path: root/drivers
2016-08-02w1:omap_hdq: fix regressionH. Nikolaus Schaller
Commit e93762bbf681 ("w1: masters: omap_hdq: add support for 1-wire mode") added a statement to clear the hdq_irqstatus flags in hdq_read_byte(). If the hdq reading process is scheduled slowly or interrupts are disabled for a while the hardware read activity might already be finished on entry of hdq_read_byte(). And hdq_isr() already has set the hdq_irqstatus to 0x6 (can be seen in debug mode) denoting that both, the TXCOMPLETE and RXCOMPLETE interrupts occurred in parallel. This means there is no need to wait and the hdq_read_byte() can just read the byte from the hdq controller. By resetting hdq_irqstatus to 0 the read process is forced to be always waiting again (because the if statement always succeeds) but the hardware will not issue another RXCOMPLETE interrupt. This results in a false timeout. After such a situation the hdq bus hangs. Link: http://lkml.kernel.org/r/b724765f87ad276a69625bc19806c8c8844c4590.1469513669.git.hns@goldelico.com Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02w1: add helper macro module_w1_familyAndrew F. Davis
The helper macro module_w1_family can be used in module drivers that only register a w1 driver in their module init functions. Add this macro and use it in all applicable drivers. Link: http://lkml.kernel.org/r/20160531204313.20979-2-afd@ti.com Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02w1: remove need for ida and use PLATFORM_DEVID_AUTOAndrew F. Davis
PLATFORM_DEVID_AUTO can be used to have the platform core assign a unique ID instead of manually creating one with IDA. Do this in all applicable drivers. Link: http://lkml.kernel.org/r/20160531204313.20979-1-afd@ti.com Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/switches: add driver for IDT gen3 switchesAlexandre Bounine
Add RapidIO switch driver for IDT Gen3 switch devices: RXS1632 and RXS2448. [alexandre.bounine@idt.com: fixup for original driver patch] Link: http://lkml.kernel.org/r/1469137596-18241-1-git-send-email-alexandre.bounine@idt.com Link: http://lkml.kernel.org/r/1469125134-16523-14-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: modify for rev.3 specification changesAlexandre Bounine
Implement changes made in RapidIO specification rev.3 to LP-Serial Physical Layer register definitions: - use per-port register offset calculations based on LP-Serial Extended Features Block (EFB) Register Map type (I or II) with different per-port offset step (0x20 vs 0x40 respectfully). - remove deprecated Parallel Physical layer definitions and related code. [alexandre.bounine@idt.com: fix DocBook warning for gen3 update] Link: http://lkml.kernel.org/r/1469191173-19338-1-git-send-email-alexandre.bounine@idt.com Link: http://lkml.kernel.org/r/1469125134-16523-12-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: change inbound window size type to u64Alexandre Bounine
Current definition of map_inb() mport operations callback uses u32 type to specify required inbound window (IBW) size. This is limiting factor because existing hardware - tsi721 and fsl_rio, both support IBW size up to 16GB. Changing type of size parameter to u64 to allow IBW size configurations larger than 4GB. [alexandre.bounine@idt.com: remove compiler warning about size of constant] Link: http://lkml.kernel.org/r/20160802184856.2566-1-alexandre.bounine@idt.com Link: http://lkml.kernel.org/r/1469125134-16523-11-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/idt_gen2: fix locking warningAlexandre Bounine
Fix lockdep warning during device probing: move sysfs initialization out of code protected by a spin lock. Link: http://lkml.kernel.org/r/1469125134-16523-10-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: fix error handling in mbox request/release functionsAlexandre Bounine
Add checking for error code returned by HW-specific mbox open routines. Ensure that resources are properly release if failed. This patch is applicable to kernel versions starting from v2.6.15. Link: http://lkml.kernel.org/r/1469125134-16523-9-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721_dma: advance queue processing from transfer submit callAlexandre Bounine
Add advancing transfer queue immediately from transfer submit call. DMA performance improvement: This will start transfer without waiting for 'issue_pending' command if there is no DMA transfer in progress. Link: http://lkml.kernel.org/r/1469125134-16523-8-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721: add messaging mbox selector parameterAlexandre Bounine
Add module parameter to allow load time configuration of available RapidIO messaging mailboxes (MBOX1 - MBOX4). Having a messaging MBOX selector mask allows to define which MBOXes are controlled by the mport device driver and reserve some of them for direct use by other drivers. Link: http://lkml.kernel.org/r/1469125134-16523-7-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721: add PCIe MRRS override parameterAlexandre Bounine
Add PCIe Maximum Read Request Size (MRRS) adjustment parameter to allow users to override configuration register value set during PCIe bus initialization. Performance of Tsi721 device as PCIe bus master can be improved if MRRS is set to its maximum value (4096 bytes). Some platforms have limitations for supported MRRS and therefore the default value should be preserved, unless it is known that given platform supports full set of MRRS values defined by PCI Express specification. Link: http://lkml.kernel.org/r/1469125134-16523-6-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio/tsi721_dma: add channel mask and queue size parametersAlexandre Bounine
