Pull virtio fixes from Michael S. Tsirkin:
"Here are some virtio fixes for 3.4: a test build fix, a patch by Ren
fixing naming for systems with a massive number of virtio blk devices,
and balloon fixes for powerpc by David Gibson.
There was some discussion about Ren's patch for virtio disc naming:
some people wanted to move the legacy name mangling function to the
block core. But there's no concensus on that yet, and we can always
deduplicate later. Added comments in the hope that this will stop
people from copying this legacy naming scheme into future drivers."
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
virtio_balloon: fix handling of PAGE_SIZE != 4k
virtio_balloon: Fix endian bug
virtio_blk: helper function to format disk names
tools/virtio: fix up vhost/test module build
Some shortcomings introduced into pci_restore_state() by commit
26f41062f28d ("PCI: check for pci bar restore completion and retry")
have been fixed by recent commit ebfc5b802fa76 ("PCI: Fix regression in
pci_restore_state(), v3"), but that commit treats all PCI devices as
those with Type 0 configuration headers.
That is not entirely correct, because Type 1 and Type 2 headers have
different layouts. In particular, the area occupied by BARs in Type 0
config headers contains the secondary status register in Type 1 ones and
it doesn't make sense to retry the restoration of that register even if
the value read back from it after a write is not the same as the written
one (it very well may be different).
For this reason, make pci_restore_state() only retry the restoration
of BARs for Type 0 config headers. This effectively makes it behave
as before commit 26f41062f28d for all header types except for Type 0.
Tested-by: Mikko Vinni <mmvinni@yahoo.com>
Pull ARM fixes from Russell King:
"Nothing too disasterous, the biggest thing being the removal of the
regulator support for vcore in the AMBA driver; only one SoC was using
this and it got broken during the last merge window, which then
started causing problems for other people. Mutual agreement was
reached for it to be removed."
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7386/1: jump_label: fixup for rename to static_key
ARM: 7384/1: ThumbEE: Disable userspace TEEHBR access for !CONFIG_ARM_THUMBEE
ARM: 7382/1: mm: truncate memory banks to fit in 4GB space for classic MMU
ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus
ARM: 7383/1: nommu: populate vectors page from paging_init
ARM: 7381/1: nommu: fix typo in mm/Kconfig
ARM: 7380/1: DT: do not add a zero-sized memory property
ARM: 7379/1: DT: fix atags_to_fdt() second call site
ARM: 7366/3: amba: Remove AMBA level regulator support
ARM: 7377/1: vic: re-read status register before dispatching each IRQ handler
ARM: 7368/1: fault.c: correct how the tsk->[maj|min]_flt gets incremented
Commit 26f41062f28d ("PCI: check for pci bar restore completion and
retry") attempted to address problems with PCI BAR restoration on
systems where FLR had not been completed before pci_restore_state() was
called, but it did that in an utterly wrong way.
First off, instead of retrying the writes for the BAR registers only, it
did that for all of the PCI config space of the device, including the
status register (whose value after the write quite obviously need not be
the same as the written one). Second, it added arbitrary delay to
pci_restore_state() even for systems where the PCI config space
restoration was successful at first attempt. Finally, the mdelay(10) it
added to every iteration of the writing loop was way too much of a delay
for any reasonable device.
All of this actually caused resume failures for some devices on Mikko's
system.
To fix the regression, make pci_restore_state() only retry the writes
for BAR registers and only wait if the first read from the register
doesn't return the written value. Additionaly, make it wait for 1 ms,
instead of 10 ms, after every failing attempt to write into config
space.
Reported-by: Mikko Vinni <mmvinni@yahoo.com>
Pull "ARM: a few more SoC fixes for 3.4-rc" from Olof Johansson:
- A handful of warning and build fixes for Qualcomm MSM
- Build/warning and bug fixes for Samsung Exynos
- A fix from Rob Herring that removes misplaced interrupt-parent
properties from a few device trees
- A fix to OMAP dealing with cpufreq build errors, removing some of the
offending code since it was redundant anyway
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: OMAP: clock: cleanup CPUfreq leftovers, fix build errors
ARM: dts: remove blank interrupt-parent properties
ARM: EXYNOS: Fix Kconfig dependencies for device tree enabled machine files
ARM: EXYNOS: Remove broken config values for touchscren for NURI board
ARM: EXYNOS: set fix xusbxti clock for NURI and Universal210 boards
ARM: EXYNOS: fix regulator name for NURI board
ARM: SAMSUNG: make SAMSUNG_PM_DEBUG select DEBUG_LL
ARM: msm: Fix section mismatches in proc_comm.c
video: msm: Fix section mismatches in mddi.c
arm: msm: trout: fix compile failure
arm: msm: halibut: remove unneeded fixup
ARM: EXYNOS: Add PDMA and MDMA physical base address defines
ARM: S5PV210: Fix compiler warning in dma.c file
ARM: EXYNOS: Fix compile error in exynos5250-cpufreq.c
ARM: EXYNOS: Add missing definition for IRQ_I2S0
ARM: S5PV210: fix unused LDO supply field from wm8994_pdata
Commit 18a4d0a22ed6 ("[SCSI] Handle disk devices which can not process
medium access commands") introduced a bug in which we would attempt to
dereference the scsi driver even when the device had no ULD attached.
