path: root/drivers
2005-08-11[PATCH] S2io: Support for Xframe II NICraghavendra.koushik@neterion.com
Hi, This patch provides basic support for the Xframe II adapter. Includes the following changes: 1. New values to program XAUI interface. 2. Print the PCI/PCI-X mode(bus frequency, width). 3. Remove EOI from reset during intialization. 4. Enable all 8 PCCs if Xframe II adapter. 5. Programs the RLDRAM size depending on the device. (Note: RLDRAM size on XFARME-I is 64Mb whereas on XFRAME-II it's 32 Mb). 6. Enable extended(64-bit) statistics counters. 7. Program timer interrupt duration based on PCI/PCI-X clock speed. 8. Not required to save/restore PCI config space before/after reset. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: VLAN supportraghavendra.koushik@neterion.com
Hi, Patch below adds VLAN support to the driver. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Timer based slowpath handlingraghavendra.koushik@neterion.com
Hi, This patch implements the slow-path handling functions(link state change, hardware errors) as a timer. It is not handled in interrupt handler as was done previously. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Support for runtime MTU changeraghavendra.koushik@neterion.com
Hi, Patch below supports MTU change on-the-fly(without bringing interface down) Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Performance improvementsraghavendra.koushik@neterion.com
Hi, This patch relates to mostly performance related changes. 1. Fixed incorrect computation of PANIC level in rx_buffer_level(). 2. Removed unnecessary PIOs(read/write of tx_traffic_int and rx_traffic_int) from interrupt handler and removed read of general_int_status register from xmit routine. 3. Enable two-buffer mode(for Rx path) automatically for SGI systems. This improves Rx performance dramatically on SGI systems. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Removed memory leaksraghavendra.koushik@neterion.com
Hi, This patch fixes certain memory leaks discovered in free_tx_buffers() and rx_osm_handler() Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Software fixesraghavendra.koushik@neterion.com
Hi, Below patch includes fixes for few purely software bugs identified since last release. 1. Keep track and display(as part of ethtool command output) the no. of single-bit and double-bit ECC errors. 2. Handle race condition between intr handler and "interface down" routine. 3. Initial link state setting modified so that the link state displayed after "interface Up" is correct. 4. Fix for "Incorrect Tx packet count when TSO is enabled". 5. Disable periodic DMA of statistics and schedule one-shot DMA only when required. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Hardware fixesraghavendra.koushik@neterion.com
Hi, Below patch addresses few h/w specific issues. 1. Check for additional ownership bit on Rx path before starting Rx processing. 2. Enable only 4 PCCs(Per Context Controller) for Xframe I revisions less than 4. 3. Program Rx and Tx round robin registers depending on no. of rings/FIFOs. 4. Tx continous interrupts is now a loadable parameter. 5. Reset the card if we get double-bit ECC errors. 6. A soft reset of XGXS being done to force a link state change has been eliminated. 7. After a reset, clear "parity error detected" bit, PCI-X ECC status register, and PCI_STATUS bit in tx_pic_int register. 8. The error in the disabling allmulticast implementation has been rectified. 9. Leave the PCI-X parameters MMRBC, OST etc. at their BIOS/system defaults. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] S2io: Code cleanupraghavendra.koushik@neterion.com
Hi, We are submitting a series of 13 patches to support our Xframe I and Xframe II line of products. The patches can be categorized as follows: Patches 1-8 : Changes applicable to both Xframe I and II Patches 9-11: Xframe II specific features Patch 12: Addresses issues found during testing cycle. Patch 13: Incorpoates mostly the review comments from community and some last moment bug fixes. Please review the patches and let us know your comments. Starting with patch 1 below. This patch involves cosmetic changes(tabs and indentation, regrouping of transmit and receive data structures, typecasting, code cleanup). Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Raghavendra Koushik <raghavendra.koushik@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11Merge /spare/repo/linux-2.6/Jeff Garzik
2005-08-10Merge head 'upstream-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
2005-08-10[PATCH] wbsd version bumpPierre Ossman
Even though the changes are minor for the next release an increasing version number simplifies my support issues. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-10Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-08-10[PATCH] ns558 list handling fixAlexander Nyberg
Need to use list_for_entry_safe(), as we're removing items during the traversal. list_for_each_entry() uses the first ptr also as an iterator, if you kfree() it slab takes it, might poison it and then you try to use it to iterate to the next object in list. Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-10[PATCH] 6pack persistence fixRalf Baechle DL5RB
Fix the p-persistence CSMA algorithm which in simplex mode was starting with a slottime delay before doing anything else as if there was carrier collision resulting in bad performance on simplex links. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-10libata: fix EH-related lockup by properly cleaning EH command listTejun Heo
Yet another hack due to the fact that libata is the only user of SCSI's ->eh_strategy_handler() hook.
