path: root/drivers
2009-01-12ti_usb_3410_5052: add Multi-Tech firmwareChris Adams
Add the Multi-Tech cellular modem firmware to the TI USB serial driver. This firmware was extracted from: ftp://ftp.multitech.com/wireless/wireless_linux.zip Firmware licence: "all firmware components are redistributable in binary form" per support@multitech.com Copyright (C) 2005 Multi-Tech Systems, Inc. Signed-off-by: Chris Adams <cmadams@hiwaay.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12ti_usb_3410_5052: add Multi-Tech modem supportChris Adams
Add Multi-Tech cellular modem support to the ti_usb_3410_5052 driver. Signed-off-by: Chris Adams <cmadams@hiwaay.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12ti_usb_3410_5052: support alternate firmwareChris Adams
The TI USB serial driver supports specifying alternate vendor and product IDs (since the chips can and are used in devices under other vendor/product IDs). However, the alternate IDs were not loaded in the combined product table. This patch also adds support for loading alternate firmware for alternate vendor/product IDs. Signed-off-by: Chris Adams <cmadams@hiwaay.net> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12usb-serial: remove NULL checkAlan Cox
Julia Lawell found a case where a NULL check was misplaced in the usb-serial code. However as the object in question cannot be NULL the check can simply be removed. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12neo: Remove a bogus NULL checkAlan Cox
Julia Lawall found an un-needed check in the neo driver. Her patch moves the check to cover the code dereferencing it, however it cannot be NULL anyway so remove the NULL check instead. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12pty: Fix documentationAlan Cox
The pty changes and updates for window sizing forgot to correct the kerneldoc Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12Merge branch 'for-next' of git://git.o-hand.com/linux-mfdLinus Torvalds
* 'for-next' of git://git.o-hand.com/linux-mfd: mfd: Fix twl4030-core build mfd: Ensure sm501 GPIO pin mode is GPIO when configured mfd: dm355 evm MMC/SD card detection regulator: PCF50633 pmic driver input: PCF50633 input driver power_supply: PCF50633 battery charger driver rtc: PCF50633 rtc driver mfd: PCF50633 gpio support mfd: PCF50633 adc driver mfd: PCF50633 core driver
2009-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits) ucc_geth: use correct UCCE macros net_dma: acquire/release dma channels on ifup/ifdown cxgb3: Keep LRO off if disabled when interface is down sfc: SFT9001: Fix condition for LNPGA power-off dccp ccid-3: Fix RFC reference smsc911x: register irq with device name, not driver name smsc911x: fix smsc911x_reg_read compiler warning forcedeth: napi schedule lock fix net: fix section mismatch warnings in dccp/ccids/lib/tfrc.c forcedeth: remove mgmt unit for mcp79 chipset qlge: Remove dynamic alloc of rx ring control blocks. qlge: Fix schedule while atomic issue. qlge: Remove support for device ID 8000. qlge: Get rid of split addresses in hardware control blocks. qlge: Get rid of volatile usage for shadow register. forcedeth: version bump and copyright forcedeth: xmit lock fix netdev: missing validate_address hooks netdev: add missing set_mac_address hook netdev: gianfar: add MII ioctl handler ...