Ensure that a driver is registered and make the driver accessor function
more resilient to errors during device discovery.
Reported-by: Elric Fu <elricfu1@gmail.com>
Reported-by: Bart Van Assche <bvanassche@acm.org>
As reported by David Gibson, current code handles PAGE_SIZE != 4k
completely wrong which can lead to guest memory corruption errors:
- page_to_balloon_pfn is wrong: e.g. on system with 64K page size
it gives the same pfn value for 16 different pages.
- we also need to convert back to linux pfns when we free.
- for each linux page we need to tell host about multiple balloon
pages, but code only adds one pfn to the array.
This patch fixes all that, tested with a 64k ppc64 kernel.
Reported-by: David Gibson <david@gibson.dropbear.id.au>
Tested-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Although virtio config space fields are usually in guest-native endian,
the spec for the virtio balloon device explicitly states that both fields
in its config space are little-endian.
However, the current virtio_balloon driver does not have a suitable endian
swap for the 'num_pages' field, although it does have one for the 'actual'
field. This patch corrects the bug, adding sparse annotation while we're
at it.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Pull fbdev fixes from Florian Tobias Schandinat:
- a compile fix for au1*fb
- a fix to make kyrofb usable on x86_64
- a fix for uvesafb to prevent an oops due to NX-protection
"The fix for kyrofb is a bit large but it's just replacing "unsigned
long" by "u32" for 64 bit compatibility."
* tag 'fbdev-fixes-for-3.4-1' of git://github.com/schandinat/linux-2.6:
video:uvesafb: Fix oops that uvesafb try to execute NX-protected page
fbdev: fix au1*fb builds
kyrofb: fix on x86_64
Pull block driver bits from Jens Axboe:
- A series of fixes for mtip32xx. Most from Asai at Micron, but also
one from Greg, getting rid of the dependency on PCIE_HOTPLUG.
- A few bug fixes for xen-blkfront, and blkback.
- A virtio-blk fix for Vivek, making resize actually work.
- Two fixes from Stephen, making larger transfers possible on cciss.
This is needed for tape drive support.
* 'for-3.4/drivers' of git://git.kernel.dk/linux-block:
block: mtip32xx: remove HOTPLUG_PCI_PCIE dependancy
mtip32xx: dump tagmap on failure
mtip32xx: fix handling of commands in various scenarios
mtip32xx: Shorten macro names
mtip32xx: misc changes
mtip32xx: Add new sysfs entry 'status'
mtip32xx: make setting comp_time as common
mtip32xx: Add new bitwise flag 'dd_flag'
mtip32xx: fix error handling in mtip_init()
virtio-blk: Call revalidate_disk() upon online disk resize
xen/blkback: Make optional features be really optional.
xen/blkback: Squash the discard support for 'file' and 'phy' type.
mtip32xx: fix incorrect value set for drv_cleanup_done, and re-initialize and start port in mtip_restart_port()
cciss: Fix scsi tape io with more than 255 scatter gather elements
cciss: Initialize scsi host max_sectors for tape drive support
xen-blkfront: make blkif_io_lock spinlock per-device
xen/blkfront: don't put bdev right after getting it
xen-blkfront: use bitmap_set() and bitmap_clear()
xen/blkback: Enable blkback on HVM guests
xen/blkback: use grant-table.c hypercall wrappers
The OMAP driver needs a 'depends on ARCH_OMAP2PLUS' since it only
builds for OMAP2+ platforms.
This 'depends on' was in the original patch from Russell King, but was
erroneously removed by me when making this option user-selectable in
commit b09db45c (cpufreq: OMAP driver depends CPUfreq tables.) This
patch remedies that.
Apologies to Russell King for breaking his originally working patch.
Also, thanks to Grazvydas Ignotas for reporting the same problem.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon patches from Guenter Roeck:
"Fix build warnings in four drivers"
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (pmbus_core) Fix compiler warning
hwmon: (smsc47m1) Fix compiler warning
hwmon: (acpi_power_meter) Fix compiler warning seen in some configurations
hwmon: (smsc47b397) Fix compiler warning
Pull GPIO bug fixes from Grant Likely:
"Miscellaneous bug fixes to GPIO drivers and for a corner case in the
gpio device tree parsing code."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux-2.6:
gpio/exynos: Fix compiler warning in gpio-samsung.c file
gpio: Fix range check in of_gpio_simple_xlate()
gpio: Fix uninitialized variable bit in adp5588_irq_handler
gpio/sodaville: Convert sodaville driver to new irqdomain API
Pull SPI bug fixes from Grant Likely:
"Miscellaneous driver bug fixes. No major changes in this branch."
* tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6:
spi/imx: prevent NULL pointer dereference in spi_imx_probe()
spi/imx: mark base member in spi_imx_data as __iomem
spi/mpc83xx: fix NULL pdata dereference bug
spi/davinci: Fix DMA API usage in davinci
spi/pL022: include types.h to remove compilation warnings
The change
commit 461cbe77d0a4f887c33a3a95ea68a7daf23b4302
Author: Gregory Bean <gbean@codeaurora.org>
Date: Wed Jul 28 10:22:13 2010 -0700
video: msm: Fix section mismatch in mddi.c.
fixes a section mismatch between the board file and the driver's probe
function, however, it misses the additional mismatches between the
probe function and some routines it calls. Fix these up as well.
