path: root/drivers
2015-06-24Merge tag 'backlight-for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight Pull backlight updates from Lee Jones: "Changes to existing drivers: - supply MODULE_DEVICE_TABLE() to ensure probing - constify struct; da9052_bl - enable compile test; lcd_l4f00242t03, lcd_lms283fg05, backlight_gpio - suspend/resume bugfix; lp855x_bl - devm_gpiod_get_optional() API fixup; pwm_bl - error handling fixup; backlight" * tag 'backlight-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight: backlight: Change the return type of backlight_update_status() to int backlight: pwm_bl: Simplify usage of devm_gpiod_get_optional backlight: lp855x: Don't clear level on suspend/blank backlight: Allow compile test of GPIO consumers if !GPIOLIB video: backlight: da9052: Constify platform_device_id gpio-backlight: Discover driver during boot time
2015-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add TX fast path in mac80211, from Johannes Berg. 2) Add TSO/GRO support to ibmveth, from Thomas Falcon 3) Move away from cached routes in ipv6, just like ipv4, from Martin KaFai Lau. 4) Lots of new rhashtable tests, from Thomas Graf. 5) Run ingress qdisc lockless, from Alexei Starovoitov. 6) Allow servers to fetch TCP packet headers for SYN packets of new connections, for fingerprinting. From Eric Dumazet. 7) Add mode parameter to pktgen, for testing receive. From Alexei Starovoitov. 8) Cache access optimizations via simplifications of build_skb(), from Alexander Duyck. 9) Move page frag allocator under mm/, also from Alexander. 10) Add xmit_more support to hv_netvsc, from KY Srinivasan. 11) Add a counter guard in case we try to perform endless reclassify loops in the packet scheduler. 12) Extern flow dissector to be programmable and use it in new "Flower" classifier. From Jiri Pirko. 13) AF_PACKET fanout rollover fixes, performance improvements, and new statistics. From Willem de Bruijn. 14) Add netdev driver for GENEVE tunnels, from John W Linville. 15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso. 16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet. 17) Add an ECN retry fallback for the initial TCP handshake, from Daniel Borkmann. 18) Add tail call support to BPF, from Alexei Starovoitov. 19) Add several pktgen helper scripts, from Jesper Dangaard Brouer. 20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa. 21) Favor even port numbers for allocation to connect() requests, and odd port numbers for bind(0), in an effort to help avoid ip_local_port_range exhaustion. From Eric Dumazet. 22) Add Cavium ThunderX driver, from Sunil Goutham. 23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata, from Alexei Starovoitov. 24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai. 25) Double TCP Small Queues default to 256K to accomodate situations like the XEN driver and wireless aggregation. From Wei Liu. 26) Add more entropy inputs to flow dissector, from Tom Herbert. 27) Add CDG congestion control algorithm to TCP, from Kenneth Klette Jonassen. 28) Convert ipset over to RCU locking, from Jozsef Kadlecsik. 29) Track and act upon link status of ipv4 route nexthops, from Andy Gospodarek. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits) bridge: vlan: flush the dynamically learned entries on port vlan delete bridge: multicast: add a comment to br_port_state_selection about blocking state net: inet_diag: export IPV6_V6ONLY sockopt stmmac: troubleshoot unexpected bits in des0 & des1 net: ipv4 sysctl option to ignore routes when nexthop link is down net: track link-status of ipv4 nexthops net: switchdev: ignore unsupported bridge flags net: Cavium: Fix MAC address setting in shutdown state drivers: net: xgene: fix for ACPI support without ACPI ip: report the original address of ICMP messages net/mlx5e: Prefetch skb data on RX net/mlx5e: Pop cq outside mlx5e_get_cqe net/mlx5e: Remove mlx5e_cq.sqrq back-pointer net/mlx5e: Remove extra spaces net/mlx5e: Avoid TX CQE generation if more xmit packets expected net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq() net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device ...
2015-06-24Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: "Mostly refactoring/clean-up: - CPU ops and PSCI (Power State Coordination Interface) refactoring following the merging of the arm64 ACPI support, together with handling of Trusted (secure) OS instances - Using fixmap for permanent FDT mapping, removing the initial dtb placement requirements (within 512MB from the start of the kernel image). This required moving the FDT self reservation out of the memreserve processing - Idmap (1:1 mapping used for MMU on/off) handling clean-up - Removing flush_cache_all() - not safe on ARM unless the MMU is off. Last stages of CPU power down/up are handled by firmware already - "Alternatives" (run-time code patching) refactoring and support for immediate branch patching, GICv3 CPU interface access - User faults handling clean-up And some fixes: - Fix for VDSO building with broken ELF toolchains - Fix another case of init_mm.pgd usage for user mappings (during ASID roll-over broadcasting) - Fix for FPSIMD reloading after CPU hotplug - Fix for missing syscall trace exit - Workaround for .inst asm bug - Compat fix for switching the user tls tpidr_el0 register" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (42 commits) arm64: use private ratelimit state along with show_unhandled_signals arm64: show unhandled SP/PC alignment faults arm64: vdso: work-around broken ELF toolchains in Makefile arm64: kernel: rename __cpu_suspend to keep it aligned with arm arm64: compat: print compat_sp instead of sp arm64: mm: Fix freeing of the wrong memmap entries with !SPARSEMEM_VMEMMAP arm64: entry: fix context tracking for el0_sp_pc arm64: defconfig: enable memtest arm64: mm: remove reference to tlb.S from comment block arm64: Do not attempt to use init_mm in reset_context() arm64: KVM: Switch vgic save/restore to alternative_insn arm64: alternative: Introduce feature for GICv3 CPU interface arm64: psci: fix !CONFIG_HOTPLUG_CPU build warning arm64: fix bug for reloading FPSIMD state after CPU hotplug. arm64: kernel thread don't need to save fpsimd context. arm64: fix missing syscall trace exit arm64: alternative: Work around .inst assembler bugs arm64: alternative: Merge alternative-asm.h into alternative.h arm64: alternative: Allow immediate branch as alternative instruction arm64: Rework alternate sequence for ARM erratum 845719 ...
2015-06-24Merge tag 'powerpc-4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - disable the 32-bit vdso when building LE, so we can build with a 64-bit only toolchain. - EEH fixes from Gavin & Richard. - enable the sys_kcmp syscall from Laurent. - sysfs control for fastsleep workaround from Shreyas. - expose OPAL events as an irq chip by Alistair. - MSI ops moved to pci_controller_ops by Daniel. - fix for kernel to userspace backtraces for perf from Anton. - merge pseries and pseries_le defconfigs from Cyril. - CXL in-kernel API from Mikey. - OPAL prd driver from Jeremy. - fix for DSCR handling & tests from Anshuman. - Powernv flash mtd driver from Cyril. - dynamic DMA Window support on powernv from Alexey. - LLVM clang fixes & workarounds from Anton. - reworked version of the patch to abort syscalls when transactional. - fix the swap encoding to support 4TB, from Aneesh. - various fixes as usual. - Freescale updates from Scott: Highlights include more 8xx optimizations, an e6500 hugetlb optimization, QMan device tree nodes, t1024/t1023 support, and various fixes and cleanup. * tag 'powerpc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (180 commits) cxl: Fix typo in debug print cxl: Add CXL_KERNEL_API config option powerpc/powernv: Fix wrong IOMMU table in pnv_ioda_setup_bus_dma() powerpc/mm: Change the swap encoding in pte. powerpc/mm: PTE_RPN_MAX is not used, remove the same powerpc/tm: Abort syscalls in active transactions powerpc/iommu/ioda2: Enable compile with IOV=on and IOMMU_API=off powerpc/include: Add opal-prd to installed uapi headers powerpc/powernv: fix construction of opal PRD messages powerpc/powernv: Increase opal-irqchip initcall priority powerpc: Make doorbell check preemption safe powerpc/powernv: pnv_init_idle_states() should only run on powernv macintosh/nvram: Remove as unused powerpc: Don't use gcc specific options on clang powerpc: Don't use -mno-strict-align on clang powerpc: Only use -mtraceback=no, -mno-string and -msoft-float if toolchain supports it powerpc: Only use -mabi=altivec if toolchain supports it powerpc: Fix duplicate const clang warning in user access code vfio: powerpc/spapr: Support Dynamic DMA windows vfio: powerpc/spapr: Register memory and define IOMMU v2 ...