Add module parameters to allow load time configuration of DMA channels. Depending on application, performance of DMA data transfers can benefit from adjusted sizes of buffer descriptor ring and/or transaction requests queue. Having HW DMA channel selector mask allows to define which channels (from seven available) are controlled by the mport device driver and reserve some of them for direct use by other drivers. Link: http://lkml.kernel.org/r/1469125134-16523-5-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: fix return value description for dma_prep functionsAlexandre Bounine
Update return value description for rio_dma_prep_... functions to include error-valued pointer that can be returned by HW mport device drivers. Return values from these functions must be checked using IS_ERR_OR_NULL macro. This patch is applicable to kernel versions starting from v4.6-rc1. Link: http://lkml.kernel.org/r/1469125134-16523-4-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: remove unnecessary 0x prefixes before %pa extension usesJoe Perches
Patch series "RapidIO subsystem updates". This set of patches contains RapidIO subsystem fixes and updates that have been made since kernel v4.6. The most significant update brings changes related to the latest revision of RapidIO specification (rev.3.x) and introduction of next generation of RapidIO switches by IDT (RXS1632 and RXS2448). This patch (of 13): This is RapidIO part of the original patch submitted by Joe Perches. (see: https://lkml.org/lkml/2016/3/5/19) Since commit 3cab1e711297 ("lib/vsprintf: refactor duplicate code to special_hex_number()") %pa uses have been output with a 0x prefix. These 0x prefixes in the formats are unnecessary. Link: http://lkml.kernel.org/r/1469125134-16523-2-git-send-email-alexandre.bounine@idt.com Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02rapidio: add RapidIO channelized messaging driverAlexandre Bounine
Add channelized messaging driver to support native RapidIO messaging exchange between multiple senders/recipients on devices that use kernel RapidIO subsystem services. This device driver is the result of collaboration within the RapidIO.org Software Task Group (STG) between Texas Instruments, Prodrive Technologies, Nokia Networks, BAE and IDT. Additional input was received from other members of RapidIO.org. The objective was to create a character mode driver interface which exposes messaging capabilities of RapidIO endpoint devices (mports) directly to applications, in a manner that allows the numerous and varied RapidIO implementations to interoperate. This char mode device driver allows user-space applications to setup messaging communication channels using single shared RapidIO messaging mailbox. By default this driver uses RapidIO MBOX_1 (MBOX_0 is reserved for use by RIONET Ethernet emulation driver). [weiyj.lk@gmail.com: rapidio/rio_cm: fix return value check in riocm_init()] Link: http://lkml.kernel.org/r/1469198221-21970-1-git-send-email-alexandre.bounine@idt.com Link: http://lkml.kernel.org/r/1468952862-18056-1-git-send-email-alexandre.bounine@idt.com Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Barry Wood <barry.wood@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Andre van Herk <andre.van.herk@prodrive-technologies.com> Cc: Barry Wood <barry.wood@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02firmware: support loading into a pre-allocated bufferStephen Boyd
Some systems are memory constrained but they need to load very large firmwares. The firmware subsystem allows drivers to request this firmware be loaded from the filesystem, but this requires that the entire firmware be loaded into kernel memory first before it's provided to the driver. This can lead to a situation where we map the firmware twice, once to load the firmware into kernel memory and once to copy the firmware into the final resting place. This creates needless memory pressure and delays loading because we have to copy from kernel memory to somewhere else. Let's add a request_firmware_into_buf() API that allows drivers to request firmware be loaded directly into a pre-allocated buffer. This skips the intermediate step of allocating a buffer in kernel memory to hold the firmware image while it's read from the filesystem. It also requires that drivers know how much memory they'll require before requesting the firmware and negates any benefits of firmware caching because the firmware layer doesn't manage the buffer lifetime. For a 16MB buffer, about half the time is spent performing a memcpy from the buffer to the final resting place. I see loading times go from 0.081171 seconds to 0.047696 seconds after applying this patch. Plus the vmalloc pressure is reduced. This is based on a patch from Vikram Mulukutla on codeaurora.org: https://www.codeaurora.org/cgit/quic/la/kernel/msm-3.18/commit/drivers/base/firmware_class.c?h=rel/msm-3.18&id=0a328c5f6cd999f5c591f172216835636f39bcb5 Link: http://lkml.kernel.org/r/20160607164741.31849-4-stephen.boyd@linaro.org Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Vikram Mulukutla <markivx@codeaurora.org> Cc: Mark Brown <broonie@kernel.org> Cc: Ming Lei <ming.lei@canonical.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02firmware: provide infrastructure to make fw caching optionalVikram Mulukutla