Signed-off-by: David Brown <davidb@codeaurora.org>
The AMBA bus regulator support is being used to model on/off switches
for power domains which isn't terribly idiomatic for modern kernels with
the generic power domain code and creates integration problems on platforms
which don't use regulators for their power domains as it's hard to tell
the difference between a regulator that is needed but failed to be provided
and one that isn't supposed to be there (though DT does make that easier).
Platforms that wish to use the regulator API to manage their power domains
can indirect via the power domain interface.
This feature is only used with the vape supply of the db8500 PRCMU
driver which supplies the UARTs and MMC controllers, none of which have
support for managing vcore at runtime in mainline (only pl022 SPI
controller does). Update that supply to have an always_on constraint
until the power domain support for the system is updated so that it is
enabled for these users, this is likely to have no impact on practical
systems as probably at least one of these devices will be active and
cause AMBA to hold the supply on anyway.
Tested-by: Shawn Guo <shawn.guo@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband fix from Roland Dreier:
"Add a fix for a bug hit by Alexey Shvetsov in ib_srtp that hits on
non-mlx4 hardware."
* tag 'srpt-srq-type' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/srpt: Set srq_type to IB_SRQT_BASIC
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of fixes for the USB core and drivers for 3.4-rc2
Lots of tiny xhci fixes here, a few usb-serial driver fixes and new
device ids, and a smattering of other minor fixes in different USB
drivers.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (30 commits)
USB: update usbtmc api documentation
xHCI: Correct the #define XHCI_LEGACY_DISABLE_SMI
xHCI: use gfp flags from caller instead of GFP_ATOMIC
xHCI: add XHCI_RESET_ON_RESUME quirk for VIA xHCI host
USB: fix bug of device descriptor got from superspeed device
xhci: Fix register save/restore order.
xhci: Restore event ring dequeue pointer on resume.
xhci: Don't write zeroed pointers to xHC registers.
xhci: Warn when hosts don't halt.
xhci: don't re-enable IE constantly
usb: xhci: fix section mismatch in linux-next
xHCI: correct to print the true HSEE of USBCMD
USB: serial: fix race between probe and open
UHCI: hub_status_data should indicate if ports are resuming
EHCI: keep track of ports being resumed and indicate in hub_status_data
USB: fix race between root-hub suspend and remote wakeup
USB: sierra: add support for Sierra Wireless MC7710
USB: ftdi_sio: fix race condition in TIOCMIWAIT, and abort of TIOCMIWAIT when the device is removed
USB: ftdi_sio: fix status line change handling for TIOCMIWAIT and TIOCGICOUNT
USB: don't ignore suspend errors for root hubs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty and serial fixes from Greg KH:
"Here are some tty and serial fixes for 3.4-rc2.
Most important here is the pl011 fix, which has been reported by about
100 different people, which means more people use it than I expected
There are also some 8250 driver reverts due to some problems reported
by them. And other minor fixes as well.
* tag 'tty-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
pch_uart: Add Kontron COMe-mTT10 uart clock quirk
pch_uart: Fix MSI setting issue
serial/8250_pci: add a "force background timer" flag and use it for the "kt" serial port
Revert "serial/8250_pci: setup-quirk workaround for the kt serial controller"
Revert "serial/8250_pci: init-quirk msi support for kt serial controller"
tty/serial/omap: console can only be built-in
serial: samsung: fix omission initialize ulcon in reset port fn()
printk(): add KERN_CONT where needed in hpet and vt code
tty/serial: atmel_serial: fix RS485 half-duplex problem
tty: serial: altera_uart: Check for NULL platform_data in probe.
isdn/gigaset: use gig_dbg() for debugging output
omap-serial: Fix the error handling in the omap_serial probe
serial: PL011: move interrupt clearing
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree fixes from Greg KH:
"Here are a number of bugfixes for the drivers/staging/ portion of the
kernel that have been reported recently.
Nothing major here, with maybe the exception of the ramster code can
now be built so it is enabled in the build again, and lots of memory
leaks that people like to have fixed on their systems.
* tag 'staging-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: android: fix mem leaks in __persistent_ram_init()
staging: vt6656: Don't leak memory in drivers/staging/vt6656/ioctl.c::private_ioctl()
staging: iio: hmc5843: Fix crash in probe function.
staging/xgifb: fix display on XGI Volari Z11m cards
Staging: android: timed_gpio: Fix resource leak in timed_gpio_probe error paths
android: make persistent_ram based drivers depend on HAVE_MEMBLOCK
staging: iio: ak8975: Remove i2c client data corruption
staging: drm/omap: move where DMM driver is registered
staging: zsmalloc: fix memory leak
Staging: rts_pstor: off by one in for loop
staging: ozwpan: Added new maintainer for ozwpan
staging:rts_pstor:Avoid "Bad target number" message when probing driver
staging:rts_pstor:Fix possible panic by NULL pointer dereference
Staging: vt6655-6: check keysize before memcpy()
staging/media/as102: Don't call release_firmware() on uninitialized variable
staging:iio:core add missing increment of loop index in iio_map_array_unregister()
staging: ramster: unbreak my heart
staging/vme: Fix module parameters
staging: sep: Fix sign of error
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core and kobject fixes from Greg KH:
"Here are some minor fixes for the driver core and kobjects that people
have reported recently.
