path: root/drivers
2005-09-08[PATCH] USB ftdi_sio: New IDs for ELV, Xsens and Falcom productsIan Abbott
This patch for the ftdi_sio driver adds a bunch of new devices and fixes an incorrect PID: o Fix PID for ELV UO100 (the PID was in fact for ELV UR100). o Add PID ELV UR100 (see above) and ELV ALC 8500 Expert. o Add a whole bunch of other PIDs for ELV USB devices, commented out for now as they may be used by other drivers eventually. (Christian Abt of ELV.de submitted a full list of devices including an indication of which set of drivers are used by default in the MS Windows world. We decided to comment out the devices that use FTDI's D2XX Windows drivers by default.) o Add PIDs for eight devices from Xsens Technologies BV (submitted in a patch against 2.6.12.2 by Patrick Riphagen). o Add PID for Falcom Samba GPRS modem (submitted by Sebastian Schubert). Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB ftdi_sio: user specified VID/PIDIan Abbott
ftdi_sio: Support one user specified vendor and product ID via a couple of new module parameters. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: pl2303 driver, makes pl2303HX chip work correctlyDariusz M
This trivial patch makes pl2303 driver work correctly with pl2303HX chip. Apparently some bug in HX version of pl2303 makes the chip loose some transmitted bytes or stop working at all after reception of USB_REQ_CLEAR_FEATURE mesage. Logs generated by UsbSnoop application reveal that windows driver does not send this type of messages to the converter. From: "Dariusz M." <D.Marcinkiewicz@elka.pw.edu.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: fix keyspan_remote endian bug on probeGreg Kroah-Hartman
2005-09-08[PATCH] USB: Gadget library: centralize gadget controller numbersDavid Brownell
This patch centralizes the assignment of bcdDevice numbers for different gadget controllers. This won't improve the object code at all, but it does save a lot of repetitive and error-prone source code ... and will simplify the work of supporting a new controller driver, since most new gadget drivers will no longer need patches (unless some hardware quirks limit USB protocol messaging). Added minor cleanups and identifer hooks for the UDC in the Freescale iMX series processors. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: drivers/serial/usb-serial: Remove unneeded void * castsTobias Klauser
The following patch removes unneeded casts for the following (void *) pointers: - tty_struct->driver_data - void *private argument of usb_serial_port_softint() Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: option card driver coding style tweaksAndrew Morton
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: whitespace fixes for cypress_m8 driverLonnie Mendez
Reading this driver I noticed some trailing whitespaces and tabs so I removed them with some 80th column fitting and a few more similar things. From: Carlo Perassi <carlo@linux.it> Signed-off-by: Lonnie Mendez <dignome@gmail.com> Signed-off-by: Carlo Perassi <carlo@linux.it> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08Merge branch 'upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
2005-09-08[PATCH] scan all enabled ports on ata_piixHannes Reinecke
ICH6 spec defines the PORT_ bits as: PORT_ENABLED (R/W): 0 = Disabled. The port is in the off state and cannot detect any devices. 1 = Enabled. The port can transition between the on, partial, and slumber states and can detect devices. PORT_PRESENT (R/O) The status of this bit may change at any time. This bit is cleared when the port is disabled via PORT_ENABLED. This bit is not cleared upon surprise removal of a device. So from a textual view it is not necessary that PORT_PRESENT _must_ be set, especially if a device detection has to be done anyway. And, in fact, this is the view that ACER has been taken with its new Laptops (e.g. Travelmate 4150). And the definition of PORT_ENABLED / PORT_PRESENT is mixed up, btw. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Jens Axboe <axboe@suse.de> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-08Merge /spare/repo/linux-2.6/ Jeff Garzik
2005-09-08Merge linux-2.6 with linux-acpi-2.6Len Brown
2005-09-07[SCSI] Re-do "final klist fixes"Linus Torvalds
With the previous commit that introduces the klist enhancements, we can now re-do 2b7d6a8cb9718fc1d9e826201b64909c44a915f4 again.