2015-06-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "Pretty boring for a merge window pull. One change in behaviour is the patch for dasd driver, the module which provides the diagnose discipline is now loaded automatically. The SCLP code got a nice cleanup, a new global structure replaces a bunch of accessor functions. And a couple of random, small improvements" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/pci: improve handling of hotplug event 0x301 s390/setup: fix DMA_API_DEBUG warnings s390/zcrypt: remove obsolete __constant s390/keyboard: avoid off-by-one when using strnlen_user() s390/sclp: pass timeout as HZ independent value s390/mm: s/specifiation/specification/, s/an specification/a specification/ s390/sclp: Use DECLARE_BITMAP s390/dasd: Enable automatic loading of dasd_diag_mod s390/sclp: move sclp_facilities into "struct sclp" s390/sclp: get rid of sclp_get_mtid() and sclp_get_mtid_max() s390/sclp: unify basic sclp access by exposing "struct sclp" s390/sclp: prepare smp_fill_possible_mask for global "struct sclp"
2015-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/mellanox/mlx4/main.c net/packet/af_packet.c Both conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24stmmac: troubleshoot unexpected bits in des0 & des1Alexey Brodkin
Current implementation of descriptor init procedure only takes care about setting/clearing ownership flag in "des0"/"des1" fields while it is perfectly possible to get unexpected bits set because of the following factors: [1] On driver probe underlying memory allocated with dma_alloc_coherent() might not be zeroed and so it will be filled with garbage. [2] During driver operation some bits could be set by SD/MMC controller (for example error flags etc). And unexpected and/or randomly set flags in "des0"/"des1" fields may lead to unpredictable behavior of GMAC DMA block. This change addresses both items above with: [1] Use of dma_zalloc_coherent() instead of simple dma_alloc_coherent() to make sure allocated memory is zeroed. That shouldn't affect performance because this allocation only happens once on driver probe. [2] Do explicit zeroing of both "des0" and "des1" fields of all buffer descriptors during initialization of DMA transfer. And while at it fixed identation of dma_free_coherent() counterpart as well. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com> Cc: arc-linux-dev@synopsys.com Cc: linux-kernel@vger.kernel.org Cc: stable@vger.kernel.org Cc: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net: Cavium: Fix MAC address setting in shutdown statePavel Fedin
This bug pops up with NetworkManager on Fedora 21. NetworkManager tends to stop the interface (nicvf_stop() is called) before changing settings. In stopped state MAC cannot be sent to a PF. However, when the interface is restarted (nicvf_open() is called), we ping the PF using NIC_MBOX_MSG_READY message, and the PF replies back with old MAC address, overriding what we had after MAC setting from userspace. As a result, we cannot set MAC address using NetworkManager. This patch introduces special tracking of MAC change in stopped state so that the correct new MAC address is sent to a PF when interface is reopen. Signed-off-by: Pavel Fedin <p.fedin@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24drivers: net: xgene: fix for ACPI support without ACPIStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Prefetch skb data on RXSaeed Mahameed
Prefetch the 1st cache line used by the buffer pointed by the skb linear data. Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Pop cq outside mlx5e_get_cqeAchiad Shochat
Separate between mlx5e_get_cqe() and mlx5_cqwq_pop(), this helps for better code readability and better CQ buffer management. Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Remove mlx5e_cq.sqrq back-pointerAchiad Shochat
Use container_of() instead. Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Remove extra spacesAchiad Shochat
Coding Style fix, remove extra spaces. Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Avoid TX CQE generation if more xmit packets expectedAchiad Shochat
In order to save PCI BW consumed by TX CQEs and to reduce the amount of CPU cache misses caused by TX CQE reading, we request TX CQE generation only when skb->xmit_more=0. As a consequence of the above, a single TX CQE may now indicate the transmission completion of multiple TX SKBs. This also handles a problem introduced in commit b1b8105ebf41 "net/mlx5e: Support NETIF_F_SG" where we didn't ask for NOP completions while the driver didn't have the proper code to handle this case. Fixes: b1b8105ebf41 ('net/mlx5e: Support NETIF_F_SG') Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completionAchiad Shochat
NOP completion SKBs are always NULL. Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()Achiad Shochat
It is already assigned at mlx5e_build_rq_param() Signed-off-by: Achiad Shochat <achiad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting themSaeed Mahameed
Instead of counting number of gso fragments, we can use skb_shinfo(skb)->gso_segs. Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queuesSaeed Mahameed
To save per-packet calculations, we use the following static mappings: 1) priv {channel, tc} to netdev txq (used @mlx5e_selec_queue()) 2) netdev txq to priv sq (used @mlx5e_xmit()) Thanks to these static mappings, no more need for a separate implementation of ndo_start_xmit when multiple TCs are configured. We believe the performance improvement of such separation would be negligible, if any. The previous way of dynamically calculating the above mappings required allocating more TX queues than actually used (@alloc_etherdev_mqs()), which is now no longer needed. Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF deviceEran Ben Elisha
Under SRIOV, the port rx/tx bytes/packets statistics should by read from the HW instead of using the PF netdevice SW accounting. This is needed in order to get the full port statistics and not just the PF own ones Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24net/mlx4_en: Fix off-by-four in ethtoolEran Ben Elisha
NUM_ALL_STATS was not updated with the new four entries, instead NUM_FLOW_STATS was updated, fix it. that caused off-by-four for all counters below pf_*_*. Fixes: b42de4d01264 ('net/mlx4_en: Show PF own statistics via ethtool') Signed-off-by: Eran Ben Elisha <eranbe@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23Merge tag 'iommu-updates-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "This time with bigger changes than usual: - A new IOMMU driver for the ARM SMMUv3. This IOMMU is pretty different from SMMUv1 and v2 in that it is configured through in-memory structures and not through the MMIO register region. The ARM SMMUv3 also supports IO demand paging for PCI devices with PRI/PASID capabilities, but this is not implemented in the driver yet. - Lots of cleanups and device-tree support for the Exynos IOMMU driver. This is part of the effort to bring Exynos DRM support upstream. - Introduction of default domains into the IOMMU core code. The rationale behind this is to move functionalily out of the IOMMU drivers to common code to get to a unified behavior between different drivers. The patches here introduce a default domain for iommu-groups (isolation groups). A device will now always be attached to a domain, either the default domain or another domain handled by the device driver. The IOMMU drivers have to be modified to make use of that feature. So long the AMD IOMMU driver is converted, with others to follow. - Patches for the Intel VT-d drvier to fix DMAR faults that happen when a kdump kernel boots. When the kdump kernel boots it re-initializes the IOMMU hardware, which destroys all mappings from the crashed kernel. As this happens before the endpoint devices are re-initialized, any in-flight DMA causes a DMAR fault. These faults cause PCI master aborts, which some devices can't handle properly and go into an undefined state, so that the device driver in the kdump kernel fails to initialize them and the dump fails. This is now fixed by copying over the mapping structures (only context tables and interrupt remapping tables) from the old kernel and keep the old mappings in place until the device driver of the new kernel takes over. This emulates the the behavior without an IOMMU to the best degree possible. - A couple of other small fixes and cleanups" * tag 'iommu-updates-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (69 commits) iommu/amd: Handle large pages correctly in free_pagetable iommu/vt-d: Don't disable IR when it was previously enabled iommu/vt-d: Make sure copied over IR entries are not reused iommu/vt-d: Copy IR table from old kernel when in kdump mode iommu/vt-d: Set IRTA in intel_setup_irq_remapping iommu/vt-d: Disable IRQ remapping in intel_prepare_irq_remapping iommu/vt-d: Move QI initializationt to intel_setup_irq_remapping iommu/vt-d: Move EIM detection to intel_prepare_irq_remapping iommu/vt-d: Enable Translation only if it was previously disabled iommu/vt-d: Don't disable translation prior to OS handover iommu/vt-d: Don't copy translation tables if RTT bit needs to be changed iommu/vt-d: Don't do early domain assignment if kdump kernel iommu/vt-d: Allocate si_domain in init_dmars() iommu/vt-d: Mark copied context entries iommu/vt-d: Do not re-use domain-ids from the old kernel iommu/vt-d: Copy translation tables from old kernel iommu/vt-d: Detect pre enabled translation iommu/vt-d: Make root entry visible for hardware right after allocation iommu/vt-d: Init QI before root entry is allocated iommu/vt-d: Cleanup log messages ...
