If the platform_data is not set, pdata will be uninitialized value.
Since the driver has the following code, if the condition is true when
the pdata is uninitialized value, the driver may jump to the illegal
phy_init().
if (pdata && pdata->phy_init)
pdata->phy_init();
This patch also fixes the following warning:
CC drivers/usb/host/ehci-hcd.o
drivers/usb/host/ehci-sh.c: In function ‘ehci_hcd_sh_probe’:
drivers/usb/host/ehci-sh.c:104: warning: ‘pdata’ may be used uninitialized in this function
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Currently CDC-ACM devices stay throttled when their TTY is closed while
throttled, stalling further communication attempts after the next open.
Unthrottling during open/activate got lost starting with kernel
3.0.0 and this patch reintroduces it.
Signed-off-by: Otto Meta <otto.patches@sister-shadow.de>
Cc: stable <stable@vger.kernel.org>
Acked-by: Johan Hovold <jhovold@gmail.com>
Its observed with some PHY, the 60Mhz clock gets
cut too soon for OMAP EHCI, leaving OMAP-EHCI in a bad state.
So on starting port suspend, make sure the 60Mhz clock to EHCI
is kept alive using an internal clock, so that EHCi can cleanly
transition its hw state machine on a port suspend.
Its not proven if this is the issue hit on USB3333,
but the symptoms look very similar.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Signed-off-by: Vikram Pandita <vikram.pandita@ti.com>
Signed-off-by: Volodymyr Mieshkov <x0182794@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
ohci_finish_controller_resume() is intended to be used in platform specific
drivers ohci-*.c, included from ohci-hcd.c. Some of them don't actually use
ohci_finish_controller_resume(), so mark it as __maybe_unused.
Signed-off-by: Roland Stigge <stigge@antcom.de>
The use of kfree(serial) in error cases of usb_serial_probe
was invalid - usb_serial structure allocated in create_serial()
gets reference of usb_device that needs to be put, so we need
to use usb_serial_put() instead of simple kfree().
Signed-off-by: Jan Safrata <jan.nikitenko@gmail.com>
This fixes the following warning:
In file included from drivers/usb/host/ehci-hcd.c:1246:0:
drivers/usb/host/ehci-xilinx-of.c:293:2: warning: initialization from incompatible pointer type [enabled by default]
drivers/usb/host/ehci-xilinx-of.c:293:2: warning: (near initialization for 'ehci_hcd_xilinx_of_driver.shutdown') [enabled by default]
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
After commit aaa0ef289afe9186f81e2340114ea413eef0492a "PS3 EHCI QH
read work-around", Terratec Grabby (em28xx) stopped working with AMD
Geode LX 800 (USB controller AMD CS5536). Since this is a PS3 only
fix, the following patch adds a conditional block around it.
Signed-off-by: Ricardo Martins <rasm@fe.up.pt>
git://git.kernel.org/pub/scm/linux/kernel/git/sarah/xhci into usb-linus
xhci: Bug fixes for 3.5
Hi Greg,
Here's five bug fixes for 3.5. They fix some memory leaks in the
bandwidth calculation code, fix a couple bugs in the USB3 Link PM
patchset, and make system suspend and resume work on platforms with the
AsMedia ASM1042 xHCI host controller.
Sarah Sharp
When system software decides to power down the xHC with the intent of
resuming operation at a later time, it will ask xHC to save the internal
state and restore it when resume to correctly recover from a power event.
Two bits are used to enable this operation: Save State and Restore State.
xHCI spec 4.23.2 says software should "Set the Controller Save/Restore
State flag in the USBCMD register and wait for the Save/Restore State
Status flag in the USBSTS register to transition to '0'". However, it does
not define how long software should wait for the SSS/RSS bit to transition
to 0.
Currently the timeout is set to 1ms. There is bug report
(https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1002697)
indicates that the timeout is too short for ASMedia ASM1042 host controller
to save/restore the state successfully. Increase the timeout to 10ms helps to
resolve the issue.