2005-09-07[PATCH] fix klist semantics for lists which have elements removed on traversalJames Bottomley
The problem is that klists claim to provide semantics for safe traversal of lists which are being modified. The failure case is when traversal of a list causes element removal (a fairly common case). The issue is that although the list node is refcounted, if it is embedded in an object (which is universally the case), then the object will be freed regardless of the klist refcount leading to slab corruption because the klist iterator refers to the prior element to get the next. The solution is to make the klist take and release references to the embedding object meaning that the embedding object won't be released until the list relinquishes the reference to it. (akpm: fast-track this because it's needed for the 2.6.13 scsi merge) Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[SCSI] Revert "final klist fixes"Linus Torvalds
Revert commit 2b7d6a8cb9718fc1d9e826201b64909c44a915f4. The "fix" was known to not even compile. Duh. That's not a fix. That's just stupid. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sata_sis: Add support for SiS182 chipsetArnaud Patard
This patch adds support for the SiS182 sata chipset. This is a minimalistic version of the patch from http://bugme.osdl.org/show_bug.cgi?id=4192. Basically, it add the PCI IDs and handles the change of the 2nd port adress register. Signed-Off-By: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-07Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6 Linus Torvalds
2005-09-07Merge branch 'drm-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/airlied/drm-2.6
2005-09-07Merge branch 'upstream' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-09-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Linus Torvalds
2005-09-07[PATCH] bogus #if (ncr53c406)viro@ZenIV.linux.org.uk
2005-09-07[PATCH] bogus #if (smc91x.h)viro@ZenIV.linux.org.uk
2005-09-07[PATCH] -Wundef fixes (hisax)viro@ZenIV.linux.org.uk
CARD_... in hisax are all used with #if; CARD_FN_ENTERNOW_PCI lacks define to 0 if corresponding config option is not set. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] -Wundef fixes (ncr5380)viro@ZenIV.linux.org.uk
NDEBUG and NDEBUG_ABORT are almost always used as integers in NCR5380; added define to 0 if they are not defined, switched lone ifdef NDEBUG into if. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] -Wundef fixes (hamachi)viro@ZenIV.linux.org.uk
All uses of ADDRLEN are comparisons with 64 (it's an address width). added define to 32 (again, we only care about comparisons with 64) if not defined. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Kconfig fix (BLK_DEV_FD dependencies)viro@ZenIV.linux.org.uk
Sanitized and fixed floppy dependencies: split the messy dependencies for BLK_DEV_FD by introducing a new symbol (ARCH_MAY_HAVE_PC_FDC), making BLK_DEV_FD depend on that one and taking declarations of ARCH_MAY_HAVE_PC_FDC to arch/*/Kconfig. While we are at it, fixed several obvious cases when BLK_DEV_FD should have been excluded (architectures lacking asm/floppy.h are *not* going to have floppy.c compile, let alone work). If you can come up with better name for that ("this architecture might have working PC-compatible floppy disk controller"), you are more than welcome - just s/ARCH_MAY_HAVE_PC_FDC/your_prefered_name/g in the patch below... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] s2io u64 use for uintptr_tviro@zenIV.linux.org.uk
u64 is not uintptr_t; unsigned long is... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07Merge master.kernel.org:/home/rmk/linux-2.6-serial Linus Torvalds
2005-09-07[PATCH] DVB: lgdt330x check callback fixMichael Krufky
Most of the patch is whitespace cleanup, but more importantly, this patch checks to see whether a callback is set before calling it. On cx88 boards (currently the only boards using lgdt330x in 2.6.13) every callback is set. However, newer drivers currently in development leave a callback undefined, and lgdt330x must not call it if it isn't defined. Signed-off-by: Patrick Boettcher <pb@linuxtv.org> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] DVB: Clarify description text for dvb-bt8xx in KconfigMichael Krufky
Patrick Keene wrote to the linux-dvb list, asking where in menuconfig he can enable dvb-bt8xx for his AVerMedia DVB card. I pointed the following out to him: config DVB_BT8XX tristate "Nebula/Pinnacle PCTV/Twinhan PCI cards" It has been agreed upon that this description is extremely misleading. This patch changes the one-liner description text of dvb-bt8xx to something more meaningful, and adds AVerMedia to the detailed description. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Indycam / VINO driversRalf Baechle
Rewrite of the Indycam / VINO video v4l2 drivers for the SGI Indy. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Mikael Nousiainen <tmnousia@cc.hut.fi> Cc: <video4linux-list@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Fix smsc_ircc_init return valueBrice Goglin
