path: root/drivers
2007-04-24[POWERPC] via-pmu: Switch to ref counting PCI APIAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Remove old interface find_devicesStephen Rothwell
Replace uses with of_find_node_by_name and for_each_node_by_name. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Remove old interface find_type_devicesStephen Rothwell
Replaced by of_find_node_by_type. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Remove old interface find_path_deviceStephen Rothwell
Replaced by of_find_node_by_path. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Remove find_compatible_devicesStephen Rothwell
This is an old interface and is replaced by of_find_compatible_node. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] hvc_console: Typo fixeswill schmidt
Fix a handful of comment typos for hvc_console. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] hvc_console: Polling mode timer backoffWill Schmidt
Add a back-off mechanism to hvc_console's polling logic. This change drops the timers/second ratio from ~90 to ~1/2 while the console is idle. This change is most noticeable when watching /proc/timer_stats output. This only affects when the hvc_console is running in poll mode, i.e. power4 and cell systems. I've tested on Power4, Michael Ellerman has both contributed to the patch and tested on cell. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Partially revert "Add correct interrupt property for pegasos ide"Paul Mackerras
It turns out that commit e48059225c2edc6f1e5a2008261f1efdf606f247 breaks some existing systems that use the via82cxxx driver. This reverts the change to via82cxxx.c. Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Add correct interrupt property for pegasos ideOlaf Hering
The firmware assigns irq 20/21 to the VIA IDE device on Pegasos. But the required interrupt is 14/15. Maybe someone confused decimal vs. hexadecimal values. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Make struct property's value a void *Stephen Rothwell
2007-04-13[POWERPC] Rename prom_n_size_cells to of_n_size_cellsStephen Rothwell
This is more consistent and gets us closer to the Sparc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename prom_n_addr_cells to of_n_addr_cellsStephen Rothwell
2007-04-13[POWERPC] get_property returns constStephen Rothwell
This just tidies up some of the remains. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Fix modalias content in sysfs for macio devicesOlaf Hering
Currently the buf pointer is advanced too far during each iteration. Also terminate the string with a newline. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] PMU LED whitelisting of PowerMac 7,2 and 7,3Tony Vroon
This allows the PMU LED on both a PowerMac 7,2 (Dual G5 2.0GHz, June 2003) and a PowerMac 7,3 (Dual G5 2.0GHz, June 2004) to be controlled. The physical LED is never off, unlike an iBook/PowerBook LED. It is rather dim ("off") or very bright ("on"). Signed-off-by: Tony Vroon <chainsaw@gentoo.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] powermac: Use the new of_device common uevent handlerSylvain Munaut
The generation of the uevent is now common to all bus using of_device. Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-11Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: myri10ge: update driver version to 1.3.0-1.233 myri10ge: more Intel chipsets providing aligned PCIe completions myri10ge: fix management of the firmware 4KB boundary crossing restriction cxgb3 - missing CPL hanler and register setting. cxgb3 - MAC watchdog update cxgb3 - avoid deadlock with mac watchdog skge: fix wake on lan sky2: phy workarounds for Yukon EC-U A1 sky2: turn on clocks when doing resume sky2: turn carrier off when down skge: turn carrier off when down [PATCH] bcm43xx: Fix PPC machine checks and match loopback gain specs [PATCH] bcm43xx: Fix 802.11b/g scan limits to match regulatory reqs [PATCH] zd1211rw: Fix E2P_PHY_REG patching [PATCH] zd1211rw: Reject AL2230S devices
2007-04-11Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: Nikon D80 unusual device patch EHCI: fix remote wakeup regression in 2.6.21-rc
2007-04-11[PATCH] PM: use kobject_name() to access kobject namesDmitry Torokhov
Noone should use kobj.name directly since it may contain garbage. Objects with longer names have them stored in separately allocated memory pointed to by kobj->k_name. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-11USB: Nikon D80 unusual device patchEmil Larsson
