This platform driver has a OF device ID table but the OF module
alias information is not created so module autoloading won't work.
Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
rockchip phy are enable when soc reset, to save power consumption,
we disable it when probe, and enable each phy when it use
Signed-off-by: huang lin <hl@rock-chips.com>
Export the following functions in order to avoid build errors
when the component PHY_QCOM_UFS is compiled as a module:
ERROR: "ufs_qcom_phy_disable_ref_clk"
[drivers/scsi/ufs/ufs-qcom.ko] undefined!
ERROR: "ufs_qcom_phy_enable_ref_clk"
ERROR: "ufs_qcom_phy_is_pcs_ready"
ERROR: "ufs_qcom_phy_disable_iface_clk"
ERROR: "ufs_qcom_phy_start_serdes"
ERROR: "ufs_qcom_phy_calibrate_phy"
ERROR: "ufs_qcom_phy_enable_dev_ref_clk"
ERROR: "ufs_qcom_phy_set_tx_lane_enable"
ERROR: "ufs_qcom_phy_disable_dev_ref_clk"
ERROR: "ufs_qcom_phy_save_controller_version"
ERROR: "ufs_qcom_phy_enable_iface_clk"
make[1]: *** [__modpost] Error 1
Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org>
I didn't notice this when merging the thermal code from Zhang, but his
merge (commit 5a924a07f882: "Merge branches 'thermal-core' and
'thermal-intel' of .git into next") of the thermal-core and
thermal-intel branches was wrong.
In thermal-core, commit 17e8351a7739 ("thermal: consistently use int for
temperatures") converted the thermal layer to use "int" for
temperatures.
But in parallel, in the thermal-intel branch commit d0a12625d2ff
("thermal: Add Intel PCH thermal driver") added support for the intel
PCH thermal sensor using the old interfaces that used "unsigned long"
pointers.
This resulted in warnings like this:
drivers/thermal/intel_pch_thermal.c:184:14: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
.get_temp = pch_thermal_get_temp,
drivers/thermal/intel_pch_thermal.c:184:14: note: (near initialization for ‘tzd_ops.get_temp’)
drivers/thermal/intel_pch_thermal.c:186:19: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
.get_trip_temp = pch_get_trip_temp,
drivers/thermal/intel_pch_thermal.c:186:19: note: (near initialization for ‘tzd_ops.get_trip_temp’)
This fixes it.
Merge fourth patch-bomb from Andrew Morton:
- sys_membarier syscall
- seq_file interface changes
- a few misc fixups
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
revert "ocfs2/dlm: use list_for_each_entry instead of list_for_each"
mm/early_ioremap: add explicit #include of asm/early_ioremap.h
fs/seq_file: convert int seq_vprint/seq_printf/etc... returns to void
selftests: enhance membarrier syscall test
selftests: add membarrier syscall test
sys_membarrier(): system-wide memory barrier (generic, x86)
MODSIGN: fix a compilation warning in extract-cert
Pull NTB fixes from Jon Mason:
"NTB bug and documentation fixes, new device IDs, performance
improvements, and adding a mailing list to MAINTAINERS for NTB"
* tag 'ntb-4.3' of git://github.com/jonmason/ntb:
NTB: Fix range check on memory window index
NTB: Improve index handling in B2B MW workaround
NTB: Fix documentation for ntb_peer_db_clear.
NTB: Fix documentation for ntb_link_is_up
NTB: Use unique DMA channels for TX and RX
NTB: Remove dma_sync_wait from ntb_async_rx
NTB: Clean up QP stats info
NTB: Make the transport list in order of discovery
NTB: Add PCI Device IDs for Broadwell Xeon
NTB: Add flow control to the ntb_netdev
NTB: Add list to MAINTAINERS
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull more input updates from Dmitry Torokhov:
"Second round of updates for the input subsystem.