* tag 'driver-core-3.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
kobject: provide more diagnostic info for kobject_add_internal() failures
sysfs: handle 'parent deleted before child added'
sysfs: Prevent crash on unset sysfs group attributes
sysfs: Update the name hash for an entry after changing the namespace
drivers/base: fix compiler warning in SoC export driver - idr should be ida
drivers/base: Remove unneeded spin_lock_init call for soc_lock
Pull timer fixes from Thomas Gleixner:
"The itimer removal one is not strictly a fix, but I really wanted to
avoid a rebase of the urgent ones."
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "clocksource: Load the ACPI PM clocksource asynchronously"
clockevents: tTack broadcast device mode change in tick_broadcast_switch_to_oneshot()
itimer: Use printk_once instead of WARN_ONCE
nohz: Fix stale jiffies update in tick_nohz_restart()
tick: Document TICK_ONESHOT config option
proc: stats: Use arch_idle_time for idle and iowait times if available
itimer: Schedule silent NULL pointer fixup in setitimer() for removal
If, in __persistent_ram_init(), the call to
persistent_ram_buffer_init() fails or the call to
persistent_ram_init_ecc() fails then we fail to free the memory we
allocated to 'prz' with kzalloc() - thus leaking it.
To prevent the leaks I consolidated all error exits from the function
at a 'err:' label at the end and made all error cases jump to that
label where we can then make sure we always free 'prz'. This is safe
since all the situations where the code bails out happen before 'prz'
has been stored anywhere and although we'll do a redundant kfree(NULL)
call in the case of kzalloc() itself failing that's OK since kfree()
deals gracefully with NULL pointers and I felt it was more important
to keep all error exits at a single location than to avoid that one
harmless/redundant kfree() on a error path.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Colin Cross <ccross@android.com>
Cc: stable <stable@vger.kernel.org>
If copy_to_user() fails in the WLAN_CMD_GET_NODE_LIST case of the
switch in drivers/staging/vt6656/ioctl.c::private_ioctl() we'll leak
the memory allocated to 'pNodeList'. Fix that by kfree'ing the memory
in the failure case.
Also remove a pointless cast (to type 'PSNodeList') of a kmalloc()
return value - kmalloc() returns a void pointer that is implicitly
converted, so there is no need for an explicit cast.
Fix crash after issuing:
echo hmc5843 0x1e > /sys/class/i2c-dev/i2c-2/device/new_device
[ 37.180999] device: '2-001e': device_add
[ 37.188293] bus: 'i2c': add device 2-001e
[ 37.194549] PM: Adding info for i2c:2-001e
[ 37.200958] bus: 'i2c': driver_probe_device: matched device 2-001e with driver hmc5843
[ 37.210815] bus: 'i2c': really_probe: probing driver hmc5843 with device 2-001e
[ 37.224884] HMC5843 initialized
[ 37.228759] ------------[ cut here ]------------
[ 37.233612] kernel BUG at mm/slab.c:505!
[ 37.237701] Internal error: Oops - BUG: 0 [#1] PREEMPT
[ 37.243103] Modules linked in:
[ 37.246337] CPU: 0 Not tainted (3.3.1-gta04+ #28)
[ 37.251647] PC is at kfree+0x84/0x144
[ 37.255493] LR is at kfree+0x20/0x144
[ 37.259338] pc : [<c00b408c>] lr : [<c00b4028>] psr: 40000093
[ 37.259368] sp : de249cd8 ip : 0000000c fp : 00000090
[ 37.271362] r10: 0000000a r9 : de229eac r8 : c0236274
[ 37.276855] r7 : c09d6490 r6 : a0000013 r5 : de229c00 r4 : de229c10
[ 37.283691] r3 : c0f00218 r2 : 00000400 r1 : c0eea000 r0 : c00b4028
[ 37.290527] Flags: nZcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 37.298095] Control: 10c5387d Table: 9e1d0019 DAC: 00000015
[ 37.304107] Process sh (pid: 91, stack limit = 0xde2482f0)
[ 37.309844] Stack: (0xde249cd8 to 0xde24a000)
[ 37.314422] 9cc0: de229c10 de229c00
[ 37.322998] 9ce0: de229c10 ffffffea 00000005 c0236274 de140a80 c00b4798 dec00080 de140a80
[ 37.331573] 9d00: c032f37c dec00080 000080d0 00000001 de229c00 de229c10 c048d578 00000005
[ 37.340148] 9d20: de229eac 0000000a 00000090 c032fa40 00000001 00000000 00000001 de229c10