Some low memory systems with complex peripherals cannot afford to have the relatively large firmware images taking up valuable memory during suspend and resume. Change the internal implementation of firmware_class to disallow caching based on a configurable option. In the near future, variants of request_firmware will take advantage of this feature. Link: http://lkml.kernel.org/r/20160607164741.31849-3-stephen.boyd@linaro.org [stephen.boyd@linaro.org: Drop firmware_desc design and use flags] Signed-off-by: Vikram Mulukutla <markivx@codeaurora.org> Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Mark Brown <broonie@kernel.org> Cc: Ming Lei <ming.lei@canonical.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02firmware: consolidate kmap/read/write logicStephen Boyd
Some systems are memory constrained but they need to load very large firmwares. The firmware subsystem allows drivers to request this firmware be loaded from the filesystem, but this requires that the entire firmware be loaded into kernel memory first before it's provided to the driver. This can lead to a situation where we map the firmware twice, once to load the firmware into kernel memory and once to copy the firmware into the final resting place. This design creates needless memory pressure and delays loading because we have to copy from kernel memory to somewhere else. This patch sets adds support to the request firmware API to load the firmware directly into a pre-allocated buffer, skipping the intermediate copying step and alleviating memory pressure during firmware loading. The drawback is that we can't use the firmware caching feature because the memory for the firmware cache is not managed by the firmware layer. This patch (of 3): We use similar structured code to read and write the kmapped firmware pages. The only difference is read copies from the kmap region and write copies to it. Consolidate this into one function to reduce duplication. Link: http://lkml.kernel.org/r/20160607164741.31849-2-stephen.boyd@linaro.org Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Cc: Vikram Mulukutla <markivx@codeaurora.org> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Mark Brown <broonie@kernel.org> Cc: Ming Lei <ming.lei@canonical.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02fbdev/bfin_adv7393fb: move DRIVER_NAME before its first useBorislav Petkov
Move the DRIVER_NAME macro definition before the first usage site and fix build error. Link: http://lkml.kernel.org/r/20160801163937.GA28119@nazgul.tnic Signed-off-by: Borislav Petkov <bp@suse.de> Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02dynamic_debug: only add header when usedLuis de Bethencourt
kernel.h header doesn't directly use dynamic debug, instead we can include it in module.c (which used it via kernel.h). printk.h only uses it if CONFIG_DYNAMIC_DEBUG is on, changing the inclusion to only happen in that case. Link: http://lkml.kernel.org/r/1468429793-16917-1-git-send-email-luisbg@osg.samsung.com [luisbg@osg.samsung.com: include dynamic_debug.h in drb_int.h] Link: http://lkml.kernel.org/r/1468447828-18558-2-git-send-email-luisbg@osg.samsung.com Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Borislav Petkov <bp@suse.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02treewide: replace obsolete _refok by __refFabian Frederick
There was only one use of __initdata_refok and __exit_refok __init_refok was used 46 times against 82 for __ref. Those definitions are obsolete since commit 312b1485fb50 ("Introduce new section reference annotations tags: __ref, __refdata, __refconst") This patch removes the following compatibility definitions and replaces them treewide. /* compatibility defines */ #define __init_refok __ref #define __initdata_refok __refdata #define __exit_refok __ref I can also provide separate patches if necessary. (One patch per tree and check in 1 month or 2 to remove old definitions) [akpm@linux-foundation.org: coding-style fixes] Link: http://lkml.kernel.org/r/1466796271-3043-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Ingo Molnar <mingo@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02memstick: don't allocate unused major for ms_blockNeilBrown
When alloc_disk(0) is used the ->major number is completely ignored. All devices are allocated with a major of BLOCK_EXT_MAJOR. So remove registration and deregistration of 'major'. Link: http://lkml.kernel.org/r/20160602064318.4403.49955.stgit@noble Signed-off-by: NeilBrown <neilb@suse.com> Cc: Keith Busch <keith.busch@intel.com> Cc: Jens Axboe <axboe@fb.com> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull more s390 updates from Martin Schwidefsky: - some cleanup for the hugetlbfs pte/pmd conversion functions - the code to check for the minimum CPU type is converted from assembler to C and an informational message is added in case the CPU is not new enough to run the kernel - bug fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/ftrace/jprobes: Fix conflict between jprobes and function graph tracing s390: Define AT_VECTOR_SIZE_ARCH for ARCH_DLINFO s390/zcrypt: fix possible memory leak in ap_module_init() s390/numa: only set possible nodes within node_possible_map s390/als: fix compile with gcov enabled s390/facilities: do not generate DWORDS define anymore s390/als: print missing facilities on facility mismatch s390/als: print machine type on facility mismatch s390/als: convert architecture level set code to C s390/sclp: move uninitialized data to data section s390/zcrypt: Fix zcrypt suspend/resume behavior s390/cio: fix premature wakeup during chp configure s390/cio: convert cfg_lock mutex to spinlock s390/mm: clean up pte/pmd encoding