This introduces two brand new touchscreen drivers (Colibri and
imx6ul_tsc), some small driver fixes, and we are no longer report
errors from evdev_flush() as users do not really have a way of
handling errors, error codes that we were returning were not on the
list of errors supposed to be returned by close(), and errors were
causing issues with one of older versions of systemd"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: imx_keypad - remove obsolete comment
Input: touchscreen - add imx6ul_tsc driver support
Input: Add touchscreen support for Colibri VF50
Input: i8042 - lower log level for "no controller" message
Input: evdev - do not report errors form flush()
Input: elants_i2c - extend the calibration timeout to 12 seconds
Input: sparcspkr - fix module autoload for OF platform drivers
Input: regulator-haptic - fix module autoload for OF platform driver
Input: pwm-beeper - fix module autoload for OF platform driver
Input: ab8500-ponkey - Fix module autoload for OF platform driver
Input: cyttsp - remove unnecessary MODULE_ALIAS()
Input: elan_i2c - add ACPI ID "ELAN1000"
Pull more power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups on top of the previous PM+ACPI
pull request (cpufreq core and drivers, cpuidle, generic power domains
framework). Some of them didn't make to that pull request and some
fix issues introduced by it.
The only really new thing is the support for suspend frequency in the
cpufreq-dt driver, but it is needed to fix an issue with Exynos
platforms.
Specifics:
- build fix for the new Mediatek MT8173 cpufreq driver (Guenter
Roeck).
- generic power domains framework fixes (power on error code path,
subdomain removal) and cleanup of a deprecated API user (Geert
Uytterhoeven, Jon Hunter, Ulf Hansson).
- cpufreq-dt driver fixes including two fixes for bugs related to the
new Operating Performance Points Device Tree bindings introduced
recently (Viresh Kumar).
- suspend frequency support for the cpufreq-dt driver (Bartlomiej
Zolnierkiewicz, Viresh Kumar).
- cpufreq core cleanups (Viresh Kumar).
- intel_pstate driver fixes (Chen Yu, Kristen Carlson Accardi).
- additional sanity check in the cpuidle core (Xunlei Pang).
- fix for a comment related to CPU power management (Lina Iyer)"
* tag 'pm+acpi-4.3-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
intel_pstate: fix PCT_TO_HWP macro
intel_pstate: Fix user input of min/max to legal policy region
PM / OPP: Return suspend_opp only if it is enabled
cpufreq-dt: add suspend frequency support
cpufreq: allow cpufreq_generic_suspend() to work without suspend frequency
PM / OPP: add dev_pm_opp_get_suspend_opp() helper
staging: board: Migrate away from __pm_genpd_name_add_device()
cpufreq: Use __func__ to print function's name
cpufreq: staticize cpufreq_cpu_get_raw()
PM / Domains: Ensure subdomain is not in use before removing
cpufreq: Add ARM_MT8173_CPUFREQ dependency on THERMAL
cpuidle/coupled: Add sanity check for safe_state_index
PM / Domains: Try power off masters in error path of __pm_genpd_poweron()
cpufreq: dt: Tolerance applies on both sides of target voltage
cpufreq: dt: Print error on failing to mark OPPs as shared
cpufreq: dt: Check OPP count before marking them shared
kernel/cpu_pm: fix cpu_cluster_pm_exit comment
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"Here are the outstanding target-pending updates for v4.3-rc1.
Mostly bug-fixes and minor changes this round. The fallout from the
big v4.2-rc1 RCU conversion have (thus far) been minimal.
