DMA on the stack is not allowed. The buffer must be kmalloced.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
GFP_ATOMIC should not be used when GFP_KERNEL can be used.
Signed-off-by: Brian Magnuson <bdmagnuson@gmail.com>
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
The driver version numbers and changelog have not been updated in a
long while to reflect actual changes. Remove the version number and
add a notice that later changes can be tracked in SCM.
Commit 4994cd8dadcf9d484ab3ec19f3c7c7a4e5353c1c introduced a
regression which causes xpad to report force feedback cababilities
for non-360 controllers too, even while there is no actual support
for those.
Fix that by adding a check for XTYPE_XBOX360 to xpad_init_ff().
The buttons BTN_C and BTN_Z are only used in the original xbox
controller, not in xbox360 controller. Therefore only add them to
keybit when the controller is a non-360 one.
Add Mad Catz and 0x0e6f xbox360 controllers which are already found
in xpad_device[] table in xpad.c into the vendor id list. Also add
Logitech into the vendor list for Logitech Chillstream gamepads.
Also add the RedOctane Guitar Hero X-plorer.
The commit ae91d10aab2762f81733e9194cb56eff99c8d808 inverted Y and RY
axes on xbox360 so that up is positive and down is negative.
This is wrong, as axes on game controllers have up as negative per
convention. Also, even xpad itself reports HAT0X with up as negative.
Fix that by inverting them again.
Also, according to http://bugzilla.kernel.org/show_bug.cgi?id=10337 the
original xbox controllers also have the Y and RY axes inverted.
Fix that by inverting them as well.
Cc: Brian Magnuson <bdmagnuson@gmail.com>
For devices not specifically listed in xpad.c, xpad->dpad_mapping
is initially set to MAP_DPAD_UNKNOWN. In xpad_probe() it gets changed
to either MAP_DPAD_TO_BUTTONS or MAP_DPAD_TO_AXES, depending on the
module parameter dpad_to_buttons.
However, MAP_DPAD_UNKNOWN is defined as -1, while the field is u8.
This results in actual value of 255, causing the MAP_DPAD_UNKNOWN
check in xpad_probe() to fail.
Fix that by defining MAP_DPAD_UNKNOWN as 2 instead.
Also, setting module parameter dpad_to_buttons to 1 should obviously
map dpad to buttons, while the default behaviour (0) should be to map
dpad to axes. However, dpad_to_buttons is directly assigned to
xpad->dpad_mapping, and as MAP_DPAD_TO_BUTTONS is 0, the actual
behaviour is reversed.
Fix that by negating dpad_to_buttons in assignment.
Match Xbox 360 controllers using the interface info, i.e. interface
class 255 (Vendor specific), subclass 93 and protocol 1, instead of
specifying the device ids individually. As the class is vendor-specific,
we have to still match against vendor id as well, though.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Signed-off-by: Tobias Mueller <Tobias_Mueller@twam.info>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com>
Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com>
Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com>
Signed-off-by: Lars Munch <lars@segv.dk>
Add support for the touchscreen controllers provided by Wolfson
Microelectronics WM97xx series chips in both polled and streaming
modes.
These drivers have been maintained out of tree since 2003. During
that time the driver the primary maintainer was Liam Girdwood and
a number of people have made contributions including Dmitry Baryshkov,
Stanley Cai, Rodolfo Giometti, Russell King, Marc Kleine-Budde,
Ian Molton, Vincent Sanders, Andrew Zabolotny, Graeme Gregory,
Mike Arthur and myself. Apologies to anyone I have omitted.
This updates the ads7846 driver to handle external vREF (required
on boards using ads7843 chips) without module parameters, and also
removes a needless variable with its associated bogus gcc warning.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Enables the Sharp Zaurus Collie and Poodle devices to be turned off
by pressing the "Cancel" button for a few seconds (as designed by
Sharp).
Additional small cleanups:
- removal of unused #defines and variables
- add missing __devinit/__devexit/__devinitconst annotations
- reorganized copyright notice
Signed-off-by: Helge Deller <deller@gmx.de>
Everyone should be using input_{get|set}_drvdata() by now.
