Fix up the maintainers info in the tpm drivers. Kylene will be out for
some time, so copying the sourceforge list is the best way to get some
attention.
Cc: Marcel Selhorst <tpm@selhorst.net>
Cc: Kylene Jo Hall <kjhall@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[WATCHDOG] Add support for 1533 bridge to alim1535_wdt
[WATCHDOG] Add a 00-INDEX file to Documentation/watchdog/
[WATCHDOG] Eurotechwdt.c - clean-up comments
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[IRDA] irda_nl_get_mode: always results in failure
[PPP]: Fix output buffer size in ppp_decompress_frame().
[IRDA]: Avoid a label defined but not used warning in irda_init()
[IPV6]: Fix kernel panic while send SCTP data with IP fragments
[SNAP]: Check packet length before reading
[DCCP]: Allocation in atomic context
When a vmur device is removed due to a detach of the device, currently the
ur device structure is freed. Unfortunately it can happen, that there is
still a user of the device structure, when the character device is open
during the detach process. To fix this, reference counting for the vmur
structure is introduced.
In addition to that, the online, offline, probe and remove functions are
serialized now using a global mutex.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
There are several s390 diagnose calls, which must be executed below the
2GB memory boundary. In order to enforce this, those diagnoses must be
compiled into the kernel. Currently diag 14 can be called within the
vmur kernel module from addresses above 2GB. This leads to specification
exceptions. This patch moves diag10, diag14 and diag210 into the new
diag.c file.
Hipersocket Multicast queue works asynchronously. When sending buffers,
the buffer state change may happen delayed. The tasklet for checking
changes in the outbound queue excluded IQDIO async queues from this
process. This created either a hang situation when the queue ran full,
or presented a hang situation a interface close time.
The tasklet processing is changed to include IQDIO async queues when
requesting buffer state refresh.
Signed-off-by: Klaus D. Wacker <kdwacker@de.ibm.com>
QDIO returned from EQBS instruction in any case after return code
CCQ=96 was issued regardless whether buffer states for at least one
buffer were extracted or not.
This caused FCP devices to hang when running under z/VM and having
QIOASSASIST=ON and having high I/O rates.
In order to fix this qdio return code processing of EQBS instruction
after CCQ=96 is changed that buffers are returned and if no buffers
where extracted the instruction is repeated at once.
cmf currently prints a message that more than 4096 channels are not
allowed in basic mode - however, this can only be enforced if cmf was
a module (which is no longer possible). It makes much more sense to
not check the specified number of channels and just print a message if
the block for basic mode could not be allocated (which may happen for
any number of specified channels).
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
This patch addresses the issue with "osize too small" errors in mppe
encryption. The patch fixes the issue with wrong output buffer size
being passed to ppp decompression routine.
As pointed out by Suresh Mahalingam, the issue addressed by
ppp-fix-osize-too-small-errors-when-decoding patch is not fully resolved yet.
The size of allocated output buffer is correct, however it size passed to
ppp->rcomp->decompress in ppp_generic.c if wrong. The patch fixes that.
Signed-off-by: Konstantin Sharlaimov <konstantin.sharlaimov@gmail.com>
There are special PHY settings available on Yukon EC-U chip that
should not get cleared. This should solve mysterious errors on some
motherboards (like Gigabyte DS-3).
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This fixes handling of USB ISO completion error -EXDEV and includes
several other changes to current CVS version at isdn4linux.de (changes
in debug flags, style of code remarks, etc)
Signed-off-by: Martin Bachem <info@colognechip.com>
Acked-by: Karsten Keil <kkeil@suse.de>
This reverts commit 196705c9bbc03540429b0f7cf9ee35c2f928a534. It was
reported to cause a regression by Daniel Exner, and Arjan van de Ven
points out that we actually already have infrastructure in place for
setting limits on acceptable DMA latency that would be the much more
correct fix for the problem with some Broadcom EHCI controllers.
Fixed up trivial conflicts due to the changes to support big-endian host
controller descriptors in drivers/usb/host/{ehci-sched.c,ehci.h}.