2015-06-23Merge tag 'for-linus-20150623' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "JFFS2: - fix a theoretical unbalanced locking issue; the lock handling was a bit unclean, but AFAICT, it didn't actually lead to real deadlocks NAND: - brcmnand driver: new driver supporting NAND controller found originally on Broadcom STB SoCs (BCM7xxx), but now also found on BCM63xxx, iProc (e.g., Cygnus, BCM5301x), BCM3xxx, and more - begin factoring out BBT code so it can be shared between traditional (parallel) NAND drivers and upcoming SPI NAND drivers (WIP) - add common DT-based init support, so nand_base can pick up some flash properties automatically, using established common NAND DT properties - mxc_nand: support 8-bit ECC - pxa3xx_nand: * fix build for ARM64 * use a jiffies-based timeout SPI NOR: - add a few new IDs - clear out some unnecessary entries - make sure SECT_4K flags are correct for all (?) entries Core: - fix mtd->usecount race conditions (BUG_ON()) - switch to modern PM ops Other: - CFI: save code space by de-inlining large functions - clean up some partition parser selection code across several drivers - various miscellaneous changes, mostly minor" * tag 'for-linus-20150623' of git://git.infradead.org/linux-mtd: (57 commits) mtd: docg3: Fix kasprintf() usage mtd: docg3: Don't leak docg3->bbt in error path mtd: nandsim: Fix kasprintf() usage mtd: cs553x_nand: Fix kasprintf() usage mtd: r852: Fix device_create_file() usage mtd: brcmnand: drop unnecessary initialization mtd: propagate error codes from add_mtd_device() mtd: diskonchip: remove two-phase partitioning / registration mtd: dc21285: use raw spinlock functions for nw_gpio_lock mtd: chips: fixup dependencies, to prevent build error mtd: cfi_cmdset_0002: Initialize datum before calling map_word_load_partial mtd: cfi: deinline large functions mtd: lantiq-flash: use default partition parsers mtd: plat_nand: use default partition probe mtd: nand: correct indentation within conditional mtd: remove incorrect file name mtd: blktrans: use better error code for unimplemented ioctl() mtd: maps: Spelling s/reseved/reserved/ mtd: blktrans: change blktrans_getgeo return value mtd: mxc_nand: generate nand_ecclayout for 8 bit ECC ...
2015-06-23Merge tag 'mfd-for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - Constify structures; throughout the subsystem - Move support to DT in; cros_ec - DT changes and documentation; cros-ec, max77693, max77686, arizona, da9063 - ACPI changes and documentation; mfd-core - Use different platform specific API in; cros_ec_*, arizona-core - Remove unused parent field from; cros_ec_i2c - Add wake-up/reset delay in; cross_ec_spi, arizona-core - Staticise structures/functions in; cros_ec - Remove redundant code; arizona-core, max77686 - Bugfix; twl4030-power - Allow compile test; aat2870, tps65910 - MAINTAINERS adaptions; samsung, syscon - Resource Management (devm_*); arizona-core - Refactor Reset code; arizona-core - Insist on at least one full boot; arizona-core - Trivial formatting; arizona-core - Add low-power-sleep; arizona-core - IRQ ONESHOT changes; twl4030-irq, mc13xxx-core, wm831x-auxadc, htc-i2cpld, wm8350-core, ab8500-debugfs, ab8500-gpadc, si476x-i2c (Re-)moved drivers: - Move protocol helpers out to drivers/platform; cros_ec New drivers/supported devices: - Add support for AXP22x into axp20x - Add support for OnKey into da9063-core - Add support for Pinctrl into mt6397-core - New STMicroelectronics LPC Watchdog driver - New STMicroelectronics LPC Real-Time Clock driver" * tag 'mfd-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (59 commits) mfd: lpc_ich: Assign subdevice ids automatically mfd: si476x-i2c: Pass the IRQF_ONESHOT flag mfd: ab8500-gpadc: Pass the IRQF_ONESHOT flag mfd: ab8500-debugfs: Pass the IRQF_ONESHOT flag mfd: wm8350-core: Pass the IRQF_ONESHOT flag mfd: htc-i2cpld: Pass the IRQF_ONESHOT flag mfd: wm831x-auxadc: Pass the IRQF_ONESHOT flag mfd: mc13xxx-core: Pass the IRQF_ONESHOT flag mfd: twl4030-irq: Pass the IRQF_ONESHOT flag mfd: mt6397-core: Add GPIO sub-module support mfd: arizona: Add convience defines for micd_rate/micd_bias_starttime mfd: dt: Add bindings for DA9063 OnKey mfd: da9063: Add support for OnKey driver mfd: arizona: Fix incorrect Makefile conditionals mfd: arizona: Add stub for wm5102_patch() mfd: Check ACPI device companion before checking resources Documentation: Add WM8998/WM1814 device tree bindings mfd: arizona: Split INx_MODE into two fields mfd: wm5110: Add delay before releasing reset line mfd: arizona: Add better support for system suspend ...
