@vger.kernel.org>
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Link: http://lkml.kernel.org/r/1437469253-8611-1-git-send-email-michael@walle.cc
If register_hdlc_device() fails, the current code returns 0 but we
should return an error code instead.
There is no need to use the IS_ERR_VALUE() macro for checking
the return value from pm_runtime_* functions.
Just do a simple negative test instead.
The semantic patch that makes this change is available
in scripts/coccinelle/api/pm_runtime.cocci.
Add debugfs support to dump tid info like stid, sftid, tids, atid and
hwtids
For T4 adapter, offloaded servers tid for IPv4 connections are
allocated from filter region. So add a new field for server filter tid if
server tid is allocated from filter region.
For the tid info, differentiate from which region the TID is allocated
from. It can be from TCAM region or HASH region.