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ide-disk: workaround for buggy HPA support on ST340823A (take 3)
hpt34x: fix CONFIG_HPT34X_AUTODMA=n handling
triflex: add missing ->dma_base check
pdc202xx_old: add missing ->dma_base check
pdc202xx_new: add missing ->dma_base check
cs5530: add missing ->dma_base check
ide: ide_config_drive_speed() bugfixes
ide: add cable detection for early UDMA66 devices (take 3)
ide-pmac: fix drive->init_speed reporting
ide: config_drive_for_dma() fixes
ide-cris: fix ->set_pio_mode method to set transfer mode on the device
ide: fix hidden dependencies on CONFIG_IDE_GENERIC
ide: make CONFIG_IDE_GENERIC default to N
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb:
V4L/DVB (6028): Turn an unnecessary mdelay() into msleep().
V4L/DVB (6027): Get rid of an ill-behaved msleep in i2c write
V4L/DVB (6026): Avoid powering up the camera on resume
V4L/DVB (6016): get_dvb_firmware: update script for new location of tda10046 firmware
V4L/DVB (5991): dvb-pll: Set minimum and maximum frequency properly
V4L/DVB (5969): ivtv: report ivtv version in status log
V4L/DVB (5967): ivtv: fix VIDIOC_S_FBUF:new OSD values where never set
V4L/DVB (5968): videodev2.h: remove superfluous FBUF GLOBAL_INV_ALPHA support
This disk reports total number of sectors instead of maximum sector address
in response to READ_NATIVE_MAX_ADDRESS command and also happily accepts
SET_MAX_ADDRESS command with the bogus value. This results in +1 sector
capacity being used and errors on attempts to use the last sector.
hdd: Host Protected Area detected.
    current capacity is 78165360 sectors (40020 MB)
    native  capacity is 78165361 sectors (40020 MB)
hdd: Host Protected Area disabled.
hdd: reading: block=78165360, sectors=1, buffer=0xc1e63000
hdd: dma_intr: status=0x51 { DriveReady SeekComplete Error }
hdd: dma_intr: error=0x10 { SectorIdNotFound }, LBAsect=78165360, sector=78165360
Add hpa_list[] table and workaround the issue in idedisk_check_hpa().
v2:
* Add missing export and improve patch description a bit.
v3:
* Add list termination. (From Mikko)
Fixes kernel bugzilla bug #8816.
Thanks to Mikko for investigating the issue and helping with this patch.
Cc: Mikko Rapeli <mikko.rapeli@iki.fi>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Programming DMA mode may destroy current PIO mode setting so if
CONFIG_HPT34X_AUTODMA=n (the default case) make ide_tune_dma() fail
early by disabling all host DMA masks and re-tune PIO mode.
This fix doesn't help with the driver being broken but is needed
for some other changes.
If ->dma_base is not set (== PCI BAR4 cannot be reserved) then DMA hooks
shouldn't be initialized or bad things will happen.
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Also this host driver requires valid PCI BAR4 for normal operation so
check it in ->init_chipset and fail initialization if not set.
* Use ->OUTBSYNC instead of ->OUTB when writing command register
(needed for scc_pata and pmac host drivers).
* Don't check DRDY bit of the status register on ATAPI devices
(ATAPI devices are free to ignore DRDY bit).
Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp>
Cc: Akira Iguchi <akira2.iguchi@toshiba.co.jp>
* Move ide_in_drive_list() from ide-dma.c to ide-iops.c.
* Add ivb_list[] table for listening early UDMA66 devices which don't conform
to ATA4 standard wrt cable detection (bit14 is zero, only bit13 is valid)
and use only device side cable detection for them since host side cable
detection may be unreliable.
* Add model "QUANTUM FIREBALLlct10 05" with firwmare "A03.0900" to the list
(from Craig's bugreport).
v2:
* Improve kernel message basing on suggestion from Sergei.
v3:
* Don't print kernel message when no device side cable detection is done,
plus some minor fixes. (Noticed by Sergei)
Thanks to Craig for testing this patch.
