This is the result of a brute-force attempt to update the kernel to 2.6.23.
Now that we have a git tree, our effort will be a little nicer in the future.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Patch for CR ENGR00053563 Fix Sahara Issue For MX27
Replace dma_map_single() with direct calls to L1,L2
cache functions. Applies to linux 2.6.22 kernel on
MX27 platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00053563-Fix-Sahara-Issue-For-MX27.patch
Patch for CR ENGR00053192 MXC Sahara2: Use CONFIG_OUTER_CACHE
Fix Sahara unit test failure by replacing CONFIG_CPU_CACHE_L2X0
with CONFIG_OUTER_CACHE. Applies to linux 2.6.22 kernel on
MX27 platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00053192-MXC-Sahara2-Use-CONFIG_OUT.patch
Patch for Bugzilla 802 - Fix MX3 DVFS/DPTC table initialization
on linux 2.6.22 kernel for MX3 platforms.
dvfs_dptc_init_default() gives MX32 the wrong default tables. This patch
corrects the logic for MX32, while maintaining proper support for MX31
TO2. A side effect of this patch is to fix another instance of the
obscure "register swizzle" bug, wherein a general register gets
corrupted and causes various kernel oops crashes.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-802-Fix-MX3-DVFS-DPTC-table-initi.patch
Patch for CR ENGR00053136: Fix mx27 v4l2 rotation cacheflush.
This patch fixes cache invalidation by MX27 V4L2 driver when rotation is
used. The consistent_sync function was is restricted to kernel direct
mapped addresses. Applies to linux 2.6.22 kernel on MX27 platform.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00053136-fix-mx27-v4l2-rotation-cac.patch
Patch for CR ENGR00052918: This patch updates the FEC ethernet with
workqueue changes for the linux 2.6.22 kernel.
Applies to MX27 platform.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00052918-fec-2.6.22-workqueue-chang.patch
Patch for CR ENGR00052743: Reset the CSPI module for MX27 before
initializing it. Applies to linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00052743-Reset-CSPI-On-MX27.patch
Patch for CR ENGR00050116 Fix flawed implementation of XIP Macros.
The existing flawed implementations of xip_currtime, xip_elasped_since
and xip_irqpending macros are fixed. Applies to linux 2.6.22 kernel
for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00050116-Fix-flawed-implementation-.patch
Patch for CR ENGR00052514 refresh of ENGR0045732 to fix MMC read data
corruption.
This patch ports 1) Changes for ENGR00045732: Fix for MMC read data
corruption problem from the 2.6.18 kernel mmc driver to the 2.6.22
kernel driver. 2) Code in mxcmci_finish_request which had accidently
been dropped has been reinserted. Applies to MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00052514-refresh-of-ENGR0045732-to-.patch
Patch for CR ENGR00043959 Merging mxc nand driver across RS ECC NFCs
DevTech Note: This patch also supports Redboot partition parsing on NAND,
and updates the NOR driver to use kzalloc instead of kmalloc/memset as
is being done throughout the mainline kernel. Applies to linux 2.6.22
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00043959-Merging-mxc-nand-driver-ac.patch
Patch for Bugzilla 784 - Fixed MMC/SD error -110 on linux 2.6.22
MMC_ERR_NONE transform in mxc_mmc.c was misapplied in one instance
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-784-Fixed-MMC-SD-error-110.patch
Patch for Bugzilla 779 - Fix OV2460 camera driver oopsen on linux 2.6.22
kernel for MX platforms. Added stubs for new routines required in the
camera interface structure. This camera driver should be considered a
prototype. It does not have all the functionality of the others.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-779-Fix-OV2460-camera-driver-oops.patch
Patch for CR ENGR00013463 IPU: wait for SDC flips to finish on disable.
This patch makes sure SDC buffer flips complete before disabling the
channel. Applies to linux 2.6.22 kernel on MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00013463-IPU-wait-for-SDC-flips-to-.patch
Patch for CR ENGR00048608: Work around untrustworthy NFMS_BIT.
Changed to set or clear NFMS bit based on mtd->writesize
in driver specific nand_scan routine. Applies to linux
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00048608-Work-around-untrustworthy-.patch
Patch for CR ENGR00039921 v4l2: support L1 writeback cached buffers
This patch makes MXC V4L2 output buffers L1 writeback cacheable. The L1
cache is flushed for each QBUF ioctl call if the buffer is mmapped.