2015-06-23Merge tag 'regulator-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "Another fairly quiet release, some new drivers with generic handling for minor features but nothing that makes a substantial difference outside of the subsystem or for most boards: - support for a bunch of new parameters which are present on enough regulators to be worth having generic handling for in the framework. - fixes for some issues with printing constraints during boot which should probably have gone in for v4.1 but didn't. - new drivers for Dialog DA9062, Maxim MAX77621 and Qualcomm SPMI regulators" * tag 'regulator-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (45 commits) regulator: qcom_spmi: Fix calculating number of voltages regulator: qcom_spmi: Add missing braces for aligned code regulator: fix simple_return.cocci warnings regulator: Add QCOM SPMI regulator driver regulator: Add docbook for soft start regulator: Add input current limit support regulator: Add soft start support regulator: Add pull down support regulator: Add system_load constraint regulator: max8973: Fix up ramp_delay for MAX8973_RAMP_25mV_PER_US case regulator: core: replace sprintf with scnprintf regulator: core: fix constraints output buffer regulator: core: Don't corrupt display when printing uV offsets regulator: max8973: add support for MAX77621 regulator: max8973: configure ramp delay through callback regulator: pwm-regulator: Diffientiate between dev (device) and rdev (regulator_dev) regulator: pwm-regulator: Remove superfluous is_enabled check regulator: pwm-regulator: Remove unnecessary descriptor attribute from ddata regulator: core: Don't spew backtraces on duplicate sysfs regulator: da9063: Fix up irq leak ...
2015-06-23Merge tag 'spi-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "No framework updates for the SPI API this time around aside from one small fix, just driver improvments. Some highlights include: - New driver support for CSR USP, Mikrotik RB4xx and Zynq GQSPI controllers. - Modernisation of the OMAP McSPI controller driver, moving it to current APIs to enable support for a wider range of client drivers. - DMA support for the bcm2835 controller" * tag 'spi-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (60 commits) spi: zynq: Remove execute bit spi: atmel: add support to FIFOs spi: atmel: update DT bindings documentation spi: spi-fsl-dspi: Update DT binding documentation spi: pxa2xx: Constify ACPI device ids spi: Add support for Zynq Ultrascale+ MPSoC GQSPI controller spi: zynq: Add DT bindings documentation for Zynq Ultrascale+ MPSoC GQSPI controller spi: fsl-dspi: Use pinctrl PM helpers spi: davinci: change the lower limit of pre-scale divider to 1 spi: spi-fsl-dspi: Change the way of increasing spi_message->actual_length spi: spi-fsl-dspi: Enable TCF interrupt mode support spi: atmel: add support for the internal chip-select of the spi controller spi: spi-pxa2xx: remove legacy PXA DMA bits spi: pxa2xx: Make LPSS SPI general register optional spi: pxa2xx: Prepare for new Intel LPSS SPI type spi: pxa2xx: Differentiate Intel LPSS types spi: restore rx/tx_buf in case of unset CONFIG_HAS_DMA spi: rspi: Re-do the returning value of qspi_transfer_out_in spi: rspi: modify the name of "qspi_trigger_transfer_out_int" function spi: orion: Fix extended baud rates for each Armada SoCs ...
2015-06-23Merge tag 'regmap-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "As well as a few fixes and updates for API changes there's two new features for the API: - Better support for handling a reset of the underlying hardware, marking the register map as needing a resync to the device when we need to do that automatically - Support for querying the size and stride of the register map, allowing higher level frameworks to configure themselves more readily" * tag 'regmap-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: Fix possible shift overflow in regmap_field_init() regmap: Fix regmap_bulk_read in BE mode regmap: kill off set_irq_flags usage regmap: irq: Fixed a typo error regmap: drop unneeded goto regmap: Introduce regmap_get_reg_stride regmap: Introduce regmap_get_max_register regmap: Use regcache_mark_dirty() to indicate power loss or reset regmap: Add a helper function for regcache sync test regmap: Constify irq_domain_ops
2015-06-23Merge tag 'fbdev-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: - ssd1307fb: various fixes and improvements, SSD1305 support - use architecture agnostic functions instead of MTRR functions in various fbdev drivers - TI DRA7xx SoC display support (arch/arm/ side) - OMAPDSS componentization to fix probing order issues - OMAPDSS scaling fixes - msm_fb: remove obsoleted driver * tag 'fbdev-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (77 commits) msm: msm_fb: Remove dead code OMAPDSS: HDMI: wait for framedone when stopping video OMAPDSS: HDMI4: fix error handling OMAPDSS: DISPC: scaler debug print OMAPDSS: DISPC: do only y decimation on OMAP3 OMAPDSS: DISPC: check if scaling setup failed OMAPDSS: DISPC: fix 64 bit issue in 5-tap OMAPDSS: DISPC: fix row_inc for OMAP3 OMAPDSS: DISPC: add check for scaling limits OMAPDSS: DISPC: fix check_horiz_timing_omap3 args OMAPDSS: DISPC: fix predecimation for YUV modes OMAPDSS: DISPC: work-around for errata i631 OMAPDSS: simplify submodule reg/unreg code OMAPDSS: componentize omapdss OMAPDSS: reorder uninit calls OMAPDSS: remove uses of __init/__exit OMAPDSS: fix dss_init_ports error handling OMAPDSS: refactor dss probe function OMAPDSS: move 'dss_initialized' to dss driver fbdev: propagate result of fb_videomode_from_videomode() ...
2015-06-23Merge tag 'for-4.2' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply and reset updates from Sebastian Reichel: - new charger drivers: BQ24257, BQ25890, AXP288, RT9455 - MAX17042 battery: add health & temperature support - BQ2415x charger: add ACPI support - misc fixes and cleanups * tag 'for-4.2' of git://git.infradead.org/battery-2.6: (32 commits) power_supply: Correct kerneldoc copy paste errors wm831x_power: Fix off-by-one at free_irq() power_supply: rt9455_charger: Fix error reported by static analysis tool power_supply: bq24257: use flags argument of devm_gpiod_get power_supply: bq25890: use flags argument of devm_gpiod_get sbs-battery: add option to always register battery power: Add devm_power_supply_get_by_phandle() helper function power_supply: max17042: Add OF support for setting thresholds power_supply: sysfs: Bring back write to writeable properties power_supply: rt9455_charger: Check if CONFIG_USB_PHY is enabled power: reset: gpio-restart: increase priority slightly power_supply: bq25890: make chip_id int power_supply: Add support for Richtek RT9455 battery charger Documentation: devicetree: Add Richtek RT9455 bindings of: Add vendor prefix for Richtek Technology Corporation power_supply: 88pm860x_charger: Do not call free_irq() twice power: bq24190_charger: Change first_time flag reset condition power: axp288_charger: axp288 charger driver power: max17042_battery: add HEALTH and TEMP_* properties support power_supply: Add support for TI BQ25890 charger chip ...
2015-06-23Merge tag 'hsi-for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-hsi Pull HSI updates from Sebastian Reichel: "Misc fixes" * tag 'hsi-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-hsi: HSI: nokia-modem: use flags argument of devm_gpiod_get to set direction HSI: nokia-modem: Reduce missing driver message to debug level HSI: cmt_speech: fix timestamp interface
2015-06-23Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI updates from James Bottomley: "This is the usual grab bag of driver updates (lpfc, hpsa, megaraid_sas, cxgbi, be2iscsi) plus an assortment of minor updates. There is also one new driver: the Cisco snic. The advansys driver has been rewritten to get rid of the warning about converting it to the DMA API, the tape statistics patch got in and finally, there's a resuffle of SCSI header files to separate more cleanly initiator from target mode (and better share the common definitions)" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (156 commits) snic: driver for Cisco SCSI HBA qla2xxx: Fix indentation qla2xxx: Comment out unreachable code fusion: remove dead MTRR code advansys: fix compilation errors and warnings when CONFIG_PCI is not set mptsas: fix depth param in scsi_track_queue_full megaraid: fix irq setup process regression lpfc: Update version to 10.7.0.0 for upstream patch set. lpfc: Fix to drop PLOGIs from fabric node till LOGO processing completes lpfc: Fix scsi task management error message. lpfc: Fix cq_id masking problem. lpfc: Fix scsi prep dma buf error. lpfc: Add support for using block multi-queue lpfc: Devices are not discovered during takeaway/giveback testing lpfc: Fix vport deletion failure. lpfc: Check for active portpeerbeacon. lpfc: Update driver version for upstream patch set 10.6.0.1. lpfc: Change buffer pool empty message to miscellaneous category lpfc: Fix incorrect log message reported for empty FCF record. lpfc: Fix rport leak. ...