The highlights this round include:
- Move sense handling routines into scsi_common code (Sagi)
- Return ABORTED_COMMAND sense key for PI errors (Sagi)
- Add tpg_enabled_sendtargets attribute for disabled iscsi-target
discovery (David)
- Shrink target struct se_cmd by rearranging fields (Roland)
- Drop iSCSI use of mutex around max_cmd_sn increment (Roland)
- Replace iSCSI __kernel_sockaddr_storage with sockaddr_storage (Andy +
Chris)
- Honor fabric max_data_sg_nents I/O transfer limit (Arun + Himanshu +
nab)
- Fix EXTENDED_COPY >= v4.1 regression OOPsen (Alex + nab)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (37 commits)
target: use stringify.h instead of own definition
target/user: Fix UFLAG_UNKNOWN_OP handling
target: Remove no-op conditional
target/user: Remove unused variable
target: Fix max_cmd_sn increment w/o cmdsn mutex regressions
target: Attach EXTENDED_COPY local I/O descriptors to xcopy_pt_sess
target/qla2xxx: Honor max_data_sg_nents I/O transfer limit
target/iscsi: Replace __kernel_sockaddr_storage with sockaddr_storage
target/iscsi: Replace conn->login_ip with login_sockaddr
target/iscsi: Keep local_ip as the actual sockaddr
target/iscsi: Fix np_ip bracket issue by removing np_ip
target: Drop iSCSI use of mutex around max_cmd_sn increment
qla2xxx: Update tcm_qla2xxx module description to 24xx+
iscsi-target: Add tpg_enabled_sendtargets for disabled discovery
drivers: target: Drop unlikely before IS_ERR(_OR_NULL)
target: check DPO/FUA usage for COMPARE AND WRITE
target: Shrink struct se_cmd by rearranging fields
target: Remove cmd->se_ordered_id (unused except debug log lines)
target: add support for START_STOP_UNIT SCSI opcode
target: improve unsupported opcode message
Pull second round of SCSI updates from James Bottomley:
"There's one late arriving patch here (added today), fixing a build
issue which the scsi_dh patch set in here uncovered. Other than that,
everything has been incubated in -next and the checkers for a week.
The major pieces of this patch are a set patches facilitating better
integration between scsi and scsi_dh (the device handling layer used
by multi-path; all the dm parts are acked by Mike Snitzer).
This also includes driver updates for mp3sas, scsi_debug and an
assortment of bug fixes"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (50 commits)
scsi_dh: fix randconfig build error
scsi: fix scsi_error_handler vs. scsi_host_dev_release race
fcoe: Convert use of __constant_htons to htons
mpt2sas: setpci reset kernel oops fix
pm80xx: Don't override ts->stat on IO_OPEN_CNX_ERROR_HW_RESOURCE_BUSY
lpfc: Fix possible use-after-free and double free in lpfc_mbx_cmpl_rdp_page_a2()
bfa: Fix incorrect de-reference of pointer
bfa: Fix indentation
scsi_transport_sas: Remove check for SAS expander when querying bay/enclosure IDs.
scsi_debug: resp_request: remove unused variable
scsi_debug: fix REPORT LUNS Well Known LU
scsi_debug: schedule_resp fix input variable check
scsi_debug: make dump_sector static
scsi_debug: vfree is null safe so drop the check
scsi_debug: use SCSI_W_LUN_REPORT_LUNS instead of SAM2_WLUN_REPORT_LUNS;
scsi_debug: define pr_fmt() for consistent logging
mpt2sas: Refcount fw_events and fix unsafe list usage
mpt2sas: Refcount sas_device objects and fix unsafe list usage
scsi_dh: return SCSI_DH_NOTCONN in scsi_dh_activate()
scsi_dh: don't allow to detach device handlers at runtime
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"A series of patches that move part of the code used to allocate memory
from the media subsystem to the mm subsystem"
[ The mm parts have been acked by VM people, and the series was
apparently in -mm for a while - Linus ]
* tag 'media/v4.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] drm/exynos: Convert g2d_userptr_get_dma_addr() to use get_vaddr_frames()
[media] media: vb2: Remove unused functions
[media] media: vb2: Convert vb2_dc_get_userptr() to use frame vector
[media] media: vb2: Convert vb2_vmalloc_get_userptr() to use frame vector
[media] media: vb2: Convert vb2_dma_sg_get_userptr() to use frame vector
[media] vb2: Provide helpers for mapping virtual addresses
[media] media: omap_vout: Convert omap_vout_uservirt_to_phys() to use get_vaddr_pfns()
[media] mm: Provide new get_vaddr_frames() helper
[media] vb2: Push mmap_sem down to memops
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
Pull edac updates from Mauro Carvalho Chehab:
"Two EDAC fixes for Intel systems (Haswell and Ivy Bridge)"
* tag 'edac/v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac:
sb_edac: correctly fetch DIMM width on Ivy Bridge and Haswell
sb_edac: look harder for DDRIO on Haswell systems
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal updates from Zhang Rui:
- use int instead of unsigned long to represent temperature to avoid
bogus overheat detection when negative temperature reported. From
Sascha Hauer.