[ 37.348724] 9d40: de229eac 00000029 c075b558 00000001 00000003 00000004 de229c10 c048d594
[ 37.357299] 9d60: 00000000 60000013 00000018 205b0007 37332020 3432322e 5d343838 c0060020
[ 37.365905] 9d80: de251600 00000001 00000000 de251600 00000001 c0065a84 de229c00 de229c48
[ 37.374481] 9da0: 00000006 0048d62c de229c38 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.383056] 9dc0: 00000000 c048d62c 00000000 de229c00 de229c00 de1f6c00 de1f6c20 00000001
[ 37.391632] 9de0: 00000000 c048d62c 00000000 c0330164 00000000 de1f6c20 c048d62c de1f6c00
[ 37.400207] 9e00: c0330078 de1f6c04 c078d714 de189b58 00000000 c02ccfd8 de1f6c20 c0795f40
[ 37.408782] 9e20: c0238330 00000000 00000000 c02381a8 de1b9fc0 de1f6c20 de1f6c20 de249e48
[ 37.417358] 9e40: c0238330 c0236bb0 decdbed8 de7d0f14 de1f6c20 de1f6c20 de1f6c54 de1f6c20
[ 37.425933] 9e60: 00000000 c0238030 de1f6c20 c078d7bc de1f6c20 c02377ec de1f6c20 de1f6c28
[ 37.434509] 9e80: dee64cb0 c0236138 c047c554 de189b58 00000000 c004b45c de1f6c20 de1f6cd8
[ 37.443084] 9ea0: c0edfa6c de1f6c00 dee64c68 de1f6c04 de1f6c20 dee64cb8 c047c554 de189b58
[ 37.451690] 9ec0: 00000000 c02cd634 dee64c68 de249ef4 de23b008 dee64cb0 0000000d de23b000
[ 37.460266] 9ee0: de23b007 c02cd78c 00000002 00000000 00000000 35636d68 00333438 00000000
[ 37.468841] 9f00: 00000000 00000000 001e0000 00000000 00000000 00000000 00000000 0a10cec0
[ 37.477416] 9f20: 00000002 de249f80 0000000d dee62990 de189b40 c0234d88 0000000d c010c354
[ 37.485992] 9f40: 0000000d de210f28 000acc88 de249f80 0000000d de248000 00000000 c00b7bf8
[ 37.494567] 9f60: de210f28 000acc88 de210f28 000acc88 00000000 00000000 0000000d c00b7ed8
[ 37.503143] 9f80: 00000000 00000000 0000000d 00000000 0007fa28 0000000d 000acc88 00000004
[ 37.511718] 9fa0: c000e544 c000e380 0007fa28 0000000d 00000001 000acc88 0000000d 00000000
[ 37.520294] 9fc0: 0007fa28 0000000d 000acc88 00000004 00000001 00000020 00000002 00000000
[ 37.528869] 9fe0: 00000000 beab8624 0000ea05 b6eaebac 600d0010 00000001 00000000 00000000
[ 37.537475] [<c00b408c>] (kfree+0x84/0x144) from [<c0236274>] (device_add+0x530/0x57c)
[ 37.545806] [<c0236274>] (device_add+0x530/0x57c) from [<c032fa40>] (iio_device_register+0x8c8/0x990)
[ 37.555480] [<c032fa40>] (iio_device_register+0x8c8/0x990) from [<c0330164>] (hmc5843_probe+0xec/0x114)
[ 37.565338] [<c0330164>] (hmc5843_probe+0xec/0x114) from [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8)
[ 37.574737] [<c02ccfd8>] (i2c_device_probe+0xc4/0xf8) from [<c02381a8>] (driver_probe_device+0x118/0x218)
[ 37.584777] [<c02381a8>] (driver_probe_device+0x118/0x218) from [<c0236bb0>] (bus_for_each_drv+0x4c/0x84)
[ 37.594818] [<c0236bb0>] (bus_for_each_drv+0x4c/0x84) from [<c0238030>] (device_attach+0x78/0xa4)
[ 37.604125] [<c0238030>] (device_attach+0x78/0xa4) from [<c02377ec>] (bus_probe_device+0x28/0x9c)
[ 37.613433] [<c02377ec>] (bus_probe_device+0x28/0x9c) from [<c0236138>] (device_add+0x3f4/0x57c)
[ 37.622650] [<c0236138>] (device_add+0x3f4/0x57c) from [<c02cd634>] (i2c_new_device+0xf8/0x19c)
[ 37.631805] [<c02cd634>] (i2c_new_device+0xf8/0x19c) from [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130)
[ 37.641754] [<c02cd78c>] (i2c_sysfs_new_device+0xb4/0x130) from [<c0234d88>] (dev_attr_store+0x18/0x24)
[ 37.651611] [<c0234d88>] (dev_attr_store+0x18/0x24) from [<c010c354>] (sysfs_write_file+0x10c/0x140)
[ 37.661193] [<c010c354>] (sysfs_write_file+0x10c/0x140) from [<c00b7bf8>] (vfs_write+0xb0/0x178)
[ 37.670410] [<c00b7bf8>] (vfs_write+0xb0/0x178) from [<c00b7ed8>] (sys_write+0x3c/0x68)
[ 37.678833] [<c00b7ed8>] (sys_write+0x3c/0x68) from [<c000e380>] (ret_fast_syscall+0x0/0x3c)
[ 37.687683] Code: 1593301c e5932000 e3120080 1a000000 (e7f001f2)
[ 37.700775] ---[ end trace aaf805debdb69390 ]---
Client data was assigned to iio_dev structure in probe but in
hmc5843_init_client function casted to private driver data structure which
is wrong. Possibly calling mutex_init(&data->lock); corrupt data
which the lead to above crash.
Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Merge fixes from Andrew Morton.