This patch should be backported to stable kernels as old as 2.6.37, that
contain the commit 5535b1d5f8885695c6ded783c692e3c0d0eda8ca "USB: xHCI:
PCI power management implementation"
Signed-off-by: Andiry Xu <andiry.xu@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: stable@vger.kernel.org
This patch fixes a few issues introduced in the recent fix
[f8a9e72d: USB: fix resource leak in xhci power loss path]
- The endpoints listed in bw table are just links and each entry is an
array member of dev->eps[]. But the commit above adds a kfree() call
to these instances, and thus it results in memory corruption.
- It clears only the first entry of rh_bw[], but there can be multiple
ports.
- It'd be safer to clear the list_head of ep as well, not only
removing from the list, as it's checked in
xhci_discover_or_reset_device().
This patch should be backported to kernels as old as 3.2, that contain
the commit 839c817ce67178ca3c7c7ad534c571bba1e69ebe "xhci: Store
information about roothubs and TTs."
Reviewed-by: Oliver Neukum <oneukum@suse.de>
Cc: <stable@vger.kernel.org>
xhci_free_tt_info() may access the invalid memory when it removes the
last entry but the list is not empty. Then tt_next reaches to the
list head but it still tries to check the tt_info of that entry.
This patch fixes the bug and cleans up the messy code by rewriting
with a simple list_for_each_entry_safe().
This patch fixes an issue discovered by Dan Carpenter:
The patch 3b3db026414b: "xhci: Add infrastructure for host-specific
LPM policies." from May 9, 2012, leads to the following warning:
drivers/usb/host/xhci.c:3909 xhci_get_timeout_no_hub_lpm()
warn: signedness bug returning '-22'
3906 default:
3907 dev_warn(&udev->dev, "%s: Can't get timeout for non-U1 or U2 state.\n",
3908 __func__);
3909 return -EINVAL;
This should be a u16 like USB3_LPM_DISABLED or something.
3910 }
3911
3912 if (sel <= max_sel_pel && pel <= max_sel_pel)
3913 return USB3_LPM_DEVICE_INITIATED;
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
We check "u1_params" instead of checking "u2_params".
This device gives a bogus answer to get_capacity(16):
[ 8628.278614] scsi 8:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 4
[ 8628.279452] sd 8:0:0:0: Attached scsi generic sg4 type 0
[ 8628.280338] sd 8:0:0:0: [sdd] 35747322042253313 512-byte logical blocks: (18.3 EB/15.8 EiB)
So set the quirk flag to avoid using get_capacity(16) with it:
[11731.386014] usb-storage 2-1.6:1.0: Quirks match for vid 090c pid 1000: 80000
[11731.386075] scsi9 : usb-storage 2-1.6:1.0
[11731.386172] usbcore: registered new interface driver usb-storage
[11731.386175] USB Mass Storage support registered.
[11732.387394] scsi 9:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 4
[11732.388462] sd 9:0:0:0: Attached scsi generic sg3 type 0
[11732.389432] sd 9:0:0:0: [sdc] 7975296 512-byte logical blocks: (4.08 GB/3.80 GiB)
Which makes the capacity look a lot more sane :)
Tested-by: Simon Raffeiner <sturmflut@lieberbiber.de>
The usb-serial-generic driver uses different device IDs for its USB
matching and its serial matching. This can lead to problems: The
driver can end up getting bound to a USB interface without being
allowed to bind to the corresponding serial port.
This patch (as1557) fixes the problem by using the same device ID
table (the one that can be altered by the "vendor=" and "product="
module parameters) for both purposes. The unused table is removed.
Now the driver will bind only to the intended devices.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Bjørn Mork <bjorn@mork.no>
We need to make sure that the USB serial driver we find
matches the USB driver whose probe we are currently
executing. Otherwise we will end up with USB serial
devices bound to the correct serial driver but wrong
USB driver.