2016-08-01Merge tag 'drm-for-v4.8' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Merge drm updates from Dave Airlie: "This is the main drm pull request for 4.8. I'm down with a cold at the moment so hopefully this isn't in too bad a state, I finished pulling stuff last week mostly (nouveau fixes just went in today), so only this message should be influenced by illness. Apologies to anyone who's major feature I missed :-) Core: Lockless GEM BO freeing Non-blocking atomic work Documentation changes (rst/sphinx) Prep for new fencing changes Simple display helpers Master/auth changes Register/unregister rework Loads of trivial patches/fixes. New stuff: ARM Mali display driver (not the 3D chip) sii902x RGB->HDMI bridge Panel: Support for new panels Improved backlight support Bridge: Convert ADV7511 to bridge driver ADV7533 support TC358767 (DSI/DPI to eDP) encoder chip support i915: BXT support enabled by default GVT-g infrastructure GuC command submission and fixes BXT workarounds SKL/BKL workarounds Demidlayering device registration Thundering herd fixes Missing pci ids Atomic updates amdgpu/radeon: ATPX improvements for better dGPU power control on PX systems New power features for CZ/BR/ST Pipelined BO moves and evictions in TTM GPU scheduler improvements GPU reset improvements Overclocking on dGPUs with amdgpu Polaris powermanagement enabled nouveau: GK20A/GM20B volt and clock improvements. Initial support for GP100/GP104 GPUs, GP104 will not yet support acceleration due to NVIDIA having not released firmware for them as of yet. exynos: Exynos5433 SoC with IOMMU support. vc4: Shader validation for branching imx-drm: Atomic mode setting conversion Reworked DMFC FIFO allocation External bridge support analogix-dp: RK3399 eDP support Lots of fixes. rockchip: Lots of small fixes. msm: DT bindings cleanups Shrinker and madvise support ASoC HDMI codec support tegra: Host1x driver cleanups SOR reworking for DP support Runtime PM support omapdrm: PLL enhancements Header refactoring Gamma table support arcgpu: Simulator support virtio-gpu: Atomic modesetting fixes. rcar-du: Misc fixes. mediatek: MT8173 HDMI support sti: ASOC HDMI codec support Minor fixes fsl-dcu: Suspend/resume support Bridge support amdkfd: Minor fixes. etnaviv: Enable GPU clock gating hisilicon: Vblank and other fixes" * tag 'drm-for-v4.8' of git://people.freedesktop.org/~airlied/linux: (1575 commits) drm/nouveau/gr/nv3x: fix instobj write offsets in gr setup drm/nouveau/acpi: fix lockup with PCIe runtime PM drm/nouveau/acpi: check for function 0x1B before using it drm/nouveau/acpi: return supported DSM functions drm/nouveau/acpi: ensure matching ACPI handle and supported functions drm/nouveau/fbcon: fix font width not divisible by 8 drm/amd/powerplay: remove enable_clock_power_gatings_tasks from initialize and resume events drm/amd/powerplay: move clockgating to after ungating power in pp for uvd/vce drm/amdgpu: add query device id and revision id into system info entry at CGS drm/amdgpu: add new definition in bif header drm/amd/powerplay: rename smum header guards drm/amdgpu: enable UVD context buffer for older HW drm/amdgpu: fix default UVD context size drm/amdgpu: fix incorrect type of info_id drm/amdgpu: make amdgpu_cgs_call_acpi_method as static drm/amdgpu: comment out unused defaults_staturn_pro static const structure to fix the build drm/amdgpu: enable UVD VM only on polaris drm/amdgpu: increase timeout of IB test drm/amdgpu: add destroy session when generate VCE destroy msg. drm/amd: fix deadlock of job_list_lock V2 ...
2016-08-02Merge branch 'linux-4.8' of git://github.com/skeggsb/linux into drm-nextDave Airlie
Runtime PM fixes, fbcon and nv30 fix. * 'linux-4.8' of git://github.com/skeggsb/linux: drm/nouveau/gr/nv3x: fix instobj write offsets in gr setup drm/nouveau/acpi: fix lockup with PCIe runtime PM drm/nouveau/acpi: check for function 0x1B before using it drm/nouveau/acpi: return supported DSM functions drm/nouveau/acpi: ensure matching ACPI handle and supported functions drm/nouveau/fbcon: fix font width not divisible by 8
2016-08-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Device tree contents continue to be the largest branches we submit. This time around, some of the contents worth pointing out is: New SoC platforms: - Freescale i.MX 7Solo - Broadcom BCM23550 - Cirrus Logic EP7209 and EP7211 (clps711x platforms)_ - Hisilicon HI3519 - Renesas R8A7792 Some of the other delta that is sticking out, line-count wise: - Exynos moves of IP blocks under an SoC bus, which causes a large delta due to indentation changes - a new Tegra K1 board: Apalis - a bunch of small updates to many Allwinner platforms; new hardware support, some cleanup, etc" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits) ARM: dts: sun8i: Add dts file for inet86dz board ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04 ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts ARM: dts: sun5i: reference-design-tablet: Remove mention of q8 ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi ARM: dts: at91: Don't build unnecessary dtbs ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions ARM: dts: at91: at91sam9g25ek: fix isi endpoint node ARM: dts: at91: move isi definition to at91sam9g25ek ARM: dts: at91: fix i2c-gpio node name ARM: dts: at91: vinco: fix regulator name ARM: dts: at91: ariag25 : fix onewire node ...