* emailed from Andrew Morton <akpm@linux-foundation.org>: (14 patches)
panic: fix stack dump print on direct call to panic()
drivers/rtc/rtc-pl031.c: enable clock on all ST variants
Revert "mm: vmscan: fix misused nr_reclaimed in shrink_mem_cgroup_zone()"
hugetlb: fix race condition in hugetlb_fault()
drivers/rtc/rtc-twl.c: use static register while reading time
drivers/rtc/rtc-s3c.c: add placeholder for driver private data
drivers/rtc/rtc-s3c.c: fix compilation error
MAINTAINERS: add PCDP console maintainer
memcg: do not open code accesses to res_counter members
drivers/rtc/rtc-efi.c: fix section mismatch warning
drivers/rtc/rtc-r9701.c: reset registers if invalid values are detected
drivers/char/random.c: fix boot id uniqueness race
memcg: fix broken boolen expression
memcg: fix up documentation on global LRU
Pull networking fixes from David Miller:
1) Fix bluetooth userland regression reported by Keith Packard, from
Gustavo Padovan.
2) Revert ath9k PS idle change, from Sujith Manoharan.
3) Correct default TCP memory limits (again), from Eric Dumazet.
4) Fix tcp_rcv_rtt_update() accidental use of unscaled RTT, from Neal
Cardwell.
5) We made a facility for layers like wireless to say how much tailroom
they need in the SKB for link layer stuff such as wireless
encryption etc., but TCP works hard to fill every SKB out to the end
defeating this specification.
This leads to every TCP packet getting reallocated by the wireless
code in order to have the right amount of tailroom available.
Fix TCP to only fill SKBs out to the real amount of data area it
asked for during the allocation, this way it won't eat into the
slack added for the device's tailroom needs.
Reported by Marc Merlin and fixed by Eric Dumazet.
6) Leaks, endian bugs, and new device IDs in bluetooth from Santosh
Nayak, João Paulo Rechi Vita, Cho, Yu-Chen, Andrei Emeltchenko,
AceLan Kao, and Andrei Emeltchenko.
7) OOPS on tty_close fix in bluetooth's hci_ldisc from Johan Hovold.
8) netfilter erroneously scales TCP window twice, fix from Changli Gao.
9) Memleak fix in wext-core from Julia Lawall.
10) Consistently handle invalid TCP packets in ipv4 vs. ipv6 conntrack,
from Jozsef Kadlecsik.
11) Validate IP header length properly in netfilter conntrack's
ipv4_get_l4proto().
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (39 commits)
NFC: Fix the LLCP Tx fragmentation loop
rtlwifi: Add missing DMA buffer unmapping for PCI drivers
rtlwifi: Preallocate USB read buffers and eliminate kalloc in read routine
tcp: avoid order-1 allocations on wifi and tx path
net: allow pskb_expand_head() to get maximum tailroom
bridge: Do not send queries on multicast group leaves
MAINTAINERS: Mark NATSEMI driver as orphan'd.
tcp: fix tcp_rcv_rtt_update() use of an unscaled RTT sample
tcp: restore correct limit
Revert "ath9k: fix going to full-sleep on PS idle"
rt2x00: Fix rfkill_polling register function.
bcma: fix build error on MIPS; implicit pcibios_enable_device
netfilter: nf_conntrack: fix incorrect logic in nf_conntrack_init_net
netfilter: nf_ct_ipv4: packets with wrong ihl are invalid
netfilter: nf_ct_ipv4: handle invalid IPv4 and IPv6 packets consistently
net/wireless/wext-core.c: add missing kfree
rtlwifi: Fix oops on rate-control failure
mac80211: Convert WARN_ON to WARN_ON_ONCE
rtlwifi: rtl8192de: Fix firmware initialization
nl80211: ensure interface is up in various APIs
Pull drm fixes from Dave Airlie:
"Mostly exynos and intel.
Intel has 3 regression fixers (more info in intel merge commit), along
with some other make hw work fixes, exynos has some cleanups and an
ioctl fix.
A couple of radeon fixes, couple of build fixes, and a savage
userspace interface possible overflow fix."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (23 commits)
drm/exynos: fixed exynos broken ioctl
drm/i915: clear fencing tracking state when retiring requests
drm/exynos: fix to pointer manager member of struct exynos_drm_subdrv
drm/exynos: fix struct for operation callback functions to driver name
drm/exynos: use define instead of default_win member in struct mixer_context
drm/exynos: rename s/HDMI_OVERLAY_NUMBER/MIXER_WIN_NR
drm/exynos: remove unused codes in hdmi and mixer
drm/exynos: remove unnecessary type conversion of hdmi and mixer
drm/i915: make rc6 module parameter read-only
drm/i915: implement ColorBlt w/a
drm/i915/ringbuffer: Exclude last 2 cachlines of ring on 845g
Revert "drm/i915: reenable gmbus on gen3+ again"
drm/radeon: only add the mm i2c bus if the hw_i2c module param is set
vgaarb.h: fix build warnings
drm/i915: properly compute dp dithering for user-created modes
drm/radeon/kms: fix DVO setup on some r4xx chips
drm/savage: fix integer overflows in savage_bci_cmdbuf()
drm/radeon: replace udelay with mdelay for long timeouts
drm/i915: Finish any pending operations on the framebuffer before disabling
drm/i915: Removed IVB forced enable of sprite dest key.