I noticed a strange return value in smsc_ircc_init in drivers/net/irda/smsc_ircc2.c in rc4-mm1. When reaching the line "if (ircc_fir > 0 && ircc_sir > 0)", ret is 0. So I don't see the point of setting it to 0 in the "else" case. >From what I see in 2.6.12 it should probably be set to -ENODEV at the begining of the "else" case. The attached patch does this. Note that I didn't actually see any breakage caused by this. Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Cc: Dmitry Torokhov <dtor_core@ameritech.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: dont use void * where specific type will doDmitry Torokhov
IRDA: smsc-ircc2 - do not over-use void * pointers, use specific types wherever possible. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: use netdev_priv()Dmitry Torokhov
IRDA: smsc-ircc2 - use netdev_priv() instead of accessing pointer directly. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: add to sysfs as platform device, new PMDmitry Torokhov
IRDA: smsc-ircc2 - add sysfs support (platform device and driver) and switch power management to the new scheme. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: dont pass iobase aroundDmitry Torokhov
IRDA: smsc-ircc2 - cleanup - do not pass around iobase, it can be retrieved from smsc_ircc_cb structure. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: remove typedefsDmitry Torokhov
IRDA: smsc-ircc2 - remove excessive typedefs. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: drop DIM macro in favor of ARRAY_SIZEDmitry Torokhov
IRDA: smsc-ircc2 - remove home-grown DIM macro, use ARRAY_SIZE intead. Also fix out-of-bound array access. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: formatting fixesDmitry Torokhov
IRDA: smsc-ircc2 - some formatting changes for better readability. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] smsc-ircc2: whitespace fixesDmitry Torokhov
IRDA: smsc-ircc2 - whitespace fixes. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Input: Add a new switch event typeRichard Purdie
The corgi keyboard has need of a switch event type with slightly type to the input system as recommended by the input maintainer. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] w100fb: Update corgi platform code to match new driverRichard Purdie
This patch moves the platform specific Sharp SL-C7x0 LCD code from the w100fb driver into a more appropriate place and updates the Corgi code to match the new w100fb driver. It also updates the corgi touchscreen code to match the new simplified interface available from w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] w100fb: Rewrite for platform independenceRichard Purdie
The code w100fb was based on was horribly Sharp SL-C7x0 specific and there was little else that could be done as I had no access to anything else with a w100 in it. There is no real documentation about this chipset available. Ian Molton has access to other platforms with the w100 (Toshiba e-series) and so between us, we've improved w100fb and made it platform independent. Ian Molton also added support for the very similar w3220 and w3200 chipsets. There are a lot of changes here and it nearly amounts to a rewrite of the driver but it has been extensively tested and is being used in preference to the original driver in the Zaurus community. I'd therefore like to update the mainline code to reflect this. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Corgi touchscreen: Fix a pmu bugRichard Purdie
Corgi Touchscreen bugfix. If the PMU isn't running, the register needs to be set to a sane value rather than reusing some random value. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Corgi Touchscreen: Code cleanup / fixesRichard Purdie
Clean up some Corgi Touchscreen logic and merge the repeat calls to w100fb_blanking() in anticipation of the w100fb patch. Fix a pm_message_t reference. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Corgi Touchscreen: Allow the driver to share the PMURichard Purdie
The Corgi Touchscreen driver uses the PMU as an accurate timing source which conflicts with its usage for performance monitoring. This patch allows it to be shared with other users such as oprofile. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Corgi Keyboard: Code tidyingRichard Purdie
The input system handles key state tracking so there's no need for the driver to do so as well. Also tidy up some comment formatting and remove a now unneeded function. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Corgi Keyboard: Add some power management codeRichard Purdie
Add some power management code to the corgi keyboard driver so that only one power event gets reported within any reasonable time frame and the driver doesn't enter an infinte loop due to key repeat. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