2016-08-01Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "Driver updates for ARM SoCs. A slew of changes this release cycle. The reset driver tree, that we merge through arm-soc for historical reasons, is also sizable this time around. Among the changes: - clps711x: Treewide changes to compatible strings, merged here for simplicity. - Qualcomm: SCM firmware driver cleanups, move to platform driver - ux500: Major cleanups, removal of old mach-specific infrastructure. - Atmel external bus memory driver - Move of brcmstb platform to the rest of bcm - PMC driver updates for tegra, various fixes and improvements - Samsung platform driver updates to support 64-bit Exynos platforms - Reset controller cleanups moving to devm_reset_controller_register() APIs - Reset controller driver for Amlogic Meson - Reset controller driver for Hisilicon hi6220 - ARM SCPI power domain support" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (100 commits) ARM: ux500: consolidate base platform files ARM: ux500: move soc_id driver to drivers/soc ARM: ux500: call ux500_setup_id later ARM: ux500: consolidate soc_device code in id.c ARM: ux500: remove cpu_is_u* helpers ARM: ux500: use CLK_OF_DECLARE() ARM: ux500: move l2x0 init to .init_irq mfd: db8500 stop passing around platform data ASoC: ab8500-codec: remove platform data based probe ARM: ux500: move ab8500_regulator_plat_data into driver ARM: ux500: remove unused regulator data soc: raspberrypi-power: add CONFIG_OF dependency firmware: scpi: add CONFIG_OF dependency video: clps711x-fb: Changing the compatibility string to match with the smallest supported chip input: clps711x-keypad: Changing the compatibility string to match with the smallest supported chip pwm: clps711x: Changing the compatibility string to match with the smallest supported chip serial: clps711x: Changing the compatibility string to match with the smallest supported chip irqchip: clps711x: Changing the compatibility string to match with the smallest supported chip clocksource: clps711x: Changing the compatibility string to match with the smallest supported chip clk: clps711x: Changing the compatibility string to match with the smallest supported chip ...
2016-08-01Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "Improved and new platform support for various SoCs: New SoC support: - Broadcom BCM23550 - Freescale i.MX7Solo - Qualcomm MDM9615 - Renesas r8a7792 Improvements: - convert clps711x to multiplatform - debug uart improvements for Atmel platforms - Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram - OMAP tweaks and improvements to hwmod - OMAP support for kexec on SMP" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits) ARM: davinci: fix build break because of undeclared dm365_evm_snd_data ARM: s3c64xx: smartq: Avoid sparse warnings ARM: sti: Implement dummy L2 cache's write_sec ARM: STi: Update machine _namestr to be more generic. arm: meson: explicitly select clk drivers ARM: tango: add Suspend-to-RAM support ARM: hisi: consolidate the hisilicon machine entries ARM: tango: fix CONFIG_HOTPLUG_CPU=n build MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry MAINTAINERS: Update BCM63XX entry MAINTAINERS: Add NS2 entry MAINTAINERS: Fix nsp false-positives MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs ARM: clps711x: Switch to MULTIPLATFORM ARM: clps711x: Remove boards support ARM: clps711x: Add basic DT support ARM: clps711x: Reduce static map size ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu ARM: oxnas: Change OX810SE default driver config ...
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-08-01Merge tag 'hwmon-for-linus-v4.8-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull more hwmon updates from Guenter Roeck: - Improved error handling in tmp102, lm75, and lm90 drivers - Bug fixes in sht3x, ftsteutates, iio_hwmon, and adt7411 drivers * tag 'hwmon-for-linus-v4.8-2' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (adt7411) set sane values for CFG1 and CFG3 hwmon: (iio_hwmon) fix memory leak in name attribute hwmon: (ftsteutates) Fix potential memory access error hwmon: (tmp102) Improve error handling hwmon: (lm75) Improve error handling hwmon: (lm90) Improve error handling hwmon: (lm90) Add missing assignment hwmon: (sht3x) set initial jiffies to last_update
2016-08-01Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: "This fixes a number of regressions in the marvell cesa driver caused by the chaining work, and a regression in lib/mpi that leads to a GFP_KERNEL allocation with preemption disabled" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: marvell - Don't copy IV vectors from the _process op for ciphers lib/mpi: Fix SG miter leak crypto: marvell - Update cache with input sg only when it is unmapped crypto: marvell - Don't chain at DMA level when backlog is disabled crypto: marvell - Fix memory leaks in TDMA chain for cipher requests
2016-08-01Merge tag 'backlight-for-linus-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight Pull backlight updates from Lee Jones: "Add support for an enable regulator to lp855x_bl" * tag 'backlight-for-linus-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight: backlight: lp855x: Add enable regulator
2016-08-01Merge tag 'mfd-for-linus-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Core Framework: - New API to call bespoke pre/post IRQ handlers; Regmap New Device Support: - Add support for RN5T567 to rn5t618 - Add support for COMe-cSL6 and COMe-mAL10 to kempld-core New Functionality: - Add support for USB Power Supply to axp20x - Add support for Power Key to hi655x-pmic Fix-ups: - Update MAINTAINERS; Dialog, Altera - Remove module support; max77843, max77620, max8998, max8997, max8925-i2c - Add module support; max14577 - Constifying; max77620 - Allow bespoke IRQ masking/unmasking; max77620 - Remove superfluous code; arizona, qcom_rpm, smsc-ece1099 - Power Management fixups; arizona-core - Error-path improvement; twl-core, dm355evm_msp, smsc-ece1099, hi655x - Clocking fixups; twl6040 - Trivial (spelling, headers, coding-style, whitespace, (re)naming); si476x-i2c, omap-usb-tll, ti_am335x_tscadc, tps6507, hi655x-pmic Bug Fixes: - Fix offset error for MSM8660; qcom_rpm - Fix possible spurious IRQs; arizona, hi655x-pmic" * tag 'mfd-for-linus-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (42 commits) mfd: qcom_rpm: Parametrize also ack selector size mfd: twl6040: Handle mclk used for HPPLL and optional internal clock source mfd: Add support for COMe-cSL6 and COMe-mAL10 to Kontron PLD driver mfd: hi655x: Fix return value check in hi655x_pmic_probe() mfd: smsc-ece1099: Return directly after a function failure in smsc_i2c_probe() mfd: smsc-ece1099: Delete an unnecessary variable initialisation in smsc_i2c_probe() mfd: dm355evm_msp: Return directly after a failed platform_device_alloc() in add_child() mfd: twl-core: Refactoring for add_numbered_child() mfd: twl-core: Return directly after a failed platform_device_alloc() in add_numbered_child() mfd: arizona: Add missing disable of PM runtime on probe error path mfd: stmpe: Move platform data into MFD driver mfd: max14577: Allow driver to be built as a module mfd: max14577: Use module_init() instead of subsys_initcall() mfd: arizona: Remove some duplicate defines mfd: qcom_rpm: Remove unused define mfd: hi655x-pmic: Add powerkey device to hi655x PMIC driver mfd: hi655x-pmic: Rename some interrupt macro names mfd: hi655x-pmic: Fixup issue with un-acked interrupts mfd: arizona: Check if AOD interrupts are pending before dispatching mfd: qcom_rpm: Fix offset error for msm8660 ...