2015-06-23Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: - a large cleanup of how device capabilities are checked for various features - additional cleanups in the MAD processing - update to the srp driver - creation and use of centralized log message helpers - add const to a number of args to calls and clean up call chain - add support for extended cq create verb - add support for timestamps on cq completion - add support for processing OPA MAD packets * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (92 commits) IB/mad: Add final OPA MAD processing IB/mad: Add partial Intel OPA MAD support IB/mad: Add partial Intel OPA MAD support IB/core: Add OPA MAD core capability flag IB/mad: Add support for additional MAD info to/from drivers IB/mad: Convert allocations from kmem_cache to kzalloc IB/core: Add ability for drivers to report an alternate MAD size. IB/mad: Support alternate Base Versions when creating MADs IB/mad: Create a generic helper for DR forwarding checks IB/mad: Create a generic helper for DR SMP Recv processing IB/mad: Create a generic helper for DR SMP Send processing IB/mad: Split IB SMI handling from MAD Recv handler IB/mad cleanup: Generalize processing of MAD data IB/mad cleanup: Clean up function params -- find_mad_agent IB/mlx4: Add support for CQ time-stamping IB/mlx4: Add mmap call to map the hardware clock IB/core: Pass hardware specific data in query_device IB/core: Add timestamp_mask and hca_core_clock to query_device IB/core: Extend ib_uverbs_create_cq IB/core: Add CQ creation time-stamping flag ...
2015-06-23Merge branch 'for-linus-clk' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull clkdev updates from Russell King: "This series addresses some breakage in clkdev caused by a previous patch set from the clk tree which introduced per-user clk structures. This basically renamed the existing 'struct clk' to 'struct clk_hw', and introduced a new 'struct clk'. This change will break anyone using clk_add_alias() with the common clk code enabled. Thankfully, the intersection of users of clk_add_alias() and those using the common clk code is practically zero, but this is something which should be fixed to keep the code sane. The problem is that clk_add_alias() does this: r = clk_get(...); l = clkdev_alloc(r, ...); clk_put(...); which causes the alias to store a pointer to 'r', which has been freed. The original patch set tried to work around this problem incorrectly - at clk_get() time, it tried to convert the struct clk to a struct clk_hw, and then creating a new struct clk from that. Clearly, if the original struct clk has been freed, then we have a use-after-free bug. We have other places in the tree which do something similar, so this series also addresses those locations too. This series addresses this problem by converting clkdev to store and use the clk_hw pointer. This allows clk_get() to only have to create it's per-user struct clk from the clk_hw. We can also get to the desired clk_hw at clk_add_alias() or clk lookup creation time, when the struct clk is "alive". We also perform some cleanups of the code: - replacing looped calls to clkdev_add() with clkdev_add_table() - replacing open-coded lookup allocation (which should have been using clkdev_alloc()) and subsequent clkdev_add() with clkdev_create() - replacing open-coded clk_add_alias() with clk_add_alias()" * 'for-linus-clk' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: clk: s2mps11: use clkdev_create() ASoC: migor: use clkdev_create() ARM: omap2: use clkdev_add_alias() ARM: omap2: use clkdev_create() ARM: orion: use clkdev_create() ARM: lpc32xx: convert to use clkdev_add_table() SH: use clkdev_add_table() clkdev: add clkdev_create() helper clkdev: const-ify connection id to clk_add_alias() clkdev: get rid of redundant clk_add_alias() prototype in linux/clk.h clkdev: drop __init from clkdev_add_table() clk: update clk API documentation to clarify clk_round_rate() clkdev: use clk_hw internally
2015-06-23Merge tag 'pm+acpi-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI updates from Rafael Wysocki: "The rework of backlight interface selection API from Hans de Goede stands out from the number of commits and the number of affected places perspective. The cpufreq core fixes from Viresh Kumar are quite significant too as far as the number of commits goes and because they should reduce CPU online/offline overhead quite a bit in the majority of cases. From the new featues point of view, the ACPICA update (to upstream revision 20150515) adding support for new ACPI 6 material to ACPICA is the one that matters the most as some new significant features will be based on it going forward. Also included is an update of the ACPI device power management core to follow ACPI 6 (which in turn reflects the Windows' device PM implementation), a PM core extension to support wakeup interrupts in a more generic way and support for the ACPI _CCA device configuration object. The rest is mostly fixes and cleanups all over and some documentation updates, including new DT bindings for Operating Performance Points. There is one fix for a regression introduced in the 4.1 cycle, but it adds quite a number of lines of code, it wasn't really ready before Thursday and you were on vacation, so I refrained from pushing it on the last minute for 4.1. Specifics: - ACPICA update to upstream revision 20150515 including basic support for ACPI 6 features: new ACPI tables introduced by ACPI 6 (STAO, XENV, WPBT, NFIT, IORT), changes related to the other tables (DTRM, FADT, LPIT, MADT), new predefined names (_BTH, _CR3, _DSD, _LPI, _MTL, _PRR, _RDI, _RST, _TFP, _TSN), fixes and cleanups (Bob Moore, Lv Zheng). - ACPI device power management core code update to follow ACPI 6 which reflects the ACPI device power management implementation in Windows (Rafael J Wysocki). - rework of the backlight interface selection logic to reduce the number of kernel command line options and improve the handling of DMI quirks that may be involved in that and to make the code generally more straightforward (Hans de Goede). - fixes for the ACPI Embedded Controller (EC) driver related to the handling of EC transactions (Lv Zheng). - fix for a regression related to the ACPI resources management and resulting from a recent change of ACPI initialization code ordering (Rafael J Wysocki). - fix for a system initialization regression related to ACPI introduced during the 3.14 cycle and caused by running the code that switches the platform over to the ACPI mode