Cc: Craig Block <chblock3@yahoo.com>
pmac_ide_tune_chipset() don't set drive->init_speed.
Fix it by setting drive->{current,init}_speed in pmac_ide_do_setfeature()
and clean up pmac_ide_{tune_chipset,mdma_enable,udma_enable}().
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
* Add DMA blacklist checking (->ide_dma_on check probably can go now).
* Add ->atapi_dma flag checking and remove no longer needed
ns87415_ide_dma_check() from ns87415 host driver.
* Remove now needless __ide_dma_check() wrapper and symbol export.
* Check drive->autodma instead of hwif->autodma (there should be no changes in
behavior as all users of config_drive_for_dma() set both ->autodma flags).
Some host drivers depend on CONFIG_IDE_GENERIC to do the probing but their
config options lack explicit dependencies on IDE_GENERIC. In the long-term
these host drivers should be fixed to do the probing themselves but for now
fix them by making their config options select CONFIG_IDE_GENERIC.
These days, CONFIG_IDE_GENERIC causes more confusion and
misconfiguration than it helps. Especially so because libata is
linked after the generic driver. Default to N.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
Cc: "P.C.Chan" <pc.chan@alcatel-lucent.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Configuring the OLPC camera requires something over 150 register
writes. Unfortunately, querying the CAFE i2c controller too
soon after a write causes the hardware to flake. The problem had
been "solved" with an msleep() call, but, between the number of
registers and how msleep() behaves, that resulted in a 3-second
delay on camera initialization. Instead, we hand-code a wait for
the completion interrupt which avoids reading the status registers.
Signed-off-by: Chris Ball <cjb@laptop.org>
The tuner maximum frequency wasn't being set, while the minimum
frequency was set to what the maximum should have been.
If a future patch were to enforce these limits, dvb-pll would be
effectively broken.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
ivtv: fix VIDIOC_S_FBUF support: new OSD values where never actually set.
The values set with VIDIOC_S_FBUF were not actually used until the next
VIDIOC_S_FMT. Fixed.
When taking a cpu down, we need to hardware_disable() it.
Unfortunately, the CPU_DYING notifier is called with interrupts
disabled, which means we can't use smp_call_function_single().
Fortunately, the CPU_DYING notifier is always called on the dying cpu,
so we don't need to use the function at all and can simply call
hardware_disable() directly.
Tested-by: Paolo Ornati <ornati@fastwebnet.it>
Signed-off-by: Avi Kivity <avi@qumranet.com>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 4549/1: KS8695: Fix build errors
[ARM] 4546/1: s3c2410: fix architecture typo for s3c2442
[ARM] 4544/1: arm: fix section mismatch in pxa fb
If the forcedeth driver receives too much work in an interrupt, it
assumes it has a broken hardware with stuck IRQ. It works around the
problem by disabling interrupts on the nic but makes a printk while
holding device spinlog - which isn't smart thing to do if you have
netconsole on the same nic.
This patch moves the printk's out of the spinlock protected area.
Without this patch the machine hangs hard. With this patch everything
still works even when there is significant increase on CPU usage while
using the nic.
Signed-off-by: Timo Jantunen <jeti@iki.fi>
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> (edited MACINTOSH_DRIVERS per Geert Uytterhoeven's remark)
The lguest block device only requests one minor, which means
partitions don't work (eg "root=/dev/lgba1").
Let's follow the crowd and ask for 16.
