path: root/drivers
2008-12-29V4L/DVB (9438): Bug! RTF is signedArvo Jarve
Signed-off-by: Arvo Jarve <arvo@softshark.ee> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9437): Disable Symbol rate auto scan featureManu Abraham
2008-12-29V4L/DVB (9436): Fix a typo in the previous commitManu Abraham
2008-12-29V4L/DVB (9435): Add post process interfacesManu Abraham
2008-12-29V4L/DVB (9434): Limit initial RF AGC gainManu Abraham
2008-12-29V4L/DVB (9433): Limit bandwidth with a 3dB response fallArvo Jarve
In this case, we will be sure that there exists a carrier and the center frequency would be simply f1 - f2. In such a circumstance, the TR loop is simplified to doing a simple check for timing, rather than searching for the same. Signed-off-by: Arvo Jarve <arvo@softshark.ee> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9432): Increment the AGC1 and AGC2 gain respectively, improves ↵Arvo Jarve
sensitivity slightly Signed-off-by: Arvo Jarve <arvo@softshark.ee> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9431): Bug ID #19: Diseqc works properly at 90MHz only on Cut 1.1 ↵Manu Abraham
and 2.0 Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9430): stb0899: avoid parameter overwritingArvo Jarve
BUG! Setting CRL parameter overwrote the CR Algorithm type, eventually leading to wrong search algorithm to be employed in the DVB-S carrier loop optimization. Symptom: Once the CR optimization stage is passed either way, in a successful or failed manner, the very next carrier search will fail, due to no Carrier Search Algorithm specified. Signed-off-by: Arvo Jarve <arvo@softshark.ee> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9429): Add support for the Satelco Easywatch DVB-S2 PCI cardArvo Jarve
2008-12-29V4L/DVB (9428): Fix: assignment of wrong valuesMarko Schluessler
Signed-off-by: Marko Schluessler <marco@lordzodiac.de> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9427): Code simplification: Sleep only for the required time interval.Manu Abraham
* Saves 70 mS LOCK time on the STB6100 based * Saves 100 mS LOCK time on the TDA8261 based Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9426): Add a missing breakManu Abraham
2008-12-29V4L/DVB (9425): Initialize at 90MHz itselfManu Abraham
2008-12-29V4L/DVB (9424): Deviation from the reference, pullup is 12k insteadManu Abraham
2008-12-29V4L/DVB (9423): Though insignificant, removes an unnecessary read of the ↵Manu Abraham
LOCK_LOSS register, which should have happenend in the DVB-S2 mode only, but reading it as it is for the other delivery systems causes nothing to say but LOCK_LOST, which just causes confusion amongst users. Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9422): Bug: Fix a typoManu Abraham
2008-12-29V4L/DVB (9421): We must wait for the PLL to stabilizeManu Abraham
Thanks to Peter for the in depth explanation Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9420): return -EINVAL for invalid parametersManu Abraham
2008-12-29V4L/DVB (9419): Bug: unnecessary large current causes large phasor errorsManu Abraham
2008-12-29V4L/DVB (9418): DVB_ATTACH for STB0899, STB6100, TDA8261Manu Abraham
2008-12-29V4L/DVB (9417): DVB_ATTACH for STB0899, STB6100, TDA8261Manu Abraham
2008-12-29V4L/DVB (9416): Hmmph, a proper calculation broke the working behaviour.Manu Abraham
Need some thoughts, temporary for now .. Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9414): Initialize DiSEqCManu Abraham
2008-12-29V4L/DVB (9413): Bug: Set Auxilliary Clock Register correctlyManu Abraham
2008-12-29V4L/DVB (9412): Fix tuner name and commentManu Abraham
2008-12-29V4L/DVB (9411): Bug! Timing recovery was calculated for 99MHz not 90 MHzManu Abraham
2008-12-29V4L/DVB (9410): Bug: Missing reference clock definitionManu Abraham
2008-12-29V4L/DVB (9409): Bug! inverted logicManu Abraham
2008-12-29V4L/DVB (9408): tda8261: check status to avoid lock lossManu Abraham
We need to check for tuner LOCK LOSS, especially in the case of simple PLL's Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9407): Optimizations Reduce capture range from 10MHz to 3MhzManu Abraham
* Reduces szapping time a lot * increased stability at Low Symbol rates * overall increases reliability in tuning Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9406): Really silly bug, setting bandwidth into frequencyMarko Schluessler
probably should stop fiddling with code late nights. :-( Thanks to Marco for pointing it out and fixing it. Signed-off-by: Marko Schluessler <marco@lordzodiac.de> Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9405): Practical tests show that the TT S2 3200 has I/Q inputs ↵Manu Abraham
inverted, similar to the KNC1. Don't have this hardware and cannot verify this for myself, but from the reports this looks to be quite a reasonable and correct hypothesis. Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9404): the KNC1 and clones also don't have the I/Q inputs swappedManu Abraham
2008-12-29V4L/DVB (9403): Fix the CA module not working issueManu Abraham
2008-12-29V4L/DVB (9402): TT S2 3200 shouldn't need Inversion ON and Inversion AUTO at ↵Manu Abraham
the same time This is a racy situation. Inversion is default OFF on the TT S2 3200 hardware, unlike the KNC1 where it is default Inverted Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9401): Code SimplificationManu Abraham
Use an enumeration for I/Q Swap rather than an int, easier to spot the nasty ones Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9400): stb6100: Code SimplificationManu Abraham
The 2 callbacks created nothing more than confusion Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9399): some cleanups at budget-ciManu Abraham
Still messing up: * Cleanup * Use KNC1's default settings to startup with * Add in tuner wrapper calls Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9398): Initial support for the Technotrend TT S2 3200Marko Schluessler
2008-12-29V4L/DVB (9397): fix some bugs at tda8261Manu Abraham
Fix bug obviously, some enhancements as well * enable i2c_gate before doing any transaction * read is one single message with 2 words * reduce sleep from 100mS to 20mS Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9396): Fix clocks at stb0899Manu Abraham
Really silly! Disabled all clocks and expected it to run. Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9395): Add initial support for two KNC1 DVB-S2 boardsManu Abraham
Add initial support for: * KNC1 DVB-S2 Plus * KNC1 DVB-S2 OEM (known as Satelco DVB-S2) Signed-off-by: Manu Abraham <manu@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-29V4L/DVB (9394): cache last successful stateManu Abraham
2008-12-29V4L/DVB (9393): Add TDA8261 to buildManu Abraham
2008-12-29V4L/DVB (9392): initial go at TDA8261 tunerManu Abraham
2008-12-29V4L/DVB (9391): Register definition bugsMarko Schluessler
2008-12-29V4L/DVB (9390): Offset Freq has been set in regMarko Schluessler
2008-12-29V4L/DVB (9389): Use kzalloc instead of kmallocMarko Schluessler
2008-12-29V4L/DVB (9388): Reference Clock is in kHzMarko Schluessler