Alias them to dev_{get|set}_drvdata() and remove ->private.
Recent driver core change causes references to parent devices being
dropped early, at device_del() time, as opposed to when all children
are freed. This causes oops in evdev with grabbed devices. Take the
reference to the parent input device ourselves to ensure that it
stays around long enough.
for-linus
When getting disconnected we need to release eventual grabs on the
underlying input device as we also release the input device itself.
Otherwise, we would try to release the grab when the client that
requested it closes its handle, accessing the input device which
might already be freed.
Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: fix for non-coherent DMA PowerPC
drm: radeon: fix sparse integer as NULL pointer warnings in radeon_mem.c
drm/i915: fix oops on agp=off
drm/r300: fix bug in r300 userspace hardware wait emission
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: ATA_EHI_LPM should be ATA_EH_LPM
pata_sil680: only enable MMIO on Cell blades
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6:
ide: fix defining SUPPORT_VLB_SYNC
Revert "ide: change master/slave IDENTIFY order"
a) every bitwise declaration will give a unique type; use typedefs.
b) no need to bother with the stuff pointed to by iomem pointers,
unless it's accessed directly. noderef will force us to use helpers
anyway.
NB: remaining endianness warnings in the file are, AFAICS, real bugs.
aka if you see a force-cast, be very suspicious...
Acked-and-tested-by: Frank Seidel <fseidel@suse.de>
Acked-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch fixes bits of the DRM so to make the radeon DRI work on
non-cache coherent PCI DMA variants of the PowerPC processors.
It moves the few places that needs change to wrappers to that
other architectures with similar issues can easily add their
own changes to those wrappers, at least until we have more useful
generic kernel API.
Cc: "Luck, Tony" <tony.luck@intel.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
drivers/char/drm/radeon_mem.c:91:23: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:116:28: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:124:28: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:177:26: warning: Using plain integer as NULL pointer
drivers/char/drm/radeon_mem.c:177:53: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
From Kernel BZ 10289 - not sure why anyone would boot an intel with no agp
but it shouldn't crash.
This interface was originally designed wrong, confusing bit-fields and
integers, major brown paper bag going back many years...
But userspace only ever used 4 values so fix the interface for new
users and fix the implementation to deal with the 4 values userspace
has ever emitted (0x1, 0x2, 0x3, 0x6).
This reverts commit b140b99c413ce410197cfcd4014e757cd745226a.
[ conflict in drivers/ide/ide-probe.c fixed manually ]
It turned out that probing order change causes problems for some drives:
http://bugzilla.kernel.org/show_bug.cgi?id=10239
Since root causes are still being investigated and are unlikely to be fixed
before 2.6.25 lets revert this change for now. As a result cable detection
becomes less reliable when compared with 2.6.24 but the affected drives are
useable again.
Reported-by: Richard Genoud <richard.genoud@gmail.com>
Bisected-by: Richard Genoud <richard.genoud@gmail.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
EH actions are ATA_EH_* not ATA_EHI_*. Rename ATA_EHI_LPM to
ATA_EH_LPM.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
There have been reported regressions of the SIL 680 driver when using MMIO, so
this makes it only try MMIO on Cell blades where it's known to be necessary
(the host bridge doesn't do PIO on these).
We'll try to find the root problem with MMIO separately.
Acked-by: Alan Cox <alan@redhat.com>
The Coverity checker spotted that we leak the storage allocated to 'name' in
int driver_add_kobj(). The leak looks legit to me - this is the code :
int driver_add_kobj(struct device_driver *drv, struct kobject *kobj,
const char *fmt, ...)
va_list args;
char *name;
int ret;
va_start(args, fmt);
name = kvasprintf(GFP_KERNEL, fmt, args);
^^^^^^^^ This dynamically allocates space...
va_end(args);
if (!name)
return -ENOMEM;
return kobject_add(kobj, &drv->p->kobj, "%s", name);
^^^^^^^^ This neglects to free the space allocated
Inside kobject_add() a copy of 'name' will be made and used. As far as I can
see, Coverity is correct in flagging this as a leak, but I'd like some
configmation before the patch is applied.
This should fix it.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