An example of such cross-probing, where the usbserial_generic
USB driver has found the sierra serial driver:
May 29 18:26:15 nemi kernel: [ 4442.559246] usbserial_generic 4-4:1.0: Sierra USB modem converter detected
May 29 18:26:20 nemi kernel: [ 4447.556747] usbserial_generic 4-4:1.2: Sierra USB modem converter detected
May 29 18:26:25 nemi kernel: [ 4452.557288] usbserial_generic 4-4:1.3: Sierra USB modem converter detected
sysfs view of the same problem:
bjorn@nemi:~$ ls -l /sys/bus/usb/drivers/sierra/
total 0
--w------- 1 root root 4096 May 29 18:23 bind
lrwxrwxrwx 1 root root 0 May 29 18:23 module -> ../../../../module/usbserial
--w------- 1 root root 4096 May 29 18:23 uevent
--w------- 1 root root 4096 May 29 18:23 unbind
bjorn@nemi:~$ ls -l /sys/bus/usb-serial/drivers/sierra/
total 0
lrwxrwxrwx 1 root root 0 May 29 18:23 module -> ../../../../module/sierra
-rw-r--r-- 1 root root 4096 May 29 18:23 new_id
lrwxrwxrwx 1 root root 0 May 29 18:32 ttyUSB0 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.0/ttyUSB0
lrwxrwxrwx 1 root root 0 May 29 18:32 ttyUSB1 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.2/ttyUSB1
lrwxrwxrwx 1 root root 0 May 29 18:32 ttyUSB2 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.3/ttyUSB2
bjorn@nemi:~$ ls -l /sys/bus/usb/drivers/usbserial_generic/
total 0
lrwxrwxrwx 1 root root 0 May 29 18:33 4-4:1.0 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.0
lrwxrwxrwx 1 root root 0 May 29 18:33 4-4:1.2 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.2
lrwxrwxrwx 1 root root 0 May 29 18:33 4-4:1.3 -> ../../../../devices/pci0000:00/0000:00:1d.7/usb4/4-4/4-4:1.3
--w------- 1 root root 4096 May 29 18:33 bind
lrwxrwxrwx 1 root root 0 May 29 18:33 module -> ../../../../module/usbserial
--w------- 1 root root 4096 May 29 18:22 uevent
--w------- 1 root root 4096 May 29 18:33 unbind
bjorn@nemi:~$ ls -l /sys/bus/usb-serial/drivers/generic/
total 0
-rw-r--r-- 1 root root 4096 May 29 18:33 new_id
So we end up with a mismatch between the USB driver and the
USB serial driver. The reason for the above is simple: The
USB driver probe will succeed if *any* registered serial
driver matches, and will use that serial driver for all
serial driver functions.
This makes ref counting go wrong. We count the USB driver
as used, but not the USB serial driver. This may result
in Oops'es as demonstrated by Johan Hovold <jhovold@gmail.com>:
[11811.646396] drivers/usb/serial/usb-serial.c: get_free_serial 1
[11811.646443] drivers/usb/serial/usb-serial.c: get_free_serial - minor base = 0
[11811.646460] drivers/usb/serial/usb-serial.c: usb_serial_probe - registering ttyUSB0
[11811.646766] usb 6-1: pl2303 converter now attached to ttyUSB0
[11812.264197] USB Serial deregistering driver FTDI USB Serial Device
[11812.264865] usbcore: deregistering interface driver ftdi_sio
[11812.282180] USB Serial deregistering driver pl2303
[11812.283141] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[11812.283272] usbcore: deregistering interface driver pl2303
[11812.301056] USB Serial deregistering driver generic
[11812.301186] usbcore: deregistering interface driver usbserial_generic
[11812.301259] drivers/usb/serial/usb-serial.c: usb_serial_disconnect
[11812.301823] BUG: unable to handle kernel paging request at f8e7438c