2016-08-01Merge tag 'iommu-updates-v4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: - big-endian support and preparation for defered probing for the Exynos IOMMU driver - simplifications in iommu-group id handling - support for Mediatek generation one IOMMU hardware - conversion of the AMD IOMMU driver to use the generic IOVA allocator. This driver now also benefits from the recent scalability improvements in the IOVA code. - preparations to use generic DMA mapping code in the Rockchip IOMMU driver - device tree adaption and conversion to use generic page-table code for the MSM IOMMU driver - an iova_to_phys optimization in the ARM-SMMU driver to greatly improve page-table teardown performance with VFIO - various other small fixes and conversions * tag 'iommu-updates-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (59 commits) iommu/amd: Initialize dma-ops domains with 3-level page-table iommu/amd: Update Alias-DTE in update_device_table() iommu/vt-d: Return error code in domain_context_mapping_one() iommu/amd: Use container_of to get dma_ops_domain iommu/amd: Flush iova queue before releasing dma_ops_domain iommu/amd: Handle IOMMU_DOMAIN_DMA in ops->domain_free call-back iommu/amd: Use dev_data->domain in get_domain() iommu/amd: Optimize map_sg and unmap_sg iommu/amd: Introduce dir2prot() helper iommu/amd: Implement timeout to flush unmap queues iommu/amd: Implement flush queue iommu/amd: Allow NULL pointer parameter for domain_flush_complete() iommu/amd: Set up data structures for flush queue iommu/amd: Remove align-parameter from __map_single() iommu/amd: Remove other remains of old address allocator iommu/amd: Make use of the generic IOVA allocator iommu/amd: Remove special mapping code for dma_ops path iommu/amd: Pass gfp-flags to iommu_map_page() iommu/amd: Implement apply_dm_region call-back iommu/amd: Create a list of reserved iova addresses ...
2016-08-01Merge branch 'mailbox-for-next' of ↵Linus Torvalds
git://git.linaro.org/landing-teams/working/fujitsu/integration Pull mailbox updates from Jussi Brar: "Broadcom: - New PDC controller driver and bindings Misc: - PL320 - Convert from 'raw' IO to 'relaxed' version - Test - fix dangling pointer" * 'mailbox-for-next' of git://git.linaro.org/landing-teams/working/fujitsu/integration: mailbox: Fix format and type mismatches in Broadcom PDC driver mailbox: Add Broadcom PDC mailbox driver dt-bindings: add bindings documentation for PDC driver. mailbox: pl320: remove __raw IO mailbox: mailbox-test: set tdev->signal to NULL after freeing
2016-07-31Merge tag 'mmc-v4.8' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC updates from Ulf Hansson: "MMC core: - A couple of changes to improve the support for erase/discard/trim cmds - Add eMMC HS400 enhanced strobe support - Show OCR and DSR registers in SYSFS for MMC/SD cards - Correct and improve busy detection logic for MMC switch (CMD6) cmds - Disable HPI cmds for certain broken Hynix eMMC cards - Allow MMC hosts to specify non-support for SD and MMC cmds - Some minor additional fixes MMC host: - sdhci: Re-works, fixes and clean-ups - sdhci: Add HW auto re-tuning support - sdhci: Re-factor code to prepare for adding support for eMMC CMDQ - sdhci-esdhc-imx: Fixes and clean-ups - sdhci-esdhc-imx: Update system PM support - sdhci-esdhc-imx: Enable HW auto re-tuning - sdhci-bcm2835: Remove driver as sdhci-iproc is used instead - sdhci-brcmstb: Add new driver for Broadcom BRCMSTB SoCs - sdhci-msm: Add support for UHS cards - sdhci-tegra: Improve support for UHS cards - sdhci-of-arasan: Update phy support for Rockchip SoCs - sdhci-of-arasan: Deploy enhanced strobe support - dw_mmc: Some fixes and clean-ups - dw_mmc: Enable support for erase/discard/trim cmds - dw_mmc: Enable CMD23 support - mediatek: Some fixes related to the eMMC HS400 support - sh_mmcif: Improve support for HW busy detection - rtsx_pci: Enable support for erase/discard/trim cmds" * tag 'mmc-v4.8' of git://git.linaro.org/people/ulf.hansson/mmc: (135 commits) mmc: rtsx_pci: Remove deprecated create_singlethread_workqueue mmc: rtsx_pci: Enable MMC_CAP_ERASE to allow erase/discard/trim requests mmc: rtsx_pci: Use the provided busy timeout from the mmc core mmc: sdhci-pltfm: Drop define for SDHCI_PLTFM_PMOPS mmc: sdhci-pltfm: Convert to use the SET_SYSTEM_SLEEP_PM_OPS mmc: sdhci-pltfm: Make sdhci_pltfm_suspend|resume() static mmc: sdhci-esdhc-imx: Use common sdhci_suspend|resume_host() mmc: sdhci-esdhc-imx: Assign system PM ops within #ifdef CONFIG_PM_SLEEP mmc: sdhci-sirf: Remove non needed #ifdef CONFIG_PM* for dev_pm_ops mmc: sdhci-s3c: Remove non needed #ifdef CONFIG_PM for dev_pm_ops mmc: sdhci-pxav3: Remove non needed #ifdef CONFIG_PM for dev_pm_ops mmc: sdhci-of-esdhc: Simplify code by using SIMPLE_DEV_PM_OPS mmc: sdhci-acpi: Simplify code by using SET_SYSTEM_SLEEP_PM_OPS mmc: sdhci-pci-core: Simplify code by using SET_SYSTEM_SLEEP_PM_OPS mmc: Change the max discard sectors and erase response when HW busy detect phy: rockchip-emmc: Wait even longer for the DLL to lock phy: rockchip-emmc: Be tolerant to card clock of 0 in power on mmc: sdhci-of-arasan: Revert: Always power the PHY off/on when clock changes mmc: sdhci-msm: Add support for UHS cards mmc: sdhci-msm: Add set_uhs_signaling() implementation ...
2016-07-31Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "Core: - min and max timeout improvements, WDOG_HW_RUNNING improvements, status funtionality - Add a device managed API for watchdog_register_device() New watchdog drivers: - Aspeed SoCs - Maxim PMIC MAX77620 - Amlogic Meson GXBB SoC Enhancements: - support for the r8a7796 watchdog device - support for F81866 watchdog device - support for 5th variation of Apollo Lake - support for MCP78S chipset - clean-up of softdog.c watchdog device driver - pic32-wdt and pic32-dmt fixes - Documentation/watchdog: watchdog-test improvements - several other fixes and improvements" * git://www.linux-watchdog.org/linux-watchdog: (50 commits) watchdog: gpio_wdt: Fix missing platform_set_drvdata() in gpio_wdt_probe() watchdog: core: Clear WDOG_HW_RUNNING before calling the stop function watchdog: core: Fix error handling of watchdog_dev_init() watchdog: pic32-wdt: Fix return value check in pic32_wdt_drv_probe() watchdog: pic32-dmt: Remove .owner field for driver watchdog: pic32-wdt: Remove .owner field for driver watchdog: renesas-wdt: Add support for the r8a7796 wdt Documentation/watchdog: check return value for magic close watchdog: sbsa: Drop status function watchdog: Implement status function in watchdog core watchdog: tangox: Set max_hw_heartbeat_ms instead of max_timeout watchdog: change watchdog_need_worker logic watchdog: add support for MCP78S chipset in nv_tco watchdog: bcm2835_wdt: remove redundant ->set_timeout callback watchdog: bcm2835_wdt: constify _ops and _info structures dt-bindings: watchdog: Add Meson GXBB Watchdog bindings watchdog: Add Meson GXBB Watchdog Driver watchdog: qcom: configure BARK time in addition to BITE time watchdog: qcom: add option for standalone watchdog not in timer block watchdog: qcom: update device tree bindings ...