- export available thermal governors information to user space via
sysfs. From Wei Ni.
- introduce new thermal driver for Wildcat Point platform controller
hub, which uses PCH thermal sensor and associated critical and hot
trip points. From Tushar Dave.
- add suuport for Intel Skylake and Denlow platforms in powerclamp
driver.
- some small cleanups in thermal core.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
thermal: Add comment explaining test for critical temperature
thermal: Use IS_ENABLED instead of #ifdef
thermal: remove unnecessary call to thermal_zone_device_set_polling
thermal: trivial: fix typo in comment
thermal: consistently use int for temperatures
thermal: add available policies sysfs attribute
thermal/powerclamp: add cpu id for denlow platform
thermal/powerclamp: add cpu id for Skylake u/y
thermal/powerclamp: add cpu id for skylake h/s
The seq_<foo> function return values were frequently misused.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
All uses of these return values have been removed, so convert the
return types to void.
Miscellanea:
o Move seq_put_decimal_<type> and seq_escape prototypes closer the
other seq_vprintf prototypes
o Reorder seq_putc and seq_puts to return early on overflow
o Add argument names to seq_vprintf and seq_printf
o Update the seq_escape kernel-doc
o Convert a couple of leading spaces to tabs in seq_escape
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Mark Brown <broonie@kernel.org>
Cc: Joerg Roedel <jroedel@suse.de>
Pull watchdog updates from Wim Van Sebroeck:
- new driver for NXP LPC18xx Watchdog Timer
- new driver for SAMA5D4 watchdog timer
- add support for MCP79 to nv_tco driver
- clean-up and improvement of the mpc8xxx watchdog driver
- improvements to gpio-wdt
- at91sam9_wdt clock improvements
... and other small fixes and improvements
* git://www.linux-watchdog.org/linux-watchdog: (25 commits)
Watchdog: Fix parent of watchdog_devices
watchdog: at91rm9200: Correct check for syscon_node_to_regmap() errors
watchdog: at91sam9: get and use slow clock
Documentation: dt: binding: atmel-sama5d4-wdt: for SAMA5D4 watchdog driver
watchdog: add a driver to support SAMA5D4 watchdog timer
watchdog: mpc8xxx: allow to compile for MPC512x
watchdog: mpc8xxx: use better error code when watchdog cannot be enabled
watchdog: mpc8xxx: use dynamic memory for device specific data
watchdog: mpc8xxx: use devm_ioremap_resource to map memory
watchdog: mpc8xxx: make use of of_device_get_match_data
watchdog: mpc8xxx: simplify registration
watchdog: mpc8xxx: remove dead code
watchdog: lpc18xx_wdt_get_timeleft() can be static
DT: watchdog: Add NXP LPC18xx Watchdog Timer binding documentation
watchdog: NXP LPC18xx Watchdog Timer Driver
watchdog: gpio-wdt: ping already at startup for always running devices
watchdog: gpio-wdt: be more strict about hw_algo matching
Documentation: watchdog: at91sam9_wdt: add clocks property
watchdog: booke_wdt: Use infrastructure to check timeout limits
watchdog: (nv_tco) add support for MCP79
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph update from Sage Weil:
"There are a few fixes for snapshot behavior with CephFS and support
for the new keepalive protocol from Zheng, a libceph fix that affects
both RBD and CephFS, a few bug fixes and cleanups for RBD from Ilya,
and several small fixes and cleanups from Jianpeng and others"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: improve readahead for file holes