[11812.301845] IP: [<f8e38445>] usb_serial_disconnect+0xb5/0x100 [usbserial]
[11812.301871] *pde = 357ef067 *pte = 00000000
[11812.301957] Oops: 0000 [#1] PREEMPT SMP
[11812.301983] Modules linked in: usbserial(-) [last unloaded: pl2303]
[11812.302008]
[11812.302019] Pid: 1323, comm: modprobe Tainted: G W 3.4.0-rc7+ #101 Dell Inc. Vostro 1520/0T816J
[11812.302115] EIP: 0060:[<f8e38445>] EFLAGS: 00010246 CPU: 1
[11812.302130] EIP is at usb_serial_disconnect+0xb5/0x100 [usbserial]
[11812.302141] EAX: f508a180 EBX: f508a180 ECX: 00000000 EDX: f8e74300
[11812.302151] ESI: f5050800 EDI: 00000001 EBP: f5141e78 ESP: f5141e58
[11812.302160] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[11812.302170] CR0: 8005003b CR2: f8e7438c CR3: 34848000 CR4: 000007d0
[11812.302180] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[11812.302189] DR6: ffff0ff0 DR7: 00000400
[11812.302199] Process modprobe (pid: 1323, ti=f5140000 task=f61e2bc0 task.ti=f5140000)
[11812.302209] Stack:
[11812.302216] f8e3be0f f8e3b29c f8e3ae00 00000000 f513641c f5136400 f513641c f507a540
[11812.302325] f5141e98 c133d2c1 00000000 00000000 f509c400 f513641c f507a590 f5136450
[11812.302372] f5141ea8 c12f0344 f513641c f507a590 f5141ebc c12f0c67 00000000 f507a590
[11812.302419] Call Trace:
[11812.302439] [<c133d2c1>] usb_unbind_interface+0x51/0x190
[11812.302456] [<c12f0344>] __device_release_driver+0x64/0xb0
[11812.302469] [<c12f0c67>] driver_detach+0x97/0xa0
[11812.302483] [<c12f001c>] bus_remove_driver+0x6c/0xe0
[11812.302500] [<c145938d>] ? __mutex_unlock_slowpath+0xcd/0x140
[11812.302514] [<c12f0ff9>] driver_unregister+0x49/0x80
[11812.302528] [<c1457df6>] ? printk+0x1d/0x1f
[11812.302540] [<c133c50d>] usb_deregister+0x5d/0xb0
[11812.302557] [<f8e37c55>] ? usb_serial_deregister+0x45/0x50 [usbserial]
[11812.302575] [<f8e37c8d>] usb_serial_deregister_drivers+0x2d/0x40 [usbserial]
[11812.302593] [<f8e3a6e2>] usb_serial_generic_deregister+0x12/0x20 [usbserial]
[11812.302611] [<f8e3acf0>] usb_serial_exit+0x8/0x32 [usbserial]
[11812.302716] [<c1080b48>] sys_delete_module+0x158/0x260
[11812.302730] [<c110594e>] ? mntput+0x1e/0x30
[11812.302746] [<c145c3c3>] ? sysenter_exit+0xf/0x18
[11812.302746] [<c107777c>] ? trace_hardirqs_on_caller+0xec/0x170
[11812.302746] [<c145c390>] sysenter_do_call+0x12/0x36
[11812.302746] Code: 24 02 00 00 e8 dd f3 20 c8 f6 86 74 02 00 00 02 74 b4 8d 86 4c 02 00 00 47 e8 78 55 4b c8 0f b6 43 0e 39 f8 7f a9 8b 53 04 89 d8 <ff> 92 8c 00 00 00 89 d8 e8 0e ff ff ff 8b 45 f0 c7 44 24 04 2f
[11812.302746] EIP: [<f8e38445>] usb_serial_disconnect+0xb5/0x100 [usbserial] SS:ESP 0068:f5141e58
[11812.302746] CR2: 00000000f8e7438c
Fix by only evaluating serial drivers pointing back to the
USB driver we are currently probing. This still allows two
or more drivers to match the same device, running their
serial driver probes to sort out which one to use.
Cc: stable@vger.kernel.org # 3.0, 3.2, 3.3, 3.4
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Reviewed-by: Felipe Balbi <balbi@ti.com>
Tested-by: Johan Hovold <jhovold@gmail.com>
This patch (as1558) fixes a problem affecting several ASUS computers:
The machine crashes or corrupts memory when going into suspend if the
ehci-hcd driver is bound to any controllers. Users have been forced
to unbind or unload ehci-hcd before putting their systems to sleep.