too early in the initialization sequence (Rafael J Wysocki). - support for the ACPI _CCA device configuration object related to DMA cache coherence (Suravee Suthikulpanit). - ACPI/APEI fixes and cleanups (Jiri Kosina, Borislav Petkov). - ACPI battery driver cleanups (Luis Henriques, Mathias Krause). - ACPI processor driver cleanups (Hanjun Guo). - cleanups and documentation update related to the ACPI device properties interface based on _DSD (Rafael J Wysocki). - ACPI device power management fixes (Rafael J Wysocki). - assorted cleanups related to ACPI (Dominik Brodowski, Fabian Frederick, Lorenzo Pieralisi, Mathias Krause, Rafael J Wysocki). - fix for a long-standing issue causing General Protection Faults to be generated occasionally on return to user space after resume from ACPI-based suspend-to-RAM on 32-bit x86 (Ingo Molnar). - fix to make the suspend core code return -EBUSY consistently in all cases when system suspend is aborted due to wakeup detection (Ruchi Kandoi). - support for automated device wakeup IRQ handling allowing drivers to make their PM support more starightforward (Tony Lindgren). - new tracepoints for suspend-to-idle tracing and rework of the prepare/complete callbacks tracing in the PM core (Todd E Brandt, Rafael J Wysocki). - wakeup sources framework enhancements (Jin Qian). - new macro for noirq system PM callbacks (Grygorii Strashko). - assorted cleanups related to system suspend (Rafael J Wysocki). - cpuidle core cleanups to make the code more efficient (Rafael J Wysocki). - powernv/pseries cpuidle driver update (Shilpasri G Bhat). - cpufreq core fixes related to CPU online/offline that should reduce the overhead of these operations quite a bit, unless the CPU in question is physically going away (Viresh Kumar, Saravana Kannan). - serialization of cpufreq governor callbacks to avoid race conditions in some cases (Viresh Kumar). - intel_pstate driver fixes and cleanups (Doug Smythies, Prarit Bhargava, Joe Konno). - cpufreq driver (arm_big_little, cpufreq-dt, qoriq) updates (Sudeep Holla, Felipe Balbi, Tang Yuantian). - assorted cleanups in cpufreq drivers and core (Shailendra Verma, Fabian Frederick, Wang Long). - new Device Tree bindings for representing Operating Performance Points (Viresh Kumar). - updates for the common clock operations support code in the PM core (Rajendra Nayak, Geert Uytterhoeven). - PM domains core code update (Geert Uytterhoeven). - Intel Knights Landing support for the RAPL (Running Average Power Limit) power capping driver (Dasaratharaman Chandramouli). - fixes related to the floor frequency setting on Atom SoCs in the RAPL power capping driver (Ajay Thomas). - runtime PM framework documentation update (Ben Dooks). - cpupower tool fix (Herton R Krzesinski)" * tag 'pm+acpi-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (194 commits) cpuidle: powernv/pseries: Auto-promotion of snooze to deeper idle state x86: Load __USER_DS into DS/ES after resume PM / OPP: Add binding for 'opp-suspend' PM / OPP: Allow multiple OPP tables to be passed via DT PM / OPP: Add new bindings to address shortcomings of existing bindings ACPI: Constify ACPI device IDs in documentation ACPI / enumeration: Document the rules regarding the PRP0001 device ID ACPI / video: Make acpi_video_unregister_backlight() private acpi-video-detect: Remove old API toshiba-acpi: Port to new backlight interface selection API thinkpad-acpi: Port to new backlight interface selection API sony-laptop: Port to new backlight interface selection API samsung-laptop: Port to new backlight interface selection API msi-wmi: Port to new backlight interface selection API msi-laptop: Port to new backlight interface selection API intel-oaktrail: Port to new backlight interface selection API ideapad-laptop: Port to new backlight interface selection API fujitsu-laptop: Port to new backlight interface selection API eeepc-laptop: Port to new backlight interface selection API dell-wmi: Port to new backlight interface selection API ...
2015-06-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "As usual, mostly comment, kerneldoc and printk() fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: lpfc: Grammar s/an negative/a negative/ ARM: lib/lib1funcs.S: fix typo s/substractions/subtractions/ cx25821: cx25821-medusa-reg.h: fix 0x0x prefix lib: crc-itu-t.[ch] fix 0x0x prefix in integer constants rapidio: Fix kerneldoc and comment qla4xxx: Fix printk() in qla4_83xx_read_reset_template() and qla4_83xx_pre_loopback_config() treewide: Kconfig: fix wording / spelling usb/serial: fix grammar in Kconfig help text for FTDI_SIO megaraid_sas: fix kerneldoc netfilter: ebtables: fix comment grammar drm/radeon: fix comment isdn: fix grammar in comment ARM: KVM: fix comment
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: - spurious power/wakeup sysfs files removal for I2C-HID devices, from Andrew Duggan - Logitech M560 support, from Goffredo Baroncelli - a lot of housekeeping cleanups to hid-lg4ff driver, from Michal Maly - improved support for Plantronics devices, from Terry Junge - Sony Motion Controller and Navigation Controller support and subsequent cleanups of hid-sony driver, from Frank Praznik and Simon Wood - HW support improvements to the Wacom driver, from Jason Gerecke and Ping Cheng - assorted small cleanups and device ID additions all over the place * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (69 commits) HID: cypress: use swap() in cp_report_fixup() HID: microsoft: Add Surface Power Cover HID: hid-sony: Fix report descriptor for Navigation Controller HID: hid-sony: Navigation controller only has 1 LED and no rumble HID: hid-sony: Add BT support for Navigation Controller HID: wacom: Introduce new 'touch_input' device HID: wacom: Split apart 'wacom_setup_pentouch_input_capabilites' HID: wacom: Introduce a new WACOM_DEVICETYPE_PAD device_type HID: wacom: Treat features->device_type values as flags HID: wacom: Simplify 'wacom_update_name' HID: rmi: Disable populating F30 when the touchpad has physical buttons HID: plantronics: Update to map volume up/down controls HID: sony: PS Move fix report descriptor HID: sony: PS3 Move enable LEDs and Rumble via BT HID: sony: Add support PS3 Move Battery via BT HID: sony: Add quirk for MOTION_CONTROLLER_BT HID: sony: Support PS3 Move Controller when connected via Bluetooth HID: i2c-hid: Do not set the ACPI companion field in the HID device usb, HID: Remove Vernier devices from lsusb and hid_ignore_list HID: hidpp: Add driver for mouse logitech M560 ...