ceph: get inode size for each append write
libceph: check data_len in ->alloc_msg()
libceph: use keepalive2 to verify the mon session is alive
rbd: plug rbd_dev->header.object_prefix memory leak
rbd: fix double free on rbd_dev->header_name
libceph: set 'exists' flag for newly up osd
ceph: cleanup use of ceph_msg_get
ceph: no need to get parent inode in ceph_open
ceph: remove the useless judgement
ceph: remove redundant test of head->safe and silence static analysis warnings
ceph: fix queuing inode to mdsdir's snaprealm
libceph: rename con_work() to ceph_con_workfn()
libceph: Avoid holding the zero page on ceph_msgr_slab_init errors
libceph: remove the unused macro AES_KEY_SIZE
ceph: invalidate dirty pages after forced umount
ceph: EIO all operations after forced umount
It looks like the Kconfig check that was meant to fix this (commit
fe9233fb6914a0eb20166c967e3020f7f0fba2c9 [SCSI] scsi_dh: fix kconfig related
build errors) was actually reversed, but no-one noticed until the new set of
patches which separated DM and SCSI_DH).
Fixes: fe9233fb6914a0eb20166c967e3020f7f0fba2c9
Tested-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Pull drm fixes from Dave Airlie:
"Just a bunch of fixes to squeeze in before -rc1:
- three nouveau regression fixes
- one qxl regression fix
- a bunch of i915 fixes
... and some core displayport/atomic fixes"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau/device: enable c800 quirk for tecra w50
drm/nouveau/clk/gt215: Unbreak engine pausing for GT21x/MCP7x
drm/nouveau/gr/nv04: fix big endian setting on gr context
drm/qxl: validate monitors config modes
drm/i915: Allow DSI dual link to be configured on any pipe
drm/i915: Don't try to use DDR DVFS on CHV when disabled in the BIOS
drm/i915: Fix CSR MMIO address check
drm/i915: Limit the number of loops for reading a split 64bit register
drm/i915: Fix broken mst get_hw_state.
drm/i915: Pass hpd_status_i915[] to intel_get_hpd_pins() in pre-g4x
uapi/drm/i915_drm.h: fix userspace compilation.
drm/i915: Always mark the object as dirty when used by the GPU
drm/dp: Add dp_aux_i2c_speed_khz module param to set the assume i2c bus speed
drm/dp: Adjust i2c-over-aux retry count based on message size and i2c bus speed
drm/dp: Define AUX_RETRY_INTERVAL as 500 us
drm/atomic: Fix bookkeeping with TEST_ONLY, v3.
Prepare second round of input updates for 4.3 merge window.
* pm-cpu:
* pm-cpuidle:
* pm-domains:
* pm-cpufreq:
* pm-opp:
Signed-off-by: David Disseldorp <ddiss@suse.de>
Acked-by: Andy Grover <agrover@redhat.com>
Calling transport_generic_request_failure() from here causes list
corruption. We should be using target_complete_cmd() instead.
Which we do in all other cases, so the UNKNOWN_OP case can become just
another member of the big else/if chain in tcmu_handle_completion().
Signed-off-by: Andy Grover <agrover@redhat.com>
This does nothing, and there are many other places where
transport_cmd_check_stop_to_fabric()'s retval is not checked>, If we
wanted to check it here, we should probably do it those other places too.
We don't use it any more.
Current for-next iscsi target is broken:
commit 109e2381749c1cfd94a0d22b2b54142539024973
Author: Roland Dreier <roland@purestorage.com>
Date: Thu Jul 23 14:53:32 2015 -0700
This patch fixes incorrect pr_debug() + atomic_inc_return() usage
within iscsit_increment_maxcmdsn() code.