the Nikon D80 camera will not work without an UNUSUAL_DEV entry embodied in the attached patch (made against 2.6.20.3). Hope you find it helpful, or if not, pass it along to someone who does. From: Emil Larsson <emil@swip.net> Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-11EHCI: fix remote wakeup regression in 2.6.21-rcAlan Stern
There is one significant difference between the behavior of root hubs (as embodied in host controller hardware) and external hubs: When a remote-wakeup signal is received, an external hub sends an interrupt message at the _end_ of the resume sequence but a root hub generates and interrupt at the _beginning_ of the resume sequence. The host system must poll for the end of the sequence. When ehci-hcd was converted to interrupt-driven operation instead of using polling, the remaining need for this particular poll was overlooked. This patch (as894) fixes the problem. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-11Merge branch 'upstream-fixes' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
2007-04-11myri10ge: update driver version to 1.3.0-1.233Brice Goglin
Update the myri10ge driver version number to 1.3.0-1.233. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11myri10ge: more Intel chipsets providing aligned PCIe completionsBrice Goglin
Add the Intel 5000 southbridge (aka Intel 6310/6311/6321ESB) PCIe ports and the Intel E30x0 chipsets to the whitelist of aligned PCIe completion. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11myri10ge: fix management of the firmware 4KB boundary crossing restrictionBrice Goglin
Simpler way of dealing with the firmware 4KB boundary crossing restriction for rx buffers. This fixes a variety of memory corruption issues when using an "uncommon" MTU with a 16KB page size. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11cxgb3 - missing CPL hanler and register setting.Divy Le Ray
Remove specific CPL handler. Add missing CPL handler. Add missing register setting when the interface is brought up. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11cxgb3 - MAC watchdog updateDivy Le Ray
The MAC watchdog was failing if the peer interface was brought down. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11cxgb3 - avoid deadlock with mac watchdogDivy Le Ray
Fix a deadlock when the interface s configured down and the watchdog tack is sleeping on rtnl_lock. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11skge: fix wake on lanStephen Hemminger
Need to rework wake on lan code to setup properly and get activated on shutdown (and suspend), not when ethtool is run. This does not need to go to stable queue because wake on lan was not even included in 2.6.20 (or earlier versions). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11sky2: phy workarounds for Yukon EC-U A1Stephen Hemminger
The workaround Yukon EC-U wasn't comparing with correct version and wasn't doing correct setup. Without it, 88e8056 throws all sorts of errors. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11sky2: turn on clocks when doing resumeStephen Hemminger
Some of these chips are disabled until clock is enabled. This fixes: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=404107 Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11sky2: turn carrier off when downStephen Hemminger
Driver needs to turn off carrier when down. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11skge: turn carrier off when downStephen Hemminger
Driver needs to turn off carrier when down, otherwise it can confuse bonding and bridging and looks like carrier is on immediately when it is brought back up. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-10[PATCH] Input: ucb1400 - set up driver's name to show in sysfsCliff Brake
The UCB1400 is missing a name parameter in the device_driver struct. This causes missing information in the /sys tree and seems to cause other problems with the AC97 functionality. This was tested on a PXA270 system. Signed-off-by: Cliff Brake <cbrake@bec-systems.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-10Merge branch 'for-2.6.21' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart * 'for-2.6.21' of master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] intel_agp: fix G965 GTT size detect
2007-04-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: change deprecation status of dv1394
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IPoIB/cm: Fix DMA direction typo IB/iser: Don't defer connection failure notification to workqueue
2007-04-10Merge branch 'upstream-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: Do not discard truncated input reports
2007-04-10Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: ide: add "optical" to sysfs "media" attribute ide: ugly messages trying to open CD drive with no media present ide: correctly prevent IDE timer expiry function to run if request was already handled