2015-06-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmciaLinus Torvalds
Pull PCMCIA update from Dominik Brodowski: "A few PCMCIA fixes and cleanups are available in the PCMCIA tree. Most of them are trivial and self-explanatory. Of particular note are the last three patches which add an important hardware quirk for Toshiba ToPIC95 sockets (or BIOS breakage on systems with these sockets), fix resource leaks in yenta_socket enable/disable call paths, and fix a regression caused by patch 1c6c9b1d9d25 since v4.0. Alan stated he is OK with me pushing this patch upstream. Once it works out well in your tree, I will push it to stable for 4.0/4.1 as well" * git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia: pcmcia: do not break rsrc_nonstatic when handling anonymous cards pcmcia: Fix resource leaks in yenta_probe() and _close() Disable write buffering on Toshiba ToPIC95 pcmcia: Convert dev_printk to dev_<level> pcmcia/vrc4171: Remove typedefs for enums and struct pcmcia: Remove typedef in structs and emum pcmcia: Remove typedef tuple_flags drivers: pcmcia: electra_cf.c fix checkpatch error and warnings drivers: pcmcia: ds.c fix checkpatch errors PCMCIA: Remove commented references to dead class_device_create_file() drivers/pcmcia/electra_cf.c: add missing iounmap and kfree pcmcia: replace open-coded ARRAY_SIZE with macro
2015-06-23Merge tag 'pci-v4.2-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v4.2 merge window: Enumeration - Move pci_ari_enabled() to global header (Alex Williamson) - Account for ARI in _PRT lookups (Alex Williamson) - Remove unused pci_scan_bus_parented() (Yijing Wang) Resource management - Use host bridge _CRS info on systems with >32 bit addressing (Bjorn Helgaas) - Use host bridge _CRS info on Foxconn K8M890-8237A (Bjorn Helgaas) - Fix pci_address_to_pio() conversion of CPU address to I/O port (Zhichang Yuan) - Add pci_bus_addr_t (Yinghai Lu) PCI device hotplug - Wait for pciehp command completion where necessary (Alex Williamson) - Drop pointless ACPI-based "slot detection" check (Rafael J. Wysocki) - Check ignore_hotplug for all downstream devices (Rafael J. Wysocki) - Propagate the "ignore hotplug" setting to parent (Rafael J. Wysocki) - Inline pciehp "handle event" functions into the ISR (Bjorn Helgaas) - Clean up pciehp debug logging (Bjorn Helgaas) Power management - Remove redundant PCIe port type checking (Yijing Wang) - Add dev->has_secondary_link to track downstream PCIe links (Yijing Wang) - Use dev->has_secondary_link to find downstream links for ASPM (Yijing Wang) - Drop __pci_disable_link_state() useless "force" parameter (Bjorn Helgaas) - Simplify Clock Power Management setting (Bjorn Helgaas) Virtualization - Add ACS quirks for Intel 9-series PCH root ports (Alex Williamson) - Add function 1 DMA alias quirk for Marvell 9120 (Sakari Ailus) MSI - Disable MSI at enumeration even if kernel doesn't support MSI (Michael S. Tsirkin) - Remove unused pci_msi_off() (Bjorn Helgaas) - Rename msi_set_enable(), msix_clear_and_set_ctrl() (Michael S. Tsirkin) - Export pci_msi_set_enable(), pci_msix_clear_and_set_ctrl() (Michael S. Tsirkin) - Drop pci_msi_off() calls during probe (Michael S. Tsirkin) APM X-Gene host bridge driver - Add APM X-Gene v1 PCIe MSI/MSIX termination driver (Duc Dang) - Add APM X-Gene PCIe MSI DTS nodes (Duc Dang) - Disable Configuration Request Retry Status for v1 silicon (Duc Dang) - Allow config access to Root Port even when link is down (Duc Dang) Broadcom iProc host bridge driver - Allow override of device tree IRQ mapping function (Hauke Mehrtens) - Add BCMA PCIe driver (Hauke Mehrtens) - Directly add PCI resources (Hauke Mehrtens) - Free resource list after registration (Hauke Mehrtens) Freescale i.MX6 host bridge driver - Add speed change timeout message (Troy Kisky) - Rename imx6_pcie_start_link() to imx6_pcie_establish_link() (Bjorn Helgaas) Freescale Layerscape host bridge driver - Use dw_pcie_link_up() consistently (Bjorn Helgaas) - Factor out ls_pcie_establish_link() (Bjorn Helgaas) Marvell MVEBU host bridge driver - Remove mvebu_pcie_scan_bus() (Yijing Wang) NVIDIA Tegra host bridge driver - Remove tegra_pcie_scan_bus() (Yijing Wang) Synopsys DesignWare host bridge driver - Consolidate outbound iATU programming functions (Jisheng Zhang) - Use iATU0 for cfg and IO, iATU1 for MEM (Jisheng Zhang) - Add support for x8 links (Zhou Wang) - Wait for link to come up with consistent style (Bjorn Helgaas) - Use pci_scan_root_bus() for simplicity (Yijing Wang) TI DRA7xx host bridge driver - Use dw_pcie_link_up() consistently (Bjorn Helgaas) Miscellaneous - Include <linux/pci.h>, not <asm/pci.h> (Bjorn Helgaas) - Remove unnecessary #includes of <asm/pci.h> (Bjorn Helgaas) - Remove unused pcibios_select_root() (again) (Bjorn Helgaas) - Remove unused pci_dma_burst_advice() (Bjorn Helgaas) - xen/pcifront: Don't use deprecated function pci_scan_bus_parented() (Arnd Bergmann)" * tag 'pci-v4.2-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits) PCI: pciehp: Inline the "handle event" functions into the ISR PCI: pciehp: Rename queue_interrupt_event() to pciehp_queue_interrupt_event() PCI: pciehp: Make queue_interrupt_event() void PCI: xgene: Allow config access to Root Port even when link is down PCI: xgene: Disable Configuration Request Retry Status for v1 silicon PCI: pciehp: Clean up debug logging x86/PCI: Use host bridge _CRS info on systems with >32 bit addressing PCI: imx6: Add #define PCIE_RC_LCSR PCI: imx6: Use "u32", not "uint32_t" PCI: Remove unused pci_scan_bus_parented() xen/pcifront: Don't use deprecated function pci_scan_bus_parented() PCI: imx6: Add speed change timeout message PCI/ASPM: Simplify Clock Power Management setting PCI: designware: Wait for link to come up with consistent style PCI: layerscape: Factor out ls_pcie_establish_link() PCI: layerscape: Use dw_pcie_link_up() consistently PCI: dra7xx: Use dw_pcie_link_up() consistently x86/PCI: Use host bridge _CRS info on Foxconn K8M890-8237A PCI: pciehp: Wait for hotplug command completion where necessary PCI: Remove unused pci_dma_burst_advice() ...
2015-06-23Merge tag 'hwmon-for-linus-v4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: - new driver for Microchip TC74 - support for ncpXXwf104 added to ntc_thermistor driver - minor cleanup * tag 'hwmon-for-linus-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: add driver for Microchip TC74 hwmon: (ntc_thermistor) Improve precision of resistance calculation hwmon: (ntc_thermistor) fix iio raw to microvolts conversion hwmon: (atxp1) Drop auto-detection hwmon: (atxp1) Drop FSF mailing address hwmon: Allow compile test of GPIO consumers if !GPIOLIB hwmon: (sht15) Constify platform_device_id hwmon: (max197) Constify platform_device_id hwmon: (ntc_thermistor) Add support for ncpXXwf104
2015-06-23Merge tag 'mmc-v4.2' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC updates from Ulf Hansson: "Here are the changes for MMC for v4.2. MMC core: - Fix an error path in the mmc block layer - Fix PM domain attachment for the SDIO bus - Add support for driver strength selection - Increase a delay to let voltage stabilize - Add support for disabling write-protect detection - Add facility to support re-tuning - Re-tune and retry in the recovery path - Add reset option for SDIO - Consolidations and clean-ups MMC host: - Add Mediatek MMC driver - Constify platform_device_id for a couple of hosts - Fix modalias to make module auto-loading work for a couple of hosts - sdhci: Add support for sdhci-arasan4.9a - sdhci: Fix low memory corruption - sdhci: Restore behavior while creating OCR mask - sdhci: Add a callback to select drive strength - sdhci: Fix driver type B and D handling - sdhci: Add support for drive strength selection for SPT - sdhci: Enable HS400 for some Intel host controllers - sdhci: Convert to use the new re-tuning facility - sdhci: Various minor fixes and clean-ups - dw_mmc: Add support for hi6220 - dw_mmc: Use core to handle absent write protect line - dw_mmc: Add support to switch voltage - tmio: Some fixes and modernizations - sh_mmcif: Improve clock rate calculation" * tag 'mmc-v4.2' of git://git.linaro.org/people/ulf.hansson/mmc: (98 commits) mmc: queue: prevent soft lockups on PREEMPT=n mmc: mediatek: Add PM support for MMC driver mmc: mediatek: Add Mediatek MMC driver mmc: dt-bindings: add Mediatek MMC bindings mmc: card: Fixup request missing in mmc_blk_issue_rw_rq mmc: sdhci: fix low memory corruption mmc: sdhci-pci: Change AMD SDHCI quirk application scope i2c-piix4: Use Macro for AMD CZ SMBus device ID pci_ids: Add AMD KERNCZ device ID support mmc: queue: use swap() in mmc_queue_thread() mmc: dw_mmc: insmod followed by rmmod will hung for eMMC mmc: sdhci: Restore behavior while creating OCR mask mmc: sdhci-pxav3: fix device wakeup initialization mmc: core: Attach PM domain prior probing of SDIO func driver mmc: core: Remove redundant ->power_restore() callback for SD mmc: core: Remove redundant ->power_restore() callback for MMC mmc: sdhci-bcm2835: Actually enable the clock mmc: sdhci-bcm2835: Clean up platform allocations if sdhci init fails. mmc: sdhci-of-esdhc: enable interrupt mode to detect card mmc: sdhci-esdhc-imx: add quirk SDHCI_QUIRK2_BROKEN_HS200 for imx6qdl ...