Also fix funny iscsit_determine_maxcmdsn() usage and update
iscsi_target_do_tx_login_io() code.
Reported-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
Cc: Roland Dreier <roland@purestorage.com>
This patch is a >= v4.1 regression bug-fix where control CDB
emulation logic in commit 38b57f82 now expects a se_cmd->se_sess
pointer to exist when determining T10-PI support is to be exposed
for initiator host ports.
To address this bug, go ahead and add locally generated se_cmd
descriptors for copy-offload block-copy to it's own stand-alone
se_session nexus, while the parent EXTENDED_COPY se_cmd descriptor
remains associated with it's originating se_cmd->se_sess nexus.
Note a valid se_cmd->se_sess is also required for future support
of WRITE_INSERT and READ_STRIP software emulation when submitting
backend I/O to se_device that exposes T10-PI suport.
Reported-by: Alex Gorbachev <ag@iss-integration.com>
Tested-by: Alex Gorbachev <ag@iss-integration.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Doug Gilbert <dgilbert@interlog.com>
Cc: <stable@vger.kernel.org> # v4.1+
This patch adds an optional fabric driver provided SGL limit
that target-core will honor as it's own internal I/O maximum
transfer length limit, as exposed by EVPD=0xb0 block limits
parameters.
This is required for handling cases when host I/O transfer
length exceeds the requested EVPD block limits maximum
transfer length. The initial user of this logic is qla2xxx,
so that we can avoid having to reject I/Os from some legacy
FC hosts where EVPD=0xb0 parameters are not honored.
When se_cmd payload length exceeds the provided limit in
target_check_max_data_sg_nents() code, se_cmd->data_length +
se_cmd->prot_length are reset with se_cmd->residual_count
plus underflow bit for outgoing TFO response callbacks.
It also checks for existing CDB level underflow + overflow
and recalculates final residual_count as necessary.
Note this patch currently assumes 1:1 mapping of PAGE_SIZE
per struct scatterlist entry.
Reported-by: Craig Watson <craig.watson@vanguard-rugged.com>
Cc: Craig Watson <craig.watson@vanguard-rugged.com>
Tested-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
Cc: Arun Easi <arun.easi@qlogic.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-next
three nouveau regression fixes.
* 'linux-4.3' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Typo that snuck in with commit 6979c6303a4abf263753cd9d577d79f05c6e8c47
Signed-off-by: Roy Spliet <rspliet@eclipso.eu>
Reported-by: Pierre Moreau <pierre.morrow@free.fr>
Broken since "gr: convert user classes to new-style nvkm_object"
Tested on a PPC64 G5 + NV34
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Merge third patch-bomb from Andrew Morton:
- even more of the rest of MM
- lib/ updates
- checkpatch updates
- small changes to a few scruffy filesystems
- kmod fixes/cleanups
- kexec updates
- a dma-mapping cleanup series from hch
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits)
dma-mapping: consolidate dma_set_mask
dma-mapping: consolidate dma_supported
dma-mapping: cosolidate dma_mapping_error
dma-mapping: consolidate dma_{alloc,free}_noncoherent
dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}
mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd()
mm: make sure all file VMAs have ->vm_ops set
mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()
mm: mark most vm_operations_struct const
namei: fix warning while make xmldocs caused by namei.c
ipc: convert invalid scenarios to use WARN_ON
zlib_deflate/deftree: remove bi_reverse()
lib/decompress_unlzma: Do a NULL check for pointer
lib/decompressors: use real out buf size for gunzip with kernel
fs/affs: make root lookup from blkdev logical size
sysctl: fix int -> unsigned long assignments in INT_MIN case
kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo
kexec: align crash_notes allocation to make it be inside one physical page