After extensive testing, it was determined that the machines don't
like going into suspend when any EHCI controllers are in the PCI D3
power state. Presumably this is a firmware bug, but there's nothing
we can do about it except to avoid putting the controllers in D3
during system sleep.
The patch adds a new flag to indicate whether the problem is present,
and avoids changing the controller's power state if the flag is set.
Runtime suspend is unaffected; this matters only for system suspend.
However as a side effect, the controller will not respond to remote
wakeup requests while the system is asleep. Hence USB wakeup is not
functional -- but of course, this is already true in the current state
of affairs.
A similar patch has already been applied as commit
151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during
suspend on ASUS computers). The patch supersedes that one and reverts
it. There are two differences:
The old patch added the flag at the USB level; this patch
adds it at the PCI level.
The old patch applied to all chipsets with the same vendor,
subsystem vendor, and product IDs; this patch makes an
exception for a known-good system (based on DMI information).
Tested-by: Dâniel Fraga <fragabr@gmail.com>
Tested-by: Andrey Rahmatullin <wrar@wrar.name>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: gavin zhu <gavin.zhu@qq.com>
The __devinitconst section can't be referenced
from usb_serial_device structure. Thus removed it as
it done in other mos* device drivers.
Error itself:
WARNING: drivers/usb/serial/mos7840.o(.data+0x8): Section mismatch in reference
from the variable moschip7840_4port_device to the variable
.devinit.rodata:id_table
The variable moschip7840_4port_device references
the variable __devinitconst id_table
[v2] no attach now
Signed-off-by: Tony Zelenoff <antonz@parallels.com>
Fix memory leak introduced by commit 383cedc3bb435de7a2 ("USB: serial:
full autosuspend support for the option driver") which allocates
usb-serial data but never frees it.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Commit 8b4c6a3ab596961b78465 ("USB: option: Use generic USB wwan code")
moved option port-data allocation to usb_wwan_startup but still cast the
port data to the old struct...
The low level helper returns 1 on success. The ioctl should however return
0. As this is the only user of the helper return, make the helper return 0 or
an error code.
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=43009
Signed-off-by: Alan Cox <alan@linux.intel.com>
Later firmwares for this device now have proper subclass and
protocol info so we can identify it nicely without needing to use
the blacklist. I'm not removing the old 0xff matching as there
may be devices in the field that still need that.
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
Add support for Sierra Wireless AirCard 320U modem
Signed-off-by: Tomas Cassidy <tomas.cassidy@gmail.com>
Signed-off-by: Mikko Tuumanen <mikko.tuumanen@qemsoftware.com>
Add support for RT Systems USB-RTS01 USB to Serial adapter:
http://www.rtsystemsinc.com/Photos/USBRTS01.html
Tested by controlling Icom IC-718 amateur radio transceiver via hamlib.
Signed-off-by: Evan McNabb <evan@mcnabbs.org>
Some additional IDs found in the BSD/GPL licensed out-of-tree
GobiSerial driver from Sierra Wireless.
Tested-by: Thomas Schäfer <tschaefer@t-online.de>
usb_ep_ops.disable must clear external copy of the endpoint descriptor,
otherwise musb crashes after loading/unloading several gadget modules
in a row:
Unable to handle kernel paging request at virtual address bf013730
pgd = c0004000
[bf013730] *pgd=8f26d811, *pte=00000000, *ppte=00000000
Internal error: Oops: 7 [#1]
Modules linked in: g_cdc [last unloaded: g_file_storage]
CPU: 0 Not tainted (3.2.17 #647)
PC is at musb_gadget_enable+0x4c/0x24c
LR is at _raw_spin_lock_irqsave+0x4c/0x58
[<c027c030>] (musb_gadget_enable+0x4c/0x24c) from [<bf01b760>] (gether_connect+0x3c/0x19c [g_cdc])
[<bf01b760>] (gether_connect+0x3c/0x19c [g_cdc]) from [<bf01ba1c>] (ecm_set_alt+0x15c/0x180 [g_cdc])
[<bf01ba1c>] (ecm_set_alt+0x15c/0x180 [g_cdc]) from [<bf01ecd4>] (composite_setup+0x85c/0xac4 [g_cdc])
[<bf01ecd4>] (composite_setup+0x85c/0xac4 [g_cdc]) from [<c027b744>] (musb_g_ep0_irq+0x844/0x924)
[<c027b744>] (musb_g_ep0_irq+0x844/0x924) from [<c027a97c>] (musb_interrupt+0x79c/0x864)
[<c027a97c>] (musb_interrupt+0x79c/0x864) from [<c027aaa8>] (generic_interrupt+0x64/0x7c)
[<c027aaa8>] (generic_interrupt+0x64/0x7c) from [<c00797cc>] (handle_irq_event_percpu+0x28/0x178)
Cc: stable@vger.kernel.org # v3.1+
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
This appears to have been broken by
commit 5cfb19ac604a68c030b245561f575c2d1bac1d49
(ARM: davinci: streamline sysmod access)
For now, fix by hardcoding USB_PHY_CTRL and DM355_DEEPSLEEP
Tested on DM365 with defconfig changes.
Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk>
Acked-by: Sekhar Nori <nsekhar@ti.com>
CC: Felipe Balbi <balbi@ti.com>
Cc: <stable@vger.kernel.org> # v3.4.x
This patch removes redundant pointer to struct usb_endpoint_descriptor which
were missed in commit 79149b8:
usb: gadget: Update fsl_udc_core to use usb_endpoint_descriptor inside the
struct usb_ep
Due to clock framework regressions, this patch is only compile tested!
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
The removed condition is always true, since the endpoint descriptor is
set prior to calling the enable endpoint.
Signed-off-by: Ido Shayevitz <idos@codeaurora.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Yu Xu <yuxu@marvell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull device-mapper updates from Alasdair G Kergon:
"Improve multipath's retrying mechanism in some defined circumstances
and provide a simple reserve/release mechanism for userspace tools to
access thin provisioning metadata while the pool is in use."
* tag 'dm-3.5-changes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm:
dm thin: provide userspace access to pool metadata
dm thin: use slab mempools
dm mpath: allow ioctls to trigger pg init
dm mpath: delay retry of bypassed pg
dm mpath: reduce size of struct multipath
This patch implements two new messages that can be sent to the thin
pool target allowing it to take a snapshot of the _metadata_. This,
read-only snapshot can be accessed by userland, concurrently with the
live target.
Only one metadata snapshot can be held at a time. The pool's status
line will give the block location for the current msnap.
Since version 0.1.5 of the userland thin provisioning tools, the
thin_dump program displays the msnap as follows:
thin_dump -m <msnap root> <metadata dev>
Available here: https://github.com/jthornber/thin-provisioning-tools
Now that userland can access the metadata we can do various things
that have traditionally been kernel side tasks:
i) Incremental backups.
By using metadata snapshots we can work out what blocks have
changed over time. Combined with data snapshots we can ensure
the data doesn't change while we back it up.
A short proof of concept script can be found here:
https://github.com/jthornber/thinp-test-suite/blob/master/incremental_backup_example.rb
ii) Migration of thin devices from one pool to another.
iii) Merging snapshots back into an external origin.
iv) Asyncronous replication.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Use dedicated caches prefixed with a "dm_" name rather than relying on
kmalloc mempools backed by generic slab caches so the memory usage of
thin provisioning (and any leaks) can be accounted for independently.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
After the failure of a group of paths, any alternative paths that
need initialising do not become available until further I/O is sent to
the device. Until this has happened, ioctls return -EAGAIN.
With this patch, new paths are made available in response to an ioctl
too. The processing of the ioctl gets delayed until this has happened.
Instead of returning an error, we submit a work item to kmultipathd
(that will potentially activate the new path) and retry in ten
milliseconds.