2005-08-10[PATCH] sata: fix sata_sx4 dma_prep to not use sg->lengthTejun Heo
sata_sx4 directly references sg->length to calculate total_len in pdc20621_dma_prep(). This is incorrect as dma_map_sg() could have merged multiple sg's into one and, in such case, sg->length doesn't reflect true size of the entry. This patch makes it use sg_dma_len(sg). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-10Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2005-08-10[PATCH] ARM: 2846/1: proper handling of CKEN for pxafbNicolas Pitre
Patch from Nicolas Pitre Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-09[PATCH] Fix ide-disk.c oops caused by hwif == NULLChristoph Lameter
1. Move hwif_to_node to ide.h 2. Use hwif_to_node in ide-disk.c Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] DVB: lgdt330x frontend: some bug fixes & add lgdt3303 supportMichael Krufky
This patch removes the tda9887 stuff from lgdt330x.c. It's experimental code which wasn't supposed to leak out and we don't want it in 2.6.13. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Acked-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] dvb: lgdt330x frontend: trivial text cleanupsMichael Krufky
Two trivial text changes in Kconfig and lgdt330x.c Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] I2O: added pci_request_regions() before using the controllerMarkus Lidel
Added pci_request_regions() before using the controller to avoid duplicate usage of the I2O controller when the dpt_i2o driver and I2O subsystem is loaded at the same time. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
2005-08-09[SPARC]: envctrl: ERR_PTR() --> PTR_ERR()David S. Miller
Fix thinko in Christoph's changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-09[SPARC]: remove ifdef CONFIG_PCI from envctrl.cChristoph Hellwig
The driver already depends on CONFIG_PCI in Kconfig. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-09[SPARC]: Use kthread infrastructure in bbc_envctrlChristoph Hellwig
2005-08-09[SPARC]: Use kthread infrastructure in envctrlChristoph Hellwig
envctrl currently uses very odd ways to stop a thread, using various things that should be exposed to drivers at all. This patch (which is untested as I don't have sparc hardware) switches it to use the proper kthread infrastructure. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-09[PATCH] i2o: remove new configuration APIMarkus Lidel
Remove new configuration API from i2o_config The API-patch is still available from the I2O website (which is mentioned in the kernel config now). It is removed because it creates a new binary sysfs-attribute, which doesn't have the limitiation of 4k. Expect for the Adaptec controllers, which has a limitation in the hardware this attribute doesn't make sense anywhere else. Until the sysfs API provides an attribute which doesn't buffer (like firmware) and let access to at least 64k blocks i provide a separate patch... (akpm: basically, this API was introduced post-2.6.12 and Markus wants to pull it out before 2.6.13). Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] cpm_uart: needs some love to compile with GCC4.0.1Kumar Gala
Fixed problems so we can build with gcc-4.0.1 Signed-off-by: Peter Schaefer-Hutter <peter.schaefer-hutter@tfk-racoms.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] cpm_uart: Fix dpram allocation and non-console uartsKumar Gala
* Makes dpram allocations work * Makes non-console UART work on both 8xx and 82xx * Fixed whitespace in files that were touched Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Pantelis Antoniou <panto@intracom.gr> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] Build fix for the Sibyte I2C driverRalf Baechle
Compile fix for the BCM1250 I2C driver. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[PATCH] i8xx_tco.c: arm watchdog only when startedWim Van Sebroeck
i8xx_tco.c v0.08: only "arm" the watchdog when the watchdog has been started. (Kernel Bug 4251: system reset when battery is read and i8xx_tco driver loaded) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[SCSI] dpt_i2o pci_request_regions fixSalyzyn, Mark
Originally From: Andrew Morton <akpm@osdl.org> Altered By: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> There is an additional 'build fix' patch that Andrew Morton submitted on the kernel list (I have changed out his dpr_i2o with dpt_i2o below though). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-08Revert "[PATCH] PCI: restore BAR values..."Linus Torvalds
Revert commit fec59a711eef002d4ef9eb8de09dd0a26986eb77, which is breaking sparc64 that doesn't have a working pci_update_resource. We'll re-do this after 2.6.13 when we'll do it all properly.