2009-01-12Merge branch 'for_2.6.29' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kkeil/ISDN-2.6 * 'for_2.6.29' of git://git.kernel.org/pub/scm/linux/kernel/git/kkeil/ISDN-2.6: Fix small typo misdn: indentation and braces disagree - add braces misdn: one handmade ARRAY_SIZE converted drivers/isdn/hardware/mISDN: move a dereference below a NULL test indentation & braces disagree - add braces Make parameter debug writable BUGFIX: used NULL pointer at ioctl(sk,IMGETDEVINFO,&devinfo) when devinfo.id not registered
2009-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] Pika Warp appliance watchdog timer [WATCHDOG] Enable watchdog timer on GE Fanuc's SBC610 [WATCHDOG] Basic support for GE Fanuc's FPGA based watchdog timer [WATCHDOG] wm8350: Fix section annotations
2009-01-12[WATCHDOG] Pika Warp appliance watchdog timerSean MacLennan
The FPGA based watchdog timer used by the Pika Warp appliance. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-01-12[WATCHDOG] Basic support for GE Fanuc's FPGA based watchdog timerMartyn Welch
GE Fanuc SBC610 Support for the FPGA based watchdog timer as found on GE Fanuc's SBC310, SBC610 and PPC9A Single Board Computers. This patch adds support for the watchdog timer found in one of the devices FPGAs. There are two identical watchdog timers at different offsets in the above mentioned boards, this driver is capable of supporting one of them. The watchdog timers are also capable of generating interrupts at a user-configurable threshold, though support for this operation is currently not supported by the driver. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-01-12[WATCHDOG] wm8350: Fix section annotationsMark Brown
The probe and remove functions were incorrectly annotated, with the misannotation of the remove function causing build failures when built in. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-01-12fbdev: Kill Atari vblank cursor blinkingGeert Uytterhoeven
Kill the last remaining vblank cursor blinking user Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: zorro - Use %pR to print resourcesGeert Uytterhoeven
2009-01-12m68k: dio - Kill resource_size_t format warningsGeert Uytterhoeven
warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: zorro - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'device_register', declared with attribute warn_unused_result warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: dio - Kill warn_unused_result warningsGeert Uytterhoeven
2009-01-12m68k: atafb - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: amiserial - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result and clean up the error path handling. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
2009-01-12m68k: ser_a2232 - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
2009-01-12m68k: vme_scc - Kill warn_unused_result warningsGeert Uytterhoeven
2009-01-12m68k: amiflop - Get rid of sleep_on callsAndreas Bombe
Apart from sleep_on() calls that could be easily converted to wait_event() and completion calls amiflop also used a flag in ms_delay() and ms_isr() as a custom mutex for ms_delay() without a need for explicit unlocking. I converted that to a standard mutex. The replacement for the unconditional sleep_on() in fd_motor_on() is a complete_all() together with a INIT_COMPLETION() before the mod_timer() call. It appears to me that fd_motor_on() might be called concurrently and fd_select() does not guarantee mutual exclusivity in the case the same drive gets selected again. Signed-off-by: Andreas Bombe <aeb@debian.org> Acked-by: Jörg Dorchain <joerg@dorchain.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12m68k: zorro - Add devlist.h and gen-devlist to .gitignoreKars de Jong
drivers/zorro/.gitignore: Added devlist.h and gen-devlist to .gitignore file because they shouldn't be tracked. Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: c2p - Rename c2p to c2p_planarGeert Uytterhoeven
2009-01-12fbdev: c2p/atafb - Add support for Atari interleaved bitplanesGeert Uytterhoeven
The c2p() for normal bitplanes is not suitable for interleaved bitplanes with 2 bytes of interleave, causing a garbled penguin logo. Add c2p_iplan2(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: c2p - Extract common c2p core to c2p_core.hGeert Uytterhoeven
2009-01-12fbdev: c2p - CleanupsGeert Uytterhoeven
- Improve comments and naming - Convert macros to static inline functions - Remove superfluous `break' after `return' - Make sure we get a build-time error (undefined reference to 'c2p_unsupported') in case of future misuse - Replace `unsigned long' by `u32' in comp(), as that's what all callers use - Use {get,put}_unaligned_be32() in store_planar{,_masked}() - Use void * for arbitrary pointers - Use a union to represent pixels/words, to avoid casts Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: c2p - Correct indentationGeert Uytterhoeven
2009-01-12fbdev: atafb - Fix 16 bpp consoleGeert Uytterhoeven
- 16 bpp must use the cfb_*() ops - 16 bpp needs to set up info->pseudo_palette[] (was fbcon_cfb16_cmap[] in 2.4.x) - Kill commented out 2.4.x fbcon remnants Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-12fbdev: atafb - Fix line length handlingGeert Uytterhoeven
- Make sure par->next_line is always set (this was done for Falcon only), as all the text console drawing operations need a valid par->next_line, - Make sure fix->line_length is always set, as some userspace applications need it because they don't have fallback code for the case where it's zero. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2009-01-11Fix small typoKarsten Keil