Note that the patch doesn't retry an ioctl if the ioctl itself fails due
to a path failure. Such retries should be handled intelligently by the
code that generated the ioctl in the first place, noting that some SCSI
commands should not be retried because they are not idempotent (XOR write
commands). For commands that could be retried, there is a danger that
if the device rejected the SCSI command, the path could be errorneously
marked as failed, and the request would be retried on another path which
might fail too. It can be determined if the failure happens on the
device or on the SCSI controller, but there is no guarantee that all
SCSI drivers set these flags correctly.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
If I/O needs retrying and only bypassed priority groups are available,
set the pg_init_delay_retry flag to wait before retrying.
If, for example, the reason for the bypass is that the controller is
getting reset or there is a firmware upgrade happening, retrying right
away would cause a flood of log messages and retries for what could be a
few seconds or even several minutes.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Move multipath structure's 'lock' and 'queue_size' members to eliminate
two 4-byte holes. Also use a bit within a single unsigned int for each
existing flag (saves 8-bytes). This allows future flags to be added
without each consuming an unsigned int.
Acked-by: Hannes Reinecke <hare@suse.de>
Pull networking updates from David Miller:
1) Make syn floods consume significantly less resources by
a) Not pre-COW'ing routing metrics for SYN/ACKs
b) Mirroring the device queue mapping of the SYN for the SYN/ACK
reply.
Both from Eric Dumazet.
2) Fix calculation errors in Byte Queue Limiting, from Hiroaki SHIMODA.
3) Validate the length requested when building a paged SKB for a
socket, so we don't overrun the page vector accidently. From Jason
Wang.
4) When netlabel is disabled, we abort all IP option processing when we
see a CIPSO option. This isn't the right thing to do, we should
simply skip over it and continue processing the remaining options
(if any). Fix from Paul Moore.
5) SRIOV fixes for the mellanox driver from Jack orgenstein and Marcel
Apfelbaum.
6) 8139cp enables the receiver before the ring address is properly
programmed, which potentially lets the device crap over random
memory. Fix from Jason Wang.
7) e1000/e1000e fixes for i217 RST handling, and an improper buffer
address reference in jumbo RX frame processing from Bruce Allan and
Sebastian Andrzej Siewior, respectively.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
fec_mpc52xx: fix timestamp filtering
mcs7830: Implement link state detection
e1000e: fix Rapid Start Technology support for i217
e1000: look into the page instead of skb->data for e1000_tbi_adjust_stats()
r8169: call netif_napi_del at errpaths and at driver unload
tcp: reflect SYN queue_mapping into SYNACK packets
tcp: do not create inetpeer on SYNACK message
8139cp/8139too: terminate the eeprom access with the right opmode
8139cp: set ring address before enabling receiver
cipso: handle CIPSO options correctly when NetLabel is disabled
net: sock: validate data_len before allocating skb in sock_alloc_send_pskb()
bql: Avoid possible inconsistent calculation.
bql: Avoid unneeded limit decrement.
bql: Fix POSDIFF() to integer overflow aware.
net/mlx4_core: Fix obscure mlx4_cmd_box parameter in QUERY_DEV_CAP
net/mlx4_core: Check port out-of-range before using in mlx4_slave_cap
net/mlx4_core: Fixes for VF / Guest startup flow
net/mlx4_en: Fix improper use of "port" parameter in mlx4_en_event
net/mlx4_core: Fix number of EQs used in ICM initialisation
net/mlx4_core: Fix the slave_id out-of-range test in mlx4_eq_int
This reverts the tty layer change to use per-tty locking, because it's
not correct yet, and fixing it will require some more deep surgery.
The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but
there are several smaller commits that built upon it, they also get
reverted here. The list of reverted commits is:
fde86d310886 - tty: add lockdep annotations
8f6576ad476b - tty: fix ldisc lock inversion trace
d3ca8b64b97e - pty: Fix lock inversion
b1d679afd766 - tty: drop the pty lock during hangup
abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock()
fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call
d29f3ef39be4 - tty_lock: Localise the lock
The revert had a trivial conflict in the 68360serial.c staging driver
that got removed in the meantime.
skb_defer_rx_timestamp was called with a freshly allocated skb but must
be called with rskb instead.
Signed-off-by: Stephan Gatzka <stephan@gatzka.org>
Acked-by: Richard Cochran <richardcochran@gmail.com>