Applies to linux 2.6.22 kernel on MX3 platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00039921-v4l2-support-L1-writeback-.patch
Patch for CR ENGR00049720 mxc_pf: add frame_size limit checks.
This patch adds checks to init ioctl for maximum frame size.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00049720-mxc_pf-add-frame_size-limi.patch
Bugzilla 783. USBCV 1.3 HaltEndpointTest fails.
Fix this by porting ch9getstatus() from fsl_usb2_udc.c.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-USB-USBCV-1.3-HaltEndpointTest-fails.patch
Patch for CR ENGR00011205: Move linux includes before other includes.
This patch moves linux includes before other includes, which is
standard practice in linux kernel development.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00011205-Move-linux-includes-before.patch
Patch for CR ENGR00048159 Add L2 flush for all mxc PF.
This patch adds an outer cache flush_all function needed by the IPU
mxc_pf driver to synchronize WT cached buffers in the L2 cache.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00048159-Add-L2-flush-for-all-mxc-P.patch
Patch for CR ENGR00046932 - Sahara build warnings are resolved.
Removed unsupported SSL code. Applies to linux 2.6.22 kernel
for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00046932-Sahara-build-warnings-are-.patch
Patch for Bugzilla 771 - Fix pata_fsl libata driver DMA mode. Full
sglist DMA working on linux 2.6.22 for MX27/MX31. Not fast enough on
MX27, though. MX31 is as fast as the old mxc_ide driver. Writes are
unreliable on MX27 TO1. Beyond UDMA3 on MX27 wasn't 100% reliable.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-771-Fix-pata_fsl-libata-driver-DM.patch
PATCH for CR DSPhl24421 Add power handlers to libata pata_fsl driver.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-DSPhl24421-Add-power-handlers-to-libata.patch
Patch for Bugzilla 771 - PATA_FSL: Remove non-working DMA support
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-771-PATA_FSL-Remove-non-working-D.patch
Patch to fix Bugzilla 745, 746, 747. USB: Clean up more Kconfig options.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-USB-cleanup-Kconfig-options-some-more.patch
USB: Restore mainline core/Kconfig contents. CONFIG_USB_OTG should not
have a prompt here, since it's already displayed in the gadget menu.
The help text erroneously mentions HNP and SRP, which isn't currently
supported. Applies to linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-USB-Restore-mainline-core-Kconfig-contents.patch
Patch to fix Bugzilla 745, 746, 747. USB: Clean up Kconfig options.
- remove prompts from options in arch/arm/plat-mxc/Kconfig.
these are auto-selected, and don't need to be visible to the user.
- restore CONFIG_TRANSCEIVER_MXC_OTG back to the original
CONFIG_ISP1504_MXC_OTG, since this is isp1504 specific,
and add the hidden CONFIG_ISP1504_MXC_OTG to arch/arm/plat-mxc/Kconfig
which is automatically selected instead of adding a user-visable
option.
- along with that, we can remove drivers/usb/otg/Kconfig, and its
inclusion from drivers/usb/Kconfig
- replace a bunch of _ARC_ names with _FSL_ names. Still needs more
work.
- fix misspellings, typos, etc.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-USB-cleanup-Kconfig-options2.patch
Patch to fix Bugzilla 745, 746, 747. USB: cleanup Kconfig options.
option.
work.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-USB-cleanup-Kconfig-options.patch
Patch to remove custom error codes in MX MMC driver.
Replace MXC-specific error codes with generic kernel error codes
in the MMC driver. Applies to linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-MXC-MMC-Remove-custom-error-codes.patch
Patch for Bugzilla 510: Update to code review fixes following L2618.2
Changes made to fix bugs and/or port to 2.6.19.2 after including GSO
L2618-2 patches as discovered and discussed in the code review.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-510-Update-to-code-review-fixes-f.patch
Patch to update drivers, such as dpm, dvfs, ide, and sir to use the new,
generic clock API's. Remove clock-gating calls from the gpio active and
inactive functions. Applies to linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Update-drivers-such-as-dpm-dvfs-ide-and-si.patch
Bug fix of Bugzilla 363 to enable ATA subsystem clock before writing to
ATA subsystem on the linux 2.6.22 kernel for MX31/32 platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bug-fix-of-Bugzilla-363-to-enable-ATA-subs.patch
Patch to work around compile breakage for mx27 on ov2640 camera driver.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Work-around-compile-breakage-for-mx27-on-o.patch
gpio_uart_active()
Patch for Bugzilla 533 - Fix "multi-times" message and prevent extra
call to gpio_uart_active() in the linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-533-Fix-multi-times-message-and-p.patch
Add Prototype FSL PATA LIBATA driver to linux 2.6.22 kernel
for MX platforms. Working in PIO mode on MX31 and MX27.