kexec: remove unnecessary test in kimage_alloc_crash_control_pages()
kexec: split kexec_load syscall from kexec core code
Pull late ARM SoC updates from Kevin Hilman:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The bulk of the changes are for samsung/exynos SoCs for some changes
that needed a few minor reworks so ended up a bit late. The others
are mainly for qcom SoCs: a couple fixes and some DTS updates"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits)
ARM: multi_v7_defconfig: Enable PBIAS regulator
soc: qcom: smd: Correct fBLOCKREADINTR handling
soc: qcom: smd: Use correct remote processor ID
soc: qcom: smem: Fix errant private access
ARM: dts: qcom: msm8974-sony-xperia-honami: Use stdout-path
ARM: dts: qcom: msm8960-cdp: Use stdout-path
ARM: dts: qcom: msm8660-surf: Use stdout-path
ARM: dts: qcom: ipq8064-ap148: Use stdout-path
ARM: dts: qcom: apq8084-mtp: Use stdout-path
ARM: dts: qcom: apq8084-ifc6540: Use stdout-path
ARM: dts: qcom: apq8074-dragonboard: Use stdout-path
ARM: dts: qcom: apq8064-ifc6410: Use stdout-path
ARM: dts: qcom: apq8064-cm-qs600: Use stdout-path
ARM: dts: qcom: Label serial nodes for aliasing and stdout-path
reset: ath79: Fix missing spin_lock_init
reset: Add (devm_)reset_control_get stub functions
ARM: EXYNOS: switch to using generic cpufreq driver for exynos4x12
cpufreq: exynos: Remove unselectable rule for arm-exynos-cpufreq.o
ARM: dts: add iommu property to JPEG device for exynos4
ARM: dts: enable SPI1 for exynos4412-odroidu3
git://anongit.freedesktop.org/drm-intel into drm-next
bunch of drm fixes.
* tag 'topic/drm-fixes-2015-09-09' of git://anongit.freedesktop.org/drm-intel:
Fixes headed for v4.3-rc1, including Maarten's DP MST state checker fix
you requested.
* tag 'drm-intel-next-fixes-2015-09-10' of git://anongit.freedesktop.org/drm-intel:
Due to some recent changes in
drm_helper_probe_single_connector_modes_merge_bits(), old custom modes
were not being pruned properly. In current kernels,
drm_mode_validate_basic() is called to sanity-check each mode in the
list. If the sanity-check passes, the mode's status gets set to to
MODE_OK. In older kernels this check was not done, so old custom modes
would still have a status of MODE_UNVERIFIED at this point, and would
therefore be pruned later in the function.
As a result of this new behavior, the list of modes for a device always
includes every custom mode ever configured for the device, with the
largest one listed first. Since desktop environments usually choose the
first preferred mode when a hotplug event is emitted, this had the
result of making it very difficult for the user to reduce the size of
the display.
The qxl driver did implement the mode_valid connector function, but it
was empty. In order to restore the old behavior where old custom modes
are pruned, we implement a proper mode_valid function for the qxl
driver. This function now checks each mode against the last configured
custom mode and the list of standard modes. If the mode doesn't match
any of these, its status is set to MODE_BAD so that it will be pruned as
expected.
Signed-off-by: Jonathon Jongsma <jjongsma@redhat.com>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen terminology fixes from David Vrabel:
"Use the correct GFN/BFN terms more consistently"
* tag 'for-linus-4.3-rc0b-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/xenbus: Rename the variable xen_store_mfn to xen_store_gfn
xen/privcmd: Further s/MFN/GFN/ clean-up
hvc/xen: Further s/MFN/GFN clean-up
video/xen-fbfront: Further s/MFN/GFN clean-up
xen/tmem: Use xen_page_to_gfn rather than pfn_to_gfn
xen: Use correctly the Xen memory terminologies
arm/xen: implement correctly pfn_to_mfn
xen: Make clear that swiotlb and biomerge are dealing with DMA address
Pull networking fixes from David Miller:
1) Fix out-of-bounds array access in netfilter ipset, from Jozsef
Kadlecsik.
2) Use correct free operation on netfilter conntrack templates, from
Daniel Borkmann.