Pull a few more fixes for md from NeilBrown:
"Two are tagged for -stable. They can cause an oops, but very rarely."
* tag 'md-3.4-fixes' of git://neil.brown.name/md:
md/bitmap: prevent bitmap_daemon_work running while initialising bitmap
md/raid1,raid10: Fix calculation of 'vcnt' when processing error recovery.
MD: Bitmap version cleanup.
The ST variants of the PL031 all require bit 26 in the control register
to be set before they work properly. Discovered this when testing on
the Nomadik board where it would suprisingly just stand still.
Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: <stable@vger.kernel.org>
RTC stores time and date in several registers. Due to the fact that
these registers can't be read instantaneously, there is a chance that
reading from counting registers gives an error of one minute, one hour,
one day, etc.
To address this issue, the RTC has hardware support to copy the RTC
counting registers to static shadowed registers. The current
implementation does not use this feature, and in a stress test, we can
reproduce this error at a rate of around two times per 300000 readings.
Fix the implementation to ensure that the right snapshot of time is
captured.
Signed-off-by: Konstantin Shlyakhovoy <x0155534@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: linux-omap <linux-omap@vger.kernel.org>
Acked-by: Mykola Oleksiienko <x0174904@ti.com>
Acked-by: Oleksandr Dmytryshyn <oleksandr.dmytryshyn@ti.com>
Acked-by: Graeme Gregory <gg@slimlogic.co.uk>
Driver data field is a pointer, hence assigning that to an integer results
in compilation warnings.
Fixes following compilation warnings:
drivers/rtc/rtc-s3c.c: In function `s3c_rtc_get_driver_data':
drivers/rtc/rtc-s3c.c:452:3: warning: return makes integer from pointer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c: At top level:
drivers/rtc/rtc-s3c.c:674:3: warning: initialization makes pointer from integer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c:674:3: warning: (near initialization for `s3c_rtc_dt_match[1].data') [enabled by default]
drivers/rtc/rtc-s3c.c:677:3: warning: initialization makes pointer from integer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c:677:3: warning: (near initialization for `s3c_rtc_dt_match[2].data') [enabled by default]
drivers/rtc/rtc-s3c.c:680:3: warning: initialization makes pointer from integer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c:680:3: warning: (near initialization for `s3c_rtc_dt_match[3].data') [enabled by default]
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Cc: Heiko Stuebner <heiko@sntech.de>
Fix this error:
drivers/rtc/rtc-s3c.c:671:3: error: request for member `data' in something not a structure or union
drivers/rtc/rtc-s3c.c:674:3: error: request for member `data' in something not a structure or union
drivers/rtc/rtc-s3c.c:677:3: error: request for member `data' in something not a structure or union
drivers/rtc/rtc-s3c.c:680:3: error: request for member `data' in something not a structure or union
efi_rtc_init() uses platform_driver_probe(), so there's no need to also
set efi_rtc_driver's probe member (as it won't be used anyway). This
fixes a modpost section mismatch warning (as efi_rtc_probe() validly is
__init).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Matthew Garrett <mjg@redhat.com>
hwclock refuses to set date/time if RTC registers contain invalid
values. Check the date/time register values at probe time and
initialize them to make hwclock happy.
Signed-off-by: Andreas Dumberger <andreas.dumberger@tqs.de>
/proc/sys/kernel/random/boot_id can be read concurrently by userspace
processes. If two (or more) user-space processes concurrently read
boot_id when sysctl_bootid is not yet assigned, a race can occur making
boot_id differ between the reads. Because the whole point of the boot id
is to be unique across a kernel execution, fix this by protecting this
operation with a spinlock.
Given that this operation is not frequently used, hitting the spinlock
on each call should not be an issue.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Just a few small fixes..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: da9052 - fix memory leak in da9052_onkey_probe()
Input: gpio_mouse - use linux/gpio.h rather than asm/gpio.h
Input: trackpoint - use psmouse_fmt() for messages
Input: elantech - v4 is a clickpad, with only one button
Input: elantech - reset touchpad before configuring it
Input: sentelic - filter taps in absolute mode
Input: tps6507x-ts - fix MODULE_ALIAS to match driver name
Pull vfs fixes from Al Viro:
"Regression fix in mtdchar_open(), fix for a really old leak
(almost never hit in practice - it's a b0rken failure exit in
simple_fill_super()) and a typo fix in vfs.txt (misspelled
method type)."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
typo fix in Documentation/filesystems/vfs.txt
dentry leak in simple_fill_super() failure exit
fix breakage in mtdchar_open(), sanitize failure exits
git://git.infradead.org/users/kmpark/linux-samsung into drm-intel-fixes
* 'exynos-drm-fixes' of git://git.infradead.org/users/kmpark/linux-samsung:
drm/exynos: add format list of plane
drm/exynos: fixed duplicated page allocation bug.
drm/exynos: fixed page align and code clean.
git://people.freedesktop.org/~danvet/drm-intel into drm-intel-fixes
Daniel Vetter writes:
3 regression fixes:
- disable gmbus again, too broken for 3.4, we'll try again for 3.5
- dp bandwidth computation fix, we've lost the 6bpc dithering flag
sometimes, this is a 3.3 regression (maybe even earlier for some
configurations).