2007-04-10ide: add "optical" to sysfs "media" attributeDanny Kukawka
Add "optical" to sysfs "media" attribute as already in /proc Signed-off-by: Danny Kukawka <dkukawka@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-10ide: ugly messages trying to open CD drive with no media presentStuart Hayes
I get the following error messages when trying to open a CD device (specifically, the Teac CD-ROM CD-224E) that has no media present: hda: packet command error: status=3D0x51 { DriveReady SeekComplete Error } hda: packet command error: error=3D0x54 { AbortedCommand LastFailedSense=0x05 } ide: failed opcode was: unknown This happens when a "start stop unit" command (0x1b 0 0 0 3 0 0 0 0 0) is sent to the drive to try to close the CD-ROM tray, but this drive doesn't have that capability (it's a slim portable-type CD-ROM), so it reports sense key 5 (illegal request) with asc/ascq 24/0. This is exactly how SFF8090i says it should respond. But ide-cd.c (in cdrom_decode_status() ) just sees sense key 5 and spews out an error. It then goes on to request sense data, and cdrom_log_sense() understands this error and doesn't log it. The patch, for kernel 2.6.20.4, suppresses this error message. Signed-off-by: Stuart Hayes <stuart_hayes@dell.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-10ide: correctly prevent IDE timer expiry function to run if request was ↵Suleiman Souhlal
already handled It is possible for the timer expiry function to run even though the request has already been handled: ide_timer_expiry() only checks that the handler is not NULL, but it is possible that we have handled a request (thus clearing the handler) and then started a new request (thus starting the timer again, and setting a handler). A simple way to exhibit this is to set the DMA timeout to 1 jiffy and run dd: The kernel will panic after a few minutes because ide_timer_expiry() tries to add a timer when it's already active. To fix this, we simply add a request generation count that gets incremented at every interrupt, and check in ide_timer_expiry() that we have not already handled a new interrupt before running the expiry function. Signed-off-by: Suleiman Souhlal <suleiman@google.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-04-10[PATCH] bcm43xx: Fix PPC machine checks and match loopback gain specsLarry Finger
The specifications for loopback_gain calculation and for G PHY initialization have been updated. This patch implements them and fixes a machine check error that occurs for PPC architecture with a phy->rev of 1. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-10[PATCH] bcm43xx: Fix 802.11b/g scan limits to match regulatory reqsLarry Finger
In 802.11b/g mode, bcm43xx actively scans channels 1-14 no matter what locale has been set, either in the sprom or by the locale option. This behaviorviolates regulatory rules everywhere in the world except Japan. This patch changes the default range to the correct value if the locale has been set, and to channels 1-13 if no locale has been set. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-10[PATCH] zd1211rw: Fix E2P_PHY_REG patchingDaniel Drake
Due to conflicting/confusing defines in the vendor driver, we were reading E2P_PHY_REG from the wrong location. CR157 patching was slightly incorrect in that the vendor driver only patches in an 8-bit value, whereas we were patching 24 bits. Additionally, CR157 patching was happening on both zd1211 and zd1211b, but this should only happen on zd1211. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-10IPoIB/cm: Fix DMA direction typoMichael S. Tsirkin
Receive buffers need to be mapped with DMA_FROM_DEVICE. Incorrectly mapping with DMA_TO_DEVICE causes a hard lock on ppc64 machines with an IOMMU. This fixes <https://bugs.openfabrics.org/show_bug.cgi?id=431> Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-04-10[PATCH] zd1211rw: Reject AL2230S devicesDaniel Drake
zd1211rw currently detects AL2230S-based devices as AL2230, and hence programs the RF incorrectly. Transmit silently fails on this misconfiguration. After this patch, AL2230S devices are rejected with an error message, to avoid any confusion with an apparent driver bug. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-09[AGPGART] intel_agp: fix G965 GTT size detectWang Zhenyu
On G965, I810_PGETBL_CTL is a mmio offset, but we wrongly take it as pci config space offset in detecting GTT size. This one line patch fixs this. Signed-off-by: Wang Zhenyu <zhenyu.z.wang@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