3) Fix route leak in SCTP, from Marcelo Ricardo Leitner.
4) Fix sizeof(pointer) in mac80211, from Thierry Reding.
5) Fix cache pointer comparison in ip6mr leading to missed unlock of
mrt_lock. From Richard Laing.
6) rds_conn_lookup() needs to consider network namespace in key
comparison, from Sowmini Varadhan.
7) Fix deadlock in TIPC code wrt broadcast link wakeups, from Kolmakov
Dmitriy.
8) Fix fd leaks in bpf syscall, from Daniel Borkmann.
9) Fix error recovery when installing ipv6 multipath routes, we would
delete the old route before we would know if we could fully commit
to the new set of nexthops. Fix from Roopa Prabhu.
10) Fix run-time suspend problems in r8152, from Hayes Wang.
11) In fec, don't program the MAC address into the chip when the clocks
are gated off. From Fugang Duan.
12) Fix poll behavior for netlink sockets when using rx ring mmap, from
Daniel Borkmann.
13) Don't allocate memory with GFP_KERNEL from get_stats64 in r8169
driver, from Corinna Vinschen.
14) In TCP Cubic congestion control, handle idle periods better where we
are application limited, in order to keep cwnd from growing out of
control. From Eric Dumzet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
tcp_cubic: better follow cubic curve after idle period
tcp: generate CA_EVENT_TX_START on data frames
xen-netfront: respect user provided max_queues
xen-netback: respect user provided max_queues
r8169: Fix sleeping function called during get_stats64, v2
ether: add IEEE 1722 ethertype - TSN
netlink, mmap: fix edge-case leakages in nf queue zero-copy
netlink, mmap: don't walk rx ring on poll if receive queue non-empty
cxgb4: changes for new firmware 1.14.4.0
net: fec: add netif status check before set mac address
r8152: fix the runtime suspend issues
r8152: split DRIVER_VERSION
ipv6: fix ifnullfree.cocci warnings
add microchip LAN88xx phy driver
stmmac: fix check for phydev being open
net: qlcnic: delete redundant memsets
net: mv643xx_eth: use kzalloc
net: jme: use kzalloc() instead of kmalloc+memset
net: cavium: liquidio: use kzalloc in setup_glist()
net: ipv6: use common fib_default_rule_pref
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
With two exceptions (drm/qxl and drm/radeon) all vm_operations_struct
structs should be constant.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Minchan Kim <minchan@kernel.org>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Instead of custom approach let's use recently introduced seq_hex_dump()
helper.
Cc: Joe Perches <joe@perches.com>
Cc: Tadeusz Struk <tadeusz.struk@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com>
Cc: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com>
helper.
Acked-by: Ingo Tuchscherer <ingo.tuchscherer@de.ibm.com>
helper.
In one case it changes the output from
1111111122222222333333334444444455555555666666667777777788888888
to
11111111 22222222 33333333 44444444 55555555 66666666 77777777 88888888
though it seems it prints same data (by meaning) in both cases. I decide
to choose to use the space divided one.
Acked-by: Helge Deller <deller@gmx.de>
helper.
Acked-by: Tadeusz Struk <tadeusz.struk@intel.com>
Originally that parameter was always reset to num_online_cpus during
module initialisation, which renders it useless.
The fix is to only set max_queues to num_online_cpus when user has not
provided a value.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
provided a value.
Reported-by: Johnny Strom <johnny.strom@linuxsolutions.fi>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=104031
Fixes: 6e85d5ad36a26debc23a9a865c029cbe242b2dc8
Based on the discussion starting at
http://www.spinics.net/lists/netdev/msg342193.html
Tested locally on RTL8168evl/8111evl with various concurrent processes
accessing /proc/net/dev while changing the link state as well as
removing/reloading the r8169 module.
Signed-off-by: Corinna Vinschen <vinschen@redhat.com>
Tested-by: poma <pomidorabelisima@gmail.com>