Remove additional ; Signed-off-by: Karsten Keil <kkeil@suse.de>
2009-01-11misdn: indentation and braces disagree - add bracesIlpo Järvinen
This is not buggy due to plain luck as there is only one entry currently in the element_attributes. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Karsten Keil <kkeil@suse.de>
2009-01-11misdn: one handmade ARRAY_SIZE convertedIlpo Järvinen
Defined as: static struct device_attribute element_attributes[] = { Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Karsten Keil <kkeil@suse.de>
2009-01-11drivers/isdn/hardware/mISDN: move a dereference below a NULL testJulia Lawall
In each case, if the NULL test is necessary, then the dereference should be moved below the NULL test. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; expression E; identifier i,fld; statement S; @@ - T i = E->fld; + T i; ... when != E when != i if (E == NULL) S + i = E->fld; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Karsten Keil <kkeil@suse.de>
2009-01-11indentation & braces disagree - add bracesIlpo Järvinen
Nothing is broken because of this - currently. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2009-01-11Make parameter debug writableKarsten Keil
Overseen in the last patch series. Signed-off-by: Karsten Keil <kkeil@suse.de>
2009-01-11ucc_geth: use correct UCCE macrosTimur Tabi
The UCC Event Register (UCCE) already has unambigous macro definitions in qe.h, so we should not be defining our own in the UCC Ethernet driver. Removed unused local variable 'dev' from ucc_geth_poll(), which fixes a warning caused by commit 908a7a16b852ffd618a9127be8d62432182d81b4 ("net: Remove unused netdev arg from some NAPI interfaces."). Replaced in_be/out_be pairs with setbits32 or clrbits32, where applicable. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11cxgb3: Keep LRO off if disabled when interface is downRoland Dreier
I have a system with a Chelsio adapter (driven by cxgb3) whose ports are part of a Linux bridge. Recently I updated the kernel and discovered that things stopped working because cxgb3 was doing LRO on packets that were passed into the bridge code for forwarding. (Incidentally, this problem manifested itself in a strange way that made debugging a bit interesting -- for some reason, the skb_warn_if_lro() check in bridge didn't trigger and these LROed packets were forwarded out a forcedeth interface, and caused the forcedeth transmit path to get stuck) This is because cxgb3 has no way of keeping state for the LRO flag until the interface is brought up, so if the bridging code disables LRO while the interface is down, then cxgb3_up() will just reenable LRO, and on my Debian system at least, the init scripts add interfaces to a bridge before bringing the interfaces up. Fix this by keeping track of each interface's LRO state in cxgb3 so that when bridge disables LRO, it stays disabled in cxgb3_up() when the interface is brought up. I did this by changing the rx_csum_offload flag into a pair of bit flags; the effect of this on the rx_eth() fast path is miniscule enough that it should be fine (eg on x86, a cmpb instruction becomes a testb instruction). Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11sfc: SFT9001: Fix condition for LNPGA power-offBen Hutchings
Only the SFX7101 requires software power control. This was incorrectly being applied to the SFT9001 rev A as well. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11smsc911x: register irq with device name, not driver nameSteve Glendinning
This change lets "cat /proc/interrupts" show the name of the ethernet device (e.g. eth0) rather than the driver name (smsc911x). Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11smsc911x: fix smsc911x_reg_read compiler warningSteve Glendinning
if this code path is ever hit, the platform_data struct isn't properly configured with a bus width flag so the device won't work (hence the BUG()). This patch adds a dummy return statement to eliminate this compiler warning: drivers/net/smsc911x.c: In function 'smsc911x_reg_read': drivers/net/smsc911x.c:148: warning: control reaches end of non-void function Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11forcedeth: napi schedule lock fixAyaz Abdulla
This patch fixes a potential race condition between scheduling napi and completing napi poll. The call to netif_rx_schedule should be under protection of the lock (as is the completion), otherwise, interrupts could be masked off. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11forcedeth: remove mgmt unit for mcp79 chipsetAyaz Abdulla
This patch removes the feature flag for mgmt unit as it is not used for this chipset. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11qlge: Remove dynamic alloc of rx ring control blocks.Ron Mercer
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11qlge: Fix schedule while atomic issue.Ron Mercer
There is no need to sleep while waiting for the hardware semaphore to become available. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11qlge: Remove support for device ID 8000.Ron Mercer
Support for dev id 8000 is pushed out until 2.6.30. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11qlge: Get rid of split addresses in hardware control blocks.Ron Mercer
2009-01-11qlge: Get rid of volatile usage for shadow register.Ron Mercer
Putting back ql_read_sh_reg() function and using rmb() instead of volatile. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11forcedeth: version bump and copyrightAyaz Abdulla
This patch bumps up the version number and adds current year to copyright. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