2005-08-08[PATCH] icn driver fails to unload when no hardware presentDave Jones
Fix a null dereference in module unload path. Found by a simple modprobe icn ; rmmod icn Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-08-08[SCSI] fix target scanning oops with fc transport classJames.Smart@Emulex.Com
We have some nasty issues with 2.6.12-rc6. Any request to scan on the lpfc or qla2xxx FC adapters will oops. What is happening is the system is defaulting to non-transport registered targets, which inherit the parent of the scan. On this second scan, performed by the attribute, the parent becomes the shost instead of the rport. The slave functions in the 2 FC adapters use starget_to_rport() routines, which incorrectly map the shost as an rport pointer. Additionally, this pointed out other weaknesses: - If the target structure is torn down outside of the transport, we have no method for it to be regenerated at the proper parent. - We have race conditions on the target being allocated by both the midlayer scan (parent=shost) and by the fc transport (parent=rport). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-08Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-08-08[PATCH] dvb: lgdt330x frontend: some bug fixes & add lgdt3303 supportMichael Krufky
- Structural changes within lgdt330x driver, framework now supports both chips... tested OK on lgdt3302 and lgdt3303. - Add LG/TUA6034 dvb_pll_desc for ATSC with LG TDVS-H062F & DViCO FusionHDTV5. - Fixed LGDT330X signal strength: For now, always set it to 0. - Corrected LGDT330X boundary condition error in read_snr: dB calculation. Signed-off-by: Mac Michaels <wmichaels1@earthlink.net> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] s390: use klist in qeth driverCornelia Huck
From: Martin Schwidesky <schwidefsky@de.ibm.com> Convert qeth to the new klist interface and make it compiling again. Signed-off-by: Frank Pavlic <pavlic@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] VIA VT8235 PCI quirkIvan Kokshaysky
Like many other southbridges from different manufacturers, VIA VT8235 chip has two non-standard BARs for power management and SMBus registers (see the datasheet at http://www.via.com.tw). This new quirk routine fixes boot problem with 2.6.13-rc2/rc6 kernels on Targa Visionary 811 Athlon64 laptop, as reported by Mikael Pettersson <mikpe@csd.uu.se>. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] nvidiafb: Fix initial display corruption on certain laptopsAntonino Daplas
Reported by:Vincent Fortier (Bugzilla Bug 4768) "At boot time the screen appears moved to the mid right portion of the actual video pannel making the end of the line appears at the left edge... It simply looks like moved half way to the right" His particular hardware has a display with an unusual dimension (1920x1200) but unfortunately has no EDID block. None of the entries in the global mode database is correct for this particular display, and it particularly has difficulty scaling up 640x480 (the default startup mode of nvidiafb) to 1920x1200 which causes the above described problem. 1, Add 1920x1200 to the global mode database. 2. Let nvidiafb base the startup mode from the flatpanel dimensions only if the EDID block is absent, no boot mode parameter is specified by the user, and a flatpanel/LCD display is attached. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[SCSI] Bug 4940 Repeatable Kernel Panic on Adaptec 2015S I20 device on bootupJames Bottomley
From: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Prevent driver from loading if another driver (i2o) has already claimed the resources associated with the card. Discussion associated with this bug can be referenced at http://bugzilla.kernel.org/show_bug.cgi?id=4940 where it was agreed to use pci_request_regions in both the dpt_i2o and the i2o driver to prevent both drivers loading on the same adapter(s). Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-07[PATCH] Fix restore of 64-bit PCI BAR'sIvan Kokshaysky
For 64-bit BAR[i] only pci_dev->resource[i] is valid, ->resource[i+1] slot is unused and contains zeroes in all fields. So when we update a PCI BAR, all we need is just to check that we're going to update a _valid_ resource. Also make sure to write high bits - use "x >> 16 >> 16" (rather than the simpler ">> 32") to avoid warnings on 32-bit architectures where we're not going to have any high bits. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-07[PATCH] ARM: switch fd1772.c from sleep_on to wait_eventChristoph Hellwig
Doesn't make the local irq disabling around it less buggy, but at least we replace the offender with the right kind of primitive. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-07[PATCH] ARM: Make sa1100fb_display_dma_period() an inline functionRussell King
This function produces a warning when CPU_FREQ=n. Since it's a very simple calculation, make it inline instead of adding preprocessor directives around it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-06[TG3]: Save initial PCI state before registering the netdevice.David S. Miller
Else on SMP systems it is possible for hotplug to execute, invoke tg3_open(), and end up loading the uninitialized PCI register save area into the card. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-06[Bluetooth] Remove unused functions and cleanup symbol exportsMarcel Holtmann
This patch removes the unused bt_dump() function and it also removes its BT_DMP macro. It also unexports the hci_dev_get(), hci_send_cmd() and hci_si_event() functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-08-06[Bluetooth] Kill redundant NULL checks before kfree()Marcel Holtmann
There's no need to check for NULL before calling kfree() on a pointer. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