Incompatible with current SDMA IAPI due to a sleep in
the DMA configuration setup path.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Prototype-FSL-PATA-LIBATA-driver.patch
Patch to add Community MMC/SD/SDIO support from Pierre Ossman's tree
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc.git
Author: Pierre Ossman
Snapshot taken 20070910, and applied to linux 2.6.22.6 by Quinn Jensen.
Portions Copyright Pierre Ossman and Monta Vista.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Community-MMC-SD-SDIO-support-from-Pierre-.patch
Backport of MMC/SD/SDIO updates from the linux 2.6.23-rc3 kernel to the
2.6.22.6 kernel. This patch created from mmc diffs between linus git
2.6.22 and 2.6.23-rc3. Sources are available from kernel.org.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Backport-to-2.6.22.6-of-MMC-SD-SDIO-update.patch
Patch for CR ENGR00049086: fix scc fail fuse not blown.
Deregistering the driver properly to prevent boot crash if SCC fuse are
not blown. Applies to linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00049086-fix-scc-fail-fuse-not-blow.patch
Patch for CR ENGR00043063: add platform device support for scc.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00043063-platform-device-for-scc-ad.patch
Patch for CR ENGR00047179: fix disable console on mxc uart breaks build
when console support on mxc uart is disabled. Applies to linux 2.6.22
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00047179-fix-disable-console-on-mxc.patch
Patch for Bugzilla 630. Allow rng registers to be read and written for
testing purposes on the linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Bugzilla-630.-Allow-rng-registers-to-be-re.patch
Patch to mke the latency hiding option MX27 specific since it could
break other platforms that have a VPU. Applies to linux 2.6.22
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Make-the-latency-hiding-option-mx27-specif.patch
Patch to fix coding errors in the mxc v4l2 output driver.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Fixed-coding-errors-in-the-mxc-v4l2-output.patch
Patch for CR ENGR00038129: Add vpu latency-hiding control. Fixes an
mpeg4 pending issue on MX27 TO2. Applies to the linux 2.6.22 kernel
for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00038129-Add-vpu-latency-hiding-con.patch
Patch for CR 34439732: Camera and V4L2 improvements.
Add flicker control, white balance, automatic exposure support, and tear
prevention to the iMagic camera driver on the linux 2.6.22 kernel for MX
platforms.
Ported to 2.6.22 by Ross Wille
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-34439732-Camera-and-V4L2-improvements.patch
Patch for CR ENGR00033520: Add a new algorithm to the PP and PRP drivers
that determines more accurate scaling factors. Applies to linux 2.6.22
kernel for the MX27 platform.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00033520-Add-a-new-algorithm-to-the.patch
Patch for CR ENGR37631: Adds correct signal handling to the V4L2 input
and output devices. Adds handling of PRP overflow on channel2 under high
system load. Applies to linux 2.6.22 kernel on MX27 platform.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR37631-Adds-correct-signal-handling-.patch
Patch for CR 34440439: Under heavy load v4l2 ioctls sometimes return
error (EINTR or ETIME). This patch fixes vpu v4l2 interrupt code to be
more robust. Applies to linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-34440439-Under-heavy-load-v4l2-ioctls-s.patch
load.
Patch for CR ENGR00037631: Add handling of prp overflow on channel 2
under high system load. Applies to linux 2.6.22 kernel for the MX27
platform.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-ENGR00037631-Add-handling-of-prp-overfl.patch
Patch for CR SDCaa01608: I2C uses wrong adapter name.
In the mxc_i2c driver, set the adapter name to be the same as the
platform_device name. Otherwise, drivers that use i2c may fail
when checking the mxc_i2c adapter name, such as the USB driver.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-CR-SDCaa01608-I2C-uses-wrong-adapter-name.patch
Patch to add interrogation of V4L2 or Linux udev to determine if a
camera is present. Add status and detection functionality for mt9v111
camera to the linux 2.6.22 kernel for MX platforms.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-Add-interrogation-of-V4L2-or-Linux-udev-to.patch