2016-07-31hwmon: (adt7411) set sane values for CFG1 and CFG3Michael Walle
According to the datasheet we have to set some bits as 0 and others as 1. Make sure we do this for CFG1 and CFG3. Signed-off-by: Michael Walle <michael@walle.cc> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (iio_hwmon) fix memory leak in name attributeQuentin Schulz
The "name" variable's memory is now freed when the device is destructed thanks to devm function. Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com> Reported-by: Guenter Roeck <linux@roeck-us.net> Fixes: e0f8a24e0edfd ("staging:iio::hwmon interface client driver.") Fixes: 61bb53bcbdd86 ("hwmon: (iio_hwmon) Add support for humidity sensors") Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (ftsteutates) Fix potential memory access errorGuenter Roeck
Using set_bit() to set a bit in an integer is not a good idea, since the function expects an unsigned long as argument, which can be 64 bit wide. Coverity reports this problem as >>> CID 1364488: Memory - illegal accesses (INCOMPATIBLE_CAST) >>> Pointer "&ret" points to an object whose effective type is "int" >>> (32 bits, signed) but is dereferenced as a wider "unsigned +long" (64 bits, unsigned). This may lead to memory corruption. 245 set_bit(1, (unsigned long *)&ret); Just use BIT instead. Cc: Thilo Cestonaro <thilo@cestona.ro> Fixes: 08426eda58e0 ("hwmon: Add driver for FTS BMC chip "Teutates"") Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (tmp102) Improve error handlingGuenter Roeck
Use devm_add_action_or_reset() instead of devm_add_action(), and check its return code. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (lm75) Improve error handlingGuenter Roeck
Use devm_add_action_or_reset() instead of devm_add_action(), and check its return value. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (lm90) Improve error handlingGuenter Roeck
Replace devm_add_action() with devm_add_action_or_reset(), and check its return value. Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (lm90) Add missing assignmentGuenter Roeck
Coverity reports the following error. >>> CID 1364474: Error handling issues (CHECKED_RETURN) >>> Calling "lm90_read_reg" without checking return value (as is done >>> elsewhere 28 out of 29 times). 532 lm90_read_reg(client, LM90_REG_R_REMOTE_LOWH); 533 if (val < 0) 534 return val; Fixes: 10bfef47bd259 ("hwmon: (lm90) Read limit registers only once") Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31hwmon: (sht3x) set initial jiffies to last_updateMatt Ranostay
Handling the wraparound requires the data->last_update to be set to an initial jiffies value. Otherwise on 32-bit systems you will not be able to request a reading till the 5 minute jiffies rollover happens. Cc: Guenter Roeck <linux@roeck-us.net> Cc: David Frey <david.frey@sensirion.com> Signed-off-by: Matt Ranostay <mranostay@gmail.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Fixes: 7c84f7f80d6fc ("hwmon: add support for Sensirion SHT3x sensors") Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-31s390/zcrypt: fix possible memory leak in ap_module_init()Wei Yongjun
ap_configuration is malloced in ap_module_init() and should be freed before leaving from the error handling cases, otherwise it may cause memory leak. Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-07-31s390/zcrypt: Fix zcrypt suspend/resume behaviorIngo Tuchscherer
The device suspend call triggers all ap devices to fetch potentially available response messages from the queues. Therefore the corresponding zcrypt device, that is allocated asynchronously after ap device probing, needs to be fully prepared. This race condition could lead to uninitialized response buffers while trying to read from the queues. Introduce a new callback within the ap layer to get noticed when a zcrypt device is fully prepared. Additional checks prevent reading from devices that are not fully prepared. Signed-off-by: Ingo Tuchscherer <ingo.tuchscherer@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-07-31s390/cio: fix premature wakeup during chp configureSebastian Ott
We store requests for channel path configure operations in an array but maintain an additional cfg_busy variable (indicating if we have requests stored in said array). When 2 tasks request a channel path configure operation cfg_busy could be set to 0 even if we still have unprocessed requests. This would lead to the second task being woken up although its request was not processed yet. Fix that by getting rid of cfg_busy and use the chp_cfg_task array in the wake up condition. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-07-31s390/cio: convert cfg_lock mutex to spinlockSebastian Ott
cfg_lock is never held long and we don't want to sleep while the lock is being held. Thus it can be converted to a simple spinlock. In addition we can now use the lock during the evaluation of a wake_up condition. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-07-31Merge tag 'sound-4.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "The majority of this update is about ASoC, including a few new drivers, and the rest are mostly minor changes. The only substantial change in ALSA core is about the additional error handling in the compress-offload API. Below are highlights: - Add the error propagating support in compress-offload API - HD-audio: a usual Dell headset fixup, an Intel HDMI/DP fix, and the default mixer setup change ot turn off the loopback - Lots of updates for ASoC Intel drivers, mostly board support and bug fixing, and to the NAU8825 driver - Work on generalizing bits of simple-card to allow more code sharing with the Renesas rsrc-card (which can't use simple-card due to DPCM) - Removal of the Odroid X2 driver due to replacement with simple-card - Support for several new Mediatek platforms and associated boards - New ASoC drivers for Allwinner A10, Analog Devices ADAU7002, Broadcom Cygnus, Cirrus Logic CS35L33 and CS53L30, Maxim MAX8960 and MAX98504, Realtek RT5514 and Wolfson WM8758" * tag 'sound-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (278 commits) sound: oss: Use kernel_read_file_from_path() for mod_firmware_load() ASoC: Intel: Skylake: Delete an unnecessary check before the function call "release_firmware" ASoC: Intel: Skylake: Fix NULL Pointer exception in dynamic_debug. ASoC: samsung: Specify DMA channels through struct snd_dmaengine_pcm_config ASoC: samsung: Fix error paths in the I2S driver's probe() ASoC: cs53l30: Fix bit shift issue of TDM mode ASoC: cs53l30: Fix a bug for TDM slot location validation ASoC: rockchip: correct the spdif clk ALSA: echoaudio: purge contradictions between dimension matrix members and total number of members ASoC: rsrc-card: use asoc_simple_card_parse_card_name() ASoC: rsrc-card: use asoc_simple_dai instead of rsrc_card_dai ASoC: rsrc-card: use asoc_simple_card_parse_dailink_name() ASoC: simple-card: use asoc_simple_card_parse_card_name() ASoC: simple-card-utils: add asoc_simple_card_parse_card_name() ASoC: simple-card: use asoc_simple_card_parse_dailink_name() ASoC: simple-card-utils: add asoc_simple_card_set_dailink_name() ASoC: nau8825: drop redundant idiom when converting integer to boolean ASoC: nau8825: jack connection decision with different insertion logic ASoC: mediatek: Add HDMI dai-links to the mt8173-rt5650 machine driver ASoC: mediatek: mt2701: fix non static symbol warning ...