2015-06-23Merge tag 'gpio-v4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio updates from Linus Walleij: "This is the big bulk of GPIO changes queued for the v4.2 kernel series: - a big set of cleanups to the aged sysfs interface from Johan Hovold. To get these in, v4.1-rc3 was merged into the tree as the first patch in that series had to go into stable. This makes the locking much more fine-grained (get rid of the "big GPIO lock(s)" and store states in the GPIO descriptors. - rename gpiod_[g|s]et_array() to gpiod_[g|s]et_array_value() to avoid confusions. - New drivers for: * NXP LPC18xx (currently LPC1850) * NetLogic XLP * Broadcom STB SoC's * Axis ETRAXFS * Zynq Ultrascale+ (subdriver) - ACPI: * make it possible to retrieve GpioInt resources from a GPIO device using acpi_dev_gpio_irq_get() * merge some dependent I2C changes exploiting this. * support the ARM X-Gene GPIO standby driver. - make it possible for the generic GPIO driver to read back the value set registers to reflect current status. - loads of OMAP IRQ handling fixes. - incremental improvements to Kona, max732x, OMAP, MXC, RCAR, PCA953x, STP-XWAY, PCF857x, Crystalcove, TB10x. - janitorial (constification, checkpatch cleanups)" * tag 'gpio-v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (71 commits) gpio: Fix checkpatch.pl issues gpio: pcf857x: handle only enabled irqs gpio / ACPI: Return -EPROBE_DEFER if the gpiochip was not found GPIO / ACPI: export acpi_gpiochip_request(free)_interrupts for module use gpio: improve error reporting on own descriptors gpio: promote own request failure to pr_err() gpio: Added support to Zynq Ultrascale+ MPSoC gpio: add ETRAXFS GPIO driver fix documentation after renaming gpiod_set_array to gpiod_set_array_value gpio: Add GPIO support for Broadcom STB SoCs gpio: xgene: add ACPI support for APM X-Gene GPIO standby driver gpio: tb10x: Drop unneeded free_irq() call gpio: crystalcove: set IRQCHIP_SKIP_SET_WAKE for the irqchip gpio: stp-xway: Use the of_property_read_u32 helper gpio: pcf857x: Check for irq_set_irq_wake() failures gpio-stp-xway: Fix enabling the highest bit of the PHY LEDs gpio: Prevent an integer overflow in the pca953x driver gpio: omap: rework omap_gpio_irq_startup to handle current pin state properly gpio: omap: rework omap_gpio_request to touch only gpio specific registers gpio: omap: rework omap_x_irq_shutdown to touch only irqs specific registers ...
2015-06-23Merge tag 'pwm/for-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm updates from Thierry Reding: "This has a couple of fixes for Atmel, Samsung and Broadcom drivers. Some preparatory patches for more upcoming Intel work is included as well" * tag 'pwm/for-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: lpss: pci: Add support for Broxton platform pwm: bcm-kona: Don't set polarity in probe pwm: Add pwmchip_add_with_polarity() API pwm: atmel: Fix incorrect CDTY value after disabling pwm: atmel: Fix incorrect CDTY value after enabling pwm: samsung: Use MODULE_DEVICE_TABLE() to include OF modalias pwm: Add support to remove registered consumer lookup tables
2015-06-23backlight: pwm_bl: Simplify usage of devm_gpiod_get_optionalAxel Lin
Since 39b2bbe3d715 (gpio: add flags argument to gpiod_get*() functions), the gpiod_get* functions take an additional parameter that allows to specify direction and initial value for output. Simplify the usage of devm_gpiod_get_optional accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-23backlight: lp855x: Don't clear level on suspend/blankSean Paul
Don't clear the backlight level when we're going into suspend or blanking. Instead, just temporarily set the level to 0 so we retain the value when we resume. Reported-by: Benson Leung <bleung@chromium.org> Signed-off-by: Sean Paul <seanpaul@chromium.org> Tested-by: Stephen Barber <smbarber@chromium.org> Reviewed-by: Benson Leung <bleung@chromium.org> Acked-by: Milo Kim <milo.kim@ti.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-23backlight: Allow compile test of GPIO consumers if !GPIOLIBGeert Uytterhoeven
The GPIO subsystem provides dummy GPIO consumer functions if GPIOLIB is not enabled. Hence drivers that depend on GPIOLIB, but use GPIO consumer functionality only, can still be compiled if GPIOLIB is not enabled. Relax the dependency on GPIOLIB if COMPILE_TEST is enabled, where appropriate. Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-23video: backlight: da9052: Constify platform_device_idKrzysztof Kozlowski
The platform_device_id is not modified by the driver and core uses it as const. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-23gpio-backlight: Discover driver during boot timeArun Bharadwaj
The gpio-backlight driver seems to be missing the MODULE_DEVICE_TABLE line which is preventing it from being modprobed during boot time even if the gpio-backlight device exists. This seems to be a bug and this patch attempts to fix that. Signed-off-by: Arun Bharadwaj <arun@gumstix.com> Signed-off-by: Ash Charles <ashcharles@gmail.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-06-23drivers: net: xgene: Check for IS_ERR rather than NULL for clock.Suman Tripathi
This patches fixes the code to check for IS_ERR rather than NULL for clock interface. Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23drivers: net: xgene: Add ACPI support for SGMII0 and XFI1 interface of 2nd ↵Suman Tripathi
H/W version of APM X-Gene SoC ethernet controller. This patch adds the ACPI support for SGMII0 and XFI1 interface of 2nd H/W version of APM X-Gene SoC ethernet controller. Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23drivers: net: xgene: Implement the backward compatibility with the old and ↵Suman Tripathi
new firmware w.r.t Tx completion IRQ interrupt. This patch implements the backward compatibility with the old firmware where the Tx completion IRQ interrupt was absent whereas incase of new firmware the Tx completion IRQ interrupt is present. Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23drivers: net: xgene: Fix the ACPI support for RGMII/SGMII0/XFI interface of ↵Suman Tripathi
APM X-Gene SoC ethernet controller. This patch implements couple of fixes to support ACPI for RGMII/SGMII0/XFI interface of APM X-Gene SoC ethernet controller driver. This patch uses the _SUN acpi object to fetch the port-id information whereas the FDT uses port-id binding for port-id information. Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: Suman Tripathi <stripathi@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