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6:
hwmon: (smsc47m1) restore missing name attribute
hwmon: (w83627ehf) don't assume bank 0
hwmon: (w83627ehf) read fan_div values during probe
hwmon: fix w83781d temp sensor type setting
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/mlx4: Incorrect semicolon after if statement
mlx4_core: Wait 1 second after reset before accessing device
IPoIB: Fix leak in ipoib_transport_dev_init() error path
IB/mlx4: Fix opcode returned in RDMA read completion
IB/srp: Add OUI for new Cisco targets
IB/srp: Wrap OUI checking for workarounds in helper functions
RDMA/cxgb3: Always call low level send function via cxgb3_ofld_send()
IB: Move the macro IB_UMEM_MAX_PAGE_CHUNK() to umem.c
IB: Include <linux/list.h> and <linux/rwsem.h> from <rdma/ib_verbs.h>
IB: Include <linux/list.h> from <rdma/ib_mad.h>
IB/mad: Fix address handle leak in mad_rmpp
IB/mad: agent_send_response() should be void
IB/mad: Fix memory leak in switch handling in ib_mad_recv_done_handler()
IB/mad: Fix error path if response alloc fails in ib_mad_recv_done_handler()
IB/sa: Don't need to check for default P_Key twice
IB/core: Ignore membership bit in ib_find_pkey()
[IPv6]: Invalid semicolon after if statement
[NET]: Fix unbalanced rcu_read_unlock in __sock_create
[VLAN] net/8021q/vlanproc.c: fix check-after-use
[NET]: Unexport dev_ethtool
[IOAT]: Remove redundant struct member to avoid descriptor cache miss
[ECONET]: remove econet_packet_type on unload
[AX25]: don't free pointers to statically allocated data
[PATCH] mac80211: probe for hidden SSIDs in pre-auth scan
[PATCH] mac80211: fix tx status frame code
[BRIDGE]: Fix typo in net/bridge/br_stp_if.c
[BRIDGE]: sysfs locking fix.
[NETFILTER]: nf_nat_sip: don't drop short packets
[NETFILTER]: nf_conntrack_sip: fix SIP-URI parsing
[NETFILTER]: nf_conntrack_sip: check sname != NULL before calling strncmp
[NETFILTER]: netfilter: xt_u32 bug correction
They are apparently pretty close (even lspci combines them). The patch
adds support for 0x1533 bridge in addition to 0x1535.
Tested on Toshiba Portege 4000 with
00:07.0 ISA bridge [0601]: ALi Corporation M1533/M1535 PCI to ISA Bridge
[Aladdin IV/V/V+] [10b9:1533]
00:08.0 Bridge [0680]: ALi Corporation M7101 Power Management Controller
[PMU] [10b9:7101]
with result
[ 2090.906736] PCI: Enabling device 0000:00:08.0 (0000 -> 0001)
[ 2090.914034] ALi_M1535: initialized. timeout=3D60 sec (nowayout=3D0)
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Clean-up history and add a comment about the fact that
the watchdog is actually part of the SMSC FDC 37B782
super I/O chipset.
A stray semicolon makes us inadvertently ignore the value of err.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Adjust libata to ignore errors after spinup
This patch is to ignore errors from the spinup attempt if the drive is
in the "standby id" state.
Signed-off-by: Ryan Power <rpower@sysreset.com>
Acked-by: Mark Lord <liml@rtr.ca>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Tejun Heo <htejun@gmail.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Add TECRA M7 to broken suspend list. Reported by Marie Koreen.
Cc: Marie Koreen <kbug@koreen.com>
Fix several inconsistencies in these drivers WRT reporting the clocks:
- when using DPLL mode, 'pata_hpt37x' driver reported the DPLL frequency as the
PCI clock -- make it properly report both clocks and add the same ability to
the 'pata_hpt3x2n' driver;
- both drivers sometimes use "pata_hpt3*:" and sometimes "hpt3*:" in the
messages -- make them use only the former one;
- the message about failed DPLL stablizatios deserves KERN_ERR and a bang. :-)
The DPLL tuning code always set up it for 66 MHz due to wrong UltraDMA mask
including mode 5 used to check for the necessity of 66 MHz clocking -- this
caused 66 MHz clock to be used for HPT374 chip that does not tolerate it.
While fixing this, also remove PLL mode from the TODO list -- I don't think
it's still a relevant item.
Maximum supported UDMA mode for AEC6280[R] is UDMA5 (not UDMA4)
and for AEC6880[R] it is UDMA6 (not UDMA5):
* Fix the problem by adding missing struct ata_port_info to artop_init_one().
* Use the right naming (s/626/628/).
* Bump driver version.
Fixes IDE->libata regression, problem was never present in IDE aec62xx driver.