- fix resume regression caused by the gen2/3 fencing fix merged into -rc2.
And a few other fixes:
- gpu hang fix for i845 (Chris)
- sprite fix (Armin Reese)
- crtc disable vs. scanlinewait race fix (Chris)
- rc6 module option read-only, it confused testers (Jesse)
- fbc related blitter death hw workaround, note that we disable fbc on snb
by default anyway.
With these fixes we have one 3.4 regression outstanding: One of the
cleanup patches for the interlaced support managed to confuse the lvds
panel fitter when upscaling. The root-cause is still unclear, but test
patches are awaiting feedback from the reporter.
* 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel:
Since commit 96104eda0169 ("RDMA/core: Add SRQ type field"), kernel
users of SRQs need to specify srq_type = IB_SRQT_BASIC in struct
ib_srq_init_attr, or else most low-level drivers will fail in
when srpt_add_one() calls ib_create_srq() and gets -ENOSYS.
(mlx4_ib works OK nearly all of the time, because it just needs
srq_type != IB_SRQT_XRC. And apparently nearly everyone using
ib_srpt is using mlx4 hardware)
Reported-by: Alexey Shvetsov <alexxy@gentoo.org>
Signed-off-by: Roland Dreier <roland@purestorage.com>
The current virtio block's naming algorithm just supports 18278
(26^3 + 26^2 + 26) disks. If there are more virtio blocks,
there will be disks with the same name.
Based on commit 3e1a7ff8a0a7b948f2684930166954f9e8e776fe, add
a function "virtblk_name_format()" for virtio block to support mass
of disks naming.
Notes:
- Our naming scheme is ugly. We are stuck with it
for virtio but don't use it for any new driver:
new drivers should name their devices PREFIX%d
where the sequence number can be allocated by ida
- sd_format_disk_name has exactly the same logic.
Moving it to a central place was deferred over worries
that this will make people keep using the legacy naming
in new drivers.
We kept code idential in case someone wants to deduplicate later.
Signed-off-by: Ren Mingxin <renmx@cn.fujitsu.com>
Acked-by: Asias He <asias@redhat.com>
commit ea5d404655ba3b356d0c06d6a3c4f24112124522
broke build for the vhost test module used
by tools/virtio. Fix it up.
Signed-off-by: Zhi Yong Wu <wuzhy@linux.vnet.ibm.com>
This fixes a resume regression introduced in
commit 7dd4906586274f3945f2aeaaa5a33b451c3b4bba
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Wed Mar 21 10:48:18 2012 +0000
drm/i915: Mark untiled BLT commands as fenced on gen2/3
which fixed fencing tracking for untiled blt commands.
A side effect of that patch was that now also untiled objects have a
non-zero obj->last_fenced_seqno to track when a fence can be set up
after a pipelined tiling change. Unfortunately this was only cleared
by the fence setup and teardown code, resulting in tons of untiled but
inactive objects with non-zero last_fenced_seqno.
Now after resume we completely reset the seqno tracking, both on the
driver side (by setting dev_priv->next_seqno = 1) and on the hw side
(by allocating a new hws page, which contains the seqnos). Hilarity
and indefinite waits ensued from the stale seqnos in
obj->last_fenced_seqno from before the suspend.
The fix is to properly clear the fencing tracking state like we
already do for the normal gpu rendering while moving objects off the
active list.
Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Jiri Slaby <jslaby@suse.cz>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This removes the HOTPLUG_PCI_PCIE dependency on the driver and makes it
depend on PCI.
Cc: Sam Bradshaw <sbradshaw@micron.com>
Acked-by: Asai Thambi S P <asamymuthupa@micron.com>
If a bitmap is added while the array is active, it is possible
for bitmap_daemon_work to run while the bitmap is being
initialised.
This is particularly a problem if bitmap_daemon_work sees
bitmap->filemap as non-NULL before it has been filled in properly.
So hold bitmap_info.mutex while filling in ->filemap
to prevent problems.
This patch is suitable for any -stable kernel, though it might not
apply cleanly before about 3.1.
Cc: stable@vger.kernel.org
Signed-off-by: NeilBrown <neilb@suse.de>
If r1bio->sectors % 8 != 0,then the memcmp and a later
memcpy will omit the last bio_vec.
This is suitable for any stable kernel since 3.1 when bad-block
management was introduced.
Signed-off-by: majianpeng <majianpeng@gmail.com>
bitmap_new_disk_sb() would still create V3 bitmap superblock
with host-endian layout.
Perhaps I'm confused, but shouldn't bitmap_new_disk_sb() be
creating a V4 bitmap superblock instead, that is portable,
as per comment in bitmap.h?
Signed-off-by: Andrei Warkentin <andrey.warkentin@gmail.com>
The struct exynos_drm_manager has to exist for exynos drm sub driver
using encoder and connector. If it isn't NULL to member of struct
exynos_drm_subdrv, will create encoder and connector else will not. And
the is_local member also doesn't need.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
The mixer driver and hdmi driver have each operation callback functions
and they is registered to hdmi common driver. Their struct names in hdmi
common driver include display, manager and overlay. It confuses to
appear whose operation and two driver cannot register same operation
callback functions at the same time. Use their struct names to driver
name.
